  4. Harmony Adapter versagt seinen Dienst !
94 Beiträge 9 Kommentatoren 15.4k Aufrufe 6 Beobachtet
  • S Springreiter
    2024-02-18 11:38:26.857 - info: host.iobroker stopInstance system.adapter.harmony.0 (force=false, process=true)
    2024-02-18 11:38:26.859 - info: harmony.0 (4155269) Got terminate signal TERMINATE_YOURSELF
    2024-02-18 11:38:26.861 - info: host.iobroker stopInstance system.adapter.harmony.0 send kill signal
    2024-02-18 11:38:26.860 - info: harmony.0 (4155269) [END] Terminating
    2024-02-18 11:38:26.861 - info: harmony.0 (4155269) terminating
    2024-02-18 11:38:26.861 - info: harmony.0 (4155269) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-02-18 11:38:27.362 - info: harmony.0 (4155269) terminating
    2024-02-18 11:38:27.455 - info: host.iobroker instance system.adapter.harmony.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-02-18 11:38:29.952 - info: host.iobroker instance system.adapter.harmony.0 started with pid 4156085
    2024-02-18 11:38:30.942 - debug: harmony.0 (4156085) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2024-02-18 11:38:30.973 - debug: harmony.0 (4156085) Objects client ready ... initialize now
    2024-02-18 11:38:30.974 - debug: harmony.0 (4156085) Objects create System PubSub Client
    2024-02-18 11:38:30.974 - debug: harmony.0 (4156085) Objects create User PubSub Client
    2024-02-18 11:38:31.025 - debug: harmony.0 (4156085) Objects client initialize lua scripts
    2024-02-18 11:38:31.029 - debug: harmony.0 (4156085) Objects connected to redis: 127.0.0.1:9001
    2024-02-18 11:38:31.077 - debug: harmony.0 (4156085) Redis States: Use Redis connection: 127.0.0.1:6379
    2024-02-18 11:38:31.081 - debug: harmony.0 (4156085) States create System PubSub Client
    2024-02-18 11:38:31.082 - debug: harmony.0 (4156085) States create User PubSub Client
    2024-02-18 11:38:31.091 - debug: harmony.0 (4156085) States connected to redis: 127.0.0.1:6379
    2024-02-18 11:38:31.228 - info: harmony.0 (4156085) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v18.19.1, js-controller: 5.0.17
    2024-02-18 11:38:31.249 - debug: harmony.0 (4156085) [START] Subnet: 255.255.255.255, Discovery interval: 10000
    2024-02-18 11:38:31.287 - info: harmony.0 (4156085) [DISCOVER] Searching for Harmony Hubs on 255.255.255.255
    HomoranH Offline
    HomoranH Offline
    @springreiter sagte in Harmony Adapter versagt seinen Dienst !:
    demnach soll er alle 10000msec suchen
      Springreiter
      @homoran wenn der nicht über Jahre problemlos funktioniert hätte. Aber nach dem Searching for Harmony Hubs kommt nichts mehr. Da wurde nichts verändert- über Fernbedienung funktioniert er auch???
      • S Springreiter
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        Sicherlich wird es mit irgendeinen Update zusammen hängen
        ioBroker läuft bei Dir im Docker?
        Lehrling seit 1975 !!!
        • DJMarc75D DJMarc75
          Springreiter
          @djmarc75 Proxmos VM mit Debian
          • S Springreiter
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @springreiter
            dann zeig mal bitte die Langfassung von:
            iob diag
            bitte in CodeTags
              @springreiter
              iob diag
              bitte in CodeTags
              Springreiter
              Leider darf der Benutzer dw »/usr/bin/curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh« als iobroker auf iobroker nicht ausführen.
              kannte ich auch nicht
              • S Springreiter
                HomoranH Offline
                HomoranH Offline
                oha!
                Rechte verbogen mit irgendwelchen "Tools"?
                bitte
                iob stop
                iob fix
                iob start
                ausführen ... warten
                dann iob diag nochmal versuchen.
                und immer jede Ein- und Ausgabe der Konsole vollständig in code-tags zeigen!
                  oha!
                  bitte
                  iob stop
                  iob fix
                  iob start
                  Springreiter
                  @homoran darf ich immer noch nicht😞
                  • S Springreiter
                    @springreiter
                    Du darfst keine vollständigen Dinge posten?
                    Wer hat denn das untersagt?
                      @springreiter
                      Springreiter
                      @thomas-braun Leider darf der Benutzer dw »/usr/bin/curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh« als iobroker auf iobroker nicht ausführen.
                      • S Springreiter
                        @springreiter
                        Vollständige Ein- wie Ausgaben inkl. des LoginPrompt, keine Nacherzählung.
                          @springreiter
                          Springreiter
                          login as: dw
                          dw@192.168.178.59's password:
                          Linux iobroker 5.10.0-18-amd64 #1 SMP Debian 5.10.140-1 (2022-09-02) x86_64
                          permitted by applicable law.
                          Last login: Sun Feb 18 12:32:09 2024 from 192.168.178.47
                          dw@iobroker:~$ iob diag
                          [sudo] Passwort für dw:
                          dw@iobroker:~$
                          • S Springreiter
                            login as: dw
                            dw@iobroker:~$
                            @springreiter
                            In CodeTags wäre noch fein...
                            groups
                            sagt?
                              @springreiter
                              groups
                              sagt?
                              Springreiter
                              @thomas-braun jetzt setzt du zuviel bei mir vorraus- was ist das
                              CodierknechtC Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                              • S Springreiter
                                CodierknechtC Offline
                                Codierknecht
                                @springreiter
                                Das da:
                                HmIP|ZigBee|Tasmota|Unifi
                                Zabbix Certified Specialist
                                • S Springreiter
                                  @springreiter
                                  Den Befehl
                                  groups
                                  in dein Terminal hacken, vollständige Ein- wie Ausgaben hier wieder rein kopieren, in CodeTags eingebettet.
                                  • S Springreiter
                                    HomoranH Offline
                                    HomoranH Offline
                                    was ist das
                                    groups?
                                    ebenfalls ein einzutippender Befehl.
                                    alles wichtige steht übrigens hier
                                      was ist das
                                      groups?
                                      mcm1957M Offline
                                      mcm1957M Offline
                                      mcm1957
                                      Prinzipiell gibgt es dazu auch ein Issue:
                                      https://github.com/iobroker-community-adapters/ioBroker.harmony/issues/140
                                      Allerdings wurde im Adapter seit November 2023 nichts geändert ...
                                      Support Repositoryverwaltung.
                                      LESEN - gute Forenbeitrage
                                      • CodierknechtC Offline
                                        Codierknecht
                                        Bei Debian 5.10.140 befürchte ich einen gewissen Update-Stau.
                                        Wir werden sehen ...
                                        • CodierknechtC Codierknecht
                                          HomoranH Offline
                                          HomoranH Offline
                                          @codierknecht sagte in Harmony Adapter versagt seinen Dienst !:
                                          das dürfte die Kernelversion sein
