  4. Test Adapter Zendure Solarflow
2.7k Beiträge 129 Kommentatoren 1.4m Aufrufe 128 Beobachtet
  • nograxN nograx
    @xbit sagte in Test Adapter Zendure Solarflow:
    @nograx
    Servus,
    hatte heute Morgen einen Restart Loop vom Adapter hier mal die log falls es hilft.
    2024-04-11 06:28:02.984  - error: zendure-solarflow.0 (792622) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-04-11 06:28:02.985  - error: zendure-solarflow.0 (792622) unhandled promise rejection: Unexpected token ~ in JSON at position 0
    2024-04-11 06:28:02.986  - error: zendure-solarflow.0 (792622) SyntaxError: Unexpected token ~ in JSON at position 0
       at JSON.parse (<anonymous>)
       at MqttClient.onMessage (/opt/iobroker/node_modules/iobroker.zendure-solarflow/build/services/mqttService.js:164:22)
       at MqttClient.emit (node:events:517:28)
       at handlePublish (/opt/iobroker/node_modules/mqtt/build/lib/handlers/publish.js:97:20)
       at handle (/opt/iobroker/node_modules/mqtt/build/lib/handlers/index.js:28:35)
       at work (/opt/iobroker/node_modules/mqtt/build/lib/client.js:227:40)
       at writable._write (/opt/iobroker/node_modules/mqtt/build/lib/client.js:252:13)
       at writeOrBuffer (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/internal/streams/writable.js:334:12)
       at _write (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/internal/streams/writable.js:283:10)
       at Writable.write (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/internal/streams/writable.js:286:10)
    2024-04-11 06:28:02.986  - error: zendure-solarflow.0 (792622) Unexpected token ~ in JSON at position 0
    2024-04-11 06:28:02.988  - info: zendure-solarflow.0 (792622) terminating
    2024-04-11 06:28:02.988  - warn: zendure-solarflow.0 (792622) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-04-11 06:28:03.204  - error: zendure-solarflow.0 (792622) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-04-11 06:28:03.205  - error: zendure-solarflow.0 (792622) unhandled promise rejection: Unexpected token ~ in JSON at position 0
    2024-04-11 06:28:03.205  - error: zendure-solarflow.0 (792622) SyntaxError: Unexpected token ~ in JSON at position 0
    2024-04-11 06:28:03.205  - error: zendure-solarflow.0 (792622) Unexpected token ~ in JSON at position 0
    2024-04-11 06:28:03.437  - error: zendure-solarflow.0 (792622) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-04-11 06:28:03.437  - error: zendure-solarflow.0 (792622) unhandled promise rejection: Unexpected token ~ in JSON at position 0
    2024-04-11 06:28:03.437  - error: zendure-solarflow.0 (792622) SyntaxError: Unexpected token ~ in JSON at position 0
    2024-04-11 06:28:03.438  - error: zendure-solarflow.0 (792622) Unexpected token ~ in JSON at position 0
    2024-04-11 06:28:03.490  - info: zendure-solarflow.0 (792622) terminating
    2024-04-11 06:28:03.607  - error: host.IoBroker instance system.adapter.zendure-solarflow.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2024-04-11 06:28:03.608  - info: host.IoBroker Restart adapter system.adapter.zendure-solarflow.0 because enabled
    2024-04-11 06:28:33.747  - info: host.IoBroker instance system.adapter.zendure-solarflow.0 started with pid 902900
    2024-04-11 06:28:35.313  - info: zendure-solarflow.0 (902900) starting. Version 1.3.0 (non-npm: nograx/ioBroker.zendure-solarflow#81847e8e1eca738ab7336d7425f5b31911376ede) in /opt/iobroker/node_modules/iobroker.zendure-solarflow, node: v18.19.1, js-controller: 5.0.19
    2024-04-11 06:28:36.340  - info: zendure-solarflow.0 (902900) [login] Login to Zendure Rest API successful!
    2024-04-11 06:28:36.563  - info: zendure-solarflow.0 (902900) [onReady] Found 1 SolarFlow device(s).
    2024-04-11 06:28:36.670  - info: zendure-solarflow.0 (902900) [onConnected] Connected with MQTT!
    2024-04-11 06:28:36.815  - error: zendure-solarflow.0 (902900) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-04-11 06:28:36.815  - error: zendure-solarflow.0 (902900) unhandled promise rejection: Unexpected token ~ in JSON at position 0
    2024-04-11 06:28:36.816  - error: zendure-solarflow.0 (902900) SyntaxError: Unexpected token ~ in JSON at position 0
    2024-04-11 06:28:36.816  - error: zendure-solarflow.0 (902900) Unexpected token ~ in JSON at position 0
    2024-04-11 06:28:36.820  - info: zendure-solarflow.0 (902900) terminating
    2024-04-11 06:28:36.821  - warn: zendure-solarflow.0 (902900) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-04-11 06:28:37.322  - info: zendure-solarflow.0 (902900) terminating
    2024-04-11 06:28:37.466  - error: host.IoBroker instance system.adapter.zendure-solarflow.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2024-04-11 06:28:37.466  - info: host.IoBroker Restart adapter system.adapter.zendure-solarflow.0 because enabled
    2024-04-11 06:29:07.576  - info: host.IoBroker instance system.adapter.zendure-solarflow.0 started with pid 902923
    2024-04-11 06:29:09.091  - info: zendure-solarflow.0 (902923) starting. Version 1.3.0 (non-npm: nograx/ioBroker.zendure-solarflow#81847e8e1eca738ab7336d7425f5b31911376ede) in /opt/iobroker/node_modules/iobroker.zendure-solarflow, node: v18.19.1, js-controller: 5.0.19
    2024-04-11 06:29:10.696  - info: zendure-solarflow.0 (902923) [login] Login to Zendure Rest API successful!
    2024-04-11 06:29:11.209  - info: zendure-solarflow.0 (902923) [onReady] Found 1 SolarFlow device(s).
    2024-04-11 06:29:11.355  - info: zendure-solarflow.0 (902923) [onConnected] Connected with MQTT!
    2024-04-11 06:29:47.712  - error: zendure-solarflow.0 (902923) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-04-11 06:29:47.713  - error: zendure-solarflow.0 (902923) unhandled promise rejection: Unexpected token ~ in JSON at position 0
    2024-04-11 06:29:47.713  - error: zendure-solarflow.0 (902923) SyntaxError: Unexpected token ~ in JSON at position 0
    2024-04-11 06:29:47.714  - error: zendure-solarflow.0 (902923) Unexpected token ~ in JSON at position 0
    2024-04-11 06:29:47.716  - info: zendure-solarflow.0 (902923) terminating
    2024-04-11 06:29:47.716  - warn: zendure-solarflow.0 (902923) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-04-11 06:29:48.217  - info: zendure-solarflow.0 (902923) terminating
    2024-04-11 06:29:48.326  - error: host.IoBroker instance system.adapter.zendure-solarflow.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2024-04-11 06:29:48.326  - info: host.IoBroker Restart adapter system.adapter.zendure-solarflow.0 because enabled
    2024-04-11 06:29:48.326  - warn: host.IoBroker Do not restart adapter system.adapter.zendure-solarflow.0 because restart loop detected
    Danke für die Info. Ist das Version 1.3.0? Ich könnte schwören das der Fehler mit der 1.4.0 aus dem Beta Kanal nicht mehr auftreten sollte...
    XBiTX Online
    XBiTX Online
    XBiT
    #257
    @nograx
    Okay Sorry bin noch auf 1.3.0 bin nicht im Beta Rep. hole mir bei bedarf immer von Git die Version... habe ich nur diesmal verschlafen nach einer neuen Version zu schauen.
    nograxN 1 Antwort Letzte Antwort
    • XBiTX XBiT
      @nograx
      nograxN Online
      nograxN Online
      nograx
      #258
      @nograx
      Hat ja auch seinen Sinn die Stable Version zu nutzen. Kann leider aufgrund eines Missverständnisses in der Adapter Konfig (trivial und beinträchtigt die Funktion nicht) kein Update im Stable Kanal veröffentlichen... :-/
      • nograxN Online
        nograxN Online
        nograx
        #259
        es ist eine neue Version verfügbar. Ich habe die Möglichkeit eingebaut im Zweifel auf den Developer MQTT Server zu wechseln, falls Zendure mal auf die Idee kommt uns vom App MQTT auszusperren. Das ist der MQTT Server der leider nur lesenden Zugriff gewährt.
        Gruß,
        Peter
        • nograxN nograx
          Gruß,
          Peter
          Rene55R Online
          Rene55R Online
          Rene55
          #260
          @nograx Hallo Peter, tolle Arbeit - aber bald brauche ich ein Handbuch, vor allem jetzt neu mit 'Zum Developer MQTT Server verbinden'
          Ich stolpere gerade über den Status hubState Stop output and shut down. Was meint Zendure damit? Akku ist bis zum Max-Wert voll und die Solarenergie geht ins Haus.
          • Rene55R Rene55
            nograxN Online
            nograxN Online
            nograx
            schrieb am zuletzt editiert von nograx
            #261
            @rene55 sagte in Test Adapter Zendure Solarflow:
            1. Um es kurz zu erklären: Der Adapter nutzt den Mqtt den auch die App nutzt, dazu war etwas Reverse Engineering möglich - und ich habe Sorge das Zendure das nicht ganz so toll findet, da sie ja für so einen Zugang extra den Deverloper mqtt bereit stellen. Damit ist aber keine Steuerung nötig. Sollte Zendure auf die Idee kommen den App mqtt umzubauen und für uns zu sperren, könnte man jetzt aber noch auf den „von Zendure gewünschten weg“ ausweichen…
            2. Damit ist gemeint das der Hub ausgeht wenn die entladegrenze erreicht ist. Alternativ kann er im Standby bleiben, zieht dann aber Strom aus den Akkus - was vermeintlich im Winter zu einigen kaputten Akkus geführt hat.
            • nograxN nograx
              Rene55R Online
              Rene55R Online
              Rene55
              #262
              @nograx Danke für die Aufklärung. Punkt 2 habe ich jetzt verstanden. Das Verhalten was ich so gesehen habe ist also richtig, der Shutdown erfolgt dann erst später - ok.
              Kann ich irgendwo nachlesen, was mit dem Developer-MQTT genau angedacht ist? Wollen wir mal hoffen, dass Zendure da nicht einen Riegel vorschiebt, da gerade die Steuerung (für mich) einen großen Vorteil bringt.
              Der Ausweg über die lokale BT-Auslesung bringt dann auch nichts, da der Zugriff ja auch nur lesend ist. Oder irre ich?
              • Rene55R Rene55
                nograxN Online
                nograxN Online
                nograx
                #263
                Die offizielle Doku findest du hier: https://github.com/Zendure/developer-device-data-report
                Wenn du den Hub mit dem Projekt von Reinhardt auf github offline nimmst kannst du den auch steuern.
                Ich hoffe natürlich auch das alles so bleibt, steuere meinen Hub ebenfalls mit dem Adapter. Will hier auch keine Panik verbreiten, nur vorbereitet sein für den Fall…
                D T 2 Antworten Letzte Antwort
                • nograxN nograx
                  diet99
                  schrieb am zuletzt editiert von diet99
                  #264
                  heute scheint der Adapter ziemlichen Müll aus der Cloud zu holen. Die App zeigt was ganz anderes an und diese Werte sind wesentlich realistischer.
                  Kann das jemand bestätigen, oder ist das nur bei mir so? Gestern war das auch schon seltsam. Da ging der Steuerbefehl irgendwie nicht durch bzw. mein ioBroker hat nicht mitbekommen, als die Akkus 30% erreicht hatten, und hat nicht zugeschaltet.
                  Laut Log sollte die Verbindung funktionieren:
                  • D diet99
                    diet99
                    #265
                    Möglicherweise spinnt mein Debian-System. Ich hab gerade mal ein update/upgrade gemacht und alles neu gestartet - im Moment sieht es wieder gut aus.
                    Seltsame Sache.
                    • MuppibaerM Muppibaer
                      @nograx Erstmal meinen dank für diesen jetzt schon tollen Adapter. Ich setze den Adapter mit einem Zendure AIO über den deutschen Account ein, und es funktioniert bisher alles .
                      Meine frage : Ist es normal das wenn im Control bereich eingaben getätigt werden diese zwar übernohmen werden , im Control bereich aber trotzdem rot ausgegeben werden. Ich kenne es nur so das Eingaben nach positiver Ausführung weiss (Bestätigt true ) ausgegeben werden (Siehe mein Beispiel mit 15 %)
                      The_Stig
                      #266
                      @muppibaer Genau das Problem habe ich mit dem Hub2000 auch. Es werden keine Änderungen in der App angezeigt und offensichtlich die Werte nicht aktualisiert.
                      • T The_Stig
                        diet99
                        #267
                        @the_stig Moin! Heute scheint es problemlos zu laufen, allerdings ist kaum Sonne, d.h. es gibt nicht allzuviele Veränderungen.
                        • D diet99
                          The_Stig
                          schrieb am zuletzt editiert von The_Stig
                          #268
                          @diet99 Aber du hast keinen Hub2000, oder? Ich befürchte, dass bei dem noch ein paar Sachen nicht rund laufen...oder ich verstehe noch was falsch, aber wenn ich was in der Zendure-App ändere, wirds nicht im Control-Bereich angezeigt...
                          • T The_Stig
                            The_Stig
                            #269
                            @nograx danke auf jeden Fall für den coolen Adapter. Eine Verständnisfrage noch: bei meinem Hub2000 tauchen einige Felder sowohl im Control-Folder wie auch im Folder des Hubs als solchem auf, z.B. im Control "zendure-solarflow.0.A8yh63.0W09SjQU.control.setOutputLimit" und im Folder des Hubs dann noch "zendure-solarflow.0.A8yh63.0W09SjQU.outputLimit". Die Werte sind aber unterschiedlich. Also ich kann den control.setOutputLimit auf 0 setzen und das "outputLimit" hat trotzdem einen anderen Wert, der dann auch über den Smart-CT-Modus stetig geändert wird (und offenbar scheint dieser Wert der relevante zu sein, da der Hub trotz gesetzter Null die Batterie entlädt). Wie hängt das zusammen?
                            • L lesiflo
                              @diet99 Das ist nicht nötig. Mit Blockly z.B. kannst du die selber und sogar wesentlich umfangreicher nachbauen.
                              So was z.B.
                              Außerdem gibt die API-Schnittstelle das nicht her.
                              The_Stig
                              #270
                              @lesiflo hänge hier auch seit ein paar Tagen daran, mein Setting optimal aufzubauen. Könntest du ggf. den Blockly-Code deiner Steuerung hier posten? Ich bin da in allem noch kompletter Anfänger und habe grad gelesen, dass man ja keinen Modus aus der ZEndure App nutzen soll. Dann fehlt mir aber die Steuerungsmöglichkeit ohne den Blockly-Code...Danke dir!
                              • T The_Stig
                                diet99
                                #271
                                @the_stig said in Test Adapter Zendure Solarflow:
                                Das Setzen des setOutputLimit macht natürlich nur Sinn, wenn man keinen Automatikmodus aktiv hat, weil der dann ggf. diesen Wert direkt wieder ändert. Die Steuerung muß dann über ein Script erfolgen oder man hat einen Wechselrichter, den man über ioBroker oder OpenDTU steuern kann.
                                • D diet99
                                  The_Stig
                                  #272
                                  @diet99 Danke dir erneut... du hilfst mir ja auch schon fleissig im Chat. Ok...dann bin ich jedenfalls einen Schritt weiter. Jetzt muss ich mir dann "nur" die Steuerung von Lesiflo nachbauen. Bei mir sind es ja 4 Module am Zendure und noch 2 weitere direkt in den WR. Da möchte ich keine Energie verschenken. Überlege gerade noch, welche Steuerungsmethode da die beste ist. Wenn ich den WR beschränke, werden ja ggf. die direkt angeschlossenen Module mit gedrosselt. Das will ich eigentlich gerne vermeiden. Aber wenn ich den nicht drossele, muss ich wieder über die Zendure-Smart-CT-Regelung gehen...alles nicht so einfach...
                                  L 1 Antwort Letzte Antwort
                                  • T The_Stig
                                    lesiflo
                                    schrieb am zuletzt editiert von lesiflo
                                    #273
                                    @the_stig Hi, ich bin da gerade auch etwas am "basteln". Das was ich vorhabe klappt nicht so richtig. Ich habe einen Shelly 3EM im Einsatz und einen Deye WR. Da ich noch eine große Anlage für Verbrauch und Einspeisung habe nutze ich das BKW nur zum Speichern. Eigentlich soll der zuerst der Speicher voll gemacht werden und wenn das erfolgt ist soll dann Abends bei Sonnenuntergang die Anlage vom Akku einspeisen. Damit das klappt habe ich am Ausgang des WR einen Shelly zwischengebaut der dann den Strom ins Netzt freigibt. Ansonsten ist der aus. Das Problem hierbei ist das der Bypass im Automatic Modus nicht zusammen mit einen Energieplan funktioniert. Hierbei hängt sich dann immer der WR. Erst nachdem ich die Verbindung zwischen dem WR und den Hub trenne und verbinde klappt das. Meine Blockly's kann ich dir aber gerne geben,
                                    Hier alles was ich so habe. Am besten komplett importieren und ziehe dir dann das raus was du brauchst.
                                    Solarflow.txt
                                    • L Offline
                                      lesiflo
                                      #274
                                      Gelöscht
                                      • L lesiflo
                                        Solarflow.txt
                                        The_Stig
                                        #275
                                        @lesiflo Wow . danke dir. Ich schaue mir das alles an und berichte dann!
                                        • T The_Stig
                                          lesiflo
                                          #276
                                          @the_stig Wie ist denn dein Aufbau mit den 6 Panels? Welche Ausrichtung? Parallel oder in Reihe?
                                          Kannst du nicht mit beiden Panels am WR deine Grundlast abdecken?
                                          Das mit dem Umschalten des Bypass-Modus hatte ich auch schon versucht. Hat leider nicht geklappt.
                                          Hast du einen Shelly 3EM? Wenn ja kannst du das damit regeln. Alles was kleiner ist als 400W und nicht über die
                                          die beiden Panels am WR abgedeckt werden kann kommt dann aus dem Hub. Um zu wissen was bei dir möglich ist müsste man wissen was du an Technik noch verbaut hast.
