  4. Backup wiederherstellen
95 Beiträge 9 Kommentatoren 19.7k Aufrufe 7 Beobachtet
  • P Pistus
    @thomas-braun ```Ein Auszug aus dem Log
    2024-02-23 19:04:00.638 info ==> Connected system.user.admin from ::ffff:192.168.178.37
    admin.0
    2024-02-23 19:03:55.121 info failed connection to socket.io from ::ffff:192.168.178.37: Passport was not initialized
    backitup.0
    2024-02-23 18:58:02.429 error umount: /opt/iobroker/backups: not mounted.
    admin.0
    2024-02-23 18:56:54.343 info <== Disconnect system.user.admin from ::ffff:192.168.178.37 admin
    admin.0
    2024-02-23 18:56:26.656 info <== Disconnect system.user.admin from ::ffff:192.168.178.37
    admin.0
    2024-02-23 18:56:20.153 info ==> Connected system.user.admin from ::ffff:192.168.178.37
    admin.0
    2024-02-23 18:56:14.237 info ==> Connected system.user.admin from ::ffff:192.168.178.37
    discovery.0
    2024-02-23 18:56:03.550 info starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.1, js-controller: 5.0.19
    backitup.0
    2024-02-23 18:56:02.432 error Error: Command failed: sudo mount -t cifs -o username=fritz1221,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backupsmount error(16): Device or resource busyRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
    admin.0
    2024-02-23 18:56:01.418 info failed connection to socket.io from ::ffff:192.168.178.37: Passport was not initialized
    backitup.0
    2024-02-23 18:55:59.570 info [iobroker] backup will be activated at 02:48 every 1 day(s)
    backitup.0
    2024-02-23 18:55:59.484 warn Cannot read log file: Error: UNKNOWN: unknown error, open '/opt/iobroker/backups/logs.txt'
    backitup.0
    2024-02-23 18:55:59.159 info starting. Version 2.10.11 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.1, js-controller: 5.0.19
    #82
    @pistus
    FritzNAS benötigt die beiden Optionen 'noserverino' und 'cache loose'.
    Siehe Anleitungen zu Backitup.
    Meine Einstellungen:
    P 1 Antwort Letzte Antwort
      @pistus
      Pistus
      #83
      @thomas-braun Restore wurde ausgeführt. Fast alle instanzen wurden grün. Die letzten 2, vis und web, da musste ich den Platz am PC verlassen. Als ich zurück kam, war mein PC im Schlafmodus. Als ich durch Tastendruck den PC aufgeweckt habe lief der blaue Kreis und ioBroker wurde abgeschaltet. Wenn ich die URL von ioBroker starte wird die URL mit den´m Pfad instanzen ergänzt. Im ioBroker erscheint das Anmeldefenster, aber startet nicht. Jetzt wollte ich die URL kopieren und hier einsetzen, aber jetzt kommt auch nicht mehr das Anmeldefenster.
      • P Pistus
        #84
        @pistus sagte in Backup wiederherstellen:
        Kann ja gar nicht sein, weil auf einem Server gar kein Desktop Environment läuft...
        iob diag
        sagt?
          iob diag
          sagt?
          Pistus
          schrieb am zuletzt editiert von Pistus
          #85
          Die vielen Seiten vorher konnte ich nicht kopieren
          v.2023-10-10
             Static hostname: raspberrypi
                   Icon name: computer
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Installation: 		native
          Kernel: 		aarch64
          Userland: 		arm64
          Timezone: 		Europe/Berlin (CET, +0100)
          User-ID: 		1000
          X-Server: 		true
          Boot Target: 		graphical.target
          Pending OS-Updates: 	0
          Pending iob updates: 	6
          Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
          			/usr/bin/node 		v18.19.1
          			/usr/bin/npm 		10.2.4
          			/usr/bin/npx 		10.2.4
          			/usr/bin/corepack 	0.22.0
          Recommended versions are nodejs 16.20.2 and npm 8.19.4
          MEMORY:
          Mem:            909M        691M         94M        0.0K        123M        158M
          Swap:            99M         99M        0.0K
          Total:          1.0G        791M         94M
          Active iob-Instances: 	10
          Active repo(s): stable
          ioBroker Core: 		js-controller 		5.0.19
          			admin 			6.3.5
          ioBroker Status: 	iobroker is running on this host.
          Objects type: jsonl
          States  type: jsonl
          Objects: 		466
          States: 		373
          Size of iob-Database:
          19M	/opt/iobroker/iobroker-data/objects.jsonl
          5.6M	/opt/iobroker/iobroker-data/states.jsonl
          === Mark text until here for copying ===
          Jetzt funktioniert der ioBroker. Alle Instanzen sind grün.
          • P Pistus
            v.2023-10-10
                     Icon name: computer
                  Architecture: arm64
            Kernel: 		aarch64
            Userland: 		arm64
            User-ID: 		1000
            X-Server: 		true
            			/usr/bin/npm 		10.2.4
            			/usr/bin/npx 		10.2.4
            MEMORY:
            Swap:            99M         99M        0.0K
            			admin 			6.3.5
            Objects type: jsonl
            States  type: jsonl
            Objects: 		466
            States: 		373
            #86
            Das sind keine Seiten, das ist eine Ausgabe.
            Und auf einen Rechner mit mageren 1GB RAM schleift man nicht auch noch eine graphische Oberfläche mit.
            Und sonst auch nicht...
            sudo systemctl set-default multi-user.target
            sudo reboot
              sudo reboot
              Pistus
              #87
              Moin Thomas, für mich iist das alles Neuland. Außerdem denke ich, daß es keinen oder nur ganz wenige User hier im Forum gibt, die älter sind als ich. Das bitte ich etwas zu berücksichtigen.
              Wie bekomme ich das System den abgespeckt?
              Soll ich die beiden Befehle ausführen? Was meinst Du mit 'Und sonst auch nicht...
              Danke für Deine Geduld und Hilfe
              • P Pistus
                #88
                Ja, die beiden Befehle führen dazu, dass die graphische Oberfläche nicht geladen wird.
                Man hat sowas grundsätzlich nicht auf einem Server laufen und auf schmalbrüstigen 1GB RAM schon gerade nicht.
                  Pistus
                  #89
                  Befehl ausgeführt.
                  oberhalb der Insztanzen steht folgender Text:
                  Freier Festplattenspeicher: 82%, Gesamte RAM-Auslastung: 1022 Mb / Frei: 10% = 87 Mb [Server: raspberrypi - 10 Prozesse]
                  Der Ram Speicher ist voll?
                  Was sagt diese Meldung in der LOG
                  host.raspberrypi
                  2024-02-24 12:32:02.760	error	Error by updating repository "stable" under "http://download.iobroker.net/sources-dist.json": Cannot download repository file from "http://download.iobroker.net/sources-dist.json": connect EHOSTUNREACH 93.90.206.45:80
                  • P Pistus
                    Befehl ausgeführt.
                    host.raspberrypi
                    #90
                    Der Server antwortet nicht/kann nicht erreicht werden.
                    Bei 1GB und laufendem Desktop ist das leicht möglich. Kann man aber da nicht richtig draus ablesen.
                    Schau die vollständige Ausgabe von
                    iob diag
                    an.
                      iob diag
                      an.
                      Pistus
                      #91
                      @thomas-braun Hallo Thomas,
                      ich habe mir einen neuen Raspberry4 mit 8G Arbeitsspeicher gekauft und auch schon installiert.
                      Jetzt wollte ich das mit dem Raspi3 erstellte Backup auf dem neuen Raspi wieder herstellen. Ist das machbar? Es erscheint folgende Error Meldung
                      	Error: Command failed: sudo mount -t cifs -o username=fritz1221,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backupsmount error(16): Device or resource busyRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                      Hier meine Einstellungen
                      • P Pistus
                        HomoranH Offline
                        HomoranH Offline
                        #92
                        Ist das machbar?
                        klar!
                        und der Pfad stimmt?
                        • P Pistus
                          #93
                          @pistus
                          Natürlich ist das machbar. Da scheint aber schon ein Mount vorhanden zu sein. Oder du stehst im Verzeichnis drin.
                          mount
                          sagt?
                            @pistus
                            mount
                            sagt?
                            Pistus
                            #94
                            Im Hauptverzeichnis gibt es den Backup Button. Über den Wiederherstellungsbutton wurden die Sicherungsdateien angezeigt.
                            Ich habe das Gefühl das System sichert Local und auf dem fritz.nas.
                            Wenn ich local auswähle, werden auch alle Sicherungsdateien angezeigt
                            permitted by applicable law.
                            Last login: Mon Mar  4 13:56:46 2024 from 192.168.178.37
                            iobroker@iobroker:~ $ mount
                            sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
                            proc on /proc type proc (rw,relatime)
                            udev on /dev type devtmpfs (rw,nosuid,relatime,size=3729648k,nr_inodes=932412,mo        de=755)
                            devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmod        e=000)
                            tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=799872k,mode=755)
                            /dev/mmcblk0p2 on / type ext4 (rw,noatime)
                            securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relat        ime)
                            tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
                            tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
                            cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelega        te,memory_recursiveprot)
                            pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
                            bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
                            systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,time        out=0,minproto=5,maxproto=5,direct,pipe_ino=13380)
                            mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
                            debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
                            tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
                            configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
                            fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatim        e)
                            ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noe        xec,relatime,mode=700)
                            ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,n        oexec,relatime,mode=700)
                            ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosu        id,nodev,noexec,relatime,mode=700)
                            /dev/mmcblk0p1 on /boot/firmware type vfat (rw,relatime,fmask=0022,dmask=0022,co        depage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
                            ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,n        odev,noexec,relatime,mode=700)
                            binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec        ,relatime)
                            sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
                            tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=799872k,nr_ino        des=199968,mode=700,uid=1000,gid=1000)
                            • P Pistus
                              #95
                              Jein, bei CIFS wird das entfernte Dateisystem auf dem Mountpunkt /opt/iobroker/backups eingehängt. Das Backup erfolgt dann 'lokal' in genau dieses Verzeichnis, physisch ist es aber natürlich auf dem Datenträger, der an der FritzBox angeflanscht ist.
                              Wenn das Dateisystem gerade nicht eingehängt wurde ist das Verzeichnis/der Mountpunkt dann auch leer.
