  4. Mulitihost
Mulitihost
18 Beiträge 3 Kommentatoren 1.7k Aufrufe 2 Beobachtet
    toki1973
    Wie kommt der Multihost zustande und wie bekomme ich das wieder weg?
    toki@iobroker:~$ iob start
    toki@iobroker:~$ iob status
     Cannot determine Set feature status: Connection is closed.
    Uncaught Rejection: Error: States DB is not allowed to start in the current Multihost environment
        at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:459:23)
        at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
     Unable to subscribe to expiry Keyspace events from Redis Server: Connection is closed.
     Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
     Unable to subscribe to meta namespace "meta." changes: Connection is closed.
    toki@iobroker:~$
    NUC, PROXMOX, Grafana, Influx, Unify
    • T toki1973
      toki@iobroker:~$
      HomoranH Offline
      HomoranH Offline
      @toki1973 sagte in Mulitihost:
      hast du keinen konfiguriert?
      Bitte iob diag in der Langfassung
        toki1973
        Nein habe ich nicht konfiguriert
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer-vm
                 Chassis: vm 🖴
          Virtualization: kvm
                  Kernel: Linux 6.1.0-17-amd64
            Architecture: x86-64
         Hardware Vendor: QEMU
          Hardware Model: Standard PC _i440FX + PIIX, 1996_
        Firmware Version: rel-1.14.0-0-g155821a1990b-prebuilt.qemu.org
        model name      : Common KVM processor
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         12:04:58 up 5 days, 22:39,  4 users,  load average: 2.88, 3.69, 2.82
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Tue 2024-03-05 12:04:58 CET
                   Universal time: Tue 2024-03-05 11:04:58 UTC
                         RTC time: Tue 2024-03-05 11:04:58
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        toki
        /home/toki
        toki cdrom floppy sudo audio dip video plugdev users netdev iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            6.3G        4.0G        1.4G        524K        1.2G        2.3G
        Swap:           1.0G        4.1M        1.0G
        Total:          7.4G        4.0G        2.4G
                 6051 M total memory
                 3841 M used memory
                  527 M active memory
                 3690 M inactive memory
                 1317 M free memory
                  240 M buffer memory
                  943 M swap cache
                  974 M total swap
                    3 M used swap
                  971 M free swap
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  3.0G     0  3.0G   0% /dev
        tmpfs          tmpfs     606M  572K  605M   1% /run
        /dev/sda1      ext4       31G  7.2G   22G  25% /
        tmpfs          tmpfs     3.0G     0  3.0G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     606M     0  606M   0% /run/user/1000
        [Wed Feb 28 13:25:12 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
        [Wed Feb 28 13:25:15 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
        [Fri Mar  1 02:16:56 2024] Modules linked in: sha512_generic cmac nls_utf8 cifs cifs_arc4 cifs_md4 dns_resolver fscache netfs sunrpc cdc_acm virtio_console virtio_balloon joydev evdev sg button serio_raw pcspkr binfmt_misc dm_mod fuse loop configfs efi_pstore qemu_fw_cfg ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 crc32c_generic hid_generic usbhid hid sd_mod t10_pi crc64_rocksoft crc64 crc_t10dif crct10dif_generic crct10dif_common sr_mod bochs drm_vram_helper cdrom drm_kms_helper virtio_net drm_ttm_helper ttm net_failover failover virtio_scsi ata_generic xhci_pci xhci_hcd ata_piix uhci_hcd ehci_hcd drm libata usbcore psmouse virtio_pci virtio_pci_legacy_dev virtio_pci_modern_dev virtio virtio_ring scsi_mod i2c_piix4 usb_common scsi_common floppy
        [Fri Mar  1 02:18:22 2024] Modules linked in: sha512_generic cmac nls_utf8 cifs cifs_arc4 cifs_md4 dns_resolver fscache netfs sunrpc cdc_acm virtio_console virtio_balloon joydev evdev sg button serio_raw pcspkr binfmt_misc dm_mod fuse loop configfs efi_pstore qemu_fw_cfg ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 crc32c_generic hid_generic usbhid hid sd_mod t10_pi crc64_rocksoft crc64 crc_t10dif crct10dif_generic crct10dif_common sr_mod bochs drm_vram_helper cdrom drm_kms_helper virtio_net drm_ttm_helper ttm net_failover failover virtio_scsi ata_generic xhci_pci xhci_hcd ata_piix uhci_hcd ehci_hcd drm libata usbcore psmouse virtio_pci virtio_pci_legacy_dev virtio_pci_modern_dev virtio virtio_ring scsi_mod i2c_piix4 usb_common scsi_common floppy
        [Tue Mar  5 12:00:42 2024] Modules linked in: sha512_generic cmac nls_utf8 cifs cifs_arc4 cifs_md4 dns_resolver fscache netfs sunrpc cdc_acm virtio_console virtio_balloon joydev evdev sg button serio_raw pcspkr binfmt_misc dm_mod fuse loop configfs efi_pstore qemu_fw_cfg ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 crc32c_generic hid_generic usbhid hid sd_mod t10_pi crc64_rocksoft crc64 crc_t10dif crct10dif_generic crct10dif_common sr_mod bochs drm_vram_helper cdrom drm_kms_helper virtio_net drm_ttm_helper ttm net_failover failover virtio_scsi ata_generic xhci_pci xhci_hcd ata_piix uhci_hcd ehci_hcd drm libata usbcore psmouse virtio_pci virtio_pci_legacy_dev virtio_pci_modern_dev virtio virtio_ring scsi_mod i2c_piix4 usb_common scsi_common floppy
        TARGET SOURCE    FSTYPE OPTIONS
        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
        /var:
        589M    /var/
        246M    /var/cache
        239M    /var/cache/apt
        172M    /var/lib
        171M    /var/log
        Archived and active journals take up 24.4M in the file system.
        /opt/iobroker/backups:
        52M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        855M    /opt/iobroker/iobroker-data/
        594M    /opt/iobroker/iobroker-data/files
        168M    /opt/iobroker/iobroker-data/backup-objects
        93M     /opt/iobroker/iobroker-data/files/vis.0
        57M     /opt/iobroker/iobroker-data/files/javascript.admin
        70M     /opt/iobroker/iobroker-data/objects.jsonl
        36M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-Texas_Instruments_XDS110__02.03.00.18__Embed_with_CMSIS-DAP_L1100C1R-if03
        /dev/serial/by-id/usb-Texas_Instruments_XDS110__02.03.00.18__Embed_with_CMSIS-DAP_L1100C1R-if00
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.1-1nodesource1
          Version table:
             18.19.1-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
         *** 18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0+dfsg1-1 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.13.16
        javascript:     7.8.0
        Adapters from github:   2
        Adapter State
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          system.adapter.ble.0                    : ble                   : iobroker                                 - disabled
        + system.adapter.bluelink.0               : bluelink              : iobroker                                 -  enabled
          system.adapter.broadlink2.0             : broadlink2            : iobroker                                 - disabled
          system.adapter.bshb.0                   : bshb                  : iobroker                                 - disabled
          system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
          system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
          system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
          system.adapter.devices.0                : devices               : iobroker                                 - disabled
          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
          system.adapter.echarts.0                : echarts               : iobroker                                 - disabled
        + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
          system.adapter.evcc.0                   : evcc                  : iobroker                                 - disabled, port: 7070
          system.adapter.firetv.0                 : firetv                : iobroker                                 - disabled
          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
          system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
        + system.adapter.go-e.0                   : go-e                  : iobroker                                 -  enabled
          system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 - disabled
          system.adapter.history.0                : history               : iobroker                                 - disabled
          system.adapter.homeconnect.0            : homeconnect           : iobroker                                 - disabled
          system.adapter.hue-extended.0           : hue-extended          : iobroker                                 - disabled
        + system.adapter.hue-extended.1           : hue-extended          : iobroker                                 -  enabled
        + system.adapter.hue.1                    : hue                   : iobroker                                 -  enabled, port: 80
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          system.adapter.javascript.1             : javascript            : iobroker                                 - disabled
          system.adapter.luftdaten.0              : luftdaten             : iobroker                                 - disabled
          system.adapter.megaesp.0                : megaesp               : iobroker                                 - disabled, port: 80
          system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
          system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
        + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
        + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
          system.adapter.modbus.2                 : modbus                : iobroker                                 - disabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
          system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 - disabled
        + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
        + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
          system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
        + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
          system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
        + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
          system.adapter.radar2.0                 : radar2                : iobroker                                 - disabled
          system.adapter.reolink.0                : reolink               : iobroker                                 - disabled
          system.adapter.samsung.0                : samsung               : iobroker                                 - disabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1881, bind: 0.0.0.0
        + system.adapter.signal-cmb.0             : signal-cmb            : iobroker                                 -  enabled
          system.adapter.smartmeter.0             : smartmeter            : iobroker                                 - disabled
          system.adapter.solarwetter.0            : solarwetter           : iobroker                                 -  enabled
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
        + system.adapter.sonoff.1                 : sonoff                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
          system.adapter.sprinklecontrol.0        : sprinklecontrol       : iobroker                                 - disabled
          system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5000
        + system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.terminal.0               : terminal              : iobroker                                 - disabled, port: 8088, bind: 0.0.0.0, run as: admin
        + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
          system.adapter.time-switch.0            : time-switch           : iobroker                                 - disabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled
          system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
          system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
          system.adapter.web-speedy.0             : web-speedy            : iobroker                                 - disabled
          system.adapter.web.1                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
        + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          system.adapter.yeelight-2.0             : yeelight-2            : iobroker                                 - disabled
        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.13.16  , installed 6.13.16
        Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
        Adapter    "backitup"     : 2.10.11  , installed 2.10.11
        Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "bshb"         : 0.2.7    , installed 0.2.7
        Adapter    "chromecast"   : 3.2.0    , installed 3.2.0
        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
        Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "devices"      : 1.1.5    , installed 1.1.5
        Adapter    "discovery"    : 4.2.0    , installed 4.2.0
        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
        Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
        Adapter    "evcc"         : 0.1.1    , installed 0.1.1
        Adapter    "firetv"       : 2.0.2    , installed 2.0.2
        Adapter    "followthesun" : 0.5.0    , installed 0.5.0
        Adapter    "fullybrowser" : 3.0.11   , installed 3.0.11
        Adapter    "go-e"         : 1.0.29   , installed 1.0.29
        Adapter    "heatingcontrol": 2.12.3  , installed 2.12.3
        Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
        Adapter    "hue"          : 3.10.2   , installed 3.10.2
        Adapter    "ical"         : 1.13.3   , installed 1.13.3
        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
        Adapter    "influxdb"     : 4.0.2    , installed 3.2.0  [Updatable]
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
        Controller "js-controller": 5.0.19   , installed 5.0.17 [Updatable]
        Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
        Adapter    "megaesp"      : 0.1.0    , installed 0.1.0
        Adapter    "mihome-vacuum": 4.1.1    , installed 4.1.1
        Adapter    "modbus"       : 6.1.0    , installed 6.1.0
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
        Adapter    "node-red"     : 5.1.0    , installed 5.1.0
        Adapter    "notification-manager": 1.0.0, installed 1.0.0
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "proxmox"      : 2.2.3    , installed 2.2.3
        Adapter    "pushover"     : 3.0.6    , installed 3.0.6
        Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
        Adapter    "radar2"       : 2.1.0    , installed 2.1.0
        Adapter    "reolink"      : 1.0.3    , installed 1.0.3
        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
        Adapter    "socketio"     : 6.6.0    , installed 6.6.0
        Adapter    "solarwetter"  : 1.1.5    , installed 1.1.5
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
        Adapter    "synology"     : 3.0.1    , installed 3.0.1
        Adapter    "telegram"     : 3.1.0    , installed 3.1.0
        Adapter    "telegram-menu": 1.5.1    , installed 1.5.1
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "trashschedule": 3.2.0    , installed 3.2.0
        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
        Adapter    "unifi"        : 0.6.7    , installed 0.6.7
        Adapter    "vis"          : 1.5.4    , installed 1.5.4
        Adapter    "vis-2-widgets-gauges": 1.0.2, installed 1.0.2
        Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
        Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
        Adapter    "ws"           : 2.5.10   , installed 2.5.10
        Adapter    "yeelight-2"   : 1.3.1    , installed 1.3.1
        Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
        Objects and States
        Objects:        120296
        States:         93115
        Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 30
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       17813483   4166491/node-red
        tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       17814072   4166094/io.shelly.0
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17813696   4166120/io.sonoff.1
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17814533   4166055/io.mqtt.0
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       17813328   4166095/io.sonoff.0
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13290      1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15279      452/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17811245   4165726/iobroker.js
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17811571   4165726/iobroker.js
        tcp6       0      0 :::111                  :::*                    LISTEN      0          13293      1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          15290      452/sshd: /usr/sbin
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17812502   4165751/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17813993   4166381/io.web.0
        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       17813974   4166382/io.ws.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13412      1/init
        udp6       0      0 :::111                  :::*                                0          13415      1/init
        2024-03-05 12:07:15.931  - info: javascript.0 (4165800) script.js.common.Gaszähler: + 0.005
        2024-03-05 12:07:15.931  - info: javascript.0 (4165800) script.js.common.Gaszähler: 7020.875
        2024-03-05 12:07:16.690  - info: javascript.0 (4165800) script.js.common.Gaszähler:  in Brennwert
        2024-03-05 12:07:16.691  - info: javascript.0 (4165800) script.js.common.Gaszähler: 76391.547
        2024-03-05 12:07:16.691  - info: javascript.0 (4165800) script.js.common.Gaszähler: 7020.875
        2024-03-05 12:07:16.692  - info: javascript.0 (4165800) script.js.common.Gaszähler: 76391.6014245125
        2024-03-05 12:07:16.692  - info: javascript.0 (4165800) script.js.common.Gaszähler: Brennwert kWh in DP geschieben
        2024-03-05 12:07:21.867  - debug: shelly.0 (4166094) [createObjects] Finished object creation of  (undefined / undefined / undefined)
        2024-03-05 12:07:21.868  - debug: shelly.0 (4166094) [MQTT] Last will for client id "shellyplus2pm-d48afc7cfa64" saved: {"retain":true,"qos":0,"topic":"shellyplus2pm-d48afc7cfa64/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}}
        2024-03-05 12:07:21.868  - debug: shelly.0 (4166094) [setIP] New IP for device undefined: 192.168.0.5 (source: MQTT connect)
        2024-03-05 12:07:21.885  - error: shelly.0 (4166094) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-d48afc7cfa64"
        2024-03-05 12:07:26.494  - debug: shelly.0 (4166094) [MQTT Server] New connection from 192.168.0.5
        2024-03-05 12:07:26.496  - debug: shelly.0 (4166094) [MQTT] Client connected: {"cmd":"connect","retain":false,"qos":0,"dup":false,"length":94,"topic":null,"payload":null,"protocolId":"MQTT","protocolVersion":4,"will":{"retain":true,"qos":0,"topic":"shellyplus2pm-d48afc7cfa64/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}},"clean":true,"keepalive":60,"clientId":"shellyplus2pm-d48afc7cfa64","username":"admin","password":{"type":"Buffer","data":[97,100,109,105,110]}}
        2024-03-05 12:07:26.496  - debug: shelly.0 (4166094) [BaseClient] Destroying 192.168.0.5 (undefined / undefined / undefined)
        2024-03-05 12:07:26.497  - debug: shelly.0 (4166094) [MQTT] Destroying
        2024-03-05 12:07:26.497  - info: shelly.0 (4166094) [MQTT] Device with client id "shellyplus2pm-d48afc7cfa64" connected!
        2024-03-05 12:07:26.644  - debug: shelly.0 (4166094) Configured device mode of  (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1) by state "shellyplus2pm#d48afc7cfa64#1.Sys.deviceMode" (fallback): cover
        2024-03-05 12:07:29.985  - debug: shelly.0 (4166094) [createObjects] Starting object creation of  (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1) for mode: cover
        2024-03-05 12:07:31.497  - info: javascript.0 (4165800) Stop script script.js.common.Beleuchtung_HUE
        2024-03-05 12:07:31.641  - info: javascript.0 (4165800) script.js.common.Gaszähler: + 0.005
        2024-03-05 12:07:31.641  - info: javascript.0 (4165800) script.js.common.Gaszähler: 7020.88
        2024-03-05 12:07:31.665  - debug: shelly.0 (4166094) [onlineCheck] Checking shellyplus2pm#d48afc7cfa64#1 on 192.168.0.5:80
        2024-03-05 12:07:31.681  - debug: shelly.0 (4166094) [deviceStatusUpdate] shellyplus2pm#d48afc7cfa64#1: true
        2024-03-05 12:07:31.835  - debug: shelly.0 (4166094) [onlineCheck] Checking shellyplus1pm#d48afc597dfc#1 on 192.168.0.53:80
        • T toki1973
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Chassis: vm 🖴
            Virtualization: kvm
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
          CPU threads: 4
                        NTP service: active
                    RTC in local TZ: no
          toki
          /home/toki
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
                   6051 M total memory
                   3841 M used memory
                    527 M active memory
                   1317 M free memory
                    240 M buffer memory
                    943 M swap cache
                    974 M total swap
                      3 M used swap
                    971 M free swap
          *** FILESYSTEM ***
          /var:
          589M    /var/
          246M    /var/cache
          239M    /var/cache/apt
          172M    /var/lib
          171M    /var/log
          USB-Devices by-id:
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.13.16
          javascript:     7.8.0
          Adapter State
          + instance is alive
          Objects and States
          Objects:        120296
          States:         93115
          Pending Updates: 30
          Pending Updates: 30
          Patches einspielen, gilt auch für den ioBroker-Bereich.
          Bei Zigbee nicht /dev/ttyACM0 sondern den richtigen Link von hier verwenden:
          T 2 Antworten Letzte Antwort
            Pending Updates: 30
            toki1973
            @thomas-braun Ja mache ich gleich - ich war auf dem Weg dahin - habe iob gestopt, iob fix und dann starten wollen bevor ich die Updates über
            sudo apt update
            sudo apt dist-upgrade
            sudo reboot
            machen wollte - siehst du die Ursache des Multihosts?
              Pending Updates: 30
              toki1973
              @thomas-braun said in Mulitihost:
              Pending Updates: 30
              In den zigbee Instanz das einstellen?
              • T toki1973
                Pending Updates: 30
                Ja, eines der beiden Interfaces. Vermutlich if00.
                • T toki1973
                  sudo apt update
                  sudo reboot
                  HomoranH Offline
                  HomoranH Offline
                  nein!
                  aber hast du 2 zigbee-sticks am Rechner?
                  T Thomas BraunT 2 Antworten Letzte Antwort
                    nein!
                    toki1973
                    @homoran Nein ich habe nur einen
                      toki1973
                      @thomas-braun Das wird wohl nur verkürzt angezeigt
                      • T toki1973
                        @toki1973
                        Nein. Trag da den vollständigen Pfad ein:
                        • T toki1973
                          HomoranH Offline
                          HomoranH Offline
                          nein, du hast es verkürzt eingetragen.
                          nach einem Neustart können sich die Ports ändern, deswegen auf das eindeutige device mappen!
                            nein!
                            @homoran sagte in Mulitihost:
                            Nein, aber einen mit zwei Interfaces.
                              toki1973
                              @thomas-braun ich habe mal den USB Port gewechselt - vlt. daher
                              • T toki1973
                                @toki1973
                                Und genau solche Aktionen laufen glatter, wenn man by-id nimmt. Die Geräte Datei kann sich nämlich dann ändern, die ID nicht.
                                Kiste durchgepatcht?
                                iob diag
                                Schau nun wie aus?
                                  @toki1973
                                  iob diag
                                  Schau nun wie aus?
                                  toki1973
                                  @thomas-braun Ja sieht nun besser aus.
                                  Anderes Thema das ich eigentlich dachte das sich nach einem Reboot löst. Ich bekomme ein neues hue0 Objekt unter Objecte angezeigt. Wenn ich einen Datenpunkt des Objektes in Blockly einbinden will erscheint er aber nicht im Objektauswahl Dialog. Wie kann man das aktualisieren?
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                           Chassis: vm 🖴
                                    Virtualization: kvm
                                            Kernel: Linux 6.1.0-18-amd64
                                  Docker          : false
                                  Kernel          : x86_64
                                  Userland        : amd64
                                   15:20:27 up 37 min,  2 users,  load average: 2.62, 2.10, 2.03
                                  CPU threads: 4
                                                 Local time: Tue 2024-03-05 15:20:27 CET
                                             Universal time: Tue 2024-03-05 14:20:27 UTC
                                                   RTC time: Tue 2024-03-05 14:20:27
                                                NTP service: active
                                            RTC in local TZ: no
                                  toki
                                  /home/toki
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            6.3G        4.5G        1.5G        585K        677M        1.9G
                                  Swap:           1.0G          0B        1.0G
                                  Total:          7.4G        4.5G        2.5G
                                           6051 M total memory
                                           4244 M used memory
                                            339 M active memory
                                           4035 M inactive memory
                                           1393 M free memory
                                             53 M buffer memory
                                            591 M swap cache
                                            974 M total swap
                                              0 M used swap
                                            974 M free swap
                                  *** FILESYSTEM ***
                                  /dev/sda1      ext4       31G  7.3G   22G  26% /
                                  [Tue Mar  5 14:43:21 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Tue Mar  5 14:43:24 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
                                  /var:
                                  604M    /var/
                                  246M    /var/cache
                                  239M    /var/cache/apt
                                  185M    /var/log
                                  172M    /var/lib
                                  Archived and active journals take up 28.4M in the file system.
                                  952M    /opt/iobroker/iobroker-data/
                                  107M    /opt/iobroker/iobroker-data/states.jsonl
                                  83M     /opt/iobroker/iobroker-data/objects.jsonl
                                  USB-Devices by-id:
                                  /usr/bin/nodejs         v18.19.1
                                  /usr/bin/node           v18.19.1
                                  /usr/bin/npm            10.2.4
                                  /usr/bin/npx            10.2.4
                                  nodejs:
                                    Installed: 18.19.1-1nodesource1
                                    Version table:
                                   *** 18.19.1-1nodesource1 1001
                                       18.13.0+dfsg1-1 500
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.13.16
                                  javascript:     7.8.0
                                  Adapter State
                                  + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__02.03.00.18__Embed_with_CMSIS-DAP_L1100C1R-if00
                                  + instance is alive
                                  Objects and States
                                  Objects:        120048
                                  States:         92869
                                  Pending Updates: 0
                                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       18505      1111/node-red
                                  tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       19542      723/io.shelly.0
                                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17118      755/io.sonoff.1
                                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18514      718/io.mqtt.0
                                  tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       17099      744/io.sonoff.0
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16180      431/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16187      431/iobroker.js-con
                                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13366      1/init
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14070      451/sshd: /usr/sbin
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17339      484/io.admin.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18735      1009/io.web.0
                                  tcp6       0      0 :::8084                 :::*                    LISTEN      1001       18717      1020/io.ws.0
                                  tcp6       0      0 :::111                  :::*                    LISTEN      0          13369      1/init
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          14072      451/sshd: /usr/sbin
                                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14348      1/init
                                  udp6       0      0 :::111                  :::*                                0          14351      1/init
                                  2024-03-05 15:23:05.050  - debug: shelly.0 (723) [MQTT] State change 192.168.0.5 (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1): shellyplus2pm-d48afc7cfa64/status/cover:0 -> state: shellyplus2pm#d48afc7cfa64#1.Cover0.temperatureC, value: 46.6
                                  2024-03-05 15:23:09.557  - info: javascript.0 (564) script.js.common.Gaszähler: + 0.005
                                  2024-03-05 15:23:09.573  - info: javascript.0 (564) script.js.common.Gaszähler: 7026.32
                                  2024-03-05 15:23:09.615  - debug: shelly.0 (723) [httpIoBrokerState] State change 192.168.0.5 (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1): state: shellyplus2pm#d48afc7cfa64#1.uptime, value: 338374
                                  2024-03-05 15:23:09.616  - debug: shelly.0 (723) [httpIoBrokerState] State change 192.168.0.5 (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1): state: shellyplus2pm#d48afc7cfa64#1.rssi, value: -75
                                  2024-03-05 15:23:09.684  - warn: shelly.0 (723) [authEnabled] 192.168.0.5 (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-03-05 15:23:10.259  - info: javascript.0 (564) script.js.common.Gaszähler:  in Brennwert
                                  2024-03-05 15:23:10.259  - info: javascript.0 (564) script.js.common.Gaszähler: 76450.792
                                  2024-03-05 15:23:10.259  - info: javascript.0 (564) script.js.common.Gaszähler: 7026.32
                                  2024-03-05 15:23:10.260  - info: javascript.0 (564) script.js.common.Gaszähler: 76450.846500056
                                  2024-03-05 15:23:10.260  - info: javascript.0 (564) script.js.common.Gaszähler: 76450.847
                                  2024-03-05 15:23:10.260  - info: javascript.0 (564) script.js.common.Gaszähler: Brennwert kWh in DP geschieben
                                  2024-03-05 15:23:11.839  - info: sonoff.1 (755) State value to set for "sonoff.1.SugerValley.NeoPool_pH_Data" has to be type "string" but received type "number"
                                  2024-03-05 15:23:12.126  - info: sonoff.1 (755) State value to set for "sonoff.1.SugerValley.NeoPool_Redox_Data" has to be type "string" but received type "number"
                                  2024-03-05 15:23:12.183  - info: sonoff.1 (755) State value to set for "sonoff.1.SugerValley.NeoPool_Hydrolysis_Data" has to be type "string" but received type "number"
                                  2024-03-05 15:23:13.772  - info: sonoff.0 (744) Client [GosBlitzw_EP2] reconnected. Old secret 1709648189940_2039. New secret 1709648593772_7398
                                  2024-03-05 15:23:13.854  - info: admin.0 (484) ==> Connected system.user.admin from ::ffff:192.168.0.148
                                  2024-03-05 15:23:14.084  - info: javascript.0 (564) script.js.common.Gaszähler: + 0.005
                                  2024-03-05 15:23:14.085  - info: javascript.0 (564) script.js.common.Gaszähler: 7026.325
                                  2024-03-05 15:23:14.480  - info: javascript.0 (564) script.js.common.Gaszähler:  in Brennwert
                                  2024-03-05 15:23:14.480  - info: javascript.0 (564) script.js.common.Gaszähler: 76450.847
                                  2024-03-05 15:23:14.481  - info: javascript.0 (564) script.js.common.Gaszähler: 7026.325
                                  2024-03-05 15:23:14.484  - info: javascript.0 (564) script.js.common.Gaszähler: 76450.90090324749
                                  2024-03-05 15:23:14.485  - info: javascript.0 (564) script.js.common.Gaszähler: 76450.901
                                  2024-03-05 15:23:14.485  - info: javascript.0 (564) script.js.common.Gaszähler: Brennwert kWh in DP geschieben
                                  • T toki1973
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                             Chassis: vm 🖴
                                      Virtualization: kvm
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : amd64
                                    CPU threads: 4
                                                  NTP service: active
                                              RTC in local TZ: no
                                    toki
                                    /home/toki
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:           1.0G          0B        1.0G
                                             6051 M total memory
                                             4244 M used memory
                                              339 M active memory
                                             1393 M free memory
                                               53 M buffer memory
                                              591 M swap cache
                                              974 M total swap
                                                0 M used swap
                                              974 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    604M    /var/
                                    246M    /var/cache
                                    239M    /var/cache/apt
                                    185M    /var/log
                                    172M    /var/lib
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.2.4
                                    /usr/bin/npx            10.2.4
                                    nodejs:
                                      Version table:
                                         18.13.0+dfsg1-1 500
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.13.16
                                    javascript:     7.8.0
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        120048
                                    States:         92869
                                    Pending Updates: 0
                                    @toki1973
                                    sudo usermod -a -G adm toki
                                    sudo systemctl set-default multi-user.target
                                    Und bring den js-controller und den influxdb-Adapter auf Stand.
                                      @toki1973
                                      toki1973
                                      @thomas-braun Vielen Dank!
