  4. Ziggbe sendet nicht mehr an empfängt aber noch Daten
67 Beiträge 6 Kommentatoren 9.0k Aufrufe 6 Beobachtet
  • T Tapdance 0
    Das kommt wenn ich den update Befehl ausführe.
    PI@raspberrypi:~ $ sudo apt full-upgrade
    iob update all
    Reading package lists... Done
    Calculating upgrade... Done
    The following packages were automatically installed and are no longer required:
      gtk2-engines-clearlookspix libcamera-apps libpisp0.0.1
    Use 'sudo apt autoremove' to remove them.
    The following packages will be upgraded:
      pixflat-icons
    1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 1,120 kB of archives.
    After this operation, 209 kB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Get:1 http://archive.raspberrypi.com/debian bookworm/main arm64 pixflat-icons all 0.24 [1,120 kB]
    Fetched 1,120 kB in 0s (3,370 kB/s)
    Reading changelogs... Done
    (Reading database ... 155651 files and directories currently installed.)
    Preparing to unpack .../pixflat-icons_0.24_all.deb ...
    Unpacking pixflat-icons (0.24) over (0.23) ...
    Setting up pixflat-icons (0.24) ...
    gtk-update-icon-cache: Cache file created successfully.
    Used repository: all
    Error: unknown repository is active - "all". Known: Beta (latest), Stable (default)
    @tapdance-0
    Vertan.
    iobroker upgrade all
      @tapdance-0
      Vertan.
      Tapdance 0
      Updates müssten jetzt glaube ich alle durch sein. Wie ich den Pfad beim Comport eintrage weiß ich nicht hier die aktuellen Logs noch mal
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.1.0-rpi7-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       17:06:09 up 6 min,  3 users,  load average: 0.55, 0.84, 0.47
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sun 2024-01-21 17:06:09 CET
                 Universal time: Sun 2024-01-21 16:06:09 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      PI
      /home/PI
      PI adm dialout cdrom sudo audio video plugdev games users input render netdev lp        admin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            4.0G        1.7G        1.9G        1.3M        423M        2.3G
      Swap:           104M          0B        104M
      Total:          4.1G        1.7G        2.1G
               3793 M total memory
               1606 M used memory
               1636 M active memory
                170 M inactive memory
               1858 M free memory
                 40 M buffer memory
                363 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.2M  379M   1% /run
      /dev/mmcblk0p2 ext4       28G  7.1G   20G  27% /
      tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
      tmpfs          tmpfs     380M   32K  380M   1% /run/user/1000
      [Sun Jan 21 16:59:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:64:62:CC vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=9515910b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles
      [Sun Jan 21 16:59:59 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
      [Sun Jan 21 17:00:02 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      651M    /var/
      194M    /var/lib
      185M    /var/cache
      172M    /var/cache/apt
      171M    /var/log
      Archived and active journals take up 169.5M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      373M    /opt/iobroker/iobroker-data/
      270M    /opt/iobroker/iobroker-data/files
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      73M     /opt/iobroker/iobroker-data/backup-objects
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      23M     /opt/iobroker/iobroker-data/objects.jsonl
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
      7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
      7.2M    /opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main arm64 Packages
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   0
      Adapter State
      + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
        system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
      + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 192.168.2.4, run as: admin
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
        system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
      + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
      + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00
      + instance is alive
      ioBroker-Repositories
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Stable (default): http://download.iobroker.net/sources-dist.json
      Installed ioBroker-Instances
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alarm"        : 3.6.0    , installed 3.6.0
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "discovery"    : 4.2.0    , installed 4.2.0
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "info"         : 2.0.0    , installed 2.0.0
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "socketio"     : 6.6.0    , installed 6.6.0
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "vis"          : 1.5.4    , installed 1.5.4
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
      Objects and States
      Objects:        5503
      States:         4905
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18478      778/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17466      768/cupsd
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16860      769/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17647      769/iobroker.js-con
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17854      1111/io.sonoff.0
      tcp        0      0 192.168.2.4:2001        0.0.0.0:*               LISTEN      1001       16989      1042/io.hm-rpc.0
      tcp        0      0 192.168.2.4:2010        0.0.0.0:*               LISTEN      1001       15037      1049/io.hm-rpc.1
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17465      768/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          18480      778/sshd: /usr/sbin
      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       22647      1525/io.terminal.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17701      946/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22866      1945/io.web.0
      tcp6       0      0 :::38469                :::*                    LISTEN      1001       20981      1983/io.yahka.0
      udp        0      0 0.0.0.0:44484           0.0.0.0:*                           104        17409      580/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       17826      1091/io.shelly.0
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16777      818/cups-browsed
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       17236      1286/io.broadlink2.
      udp        0      0 0.0.0.0:44173           0.0.0.0:*                           1001       17239      1286/io.broadlink2.
      udp        0      0 0.0.0.0:56537           0.0.0.0:*                           1001       23299      1286/io.broadlink2.
      udp        0      0 192.168.2.4:5353        0.0.0.0:*                           1001       19061      1146/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        12287      580/avahi-daemon: r
      udp6       0      0 :::50851                :::*                                104        17410      580/avahi-daemon: r
      udp6       0      0 fe80::67d1:e1cb:7ef:546 :::*                                0          17623      706/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        12288      580/avahi-daemon: r
      2024-01-21 17:06:49.735  - warn: sonoff.0 (1111) Client [Pool Pumpe] has invalid password or username
      2024-01-21 17:06:51.462  - warn: sonoff.0 (1111) Client [Muschel Terrasse] has invalid password or username
      2024-01-21 17:06:52.102  - warn: sonoff.0 (1111) Client [Pavillon Beleuchtung] has invalid password or username
      2024-01-21 17:06:54.224  - warn: shelly.0 (1091) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 17:06:54.227  - warn: sonoff.0 (1111) Client [Taster-Schlafzimmer-Bett-L] has invalid password or username
      2024-01-21 17:06:54.230  - warn: sonoff.0 (1111) Client [Wohnzimmer-Vitrine] has invalid password or username
      2024-01-21 17:06:54.288  - warn: shelly.0 (1091) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 17:06:54.315  - warn: shelly.0 (1091) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 17:06:56.433  - warn: sonoff.0 (1111) Client [PC-Buero] has invalid password or username
      2024-01-21 17:07:03.413  - warn: shelly.0 (1091) State value to set for "shelly.0.SHDM-2#8CAAB54C4E21#1.temperatureF" has value "141.05" greater than max "100"
      2024-01-21 17:07:06.195  - warn: shelly.0 (1091) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 17:07:06.513  - warn: shelly.0 (1091) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 17:07:07.480  - warn: shelly.0 (1091) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 17:07:14.240  - warn: sonoff.0 (1111) Client [Pool Beleuchtung] has invalid password or username
      2024-01-21 17:07:15.493  - warn: sonoff.0 (1111) Client [Pool Pumpe] has invalid password or username
      2024-01-21 17:07:17.252  - warn: sonoff.0 (1111) Client [Muschel Terrasse] has invalid password or username
      2024-01-21 17:07:17.896  - warn: sonoff.0 (1111) Client [Pavillon Beleuchtung] has invalid password or username
      2024-01-21 17:07:18.796  - warn: shelly.0 (1091) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 17:07:20.186  - warn: sonoff.0 (1111) Client [Wohnzimmer-Vitrine] has invalid password or username
      2024-01-21 17:07:20.188  - warn: sonoff.0 (1111) Client [Taster-Schlafzimmer-Bett-L] has invalid password or username
      2024-01-21 17:07:20.405  - warn: shelly.0 (1091) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 17:07:22.524  - warn: sonoff.0 (1111) Client [PC-Buero] has invalid password or username
      2024-01-21 17:07:26.175  - warn: shelly.0 (1091) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 17:07:32.167  - warn: shelly.0 (1091) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 17:07:33.565  - warn: shelly.0 (1091) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      iob diag has finished.
      PI@raspberrypi:~ $ iob logs | grep zigbee
      2024-01-21 16:58:32.729  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
      2024-01-21 16:58:32.736  - info: zigbee.0 (5918) Got terminate signal TERMINATE_YOURSELF
      2024-01-21 16:58:32.855  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
      2024-01-21 16:58:33.857  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 5918
      2024-01-21 16:58:35.954  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 6066
      2024-01-21 16:58:32.738  - info: zigbee.0 (5918) cleaned everything up...
      2024-01-21 16:58:32.772  - info: zigbee.0 (5918) Zigbee: disabling joining new devices.
      2024-01-21 16:58:32.773  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d00044d8e0b = false
      2024-01-21 16:58:32.785  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d00044d8e0b = 0
      2024-01-21 16:58:32.797  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d000257bae7 = false
      2024-01-21 16:58:32.810  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d000257bae7 = 0
      2024-01-21 16:58:32.820  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d00045f7cee = false
      2024-01-21 16:58:32.825  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d00045f7cee = 0
      2024-01-21 16:58:32.831  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d0004521481 = false
      2024-01-21 16:58:32.836  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d0004521481 = 0
      2024-01-21 16:58:32.843  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d000461b53e = false
      2024-01-21 16:58:32.849  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d000461b53e = 0
      2024-01-21 16:58:32.855  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x680ae2fffec91ea4 = false
      2024-01-21 16:58:32.860  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x680ae2fffec91ea4 = 0
      2024-01-21 16:58:32.867  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x588e81fffe2b8762 = false
      2024-01-21 16:58:32.873  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x588e81fffe2b8762 = 0
      2024-01-21 16:58:32.880  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x680ae2fffe924d57 = false
      2024-01-21 16:58:32.885  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x680ae2fffe924d57 = 0
      2024-01-21 16:58:32.892  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d00045eb708 = false
      2024-01-21 16:58:32.897  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d00045eb708 = 0
      2024-01-21 16:58:32.905  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d0002a71e25 = false
      2024-01-21 16:58:32.909  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d0002a71e25 = 0
      2024-01-21 16:58:32.915  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c794764 = false
      2024-01-21 16:58:32.919  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c794764 = 0
      2024-01-21 16:58:32.925  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c7946a1 = false
      2024-01-21 16:58:32.929  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7946a1 = 0
      2024-01-21 16:58:32.933  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d00045f8d3d = false
      2024-01-21 16:58:32.938  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d00045f8d3d = 0
      2024-01-21 16:58:32.943  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d0004597653 = false
      2024-01-21 16:58:32.947  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d0004597653 = 0
      2024-01-21 16:58:32.952  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x842e14fffe768d41 = false
      2024-01-21 16:58:32.956  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x842e14fffe768d41 = 0
      2024-01-21 16:58:32.962  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xbc33acfffe2ab392 = false
      2024-01-21 16:58:32.965  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xbc33acfffe2ab392 = 0
      2024-01-21 16:58:32.970  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c7b5255 = false
      2024-01-21 16:58:32.974  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b5255 = 0
      2024-01-21 16:58:32.980  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c7b51f7 = false
      2024-01-21 16:58:32.985  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b51f7 = 0
      2024-01-21 16:58:32.990  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c78b7ba = false
      2024-01-21 16:58:32.993  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c78b7ba = 0
      2024-01-21 16:58:32.998  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d000461da61 = false
      2024-01-21 16:58:33.001  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d000461da61 = 0
      2024-01-21 16:58:33.005  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef87315 = false
      2024-01-21 16:58:33.008  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87315 = 0
      2024-01-21 16:58:33.012  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef8731e = false
      2024-01-21 16:58:33.016  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef8731e = 0
      2024-01-21 16:58:33.019  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef84d2d = false
      2024-01-21 16:58:33.022  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef84d2d = 0
      2024-01-21 16:58:33.027  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef87b6a = false
      2024-01-21 16:58:33.030  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87b6a = 0
      2024-01-21 16:58:33.033  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef853ac = false
      2024-01-21 16:58:33.036  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef853ac = 0
      2024-01-21 16:58:33.040  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cd15fffefe9ca8 = false
      2024-01-21 16:58:33.043  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cd15fffefe9ca8 = 0
      2024-01-21 16:58:33.046  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xa4c138c66404899e = false
      2024-01-21 16:58:33.049  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xa4c138c66404899e = 0
      2024-01-21 16:58:39.403  - warn: zigbee.0 (5918) Failed to stop zigbee during startup
      2024-01-21 16:58:39.405  - info: zigbee.0 (5918) terminating
      2024-01-21 16:58:39.408  - debug: zigbee.0 (5918) Plugin sentry destroyed
      2024-01-21 16:58:39.409  - info: zigbee.0 (5918) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-01-21 16:58:39.412  - info: zigbee.0 (5918) terminating
      2024-01-21 16:58:39.502  - warn: zigbee.0 (5918) Got terminate signal. Checking desired PID: 0 vs own PID 5918
      2024-01-21 16:58:39.504  - warn: zigbee.0 (5918) Got terminate signal. Checking desired PID: 6066 vs own PID 5918
      2024-01-21 16:58:39.560  - info: zigbee.0 (5918) debug devices set to []
      2024-01-21 16:58:40.065  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2024-01-21 16:58:40.065  - info: host.raspberrypi Do not restart adapter system.adapter.zigbee.0 because desired by instance
      2024-01-21 16:58:40.406  - debug: zigbee.0 (6066) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2024-01-21 16:58:40.452  - debug: zigbee.0 (6066) Objects client ready ... initialize now
      2024-01-21 16:58:40.455  - debug: zigbee.0 (6066) Objects create System PubSub Client
      2024-01-21 16:58:40.457  - debug: zigbee.0 (6066) Objects create User PubSub Client
      2024-01-21 16:58:40.538  - debug: zigbee.0 (6066) Objects client initialize lua scripts
      2024-01-21 16:58:40.549  - debug: zigbee.0 (6066) Objects connected to redis: 127.0.0.1:9001
      2024-01-21 16:58:40.596  - debug: zigbee.0 (6066) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-01-21 16:58:40.616  - debug: zigbee.0 (6066) States create System PubSub Client
      2024-01-21 16:58:40.617  - debug: zigbee.0 (6066) States create User PubSub Client
      2024-01-21 16:58:40.688  - debug: zigbee.0 (6066) States connected to redis: 127.0.0.1:9000
      2024-01-21 16:58:40.742  - debug: zigbee.0 (6066) Plugin sentry Initialize Plugin (enabled=true)
      2024-01-21 16:58:41.361  - info: zigbee.0 (6066) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
      2024-01-21 16:58:41.396  - debug: zigbee.0 (6066) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
      2024-01-21 16:58:41.477  - info: zigbee.0 (6066) delete old Backup files. keep only last 10
      2024-01-21 16:58:41.480  - info: zigbee.0 (6066) Starting Zigbee  npm ...
      2024-01-21 16:58:41.526  - debug: zigbee.0 (6066) Starting zigbee-herdsman...
      2024-01-21 16:58:41.876  - error: zigbee.0 (6066) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
      2024-01-21 16:58:41.877  - error: zigbee.0 (6066) Failed to start Zigbee
      2024-01-21 16:58:41.877  - error: zigbee.0 (6066) Error herdsman start
      2024-01-21 16:58:41.881  - info: zigbee.0 (6066) Installed Version: iobroker.zigbee@1.10.1
      2024-01-21 16:58:42.387  - debug: zigbee.0 (6066) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_21-16_58_41.tar.gz success
      2024-01-21 16:58:51.881  - info: zigbee.0 (6066) Try to reconnect. 1 attempts left
      2024-01-21 16:58:51.882  - info: zigbee.0 (6066) Starting Zigbee  npm ...
      2024-01-21 16:58:51.887  - debug: zigbee.0 (6066) Starting zigbee-herdsman...
      2024-01-21 16:58:51.898  - error: zigbee.0 (6066) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
      2024-01-21 16:58:51.899  - error: zigbee.0 (6066) Failed to start Zigbee
      2024-01-21 16:58:51.899  - error: zigbee.0 (6066) Error herdsman start
      2024-01-21 16:58:51.907  - info: zigbee.0 (6066) Installed Version: iobroker.zigbee@1.10.1
      2024-01-21 16:59:25.780  - info: zigbee.0 (6066) cleaned everything up...
      2024-01-21 16:59:25.828  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=false)
      2024-01-21 16:59:25.876  - info: zigbee.0 (6066) Zigbee: disabling joining new devices.
      2024-01-21 16:59:25.877  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d00044d8e0b = false
      2024-01-21 16:59:25.893  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d00044d8e0b = 0
      2024-01-21 16:59:25.905  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d000257bae7 = false
      2024-01-21 16:59:25.916  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d000257bae7 = 0
      2024-01-21 16:59:25.928  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d00045f7cee = false
      2024-01-21 16:59:25.934  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d00045f7cee = 0
      2024-01-21 16:59:25.964  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d0004521481 = false
      2024-01-21 16:59:25.968  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d0004521481 = 0
      2024-01-21 16:59:25.974  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d000461b53e = false
      2024-01-21 16:59:25.979  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d000461b53e = 0
      2024-01-21 16:59:25.993  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x680ae2fffec91ea4 = false
      2024-01-21 16:59:26.015  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x680ae2fffec91ea4 = 0
      2024-01-21 16:59:26.024  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x588e81fffe2b8762 = false
      2024-01-21 16:59:26.030  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x588e81fffe2b8762 = 0
      2024-01-21 16:59:26.038  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x680ae2fffe924d57 = false
      2024-01-21 16:59:26.044  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x680ae2fffe924d57 = 0
      2024-01-21 16:59:26.063  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d00045eb708 = false
      2024-01-21 16:59:26.071  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d00045eb708 = 0
      2024-01-21 16:59:26.077  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d0002a71e25 = false
      2024-01-21 16:59:26.082  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d0002a71e25 = 0
      2024-01-21 16:59:26.088  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c794764 = false
      2024-01-21 16:59:26.092  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c794764 = 0
      2024-01-21 16:59:26.096  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c7946a1 = false
      2024-01-21 16:59:26.103  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7946a1 = 0
      2024-01-21 16:59:26.109  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d00045f8d3d = false
      2024-01-21 16:59:26.112  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d00045f8d3d = 0
      2024-01-21 16:59:26.125  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d0004597653 = false
      2024-01-21 16:59:26.129  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d0004597653 = 0
      2024-01-21 16:59:26.134  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x842e14fffe768d41 = false
      2024-01-21 16:59:26.139  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x842e14fffe768d41 = 0
      2024-01-21 16:59:26.144  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xbc33acfffe2ab392 = false
      2024-01-21 16:59:26.147  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xbc33acfffe2ab392 = 0
      2024-01-21 16:59:26.155  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c7b5255 = false
      2024-01-21 16:59:26.161  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b5255 = 0
      2024-01-21 16:59:26.167  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c7b51f7 = false
      2024-01-21 16:59:26.173  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b51f7 = 0
      2024-01-21 16:59:26.182  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c78b7ba = false
      2024-01-21 16:59:26.186  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c78b7ba = 0
      2024-01-21 16:59:26.197  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d000461da61 = false
      2024-01-21 16:59:26.201  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d000461da61 = 0
      2024-01-21 16:59:26.206  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef87315 = false
      2024-01-21 16:59:26.211  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87315 = 0
      2024-01-21 16:59:26.216  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef8731e = false
      2024-01-21 16:59:26.220  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef8731e = 0
      2024-01-21 16:59:26.225  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef84d2d = false
      2024-01-21 16:59:26.229  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef84d2d = 0
      2024-01-21 16:59:26.234  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef87b6a = false
      2024-01-21 16:59:26.238  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87b6a = 0
      2024-01-21 16:59:26.246  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef853ac = false
      2024-01-21 16:59:26.249  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef853ac = 0
      2024-01-21 16:59:26.257  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cd15fffefe9ca8 = false
      2024-01-21 16:59:26.261  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cd15fffefe9ca8 = 0
      2024-01-21 16:59:26.268  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xa4c138c66404899e = false
      2024-01-21 16:59:26.271  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xa4c138c66404899e = 0
      2024-01-21 16:59:31.550  - warn: zigbee.0 (6066) Failed to stop zigbee during startup
      2024-01-21 16:59:31.682  - error: zigbee.0 (6066) Objects database error: write EPIPE
      2024-01-21 16:59:31.751  - info: zigbee.0 (6066) terminating
      2024-01-21 16:59:31.752  - debug: zigbee.0 (6066) Plugin sentry destroyed
      2024-01-21 16:59:31.753  - info: zigbee.0 (6066) Terminated (NO_ERROR): Without reason
      2024-01-21 16:59:31.753  - info: zigbee.0 (6066) terminating
      2024-01-21 16:59:32.687  - info: zigbee.0 (6066) terminating with timeout
      2024-01-21 17:01:20.456  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1190
      2024-01-21 17:01:27.027  - debug: zigbee.0 (1190) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2024-01-21 17:01:27.080  - debug: zigbee.0 (1190) Objects client ready ... initialize now
      2024-01-21 17:01:27.084  - debug: zigbee.0 (1190) Objects create System PubSub Client
      2024-01-21 17:01:27.086  - debug: zigbee.0 (1190) Objects create User PubSub Client
      2024-01-21 17:01:27.162  - debug: zigbee.0 (1190) Objects client initialize lua scripts
      2024-01-21 17:01:27.176  - debug: zigbee.0 (1190) Objects connected to redis: 127.0.0.1:9001
      2024-01-21 17:01:27.225  - debug: zigbee.0 (1190) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-01-21 17:01:27.247  - debug: zigbee.0 (1190) States create System PubSub Client
      2024-01-21 17:01:27.248  - debug: zigbee.0 (1190) States create User PubSub Client
      2024-01-21 17:01:27.339  - debug: zigbee.0 (1190) States connected to redis: 127.0.0.1:9000
      2024-01-21 17:01:27.397  - debug: zigbee.0 (1190) Plugin sentry Initialize Plugin (enabled=true)
      2024-01-21 17:01:28.242  - info: zigbee.0 (1190) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
      2024-01-21 17:01:28.283  - debug: zigbee.0 (1190) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
      2024-01-21 17:01:28.387  - info: zigbee.0 (1190) delete old Backup files. keep only last 10
      2024-01-21 17:01:28.390  - info: zigbee.0 (1190) Starting Zigbee  npm ...
      2024-01-21 17:01:28.468  - debug: zigbee.0 (1190) Starting zigbee-herdsman...
      2024-01-21 17:01:29.117  - error: zigbee.0 (1190) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
      2024-01-21 17:01:29.118  - error: zigbee.0 (1190) Failed to start Zigbee
      2024-01-21 17:01:29.118  - error: zigbee.0 (1190) Error herdsman start
      2024-01-21 17:01:29.123  - info: zigbee.0 (1190) Installed Version: iobroker.zigbee@1.10.1
      2024-01-21 17:01:29.643  - debug: zigbee.0 (1190) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_21-17_01_28.tar.gz success
      2024-01-21 17:01:39.122  - info: zigbee.0 (1190) Try to reconnect. 1 attempts left
      2024-01-21 17:01:39.123  - info: zigbee.0 (1190) Starting Zigbee  npm ...
      2024-01-21 17:01:39.128  - debug: zigbee.0 (1190) Starting zigbee-herdsman...
      2024-01-21 17:01:39.139  - error: zigbee.0 (1190) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
      2024-01-21 17:01:39.140  - error: zigbee.0 (1190) Failed to start Zigbee
      2024-01-21 17:01:39.141  - error: zigbee.0 (1190) Error herdsman start
      2024-01-21 17:01:39.149  - info: zigbee.0 (1190) Installed Version: iobroker.zigbee@1.10.1
      2024-01-21 17:04:17.656  - error: zigbee.0 (1190) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      2024-01-21 17:04:18.043  - info: zigbee.0 (1190) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"8eb6f719a99ded11ad35dca5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"}]
      • T Tapdance 0
        Skript v.2023-10-10
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        PI
        /home/PI
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           104M          0B        104M
                 3793 M total memory
                 1606 M used memory
                 1858 M free memory
                   40 M buffer memory
                  363 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        651M    /var/
        194M    /var/lib
        185M    /var/cache
        172M    /var/cache/apt
        171M    /var/log
        USB-Devices by-id:
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.0
        javascript:     7.1.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        5503
        States:         4905
        Pending Updates: 0
        @tapdance-0 sagte in Ziggbe sendet nicht mehr an empfängt aber noch Daten:
        Da:
        das eintragen:
        T 2 Antworten Letzte Antwort
          Da:
          das eintragen:
          Tapdance 0
          geht leider nicht da der Adapter nicht startet.
          Bekomme immer folgende Meldung wenn ich darauf gehe.
          You need save and run adapter before pairing!
          T AsgothianA 2 Antworten Letzte Antwort
          • T Tapdance 0
            Tapdance 0
            @tapdance-0
            starte das System noch mal komplett neu mit
            sudo reboot
            • T Tapdance 0
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              Das ist normal. Du solltest trotzdem auf die Seite zum konfigurieren kommen um da Einstellungen zu machen.
              A.
              • AsgothianA Asgothian
                A.
                Tapdance 0
                @asgothian
                leider nicht
                • T Tapdance 0
                  @asgothian
                  leider nicht
                  Tapdance 0
                  @tapdance-0
                  Neustart hat auch nichts gebracht
                  2024-01-21 17:16:30.300  - error: zigbee.0 (1190) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                  2024-01-21 17:16:30.544  - info: zigbee.0 (1190) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"8eb6f719a99ded11ad35dca5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"}]
                  2024-01-21 17:16:55.971  - error: zigbee.0 (1190) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                  2024-01-21 17:16:56.206  - info: zigbee.0 (1190) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"8eb6f719a99ded11ad35dca5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"}]
                  2024-01-21 17:18:59.211  - info: zigbee.0 (1190) cleaned everything up...
                  2024-01-21 17:18:59.251  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                  2024-01-21 17:18:59.762  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                  2024-01-21 17:19:00.770  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 1190
                  2024-01-21 17:18:59.315  - info: zigbee.0 (1190) Zigbee: disabling joining new devices.
                  2024-01-21 17:18:59.317  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d00044d8e0b = false
                  2024-01-21 17:18:59.332  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d00044d8e0b = 0
                  2024-01-21 17:18:59.344  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d000257bae7 = false
                  2024-01-21 17:18:59.360  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d000257bae7 = 0
                  2024-01-21 17:18:59.382  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d00045f7cee = false
                  2024-01-21 17:18:59.386  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d00045f7cee = 0
                  2024-01-21 17:18:59.392  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d0004521481 = false
                  2024-01-21 17:18:59.396  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d0004521481 = 0
                  2024-01-21 17:18:59.411  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d000461b53e = false
                  2024-01-21 17:18:59.429  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d000461b53e = 0
                  2024-01-21 17:18:59.435  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x680ae2fffec91ea4 = false
                  2024-01-21 17:18:59.438  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x680ae2fffec91ea4 = 0
                  2024-01-21 17:18:59.444  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x588e81fffe2b8762 = false
                  2024-01-21 17:18:59.455  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x588e81fffe2b8762 = 0
                  2024-01-21 17:18:59.463  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x680ae2fffe924d57 = false
                  2024-01-21 17:18:59.467  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x680ae2fffe924d57 = 0
                  2024-01-21 17:18:59.474  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d00045eb708 = false
                  2024-01-21 17:18:59.479  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d00045eb708 = 0
                  2024-01-21 17:18:59.490  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d0002a71e25 = false
                  2024-01-21 17:18:59.494  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d0002a71e25 = 0
                  2024-01-21 17:18:59.499  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c794764 = false
                  2024-01-21 17:18:59.502  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c794764 = 0
                  2024-01-21 17:18:59.507  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c7946a1 = false
                  2024-01-21 17:18:59.510  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7946a1 = 0
                  2024-01-21 17:18:59.515  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d00045f8d3d = false
                  2024-01-21 17:18:59.518  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d00045f8d3d = 0
                  2024-01-21 17:18:59.523  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d0004597653 = false
                  2024-01-21 17:18:59.528  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d0004597653 = 0
                  2024-01-21 17:18:59.539  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x842e14fffe768d41 = false
                  2024-01-21 17:18:59.542  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x842e14fffe768d41 = 0
                  2024-01-21 17:18:59.549  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xbc33acfffe2ab392 = false
                  2024-01-21 17:18:59.555  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xbc33acfffe2ab392 = 0
                  2024-01-21 17:18:59.562  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c7b5255 = false
                  2024-01-21 17:18:59.565  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b5255 = 0
                  2024-01-21 17:18:59.570  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c7b51f7 = false
                  2024-01-21 17:18:59.574  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b51f7 = 0
                  2024-01-21 17:18:59.579  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c78b7ba = false
                  2024-01-21 17:18:59.583  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c78b7ba = 0
                  2024-01-21 17:18:59.588  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d000461da61 = false
                  2024-01-21 17:18:59.591  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d000461da61 = 0
                  2024-01-21 17:18:59.595  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef87315 = false
                  2024-01-21 17:18:59.599  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87315 = 0
                  2024-01-21 17:18:59.604  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef8731e = false
                  2024-01-21 17:18:59.608  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef8731e = 0
                  2024-01-21 17:18:59.613  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef84d2d = false
                  2024-01-21 17:18:59.623  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef84d2d = 0
                  2024-01-21 17:18:59.637  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef87b6a = false
                  2024-01-21 17:18:59.652  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87b6a = 0
                  2024-01-21 17:18:59.655  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef853ac = false
                  2024-01-21 17:18:59.670  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef853ac = 0
                  2024-01-21 17:18:59.689  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cd15fffefe9ca8 = false
                  2024-01-21 17:18:59.692  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cd15fffefe9ca8 = 0
                  2024-01-21 17:18:59.696  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xa4c138c66404899e = false
                  2024-01-21 17:18:59.700  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xa4c138c66404899e = 0
                  2024-01-21 17:19:03.382  - warn: zigbee.0 (1190) Failed to stop zigbee during startup
                  2024-01-21 17:19:03.714  - warn: host.raspberrypi instance system.adapter.zigbee.0 terminated due to SIGTERM
                  2024-01-21 17:19:03.714  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code null ()
                  2024-01-21 17:20:50.131  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1208
                  2024-01-21 17:20:57.122  - debug: zigbee.0 (1208) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2024-01-21 17:20:57.175  - debug: zigbee.0 (1208) Objects client ready ... initialize now
                  2024-01-21 17:20:57.178  - debug: zigbee.0 (1208) Objects create System PubSub Client
                  2024-01-21 17:20:57.179  - debug: zigbee.0 (1208) Objects create User PubSub Client
                  2024-01-21 17:20:57.241  - debug: zigbee.0 (1208) Objects client initialize lua scripts
                  2024-01-21 17:20:57.260  - debug: zigbee.0 (1208) Objects connected to redis: 127.0.0.1:9001
                  2024-01-21 17:20:57.320  - debug: zigbee.0 (1208) Redis States: Use Redis connection: 127.0.0.1:9000
                  2024-01-21 17:20:57.346  - debug: zigbee.0 (1208) States create System PubSub Client
                  2024-01-21 17:20:57.348  - debug: zigbee.0 (1208) States create User PubSub Client
                  2024-01-21 17:20:57.441  - debug: zigbee.0 (1208) States connected to redis: 127.0.0.1:9000
                  2024-01-21 17:20:57.535  - debug: zigbee.0 (1208) Plugin sentry Initialize Plugin (enabled=true)
                  2024-01-21 17:20:58.509  - info: zigbee.0 (1208) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                  2024-01-21 17:20:58.553  - debug: zigbee.0 (1208) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
                  2024-01-21 17:20:58.661  - info: zigbee.0 (1208) delete old Backup files. keep only last 10
                  2024-01-21 17:20:58.663  - info: zigbee.0 (1208) Starting Zigbee  npm ...
                  2024-01-21 17:20:58.724  - debug: zigbee.0 (1208) Starting zigbee-herdsman...
                  2024-01-21 17:21:00.498  - error: zigbee.0 (1208) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
                  2024-01-21 17:21:00.499  - error: zigbee.0 (1208) Failed to start Zigbee
                  2024-01-21 17:21:00.499  - error: zigbee.0 (1208) Error herdsman start
                  2024-01-21 17:21:00.507  - info: zigbee.0 (1208) Installed Version: iobroker.zigbee@1.10.1
                  2024-01-21 17:21:01.087  - debug: zigbee.0 (1208) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_21-17_20_58.tar.gz success
                  2024-01-21 17:21:10.505  - info: zigbee.0 (1208) Try to reconnect. 1 attempts left
                  2024-01-21 17:21:10.506  - info: zigbee.0 (1208) Starting Zigbee  npm ...
                  2024-01-21 17:21:10.512  - debug: zigbee.0 (1208) Starting zigbee-herdsman...
                  2024-01-21 17:21:10.524  - error: zigbee.0 (1208) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
                  2024-01-21 17:21:10.525  - error: zigbee.0 (1208) Failed to start Zigbee
                  2024-01-21 17:21:10.526  - error: zigbee.0 (1208) Error herdsman start
                  2024-01-21 17:21:10.535  - info: zigbee.0 (1208) Installed Version: iobroker.zigbee@1.10.1
                  2024-01-21 17:25:54.886  - error: zigbee.0 (1208) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                  2024-01-21 17:25:55.156  - info: zigbee.0 (1208) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"8eb6f719a99ded11ad35dca5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"}]
                  • T Tapdance 0
                    @tapdance-0
                    Du hast da immer noch den alten Stick in den Einstellungen. Das muss durch den aktuellen Link ersetzt werden.
                    Edit:
                    Okay, hier scheint es nun drin zu sein:
                      Da:
                      das eintragen:
                      Tapdance 0
                      habe den Punkt zum eintragen des Pfades gefunden. Der wird nur angezeigt wenn man über die Instanz in Menü geht. Pfad ist eingetragen Adapter ist grün, aber leider funktioniert noch nichts.
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : arm64
                       17:39:43 up 6 min,  3 users,  load average: 0.52, 0.90, 0.57
                      CPU threads: 4
                      Current issues:
                                     Local time: Sun 2024-01-21 17:39:43 CET
                                 Universal time: Sun 2024-01-21 16:39:43 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      PI
                      /home/PI
                      PI adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            4.0G        1.6G        2.0G        1.3M        420M        2.3G
                      Swap:           104M          0B        104M
                      Total:          4.1G        1.6G        2.1G
                               3793 M total memory
                               1571 M used memory
                               1603 M active memory
                                166 M inactive memory
                               1897 M free memory
                                 40 M buffer memory
                                359 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      [Sun Jan 21 17:32:52 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:64:62:CC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9515910b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                      [Sun Jan 21 17:32:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Sun Jan 21 17:32:59 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      667M    /var/
                      194M    /var/lib
                      187M    /var/log
                      186M    /var/log/journal/67fa5cc7176343b98d5ef1e5e5a27de6
                      Archived and active journals take up 185.5M in the file system.
                      368M    /opt/iobroker/iobroker-data/
                      24M     /opt/iobroker/iobroker-data/objects.jsonl
                      7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                           18.13.0+dfsg1-1 500
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.0
                      javascript:     7.1.6
                      Adapter State
                      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0
                      + instance is alive
                      Objects and States
                      Objects:        5503
                      States:         4905
                      Pending Updates: 0
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12153      804/sshd: /usr/sbin
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16485      794/cupsd
                      tcp        0      0 192.168.2.4:2001        0.0.0.0:*               LISTEN      1001       19586      1091/io.hm-rpc.0
                      tcp        0      0 192.168.2.4:2010        0.0.0.0:*               LISTEN      1001       16840      1092/io.hm-rpc.1
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16343      795/iobroker.js-con
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18476      795/iobroker.js-con
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18056      1150/io.sonoff.0
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          12155      804/sshd: /usr/sbin
                      tcp6       0      0 :::39615                :::*                    LISTEN      1001       19369      1962/io.yahka.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20340      1882/io.web.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17851      969/io.admin.0
                      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       17327      1565/io.terminal.0
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16484      794/cupsd
                      udp        0      0 0.0.0.0:36784           0.0.0.0:*                           104        16424      573/avahi-daemon: r
                      udp        0      0 0.0.0.0:34788           0.0.0.0:*                           1001       20998      1325/io.broadlink2.
                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16262      844/cups-browsed
                      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       20995      1325/io.broadlink2.
                      udp        0      0 0.0.0.0:58383           0.0.0.0:*                           1001       22993      1325/io.broadlink2.
                      udp        0      0 192.168.2.4:5353        0.0.0.0:*                           1001       18718      1181/io.tr-064.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        16422      573/avahi-daemon: r
                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       18034      1116/io.shelly.0
                      udp6       0      0 fe80::67d1:e1cb:7ef:546 :::*                                0          12279      733/NetworkManager
                      udp6       0      0 :::50277                :::*                                104        16425      573/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                104        16423      573/avahi-daemon: r
                      2024-01-21 17:40:28.300  - debug: zigbee.0 (1229) DeviceAvailability:Non-pingable device 0x00158d000461da61 lumi.sensor_magnet was last seen '34744106.67' seconds ago.
                      2024-01-21 17:40:28.329  - debug: zigbee.0 (1229) DeviceAvailability:Non-pingable device 0x04cd15fffefe9ca8 ZBMINIL2 was last seen '5227.093' seconds ago.
                      2024-01-21 17:40:28.907  - warn: shelly.0 (1116) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-01-21 17:40:37.805  - warn: sonoff.0 (1150) Client [Pavillon Beleuchtung] has invalid password or username
                      2024-01-21 17:40:38.241  - warn: shelly.0 (1116) State value to set for "shelly.0.SHDM-1#D3E918#1.temperatureF" has value "102.12" greater than max "100"
                      2024-01-21 17:40:38.726  - warn: sonoff.0 (1150) Client [Pool Beleuchtung] has invalid password or username
                      2024-01-21 17:40:38.782  - warn: sonoff.0 (1150) Client [Muschel Terrasse] has invalid password or username
                      2024-01-21 17:40:38.794  - warn: shelly.0 (1116) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-01-21 17:40:38.899  - warn: shelly.0 (1116) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-01-21 17:40:40.448  - warn: sonoff.0 (1150) Client [Pool Pumpe] has invalid password or username
                      2024-01-21 17:40:43.820  - warn: sonoff.0 (1150) Client [Taster-Schlafzimmer-Bett-L] has invalid password or username
                      2024-01-21 17:40:44.160  - warn: shelly.0 (1116) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-01-21 17:40:44.159  - warn: sonoff.0 (1150) Client [Wohnzimmer-Vitrine] has invalid password or username
                      2024-01-21 17:40:44.733  - warn: sonoff.0 (1150) Client [PC-Buero] has invalid password or username
                      2024-01-21 17:40:51.475  - warn: shelly.0 (1116) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-01-21 17:40:51.688  - warn: shelly.0 (1116) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-01-21 17:40:51.753  - warn: shelly.0 (1116) State value to set for "shelly.0.SHDM-2#8CAAB54C4B57#1.temperatureF" has value "106.96" greater than max "100"
                      2024-01-21 17:40:55.957  - warn: shelly.0 (1116) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-01-21 17:41:03.864  - warn: sonoff.0 (1150) Client [Pavillon Beleuchtung] has invalid password or username
                      2024-01-21 17:41:04.546  - warn: sonoff.0 (1150) Client [Pool Beleuchtung] has invalid password or username
                      2024-01-21 17:41:05.691  - warn: shelly.0 (1116) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-01-21 17:41:05.875  - warn: shelly.0 (1116) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-01-21 17:41:06.282  - warn: sonoff.0 (1150) Client [Pool Pumpe] has invalid password or username
                      2024-01-21 17:41:07.007  - warn: shelly.0 (1116) State value to set for "shelly.0.SHDM-2#8CAAB54C4B57#1.temperatureF" has value "107.08" greater than max "100"
                      2024-01-21 17:41:07.280  - warn: sonoff.0 (1150) Client [Muschel Terrasse] has invalid password or username
                      Press any key for a summary
                      2024-01-21 17:34:16.171 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1229
                      2024-01-21 17:34:22.326 - debug: zigbee.0 (1229) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      2024-01-21 17:34:22.397 - debug: zigbee.0 (1229) Objects client ready ... initialize now
                      2024-01-21 17:34:22.400 - debug: zigbee.0 (1229) Objects create System PubSub Client
                      2024-01-21 17:34:22.402 - debug: zigbee.0 (1229) Objects create User PubSub Client
                      2024-01-21 17:34:22.481 - debug: zigbee.0 (1229) Objects client initialize lua scripts
                      2024-01-21 17:34:22.495 - debug: zigbee.0 (1229) Objects connected to redis: 127.0.0.1:9001
                      2024-01-21 17:34:22.546 - debug: zigbee.0 (1229) Redis States: Use Redis connection: 127.0.0.1:9000
                      2024-01-21 17:34:22.625 - debug: zigbee.0 (1229) States create System PubSub Client
                      2024-01-21 17:34:22.627 - debug: zigbee.0 (1229) States create User PubSub Client
                      2024-01-21 17:34:22.711 - debug: zigbee.0 (1229) States connected to redis: 127.0.0.1:9000
                      2024-01-21 17:34:22.780 - debug: zigbee.0 (1229) Plugin sentry Initialize Plugin (enabled=true)
                      2024-01-21 17:34:23.636 - info: zigbee.0 (1229) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                      2024-01-21 17:34:23.678 - debug: zigbee.0 (1229) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
                      2024-01-21 17:34:23.787 - info: zigbee.0 (1229) delete old Backup files. keep only last 10
                      2024-01-21 17:34:23.790 - info: zigbee.0 (1229) Starting Zigbee npm ...
                      2024-01-21 17:34:23.867 - debug: zigbee.0 (1229) Starting zigbee-herdsman...
                      2024-01-21 17:34:24.431 - info: zigbee.0 (1229) Installed Version: iobroker.zigbee@1.10.1
                      2024-01-21 17:34:25.075 - debug: zigbee.0 (1229) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_21-17_34_23.tar.gz success
                      2024-01-21 17:34:28.117 - debug: zigbee.0 (1229) zigbee-herdsman started
                      2024-01-21 17:34:28.120 - info: zigbee.0 (1229) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
                      2024-01-21 17:34:28.129 - debug: zigbee.0 (1229) Zigbee network parameters: panID=6754 channel=11 extendedPanID=dddddddddddddddd
                      2024-01-21 17:34:28.130 - info: zigbee.0 (1229) Disable LED
                      2024-01-21 17:34:28.131 - info: zigbee.0 (1229) Unable to disable LED, unsupported function.
                      2024-01-21 17:34:28.151 - info: zigbee.0 (1229) --> transmitPower : normal
                      2024-01-21 17:34:28.194 - info: zigbee.0 (1229) Currently 28 devices are joined:
                      2024-01-21 17:34:28.195 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00044d8e0b = true
                      2024-01-21 17:34:28.203 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00044d8e0b = 10
                      2024-01-21 17:34:28.211 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d000257bae7 = true
                      2024-01-21 17:34:28.218 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d000257bae7 = 10
                      2024-01-21 17:34:28.221 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00045f7cee = true
                      2024-01-21 17:34:28.225 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00045f7cee = 10
                      2024-01-21 17:34:28.228 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d0004521481 = true
                      2024-01-21 17:34:28.232 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d0004521481 = 10
                      2024-01-21 17:34:28.235 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d000461b53e = true
                      2024-01-21 17:34:28.239 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d000461b53e = 10
                      2024-01-21 17:34:28.243 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x680ae2fffec91ea4 = true
                      2024-01-21 17:34:28.247 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x680ae2fffec91ea4 = 10
                      2024-01-21 17:34:28.250 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x588e81fffe2b8762 = true
                      2024-01-21 17:34:28.254 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x588e81fffe2b8762 = 10
                      2024-01-21 17:34:28.258 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00045eb708 = true
                      2024-01-21 17:34:28.261 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00045eb708 = 10
                      2024-01-21 17:34:28.265 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d0002a71e25 = true
                      2024-01-21 17:34:28.269 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d0002a71e25 = 10
                      2024-01-21 17:34:28.273 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c794764 = true
                      2024-01-21 17:34:28.277 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c794764 = 10
                      2024-01-21 17:34:28.280 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c7946a1 = true
                      2024-01-21 17:34:28.284 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7946a1 = 10
                      2024-01-21 17:34:28.288 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00045f8d3d = true
                      2024-01-21 17:34:28.291 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00045f8d3d = 10
                      2024-01-21 17:34:28.295 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d0004597653 = true
                      2024-01-21 17:34:28.299 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d0004597653 = 10
                      2024-01-21 17:34:28.314 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0xbc33acfffe2ab392 = true
                      2024-01-21 17:34:28.318 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0xbc33acfffe2ab392 = 10
                      2024-01-21 17:34:28.322 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c7b5255 = true
                      2024-01-21 17:34:28.326 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b5255 = 10
                      2024-01-21 17:34:28.330 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c7b51f7 = true
                      2024-01-21 17:34:28.334 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b51f7 = 10
                      2024-01-21 17:34:28.338 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c78b7ba = true
                      2024-01-21 17:34:28.341 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c78b7ba = 10
                      2024-01-21 17:34:28.345 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d000461da61 = true
                      2024-01-21 17:34:28.349 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d000461da61 = 10
                      2024-01-21 17:34:28.354 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cd15fffefe9ca8 = true
                      2024-01-21 17:34:28.358 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cd15fffefe9ca8 = 10
                      grep: (standard input): binary file matches
                      code_text
                      • T Tapdance 0
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                         Static hostname: raspberrypi
                               Icon name: computer
                                  Kernel: Linux 6.1.0-rpi7-rpi-v8
                            Architecture: arm64
                        Model           : Raspberry Pi 4 Model B Rev 1.1
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : arm64
                        Systemuptime and Load:
                        CPU threads: 4
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** Time and Time Zones ***
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        PI
                        /home/PI
                        *** X-Server-Setup ***
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        Boot Target:    multi-user.target
                        *** MEMORY ***
                        Swap:           104M          0B        104M
                                 3793 M total memory
                                 1571 M used memory
                                 1897 M free memory
                                   40 M buffer memory
                                  359 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FAILED SERVICES ***
                        0 loaded units listed.
                        *** FILESYSTEM ***
                        udev           devtmpfs  1.6G     0  1.6G   0% /dev
                        tmpfs          tmpfs     380M  1.2M  379M   1% /run
                        /dev/mmcblk0p2 ext4       28G  7.1G   20G  27% /
                        tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
                        tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                        /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
                        tmpfs          tmpfs     380M   32K  380M   1% /run/user/1000
                        TARGET           SOURCE         FSTYPE OPTIONS
                        /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                        /var:
                        667M    /var/
                        194M    /var/lib
                        187M    /var/log
                        /opt/iobroker/backups:
                        4.0K    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        270M    /opt/iobroker/iobroker-data/files
                        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                        73M     /opt/iobroker/iobroker-data/backup-objects
                        67M     /opt/iobroker/iobroker-data/files/javascript.admin
                        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
                        7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
                        USB-Devices by-id:
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v18.19.0
                        /usr/bin/node           v18.19.0
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        /usr/bin/corepack       0.22.0
                        nodejs:
                          Installed: 18.19.0-1nodesource1
                          Candidate: 18.19.0-1nodesource1
                          Version table:
                             18.19.0+dfsg-6~deb12u1 500
                                500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                         *** 18.19.0-1nodesource1 1001
                                500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                             18.18.2-1nodesource1 1001
                             18.18.1-1nodesource1 1001
                             18.18.0-1nodesource1 1001
                             18.17.1-1nodesource1 1001
                             18.17.0-1nodesource1 1001
                             18.16.1-1nodesource1 1001
                             18.16.0-1nodesource1 1001
                             18.15.0-1nodesource1 1001
                             18.14.2-1nodesource1 1001
                             18.14.1-1nodesource1 1001
                             18.14.0-1nodesource1 1001
                             18.13.0+dfsg1-1 500
                                500 http://deb.debian.org/debian bookworm/main arm64 Packages
                             18.13.0-1nodesource1 1001
                             18.12.0-1nodesource1 1001
                             18.11.0-1nodesource1 1001
                             18.10.0-1nodesource1 1001
                             18.9.1-1nodesource1 1001
                             18.9.0-1nodesource1 1001
                             18.8.0-1nodesource1 1001
                             18.7.0-1nodesource1 1001
                             18.6.0-1nodesource1 1001
                             18.5.0-1nodesource1 1001
                             18.4.0-1nodesource1 1001
                             18.3.0-1nodesource1 1001
                             18.2.0-1nodesource1 1001
                             18.1.0-1nodesource1 1001
                             18.0.0-1nodesource1 1001
                        No problems detected
                        Errors in npm tree:
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        admin:          6.12.0
                        javascript:     7.1.6
                        Adapters from github:   0
                        Adapter State
                        + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
                        + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                        + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                        + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                        + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                        + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                          system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
                          system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
                          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
                          system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
                        + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                        + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
                        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
                        + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 192.168.2.4, run as: admin
                        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                          system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                          system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
                        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
                        + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
                        + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                        + instance is alive
                        ioBroker-Repositories
                        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                        Stable (default): http://download.iobroker.net/sources-dist.json
                        Installed ioBroker-Instances
                        Adapter    "admin"        : 6.12.0   , installed 6.12.0
                        Adapter    "alarm"        : 3.6.0    , installed 3.6.0
                        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                        Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                        Adapter    "info"         : 2.0.0    , installed 2.0.0
                        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                        Controller "js-controller": 5.0.17   , installed 5.0.17
                        Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                        Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                        Adapter    "synology"     : 3.0.1    , installed 3.0.1
                        Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                        Adapter    "vis"          : 1.5.4    , installed 1.5.4
                        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                        Adapter    "web"          : 6.1.10   , installed 6.1.10
                        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                        Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                        Adapter    "ws"           : 2.5.8    , installed 2.5.8
                        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                        Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                        Objects and States
                        Objects:        5503
                        States:         4905
                        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        code_text
                        Läuft doch.
                        • T Tapdance 0
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : arm64
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          PI
                          /home/PI
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:           104M          0B        104M
                                   3793 M total memory
                                   1571 M used memory
                                   1897 M free memory
                                     40 M buffer memory
                                    359 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          667M    /var/
                          194M    /var/lib
                          187M    /var/log
                          USB-Devices by-id:
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          nodejs:
                            Version table:
                               18.13.0+dfsg1-1 500
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.12.0
                          javascript:     7.1.6
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        5503
                          States:         4905
                          Pending Updates: 0
                          code_text
                          firmware version: "revision":20210708
                          Ist allerdings steinalt. Würde ich aktualisieren.
                            Läuft doch.
                            Tapdance 0
                            Aber kein Gerät reagiert, selbst die nicht die vorher noch funktioniert haben.
                            • T Tapdance 0
                              Tapdance 0
                              @tapdance-0
                              PI@raspberrypi:~ $ ^C
                              PI@raspberrypi:~ $ iob logs | grep zigbee
                              2024-01-21 17:36:23.926  - debug: zigbee.0 (1229) Failed to execute LQI for '0xf4b3b1fffef8731e'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n    at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:63:23)\n    at request (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:582:47)\n    at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:604:28\n    at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20)\n    at ZigbeeController.getMap (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:721:30)"
                              PI@raspberrypi:~ $
                                Tapdance 0
                                Ok und wie mache ich das mit der Firmware Version?
                                Jetzt bin ich wieder bei meinem Ursprungsproblem alles hat sich eingependelt und läuft außer.
                                bei "MOES ZigBee Mini Smart" da kann ich keine Daten mehr senden kann nur empfangen.
                                Ich kann im IO Broker aber den Status der Geräte sehen der Empfang der daten funktioniert also. Beispiel ich ändere am Schalter manuell die Helligkeit dann sehe ich im IOBrocker die aktuelle Prozentzahl der Helligkeit. Andere Zigbee Komponenten wie meine Bewegungsmelder von Acera scheinen nicht betroffen zu sein.
                                • T Tapdance 0
                                  @tapdance-0
                                  https://www.zigbee2mqtt.io/guide/adapters/flashing/flashing_via_cc2538-bsl.html
                                    @tapdance-0
                                    Tapdance 0
                                    Method without Docker
                                    Prepare your system (debian based)
                                    Ist debian = RasperyPI
                                    • T Tapdance 0
                                      @tapdance-0
                                      Ja, Raspberry OS basiert auf Debian.
                                        @tapdance-0
                                        Tapdance 0
                                        Bis Download the Firmware verstehe ich das aber wie lade ich dann die firmware von der webseite runter und bringe sie in den Raspberry?
                                        Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
                                        • T Tapdance 0
                                          Meister MopperM Online
                                          Meister Mopper
                                          schrieb am zuletzt editiert von Meister Mopper
                                          Du solltest die Firmware des Geräts aktualisieren, nicht die des Raspi.
                                          Proxmox und HA ...
