  4. [Gelöst] CPU Temperatur von Proxmox VM
    6.5k
monitoringjavascriptblockly
129 Beiträge 31 Kommentatoren 36.5k Aufrufe 32 Beobachtet
  • B babl
    @crunchip
    sensors
    coretemp-isa-0000
    Adapter: ISA adapter
    Package id 0:  +62.0°C  (high = +84.0°C, crit = +100.0°C)
    Core 0:        +59.0°C  (high = +84.0°C, crit = +100.0°C)
    Core 1:        +62.0°C  (high = +84.0°C, crit = +100.0°C)
    Core 2:        +59.0°C  (high = +84.0°C, crit = +100.0°C)
    Core 3:        +61.0°C  (high = +84.0°C, crit = +100.0°C)
    acpitz-acpi-0
    Adapter: ACPI interface
    temp1:        +27.8°C  (crit = +119.0°C)
    temp2:        +29.8°C  (crit = +119.0°C)
    nvme-pci-0100
    Adapter: PCI adapter
    Composite:    +54.9°C  (low  =  -0.1°C, high = +74.8°C)
                           (crit = +79.8°C)
    ERROR: Can't get value of subfeature temp3_min: I/O error
    ERROR: Can't get value of subfeature temp3_max: I/O error
    Sensor 2:     +54.9°C  (low  =  +0.0°C, high =  +0.0°C)
    ERROR: Can't get value of subfeature temp4_min: I/O error
    ERROR: Can't get value of subfeature temp4_max: I/O error
    Sensor 3:     +81.8°C  (low  =  +0.0°C, high =  +0.0°C)
    ERROR: Can't get value of subfeature temp7_min: I/O error
    ERROR: Can't get value of subfeature temp7_max: I/O error
    Sensor 6:     +54.9°C  (low  =  +0.0°C, high =  +0.0°C)
    crunchipC Offline
    crunchipC Offline
    #116
    @babl dann sollte ja die Abfrage eigentlich passen, schau mal wegen deinem
    https://github.com/lm-sensors/lm-sensors/issues/368/
    B 2 Antworten Letzte Antwort
      babl
      #117
      @crunchip ok, danke aber das ist mir leider zu hoch, mal schauen ob es einen anderen Weg gibt, ich versteh nur nicht warum daß in Proxmox nicht integriert ist.
        babl
        #118
        @crunchip ok habs doch mal probiert, so lernt man ja auch was und es funktioniert, dank deinem Link.
         sensors
        coretemp-isa-0000
        Package id 0:  +60.0°C  (high = +84.0°C, crit = +100.0°C)
        Core 0:        +60.0°C  (high = +84.0°C, crit = +100.0°C)
        Core 1:        +57.0°C  (high = +84.0°C, crit = +100.0°C)
        Core 2:        +57.0°C  (high = +84.0°C, crit = +100.0°C)
        Core 3:        +56.0°C  (high = +84.0°C, crit = +100.0°C)
        acpitz-acpi-0
        nvme-pci-0100
                               (crit = +79.8°C)
        Hab mir im Ordner /etc/sensors.d/nvme.conf erstellt und hier habe ich folgendes reingeschrieben
        chip "nvme-pci-0100"
            ignore temp3
            ignore temp4
            ignore temp7
        und das wars, das andere denke ich finde ich noch heraus. aber der eine grep befehl paßt dann
        sensors | grep 'Core 1:' | awk '{print $3}' | cut -c2-3
        Kommt genau das raus was ich wollte, danke dir.
        • M Online
          M Online
          Micha 3
          #119
          Wie kann ich info.0.sysinfo.cpu.temperature.main die schreibrechte dauerhaft einrichten? jedes mal bei einem Neustart sind die wieder weg.
          • M Micha 3
            FredFF Online
            FredFF Online
            FredF
            Most Active Forum Testing
            #120
            @micha-3 Temperatur der CPU soll manuel geändert werden? verstehe ich nicht...
            • FredFF FredF
              M Online
              M Online
              Micha 3
              schrieb am zuletzt editiert von Micha 3
              #121
              @fredf Wie meinst du? Ist hiernach https://forum.iobroker.net/topic/23602/gel%C3%B6st-cpu-temperatur-von-proxmox-vm/37 eingerichtet, aber die schreibrechte sind immer weg nach einem Neustart. Bei anderen scheint es ja so zu funktionieren.
              • M Micha 3
                FredFF Online
                FredFF Online
                FredF
                #122
                @micha-3 Da musst du dich beim Entwickler des Info Adapters beschweren
                • M martinschm
                  @TeNNo2k5 said in [Gelöst] CPU Temperatur von Proxmox VM:
                  Ich bin vor kurzem auf die gleiche Idee gekommen und habe es etwas simpler gelöst, ich poste es mal als alternative Lösung da es vielleicht der ein oder andere brauchen kann.
                  Per Bashscript führe ich folgenden Befehl 1x pro Minute per Blockly Script aus:
                  paste <(cat /sys/class/thermal/thermal_zone*/type) <(cat /sys/class/thermal/thermal_zone*/temp) \
                  | column -s $'\t' -t | sed 's/\(.\)..$/.\1/' | grep x86_pkg_temp | cut -d " " -f3
                  Ausgegeben wird nur der CPU Temperatur Wert vom Host also nicht die Werte der einzelnen Cores, dafür funktioniert der Code ootb, es müssen keine Abhängigkeiten oder Adapter installiert werden.
                  Der code kann entweder direkt auf dem Proxmox Host, oder innerhalb einer VM/LXC ausgeführt werden, ich führe es auf dem Container vom iobroker aus.
                  hab das Skript auch angelegt und rufe es auch über dein Blockly Skript auf. Leider bekomme ich nur null zurück. Wenn ich den Befehl auf der shell aufrufe bekomme ich einen Wert zurück.
                  Müssen da noch irgendwelche Rechte gesetzt werden ?
                  ciao
                  Martin
                  sherlock
                  #123
                  @martinschm
                  Moin,
                  dein Befehl kann nur in einem LXC ausgeführt werden, aber nicht in einer VM!
                  Außerdem sollte man auf keinem Fall iobroker in einem LXC installieren!
                  Rolf
                  NashraN arteckA Meister MopperM 4 Antworten Letzte Antwort
                  • S sherlock
                    @martinschm
                    Moin,
                    Rolf
                    NashraN Offline
                    NashraN Offline
                    Nashra
                    #124
                    @sherlock sagte in [Gelöst] CPU Temperatur von Proxmox VM:
                    @martinschm
                    Warum sollte man das nicht?
                    Gruß Ralf
                    • S sherlock
                      @martinschm
                      Moin,
                      Rolf
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #125
                      ahhhhhhhhhhhh was eine Erkentniss.. was mach ich den jetzt..ich habe 4 Installationen so laufen
                      schlau uns auf .........
                      • S sherlock
                        @martinschm
                        Moin,
                        Rolf
                        Meister MopperM Online
                        Meister Mopper
                        #126
                        Das würde mich auch interessieren, es läuft nämlich hier seit Jahren problemfrei.
                        Proxmox und HA ...
                        • arteckA arteck
                          sherlock
                          #127
                          @arteck
                          Die Welt besteht nicht nur aus Profis! Mögt Ihr diese sein, nur für einen Laie, ist die VM immer deutlich einfacher alles durchzureichen. Oder nutzt Ihr keinen Bluetooth, ZigBee und USB / SATA Festplatten.....? Außerdem könnte Ihr eine VM immer mitnehmen, einen LXC Container mal eben nicht so. Aber was Rede ich, ich bin ja auch nur ein kluger Laie....
                          • S sherlock
                            @arteck
                            #128
                            Und warum sollen dann "Profis" nicht auch LXCs einsetzen?
                            Also in der hier vertretenen Absolutheit
                            ist die Aussage natürlich Quatsch. Natürlich kann man einen ioBroker auch in einem LXC betreiben. Warum auch nicht? Das andere Setups 'einfacher' sind schließt das ja nicht aus. Muss halt jeder selber wissen, was in der persönlichen Situation besser geeignet ist.
                            • S sherlock
                              @martinschm
                              Moin,
                              Rolf
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #129
                              das ist deine Assage.. ohne jegliche weitere Erklärung..
                              was hat das mit einem Profi oder Leien zu tun .. nopes...
                              wenn du solche Aussage in die Welt setzt solltest du auch erklären warum nicht...
                              es gibt auch andere Gründe als die von dir genannte... ein LXC ist nicht migrationsfähig..als Beispiel.. hat abe nix damit zu tun dass man im LXC keine iobroker installieren sollte...
                              und ja ich gebe dir recht USB Geräte sind einfacher in eine VM zu durchreichen.. trotzdem läuft iobroker genausogut in einem LXC (vielleicht sogar besser da Ressourcen schonender)
