  4. kein iobroker-Backup mit Backitup
51 Beiträge 9 Kommentatoren 6.0k Aufrufe 8 Beobachtet
  • H Hausbaer
    @thomas-braun sagte in kein iobroker-Backup mit Backitup:
    @hausbaer
    Nein. Ich meine den ganzen Kram:
    *** FAILED SERVICES ***
      UNIT                               LOAD   ACTIVE SUB    DESCRIPTION
    * nftables.service                   loaded failed failed nftables
    * systemd-hostnamed.service          loaded failed failed Hostname Service
    * systemd-logind.service             loaded failed failed User Login Management
    * systemd-networkd.service           loaded failed failed Network Configuration
    * systemd-sysctl.service             loaded failed failed Apply Kernel Variables
    * systemd-sysusers.service           loaded failed failed Create System Users
    * systemd-timedated.service          loaded failed failed Time & Date Service
    * systemd-tmpfiles-clean.service     loaded failed failed Cleanup of Temporary Directories
    * systemd-tmpfiles-setup-dev.service loaded failed failed Create Static Device Nodes in /dev
    * systemd-tmpfiles-setup.service     loaded failed failed Create Volatile Files and Directories
    * systemd-networkd.socket            loaded failed failed Network Service Netlink Socket
    Ich hab grad mal nen iob-Server neu aufgesetzt. Nach der Anleitung hier
    https://www.iobroker.net/#de/documentation/install/proxmox.md
    Ergebnis:
    Die gleichen "Fehler"
    Skript v.2023-10-10
    *** BASE SYSTEM ***
    Failed to query system properties: Connection timed out
    model name      : AMD Ryzen 5 5600H with Radeon Graphics
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     19:26:23 up 25 min,  0 user,  load average: 1.42, 1.53, 1.29
    CPU threads: 2
    *** Time and Time Zones ***
    Failed to query server: Connection timed out
    *** User and Groups ***
    helmut
    /home/helmut
    helmut sudo users
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            8.6G        357M        5.0G         77K        3.3G        8.2G
    Swap:           536M          0B        536M
    Total:          9.1G        357M        5.5G
             8192 M total memory
              340 M used memory
              239 M active memory
             3052 M inactive memory
             4720 M free memory
                0 M buffer memory
             3130 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    * networking.service                 loaded failed failed Raise network interfaces
    12 loaded units listed.
    *** FILESYSTEM ***
    Filesystem     Type   Size  Used Avail Use% Mounted on
    /dev/loop1     ext4    12G  2.0G  9.2G  18% /
    none           tmpfs  492K  4.0K  488K   1% /dev
    tmpfs          tmpfs   15G     0   15G   0% /dev/shm
    tmpfs          tmpfs  5.9G   72K  5.9G   1% /run
    tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
    [Mon Jan 29 18:38:56 2024] EXT4-fs (dm-1): mounted filesystem 00f6a6d1-3114-4076-a271-1888ec86d71e ro with ordered data mode. Quota mode: none.
    [Mon Jan 29 18:38:56 2024] EXT4-fs (dm-1): re-mounted 00f6a6d1-3114-4076-a271-1888ec86d71e r/w. Quota mode: none.
    [Mon Jan 29 18:38:58 2024] EXT4-fs (sda1): mounted filesystem 77f8d533-299f-4623-b58f-dd04c3b7ca37 r/w with ordered data mode. Quota mode: none.
    [Mon Jan 29 18:39:06 2024] EXT4-fs (dm-6): mounted filesystem af4ca989-a3ad-47ba-9531-70d67e3b340e r/w with ordered data mode. Quota mode: none.
    [Mon Jan 29 18:39:08 2024] EXT4-fs (dm-7): mounted filesystem 83957904-47b6-4cdc-a603-8c1ca3192aa7 r/w with ordered data mode. Quota mode: none.
    [Mon Jan 29 18:39:10 2024] EXT4-fs (loop0): mounted filesystem ba3a3211-6e2e-453e-ab2d-87a60fa02e8f r/w with ordered data mode. Quota mode: none.
    [Mon Jan 29 18:44:36 2024] EXT4-fs (loop1): mounted filesystem 906f7bce-d75c-41ef-b4f9-1e99bf576c90 r/w with ordered data mode. Quota mode: none.
    [Mon Jan 29 18:44:57 2024] EXT4-fs (loop1): unmounting filesystem 906f7bce-d75c-41ef-b4f9-1e99bf576c90.
    [Mon Jan 29 18:45:07 2024] EXT4-fs (loop1): mounted filesystem 906f7bce-d75c-41ef-b4f9-1e99bf576c90 r/w with ordered data mode. Quota mode: none.
    [Mon Jan 29 19:01:06 2024] EXT4-fs (loop1): unmounting filesystem 906f7bce-d75c-41ef-b4f9-1e99bf576c90.
    [Mon Jan 29 19:01:07 2024] EXT4-fs (loop1): mounted filesystem 906f7bce-d75c-41ef-b4f9-1e99bf576c90 r/w with ordered data mode. Quota mode: none.
    TARGET SOURCE     FSTYPE OPTIONS
    /      /dev/loop1 ext4   rw,relatime
    /var:
    417M    /var/
    247M    /var/cache
    243M    /var/cache/apt
    168M    /var/cache/apt/archives
    145M    /var/lib
          Users in the 'systemd-journal' group can see all messages. Pass -q to
          turn off this notice.
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    15M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
    384K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-test                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker-test                            -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker-test                            -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Objects and States
    Objects:        142
    States:         105
    Hit:2 http://security.debian.org bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          291741     327/master
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       508272     11354/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       508265     11354/iobroker.js-c
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          474036     1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       507772     11372/io.admin.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          291742     327/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          247375     1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          474040     1/init
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          474038     1/init
    udp6       0      0 :::111                  :::*                                0          474042     1/init
    2024-01-29 19:23:40.582  - info: host.iobroker-test connected to Objects and States
    2024-01-29 19:23:40.588  - info: host.iobroker-test added notifications configuration of host
    2024-01-29 19:23:40.725  - info: host.iobroker-test Delete state "system.host.iobroker-test.versions.nodeCurrent"
    2024-01-29 19:23:40.726  - info: host.iobroker-test 3 instances found
    2024-01-29 19:23:40.728  - info: host.iobroker-test starting 3 instances
    2024-01-29 19:23:40.732  - info: host.iobroker-test Delete state "system.host.iobroker-test.versions.nodeNewest"
    2024-01-29 19:23:40.738  - info: host.iobroker-test Delete state "system.host.iobroker-test.versions.nodeNewestNext"
    2024-01-29 19:23:40.740  - info: host.iobroker-test Delete state "system.host.iobroker-test.versions.npmCurrent"
    2024-01-29 19:23:40.743  - info: host.iobroker-test instance system.adapter.admin.0 started with pid 11372
    2024-01-29 19:23:40.745  - info: host.iobroker-test Delete state "system.host.iobroker-test.versions.npmNewest"
    2024-01-29 19:23:40.746  - info: host.iobroker-test Delete state "system.host.iobroker-test.versions.npmNewestNext"
    2024-01-29 19:23:40.789  - info: host.iobroker-test Some obsolete host states deleted.
    2024-01-29 19:23:41.248  - info: admin.0 (11372) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.17
    2024-01-29 19:23:41.256  - info: admin.0 (11372) requesting all objects
    2024-01-29 19:23:41.290  - info: admin.0 (11372) received all objects
    2024-01-29 19:23:41.295  - warn: admin.0 (11372) Repository cannot be read: Active repo - stable
    2024-01-29 19:23:41.295  - warn: admin.0 (11372) Active repository "stable" cannot be read
    2024-01-29 19:23:41.356  - info: admin.0 (11372) socket.io server listening on port 8081
    2024-01-29 19:23:41.357  - info: admin.0 (11372) http server listening on port 8081
    2024-01-29 19:23:41.357  - info: admin.0 (11372) Use link "http://127.0.0.1:8081" to configure.
    2024-01-29 19:23:44.738  - info: host.iobroker-test instance system.adapter.discovery.0 started with pid 11399
    2024-01-29 19:23:45.149  - info: discovery.0 (11399) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.0, js-controller: 5.0.17
    2024-01-29 19:23:48.736  - info: host.iobroker-test instance system.adapter.backitup.0 started with pid 11414
    2024-01-29 19:23:49.176  - info: backitup.0 (11414) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
    2024-01-29 19:23:49.190  - info: backitup.0 (11414) [iobroker] backup will be activated at 02:48 every 1 day(s)
    crunchipC Offline
    crunchipC Offline
    @hausbaer sagte in kein iobroker-Backup mit Backitup:
    Scheinbar nicht ganz nach der Anleitung😉
    • H Offline
      Hausbaer
      @meister-mopper sagte in kein iobroker-Backup mit Backitup:
      Und wie krieg ich den ganzen Kram jetzt gebacken?
      Die Anleitung von @crunchip ist schon die richtige.
      Sorry, aber welche Anleitung meinst du?
      diese hier? https://forum.iobroker.net/topic/71478/plötzliche-probleme-durch-nodejs-dfsg-version-npm-fehlt
      Wieso will eigentlich kein Mensch mehr suchen, richtige Lösungen werden glaube ich immer seltener (ich werde auch schon müde 😁 ).
      Das kann ich so leider nicht stehen lassen. Nach welchen Punkten soll ich suchen, wenn mir nicht klar ist, nach was? Wo liegt der Fehler, was ist mein Problem?
      MartinPM simatecS 2 Antworten Letzte Antwort
      • H Hausbaer
        MartinPM Offline
        MartinPM Offline
        MartinP
        @hausbaer mir scheint es da Probleme mit dem Betriebssystem zu geben
        • H Hausbaer
          simatecS Offline
          simatecS Offline
          simatec
          @hausbaer
          Hier liegt schonmal das erste Problem.
          2024-01-29 14:40:34.222 error [iobroker/iobroker] FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
          Bitte führe das Backup auf der CLI aus und poste hier die Ausgabe.
          iob backup
          • Besuche meine Github Seite
          • HowTo Restore ioBroker
          H 1 Antwort Letzte Antwort
          • CodierknechtC Offline
            Codierknecht
            @Hausbaer
            Mit welchem Template hast Du den LXC aufgesetzt?
            HmIP|ZigBee|Tasmota|Unifi
            Zabbix Certified Specialist
            • simatecS simatec
              @hausbaer
              iob backup
              Hausbaer
              @simatec
              HIer die Ausgabe:
              helmut@iobroker:~$ iob backup
              host.iobroker 34560 states saved
              host.iobroker 41492 objects saved
              <--- Last few GCs --->
              [58582:0x5c3f870]    62679 ms: Mark-sweep (reduce) 2047.4 (2081.8) -> 2046.4 (2081.8) MB, 620.5 / 0.0 ms  (+ 194.7 ms in 38 steps since start of marking, biggest step 27.1 ms, walltime since start of marking 1055 ms) (average mu = 0.497, current mu = 0.50[58582:0x5c3f870]    64210 ms: Mark-sweep (reduce) 2047.5 (2081.9) -> 2046.8 (2082.1) MB, 851.5 / 0.0 ms  (+ 42.6 ms in 8 steps since start of marking, biggest step 26.7 ms, walltime since start of marking 991 ms) (average mu = 0.458, current mu = 0.416)
              <--- JS stacktrace --->
               1: 0xb95b60 node::Abort() [node]
               2: 0xa9a7f8  [node]
               3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [node]
               4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [node]
               5: 0xf4cba5  [node]
               6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [node]
               7: 0xf3978e v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node]
               8: 0xf3ab57 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node]
               9: 0xf1b0a0 v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [node]
              10: 0xf12b14 v8::internal::FactoryBase<v8::internal::Factory>::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [node]
              11: 0xf14dc8 v8::internal::FactoryBase<v8::internal::Factory>::NewRawOneByteString(int, v8::internal::AllocationType) [node]
              12: 0xf1e38d v8::internal::Factory::NewStringFromUtf8(v8::base::Vector<char const> const&, v8::internal::AllocationType) [node]
              13: 0xd7e3a3 v8::String::NewFromUtf8(v8::Isolate*, char const*, v8::NewStringType, int) [node]
              14: 0xc81e39 node::StringBytes::Encode(v8::Isolate*, char const*, unsigned long, node::encoding, v8::Local<v8::Value>*) [node]
              15: 0xb6870d  [node]
              16: 0x169372f  [node]
              /usr/bin/iob: line 12: 58580 Aborted                 sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
              helmut@iobroker:~$
              • CodierknechtC Codierknecht
                @Hausbaer
                Hausbaer
                @codierknecht
                • H Hausbaer
                  @codierknecht
                  MartinPM Offline
                  MartinPM Offline
                  MartinP
                  @hausbaer Welche Rechte hat denn der User "helmut"
                  groups helmut
                  groups iobroker
                  • H Offline
                    Hausbaer
                    @martinp sagte in kein iobroker-Backup mit Backitup:
                    groups iobroker
                    helmut@iobroker:~$ groups helmut
                    helmut : helmut sudo users iobroker
                    helmut@iobroker:~$ groups iobroker
                    iobroker : iobroker tty dialout audio video
                    helmut@iobroker:~$
                    • H Hausbaer
                      groups iobroker
                      helmut@iobroker:~$
                      MartinPM Offline
                      MartinPM Offline
                      MartinP
                      @hausbaer Schade, ich habe auch einen LXC-Container mit Debian für iobroker. Der ist aber mit Debian 11 aufgesetzt worden, und dann irgendwann auf Debian 12 hochgezogen ...
                      Der "iobroker" User und "martin" sehen bei mir jedenfalls auch so aus ...
                      Bin etwas Ratlos ...
                      Hier noch die Proxmox Optionen meines Containers
                      H Meister MopperM 2 Antworten Letzte Antwort
                      • MartinPM MartinP
                        Hausbaer
                        @martinp
                        Sieht bei mir ähnlich aus, mit Ausnahme des priviligierten Containers
                        • MartinPM MartinP
                          Meister MopperM Online
                          Meister Mopper
                          keyctl im lxc vergessen?
                          Proxmox und HA ...
                          • H Hausbaer
                            @martinp
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            @hausbaer wo sicherst Du eigentlich per Backitup hin ? Nur lokal oder auf eine NAS ?
                            Lehrling seit 1975 !!!
                            • DJMarc75D DJMarc75
                              Hausbaer
                              @djmarc75 per FTP auf Nas
                              • H Hausbaer
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                per FTP auf Nas
                                kann die unbekannte NAS kein NFS ?
                                • H Offline
                                  Hausbaer
                                  Oh Mann.
                                  Ich hab vorhin gesehen, dass einige Bilder relativ groß waren und diese gelöscht und in verkleinerter Form wieder hinzugefügt.
                                  Jetzt funktioniert das Backup - hat aber eine Größe von 118 MB.
                                  Mir sind um die 50 MB bekannt und bewusst. Diese Größe ünerrascht mich, ich werde da mal auf die Suche gehen.
                                  • H Offline
                                    Hausbaer
                                    schrieb am zuletzt editiert von Hausbaer
                                    Gibt's eigentlich Richtwerte, wie groß das sein soll?
                                    /usr
                                    /var
                                    • H Offline
                                      Hausbaer
                                      Doppelpost
                                      • H Hausbaer
                                        Doppelpost
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        Doppelpost
                                        nein, Dreifachpost ;)
                                          Doppelpost
                                          Hausbaer
                                          @djmarc75 nein, nicht mehr😁
                                          Blöde Ungeduld
