  4. RasPi 5, 8 GB überlastet
55 Beiträge 12 Kommentatoren 5.9k Aufrufe 8 Beobachtet
  • T tcfigge
    @da_woody
    diag
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobrokerberry
           Icon name: computer
              Kernel: Linux 6.1.0-rpi8-rpi-2712
        Architecture: arm64
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     14:00:13 up 22:14,  2 users,  load average: 1.38, 0.67, 0.54
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2024-02-25 14:00:16 CET
               Universal time: Sun 2024-02-25 13:00:16 UTC
                     RTC time: Sun 2024-02-25 13:00:16
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    thorsten
    /home/thorsten
    thorsten adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            8.4G        6.7G        696M        4.6M        1.1G        1.7G
    Swap:           104M        104M        229K
    Total:          8.5G        6.8G        696M
             8053 M total memory
             6429 M used memory
             5362 M active memory
             1290 M inactive memory
              653 M free memory
               68 M buffer memory
             1002 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    Raspberry only:
    vc_gencmd_read_response returned -1
    error=1 error_msg="Command not registered"
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  3.8G     0  3.8G   0% /dev
    tmpfs          tmpfs     806M  5.1M  801M   1% /run
    /dev/mmcblk0p2 ext4      117G  6.9G  105G   7% /
    tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
    /dev/sda1      vfat      7.7G  364M  7.4G   5% /mnt/usb0
    tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
    [Sat Feb 24 15:45:22 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:DE:3B:E7 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=044a845b-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sat Feb 24 15:45:25 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Feb 24 15:45:26 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    |-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/mnt/usb0      /dev/sda1      vfat   rw,nosuid,nodev,noexec,relatime,fmask=0000,dmask=0000,allow_utime=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1005M   /var/
    608M    /var/lib
    444M    /var/lib/redis
    203M    /var/cache
    197M    /var/cache/apt
    Archived and active journals take up 89.3M in the file system.
    /opt/iobroker/backups:
    423M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    685M    /opt/iobroker/iobroker-data/
    341M    /opt/iobroker/iobroker-data/files
    157M    /opt/iobroker/iobroker-data/backup-objects
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    151M    /opt/iobroker/iobroker-data/objects.jsonl
    38M     /opt/iobroker/iobroker-data/states.jsonl
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.1
    /usr/bin/node           v18.19.1
    /usr/bin/npm            10.2.4
    /usr/bin/npx            10.2.4
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.1-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
     *** 18.19.1-1nodesource1 600
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
         18.19.0-1nodesource1 600
         18.18.2-1nodesource1 600
         18.18.1-1nodesource1 600
         18.18.0-1nodesource1 600
         18.17.1-1nodesource1 600
         18.17.0-1nodesource1 600
         18.16.1-1nodesource1 600
         18.16.0-1nodesource1 600
         18.15.0-1nodesource1 600
         18.14.2-1nodesource1 600
         18.14.1-1nodesource1 600
         18.14.0-1nodesource1 600
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 600
         18.12.0-1nodesource1 600
         18.11.0-1nodesource1 600
         18.10.0-1nodesource1 600
         18.9.1-1nodesource1 600
         18.9.0-1nodesource1 600
         18.8.0-1nodesource1 600
         18.7.0-1nodesource1 600
         18.6.0-1nodesource1 600
         18.5.0-1nodesource1 600
         18.4.0-1nodesource1 600
         18.3.0-1nodesource1 600
         18.2.0-1nodesource1 600
         18.1.0-1nodesource1 600
         18.0.0-1nodesource1 600
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: redis
    States  type: redis
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   5
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobrokerberry                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobrokerberry                            -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobrokerberry                            -  enabled
    + system.adapter.backitup.0               : backitup              : iobrokerberry                            -  enabled
      system.adapter.birthdays.0              : birthdays             : iobrokerberry                            -  enabled
    + system.adapter.bring.0                  : bring                 : iobrokerberry                            -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : iobrokerberry                            -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobrokerberry                            -  enabled
    + system.adapter.countdown.0              : countdown             : iobrokerberry                            -  enabled
      system.adapter.daswetter.0              : daswetter             : iobrokerberry                            -  enabled
      system.adapter.devices.0                : devices               : iobrokerberry                            -  enabled
    + system.adapter.discovery.0              : discovery             : iobrokerberry                            -  enabled
      system.adapter.dwd.0                    : dwd                   : iobrokerberry                            -  enabled
    + system.adapter.email.0                  : email                 : iobrokerberry                            -  enabled
      system.adapter.feiertage.0              : feiertage             : iobrokerberry                            -  enabled
      system.adapter.flot.0                   : flot                  : iobrokerberry                            - disabled
    + system.adapter.followthesun.0           : followthesun          : iobrokerberry                            -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobrokerberry                            -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobrokerberry                            -  enabled, port: 2001
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobrokerberry                            -  enabled, port: 0
    + system.adapter.hm-rpc.3                 : hm-rpc                : iobrokerberry                            -  enabled, port: 0
    + system.adapter.hoover.0                 : hoover                : iobrokerberry                            -  enabled
    + system.adapter.hue.0                    : hue                   : iobrokerberry                            -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : iobrokerberry                            -  enabled
      system.adapter.ical.1                   : ical                  : iobrokerberry                            -  enabled
      system.adapter.ical.2                   : ical                  : iobrokerberry                            -  enabled
      system.adapter.ical.3                   : ical                  : iobrokerberry                            -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobrokerberry                            - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobrokerberry                            - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobrokerberry                            - disabled
    + system.adapter.iot.0                    : iot                   : iobrokerberry                            -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : iobrokerberry                            -  enabled
    + system.adapter.javascript.0             : javascript            : iobrokerberry                            -  enabled
    + system.adapter.javascript.1             : javascript            : iobrokerberry                            -  enabled
    + system.adapter.linkeddevices.0          : linkeddevices         : iobrokerberry                            -  enabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : iobrokerberry                            -  enabled
      system.adapter.modbus.0                 : modbus                : iobrokerberry                            - disabled
      system.adapter.mqtt.0                   : mqtt                  : iobrokerberry                            - disabled, port: 1883, bind: 10.10.5.5
    + system.adapter.mytime.0                 : mytime                : iobrokerberry                            -  enabled
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobrokerberry                            - disabled
      system.adapter.openweathermap.0         : openweathermap        : iobrokerberry                            -  enabled
    + system.adapter.parcel.0                 : parcel                : iobrokerberry                            -  enabled
    + system.adapter.ping.0                   : ping                  : iobrokerberry                            -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : iobrokerberry                            -  enabled
    + system.adapter.ring.0                   : ring                  : iobrokerberry                            -  enabled
    + system.adapter.shelly.0                 : shelly                : iobrokerberry                            -  enabled, port: 1882, bind: 10.10.3.2
    + system.adapter.simple-api.0             : simple-api            : iobrokerberry                            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : iobrokerberry                            -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sql.0                    : sql                   : iobrokerberry                            -  enabled, port: 3307
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobrokerberry                            -  enabled
      system.adapter.tapo.0                   : tapo                  : iobrokerberry                            - disabled
    + system.adapter.telegram.0               : telegram              : iobrokerberry                            -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobrokerberry                            -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.10              : telegram              : iobrokerberry                            -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.11              : telegram              : iobrokerberry                            -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.12              : telegram              : iobrokerberry                            -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.13              : telegram              : iobrokerberry                            -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.2               : telegram              : iobrokerberry                            -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.3               : telegram              : iobrokerberry                            -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.4               : telegram              : iobrokerberry                            -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.5               : telegram              : iobrokerberry                            -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.6               : telegram              : iobrokerberry                            -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.7               : telegram              : iobrokerberry                            -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.8               : telegram              : iobrokerberry                            -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.9               : telegram              : iobrokerberry                            -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : iobrokerberry                            -  enabled
    + system.adapter.text2command.1           : text2command          : iobrokerberry                            -  enabled
    + system.adapter.text2command.2           : text2command          : iobrokerberry                            -  enabled
    + system.adapter.text2command.3           : text2command          : iobrokerberry                            -  enabled
    + system.adapter.text2command.4           : text2command          : iobrokerberry                            -  enabled
    + system.adapter.text2command.5           : text2command          : iobrokerberry                            -  enabled
    + system.adapter.todoist2.0               : todoist2              : iobrokerberry                            -  enabled
    + system.adapter.traccar.0                : traccar               : iobrokerberry                            -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobrokerberry                            -  enabled
    + system.adapter.unifi.0                  : unifi                 : iobrokerberry                            -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobrokerberry                            - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobrokerberry                            - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobrokerberry                            - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobrokerberry                            - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobrokerberry                            -  enabled
      system.adapter.vis-map.0                : vis-map               : iobrokerberry                            - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobrokerberry                            - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobrokerberry                            - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobrokerberry                            - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobrokerberry                            - disabled
      system.adapter.vis.0                    : vis                   : iobrokerberry                            -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : iobrokerberry                            -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobrokerberry                            -  enabled
    + system.adapter.web.0                    : web                   : iobrokerberry                            -  enabled, port: 8082, bind: 10.10.3.2, run as: admin
    + system.adapter.ws.0                     : ws                    : iobrokerberry                            -  enabled, port: 8097, bind: 0.0.0.0, run as: admin
      system.adapter.yr.0                     : yr                    : iobrokerberry                            -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
    Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "countdown"    : 2.2.0    , installed 2.2.0
    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "email"        : 1.2.2    , installed 1.2.2
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "followthesun" : 0.5.0    , installed 0.5.0
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
    Adapter    "hoover"       : 0.0.7    , installed 0.1.2
    Adapter    "hue"          : 3.10.2   , installed 3.10.2
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "modbus"       : 6.1.0    , installed 6.1.0
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "openweathermap": 1.0.4   , installed 1.0.4
    Adapter    "parcel"       : 0.0.27   , installed 0.0.27
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "ring"         : 5.0.10   , installed 5.0.10
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "tapo"         : 0.0.8    , installed 0.0.8
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "traccar"      : 1.1.4    , installed 1.1.4
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "unifi"        : 0.6.7    , installed 0.6.7
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
    Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.75
    Adapter    "vw-connect"   : 0.0.67   , installed 0.5.1
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    @tcfigge sagte: diag
    6,7 GB RAM + 104 MB Swap verbraucht: Das sieht nicht gesund aus.
    Prüfe mit top, welche Prozesse so viel RAM verbrauchen.
    • T tcfigge
      @da_woody sagte in Alias-Manager Adapter
      edith: oops
      JS Instanzen laufen mehrere.
      wie das?
      Einer Produktiv, und einer zum Spielen...
      da_WoodyD Online
      da_WoodyD Online
      @tcfigge sagte in Alias-Manager Adapter:
      auf einem raspi? naja. selbst dann wären es 2 und nicht mehrere.
        tcfigge
        top - 14:11:34 up 22:26,  1 user,  load average: 0.98, 8.30, 9.21
        Tasks: 196 total,   1 running, 195 sleeping,   0 stopped,   0 zombie
        top - 14:11:51 up 22:26,  1 user,  load average: 0.76, 7.89, 9.06
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   8053.7 total,   1389.5 free,   6267.6 used,    493.8 buff/cache
        MiB Swap:    100.0 total,      0.4 free,     99.6 used.   1786.1 avail Mem
            PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
          81832 iobroker  20   0 1426784 551728  15360 S   0.0   6.7   4:07.61 io.javascript.0
          81860 iobroker  20   0 1297168 535904  17168 S   0.0   6.5   3:58.38 io.javascript.1
            804 redis     20   0 1134192 513728   3088 S   0.0   6.2  63:22.86 redis-server
          81890 iobroker  20   0 1185696 307760  17760 S   0.0   3.7   3:06.83 io.admin.0
           2114 iobroker  20   0 1086768 236768  19392 S   0.0   2.9   0:32.49 io.tankerkoenig
            840 iobroker  20   0 5246528 151296  14352 S   0.0   1.8   2:53.59 iobroker.js-con
           2157 iobroker  20   0 5210160 134480  20496 S   0.0   1.6   7:19.37 io.ring.0
           2052 iobroker  20   0 5031344 114304  19104 S   0.0   1.4  27:52.29 io.traccar.0
           1949 iobroker  20   0  728352 111824  15024 S   0.0   1.4   1:24.50 io.linkeddevice
           1472 iobroker  20   0  973152 110528  16240 S   0.0   1.3   1:22.36 io.alexa2.0
           1332 iobroker  20   0  717024 104864  18240 S   0.0   1.3  11:00.25 io.shelly.0
           1837 iobroker  20   0 5173072  93600  13616 S   0.0   1.1   1:03.87 io.parcel.0
           1407 iobroker  20   0 4964288  92048  18176 S   0.0   1.1  10:13.11 io.unifi.0
           1438 iobroker  20   0 9362672  89488  14272 S   0.0   1.1   0:25.24 io.backitup.0
           1290 iobroker  20   0 4866928  88752  19376 S   0.0   1.1  14:59.02 io.hue.0
           1080 iobroker  20   0  788944  87008  16256 S   0.0   1.1   1:29.32 io.sql.0
           1668 iobroker  20   0  832080  84800  19328 S   0.0   1.0   0:26.16 io.iot.0
           1896 iobroker  20   0 5162160  82880  18832 S   0.0   1.0   0:37.24 io.hoover.0
          53476 iobroker  20   0  982992  81504  19264 S   0.0   1.0   0:19.52 io.telegram.9
          53434 iobroker  20   0  983264  81488  19312 S   0.0   1.0   0:19.85 io.telegram.4
          53465 iobroker  20   0  982896  81152  19248 S   0.0   1.0   0:19.44 io.telegram.8
          53427 iobroker  20   0  983504  80592  19120 S   0.0   1.0   0:19.54 io.telegram.7
          53509 iobroker  20   0  982528  80384  19312 S   0.0   1.0   0:20.06 io.telegram.2
          53455 iobroker  20   0  982464  80304  19184 S   0.0   1.0   0:20.19 io.telegram.13
          53448 iobroker  20   0  978784  80192  19360 S   0.0   1.0   0:19.48 io.telegram.6
          53467 iobroker  20   0  982848  80192  19248 S   0.0   1.0   0:19.44 io.telegram.5
          53486 iobroker  20   0  979744  79792  19424 S   0.0   1.0   0:19.50 io.telegram.1
          53508 iobroker  20   0  982848  79744  19248 S   0.0   1.0   0:19.20 io.telegram.11
          53441 iobroker  20   0  979520  79600  19312 S   0.0   1.0   0:19.96 io.telegram.3
          53466 iobroker  20   0  978384  78240  19392 S   0.0   0.9   0:19.71 io.telegram.12
          53507 iobroker  20   0  983744  77808  17216 S   0.0   0.9   0:19.53 io.telegram.10
          53469 iobroker  20   0  982976  77744  17344 S   0.0   0.9   0:19.41 io.telegram.0
           1529 iobroker  20   0  702336  75760  15264 S   0.0   0.9   1:15.05 io.hm-rpc.3
           2131 iobroker  20   0  956480  75744  17664 S   0.0   0.9   0:56.06 io.bring.0
           1791 iobroker  20   0  959168  75632  19136 S   0.0   0.9   0:35.80 io.vw-connect.0
           1544 iobroker  20   0  698432  73968  15824 S   0.0   0.9   2:21.12 io.hm-rpc.0
           1819 iobroker  20   0  825472  73824  14368 S   0.0   0.9   0:23.16 io.web.0
           1451 iobroker  20   0  695472  72704  15744 S   0.0   0.9   0:53.65 io.hm-rega.0
           1260 iobroker  20   0  694624  69744  14464 S   0.0   0.8   0:40.16 io.hm-rpc.2
           1516 iobroker  20   0 5150800  66480  16160 S   0.0   0.8   0:28.31 io.mielecloudse
           1612 iobroker  20   0  821888  66416  19536 S   0.0   0.8   0:24.84 io.cloud.0
           1582 iobroker  20   0  952192  65952  18528 S   0.0   0.8   0:29.28 io.todoist2.0
           1774 iobroker  20   0  713120  64736  14704 S   0.0   0.8   0:25.76 io.simple-api.0
           2025 iobroker  20   0  688528  64368  14272 S   0.0   0.8   0:21.64 io.followthesun
           1919 iobroker  20   0  689488  62160  14096 S   0.0   0.8   0:20.74 io.trashschedul
           1305 iobroker  20   0  688080  61472  14832 S   0.0   0.7   2:39.89 io.ping.0
           2097 iobroker  20   0  823520  60848  14192 S   0.0   0.7   0:21.17 io.pollenflug.0
        Hilft das?
        • T tcfigge
          Hilft das?
          @tcfigge sagte: Hilft das?
          Offenbar macht es die Menge der aktiven Instanzen, wobei Javascript mit zweimal mehr als 500 MB hervorsticht, was aber auch an der Menge der Objekte / Zustände liegen kann, die in jeder JS-Instanz gepuffert werden.
            tcfigge
            schrieb am zuletzt editiert von tcfigge
            @paul53 sagte in Alias-Manager Adapter:
            Kann ich irgendwie die Anzahl der Objekte und Instanzen auswerten?
            Gefühlt habe ich nicht so viele, aber was ist schon ein Gefühl, wenn man keine Ahnung hat...😊
            • T tcfigge
              @tcfigge sagte: Anzahl der Objekte und Instanzen auswerten?
              Im Tab "Objekte" rechts oben.
              Ich sehe ca. 60 aktive Instanzen!
              T 2 Antworten Letzte Antwort
                tcfigge
                Objekte: 162625, Zustände: 108228
                Ist das viel? Vielleicht sind meine Scripte aber auch unvorteilhaft programmiert... sind ja von mir :man-facepalming:
                • T tcfigge
                  @tcfigge sagte: Ist das viel?
                  Ja, sehr viel.
                    tcfigge
                    OK..... dann muss ich wohl mal abspecken... sind ja alleine 20 für Telegram.
                    wendy2702W CodierknechtC 2 Antworten Letzte Antwort
                      Ja, sehr viel.
                      tcfigge
                      Ja, sehr viel.
                      Pfffft..... Joa. Dann muß ich wohl auch da abspecken...
                      Die meisten braucht man eigentlich nicht. Beim Yr Adapter werden wahrscheinlich 2000 gehlot, ich brauch aber nur 5 davon. :man-shrugging:
                      • T tcfigge
                        ich versuche mich gerade in den Alias Manager einzuarbeiten...
                        Leider bekommen ich immer zwischendurch die Meldung >Seite reagiert nicht<
                        Also, wenn ich versuche einen Alias automatisch zu erstellen, meist das erste Mal beim Aufruf des Objektbaumes.
                        Aber auch immer wieder wenn ich die Datenpunkte editiere...
                        Dann dreht immer ne Weile der ioB Ladekreisel und dann geht es weiter...
                        Das macht die Arbeit noch langwieriger!
                        Ist das ein bekanntes Problem?
                        Arbeite auf einem Pi5.
                        System ist rundum aktuell.
                        Datenbank ist redis.
                        Danke vorab!
                        @Homoran
                        Trenne bitte ab hier ab. Titel z.B. "RasPi 5, 8 GB überlastet".
                          @Homoran
                          HomoranH Offline
                          HomoranH Offline
                          @paul53 erledigt!
                            Ja, sehr viel.
                            tcfigge
                            @paul53 sagte in RasPi 5, 8 GB überlastet:
                            Ja, sehr viel.
                            Noch eine Frage:
                            Am Beispiel des yr Adapters.
                            Der holt ja wirklich Daten ohne Ende!
                            Man sollte ja keine Ordner im Adapter löschen?
                            Dann bleibt mir aber nur, einfach Instanzen löschen und auf gewissen Daten zu verzichten?
                            Danke!
                            paul53P FredFF 2 Antworten Letzte Antwort
                            • T tcfigge
                              Ja, sehr viel.
                              Noch eine Frage:
                              Danke!
                              @tcfigge sagte: Am Beispiel des yr Adapters. Der holt ja wirklich Daten ohne Ende!
                              Den Adapter nutze ich nicht, kann also dazu nichts beitragen.
                              @tcfigge sagte in RasPi 5, 8 GB überlastet:
                              Ja. Wenn man es in der Konfiguration eingrenzen kann, muss man nicht komplett verzichten.
                              • mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                Im Prinzip könntest du auch schaun ob der Compact Mode bei dir
                                Support Repositoryverwaltung.
                                LESEN - gute Forenbeitrage
                                • T tcfigge
                                  wendy2702W Offline
                                  wendy2702W Offline
                                  Warum soviele?
                                  Eiegntlich reicht doch eine in der mal alle User definiert und diese dann gezielt anspricht wenn man nachrichten versenden will.
                                  Ähnlich sollt es mit Text2Command sein.
                                  • T tcfigge
                                    CodierknechtC Offline
                                    Codierknecht
                                    Ich zähle 14.
                                    Fragt sich trotzdem: Wozu?
                                    Und dann daswetter, dwd, openweathermap, weatherunderground, yr.
                                    Bist Du Meteorologe?
                                    Ich sehe da so einige Adapter, die gleich mit mehreren Instanzen laufen wo doch ggf. eine reicht.
                                    Oder mehrere Adapter für ein und denselben Zweck.
                                    Auch ein Pi5 ist schließlich kein Rechenwunder und der Speicher ist nun mal begrenzt.
                                    HmIP|ZigBee|Tasmota|Unifi
                                    Zabbix Certified Specialist
                                    • T tcfigge
                                      Ja, sehr viel.
                                      Noch eine Frage:
                                      Danke!
                                      FredFF Online
                                      FredFF Online
                                      FredF
                                      Most Active Forum Testing
                                      @tcfigge Ich würde bei anderen Adaptern/Skripten suchen.
                                      Den yr habe ich auch im Einsatz.
                                      Mit insgesamt 62 Instanzen habe ich "nur" Objects: 34645 und States: 28620
                                      • T tcfigge
                                        edith: oops
                                        wie das?
                                        Codierknecht
                                        Auf ein und derselben Maschine? Kann man so machen, ist dann aber ka**e.
                                        Wenn Dir beim rumspielen ein Script Amok läuft, hast Du Dein Produktivsystem zerlegt.
                                        • CodierknechtC Codierknecht
                                          Ich zähle 14.
                                          @codierknecht sagte: daswetter, dwd, openweathermap, weatherunderground, yr.
                                          Das sind "scheduled" Instanzen. Wenn mehrere gleichzeitig starten, geht der RAM-Bedarf stark hoch, weshalb es mich nicht wundert, dass der Swap genutzt wurde.
