  4. Beta Test Simulation auf der Basis von fullcalendar
    6.4k
21 Beiträge 10 Kommentatoren 3.9k Aufrufe 14 Beobachtet
  • M MDorf
    @andreas-k-0 said in Beta Test Simulation auf dem Basis von fullcalendar:
    Sekundenbruchteil "rot"
    Das geht mir leider auch so.
    Kann ich irgendwelche Loginfo's zur Verfügung stellen...?
    arteckA Offline
    arteckA Offline
    arteck
    @mdorf steht den was im LOG
    M 2 Antworten Letzte Antwort
    • arteckA arteck
      MDorf
      @arteck
      Simulation eingerichtet:
      Gestartet und dann die Lampe geschaltet.
      Fullkalender raucht ab...
      Log:
      2024-02-11 22:41:21.692 - info: admin.0 (2641) ==> Connected system.user.admin from 2a00:6020:43cd:bd00:5d21:966e:d2b2:80a9
      2024-02-11 22:44:00.144 - error: fullcalendar.0 (116191) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2024-02-11 22:44:00.147 - error: fullcalendar.0 (116191) unhandled promise rejection: Cannot read properties of null (reading '_id')
      2024-02-11 22:44:00.155 - error: fullcalendar.0 (116191) TypeError: Cannot read properties of null (reading '_id')
      at getImage (/opt/iobroker/node_modules/iobroker.fullcalendar/main.js:200:29)
      at AdapterClass. (/opt/iobroker/node_modules/iobroker.fullcalendar/main.js:412:36)
      2024-02-11 22:44:00.157 - error: fullcalendar.0 (116191) Cannot read properties of null (reading '_id')
      2024-02-11 22:44:00.193 - info: fullcalendar.0 (116191) terminating
      2024-02-11 22:44:00.195 - warn: fullcalendar.0 (116191) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2024-02-11 22:44:00.698 - info: fullcalendar.0 (116191) terminating
      2024-02-11 22:44:00.793 - error: host.smarthomepi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2024-02-11 22:44:00.794 - error: host.smarthomepi Caught by controller[1]: TypeError: Cannot read properties of null (reading '_id')
      2024-02-11 22:44:00.794 - error: host.smarthomepi Caught by controller[1]: at getImage (/opt/iobroker/node_modules/iobroker.fullcalendar/main.js:200:29)
      2024-02-11 22:44:00.795 - error: host.smarthomepi Caught by controller[1]: at AdapterClass. (/opt/iobroker/node_modules/iobroker.fullcalendar/main.js:412:36)
      2024-02-11 22:44:00.795 - error: host.smarthomepi instance system.adapter.fullcalendar.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2024-02-11 22:44:00.795 - info: host.smarthomepi Restart adapter system.adapter.fullcalendar.0 because enabled
      2024-02-11 22:44:30.921 - info: host.smarthomepi instance system.adapter.fullcalendar.0 started with pid 116742
      2024-02-11 22:44:33.250 - info: fullcalendar.0 (116742) starting. Version 2.3.4 in /opt/iobroker/node_modules/iobroker.fullcalendar, node: v18.17.1, js-controller: 5.0.17
      • arteckA arteck
        MDorf
        @arteck
        Wäre Klasse wenn du was fixen könntest! Der Adapter wäre sonst sehr genial...:-)
        • M MDorf
          @arteck
          Log:
          @mdorf sagte in Beta Test Simulation auf dem Basis von fullcalendar:
          node: v18.17.1
          Offenbar hängst du noch auf dem obsoleten Repo. Stell das um:
          iob stop
          iob fix
          iob nodejs-update
            node: v18.17.1
            iob stop
            iob fix
            iob nodejs-update
            MDorf
            Versuch war's wert...es wurde auch aktualisiert, allerdings besteht das Problem noch:
            2024-02-11 23:18:33.749 - info: admin.0 (121751) ==> Connected system.user.admin from 2a00:6020:43cd:bd00:5d21:966e:d2b2:80a9
            2024-02-11 23:19:06.642 - info: admin.0 (121751) <== Disconnect system.user.admin from 2a00:6020:43cd:bd00:5d21:966e:d2b2:80a9 fullcalendar
            2024-02-11 23:19:12.677 - error: fullcalendar.0 (122758) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2024-02-11 23:19:12.678 - error: fullcalendar.0 (122758) unhandled promise rejection: Cannot read properties of null (reading '_id')
            2024-02-11 23:19:12.684 - error: fullcalendar.0 (122758) TypeError: Cannot read properties of null (reading '_id')
            2024-02-11 23:19:12.685 - error: fullcalendar.0 (122758) Cannot read properties of null (reading '_id')
            2024-02-11 23:19:12.711 - info: fullcalendar.0 (122758) terminating
            2024-02-11 23:19:12.713 - warn: fullcalendar.0 (122758) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2024-02-11 23:19:13.215 - info: fullcalendar.0 (122758) terminating
            2024-02-11 23:19:13.307 - error: host.smarthomepi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-02-11 23:19:13.308 - error: host.smarthomepi Caught by controller[1]: TypeError: Cannot read properties of null (reading '_id')
            2024-02-11 23:19:13.308 - error: host.smarthomepi Caught by controller[1]: at getImage (/opt/iobroker/node_modules/iobroker.fullcalendar/main.js:200:29)
            2024-02-11 23:19:13.308 - error: host.smarthomepi Caught by controller[1]: at AdapterClass. (/opt/iobroker/node_modules/iobroker.fullcalendar/main.js:412:36)
            2024-02-11 23:19:13.309 - error: host.smarthomepi instance system.adapter.fullcalendar.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2024-02-11 23:19:13.309 - info: host.smarthomepi Restart adapter system.adapter.fullcalendar.0 because enabled
            • M MDorf
              RandyAndy
              Das kann ich nur bestätigen.
              • Andreas K 0A Andreas K 0
                ich kann keine Simulation starten. Der Knopf wird nur für einen Sekundenbruchteil "rot" und dann war es das. Was könnte das sein? Was kann ich an weiteren Infos zur Verfügung stellen?`
                Andreas
                RandyAndy
                schrieb am zuletzt editiert von RandyAndy
                Es gibt zwar in der beta eine neue Version, aber die Simulations-Aufzeichnung lässt sich leider immer noch nicht starten.
                Diese Funktion wäre aber eigentlich der Schritt zu einer realistischen Simulation.
                Andreas
                • BluefoxB Bluefox
                  Aktuelle Test Version 2.1.0
                  Veröffentlichungsdatum 24.04.2023
                  Github Link https://github.com/ioBroker/ioBroker.fullcalendar
                  Auf der Basis von fullcalendar wurde die lang-erwartetete Funktionalität von Präsenzsimulation entwickelt.
                  Es funktioniert folgendermaßen:
                  • Erst muss man sein Verhältnis aufnehmen (ein Tag oder eine Woche). Dabei muss man einzelne Zustände oder Kategorien selektieren. Die Aufnahme haltet sich automatisch an.
                  • Nach der Aufnahme: Falsche/Unnötige Ereignisse löschen, falls vorhanden
                  • Die aufgenommenene Ereignisse abspielen lassen. Dabei kann man definieren am welchen Wochentag, ab Wann und bis Wann die Ereignisse abgespielt werden müssen.
                  Es ist so, dass die Funktionalität ist noch nicht finalisiert, da noch zu wenig Live-Tests gemacht wurde. Aber ich würde mich freuen über Vorschläge und Verbesserungen.
                  Z.B. Es ist noch nicht klar, sollten alle Zustände am Ende von der Abspielen auf "false/0" gesetzt werden? Oder sollte alle Zustandswerte bei Aufnahmestart gespeichert werden und dann am Ende von Abspielen wiederherstellt werden....
                  RandyAndy
                  @bluefox
                  Es scheint so, dass die Simulation immer noch nicht richtig gestartet werden kann.
                  Allerdings habe ich es nun mit einem Workaround hingebracht.
                  Erst den Adapter stoppen, dann Simulation aufzeichenen starten und dann den Adpater wieder starten. Dann scheint er aufzuzeichnen.
                  Ich beobachte das mal.
                  O 123brokerei1 2 Antworten Letzte Antwort
                  • R RandyAndy
                    @bluefox
                    O Offline
                    O Offline
                    oFbEQnpoLKKl6mbY5e13
                    Erstellt doch bitte ein Issue dazu im Adapter-Repo:
                    https://github.com/ioBroker/ioBroker.fullcalendar/issues
                    R 1 Antwort Letzte Antwort
                    • O oFbEQnpoLKKl6mbY5e13
                      RandyAndy
                      @ofbeqnpolkkl6mby5e13
                      Habe ich soeben gemacht. Und es scheint so, dass Event aufgezeichent werden die gar nicht vorhanden sind auch an Tagen die noch gar nicht erreicht sind. So habe ich am Montag den 15. April plötzlich auch events für Dienstag den 16. April.
                      Da stimmt noch etwas in der Summe nicht.
                      • BluefoxB Bluefox
                        RandyAndy
                        @bluefox
                        Und noch ein Frage. Wie kann ich eigentlich einzelne Simulationen oder Kalender deaktivieren bzw. wieder aktivieren.
                        Derzeit kann ich eigentlich nur immer den gesamten Adapter an und ausschalten, das ist aber nicht wirklich zielführend.
                        Vielleicht sehe ich es nur nicht
                        Andreas
                        • R RandyAndy
                          @bluefox
                          123brokerei1 Offline
                          123brokerei
                          @randyandy
                          @Bluefox
                          Bei mir leider auch genau das gleiche Verhalten. Habe die 2.3.17 installiert.
                          123brokerei1 BluefoxB 2 Antworten Letzte Antwort
                          • 123brokerei1 123brokerei
                            @randyandy
                            @Bluefox
                            123brokerei
                            Was mir noch aufgefallen ist... kann es sein, dass der Adapter einen String als true/false sendet?
                            Das macht die Interpretation etwas komplizierter bzw. verursacht in meinen blocklys Warnungen.
                            BluefoxB 1 Antwort Letzte Antwort
                              @randyandy
                              @Bluefox
                              BluefoxB Offline
                              BluefoxB Offline
                              @123brokerei Bitte hier kommentieren https://github.com/ioBroker/ioBroker.fullcalendar/issues/234
                                BluefoxB Offline
                                BluefoxB Offline
                                @123brokerei Kannst du bitte ein issue öffnen. Es ist für mich nicht klar welche Zustände geschrieben werden
                                • BluefoxB Bluefox
                                  Alero
                                  @bluefox
                                  hi,
                                  ich versuche den Full Kalender auch für eine Abwesenheitssimulation zu nutzen.
                                  Ich kann sie anlegen, Bei Zustände bekomme ich die Möglichkeit diese auszuwählen. Nur bei den Kategorien bekomme ich, wenn ich drauf klicke, einen weißen Bildschirm anstatt die die Kategorien wie z.B. Beleuchtung wo ich alle meine Shellys reingepackt habe. Was mache ich falsch?
