  4. Harmony Adapter versagt seinen Dienst !
94 Beiträge 9 Kommentatoren 15.4k Aufrufe 6 Beobachtet
  • DJMarc75D DJMarc75
    @springreiter sagte in Harmony Adapter versagt seinen Dienst !:
    garnichts!
    Adapter neu starten und dann muss sogar beim LOG-Level Info einiges im LOG stehen.
    bei mir z.B.
    harmony.0
    	2024-02-18 11:13:48.888	debug	current activity: MagentaTV
    harmony.0
    	2024-02-18 11:13:48.849	info	[PROCESS] Synced hub config for ML Multimedia (192.168.178.176)
    harmony.0
    	2024-02-18 11:13:48.849	debug	[PROCESS] Deleting devices
    harmony.0
    	2024-02-18 11:13:48.849	debug	[PROCESS] Deleting activities
    harmony.0
    	2024-02-18 11:13:48.849	debug	[PROCESS] Creating devices
    harmony.0
    	2024-02-18 11:13:48.849	debug	creating activities
    harmony.0
    	2024-02-18 11:13:48.848	debug	[PROCESS] Creating hub device
    harmony.0
    	2024-02-18 11:13:48.848	debug	[PROCESS] Creating activities and devices
    harmony.0
    	2024-02-18 11:13:48.082	info	[CONNECT] Connected to ML Multimedia (192.168.178.176)
    harmony.0
    	2024-02-18 11:13:46.951	info	[CONNECT] Connecting to ML Multimedia (192.168.178.176)
    harmony.0
    	2024-02-18 11:13:46.926	debug	hub initialized
    harmony.0
    	2024-02-18 11:13:46.898	info	[DISCOVER] Discovered ML Multimedia (192.168.178.176) and will try to connect
    harmony.0
    	2024-02-18 11:13:36.647	info	[DISCOVER] Searching for Harmony Hubs on 255.255.255.255
    harmony.0
    	2024-02-18 11:13:36.640	debug	[START] Subnet: 255.255.255.255, Discovery interval: 10000
    harmony.0
    	2024-02-18 11:13:36.632	info	starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v18.19.1, js-controller: 5.0.19
    harmony.0
    	2024-02-18 11:13:36.555	debug	States connected to redis: 127.0.0.1:9000
    harmony.0
    	2024-02-18 11:13:36.488	debug	States create User PubSub Client
    harmony.0
    	2024-02-18 11:13:36.488	debug	States create System PubSub Client
    harmony.0
    	2024-02-18 11:13:36.473	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    harmony.0
    	2024-02-18 11:13:36.446	debug	Objects connected to redis: 127.0.0.1:9001
    harmony.0
    	2024-02-18 11:13:36.443	debug	Objects client initialize lua scripts
    harmony.0
    	2024-02-18 11:13:36.393	debug	Objects create User PubSub Client
    harmony.0
    	2024-02-18 11:13:36.392	debug	Objects create System PubSub Client
    harmony.0
    	2024-02-18 11:13:36.391	debug	Objects client ready ... initialize now
    harmony.0
    	2024-02-18 11:13:36.366	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    Springreiter
    • S Springreiter
      HomoranH Offline
      HomoranH Offline
      @springreiter bitte als Text in code-tags posten.
        Springreiter
        2024-02-18 11:38:26.857 - info: host.iobroker stopInstance system.adapter.harmony.0 (force=false, process=true)
        2024-02-18 11:38:26.859 - info: harmony.0 (4155269) Got terminate signal TERMINATE_YOURSELF
        2024-02-18 11:38:26.861 - info: host.iobroker stopInstance system.adapter.harmony.0 send kill signal
        2024-02-18 11:38:26.860 - info: harmony.0 (4155269) [END] Terminating
        2024-02-18 11:38:26.861 - info: harmony.0 (4155269) terminating
        2024-02-18 11:38:26.861 - info: harmony.0 (4155269) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-02-18 11:38:27.362 - info: harmony.0 (4155269) terminating
        2024-02-18 11:38:27.455 - info: host.iobroker instance system.adapter.harmony.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-02-18 11:38:29.952 - info: host.iobroker instance system.adapter.harmony.0 started with pid 4156085
        2024-02-18 11:38:30.942 - debug: harmony.0 (4156085) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2024-02-18 11:38:30.973 - debug: harmony.0 (4156085) Objects client ready ... initialize now
        2024-02-18 11:38:30.974 - debug: harmony.0 (4156085) Objects create System PubSub Client
        2024-02-18 11:38:30.974 - debug: harmony.0 (4156085) Objects create User PubSub Client
        2024-02-18 11:38:31.025 - debug: harmony.0 (4156085) Objects client initialize lua scripts
        2024-02-18 11:38:31.029 - debug: harmony.0 (4156085) Objects connected to redis: 127.0.0.1:9001
        2024-02-18 11:38:31.077 - debug: harmony.0 (4156085) Redis States: Use Redis connection: 127.0.0.1:6379
        2024-02-18 11:38:31.081 - debug: harmony.0 (4156085) States create System PubSub Client
        2024-02-18 11:38:31.082 - debug: harmony.0 (4156085) States create User PubSub Client
        2024-02-18 11:38:31.091 - debug: harmony.0 (4156085) States connected to redis: 127.0.0.1:6379
        2024-02-18 11:38:31.228 - info: harmony.0 (4156085) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v18.19.1, js-controller: 5.0.17
        2024-02-18 11:38:31.249 - debug: harmony.0 (4156085) [START] Subnet: 255.255.255.255, Discovery interval: 10000
        2024-02-18 11:38:31.287 - info: harmony.0 (4156085) [DISCOVER] Searching for Harmony Hubs on 255.255.255.255
        • S Springreiter
          HomoranH Offline
          HomoranH Offline
          und 10 Sekunden später kommt nichts?
            Springreiter
            @homoran nein- nichts
            • S Springreiter
              HomoranH Offline
              HomoranH Offline
              demnach soll er alle 10000msec suchen
                Springreiter
                @homoran wenn der nicht über Jahre problemlos funktioniert hätte. Aber nach dem Searching for Harmony Hubs kommt nichts mehr. Da wurde nichts verändert- über Fernbedienung funktioniert er auch???
                • S Springreiter
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  Sicherlich wird es mit irgendeinen Update zusammen hängen
                  ioBroker läuft bei Dir im Docker?
                  Lehrling seit 1975 !!!
                    Springreiter
                    @djmarc75 Proxmos VM mit Debian
                    • S Springreiter
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      @springreiter
                      dann zeig mal bitte die Langfassung von:
                      iob diag
                      bitte in CodeTags
                        @springreiter
                        iob diag
                        bitte in CodeTags
                        Springreiter
                        Leider darf der Benutzer dw »/usr/bin/curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh« als iobroker auf iobroker nicht ausführen.
                        kannte ich auch nicht
                        • S Springreiter
                          HomoranH Offline
                          HomoranH Offline
                          oha!
                          Rechte verbogen mit irgendwelchen "Tools"?
                          bitte
                          iob stop
                          iob fix
                          iob start
                          ausführen ... warten
                          dann iob diag nochmal versuchen.
                          und immer jede Ein- und Ausgabe der Konsole vollständig in code-tags zeigen!
                            oha!
                            bitte
                            iob stop
                            iob fix
                            iob start
                            Springreiter
                            @homoran darf ich immer noch nicht😞
                            • S Springreiter
                              @springreiter
                              Du darfst keine vollständigen Dinge posten?
                              Wer hat denn das untersagt?
                                @springreiter
                                Springreiter
                                @thomas-braun Leider darf der Benutzer dw »/usr/bin/curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh« als iobroker auf iobroker nicht ausführen.
                                • S Springreiter
                                  @springreiter
                                  Vollständige Ein- wie Ausgaben inkl. des LoginPrompt, keine Nacherzählung.
                                    @springreiter
                                    Springreiter
                                    login as: dw
                                    dw@192.168.178.59's password:
                                    Linux iobroker 5.10.0-18-amd64 #1 SMP Debian 5.10.140-1 (2022-09-02) x86_64
                                    permitted by applicable law.
                                    Last login: Sun Feb 18 12:32:09 2024 from 192.168.178.47
                                    dw@iobroker:~$ iob diag
                                    [sudo] Passwort für dw:
                                    dw@iobroker:~$
                                    • S Springreiter
                                      login as: dw
                                      dw@iobroker:~$
                                      @springreiter
                                      In CodeTags wäre noch fein...
                                      groups
                                      sagt?
                                        @springreiter
                                        groups
                                        sagt?
                                        Springreiter
                                        @thomas-braun jetzt setzt du zuviel bei mir vorraus- was ist das
                                        CodierknechtC Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                                        • S Springreiter
                                          CodierknechtC Offline
                                          Codierknecht
                                          @springreiter
                                          Das da:
                                          HmIP|ZigBee|Tasmota|Unifi
                                          Zabbix Certified Specialist
