  4. Mulitihost
Mulitihost
18 Beiträge 3 Kommentatoren 1.7k Aufrufe 2 Beobachtet
    @toki1973 sagte in Mulitihost:
    Wie kommt der Multihost zustande
    hast du keinen konfiguriert?
    Bitte iob diag in der Langfassung
    toki1973
    Nein habe ich nicht konfiguriert
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-17-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.14.0-0-g155821a1990b-prebuilt.qemu.org
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     12:04:58 up 5 days, 22:39,  4 users,  load average: 2.88, 3.69, 2.82
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Tue 2024-03-05 12:04:58 CET
               Universal time: Tue 2024-03-05 11:04:58 UTC
                     RTC time: Tue 2024-03-05 11:04:58
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    toki
    /home/toki
    toki cdrom floppy sudo audio dip video plugdev users netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            6.3G        4.0G        1.4G        524K        1.2G        2.3G
    Swap:           1.0G        4.1M        1.0G
    Total:          7.4G        4.0G        2.4G
             6051 M total memory
             3841 M used memory
              527 M active memory
             3690 M inactive memory
             1317 M free memory
              240 M buffer memory
              943 M swap cache
              974 M total swap
                3 M used swap
              971 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  3.0G     0  3.0G   0% /dev
    tmpfs          tmpfs     606M  572K  605M   1% /run
    /dev/sda1      ext4       31G  7.2G   22G  25% /
    tmpfs          tmpfs     3.0G     0  3.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     606M     0  606M   0% /run/user/1000
    [Wed Feb 28 13:25:12 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Feb 28 13:25:15 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
    [Fri Mar  1 02:16:56 2024] Modules linked in: sha512_generic cmac nls_utf8 cifs cifs_arc4 cifs_md4 dns_resolver fscache netfs sunrpc cdc_acm virtio_console virtio_balloon joydev evdev sg button serio_raw pcspkr binfmt_misc dm_mod fuse loop configfs efi_pstore qemu_fw_cfg ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 crc32c_generic hid_generic usbhid hid sd_mod t10_pi crc64_rocksoft crc64 crc_t10dif crct10dif_generic crct10dif_common sr_mod bochs drm_vram_helper cdrom drm_kms_helper virtio_net drm_ttm_helper ttm net_failover failover virtio_scsi ata_generic xhci_pci xhci_hcd ata_piix uhci_hcd ehci_hcd drm libata usbcore psmouse virtio_pci virtio_pci_legacy_dev virtio_pci_modern_dev virtio virtio_ring scsi_mod i2c_piix4 usb_common scsi_common floppy
    [Fri Mar  1 02:18:22 2024] Modules linked in: sha512_generic cmac nls_utf8 cifs cifs_arc4 cifs_md4 dns_resolver fscache netfs sunrpc cdc_acm virtio_console virtio_balloon joydev evdev sg button serio_raw pcspkr binfmt_misc dm_mod fuse loop configfs efi_pstore qemu_fw_cfg ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 crc32c_generic hid_generic usbhid hid sd_mod t10_pi crc64_rocksoft crc64 crc_t10dif crct10dif_generic crct10dif_common sr_mod bochs drm_vram_helper cdrom drm_kms_helper virtio_net drm_ttm_helper ttm net_failover failover virtio_scsi ata_generic xhci_pci xhci_hcd ata_piix uhci_hcd ehci_hcd drm libata usbcore psmouse virtio_pci virtio_pci_legacy_dev virtio_pci_modern_dev virtio virtio_ring scsi_mod i2c_piix4 usb_common scsi_common floppy
    [Tue Mar  5 12:00:42 2024] Modules linked in: sha512_generic cmac nls_utf8 cifs cifs_arc4 cifs_md4 dns_resolver fscache netfs sunrpc cdc_acm virtio_console virtio_balloon joydev evdev sg button serio_raw pcspkr binfmt_misc dm_mod fuse loop configfs efi_pstore qemu_fw_cfg ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 crc32c_generic hid_generic usbhid hid sd_mod t10_pi crc64_rocksoft crc64 crc_t10dif crct10dif_generic crct10dif_common sr_mod bochs drm_vram_helper cdrom drm_kms_helper virtio_net drm_ttm_helper ttm net_failover failover virtio_scsi ata_generic xhci_pci xhci_hcd ata_piix uhci_hcd ehci_hcd drm libata usbcore psmouse virtio_pci virtio_pci_legacy_dev virtio_pci_modern_dev virtio virtio_ring scsi_mod i2c_piix4 usb_common scsi_common floppy
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    589M    /var/
    246M    /var/cache
    239M    /var/cache/apt
    172M    /var/lib
    171M    /var/log
    Archived and active journals take up 24.4M in the file system.
    /opt/iobroker/backups:
    52M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    855M    /opt/iobroker/iobroker-data/
    594M    /opt/iobroker/iobroker-data/files
    168M    /opt/iobroker/iobroker-data/backup-objects
    93M     /opt/iobroker/iobroker-data/files/vis.0
    57M     /opt/iobroker/iobroker-data/files/javascript.admin
    70M     /opt/iobroker/iobroker-data/objects.jsonl
    36M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_XDS110__02.03.00.18__Embed_with_CMSIS-DAP_L1100C1R-if03
    /dev/serial/by-id/usb-Texas_Instruments_XDS110__02.03.00.18__Embed_with_CMSIS-DAP_L1100C1R-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
         18.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
     *** 18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   2
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.ble.0                    : ble                   : iobroker                                 - disabled
    + system.adapter.bluelink.0               : bluelink              : iobroker                                 -  enabled
      system.adapter.broadlink2.0             : broadlink2            : iobroker                                 - disabled
      system.adapter.bshb.0                   : bshb                  : iobroker                                 - disabled
      system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
      system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
      system.adapter.devices.0                : devices               : iobroker                                 - disabled
      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
      system.adapter.echarts.0                : echarts               : iobroker                                 - disabled
    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
      system.adapter.evcc.0                   : evcc                  : iobroker                                 - disabled, port: 7070
      system.adapter.firetv.0                 : firetv                : iobroker                                 - disabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
    + system.adapter.go-e.0                   : go-e                  : iobroker                                 -  enabled
      system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 - disabled
      system.adapter.history.0                : history               : iobroker                                 - disabled
      system.adapter.homeconnect.0            : homeconnect           : iobroker                                 - disabled
      system.adapter.hue-extended.0           : hue-extended          : iobroker                                 - disabled
    + system.adapter.hue-extended.1           : hue-extended          : iobroker                                 -  enabled
    + system.adapter.hue.1                    : hue                   : iobroker                                 -  enabled, port: 80
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.javascript.1             : javascript            : iobroker                                 - disabled
      system.adapter.luftdaten.0              : luftdaten             : iobroker                                 - disabled
      system.adapter.megaesp.0                : megaesp               : iobroker                                 - disabled, port: 80
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
      system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
      system.adapter.modbus.2                 : modbus                : iobroker                                 - disabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 - disabled
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
      system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
      system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
      system.adapter.radar2.0                 : radar2                : iobroker                                 - disabled
      system.adapter.reolink.0                : reolink               : iobroker                                 - disabled
      system.adapter.samsung.0                : samsung               : iobroker                                 - disabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1881, bind: 0.0.0.0
    + system.adapter.signal-cmb.0             : signal-cmb            : iobroker                                 -  enabled
      system.adapter.smartmeter.0             : smartmeter            : iobroker                                 - disabled
      system.adapter.solarwetter.0            : solarwetter           : iobroker                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.sonoff.1                 : sonoff                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
      system.adapter.sprinklecontrol.0        : sprinklecontrol       : iobroker                                 - disabled
      system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5000
    + system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.terminal.0               : terminal              : iobroker                                 - disabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
      system.adapter.time-switch.0            : time-switch           : iobroker                                 - disabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled
      system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
      system.adapter.web-speedy.0             : web-speedy            : iobroker                                 - disabled
      system.adapter.web.1                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
    + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.yeelight-2.0             : yeelight-2            : iobroker                                 - disabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
    Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "bshb"         : 0.2.7    , installed 0.2.7
    Adapter    "chromecast"   : 3.2.0    , installed 3.2.0
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
    Adapter    "evcc"         : 0.1.1    , installed 0.1.1
    Adapter    "firetv"       : 2.0.2    , installed 2.0.2
    Adapter    "followthesun" : 0.5.0    , installed 0.5.0
    Adapter    "fullybrowser" : 3.0.11   , installed 3.0.11
    Adapter    "go-e"         : 1.0.29   , installed 1.0.29
    Adapter    "heatingcontrol": 2.12.3  , installed 2.12.3
    Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
    Adapter    "hue"          : 3.10.2   , installed 3.10.2
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "influxdb"     : 4.0.2    , installed 3.2.0  [Updatable]
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.17 [Updatable]
    Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
    Adapter    "megaesp"      : 0.1.0    , installed 0.1.0
    Adapter    "mihome-vacuum": 4.1.1    , installed 4.1.1
    Adapter    "modbus"       : 6.1.0    , installed 6.1.0
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "node-red"     : 5.1.0    , installed 5.1.0
    Adapter    "notification-manager": 1.0.0, installed 1.0.0
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "proxmox"      : 2.2.3    , installed 2.2.3
    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
    Adapter    "radar2"       : 2.1.0    , installed 2.1.0
    Adapter    "reolink"      : 1.0.3    , installed 1.0.3
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "solarwetter"  : 1.1.5    , installed 1.1.5
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "telegram"     : 3.1.0    , installed 3.1.0
    Adapter    "telegram-menu": 1.5.1    , installed 1.5.1
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 3.2.0    , installed 3.2.0
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "unifi"        : 0.6.7    , installed 0.6.7
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-2-widgets-gauges": 1.0.2, installed 1.0.2
    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
    Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "yeelight-2"   : 1.3.1    , installed 1.3.1
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Objects and States
    Objects:        120296
    States:         93115
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 30
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       17813483   4166491/node-red
    tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       17814072   4166094/io.shelly.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17813696   4166120/io.sonoff.1
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17814533   4166055/io.mqtt.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       17813328   4166095/io.sonoff.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13290      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15279      452/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17811245   4165726/iobroker.js
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17811571   4165726/iobroker.js
    tcp6       0      0 :::111                  :::*                    LISTEN      0          13293      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15290      452/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17812502   4165751/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17813993   4166381/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       17813974   4166382/io.ws.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13412      1/init
    udp6       0      0 :::111                  :::*                                0          13415      1/init
    2024-03-05 12:07:15.931  - info: javascript.0 (4165800) script.js.common.Gaszähler: + 0.005
    2024-03-05 12:07:15.931  - info: javascript.0 (4165800) script.js.common.Gaszähler: 7020.875
    2024-03-05 12:07:16.690  - info: javascript.0 (4165800) script.js.common.Gaszähler:  in Brennwert
    2024-03-05 12:07:16.691  - info: javascript.0 (4165800) script.js.common.Gaszähler: 76391.547
    2024-03-05 12:07:16.691  - info: javascript.0 (4165800) script.js.common.Gaszähler: 7020.875
    2024-03-05 12:07:16.692  - info: javascript.0 (4165800) script.js.common.Gaszähler: 76391.6014245125
    2024-03-05 12:07:16.692  - info: javascript.0 (4165800) script.js.common.Gaszähler: Brennwert kWh in DP geschieben
    2024-03-05 12:07:21.867  - debug: shelly.0 (4166094) [createObjects] Finished object creation of  (undefined / undefined / undefined)
    2024-03-05 12:07:21.868  - debug: shelly.0 (4166094) [MQTT] Last will for client id "shellyplus2pm-d48afc7cfa64" saved: {"retain":true,"qos":0,"topic":"shellyplus2pm-d48afc7cfa64/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}}
    2024-03-05 12:07:21.868  - debug: shelly.0 (4166094) [setIP] New IP for device undefined: 192.168.0.5 (source: MQTT connect)
    2024-03-05 12:07:21.885  - error: shelly.0 (4166094) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-d48afc7cfa64"
    2024-03-05 12:07:26.494  - debug: shelly.0 (4166094) [MQTT Server] New connection from 192.168.0.5
    2024-03-05 12:07:26.496  - debug: shelly.0 (4166094) [MQTT] Client connected: {"cmd":"connect","retain":false,"qos":0,"dup":false,"length":94,"topic":null,"payload":null,"protocolId":"MQTT","protocolVersion":4,"will":{"retain":true,"qos":0,"topic":"shellyplus2pm-d48afc7cfa64/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}},"clean":true,"keepalive":60,"clientId":"shellyplus2pm-d48afc7cfa64","username":"admin","password":{"type":"Buffer","data":[97,100,109,105,110]}}
    2024-03-05 12:07:26.496  - debug: shelly.0 (4166094) [BaseClient] Destroying 192.168.0.5 (undefined / undefined / undefined)
    2024-03-05 12:07:26.497  - debug: shelly.0 (4166094) [MQTT] Destroying
    2024-03-05 12:07:26.497  - info: shelly.0 (4166094) [MQTT] Device with client id "shellyplus2pm-d48afc7cfa64" connected!
    2024-03-05 12:07:26.644  - debug: shelly.0 (4166094) Configured device mode of  (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1) by state "shellyplus2pm#d48afc7cfa64#1.Sys.deviceMode" (fallback): cover
    2024-03-05 12:07:29.985  - debug: shelly.0 (4166094) [createObjects] Starting object creation of  (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1) for mode: cover
    2024-03-05 12:07:31.497  - info: javascript.0 (4165800) Stop script script.js.common.Beleuchtung_HUE
    2024-03-05 12:07:31.641  - info: javascript.0 (4165800) script.js.common.Gaszähler: + 0.005
    2024-03-05 12:07:31.641  - info: javascript.0 (4165800) script.js.common.Gaszähler: 7020.88
    2024-03-05 12:07:31.665  - debug: shelly.0 (4166094) [onlineCheck] Checking shellyplus2pm#d48afc7cfa64#1 on 192.168.0.5:80
    2024-03-05 12:07:31.681  - debug: shelly.0 (4166094) [deviceStatusUpdate] shellyplus2pm#d48afc7cfa64#1: true
    2024-03-05 12:07:31.835  - debug: shelly.0 (4166094) [onlineCheck] Checking shellyplus1pm#d48afc597dfc#1 on 192.168.0.53:80
    NUC, PROXMOX, Grafana, Influx, Unify
    • T toki1973
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Chassis: vm 🖴
        Virtualization: kvm
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 4
                    NTP service: active
                RTC in local TZ: no
      toki
      /home/toki
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
               6051 M total memory
               3841 M used memory
                527 M active memory
               1317 M free memory
                240 M buffer memory
                943 M swap cache
                974 M total swap
                  3 M used swap
                971 M free swap
      *** FILESYSTEM ***
      /var:
      589M    /var/
      246M    /var/cache
      239M    /var/cache/apt
      172M    /var/lib
      171M    /var/log
      USB-Devices by-id:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.13.16
      javascript:     7.8.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        120296
      States:         93115
      Pending Updates: 30
      Pending Updates: 30
      Patches einspielen, gilt auch für den ioBroker-Bereich.
      Bei Zigbee nicht /dev/ttyACM0 sondern den richtigen Link von hier verwenden:
      T 2 Antworten Letzte Antwort
        Pending Updates: 30
        toki1973
        @thomas-braun Ja mache ich gleich - ich war auf dem Weg dahin - habe iob gestopt, iob fix und dann starten wollen bevor ich die Updates über
        sudo apt update
        sudo apt dist-upgrade
        sudo reboot
        machen wollte - siehst du die Ursache des Multihosts?
          Pending Updates: 30
          toki1973
          @thomas-braun said in Mulitihost:
          Pending Updates: 30
          In den zigbee Instanz das einstellen?
          • T toki1973
            Pending Updates: 30
            Ja, eines der beiden Interfaces. Vermutlich if00.
            • T toki1973
              sudo apt update
              sudo reboot
              HomoranH Offline
              HomoranH Offline
              nein!
              aber hast du 2 zigbee-sticks am Rechner?
              T Thomas BraunT 2 Antworten Letzte Antwort
                nein!
                toki1973
                @homoran Nein ich habe nur einen
                  toki1973
                  @thomas-braun Das wird wohl nur verkürzt angezeigt
                  • T toki1973
                    @toki1973
                    Nein. Trag da den vollständigen Pfad ein:
                    • T toki1973
                      HomoranH Offline
                      HomoranH Offline
                      nein, du hast es verkürzt eingetragen.
                      nach einem Neustart können sich die Ports ändern, deswegen auf das eindeutige device mappen!
                        nein!
                        @homoran sagte in Mulitihost:
                        Nein, aber einen mit zwei Interfaces.
                          toki1973
                          @thomas-braun ich habe mal den USB Port gewechselt - vlt. daher
                          • T toki1973
                            @toki1973
                            Und genau solche Aktionen laufen glatter, wenn man by-id nimmt. Die Geräte Datei kann sich nämlich dann ändern, die ID nicht.
                            Kiste durchgepatcht?
                            iob diag
                            Schau nun wie aus?
                              @toki1973
                              iob diag
                              Schau nun wie aus?
                              toki1973
                              @thomas-braun Ja sieht nun besser aus.
                              Anderes Thema das ich eigentlich dachte das sich nach einem Reboot löst. Ich bekomme ein neues hue0 Objekt unter Objecte angezeigt. Wenn ich einen Datenpunkt des Objektes in Blockly einbinden will erscheint er aber nicht im Objektauswahl Dialog. Wie kann man das aktualisieren?
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                       Chassis: vm 🖴
                                Virtualization: kvm
                                        Kernel: Linux 6.1.0-18-amd64
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : amd64
                               15:20:27 up 37 min,  2 users,  load average: 2.62, 2.10, 2.03
                              CPU threads: 4
                                             Local time: Tue 2024-03-05 15:20:27 CET
                                         Universal time: Tue 2024-03-05 14:20:27 UTC
                                               RTC time: Tue 2024-03-05 14:20:27
                                            NTP service: active
                                        RTC in local TZ: no
                              toki
                              /home/toki
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            6.3G        4.5G        1.5G        585K        677M        1.9G
                              Swap:           1.0G          0B        1.0G
                              Total:          7.4G        4.5G        2.5G
                                       6051 M total memory
                                       4244 M used memory
                                        339 M active memory
                                       4035 M inactive memory
                                       1393 M free memory
                                         53 M buffer memory
                                        591 M swap cache
                                        974 M total swap
                                          0 M used swap
                                        974 M free swap
                              *** FILESYSTEM ***
                              /dev/sda1      ext4       31G  7.3G   22G  26% /
                              [Tue Mar  5 14:43:21 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                              [Tue Mar  5 14:43:24 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
                              /var:
                              604M    /var/
                              246M    /var/cache
                              239M    /var/cache/apt
                              185M    /var/log
                              172M    /var/lib
                              Archived and active journals take up 28.4M in the file system.
                              952M    /opt/iobroker/iobroker-data/
                              107M    /opt/iobroker/iobroker-data/states.jsonl
                              83M     /opt/iobroker/iobroker-data/objects.jsonl
                              USB-Devices by-id:
                              /usr/bin/nodejs         v18.19.1
                              /usr/bin/node           v18.19.1
                              /usr/bin/npm            10.2.4
                              /usr/bin/npx            10.2.4
                              nodejs:
                                Installed: 18.19.1-1nodesource1
                                Version table:
                               *** 18.19.1-1nodesource1 1001
                                   18.13.0+dfsg1-1 500
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.13.16
                              javascript:     7.8.0
                              Adapter State
                              + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__02.03.00.18__Embed_with_CMSIS-DAP_L1100C1R-if00
                              + instance is alive
                              Objects and States
                              Objects:        120048
                              States:         92869
                              Pending Updates: 0
                              tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       18505      1111/node-red
                              tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       19542      723/io.shelly.0
                              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17118      755/io.sonoff.1
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18514      718/io.mqtt.0
                              tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       17099      744/io.sonoff.0
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16180      431/iobroker.js-con
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16187      431/iobroker.js-con
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13366      1/init
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14070      451/sshd: /usr/sbin
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17339      484/io.admin.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18735      1009/io.web.0
                              tcp6       0      0 :::8084                 :::*                    LISTEN      1001       18717      1020/io.ws.0
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          13369      1/init
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          14072      451/sshd: /usr/sbin
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14348      1/init
                              udp6       0      0 :::111                  :::*                                0          14351      1/init
                              2024-03-05 15:23:05.050  - debug: shelly.0 (723) [MQTT] State change 192.168.0.5 (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1): shellyplus2pm-d48afc7cfa64/status/cover:0 -> state: shellyplus2pm#d48afc7cfa64#1.Cover0.temperatureC, value: 46.6
                              2024-03-05 15:23:09.557  - info: javascript.0 (564) script.js.common.Gaszähler: + 0.005
                              2024-03-05 15:23:09.573  - info: javascript.0 (564) script.js.common.Gaszähler: 7026.32
                              2024-03-05 15:23:09.615  - debug: shelly.0 (723) [httpIoBrokerState] State change 192.168.0.5 (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1): state: shellyplus2pm#d48afc7cfa64#1.uptime, value: 338374
                              2024-03-05 15:23:09.616  - debug: shelly.0 (723) [httpIoBrokerState] State change 192.168.0.5 (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1): state: shellyplus2pm#d48afc7cfa64#1.rssi, value: -75
                              2024-03-05 15:23:09.684  - warn: shelly.0 (723) [authEnabled] 192.168.0.5 (shellyplus2pm / shellyplus2pm-d48afc7cfa64 / shellyplus2pm#d48afc7cfa64#1): This device is not protected via restricted login (see adapter documentation for details)
                              2024-03-05 15:23:10.259  - info: javascript.0 (564) script.js.common.Gaszähler:  in Brennwert
                              2024-03-05 15:23:10.259  - info: javascript.0 (564) script.js.common.Gaszähler: 76450.792
                              2024-03-05 15:23:10.259  - info: javascript.0 (564) script.js.common.Gaszähler: 7026.32
                              2024-03-05 15:23:10.260  - info: javascript.0 (564) script.js.common.Gaszähler: 76450.846500056
                              2024-03-05 15:23:10.260  - info: javascript.0 (564) script.js.common.Gaszähler: 76450.847
                              2024-03-05 15:23:10.260  - info: javascript.0 (564) script.js.common.Gaszähler: Brennwert kWh in DP geschieben
                              2024-03-05 15:23:11.839  - info: sonoff.1 (755) State value to set for "sonoff.1.SugerValley.NeoPool_pH_Data" has to be type "string" but received type "number"
                              2024-03-05 15:23:12.126  - info: sonoff.1 (755) State value to set for "sonoff.1.SugerValley.NeoPool_Redox_Data" has to be type "string" but received type "number"
                              2024-03-05 15:23:12.183  - info: sonoff.1 (755) State value to set for "sonoff.1.SugerValley.NeoPool_Hydrolysis_Data" has to be type "string" but received type "number"
                              2024-03-05 15:23:13.772  - info: sonoff.0 (744) Client [GosBlitzw_EP2] reconnected. Old secret 1709648189940_2039. New secret 1709648593772_7398
                              2024-03-05 15:23:13.854  - info: admin.0 (484) ==> Connected system.user.admin from ::ffff:192.168.0.148
                              2024-03-05 15:23:14.084  - info: javascript.0 (564) script.js.common.Gaszähler: + 0.005
                              2024-03-05 15:23:14.085  - info: javascript.0 (564) script.js.common.Gaszähler: 7026.325
                              2024-03-05 15:23:14.480  - info: javascript.0 (564) script.js.common.Gaszähler:  in Brennwert
                              2024-03-05 15:23:14.480  - info: javascript.0 (564) script.js.common.Gaszähler: 76450.847
                              2024-03-05 15:23:14.481  - info: javascript.0 (564) script.js.common.Gaszähler: 7026.325
                              2024-03-05 15:23:14.484  - info: javascript.0 (564) script.js.common.Gaszähler: 76450.90090324749
                              2024-03-05 15:23:14.485  - info: javascript.0 (564) script.js.common.Gaszähler: 76450.901
                              2024-03-05 15:23:14.485  - info: javascript.0 (564) script.js.common.Gaszähler: Brennwert kWh in DP geschieben
                              • T toki1973
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                         Chassis: vm 🖴
                                  Virtualization: kvm
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : amd64
                                CPU threads: 4
                                              NTP service: active
                                          RTC in local TZ: no
                                toki
                                /home/toki
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:           1.0G          0B        1.0G
                                         6051 M total memory
                                         4244 M used memory
                                          339 M active memory
                                         1393 M free memory
                                           53 M buffer memory
                                          591 M swap cache
                                          974 M total swap
                                            0 M used swap
                                          974 M free swap
                                *** FILESYSTEM ***
                                /var:
                                604M    /var/
                                246M    /var/cache
                                239M    /var/cache/apt
                                185M    /var/log
                                172M    /var/lib
                                USB-Devices by-id:
                                /usr/bin/npm            10.2.4
                                /usr/bin/npx            10.2.4
                                nodejs:
                                  Version table:
                                     18.13.0+dfsg1-1 500
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.13.16
                                javascript:     7.8.0
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        120048
                                States:         92869
                                Pending Updates: 0
                                @toki1973
                                sudo usermod -a -G adm toki
                                sudo systemctl set-default multi-user.target
                                Und bring den js-controller und den influxdb-Adapter auf Stand.
                                  @toki1973
                                  toki1973
                                  @thomas-braun Vielen Dank!
