  4. Ziggbe sendet nicht mehr an empfängt aber noch Daten
67 Beiträge 6 Kommentatoren 9.0k Aufrufe 6 Beobachtet
    @tapdance-0
    Vertan.
    iobroker upgrade all
    Tapdance 0
    Updates müssten jetzt glaube ich alle durch sein. Wie ich den Pfad beim Comport eintrage weiß ich nicht hier die aktuellen Logs noch mal
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.1.0-rpi7-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     17:06:09 up 6 min,  3 users,  load average: 0.55, 0.84, 0.47
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2024-01-21 17:06:09 CET
               Universal time: Sun 2024-01-21 16:06:09 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    PI
    /home/PI
    PI adm dialout cdrom sudo audio video plugdev games users input render netdev lp        admin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            4.0G        1.7G        1.9G        1.3M        423M        2.3G
    Swap:           104M          0B        104M
    Total:          4.1G        1.7G        2.1G
             3793 M total memory
             1606 M used memory
             1636 M active memory
              170 M inactive memory
             1858 M free memory
               40 M buffer memory
              363 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  379M   1% /run
    /dev/mmcblk0p2 ext4       28G  7.1G   20G  27% /
    tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
    tmpfs          tmpfs     380M   32K  380M   1% /run/user/1000
    [Sun Jan 21 16:59:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:64:62:CC vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=9515910b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles
    [Sun Jan 21 16:59:59 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
    [Sun Jan 21 17:00:02 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    651M    /var/
    194M    /var/lib
    185M    /var/cache
    172M    /var/cache/apt
    171M    /var/log
    Archived and active journals take up 169.5M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    373M    /opt/iobroker/iobroker-data/
    270M    /opt/iobroker/iobroker-data/files
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    73M     /opt/iobroker/iobroker-data/backup-objects
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    23M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
    7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
    7.2M    /opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   0
    Adapter State
    + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
      system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
    + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 192.168.2.4, run as: admin
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
    + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
    + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00
    + instance is alive
    ioBroker-Repositories
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Stable (default): http://download.iobroker.net/sources-dist.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alarm"        : 3.6.0    , installed 3.6.0
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Objects and States
    Objects:        5503
    States:         4905
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18478      778/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17466      768/cupsd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16860      769/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17647      769/iobroker.js-con
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17854      1111/io.sonoff.0
    tcp        0      0 192.168.2.4:2001        0.0.0.0:*               LISTEN      1001       16989      1042/io.hm-rpc.0
    tcp        0      0 192.168.2.4:2010        0.0.0.0:*               LISTEN      1001       15037      1049/io.hm-rpc.1
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17465      768/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          18480      778/sshd: /usr/sbin
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       22647      1525/io.terminal.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17701      946/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22866      1945/io.web.0
    tcp6       0      0 :::38469                :::*                    LISTEN      1001       20981      1983/io.yahka.0
    udp        0      0 0.0.0.0:44484           0.0.0.0:*                           104        17409      580/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       17826      1091/io.shelly.0
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16777      818/cups-browsed
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       17236      1286/io.broadlink2.
    udp        0      0 0.0.0.0:44173           0.0.0.0:*                           1001       17239      1286/io.broadlink2.
    udp        0      0 0.0.0.0:56537           0.0.0.0:*                           1001       23299      1286/io.broadlink2.
    udp        0      0 192.168.2.4:5353        0.0.0.0:*                           1001       19061      1146/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        12287      580/avahi-daemon: r
    udp6       0      0 :::50851                :::*                                104        17410      580/avahi-daemon: r
    udp6       0      0 fe80::67d1:e1cb:7ef:546 :::*                                0          17623      706/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        12288      580/avahi-daemon: r
    2024-01-21 17:06:49.735  - warn: sonoff.0 (1111) Client [Pool Pumpe] has invalid password or username
    2024-01-21 17:06:51.462  - warn: sonoff.0 (1111) Client [Muschel Terrasse] has invalid password or username
    2024-01-21 17:06:52.102  - warn: sonoff.0 (1111) Client [Pavillon Beleuchtung] has invalid password or username
    2024-01-21 17:06:54.224  - warn: shelly.0 (1091) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-21 17:06:54.227  - warn: sonoff.0 (1111) Client [Taster-Schlafzimmer-Bett-L] has invalid password or username
    2024-01-21 17:06:54.230  - warn: sonoff.0 (1111) Client [Wohnzimmer-Vitrine] has invalid password or username
    2024-01-21 17:06:54.288  - warn: shelly.0 (1091) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-21 17:06:54.315  - warn: shelly.0 (1091) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-21 17:06:56.433  - warn: sonoff.0 (1111) Client [PC-Buero] has invalid password or username
    2024-01-21 17:07:03.413  - warn: shelly.0 (1091) State value to set for "shelly.0.SHDM-2#8CAAB54C4E21#1.temperatureF" has value "141.05" greater than max "100"
    2024-01-21 17:07:06.195  - warn: shelly.0 (1091) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-21 17:07:06.513  - warn: shelly.0 (1091) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-21 17:07:07.480  - warn: shelly.0 (1091) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-21 17:07:14.240  - warn: sonoff.0 (1111) Client [Pool Beleuchtung] has invalid password or username
    2024-01-21 17:07:15.493  - warn: sonoff.0 (1111) Client [Pool Pumpe] has invalid password or username
    2024-01-21 17:07:17.252  - warn: sonoff.0 (1111) Client [Muschel Terrasse] has invalid password or username
    2024-01-21 17:07:17.896  - warn: sonoff.0 (1111) Client [Pavillon Beleuchtung] has invalid password or username
    2024-01-21 17:07:18.796  - warn: shelly.0 (1091) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-21 17:07:20.186  - warn: sonoff.0 (1111) Client [Wohnzimmer-Vitrine] has invalid password or username
    2024-01-21 17:07:20.188  - warn: sonoff.0 (1111) Client [Taster-Schlafzimmer-Bett-L] has invalid password or username
    2024-01-21 17:07:20.405  - warn: shelly.0 (1091) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-21 17:07:22.524  - warn: sonoff.0 (1111) Client [PC-Buero] has invalid password or username
    2024-01-21 17:07:26.175  - warn: shelly.0 (1091) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-21 17:07:32.167  - warn: shelly.0 (1091) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-21 17:07:33.565  - warn: shelly.0 (1091) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
    iob diag has finished.
    PI@raspberrypi:~ $ iob logs | grep zigbee
    2024-01-21 16:58:32.729  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2024-01-21 16:58:32.736  - info: zigbee.0 (5918) Got terminate signal TERMINATE_YOURSELF
    2024-01-21 16:58:32.855  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
    2024-01-21 16:58:33.857  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 5918
    2024-01-21 16:58:35.954  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 6066
    2024-01-21 16:58:32.738  - info: zigbee.0 (5918) cleaned everything up...
    2024-01-21 16:58:32.772  - info: zigbee.0 (5918) Zigbee: disabling joining new devices.
    2024-01-21 16:58:32.773  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d00044d8e0b = false
    2024-01-21 16:58:32.785  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d00044d8e0b = 0
    2024-01-21 16:58:32.797  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d000257bae7 = false
    2024-01-21 16:58:32.810  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d000257bae7 = 0
    2024-01-21 16:58:32.820  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d00045f7cee = false
    2024-01-21 16:58:32.825  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d00045f7cee = 0
    2024-01-21 16:58:32.831  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d0004521481 = false
    2024-01-21 16:58:32.836  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d0004521481 = 0
    2024-01-21 16:58:32.843  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d000461b53e = false
    2024-01-21 16:58:32.849  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d000461b53e = 0
    2024-01-21 16:58:32.855  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x680ae2fffec91ea4 = false
    2024-01-21 16:58:32.860  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x680ae2fffec91ea4 = 0
    2024-01-21 16:58:32.867  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x588e81fffe2b8762 = false
    2024-01-21 16:58:32.873  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x588e81fffe2b8762 = 0
    2024-01-21 16:58:32.880  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x680ae2fffe924d57 = false
    2024-01-21 16:58:32.885  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x680ae2fffe924d57 = 0
    2024-01-21 16:58:32.892  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d00045eb708 = false
    2024-01-21 16:58:32.897  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d00045eb708 = 0
    2024-01-21 16:58:32.905  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d0002a71e25 = false
    2024-01-21 16:58:32.909  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d0002a71e25 = 0
    2024-01-21 16:58:32.915  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c794764 = false
    2024-01-21 16:58:32.919  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c794764 = 0
    2024-01-21 16:58:32.925  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c7946a1 = false
    2024-01-21 16:58:32.929  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7946a1 = 0
    2024-01-21 16:58:32.933  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d00045f8d3d = false
    2024-01-21 16:58:32.938  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d00045f8d3d = 0
    2024-01-21 16:58:32.943  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d0004597653 = false
    2024-01-21 16:58:32.947  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d0004597653 = 0
    2024-01-21 16:58:32.952  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x842e14fffe768d41 = false
    2024-01-21 16:58:32.956  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x842e14fffe768d41 = 0
    2024-01-21 16:58:32.962  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xbc33acfffe2ab392 = false
    2024-01-21 16:58:32.965  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xbc33acfffe2ab392 = 0
    2024-01-21 16:58:32.970  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c7b5255 = false
    2024-01-21 16:58:32.974  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b5255 = 0
    2024-01-21 16:58:32.980  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c7b51f7 = false
    2024-01-21 16:58:32.985  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b51f7 = 0
    2024-01-21 16:58:32.990  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c78b7ba = false
    2024-01-21 16:58:32.993  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c78b7ba = 0
    2024-01-21 16:58:32.998  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d000461da61 = false
    2024-01-21 16:58:33.001  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d000461da61 = 0
    2024-01-21 16:58:33.005  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef87315 = false
    2024-01-21 16:58:33.008  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87315 = 0
    2024-01-21 16:58:33.012  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef8731e = false
    2024-01-21 16:58:33.016  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef8731e = 0
    2024-01-21 16:58:33.019  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef84d2d = false
    2024-01-21 16:58:33.022  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef84d2d = 0
    2024-01-21 16:58:33.027  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef87b6a = false
    2024-01-21 16:58:33.030  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87b6a = 0
    2024-01-21 16:58:33.033  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef853ac = false
    2024-01-21 16:58:33.036  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef853ac = 0
    2024-01-21 16:58:33.040  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cd15fffefe9ca8 = false
    2024-01-21 16:58:33.043  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cd15fffefe9ca8 = 0
    2024-01-21 16:58:33.046  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xa4c138c66404899e = false
    2024-01-21 16:58:33.049  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xa4c138c66404899e = 0
    2024-01-21 16:58:39.403  - warn: zigbee.0 (5918) Failed to stop zigbee during startup
    2024-01-21 16:58:39.405  - info: zigbee.0 (5918) terminating
    2024-01-21 16:58:39.408  - debug: zigbee.0 (5918) Plugin sentry destroyed
    2024-01-21 16:58:39.409  - info: zigbee.0 (5918) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-01-21 16:58:39.412  - info: zigbee.0 (5918) terminating
    2024-01-21 16:58:39.502  - warn: zigbee.0 (5918) Got terminate signal. Checking desired PID: 0 vs own PID 5918
    2024-01-21 16:58:39.504  - warn: zigbee.0 (5918) Got terminate signal. Checking desired PID: 6066 vs own PID 5918
    2024-01-21 16:58:39.560  - info: zigbee.0 (5918) debug devices set to []
    2024-01-21 16:58:40.065  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2024-01-21 16:58:40.065  - info: host.raspberrypi Do not restart adapter system.adapter.zigbee.0 because desired by instance
    2024-01-21 16:58:40.406  - debug: zigbee.0 (6066) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2024-01-21 16:58:40.452  - debug: zigbee.0 (6066) Objects client ready ... initialize now
    2024-01-21 16:58:40.455  - debug: zigbee.0 (6066) Objects create System PubSub Client
    2024-01-21 16:58:40.457  - debug: zigbee.0 (6066) Objects create User PubSub Client
    2024-01-21 16:58:40.538  - debug: zigbee.0 (6066) Objects client initialize lua scripts
    2024-01-21 16:58:40.549  - debug: zigbee.0 (6066) Objects connected to redis: 127.0.0.1:9001
    2024-01-21 16:58:40.596  - debug: zigbee.0 (6066) Redis States: Use Redis connection: 127.0.0.1:9000
    2024-01-21 16:58:40.616  - debug: zigbee.0 (6066) States create System PubSub Client
    2024-01-21 16:58:40.617  - debug: zigbee.0 (6066) States create User PubSub Client
    2024-01-21 16:58:40.688  - debug: zigbee.0 (6066) States connected to redis: 127.0.0.1:9000
    2024-01-21 16:58:40.742  - debug: zigbee.0 (6066) Plugin sentry Initialize Plugin (enabled=true)
    2024-01-21 16:58:41.361  - info: zigbee.0 (6066) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
    2024-01-21 16:58:41.396  - debug: zigbee.0 (6066) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
    2024-01-21 16:58:41.477  - info: zigbee.0 (6066) delete old Backup files. keep only last 10
    2024-01-21 16:58:41.480  - info: zigbee.0 (6066) Starting Zigbee  npm ...
    2024-01-21 16:58:41.526  - debug: zigbee.0 (6066) Starting zigbee-herdsman...
    2024-01-21 16:58:41.876  - error: zigbee.0 (6066) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
    2024-01-21 16:58:41.877  - error: zigbee.0 (6066) Failed to start Zigbee
    2024-01-21 16:58:41.877  - error: zigbee.0 (6066) Error herdsman start
    2024-01-21 16:58:41.881  - info: zigbee.0 (6066) Installed Version: iobroker.zigbee@1.10.1
    2024-01-21 16:58:42.387  - debug: zigbee.0 (6066) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_21-16_58_41.tar.gz success
    2024-01-21 16:58:51.881  - info: zigbee.0 (6066) Try to reconnect. 1 attempts left
    2024-01-21 16:58:51.882  - info: zigbee.0 (6066) Starting Zigbee  npm ...
    2024-01-21 16:58:51.887  - debug: zigbee.0 (6066) Starting zigbee-herdsman...
    2024-01-21 16:58:51.898  - error: zigbee.0 (6066) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
    2024-01-21 16:58:51.899  - error: zigbee.0 (6066) Failed to start Zigbee
    2024-01-21 16:58:51.899  - error: zigbee.0 (6066) Error herdsman start
    2024-01-21 16:58:51.907  - info: zigbee.0 (6066) Installed Version: iobroker.zigbee@1.10.1
    2024-01-21 16:59:25.780  - info: zigbee.0 (6066) cleaned everything up...
    2024-01-21 16:59:25.828  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=false)
    2024-01-21 16:59:25.876  - info: zigbee.0 (6066) Zigbee: disabling joining new devices.
    2024-01-21 16:59:25.877  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d00044d8e0b = false
    2024-01-21 16:59:25.893  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d00044d8e0b = 0
    2024-01-21 16:59:25.905  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d000257bae7 = false
    2024-01-21 16:59:25.916  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d000257bae7 = 0
    2024-01-21 16:59:25.928  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d00045f7cee = false
    2024-01-21 16:59:25.934  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d00045f7cee = 0
    2024-01-21 16:59:25.964  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d0004521481 = false
    2024-01-21 16:59:25.968  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d0004521481 = 0
    2024-01-21 16:59:25.974  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d000461b53e = false
    2024-01-21 16:59:25.979  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d000461b53e = 0
    2024-01-21 16:59:25.993  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x680ae2fffec91ea4 = false
    2024-01-21 16:59:26.015  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x680ae2fffec91ea4 = 0
    2024-01-21 16:59:26.024  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x588e81fffe2b8762 = false
    2024-01-21 16:59:26.030  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x588e81fffe2b8762 = 0
    2024-01-21 16:59:26.038  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x680ae2fffe924d57 = false
    2024-01-21 16:59:26.044  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x680ae2fffe924d57 = 0
    2024-01-21 16:59:26.063  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d00045eb708 = false
    2024-01-21 16:59:26.071  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d00045eb708 = 0
    2024-01-21 16:59:26.077  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d0002a71e25 = false
    2024-01-21 16:59:26.082  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d0002a71e25 = 0
    2024-01-21 16:59:26.088  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c794764 = false
    2024-01-21 16:59:26.092  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c794764 = 0
    2024-01-21 16:59:26.096  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c7946a1 = false
    2024-01-21 16:59:26.103  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7946a1 = 0
    2024-01-21 16:59:26.109  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d00045f8d3d = false
    2024-01-21 16:59:26.112  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d00045f8d3d = 0
    2024-01-21 16:59:26.125  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d0004597653 = false
    2024-01-21 16:59:26.129  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d0004597653 = 0
    2024-01-21 16:59:26.134  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x842e14fffe768d41 = false
    2024-01-21 16:59:26.139  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x842e14fffe768d41 = 0
    2024-01-21 16:59:26.144  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xbc33acfffe2ab392 = false
    2024-01-21 16:59:26.147  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xbc33acfffe2ab392 = 0
    2024-01-21 16:59:26.155  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c7b5255 = false
    2024-01-21 16:59:26.161  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b5255 = 0
    2024-01-21 16:59:26.167  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c7b51f7 = false
    2024-01-21 16:59:26.173  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b51f7 = 0
    2024-01-21 16:59:26.182  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c78b7ba = false
    2024-01-21 16:59:26.186  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c78b7ba = 0
    2024-01-21 16:59:26.197  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d000461da61 = false
    2024-01-21 16:59:26.201  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d000461da61 = 0
    2024-01-21 16:59:26.206  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef87315 = false
    2024-01-21 16:59:26.211  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87315 = 0
    2024-01-21 16:59:26.216  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef8731e = false
    2024-01-21 16:59:26.220  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef8731e = 0
    2024-01-21 16:59:26.225  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef84d2d = false
    2024-01-21 16:59:26.229  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef84d2d = 0
    2024-01-21 16:59:26.234  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef87b6a = false
    2024-01-21 16:59:26.238  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87b6a = 0
    2024-01-21 16:59:26.246  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef853ac = false
    2024-01-21 16:59:26.249  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef853ac = 0
    2024-01-21 16:59:26.257  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cd15fffefe9ca8 = false
    2024-01-21 16:59:26.261  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cd15fffefe9ca8 = 0
    2024-01-21 16:59:26.268  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xa4c138c66404899e = false
    2024-01-21 16:59:26.271  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xa4c138c66404899e = 0
    2024-01-21 16:59:31.550  - warn: zigbee.0 (6066) Failed to stop zigbee during startup
    2024-01-21 16:59:31.682  - error: zigbee.0 (6066) Objects database error: write EPIPE
    2024-01-21 16:59:31.751  - info: zigbee.0 (6066) terminating
    2024-01-21 16:59:31.752  - debug: zigbee.0 (6066) Plugin sentry destroyed
    2024-01-21 16:59:31.753  - info: zigbee.0 (6066) Terminated (NO_ERROR): Without reason
    2024-01-21 16:59:31.753  - info: zigbee.0 (6066) terminating
    2024-01-21 16:59:32.687  - info: zigbee.0 (6066) terminating with timeout
    2024-01-21 17:01:20.456  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1190
    2024-01-21 17:01:27.027  - debug: zigbee.0 (1190) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2024-01-21 17:01:27.080  - debug: zigbee.0 (1190) Objects client ready ... initialize now
    2024-01-21 17:01:27.084  - debug: zigbee.0 (1190) Objects create System PubSub Client
    2024-01-21 17:01:27.086  - debug: zigbee.0 (1190) Objects create User PubSub Client
    2024-01-21 17:01:27.162  - debug: zigbee.0 (1190) Objects client initialize lua scripts
    2024-01-21 17:01:27.176  - debug: zigbee.0 (1190) Objects connected to redis: 127.0.0.1:9001
    2024-01-21 17:01:27.225  - debug: zigbee.0 (1190) Redis States: Use Redis connection: 127.0.0.1:9000
    2024-01-21 17:01:27.247  - debug: zigbee.0 (1190) States create System PubSub Client
    2024-01-21 17:01:27.248  - debug: zigbee.0 (1190) States create User PubSub Client
    2024-01-21 17:01:27.339  - debug: zigbee.0 (1190) States connected to redis: 127.0.0.1:9000
    2024-01-21 17:01:27.397  - debug: zigbee.0 (1190) Plugin sentry Initialize Plugin (enabled=true)
    2024-01-21 17:01:28.242  - info: zigbee.0 (1190) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
    2024-01-21 17:01:28.283  - debug: zigbee.0 (1190) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
    2024-01-21 17:01:28.387  - info: zigbee.0 (1190) delete old Backup files. keep only last 10
    2024-01-21 17:01:28.390  - info: zigbee.0 (1190) Starting Zigbee  npm ...
    2024-01-21 17:01:28.468  - debug: zigbee.0 (1190) Starting zigbee-herdsman...
    2024-01-21 17:01:29.117  - error: zigbee.0 (1190) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
    2024-01-21 17:01:29.118  - error: zigbee.0 (1190) Failed to start Zigbee
    2024-01-21 17:01:29.118  - error: zigbee.0 (1190) Error herdsman start
    2024-01-21 17:01:29.123  - info: zigbee.0 (1190) Installed Version: iobroker.zigbee@1.10.1
    2024-01-21 17:01:29.643  - debug: zigbee.0 (1190) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_21-17_01_28.tar.gz success
    2024-01-21 17:01:39.122  - info: zigbee.0 (1190) Try to reconnect. 1 attempts left
    2024-01-21 17:01:39.123  - info: zigbee.0 (1190) Starting Zigbee  npm ...
    2024-01-21 17:01:39.128  - debug: zigbee.0 (1190) Starting zigbee-herdsman...
    2024-01-21 17:01:39.139  - error: zigbee.0 (1190) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
    2024-01-21 17:01:39.140  - error: zigbee.0 (1190) Failed to start Zigbee
    2024-01-21 17:01:39.141  - error: zigbee.0 (1190) Error herdsman start
    2024-01-21 17:01:39.149  - info: zigbee.0 (1190) Installed Version: iobroker.zigbee@1.10.1
    2024-01-21 17:04:17.656  - error: zigbee.0 (1190) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    2024-01-21 17:04:18.043  - info: zigbee.0 (1190) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"8eb6f719a99ded11ad35dca5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"}]
    • T Tapdance 0
      Skript v.2023-10-10
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      PI
      /home/PI
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           104M          0B        104M
               3793 M total memory
               1606 M used memory
               1858 M free memory
                 40 M buffer memory
                363 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      651M    /var/
      194M    /var/lib
      185M    /var/cache
      172M    /var/cache/apt
      171M    /var/log
      USB-Devices by-id:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        5503
      States:         4905
      Pending Updates: 0
      @tapdance-0 sagte in Ziggbe sendet nicht mehr an empfängt aber noch Daten:
      Da:
      das eintragen:
      T 2 Antworten Letzte Antwort
        Da:
        das eintragen:
        Tapdance 0
        geht leider nicht da der Adapter nicht startet.
        Bekomme immer folgende Meldung wenn ich darauf gehe.
        You need save and run adapter before pairing!
        T AsgothianA 2 Antworten Letzte Antwort
        • T Tapdance 0
          Tapdance 0
          @tapdance-0
          starte das System noch mal komplett neu mit
          sudo reboot
          • T Tapdance 0
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            Das ist normal. Du solltest trotzdem auf die Seite zum konfigurieren kommen um da Einstellungen zu machen.
            A.
            • AsgothianA Asgothian
              A.
              Tapdance 0
              @asgothian
              leider nicht
              • T Tapdance 0
                @asgothian
                leider nicht
                Tapdance 0
                @tapdance-0
                Neustart hat auch nichts gebracht
                2024-01-21 17:16:30.300  - error: zigbee.0 (1190) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                2024-01-21 17:16:30.544  - info: zigbee.0 (1190) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"8eb6f719a99ded11ad35dca5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"}]
                2024-01-21 17:16:55.971  - error: zigbee.0 (1190) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                2024-01-21 17:16:56.206  - info: zigbee.0 (1190) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"8eb6f719a99ded11ad35dca5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"}]
                2024-01-21 17:18:59.211  - info: zigbee.0 (1190) cleaned everything up...
                2024-01-21 17:18:59.251  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                2024-01-21 17:18:59.762  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                2024-01-21 17:19:00.770  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 1190
                2024-01-21 17:18:59.315  - info: zigbee.0 (1190) Zigbee: disabling joining new devices.
                2024-01-21 17:18:59.317  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d00044d8e0b = false
                2024-01-21 17:18:59.332  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d00044d8e0b = 0
                2024-01-21 17:18:59.344  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d000257bae7 = false
                2024-01-21 17:18:59.360  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d000257bae7 = 0
                2024-01-21 17:18:59.382  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d00045f7cee = false
                2024-01-21 17:18:59.386  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d00045f7cee = 0
                2024-01-21 17:18:59.392  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d0004521481 = false
                2024-01-21 17:18:59.396  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d0004521481 = 0
                2024-01-21 17:18:59.411  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d000461b53e = false
                2024-01-21 17:18:59.429  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d000461b53e = 0
                2024-01-21 17:18:59.435  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x680ae2fffec91ea4 = false
                2024-01-21 17:18:59.438  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x680ae2fffec91ea4 = 0
                2024-01-21 17:18:59.444  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x588e81fffe2b8762 = false
                2024-01-21 17:18:59.455  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x588e81fffe2b8762 = 0
                2024-01-21 17:18:59.463  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x680ae2fffe924d57 = false
                2024-01-21 17:18:59.467  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x680ae2fffe924d57 = 0
                2024-01-21 17:18:59.474  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d00045eb708 = false
                2024-01-21 17:18:59.479  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d00045eb708 = 0
                2024-01-21 17:18:59.490  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d0002a71e25 = false
                2024-01-21 17:18:59.494  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d0002a71e25 = 0
                2024-01-21 17:18:59.499  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c794764 = false
                2024-01-21 17:18:59.502  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c794764 = 0
                2024-01-21 17:18:59.507  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c7946a1 = false
                2024-01-21 17:18:59.510  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7946a1 = 0
                2024-01-21 17:18:59.515  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d00045f8d3d = false
                2024-01-21 17:18:59.518  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d00045f8d3d = 0
                2024-01-21 17:18:59.523  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d0004597653 = false
                2024-01-21 17:18:59.528  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d0004597653 = 0
                2024-01-21 17:18:59.539  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x842e14fffe768d41 = false
                2024-01-21 17:18:59.542  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x842e14fffe768d41 = 0
                2024-01-21 17:18:59.549  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xbc33acfffe2ab392 = false
                2024-01-21 17:18:59.555  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xbc33acfffe2ab392 = 0
                2024-01-21 17:18:59.562  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c7b5255 = false
                2024-01-21 17:18:59.565  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b5255 = 0
                2024-01-21 17:18:59.570  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c7b51f7 = false
                2024-01-21 17:18:59.574  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b51f7 = 0
                2024-01-21 17:18:59.579  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c78b7ba = false
                2024-01-21 17:18:59.583  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c78b7ba = 0
                2024-01-21 17:18:59.588  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d000461da61 = false
                2024-01-21 17:18:59.591  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d000461da61 = 0
                2024-01-21 17:18:59.595  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef87315 = false
                2024-01-21 17:18:59.599  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87315 = 0
                2024-01-21 17:18:59.604  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef8731e = false
                2024-01-21 17:18:59.608  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef8731e = 0
                2024-01-21 17:18:59.613  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef84d2d = false
                2024-01-21 17:18:59.623  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef84d2d = 0
                2024-01-21 17:18:59.637  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef87b6a = false
                2024-01-21 17:18:59.652  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87b6a = 0
                2024-01-21 17:18:59.655  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef853ac = false
                2024-01-21 17:18:59.670  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef853ac = 0
                2024-01-21 17:18:59.689  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cd15fffefe9ca8 = false
                2024-01-21 17:18:59.692  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cd15fffefe9ca8 = 0
                2024-01-21 17:18:59.696  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xa4c138c66404899e = false
                2024-01-21 17:18:59.700  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xa4c138c66404899e = 0
                2024-01-21 17:19:03.382  - warn: zigbee.0 (1190) Failed to stop zigbee during startup
                2024-01-21 17:19:03.714  - warn: host.raspberrypi instance system.adapter.zigbee.0 terminated due to SIGTERM
                2024-01-21 17:19:03.714  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code null ()
                2024-01-21 17:20:50.131  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1208
                2024-01-21 17:20:57.122  - debug: zigbee.0 (1208) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2024-01-21 17:20:57.175  - debug: zigbee.0 (1208) Objects client ready ... initialize now
                2024-01-21 17:20:57.178  - debug: zigbee.0 (1208) Objects create System PubSub Client
                2024-01-21 17:20:57.179  - debug: zigbee.0 (1208) Objects create User PubSub Client
                2024-01-21 17:20:57.241  - debug: zigbee.0 (1208) Objects client initialize lua scripts
                2024-01-21 17:20:57.260  - debug: zigbee.0 (1208) Objects connected to redis: 127.0.0.1:9001
                2024-01-21 17:20:57.320  - debug: zigbee.0 (1208) Redis States: Use Redis connection: 127.0.0.1:9000
                2024-01-21 17:20:57.346  - debug: zigbee.0 (1208) States create System PubSub Client
                2024-01-21 17:20:57.348  - debug: zigbee.0 (1208) States create User PubSub Client
                2024-01-21 17:20:57.441  - debug: zigbee.0 (1208) States connected to redis: 127.0.0.1:9000
                2024-01-21 17:20:57.535  - debug: zigbee.0 (1208) Plugin sentry Initialize Plugin (enabled=true)
                2024-01-21 17:20:58.509  - info: zigbee.0 (1208) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                2024-01-21 17:20:58.553  - debug: zigbee.0 (1208) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
                2024-01-21 17:20:58.661  - info: zigbee.0 (1208) delete old Backup files. keep only last 10
                2024-01-21 17:20:58.663  - info: zigbee.0 (1208) Starting Zigbee  npm ...
                2024-01-21 17:20:58.724  - debug: zigbee.0 (1208) Starting zigbee-herdsman...
                2024-01-21 17:21:00.498  - error: zigbee.0 (1208) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
                2024-01-21 17:21:00.499  - error: zigbee.0 (1208) Failed to start Zigbee
                2024-01-21 17:21:00.499  - error: zigbee.0 (1208) Error herdsman start
                2024-01-21 17:21:00.507  - info: zigbee.0 (1208) Installed Version: iobroker.zigbee@1.10.1
                2024-01-21 17:21:01.087  - debug: zigbee.0 (1208) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_21-17_20_58.tar.gz success
                2024-01-21 17:21:10.505  - info: zigbee.0 (1208) Try to reconnect. 1 attempts left
                2024-01-21 17:21:10.506  - info: zigbee.0 (1208) Starting Zigbee  npm ...
                2024-01-21 17:21:10.512  - debug: zigbee.0 (1208) Starting zigbee-herdsman...
                2024-01-21 17:21:10.524  - error: zigbee.0 (1208) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
                2024-01-21 17:21:10.525  - error: zigbee.0 (1208) Failed to start Zigbee
                2024-01-21 17:21:10.526  - error: zigbee.0 (1208) Error herdsman start
                2024-01-21 17:21:10.535  - info: zigbee.0 (1208) Installed Version: iobroker.zigbee@1.10.1
                2024-01-21 17:25:54.886  - error: zigbee.0 (1208) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                2024-01-21 17:25:55.156  - info: zigbee.0 (1208) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"8eb6f719a99ded11ad35dca5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"}]
                • T Tapdance 0
                  @tapdance-0
                  Du hast da immer noch den alten Stick in den Einstellungen. Das muss durch den aktuellen Link ersetzt werden.
                  Edit:
                  Okay, hier scheint es nun drin zu sein:
                    Da:
                    das eintragen:
                    Tapdance 0
                    habe den Punkt zum eintragen des Pfades gefunden. Der wird nur angezeigt wenn man über die Instanz in Menü geht. Pfad ist eingetragen Adapter ist grün, aber leider funktioniert noch nichts.
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                     17:39:43 up 6 min,  3 users,  load average: 0.52, 0.90, 0.57
                    CPU threads: 4
                    Current issues:
                                   Local time: Sun 2024-01-21 17:39:43 CET
                               Universal time: Sun 2024-01-21 16:39:43 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    PI
                    /home/PI
                    PI adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            4.0G        1.6G        2.0G        1.3M        420M        2.3G
                    Swap:           104M          0B        104M
                    Total:          4.1G        1.6G        2.1G
                             3793 M total memory
                             1571 M used memory
                             1603 M active memory
                              166 M inactive memory
                             1897 M free memory
                               40 M buffer memory
                              359 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    [Sun Jan 21 17:32:52 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:64:62:CC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9515910b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                    [Sun Jan 21 17:32:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Sun Jan 21 17:32:59 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    /var:
                    667M    /var/
                    194M    /var/lib
                    187M    /var/log
                    186M    /var/log/journal/67fa5cc7176343b98d5ef1e5e5a27de6
                    Archived and active journals take up 185.5M in the file system.
                    368M    /opt/iobroker/iobroker-data/
                    24M     /opt/iobroker/iobroker-data/objects.jsonl
                    7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                         18.13.0+dfsg1-1 500
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0
                    + instance is alive
                    Objects and States
                    Objects:        5503
                    States:         4905
                    Pending Updates: 0
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12153      804/sshd: /usr/sbin
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16485      794/cupsd
                    tcp        0      0 192.168.2.4:2001        0.0.0.0:*               LISTEN      1001       19586      1091/io.hm-rpc.0
                    tcp        0      0 192.168.2.4:2010        0.0.0.0:*               LISTEN      1001       16840      1092/io.hm-rpc.1
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16343      795/iobroker.js-con
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18476      795/iobroker.js-con
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18056      1150/io.sonoff.0
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          12155      804/sshd: /usr/sbin
                    tcp6       0      0 :::39615                :::*                    LISTEN      1001       19369      1962/io.yahka.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20340      1882/io.web.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17851      969/io.admin.0
                    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       17327      1565/io.terminal.0
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16484      794/cupsd
                    udp        0      0 0.0.0.0:36784           0.0.0.0:*                           104        16424      573/avahi-daemon: r
                    udp        0      0 0.0.0.0:34788           0.0.0.0:*                           1001       20998      1325/io.broadlink2.
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16262      844/cups-browsed
                    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       20995      1325/io.broadlink2.
                    udp        0      0 0.0.0.0:58383           0.0.0.0:*                           1001       22993      1325/io.broadlink2.
                    udp        0      0 192.168.2.4:5353        0.0.0.0:*                           1001       18718      1181/io.tr-064.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        16422      573/avahi-daemon: r
                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       18034      1116/io.shelly.0
                    udp6       0      0 fe80::67d1:e1cb:7ef:546 :::*                                0          12279      733/NetworkManager
                    udp6       0      0 :::50277                :::*                                104        16425      573/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                104        16423      573/avahi-daemon: r
                    2024-01-21 17:40:28.300  - debug: zigbee.0 (1229) DeviceAvailability:Non-pingable device 0x00158d000461da61 lumi.sensor_magnet was last seen '34744106.67' seconds ago.
                    2024-01-21 17:40:28.329  - debug: zigbee.0 (1229) DeviceAvailability:Non-pingable device 0x04cd15fffefe9ca8 ZBMINIL2 was last seen '5227.093' seconds ago.
                    2024-01-21 17:40:28.907  - warn: shelly.0 (1116) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-01-21 17:40:37.805  - warn: sonoff.0 (1150) Client [Pavillon Beleuchtung] has invalid password or username
                    2024-01-21 17:40:38.241  - warn: shelly.0 (1116) State value to set for "shelly.0.SHDM-1#D3E918#1.temperatureF" has value "102.12" greater than max "100"
                    2024-01-21 17:40:38.726  - warn: sonoff.0 (1150) Client [Pool Beleuchtung] has invalid password or username
                    2024-01-21 17:40:38.782  - warn: sonoff.0 (1150) Client [Muschel Terrasse] has invalid password or username
                    2024-01-21 17:40:38.794  - warn: shelly.0 (1116) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-01-21 17:40:38.899  - warn: shelly.0 (1116) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-01-21 17:40:40.448  - warn: sonoff.0 (1150) Client [Pool Pumpe] has invalid password or username
                    2024-01-21 17:40:43.820  - warn: sonoff.0 (1150) Client [Taster-Schlafzimmer-Bett-L] has invalid password or username
                    2024-01-21 17:40:44.160  - warn: shelly.0 (1116) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-01-21 17:40:44.159  - warn: sonoff.0 (1150) Client [Wohnzimmer-Vitrine] has invalid password or username
                    2024-01-21 17:40:44.733  - warn: sonoff.0 (1150) Client [PC-Buero] has invalid password or username
                    2024-01-21 17:40:51.475  - warn: shelly.0 (1116) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-01-21 17:40:51.688  - warn: shelly.0 (1116) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-01-21 17:40:51.753  - warn: shelly.0 (1116) State value to set for "shelly.0.SHDM-2#8CAAB54C4B57#1.temperatureF" has value "106.96" greater than max "100"
                    2024-01-21 17:40:55.957  - warn: shelly.0 (1116) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-01-21 17:41:03.864  - warn: sonoff.0 (1150) Client [Pavillon Beleuchtung] has invalid password or username
                    2024-01-21 17:41:04.546  - warn: sonoff.0 (1150) Client [Pool Beleuchtung] has invalid password or username
                    2024-01-21 17:41:05.691  - warn: shelly.0 (1116) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-01-21 17:41:05.875  - warn: shelly.0 (1116) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-01-21 17:41:06.282  - warn: sonoff.0 (1150) Client [Pool Pumpe] has invalid password or username
                    2024-01-21 17:41:07.007  - warn: shelly.0 (1116) State value to set for "shelly.0.SHDM-2#8CAAB54C4B57#1.temperatureF" has value "107.08" greater than max "100"
                    2024-01-21 17:41:07.280  - warn: sonoff.0 (1150) Client [Muschel Terrasse] has invalid password or username
                    Press any key for a summary
                    2024-01-21 17:34:16.171 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1229
                    2024-01-21 17:34:22.326 - debug: zigbee.0 (1229) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2024-01-21 17:34:22.397 - debug: zigbee.0 (1229) Objects client ready ... initialize now
                    2024-01-21 17:34:22.400 - debug: zigbee.0 (1229) Objects create System PubSub Client
                    2024-01-21 17:34:22.402 - debug: zigbee.0 (1229) Objects create User PubSub Client
                    2024-01-21 17:34:22.481 - debug: zigbee.0 (1229) Objects client initialize lua scripts
                    2024-01-21 17:34:22.495 - debug: zigbee.0 (1229) Objects connected to redis: 127.0.0.1:9001
                    2024-01-21 17:34:22.546 - debug: zigbee.0 (1229) Redis States: Use Redis connection: 127.0.0.1:9000
                    2024-01-21 17:34:22.625 - debug: zigbee.0 (1229) States create System PubSub Client
                    2024-01-21 17:34:22.627 - debug: zigbee.0 (1229) States create User PubSub Client
                    2024-01-21 17:34:22.711 - debug: zigbee.0 (1229) States connected to redis: 127.0.0.1:9000
                    2024-01-21 17:34:22.780 - debug: zigbee.0 (1229) Plugin sentry Initialize Plugin (enabled=true)
                    2024-01-21 17:34:23.636 - info: zigbee.0 (1229) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                    2024-01-21 17:34:23.678 - debug: zigbee.0 (1229) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
                    2024-01-21 17:34:23.787 - info: zigbee.0 (1229) delete old Backup files. keep only last 10
                    2024-01-21 17:34:23.790 - info: zigbee.0 (1229) Starting Zigbee npm ...
                    2024-01-21 17:34:23.867 - debug: zigbee.0 (1229) Starting zigbee-herdsman...
                    2024-01-21 17:34:24.431 - info: zigbee.0 (1229) Installed Version: iobroker.zigbee@1.10.1
                    2024-01-21 17:34:25.075 - debug: zigbee.0 (1229) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_21-17_34_23.tar.gz success
                    2024-01-21 17:34:28.117 - debug: zigbee.0 (1229) zigbee-herdsman started
                    2024-01-21 17:34:28.120 - info: zigbee.0 (1229) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
                    2024-01-21 17:34:28.129 - debug: zigbee.0 (1229) Zigbee network parameters: panID=6754 channel=11 extendedPanID=dddddddddddddddd
                    2024-01-21 17:34:28.130 - info: zigbee.0 (1229) Disable LED
                    2024-01-21 17:34:28.131 - info: zigbee.0 (1229) Unable to disable LED, unsupported function.
                    2024-01-21 17:34:28.151 - info: zigbee.0 (1229) --> transmitPower : normal
                    2024-01-21 17:34:28.194 - info: zigbee.0 (1229) Currently 28 devices are joined:
                    2024-01-21 17:34:28.195 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00044d8e0b = true
                    2024-01-21 17:34:28.203 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00044d8e0b = 10
                    2024-01-21 17:34:28.211 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d000257bae7 = true
                    2024-01-21 17:34:28.218 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d000257bae7 = 10
                    2024-01-21 17:34:28.221 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00045f7cee = true
                    2024-01-21 17:34:28.225 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00045f7cee = 10
                    2024-01-21 17:34:28.228 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d0004521481 = true
                    2024-01-21 17:34:28.232 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d0004521481 = 10
                    2024-01-21 17:34:28.235 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d000461b53e = true
                    2024-01-21 17:34:28.239 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d000461b53e = 10
                    2024-01-21 17:34:28.243 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x680ae2fffec91ea4 = true
                    2024-01-21 17:34:28.247 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x680ae2fffec91ea4 = 10
                    2024-01-21 17:34:28.250 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x588e81fffe2b8762 = true
                    2024-01-21 17:34:28.254 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x588e81fffe2b8762 = 10
                    2024-01-21 17:34:28.258 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00045eb708 = true
                    2024-01-21 17:34:28.261 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00045eb708 = 10
                    2024-01-21 17:34:28.265 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d0002a71e25 = true
                    2024-01-21 17:34:28.269 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d0002a71e25 = 10
                    2024-01-21 17:34:28.273 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c794764 = true
                    2024-01-21 17:34:28.277 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c794764 = 10
                    2024-01-21 17:34:28.280 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c7946a1 = true
                    2024-01-21 17:34:28.284 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7946a1 = 10
                    2024-01-21 17:34:28.288 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00045f8d3d = true
                    2024-01-21 17:34:28.291 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00045f8d3d = 10
                    2024-01-21 17:34:28.295 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d0004597653 = true
                    2024-01-21 17:34:28.299 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d0004597653 = 10
                    2024-01-21 17:34:28.314 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0xbc33acfffe2ab392 = true
                    2024-01-21 17:34:28.318 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0xbc33acfffe2ab392 = 10
                    2024-01-21 17:34:28.322 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c7b5255 = true
                    2024-01-21 17:34:28.326 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b5255 = 10
                    2024-01-21 17:34:28.330 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c7b51f7 = true
                    2024-01-21 17:34:28.334 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b51f7 = 10
                    2024-01-21 17:34:28.338 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c78b7ba = true
                    2024-01-21 17:34:28.341 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c78b7ba = 10
                    2024-01-21 17:34:28.345 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d000461da61 = true
                    2024-01-21 17:34:28.349 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d000461da61 = 10
                    2024-01-21 17:34:28.354 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cd15fffefe9ca8 = true
                    2024-01-21 17:34:28.358 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cd15fffefe9ca8 = 10
                    grep: (standard input): binary file matches
                    code_text
                    • T Tapdance 0
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                       Static hostname: raspberrypi
                             Icon name: computer
                                Kernel: Linux 6.1.0-rpi7-rpi-v8
                          Architecture: arm64
                      Model           : Raspberry Pi 4 Model B Rev 1.1
                      Docker          : false
                      Virtualization  : none
                      Kernel          : aarch64
                      Userland        : arm64
                      Systemuptime and Load:
                      CPU threads: 4
                      *** RASPBERRY THROTTLING ***
                      Current issues:
                      Previously detected issues:
                      *** Time and Time Zones ***
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      *** User and Groups ***
                      PI
                      /home/PI
                      *** X-Server-Setup ***
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      Boot Target:    multi-user.target
                      *** MEMORY ***
                      Swap:           104M          0B        104M
                               3793 M total memory
                               1571 M used memory
                               1897 M free memory
                                 40 M buffer memory
                                359 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** FILESYSTEM ***
                      udev           devtmpfs  1.6G     0  1.6G   0% /dev
                      tmpfs          tmpfs     380M  1.2M  379M   1% /run
                      /dev/mmcblk0p2 ext4       28G  7.1G   20G  27% /
                      tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
                      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                      /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
                      tmpfs          tmpfs     380M   32K  380M   1% /run/user/1000
                      TARGET           SOURCE         FSTYPE OPTIONS
                      /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                      /var:
                      667M    /var/
                      194M    /var/lib
                      187M    /var/log
                      /opt/iobroker/backups:
                      4.0K    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      270M    /opt/iobroker/iobroker-data/files
                      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                      73M     /opt/iobroker/iobroker-data/backup-objects
                      67M     /opt/iobroker/iobroker-data/files/javascript.admin
                      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
                      7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
                      USB-Devices by-id:
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v18.19.0
                      /usr/bin/node           v18.19.0
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      /usr/bin/corepack       0.22.0
                      nodejs:
                        Installed: 18.19.0-1nodesource1
                        Candidate: 18.19.0-1nodesource1
                        Version table:
                           18.19.0+dfsg-6~deb12u1 500
                              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                       *** 18.19.0-1nodesource1 1001
                              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                           18.18.2-1nodesource1 1001
                           18.18.1-1nodesource1 1001
                           18.18.0-1nodesource1 1001
                           18.17.1-1nodesource1 1001
                           18.17.0-1nodesource1 1001
                           18.16.1-1nodesource1 1001
                           18.16.0-1nodesource1 1001
                           18.15.0-1nodesource1 1001
                           18.14.2-1nodesource1 1001
                           18.14.1-1nodesource1 1001
                           18.14.0-1nodesource1 1001
                           18.13.0+dfsg1-1 500
                              500 http://deb.debian.org/debian bookworm/main arm64 Packages
                           18.13.0-1nodesource1 1001
                           18.12.0-1nodesource1 1001
                           18.11.0-1nodesource1 1001
                           18.10.0-1nodesource1 1001
                           18.9.1-1nodesource1 1001
                           18.9.0-1nodesource1 1001
                           18.8.0-1nodesource1 1001
                           18.7.0-1nodesource1 1001
                           18.6.0-1nodesource1 1001
                           18.5.0-1nodesource1 1001
                           18.4.0-1nodesource1 1001
                           18.3.0-1nodesource1 1001
                           18.2.0-1nodesource1 1001
                           18.1.0-1nodesource1 1001
                           18.0.0-1nodesource1 1001
                      No problems detected
                      Errors in npm tree:
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Core adapters versions
                      admin:          6.12.0
                      javascript:     7.1.6
                      Adapters from github:   0
                      Adapter State
                      + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
                      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
                        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
                        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
                        system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
                      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                      + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
                      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
                      + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 192.168.2.4, run as: admin
                      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                        system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
                      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
                      + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
                      + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                      + instance is alive
                      ioBroker-Repositories
                      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                      Stable (default): http://download.iobroker.net/sources-dist.json
                      Installed ioBroker-Instances
                      Adapter    "admin"        : 6.12.0   , installed 6.12.0
                      Adapter    "alarm"        : 3.6.0    , installed 3.6.0
                      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                      Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                      Adapter    "info"         : 2.0.0    , installed 2.0.0
                      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                      Controller "js-controller": 5.0.17   , installed 5.0.17
                      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                      Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                      Adapter    "synology"     : 3.0.1    , installed 3.0.1
                      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                      Adapter    "vis"          : 1.5.4    , installed 1.5.4
                      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                      Adapter    "web"          : 6.1.10   , installed 6.1.10
                      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                      Adapter    "ws"           : 2.5.8    , installed 2.5.8
                      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                      Objects and States
                      Objects:        5503
                      States:         4905
                      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Reading package lists...
                      Pending Updates: 0
                      *** Listening Ports ***
                      code_text
                      Läuft doch.
                      • T Tapdance 0
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        PI
                        /home/PI
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:           104M          0B        104M
                                 3793 M total memory
                                 1571 M used memory
                                 1897 M free memory
                                   40 M buffer memory
                                  359 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        667M    /var/
                        194M    /var/lib
                        187M    /var/log
                        USB-Devices by-id:
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        nodejs:
                          Version table:
                             18.13.0+dfsg1-1 500
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.12.0
                        javascript:     7.1.6
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        5503
                        States:         4905
                        Pending Updates: 0
                        code_text
                        firmware version: "revision":20210708
                        Ist allerdings steinalt. Würde ich aktualisieren.
                          Läuft doch.
                          Tapdance 0
                          Aber kein Gerät reagiert, selbst die nicht die vorher noch funktioniert haben.
                          • T Tapdance 0
                            Tapdance 0
                            @tapdance-0
                            PI@raspberrypi:~ $ ^C
                            PI@raspberrypi:~ $ iob logs | grep zigbee
                            2024-01-21 17:36:23.926  - debug: zigbee.0 (1229) Failed to execute LQI for '0xf4b3b1fffef8731e'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n    at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:63:23)\n    at request (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:582:47)\n    at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:604:28\n    at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20)\n    at ZigbeeController.getMap (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:721:30)"
                            PI@raspberrypi:~ $
                              Tapdance 0
                              Ok und wie mache ich das mit der Firmware Version?
                              Jetzt bin ich wieder bei meinem Ursprungsproblem alles hat sich eingependelt und läuft außer.
                              bei "MOES ZigBee Mini Smart" da kann ich keine Daten mehr senden kann nur empfangen.
                              Ich kann im IO Broker aber den Status der Geräte sehen der Empfang der daten funktioniert also. Beispiel ich ändere am Schalter manuell die Helligkeit dann sehe ich im IOBrocker die aktuelle Prozentzahl der Helligkeit. Andere Zigbee Komponenten wie meine Bewegungsmelder von Acera scheinen nicht betroffen zu sein.
                              • T Tapdance 0
                                @tapdance-0
                                https://www.zigbee2mqtt.io/guide/adapters/flashing/flashing_via_cc2538-bsl.html
                                  @tapdance-0
                                  Tapdance 0
                                  Method without Docker
                                  Prepare your system (debian based)
                                  Ist debian = RasperyPI
                                  • T Tapdance 0
                                    @tapdance-0
                                    Ja, Raspberry OS basiert auf Debian.
                                      @tapdance-0
                                      Tapdance 0
                                      Bis Download the Firmware verstehe ich das aber wie lade ich dann die firmware von der webseite runter und bringe sie in den Raspberry?
                                      Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
                                      • T Tapdance 0
                                        Meister MopperM Online
                                        Meister Mopper
                                        schrieb am zuletzt editiert von Meister Mopper
                                        Du solltest die Firmware des Geräts aktualisieren, nicht die des Raspi.
                                        Proxmox und HA ...
                                        • T Tapdance 0
                                          @tapdance-0
                                          Mach es danach:
                                          https://forum.iobroker.net/topic/50180/anleitung-zigbee-firmware-auf-der-kommandozeile-flashen
                                          Achtung! Du brauchst für den Stick andere Firmware. Und eine zusätzliche Option beim flash.
