  4. javascript startet nicht mehr
28 Beiträge 3 Kommentatoren 3.4k Aufrufe 3 Beobachtet
  • rtwlR rtwl
    okay danke. das beruhigt.
    kannst du hier in der aktuellen langfassung von iob diag erkennen, ob es noch weitere Baustellen gibt? Es tauchen nämlich noch ein paar "npm errors" auf:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: smarthome
           Icon name: computer
              Kernel: Linux 6.6.20+rpt-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     21:50:13 up 10:01,  2 users,  load average: 0.69, 0.84, 1.03
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2024-04-07 21:50:14 CEST
               Universal time: Sun 2024-04-07 19:50:14 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    rtwl
    /home/rtwl
    rtwl adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            4.0G        2.5G        1.1G        1.2M        533M        1.5G
    Swap:           104M          0B        104M
    Total:          4.1G        2.5G        1.2G
             3792 M total memory
             2356 M used memory
             2349 M active memory
              307 M inactive memory
             1003 M free memory
               70 M buffer memory
              438 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  379M   1% /run
    /dev/mmcblk0p2 ext4       15G  7.7G  5.8G  58% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   63M  448M  13% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Sun Apr  7 11:48:28 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:75:F7:C5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=baa0be65-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Apr  7 11:48:30 2024] EXT4-fs (mmcblk0p2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
    [Sun Apr  7 11:48:32 2024] EXT4-fs (mmcblk0p2): re-mounted 3b614a3f-4a65-4480-876a-8a998e01ac9b r/w. Quota mode: none.
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    609M    /var/
    203M    /var/cache
    197M    /var/cache/apt
    164M    /var/lib
    141M    /var/log/journal/347b9e5236b042cab12c17eb2f4c9517
    Archived and active journals take up 140.1M in the file system.
    /opt/iobroker/backups:
    1.6G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.4G    /opt/iobroker/iobroker-data/
    968M    /opt/iobroker/iobroker-data/history
    233M    /opt/iobroker/iobroker-data/files
    99M     /opt/iobroker/iobroker-data/backup-objects
    58M     /opt/iobroker/iobroker-data/files/javascript.admin
    38M     /opt/iobroker/iobroker-data/states.jsonl
    38M     /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230804163324-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.1
    /usr/bin/node           v18.20.1
    /usr/bin/npm            10.5.0
    /usr/bin/npx            10.5.0
    /usr/bin/corepack       0.25.2
    nodejs:
      Installed: 18.20.1-1nodesource1
      Candidate: 18.20.1-1nodesource1
      Version table:
     *** 18.20.1-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.20.0-1nodesource1 500
         18.19.1-1nodesource1 500
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
         18.19.0-1nodesource1 500
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @abandonware/bluetooth-hci-socket@0.5.3-10 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
    npm ERR! extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
    npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
    npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
    npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
    npm ERR! extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
    npm ERR! extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
    npm ERR! extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
    npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
    npm ERR! extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
    npm ERR! extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
    npm ERR! extraneous: detect-libc@2.0.2 /opt/iobroker/node_modules/detect-libc
    npm ERR! extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
    npm ERR! extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
    npm ERR! extraneous: node-addon-api@4.3.0 /opt/iobroker/node_modules/node-addon-api
    npm ERR! extraneous: node-gyp-build@4.7.1 /opt/iobroker/node_modules/node-gyp-build
    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
    npm ERR! extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
    npm ERR! extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
    npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
    npm ERR! extraneous: set-blocking@2.0.0 /opt/iobroker/node_modules/set-blocking
    npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
    npm ERR! extraneous: usb@1.9.2 /opt/iobroker/node_modules/usb
    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
    npm ERR! extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
    npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/debug
    npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/ms
    npm ERR! extraneous: agent-base@6.0.2 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/agent-base
    npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/debug
    npm ERR! extraneous: https-proxy-agent@5.0.1 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/https-proxy-agent
    npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/ms
    npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
    npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
    npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
    npm ERR! invalid: form-data@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data
    npm ERR! A complete log of this run can be found in: /home/rtwl/.npm/_logs/2024-04-07T19_50_23_555Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.13.16
    javascript:     8.0.0
    Adapters from github:   3
    Adapter State
    + system.adapter.admin.0                  : admin                 : smarthome                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : smarthome                                -  enabled
    + system.adapter.alexa2.0                 : alexa2                : smarthome                                -  enabled
      system.adapter.alias-manager.0          : alias-manager         : smarthome                                - disabled
    + system.adapter.backitup.0               : backitup              : smarthome                                -  enabled
    + system.adapter.bring.0                  : bring                 : smarthome                                -  enabled
    + system.adapter.cloud.0                  : cloud                 : smarthome                                -  enabled
      system.adapter.daswetter.0              : daswetter             : smarthome                                -  enabled
      system.adapter.discovery.0              : discovery             : smarthome                                - disabled
      system.adapter.feiertage.0              : feiertage             : smarthome                                -  enabled
      system.adapter.flot.0                   : flot                  : smarthome                                - disabled
    + system.adapter.fronius.0                : fronius               : smarthome                                -  enabled
    + system.adapter.harmony.0                : harmony               : smarthome                                -  enabled
    + system.adapter.history.0                : history               : smarthome                                -  enabled
      system.adapter.ical.0                   : ical                  : smarthome                                -  enabled
      system.adapter.ical.1                   : ical                  : smarthome                                -  enabled
    + system.adapter.iot.0                    : iot                   : smarthome                                -  enabled
    + system.adapter.javascript.0             : javascript            : smarthome                                -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : smarthome                                -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : smarthome                                -  enabled
    + system.adapter.onkyo.0                  : onkyo                 : smarthome                                -  enabled
    + system.adapter.operating-hours.0        : operating-hours       : smarthome                                -  enabled
    + system.adapter.pi-hole.0                : pi-hole               : smarthome                                -  enabled
    + system.adapter.pushover.0               : pushover              : smarthome                                -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : smarthome                                -  enabled
    + system.adapter.radar2.0                 : radar2                : smarthome                                -  enabled
    + system.adapter.shelly.0                 : shelly                : smarthome                                -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : smarthome                                -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : smarthome                                -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : smarthome                                -  enabled
      system.adapter.uv-protect.0             : uv-protect            : smarthome                                -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : smarthome                                - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : smarthome                                -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : smarthome                                - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : smarthome                                - disabled
      system.adapter.vis.0                    : vis                   : smarthome                                -  enabled
    + system.adapter.weather-warnings.0       : weather-warnings      : smarthome                                -  enabled
    + system.adapter.web.0                    : web                   : smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : smarthome                                -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230804163324-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alexa-timer-vis": 0.3.0  , installed 0.3.0
    Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fronius"      : 2.0.2    , installed 2.0.2
    Adapter    "harmony"      : 1.3.0    , installed 1.3.0
    Adapter    "ical"         : 1.14.3   , installed 1.14.3
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.8.0    , installed 8.0.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "operating-hours": 1.0.6  , installed 1.0.6
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
    Adapter    "radar2"       : 2.1.0    , installed 2.1.0
    Adapter    "shelly"       : 6.8.0    , installed 6.8.0
    Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
    Adapter    "trashschedule": 3.2.0    , installed 3.2.0
    Adapter    "uv-protect"   : 0.6.0    , installed 0.6.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
    Adapter    "weather-warnings": 0.6.7 , installed 0.6.7
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.11   , installed 2.5.11
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Objects and States
    Objects:        12395
    States:         10907
    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5797       693/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7347       906/io.mqtt.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4798       686/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6218       686/iobroker.js-con
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       6664       1154/io.harmony.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5799       693/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8001       1296/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6282       778/io.admin.0
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       6665       1154/io.harmony.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4690       532/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       7519       976/io.shelly.0
    udp        0      0 0.0.0.0:32832           0.0.0.0:*                           104        4692       532/avahi-daemon: r
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       7435       943/io.radar2.0
    udp6       0      0 :::5353                 :::*                                104        4691       532/avahi-daemon: r
    udp6       0      0 :::60874                :::*                                104        4693       532/avahi-daemon: r
    2024-04-07 21:39:13.968  - info: javascript.0 (75060) script.js.Haussteuerung.Timer: Timer Geräte entkalken: Prüfungsergebnis: Fällig seit 12 Tagen
    2024-04-07 21:39:13.972  - info: javascript.0 (75060) script.js.Haussteuerung.Timer: Timer Wasserfilter spülen: Script wurde neu gestartet. Ein Timer-Startdatum ist vorhanden, also wird nur aktualisiert.
    2024-04-07 21:39:13.973  - info: javascript.0 (75060) script.js.Haussteuerung.Timer: Timer Wasserfilter spülen: Prüfungsergebnis: Fällig seit 71 Tagen
    2024-04-07 21:39:13.978  - info: javascript.0 (75060) script.js.Haussteuerung.Timer: Timer Fusselfilter Waschmaschine: Script wurde neu gestartet. Ein Timer-Startdatum ist vorhanden, also wird nur aktualisiert.
    2024-04-07 21:39:13.980  - info: javascript.0 (75060) script.js.Haussteuerung.Timer: Timer Fusselfilter Waschmaschine: Prüfungsergebnis: Fällig seit 12 Tagen
    2024-04-07 21:39:14.015  - info: javascript.0 (75060) script.js.LMair.test_marker_abrufen: 0
    2024-04-07 21:39:14.081  - info: javascript.0 (75060) Start javascript script.js.Haussteuerung.Strom.kWh_Erzeugung
    2024-04-07 21:39:14.133  - info: javascript.0 (75060) script.js.Haussteuerung.Strom.kWh_Erzeugung: registered 0 subscriptions, 5 schedules, 0 messages, 0 logs and 0 file subscriptions
    2024-04-07 21:39:14.134  - info: javascript.0 (75060) Start javascript script.js.Haussteuerung.Strom.kWh_Gesamtverbrauch
    2024-04-07 21:39:14.206  - info: javascript.0 (75060) script.js.Haussteuerung.Strom.kWh_Gesamtverbrauch: registered 0 subscriptions, 5 schedules, 0 messages, 0 logs and 0 file subscriptions
    2024-04-07 21:39:14.350  - info: javascript.0 (75060) script.js.LMair.marker1: 200
    2024-04-07 21:39:14.482  - info: javascript.0 (75060) Start javascript script.js.LMair.marker
    2024-04-07 21:39:14.494  - info: javascript.0 (75060) script.js.LMair.marker: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
    2024-04-07 21:39:14.495  - info: javascript.0 (75060) Start javascript script.js.LMair.weather_json
    2024-04-07 21:39:14.502  - info: javascript.0 (75060) script.js.LMair.weather_json: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
    2024-04-07 21:39:14.627  - info: javascript.0 (75060) Start javascript script.js.Haussteuerung.Fernseher.ambilight
    2024-04-07 21:39:14.634  - info: javascript.0 (75060) script.js.Haussteuerung.Fernseher.ambilight: registered 1 subscription, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
    2024-04-07 21:39:15.404  - info: javascript.0 (75060) script.js.Haussteuerung.Lüftungsempfehlungs.Lüftungsempfehlung: Subscriptions angelegt: 20
    2024-04-07 21:39:16.067  - error: javascript.0 (75060) script.js.LMair.marker1: timeout of 2000ms exceeded
    2024-04-07 21:39:16.067  - info: javascript.0 (75060) script.js.LMair.marker1: undefined
    2024-04-07 21:40:00.352  - info: javascript.0 (75060) script.js.VIS.Liste_Lampen: Bodenbeleuchtung<br>Bücherregal<br>Nachtlicht Linda<br>Vorhang
    2024-04-07 21:40:00.393  - info: javascript.0 (75060) script.js.VIS.Liste_Lampen: Bodenbeleuchtung<br>Bücherregal<br>Nachtlicht Linda<br>Vorhang
    2024-04-07 21:40:00.426  - info: javascript.0 (75060) script.js.VIS.Liste_Lampen: Bodenbeleuchtung<br>Bücherregal<br>Nachtlicht Linda<br>Vorhang
    2024-04-07 21:40:01.653  - info: javascript.0 (75060) script.js.Haussteuerung.Lüftungsempfehlungs.Liste_Lueftungsempfehlung: Badezimmer
    2024-04-07 21:50:24.476  - warn: zigbee.0 (1038) DeviceAvailability:Stopping to ping 0x000b57fffe2a31ca TRADFRI bulb E27 WS�opal 980lm after 4 ping attempts
    @rtwl sagte in javascript startet nicht mehr:
    Der klemmt noch. Ist das ein Zusätzliches Modul im Adapter?
    rtwlR 1 Antwort Letzte Antwort
      rtwlR Offline
      rtwlR Offline
      rtwl
      Ehrlichgesagt, keine Ahnung was das ist.
      Als ich soeben keine Blocklys mehr speichern konnte dachte ich mir es würde
      iob stop
      sudo reboot
      helfen. Doch leider bin ich jetzt wieder am Anfang. Der Javascript Adapter bleibt Rot. 😥
      Auch die Log Meldungen (siehe erster Post) sind wieder alle 30 Sek vorhanden.
      Hast du noch eine Idee, oder bleibt es mir nicht erspart neu aufzusetzen?
      -Peter
      • rtwlR rtwl
        iob stop
        sudo reboot
        Backup?
          Backup?
          rtwlR Offline
          rtwlR Offline
          rtwl
          hab mich für die neue Installation auf einer neuen SD Karte entschieden. Dort kommt dann das Backup drauf. Somit sollte ich dann auf der sicheren Seite sein. Nicht, dass dann doch noch irgendwo Fehler auftauchen - hab ja den Raspi heute morgen einfach Stromlos gemacht.
          Danke wiedermal für deine Hilfe 👍
          -Peter
          • rtwlR Offline
            rtwlR Offline
            rtwl
            der iobroker (Raspberry/SD Karte) war zwar per Ping ansprechbar. aber weder der iobroker konnte geöffnet werden auch per ssh hatte ich keinen Zugriff mehr.
            3 Tage später mit dem frisch installiertem iobroker wieder das gleiche Problem...
            Ping erfolgreich - per ssh aber keinen Zugriff mehr - es kommt keine Passwortanforderung nach der ssh Eingabe.
            Kann ich außer innerlich durchdrehen noch irgendwas tun?
            Warum passiert das immer so unvorhergesehen?
            -Peter
            • rtwlR rtwl
              iob diag
              anschauen.
              rtwlR 2 Antworten Letzte Antwort
                iob diag
                anschauen.
                rtwlR Offline
                rtwlR Offline
                rtwl
                @thomas-braun soweit komm ich ja gar nicht. Hab keinen Zugriff per ssh. Der iobroker ist ja "abgestürzt"
                -Peter
                  iob diag
                  anschauen.
                  rtwlR Offline
                  rtwlR Offline
                  rtwl
                  es gibt nicht zufällig einen http request den ich an die ip-adresse des Raspberry schicken kann um iobroker neu zu starten oder sowas in der Art?
                  -Peter
                  • rtwlR rtwl
                    @rtwl
                    Du kommst ja wohl nicht drauf.
                    Mit lokal angeklemmter Tastatur:
                    https://wiki.ubuntuusers.de/Magic_SysRQ/
                      @rtwl
                      rtwlR Offline
                      rtwlR Offline
                      rtwl
                      leider hab ich keinen mini-hdmi adapter für den Raspi.
                      aber meinst du es würde funktionieren eine Tastatur anzuschließen und dann
                      Zitat der Website: "hierfür wird die ganze Zeit Alt + Druck gedrückt gehalten und nacheinander die Tasten R + E + I + S + U + B betätigt."?
                      -Peter
                      • rtwlR rtwl
                        @rtwl
                        Das hängt von der Tastatur ab. Viele moderne Spar-Tastaturen haben die Taste nicht (mehr direkt), manche auch gar nicht.
                        Ich weiß auch ehrlich gesagt gar nicht, ob Raspberry OS die Funktion nicht auch abgestellt hat. Ich musste die bei mir noch nie verwenden. Das Ding läuft einfach.
                        Auf meinem Arch Linux geht es nämlich nicht:
                        [Do, 11. Apr 2024, 00:02:24] sysrq: This sysrq operation is disabled.
                        [Do, 11. Apr 2024, 00:02:25] sysrq: This sysrq operation is disabled.
                        [Do, 11. Apr 2024, 00:02:26] sysrq: This sysrq operation is disabled.
                        [Do, 11. Apr 2024, 00:02:27] sysrq: Emergency Sync
                        [Do, 11. Apr 2024, 00:02:27] Emergency Sync complete
                        [Do, 11. Apr 2024, 00:02:28] sysrq: This sysrq operation is disabled.
                        [Do, 11. Apr 2024, 00:02:29] sysrq: This sysrq operation is disabled.
                          @rtwl
                          rtwlR Offline
                          rtwlR Offline
                          rtwl
                          @thomas-braun wow, das hat tatsächlich funktioniert 👍
                          iob diag für dich zur Kontrolle. Bitte Danke.
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : arm64
                           23:58:26 up 1 min,  2 users,  load average: 3.98, 1.25, 0.44
                          CPU threads: 4
                          Current issues:
                          ~ Under-voltage has occurred
                                         Local time: Wed 2024-04-10 23:58:26 CEST
                                     Universal time: Wed 2024-04-10 21:58:26 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          rtwl
                          /home/rtwl
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            4.0G        1.6G        2.2G        1.2M        329M        2.4G
                          Swap:           104M          0B        104M
                          Total:          4.1G        1.6G        2.3G
                                   3792 M total memory
                                   1478 M used memory
                                   1477 M active memory
                                    156 M inactive memory
                                   2066 M free memory
                                     31 M buffer memory
                                    283 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /dev/mmcblk0p2 ext4       15G  5.7G  7.8G  43% /
                          [Wed Apr 10 23:56:37 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:75:F7:C5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c17d14e5-02 rootfstype=ext4 fsck.repair=yes rootwait
                          [Wed Apr 10 23:56:41 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
                          [Wed Apr 10 23:56:44 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
                          /var:
                          513M    /var/
                          203M    /var/cache
                          197M    /var/cache/apt
                          161M    /var/lib
                          133M    /var/lib/apt/lists
                          Archived and active journals take up 48.0M in the file system.
                          191M    /opt/iobroker/backups/
                          974M    /opt/iobroker/iobroker-data/history
                          249M    /opt/iobroker/iobroker-data/files
                          98M     /opt/iobroker/iobroker-data/backup-objects
                          75M     /opt/iobroker/iobroker-data/files/javascript.admin
                          30M     /opt/iobroker/iobroker-data/objects.jsonl
                          23M     /opt/iobroker/iobroker-data/states.jsonl
                          USB-Devices by-id:
                          /usr/bin/npm            10.5.0
                          /usr/bin/npx            10.5.0
                          nodejs:
                            Version table:
                           *** 18.20.1-1nodesource1 1001
                               18.20.0-1nodesource1 1001
                               18.19.1-1nodesource1 1001
                               18.19.0-1nodesource1 1001
                               18.18.2-1nodesource1 1001
                               18.18.1-1nodesource1 1001
                               18.18.0-1nodesource1 1001
                               18.17.1-1nodesource1 1001
                               18.17.0-1nodesource1 1001
                               18.16.1-1nodesource1 1001
                               18.16.0-1nodesource1 1001
                               18.15.0-1nodesource1 1001
                               18.14.2-1nodesource1 1001
                               18.14.1-1nodesource1 1001
                               18.14.0-1nodesource1 1001
                               18.13.0+dfsg1-1 500
                               18.13.0-1nodesource1 1001
                               18.12.0-1nodesource1 1001
                               18.11.0-1nodesource1 1001
                               18.10.0-1nodesource1 1001
                               18.9.1-1nodesource1 1001
                               18.9.0-1nodesource1 1001
                               18.8.0-1nodesource1 1001
                               18.7.0-1nodesource1 1001
                               18.6.0-1nodesource1 1001
                               18.5.0-1nodesource1 1001
                               18.4.0-1nodesource1 1001
                               18.3.0-1nodesource1 1001
                               18.2.0-1nodesource1 1001
                               18.1.0-1nodesource1 1001
                               18.0.0-1nodesource1 1001
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.13.16
                          javascript:     8.0.2
                          Adapter State
                          + system.adapter.daswetter.0              : daswetter             : smarthome                                -  enabled
                            system.adapter.pi-hole.0                : pi-hole               : smarthome                                - disabled
                            system.adapter.uv-protect.0             : uv-protect            : smarthome                                - disabled
                          + instance is alive
                          Adapter    "javascript"   : 7.8.0    , installed 8.0.2
                          Objects and States
                          Objects:        12474
                          States:         10977
                          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                          Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Pending Updates: 2
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7443       1215/io.mqtt.0
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6394       717/sshd: /usr/sbin
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5898       710/iobroker.js-con
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5891       710/iobroker.js-con
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5037       943/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       11032      1916/io.web.0
                          tcp6       0      0 :::61991                :::*                    LISTEN      1001       11375      1693/io.harmony.0
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          6396       717/sshd: /usr/sbin
                          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       11376      1693/io.harmony.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        729        559/avahi-daemon: r
                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       10659      1485/io.shelly.0
                          udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       6973       1366/io.radar2.0
                          udp        0      0 0.0.0.0:41284           0.0.0.0:*                           104        731        559/avahi-daemon: r
                          udp6       0      0 :::5353                 :::*                                104        730        559/avahi-daemon: r
                          udp6       0      0 :::42826                :::*                                104        732        559/avahi-daemon: r
                          2024-04-11 00:00:16.802  - info: weather-warnings.0 (1887) Refresh Interval: 10 minutes
                          2024-04-11 00:00:16.940  - info: weather-warnings.0 (1887) [pushover] Create notification service pushover adapter: pushover.0.
                          2024-04-11 00:00:16.941  - info: weather-warnings.0 (1887) ZAMG activated. Retrieve data.
                          2024-04-11 00:00:20.464  - error: daswetter.0 (1193) force terminate
                          2024-04-11 00:00:20.512  - warn: daswetter.0 (1193) Terminated (UNKNOWN_ERROR): Without reason
                          2024-04-11 00:00:21.112  - error: daswetter.0 (1193) exception in await insertIntoList [Error: DB closed]
                          2024-04-11 00:00:21.125  - error: daswetter.0 (1193) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_3.Hour_23.rain_value": Connection is closed.
                          2024-04-11 00:00:21.309  - error: host.smarthome instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
                          2024-04-11 00:00:23.262  - info: pvforecast.0 (1827) Starting internal update cron (every 15 Minutes) for timezone: Europe/Berlin
                          2024-04-11 00:00:33.382  - warn: javascript.0 (1031) You are assigning a number to the state "0_userdata.0.VIS.Wetter.Wetterwarnungen_Popup.Nummer" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
                          2024-04-11 00:00:33.820  - warn: javascript.0 (1031)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1929:20)
                          2024-04-11 00:00:33.824  - warn: javascript.0 (1031)     at Object.<anonymous> (script.js.VIS.Wetter.Wetterwarnung_Popup:7:3)
                          2024-04-11 00:00:33.825  - warn: javascript.0 (1031)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1350:38)
                          2024-04-11 00:00:33.826  - warn: javascript.0 (1031)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:640:29)
                          2024-04-11 00:00:33.826  - warn: javascript.0 (1031)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11200:62)
                          2024-04-11 00:00:33.827  - warn: javascript.0 (1031)     at processImmediate (node:internal/timers:476:21)
                          2024-04-11 00:00:34.123  - info: javascript.0 (1031) State value to set for "0_userdata.0.VIS.Wetter.Wetterwarnungen_Popup.Nummer" has to be type "string" but received type "number"
                          2024-04-11 00:00:34.178  - warn: javascript.0 (1031) You are assigning a number to the state "0_userdata.0.VIS.Wetter.Wetterwarnungen_Popup.Nummer" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
                          2024-04-11 00:00:34.181  - warn: javascript.0 (1031)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1929:20)
                          2024-04-11 00:00:34.181  - warn: javascript.0 (1031)     at Object.<anonymous> (script.js.VIS.Wetter.Wetterwarnung_Popup:7:3)
                          2024-04-11 00:00:34.182  - warn: javascript.0 (1031)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1350:38)
                          2024-04-11 00:00:34.182  - warn: javascript.0 (1031)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:640:29)
                          2024-04-11 00:00:34.183  - warn: javascript.0 (1031)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11200:62)
                          2024-04-11 00:00:34.183  - warn: javascript.0 (1031)     at processImmediate (node:internal/timers:476:21)
                          2024-04-11 00:00:34.590  - info: javascript.0 (1031) State value to set for "0_userdata.0.VIS.Wetter.Wetterwarnungen_Popup.Nummer" has to be type "string" but received type "number"
                          -Peter
                          • rtwlR rtwl
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : arm64
                            CPU threads: 4
                            Current issues:
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            rtwl
                            /home/rtwl
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:           104M          0B        104M
                                     3792 M total memory
                                     1478 M used memory
                                     2066 M free memory
                                       31 M buffer memory
                                      283 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /var:
                            513M    /var/
                            203M    /var/cache
                            197M    /var/cache/apt
                            161M    /var/lib
                            USB-Devices by-id:
                            /usr/bin/npm            10.5.0
                            /usr/bin/npx            10.5.0
                            nodejs:
                              Version table:
                                 18.13.0+dfsg1-1 500
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.13.16
                            javascript:     8.0.2
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        12474
                            States:         10977
                            Pending Updates: 2
                            Das würde ich mir anschauen. Besseres NETZteil besorgen. Kein Handy-Ladegerät oder sowas.
                              rtwlR Offline
                              rtwlR Offline
                              rtwl
                              @thomas-braun Vielen Dank, das werde ich probieren 👍
                              -Peter
                              • rtwlR rtwl
                                @rtwl
                                Ist zwar nicht dein Problem, aber das würde ich auch angehen:
                                Irgendwann fliegt dir das als Fehler um die Ohren. Wie angekündigt.
                                  @rtwl
                                  rtwlR Offline
                                  rtwlR Offline
                                  rtwl
                                  @thomas-braun sagte in javascript startet nicht mehr:
                                  Danke, hab ich angepasst.
                                  Kann ich irgendwo prüfen wieviel Volt das Ladegerät zum Raspi liefert? hab jetzt eines Handy-Schnellladegerät mit 2A zuhause gefunden. Anscheinend sollte das schon reichen, oder? - aktuell hab ich nur ein billiges NoName stecken. und würde gerne ein davor und danach sehen.
                                  -Peter
                                  • rtwlR rtwl
                                    @rtwl
                                    Zum beliebten Thema 'echtes Netzteil' vs. Handyladegerät:
                                    https://www.elektronik-kompendium.de/sites/raspberry-pi/1912111.htm
                                    Nur weil aus einem schwarzen Plastikteil mit langem Schwanz und Micro-USB-Stecker 5 Volt rauskommen, bedeutet das nicht, dass damit ein Raspberry Pi zuverlässig betrieben werden kann.
