  4. InfluxDB: Error: connect ECONNREFUSED 127.0.0.1:8086
42 Beiträge 5 Kommentatoren 6.2k Aufrufe 3 Beobachtet
    @obstbauer
    Aber die Keys musst du an der Stelle löschen:
    rm influxdata-archive_compat*
    O Offline
    O Offline
    obstbauer
    @thomas-braun Hallo,sudo apt update macht jetzt keine Probleme mehr
    ich habe rm influxdata-archive_compat* ausgeführt erhalte aber immer noch die selbe Fehlermeldung Error: connect ECONNREFUSED 127.0.0.1:8086
    O 1 Antwort Letzte Antwort
    • O obstbauer
      O Offline
      O Offline
      obstbauer
      pi@raspberrypi:~ $ systemctl status influx*
      ● influxdb.service - InfluxDB is an open-source, distributed, time series datab>
           Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor pres>
           Active: activating (start) since Mon 2024-02-12 10:59:27 CET; 1min 27s ago
             Docs: https://docs.influxdata.com/influxdb/
      Cntrl PID: 17670 (influxd-systemd)
            Tasks: 14 (limit: 3933)
              CPU: 2min 40.311s
           CGroup: /system.slice/influxdb.service
                   ├─17670 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-sta>
                   ├─17671 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                   └─18132 sleep 1
      Feb 12 11:00:48 raspberrypi influxd-systemd-start.sh[17670]: InfluxDB API unava>
      Feb 12 11:00:48 raspberrypi influxd-systemd-start.sh[17671]: ts=2024-02-12T10:0>
      Feb 12 11:00:49 raspberrypi influxd-systemd-start.sh[17670]: InfluxDB API unava>
      Feb 12 11:00:50 raspberrypi influxd-systemd-start.sh[17670]: InfluxDB API unava>
      Feb 12 11:00:51 raspberrypi influxd-systemd-start.sh[17670]: InfluxDB API unava>
      Feb 12 11:00:51 raspberrypi influxd-systemd-start.sh[17671]: ts=2024-02-12T10:0>
      Feb 12 11:00:52 raspberrypi influxd-systemd-start.sh[17670]: InfluxDB API unava>
      Feb 12 11:00:53 raspberrypi influxd-systemd-start.sh[17670]: InfluxDB API unava>
      Feb 12 11:00:53 raspberrypi influxd-systemd-start.sh[17671]: ts=2024-02-12T10:0>
      Feb 12 11:00:54 raspberrypi influxd-systemd-start.sh[17670]: InfluxDB API unava>
      Feb 12 11:00:55 raspberrypi influxd-systemd-start.sh[17670]: InfluxDB API unava>
      lines 1-23...skipping...
      beim googlen habe ich jetzt rausgefunden, dass es an der timeout Zeit liegen kann und ich diese anpassen soll, beispielsweise so:
      $ cat /etc/systemd/system/influxdb.service.d/override.conf
      [Service]
      TimeoutStartSec=45m
      würde das Sinn machen?
      • O obstbauer
                CPU: 2min 40.311s
                     └─18132 sleep 1
        [Service]
        TimeoutStartSec=45m
        O Offline
        O Offline
        obstbauer
        @obstbauer mit htop sehe ich auch, dass influxdp das System ordentlich auslastet, verstehe ich auch nicht...
        • O obstbauer
          Marc BergM Offline
          Marc BergM Offline
          Marc Berg
          @obstbauer sagte in InfluxDB: Error: connect ECONNREFUSED 127.0.0.1:8086:
          Ich vermute, dass deine Datenbank einfach zu groß ist und/oder korrupte Daten vorhanden sind. Was sagt:
          sudo du -sh /var/lib/influxdb/
          • Marc BergM Marc Berg
            O Offline
            O Offline
            obstbauer
            @marc-berg
            pi@raspberrypi:~ $ sudo du -sh /var/lib/influxdb/
            1.1G	/var/lib/influxdb/
            is jetzt nicht sooo groß oder ?
            • O obstbauer
              @marc-berg
              Marc BergM Offline
              Marc BergM Offline
              Marc Berg
              Nein, das geht. Dann wird wohl was kaputt gegangen sein. Bevor du da lange rumdokterst, würde ich ein Restore machen.
                O Offline
                O Offline
                obstbauer
                @marc-berg ok also mein backup wieder reinladen? Das habe ich noch nicht gemacht bisher, werde es aber morgen mal versuchen. Der Kaltstart hat irgendwas zerschossen leider :/ aber das ist ja bekannt, dass der Pi so etwas nicht mag....
                Wenn ich mal Zeit habe werde ich alles neu und frisch installieren, dann läuft es auch stabiler....
                Thomas BraunT Marc BergM 2 Antworten Letzte Antwort
                • O obstbauer
                  Der Kaltstart hat irgendwas zerschossen leider aber das ist ja bekannt, dass der Pi so etwas nicht mag....
                  Das mag gar kein EDV-System. Da ist der Pi nicht alleine.
                  • O obstbauer
                    Marc BergM Offline
                    Marc BergM Offline
                    Marc Berg
                    ja, genau.
                    Ohne mit dem erhobenen Zeigefinger wedeln zu wollen: Es ist immer eine gute Idee, das zu üben, wenn man keinen "Druck" hat :-)
                      ja, genau.
                      O Offline
                      O Offline
                      obstbauer
                      @marc-berg ja ich hatte eh mal vor die Datenbank auf die Festplatte umzusiedeln damit die SD Karte geschont wird, auch dafür is es jetzt ein guter Zeitpunkt :) es ist halt die mangelnde Zeit....
                      • O Offline
                        O Offline
                        obstbauer
                        @marc-berg aktuell scheitere ich an dem restore... ich habe die Backup Datei die der iobroker als letztes erstellt hat auf meinen Pi kopiert (das Backup geht auf einen ftp) und es entpackt
                        Mit diesem Befehl wollte ich es nun wieder herstellen, erhalte aber folgende Meldung mit der ich nichts anfangen kann:
                        pi@raspberrypi:~ $ influxd restore \ -db iobroker \ -datadir /var/lib/influxdb/data/iobroker \ -metadir /var/lib/influxdb/meta \ /home/pi/influx_backup
                        restore: backup path should be a valid directory:  -db
                        ich wollte es mit der offline legacy methode machen nach folgendem Beispiel von der influx Seite
                        influxd restore \
                          -db example-db \
                          -datadir /path/to/data-directory \
                          -metadir /path/to/meta-directory \
                          /path/to/backup-directory
                        O HomoranH Marc BergM 3 Antworten Letzte Antwort
                        • O obstbauer
                          influxd restore \
                            -db example-db \
                          O Offline
                          O Offline
                          obstbauer
                          das bekomme ich als Fehler, wenn ich das Backup über iobroker laden will:
                          Started restore ...
                          [DEBUG] [influxDB] - Created tmp directory
                          [DEBUG] [influxDB] - Start infuxDB Restore ...
                          [DEBUG] [influxDB] - influxdb.0 is stopped
                          [ERROR] [influxDB] - 2024/02/13 18:18:29 error updating meta: updating metadata on influxd service failed: err=read tcp 127.0.0.1:55584->127.0.0.1:8088: read: connection reset by peer, n=0
                          restore: updating metadata on influxd service failed: err=read tcp 127.0.0.1:55584->127.0.0.1:8088: read: connection reset by peer, n=0
                          [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
                          [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
                          [DEBUG] [influxDB] - infuxDB Restore completed successfully
                          [EXIT] influxDB restore done
                          [DEBUG] [influxDB] - influxdb.0 started
                          • O obstbauer
                            influxd restore \
                              -db example-db \
                            HomoranH Offline
                            HomoranH Offline
                            und es entpackt
                            warum?
                            das macht der restore!
                              und es entpackt
                              warum?
                              O Offline
                              O Offline
                              obstbauer
                              @homoran es ging weder gepackt noch entpackt
                              Backup von iobroker stellt das Backup ja auch nicht wieder her
                              • O Offline
                                O Offline
                                obstbauer
                                ich habe nun auch diese Lösung versucht:
                                Influx DB abgelehnt aus dem Forum, die sleep zeit von 1 auf 10 und erneutes eingeben des Passwortes, aber auch das will das Problem nicht lösen
                                langsam weiß ich nicht mehr weiter....
                                • O obstbauer
                                  O Offline
                                  O Offline
                                  obstbauer
                                  das erhalte ich nun auch:
                                  Unit influx_backup.service could not be found.
                                  • O obstbauer
                                    O Offline
                                    O Offline
                                    obstbauer
                                    hat keiner eine Idee?
                                    Mein ganzes System steht durch den Ausfall von influx :/
                                    • O obstbauer
                                      influxd restore \
                                        -db example-db \
                                      Marc BergM Offline
                                      Marc BergM Offline
                                      Marc Berg
                                      Der Befehl ist falsch, und was sollen die Backslashes darin? Wenn das Backup durch Backitup erzeugt wurde, heißt er korrekte Befehl
                                      influxd restore -db iobroker -portable /home/pi/influx_backup
                                      Das Backup muss vorher entpackt worden sein. Zeig mal den Inhalt des Backup Verzeichnisses.
                                      Wichtig: die DB muss vorher gelöscht worden sein. Das geht u.a. über den Adapter.
                                        O Offline
                                        O Offline
                                        obstbauer
                                        @marc-berg
                                        pi@raspberrypi:~ $ cd /home/pi/influx_backup
                                        pi@raspberrypi:~/influx_backup $ ls
                                        20240210T014020Z.manifest
                                        20240210T014020Z.meta
                                        20240210T014020Z.s177.tar.gz
                                        20240210T014020Z.s185.tar.gz
                                        20240210T014020Z.s193.tar.gz
                                        20240210T014020Z.s201.tar.gz
                                        20240210T014020Z.s209.tar.gz
                                        20240210T014020Z.s217.tar.gz
                                        20240210T014020Z.s225.tar.gz
                                        20240210T014020Z.s233.tar.gz
                                        20240210T014020Z.s241.tar.gz
                                        20240210T014020Z.s249.tar.gz
                                        20240210T014020Z.s257.tar.gz
                                        20240210T014020Z.s265.tar.gz
                                        20240210T014020Z.s273.tar.gz
                                        20240210T014020Z.s281.tar.gz
                                        20240210T014020Z.s289.tar.gz
                                        20240210T014020Z.s297.tar.gz
                                        20240210T014020Z.s305.tar.gz
                                        20240210T014020Z.s313.tar.gz
                                        20240210T014020Z.s321.tar.gz
                                        20240210T014020Z.s329.tar.gz
                                        20240210T014020Z.s337.tar.gz
                                        20240210T014020Z.s345.tar.gz
                                        20240210T014020Z.s353.tar.gz
                                        20240210T014020Z.s361.tar.gz
                                        20240210T014020Z.s369.tar.gz
                                        20240210T014020Z.s377.tar.gz
                                        20240210T014020Z.s385.tar.gz
                                        20240210T014020Z.s393.tar.gz
                                        20240210T014020Z.s401.tar.gz
                                        20240210T014020Z.s409.tar.gz
                                        20240210T014020Z.s417.tar.gz
                                        20240210T014020Z.s425.tar.gz
                                        20240210T014020Z.s433.tar.gz
                                        20240210T014020Z.s441.tar.gz
                                        20240210T014020Z.s449.tar.gz
                                        20240210T014020Z.s457.tar.gz
                                        20240210T014020Z.s465.tar.gz
                                        20240210T014020Z.s473.tar.gz
                                        20240210T014020Z.s481.tar.gz
                                        20240210T014020Z.s489.tar.gz
                                        20240210T014020Z.s497.tar.gz
                                        20240210T014020Z.s505.tar.gz
                                        20240210T014020Z.s513.tar.gz
                                        20240210T014020Z.s521.tar.gz
                                        20240210T014020Z.s529.tar.gz
                                        20240210T014020Z.s537.tar.gz
                                        20240210T014020Z.s545.tar.gz
                                        20240210T014020Z.s553.tar.gz
                                        20240210T014020Z.s561.tar.gz
                                        20240210T014020Z.s569.tar.gz
                                        20240210T014020Z.s577.tar.gz
                                        20240210T014020Z.s585.tar.gz
                                        20240210T014020Z.s593.tar.gz
                                        influxDB_2024_02_10-02_40_19_backupiobroker.tar.gz
                                        oben hieß es, dass es nicht entpackt werden sollte.
                                        Mein weiteres Vorgehen wäre dann, die Datenbank mit Backitup löschen und mit dem Befehl wiedeherstellen?
                                        Die Backslashes habe ich drin weil sie auch in dem Beispiel dabei waren aus der Influx Doku, siehe weiter oben
                                        Marc BergM Thomas BraunT 2 Antworten Letzte Antwort
                                        • O obstbauer
                                          @marc-berg
                                          Marc BergM Offline
                                          Marc BergM Offline
                                          Marc Berg
                                          Naja, es kommt halt darauf an. Wenn du es auf der Kommandozeile selbst machst, dann muss es entpackt werden. Backitup entpackt selbst und erwartet auch EIN gepacktes File.
                                          Korrekt. Wenn du neben "iobroker" weitere DBs hast, musst du da ebenso verfahren.
                                          Ja, das gilt aber nur, wenn man den Befehl über mehrere Zeilen "verteilt" eingibt. So wie du es gemacht hast, gehören die Zeichen da nicht rein.
                                          EDIT:
                                          Ja, so passt es. Wollte nur sichergehen, dass die einzelnen *.gz Dateien nicht mit entpackt wurden.
