  4. Ziggbe sendet nicht mehr an empfängt aber noch Daten
67 Beiträge 6 Kommentatoren 9.0k Aufrufe 6 Beobachtet
  • T Tapdance 0
    Der neue Zigbee stick ist da und angeschlossen, doch jetzt startet der Zigbee Adapter wieder nicht 😥
    Hoffe ihr könnt noch mal helfen.
    DANKE
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.1.0-rpi7-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     16:32:45 up 3 min,  3 users,  load average: 1.29, 1.41, 0.63
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2024-01-21 16:32:45 CET
               Universal time: Sun 2024-01-21 15:32:45 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    PI
    /home/PI
    PI adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            4.0G        1.6G        2.0G        1.3M        417M        2.3G
    Swap:           104M          0B        104M
    Total:          4.1G        1.6G        2.1G
             3793 M total memory
             1567 M used memory
             1595 M active memory
              164 M inactive memory
             1903 M free memory
               39 M buffer memory
              358 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  379M   1% /run
    /dev/mmcblk0p2 ext4       28G  7.0G   20G  27% /
    tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
    tmpfs          tmpfs     380M   32K  380M   1% /run/user/1000
    [Sun Jan 21 16:28:52 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:64:62:CC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9515910b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sun Jan 21 16:28:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Jan 21 16:28:59 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    643M    /var/
    194M    /var/lib
    185M    /var/cache
    172M    /var/cache/apt
    163M    /var/log
    Archived and active journals take up 161.5M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    369M    /opt/iobroker/iobroker-data/
    270M    /opt/iobroker/iobroker-data/files
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    73M     /opt/iobroker/iobroker-data/backup-objects
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
    7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
    7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   0
    Adapter State
    + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
      system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
    + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 192.168.2.4, run as: admin
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
    + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
    + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00
    + instance is alive
    ioBroker-Repositories
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Stable (default): http://download.iobroker.net/sources-dist.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alarm"        : 3.6.0    , installed 3.6.0
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "telegram"     : 3.0.1    , installed 1.16.0 [Updatable]
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.10.1   , installed 1.9.7  [Updatable]
    Objects and States
    Objects:        5503
    States:         4905
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18072      1133/io.sonoff.0
    tcp        0      0 192.168.2.4:2010        0.0.0.0:*               LISTEN      1001       15234      1081/io.hm-rpc.1
    tcp        0      0 192.168.2.4:2001        0.0.0.0:*               LISTEN      1001       18000      1057/io.hm-rpc.0
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15659      783/cupsd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17317      784/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15044      784/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14884      796/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20375      1964/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15912      962/io.admin.0
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       20131      1544/io.terminal.0
    tcp6       0      0 :::37485                :::*                    LISTEN      1001       21491      2003/io.yahka.0
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15658      783/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14886      796/sshd: /usr/sbin
    udp        0      0 0.0.0.0:41433           0.0.0.0:*                           1001       27228      3290/io.broadlink2.
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14975      863/cups-browsed
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       28156      3290/io.broadlink2.
    udp        0      0 0.0.0.0:52376           0.0.0.0:*                           1001       27229      3290/io.broadlink2.
    udp        0      0 192.168.2.4:5353        0.0.0.0:*                           1001       16153      1165/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15556      523/avahi-daemon: r
    udp        0      0 0.0.0.0:60813           0.0.0.0:*                           104        15558      523/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       18051      1106/io.shelly.0
    udp6       0      0 :::39207                :::*                                104        15559      523/avahi-daemon: r
    udp6       0      0 fe80::67d1:e1cb:7ef:546 :::*                                0          17307      664/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        15557      523/avahi-daemon: r
    2024-01-21 16:34:01.381  - warn: sonoff.0 (1133) Client [Muschel Terrasse] has invalid password or username
    2024-01-21 16:34:01.418  - warn: sonoff.0 (1133) Client [Pavillon Beleuchtung] has invalid password or username
    2024-01-21 16:34:01.764  - info: host.raspberrypi instance system.adapter.broadlink2.0 started with pid 3290
    2024-01-21 16:34:02.379  - warn: sonoff.0 (1133) Client [Wohnzimmer-Vitrine] has invalid password or username
    2024-01-21 16:34:02.422  - warn: sonoff.0 (1133) Client [Pool Beleuchtung] has invalid password or username
    2024-01-21 16:34:02.488  - warn: sonoff.0 (1133) Client [PC-Buero] has invalid password or username
    2024-01-21 16:34:05.121  - warn: sonoff.0 (1133) Client [Pool Pumpe] has invalid password or username
    2024-01-21 16:34:06.343  - warn: shelly.0 (1106) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-21 16:34:07.510  - warn: shelly.0 (1106) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-21 16:34:08.211  - info: broadlink2.0 (3290) starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v18.19.0, js-controller: 5.0.17
    2024-01-21 16:34:07.671  - warn: shelly.0 (1106) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-21 16:34:07.683  - warn: shelly.0 (1106) State value to set for "shelly.0.SHDM-1#D3E918#1.temperatureF" has value "101.66" greater than max "100"
    2024-01-21 16:34:08.481  - info: broadlink2.0 (3290) broadlink2 initialization started...
    2024-01-21 16:34:08.486  - info: broadlink2.0 (3290) Scanning additional IP's: 192.168.2.169
    2024-01-21 16:34:08.487  - info: broadlink2.0 (3290) Devices to add: 0xabcd=RM4
    2024-01-21 16:34:08.489  - info: broadlink2.0 (3290) Devices to rename: LB:hostName-aa-bb-cc=LB:SmartBulb
    2024-01-21 16:34:08.492  - info: broadlink2.0 (3290) broadlink2 has 3 old devices!
    2024-01-21 16:34:08.497  - info: broadlink2.0 (3290) interface to be used: { netmaskBits: 24, address: '192.168.2.4/24', addrs: [ 192, 168, 2, 4 ], cidr: '192.168.2.4/24', bcaddr: '192.168.2.255'
    2024-01-21 16:34:08.498  - info: broadlink2.0 (3290) macObjects: [ '24:df:a7:b1:1a:8d', 'a0:43:b0:14:80:2b', 'b4:43:0d:aa:80:31' ]
    2024-01-21 16:34:08.502  - info: broadlink2.0 (3290) Discover Broadlink devices for 10sec on broadlink2.0
    2024-01-21 16:34:08.590  - info: broadlink2.0 (3290) interface to be used: { netmaskBits: 24, address: '192.168.2.4/24', addrs: [ 192, 168, 2, 4 ], cidr: '192.168.2.4/24', bcaddr: '192.168.2.255'
    2024-01-21 16:34:08.593  - info: broadlink2.0 (3290) discover  [ '192.168.2.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:41433
    2024-01-21 16:34:09.382  - info: broadlink2.0 (3290) Device RM:RMPRO-MOVE315-b1-1a-8d detected: address=192.168.2.169, mac=24:df:a7:b1:1a:8d, typ=RMP, id=0x27a9 devtype=RM3 Pro Plus
    iob diag has finished.
                            v.2023-10-10
           Icon name: computer
        Architecture: arm64
    Kernel:                 aarch64
    Userland:               arm64
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     1
    Pending iob updates:    2
    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
    Recommended versions are nodejs 18.19.0 and npm 10.2.3
    MEMORY:
    Mem:            4.0G        1.7G        1.6G        1.3M        765M        2.3G
    Swap:           104M          0B        104M
    Total:          4.1G        1.7G        1.7G
    Active iob-Instances:   25
    ioBroker Core:          js-controller           5.0.17
                            admin                   6.12.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                5503
    States:                 4905
    Size of iob-Database:
    5.3M    /opt/iobroker/iobroker-data/states.jsonl
    PI@raspberrypi:~ $ iob logs | grep zigbee
    2024-01-21 16:24:16.091  - debug: zigbee.0 (2837) DeviceAvailability:Publish available for 0xf4b3b1fffef87315 = false
    2024-01-21 16:24:16.105  - debug: zigbee.0 (2837) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87315 = 0
    2024-01-21 16:24:16.109  - debug: zigbee.0 (2837) DeviceAvailability:Publish available for 0xf4b3b1fffef8731e = false
    2024-01-21 16:24:16.122  - debug: zigbee.0 (2837) DeviceAvailability:Publish LQ for 0xf4b3b1fffef8731e = 0
    2024-01-21 16:24:16.127  - debug: zigbee.0 (2837) DeviceAvailability:Publish available for 0xf4b3b1fffef84d2d = false
    2024-01-21 16:24:16.138  - debug: zigbee.0 (2837) DeviceAvailability:Publish LQ for 0xf4b3b1fffef84d2d = 0
    2024-01-21 16:24:16.143  - debug: zigbee.0 (2837) DeviceAvailability:Publish available for 0xf4b3b1fffef87b6a = false
    2024-01-21 16:24:16.148  - debug: zigbee.0 (2837) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87b6a = 0
    2024-01-21 16:24:16.152  - debug: zigbee.0 (2837) DeviceAvailability:Publish available for 0xf4b3b1fffef853ac = false
    2024-01-21 16:24:16.176  - debug: zigbee.0 (2837) DeviceAvailability:Publish LQ for 0xf4b3b1fffef853ac = 0
    2024-01-21 16:24:16.181  - debug: zigbee.0 (2837) DeviceAvailability:Publish available for 0x04cd15fffefe9ca8 = false
    2024-01-21 16:24:16.185  - debug: zigbee.0 (2837) DeviceAvailability:Publish LQ for 0x04cd15fffefe9ca8 = 0
    2024-01-21 16:24:16.191  - debug: zigbee.0 (2837) DeviceAvailability:Publish available for 0xa4c138c66404899e = false
    2024-01-21 16:24:16.198  - debug: zigbee.0 (2837) DeviceAvailability:Publish LQ for 0xa4c138c66404899e = 0
    2024-01-21 16:24:16.215  - info: zigbee.0 (2837) Zigbee: disabling joining new devices.
    2024-01-21 16:24:19.977  - warn: zigbee.0 (2837) Failed to stop zigbee during startup
    2024-01-21 16:24:20.282  - warn: host.raspberrypi instance system.adapter.zigbee.0 terminated due to SIGTERM
    2024-01-21 16:24:20.282  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code null ()
    2024-01-21 16:30:15.740  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1209
    2024-01-21 16:30:22.216  - debug: zigbee.0 (1209) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2024-01-21 16:30:22.270  - debug: zigbee.0 (1209) Objects client ready ... initialize now
    2024-01-21 16:30:22.274  - debug: zigbee.0 (1209) Objects create System PubSub Client
    2024-01-21 16:30:22.275  - debug: zigbee.0 (1209) Objects create User PubSub Client
    2024-01-21 16:30:22.336  - debug: zigbee.0 (1209) Objects client initialize lua scripts
    2024-01-21 16:30:22.348  - debug: zigbee.0 (1209) Objects connected to redis: 127.0.0.1:9001
    2024-01-21 16:30:22.403  - debug: zigbee.0 (1209) Redis States: Use Redis connection: 127.0.0.1:9000
    2024-01-21 16:30:22.433  - debug: zigbee.0 (1209) States create System PubSub Client
    2024-01-21 16:30:22.435  - debug: zigbee.0 (1209) States create User PubSub Client
    2024-01-21 16:30:22.509  - debug: zigbee.0 (1209) States connected to redis: 127.0.0.1:9000
    2024-01-21 16:30:22.575  - debug: zigbee.0 (1209) Plugin sentry Initialize Plugin (enabled=true)
    2024-01-21 16:30:23.292  - info: zigbee.0 (1209) starting. Version 1.9.7 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
    2024-01-21 16:30:23.324  - debug: zigbee.0 (1209) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
    2024-01-21 16:30:23.412  - info: zigbee.0 (1209) delete old Backup files. keep only last 10
    2024-01-21 16:30:23.414  - info: zigbee.0 (1209) Starting Zigbee  npm ...
    2024-01-21 16:30:23.462  - debug: zigbee.0 (1209) Starting zigbee-herdsman...
    2024-01-21 16:30:24.299  - error: zigbee.0 (1209) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
    2024-01-21 16:30:24.300  - error: zigbee.0 (1209) Failed to start Zigbee
    2024-01-21 16:30:24.300  - error: zigbee.0 (1209) Error herdsman start
    2024-01-21 16:30:24.327  - info: zigbee.0 (1209) Installed Version: iobroker.zigbee@1.9.7
    2024-01-21 16:30:24.887  - debug: zigbee.0 (1209) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_21-16_30_23.tar.gz success
    2024-01-21 16:30:34.304  - info: zigbee.0 (1209) Try to reconnect. 1 attempts left
    2024-01-21 16:30:34.305  - info: zigbee.0 (1209) Starting Zigbee  npm ...
    2024-01-21 16:30:34.311  - debug: zigbee.0 (1209) Starting zigbee-herdsman...
    2024-01-21 16:30:34.321  - error: zigbee.0 (1209) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
    2024-01-21 16:30:34.323  - error: zigbee.0 (1209) Failed to start Zigbee
    2024-01-21 16:30:34.323  - error: zigbee.0 (1209) Error herdsman start
    2024-01-21 16:30:34.332  - info: zigbee.0 (1209) Installed Version: iobroker.zigbee@1.9.7
    PI@raspberrypi:~ $ ^C
    @tapdance-0 sagte in Ziggbe sendet nicht mehr an empfängt aber noch Daten:
    Trag beim Comport ein:
    Bei dir steht der alte Stick noch drin.
    Und bring alles auf Stand.
    sudo apt full-upgrade
    iob update all
      iob update all
      Tapdance 0
      das Update hatte ich doch gestern schon angestoßen. Habe ich gerade noch mal angestoßen.
      Wie ändere ich den Eintrag beim Comport?
      Sorry bin kein kein Linux und Kommandozeilen Typ
      Thomas BraunT T 2 Antworten Letzte Antwort
      • T Tapdance 0
        In den Einstellungen des zigbee-Adapters. Ganz ohne Kommandozeile...
        • T Tapdance 0
          Tapdance 0
          Das kommt wenn ich den update Befehl ausführe.
          PI@raspberrypi:~ $ sudo apt full-upgrade
          iob update all
          Reading package lists... Done
          Calculating upgrade... Done
          The following packages were automatically installed and are no longer required:
            gtk2-engines-clearlookspix libcamera-apps libpisp0.0.1
          Use 'sudo apt autoremove' to remove them.
          The following packages will be upgraded:
            pixflat-icons
          1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          Need to get 1,120 kB of archives.
          After this operation, 209 kB of additional disk space will be used.
          Do you want to continue? [Y/n] y
          Get:1 http://archive.raspberrypi.com/debian bookworm/main arm64 pixflat-icons all 0.24 [1,120 kB]
          Fetched 1,120 kB in 0s (3,370 kB/s)
          Reading changelogs... Done
          (Reading database ... 155651 files and directories currently installed.)
          Preparing to unpack .../pixflat-icons_0.24_all.deb ...
          Unpacking pixflat-icons (0.24) over (0.23) ...
          Setting up pixflat-icons (0.24) ...
          gtk-update-icon-cache: Cache file created successfully.
          Used repository: all
          Error: unknown repository is active - "all". Known: Beta (latest), Stable (default)
          • T Tapdance 0
            iob update all
              pixflat-icons
            @tapdance-0
            Vertan.
            iobroker upgrade all
              @tapdance-0
              Vertan.
              Tapdance 0
              Updates müssten jetzt glaube ich alle durch sein. Wie ich den Pfad beim Comport eintrage weiß ich nicht hier die aktuellen Logs noch mal
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
               17:06:09 up 6 min,  3 users,  load average: 0.55, 0.84, 0.47
              CPU threads: 4
              Current issues:
                             Local time: Sun 2024-01-21 17:06:09 CET
                         Universal time: Sun 2024-01-21 16:06:09 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              PI
              /home/PI
              PI adm dialout cdrom sudo audio video plugdev games users input render netdev lp        admin gpio i2c spi iobroker
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            4.0G        1.7G        1.9G        1.3M        423M        2.3G
              Swap:           104M          0B        104M
              Total:          4.1G        1.7G        2.1G
                       3793 M total memory
                       1606 M used memory
                       1636 M active memory
                        170 M inactive memory
                       1858 M free memory
                         40 M buffer memory
                        363 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /dev/mmcblk0p2 ext4       28G  7.1G   20G  27% /
              [Sun Jan 21 16:59:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:64:62:CC vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=9515910b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles
              [Sun Jan 21 16:59:59 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
              [Sun Jan 21 17:00:02 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              651M    /var/
              194M    /var/lib
              185M    /var/cache
              172M    /var/cache/apt
              171M    /var/log
              Archived and active journals take up 169.5M in the file system.
              373M    /opt/iobroker/iobroker-data/
              23M     /opt/iobroker/iobroker-data/objects.jsonl
              7.2M    /opt/iobroker/iobroker-data/states.jsonl
              USB-Devices by-id:
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              nodejs:
                Version table:
                   18.13.0+dfsg1-1 500
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.12.0
              javascript:     7.1.6
              Adapter State
              + instance is alive
              Adapter    "telegram"     : 3.0.1    , installed 3.0.1
              Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
              Objects and States
              Objects:        5503
              States:         4905
              Pending Updates: 0
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18478      778/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17466      768/cupsd
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16860      769/iobroker.js-con
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17647      769/iobroker.js-con
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17854      1111/io.sonoff.0
              tcp        0      0 192.168.2.4:2001        0.0.0.0:*               LISTEN      1001       16989      1042/io.hm-rpc.0
              tcp        0      0 192.168.2.4:2010        0.0.0.0:*               LISTEN      1001       15037      1049/io.hm-rpc.1
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17465      768/cupsd
              tcp6       0      0 :::22                   :::*                    LISTEN      0          18480      778/sshd: /usr/sbin
              tcp6       0      0 :::8088                 :::*                    LISTEN      1001       22647      1525/io.terminal.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17701      946/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22866      1945/io.web.0
              tcp6       0      0 :::38469                :::*                    LISTEN      1001       20981      1983/io.yahka.0
              udp        0      0 0.0.0.0:44484           0.0.0.0:*                           104        17409      580/avahi-daemon: r
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       17826      1091/io.shelly.0
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16777      818/cups-browsed
              udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       17236      1286/io.broadlink2.
              udp        0      0 0.0.0.0:44173           0.0.0.0:*                           1001       17239      1286/io.broadlink2.
              udp        0      0 0.0.0.0:56537           0.0.0.0:*                           1001       23299      1286/io.broadlink2.
              udp        0      0 192.168.2.4:5353        0.0.0.0:*                           1001       19061      1146/io.tr-064.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        12287      580/avahi-daemon: r
              udp6       0      0 :::50851                :::*                                104        17410      580/avahi-daemon: r
              udp6       0      0 fe80::67d1:e1cb:7ef:546 :::*                                0          17623      706/NetworkManager
              udp6       0      0 :::5353                 :::*                                104        12288      580/avahi-daemon: r
              2024-01-21 17:06:49.735  - warn: sonoff.0 (1111) Client [Pool Pumpe] has invalid password or username
              2024-01-21 17:06:51.462  - warn: sonoff.0 (1111) Client [Muschel Terrasse] has invalid password or username
              2024-01-21 17:06:52.102  - warn: sonoff.0 (1111) Client [Pavillon Beleuchtung] has invalid password or username
              2024-01-21 17:06:54.224  - warn: shelly.0 (1091) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
              2024-01-21 17:06:54.227  - warn: sonoff.0 (1111) Client [Taster-Schlafzimmer-Bett-L] has invalid password or username
              2024-01-21 17:06:54.230  - warn: sonoff.0 (1111) Client [Wohnzimmer-Vitrine] has invalid password or username
              2024-01-21 17:06:54.288  - warn: shelly.0 (1091) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
              2024-01-21 17:06:54.315  - warn: shelly.0 (1091) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
              2024-01-21 17:06:56.433  - warn: sonoff.0 (1111) Client [PC-Buero] has invalid password or username
              2024-01-21 17:07:03.413  - warn: shelly.0 (1091) State value to set for "shelly.0.SHDM-2#8CAAB54C4E21#1.temperatureF" has value "141.05" greater than max "100"
              2024-01-21 17:07:06.195  - warn: shelly.0 (1091) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
              2024-01-21 17:07:06.513  - warn: shelly.0 (1091) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
              2024-01-21 17:07:07.480  - warn: shelly.0 (1091) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
              2024-01-21 17:07:14.240  - warn: sonoff.0 (1111) Client [Pool Beleuchtung] has invalid password or username
              2024-01-21 17:07:15.493  - warn: sonoff.0 (1111) Client [Pool Pumpe] has invalid password or username
              2024-01-21 17:07:17.252  - warn: sonoff.0 (1111) Client [Muschel Terrasse] has invalid password or username
              2024-01-21 17:07:17.896  - warn: sonoff.0 (1111) Client [Pavillon Beleuchtung] has invalid password or username
              2024-01-21 17:07:18.796  - warn: shelly.0 (1091) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
              2024-01-21 17:07:20.186  - warn: sonoff.0 (1111) Client [Wohnzimmer-Vitrine] has invalid password or username
              2024-01-21 17:07:20.188  - warn: sonoff.0 (1111) Client [Taster-Schlafzimmer-Bett-L] has invalid password or username
              2024-01-21 17:07:20.405  - warn: shelly.0 (1091) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
              2024-01-21 17:07:22.524  - warn: sonoff.0 (1111) Client [PC-Buero] has invalid password or username
              2024-01-21 17:07:26.175  - warn: shelly.0 (1091) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
              2024-01-21 17:07:32.167  - warn: shelly.0 (1091) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
              2024-01-21 17:07:33.565  - warn: shelly.0 (1091) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
              2024-01-21 16:58:32.729  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
              2024-01-21 16:58:32.736  - info: zigbee.0 (5918) Got terminate signal TERMINATE_YOURSELF
              2024-01-21 16:58:32.855  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
              2024-01-21 16:58:33.857  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 5918
              2024-01-21 16:58:35.954  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 6066
              2024-01-21 16:58:32.738  - info: zigbee.0 (5918) cleaned everything up...
              2024-01-21 16:58:32.772  - info: zigbee.0 (5918) Zigbee: disabling joining new devices.
              2024-01-21 16:58:32.773  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d00044d8e0b = false
              2024-01-21 16:58:32.785  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d00044d8e0b = 0
              2024-01-21 16:58:32.797  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d000257bae7 = false
              2024-01-21 16:58:32.810  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d000257bae7 = 0
              2024-01-21 16:58:32.820  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d00045f7cee = false
              2024-01-21 16:58:32.825  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d00045f7cee = 0
              2024-01-21 16:58:32.831  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d0004521481 = false
              2024-01-21 16:58:32.836  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d0004521481 = 0
              2024-01-21 16:58:32.843  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d000461b53e = false
              2024-01-21 16:58:32.849  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d000461b53e = 0
              2024-01-21 16:58:32.855  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x680ae2fffec91ea4 = false
              2024-01-21 16:58:32.860  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x680ae2fffec91ea4 = 0
              2024-01-21 16:58:32.867  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x588e81fffe2b8762 = false
              2024-01-21 16:58:32.873  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x588e81fffe2b8762 = 0
              2024-01-21 16:58:32.880  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x680ae2fffe924d57 = false
              2024-01-21 16:58:32.885  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x680ae2fffe924d57 = 0
              2024-01-21 16:58:32.892  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d00045eb708 = false
              2024-01-21 16:58:32.897  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d00045eb708 = 0
              2024-01-21 16:58:32.905  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d0002a71e25 = false
              2024-01-21 16:58:32.909  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d0002a71e25 = 0
              2024-01-21 16:58:32.915  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c794764 = false
              2024-01-21 16:58:32.919  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c794764 = 0
              2024-01-21 16:58:32.925  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c7946a1 = false
              2024-01-21 16:58:32.929  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7946a1 = 0
              2024-01-21 16:58:32.933  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d00045f8d3d = false
              2024-01-21 16:58:32.938  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d00045f8d3d = 0
              2024-01-21 16:58:32.943  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d0004597653 = false
              2024-01-21 16:58:32.947  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d0004597653 = 0
              2024-01-21 16:58:32.952  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x842e14fffe768d41 = false
              2024-01-21 16:58:32.956  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x842e14fffe768d41 = 0
              2024-01-21 16:58:32.962  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xbc33acfffe2ab392 = false
              2024-01-21 16:58:32.965  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xbc33acfffe2ab392 = 0
              2024-01-21 16:58:32.970  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c7b5255 = false
              2024-01-21 16:58:32.974  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b5255 = 0
              2024-01-21 16:58:32.980  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c7b51f7 = false
              2024-01-21 16:58:32.985  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b51f7 = 0
              2024-01-21 16:58:32.990  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c78b7ba = false
              2024-01-21 16:58:32.993  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c78b7ba = 0
              2024-01-21 16:58:32.998  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d000461da61 = false
              2024-01-21 16:58:33.001  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d000461da61 = 0
              2024-01-21 16:58:33.005  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef87315 = false
              2024-01-21 16:58:33.008  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87315 = 0
              2024-01-21 16:58:33.012  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef8731e = false
              2024-01-21 16:58:33.016  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef8731e = 0
              2024-01-21 16:58:33.019  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef84d2d = false
              2024-01-21 16:58:33.022  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef84d2d = 0
              2024-01-21 16:58:33.027  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef87b6a = false
              2024-01-21 16:58:33.030  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87b6a = 0
              2024-01-21 16:58:33.033  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef853ac = false
              2024-01-21 16:58:33.036  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef853ac = 0
              2024-01-21 16:58:33.040  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cd15fffefe9ca8 = false
              2024-01-21 16:58:33.043  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cd15fffefe9ca8 = 0
              2024-01-21 16:58:33.046  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xa4c138c66404899e = false
              2024-01-21 16:58:33.049  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xa4c138c66404899e = 0
              2024-01-21 16:58:39.403  - warn: zigbee.0 (5918) Failed to stop zigbee during startup
              2024-01-21 16:58:39.405  - info: zigbee.0 (5918) terminating
              2024-01-21 16:58:39.408  - debug: zigbee.0 (5918) Plugin sentry destroyed
              2024-01-21 16:58:39.409  - info: zigbee.0 (5918) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2024-01-21 16:58:39.412  - info: zigbee.0 (5918) terminating
              2024-01-21 16:58:39.502  - warn: zigbee.0 (5918) Got terminate signal. Checking desired PID: 0 vs own PID 5918
              2024-01-21 16:58:39.504  - warn: zigbee.0 (5918) Got terminate signal. Checking desired PID: 6066 vs own PID 5918
              2024-01-21 16:58:39.560  - info: zigbee.0 (5918) debug devices set to []
              2024-01-21 16:58:40.065  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
              2024-01-21 16:58:40.065  - info: host.raspberrypi Do not restart adapter system.adapter.zigbee.0 because desired by instance
              2024-01-21 16:58:40.406  - debug: zigbee.0 (6066) Redis Objects: Use Redis connection: 127.0.0.1:9001
              2024-01-21 16:58:40.452  - debug: zigbee.0 (6066) Objects client ready ... initialize now
              2024-01-21 16:58:40.455  - debug: zigbee.0 (6066) Objects create System PubSub Client
              2024-01-21 16:58:40.457  - debug: zigbee.0 (6066) Objects create User PubSub Client
              2024-01-21 16:58:40.538  - debug: zigbee.0 (6066) Objects client initialize lua scripts
              2024-01-21 16:58:40.549  - debug: zigbee.0 (6066) Objects connected to redis: 127.0.0.1:9001
              2024-01-21 16:58:40.596  - debug: zigbee.0 (6066) Redis States: Use Redis connection: 127.0.0.1:9000
              2024-01-21 16:58:40.616  - debug: zigbee.0 (6066) States create System PubSub Client
              2024-01-21 16:58:40.617  - debug: zigbee.0 (6066) States create User PubSub Client
              2024-01-21 16:58:40.688  - debug: zigbee.0 (6066) States connected to redis: 127.0.0.1:9000
              2024-01-21 16:58:40.742  - debug: zigbee.0 (6066) Plugin sentry Initialize Plugin (enabled=true)
              2024-01-21 16:58:41.361  - info: zigbee.0 (6066) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
              2024-01-21 16:58:41.396  - debug: zigbee.0 (6066) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
              2024-01-21 16:58:41.477  - info: zigbee.0 (6066) delete old Backup files. keep only last 10
              2024-01-21 16:58:41.480  - info: zigbee.0 (6066) Starting Zigbee  npm ...
              2024-01-21 16:58:41.526  - debug: zigbee.0 (6066) Starting zigbee-herdsman...
              2024-01-21 16:58:41.876  - error: zigbee.0 (6066) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
              2024-01-21 16:58:41.877  - error: zigbee.0 (6066) Failed to start Zigbee
              2024-01-21 16:58:41.877  - error: zigbee.0 (6066) Error herdsman start
              2024-01-21 16:58:41.881  - info: zigbee.0 (6066) Installed Version: iobroker.zigbee@1.10.1
              2024-01-21 16:58:42.387  - debug: zigbee.0 (6066) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_21-16_58_41.tar.gz success
              2024-01-21 16:58:51.881  - info: zigbee.0 (6066) Try to reconnect. 1 attempts left
              2024-01-21 16:58:51.882  - info: zigbee.0 (6066) Starting Zigbee  npm ...
              2024-01-21 16:58:51.887  - debug: zigbee.0 (6066) Starting zigbee-herdsman...
              2024-01-21 16:58:51.898  - error: zigbee.0 (6066) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
              2024-01-21 16:58:51.899  - error: zigbee.0 (6066) Failed to start Zigbee
              2024-01-21 16:58:51.899  - error: zigbee.0 (6066) Error herdsman start
              2024-01-21 16:58:51.907  - info: zigbee.0 (6066) Installed Version: iobroker.zigbee@1.10.1
              2024-01-21 16:59:25.780  - info: zigbee.0 (6066) cleaned everything up...
              2024-01-21 16:59:25.828  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=false)
              2024-01-21 16:59:25.876  - info: zigbee.0 (6066) Zigbee: disabling joining new devices.
              2024-01-21 16:59:25.877  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d00044d8e0b = false
              2024-01-21 16:59:25.893  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d00044d8e0b = 0
              2024-01-21 16:59:25.905  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d000257bae7 = false
              2024-01-21 16:59:25.916  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d000257bae7 = 0
              2024-01-21 16:59:25.928  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d00045f7cee = false
              2024-01-21 16:59:25.934  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d00045f7cee = 0
              2024-01-21 16:59:25.964  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d0004521481 = false
              2024-01-21 16:59:25.968  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d0004521481 = 0
              2024-01-21 16:59:25.974  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d000461b53e = false
              2024-01-21 16:59:25.979  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d000461b53e = 0
              2024-01-21 16:59:25.993  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x680ae2fffec91ea4 = false
              2024-01-21 16:59:26.015  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x680ae2fffec91ea4 = 0
              2024-01-21 16:59:26.024  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x588e81fffe2b8762 = false
              2024-01-21 16:59:26.030  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x588e81fffe2b8762 = 0
              2024-01-21 16:59:26.038  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x680ae2fffe924d57 = false
              2024-01-21 16:59:26.044  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x680ae2fffe924d57 = 0
              2024-01-21 16:59:26.063  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d00045eb708 = false
              2024-01-21 16:59:26.071  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d00045eb708 = 0
              2024-01-21 16:59:26.077  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d0002a71e25 = false
              2024-01-21 16:59:26.082  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d0002a71e25 = 0
              2024-01-21 16:59:26.088  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c794764 = false
              2024-01-21 16:59:26.092  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c794764 = 0
              2024-01-21 16:59:26.096  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c7946a1 = false
              2024-01-21 16:59:26.103  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7946a1 = 0
              2024-01-21 16:59:26.109  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d00045f8d3d = false
              2024-01-21 16:59:26.112  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d00045f8d3d = 0
              2024-01-21 16:59:26.125  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d0004597653 = false
              2024-01-21 16:59:26.129  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d0004597653 = 0
              2024-01-21 16:59:26.134  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x842e14fffe768d41 = false
              2024-01-21 16:59:26.139  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x842e14fffe768d41 = 0
              2024-01-21 16:59:26.144  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xbc33acfffe2ab392 = false
              2024-01-21 16:59:26.147  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xbc33acfffe2ab392 = 0
              2024-01-21 16:59:26.155  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c7b5255 = false
              2024-01-21 16:59:26.161  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b5255 = 0
              2024-01-21 16:59:26.167  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c7b51f7 = false
              2024-01-21 16:59:26.173  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b51f7 = 0
              2024-01-21 16:59:26.182  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c78b7ba = false
              2024-01-21 16:59:26.186  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c78b7ba = 0
              2024-01-21 16:59:26.197  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d000461da61 = false
              2024-01-21 16:59:26.201  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d000461da61 = 0
              2024-01-21 16:59:26.206  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef87315 = false
              2024-01-21 16:59:26.211  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87315 = 0
              2024-01-21 16:59:26.216  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef8731e = false
              2024-01-21 16:59:26.220  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef8731e = 0
              2024-01-21 16:59:26.225  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef84d2d = false
              2024-01-21 16:59:26.229  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef84d2d = 0
              2024-01-21 16:59:26.234  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef87b6a = false
              2024-01-21 16:59:26.238  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87b6a = 0
              2024-01-21 16:59:26.246  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef853ac = false
              2024-01-21 16:59:26.249  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef853ac = 0
              2024-01-21 16:59:26.257  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cd15fffefe9ca8 = false
              2024-01-21 16:59:26.261  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cd15fffefe9ca8 = 0
              2024-01-21 16:59:26.268  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xa4c138c66404899e = false
              2024-01-21 16:59:26.271  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xa4c138c66404899e = 0
              2024-01-21 16:59:31.550  - warn: zigbee.0 (6066) Failed to stop zigbee during startup
              2024-01-21 16:59:31.682  - error: zigbee.0 (6066) Objects database error: write EPIPE
              2024-01-21 16:59:31.751  - info: zigbee.0 (6066) terminating
              2024-01-21 16:59:31.752  - debug: zigbee.0 (6066) Plugin sentry destroyed
              2024-01-21 16:59:31.753  - info: zigbee.0 (6066) Terminated (NO_ERROR): Without reason
              2024-01-21 16:59:31.753  - info: zigbee.0 (6066) terminating
              2024-01-21 16:59:32.687  - info: zigbee.0 (6066) terminating with timeout
              2024-01-21 17:01:20.456  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1190
              2024-01-21 17:01:27.027  - debug: zigbee.0 (1190) Redis Objects: Use Redis connection: 127.0.0.1:9001
              2024-01-21 17:01:27.080  - debug: zigbee.0 (1190) Objects client ready ... initialize now
              2024-01-21 17:01:27.084  - debug: zigbee.0 (1190) Objects create System PubSub Client
              2024-01-21 17:01:27.086  - debug: zigbee.0 (1190) Objects create User PubSub Client
              2024-01-21 17:01:27.162  - debug: zigbee.0 (1190) Objects client initialize lua scripts
              2024-01-21 17:01:27.176  - debug: zigbee.0 (1190) Objects connected to redis: 127.0.0.1:9001
              2024-01-21 17:01:27.225  - debug: zigbee.0 (1190) Redis States: Use Redis connection: 127.0.0.1:9000
              2024-01-21 17:01:27.247  - debug: zigbee.0 (1190) States create System PubSub Client
              2024-01-21 17:01:27.248  - debug: zigbee.0 (1190) States create User PubSub Client
              2024-01-21 17:01:27.339  - debug: zigbee.0 (1190) States connected to redis: 127.0.0.1:9000
              2024-01-21 17:01:27.397  - debug: zigbee.0 (1190) Plugin sentry Initialize Plugin (enabled=true)
              2024-01-21 17:01:28.242  - info: zigbee.0 (1190) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
              2024-01-21 17:01:28.283  - debug: zigbee.0 (1190) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
              2024-01-21 17:01:28.387  - info: zigbee.0 (1190) delete old Backup files. keep only last 10
              2024-01-21 17:01:28.390  - info: zigbee.0 (1190) Starting Zigbee  npm ...
              2024-01-21 17:01:28.468  - debug: zigbee.0 (1190) Starting zigbee-herdsman...
              2024-01-21 17:01:29.117  - error: zigbee.0 (1190) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
              2024-01-21 17:01:29.118  - error: zigbee.0 (1190) Failed to start Zigbee
              2024-01-21 17:01:29.118  - error: zigbee.0 (1190) Error herdsman start
              2024-01-21 17:01:29.123  - info: zigbee.0 (1190) Installed Version: iobroker.zigbee@1.10.1
              2024-01-21 17:01:29.643  - debug: zigbee.0 (1190) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_21-17_01_28.tar.gz success
              2024-01-21 17:01:39.122  - info: zigbee.0 (1190) Try to reconnect. 1 attempts left
              2024-01-21 17:01:39.123  - info: zigbee.0 (1190) Starting Zigbee  npm ...
              2024-01-21 17:01:39.128  - debug: zigbee.0 (1190) Starting zigbee-herdsman...
              2024-01-21 17:01:39.139  - error: zigbee.0 (1190) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
              2024-01-21 17:01:39.140  - error: zigbee.0 (1190) Failed to start Zigbee
              2024-01-21 17:01:39.141  - error: zigbee.0 (1190) Error herdsman start
              2024-01-21 17:01:39.149  - info: zigbee.0 (1190) Installed Version: iobroker.zigbee@1.10.1
              2024-01-21 17:04:17.656  - error: zigbee.0 (1190) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
              2024-01-21 17:04:18.043  - info: zigbee.0 (1190) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"8eb6f719a99ded11ad35dca5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"}]
              • T Tapdance 0
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                PI
                /home/PI
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:           104M          0B        104M
                         3793 M total memory
                         1606 M used memory
                         1858 M free memory
                           40 M buffer memory
                          363 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                651M    /var/
                194M    /var/lib
                185M    /var/cache
                172M    /var/cache/apt
                171M    /var/log
                USB-Devices by-id:
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                     18.13.0+dfsg1-1 500
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     7.1.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        5503
                States:         4905
                Pending Updates: 0
                Da:
                das eintragen:
                  Da:
                  das eintragen:
                  Tapdance 0
                  geht leider nicht da der Adapter nicht startet.
                  Bekomme immer folgende Meldung wenn ich darauf gehe.
                  You need save and run adapter before pairing!
                  T AsgothianA 2 Antworten Letzte Antwort
                  • T Tapdance 0
                    Tapdance 0
                    @tapdance-0
                    starte das System noch mal komplett neu mit
                    sudo reboot
                    • T Tapdance 0
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      Das ist normal. Du solltest trotzdem auf die Seite zum konfigurieren kommen um da Einstellungen zu machen.
                      A.
                      • AsgothianA Asgothian
                        A.
                        Tapdance 0
                        @asgothian
                        leider nicht
                        • T Tapdance 0
                          @asgothian
                          leider nicht
                          Tapdance 0
                          @tapdance-0
                          Neustart hat auch nichts gebracht
                          2024-01-21 17:16:30.300  - error: zigbee.0 (1190) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                          2024-01-21 17:16:30.544  - info: zigbee.0 (1190) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"8eb6f719a99ded11ad35dca5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"}]
                          2024-01-21 17:16:55.971  - error: zigbee.0 (1190) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                          2024-01-21 17:16:56.206  - info: zigbee.0 (1190) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"8eb6f719a99ded11ad35dca5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"}]
                          2024-01-21 17:18:59.211  - info: zigbee.0 (1190) cleaned everything up...
                          2024-01-21 17:18:59.251  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                          2024-01-21 17:18:59.762  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                          2024-01-21 17:19:00.770  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 1190
                          2024-01-21 17:18:59.315  - info: zigbee.0 (1190) Zigbee: disabling joining new devices.
                          2024-01-21 17:18:59.317  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d00044d8e0b = false
                          2024-01-21 17:18:59.332  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d00044d8e0b = 0
                          2024-01-21 17:18:59.344  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d000257bae7 = false
                          2024-01-21 17:18:59.360  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d000257bae7 = 0
                          2024-01-21 17:18:59.382  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d00045f7cee = false
                          2024-01-21 17:18:59.386  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d00045f7cee = 0
                          2024-01-21 17:18:59.392  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d0004521481 = false
                          2024-01-21 17:18:59.396  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d0004521481 = 0
                          2024-01-21 17:18:59.411  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d000461b53e = false
                          2024-01-21 17:18:59.429  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d000461b53e = 0
                          2024-01-21 17:18:59.435  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x680ae2fffec91ea4 = false
                          2024-01-21 17:18:59.438  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x680ae2fffec91ea4 = 0
                          2024-01-21 17:18:59.444  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x588e81fffe2b8762 = false
                          2024-01-21 17:18:59.455  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x588e81fffe2b8762 = 0
                          2024-01-21 17:18:59.463  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x680ae2fffe924d57 = false
                          2024-01-21 17:18:59.467  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x680ae2fffe924d57 = 0
                          2024-01-21 17:18:59.474  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d00045eb708 = false
                          2024-01-21 17:18:59.479  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d00045eb708 = 0
                          2024-01-21 17:18:59.490  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d0002a71e25 = false
                          2024-01-21 17:18:59.494  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d0002a71e25 = 0
                          2024-01-21 17:18:59.499  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c794764 = false
                          2024-01-21 17:18:59.502  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c794764 = 0
                          2024-01-21 17:18:59.507  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c7946a1 = false
                          2024-01-21 17:18:59.510  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7946a1 = 0
                          2024-01-21 17:18:59.515  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d00045f8d3d = false
                          2024-01-21 17:18:59.518  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d00045f8d3d = 0
                          2024-01-21 17:18:59.523  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d0004597653 = false
                          2024-01-21 17:18:59.528  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d0004597653 = 0
                          2024-01-21 17:18:59.539  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x842e14fffe768d41 = false
                          2024-01-21 17:18:59.542  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x842e14fffe768d41 = 0
                          2024-01-21 17:18:59.549  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xbc33acfffe2ab392 = false
                          2024-01-21 17:18:59.555  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xbc33acfffe2ab392 = 0
                          2024-01-21 17:18:59.562  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c7b5255 = false
                          2024-01-21 17:18:59.565  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b5255 = 0
                          2024-01-21 17:18:59.570  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c7b51f7 = false
                          2024-01-21 17:18:59.574  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b51f7 = 0
                          2024-01-21 17:18:59.579  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c78b7ba = false
                          2024-01-21 17:18:59.583  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c78b7ba = 0
                          2024-01-21 17:18:59.588  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d000461da61 = false
                          2024-01-21 17:18:59.591  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d000461da61 = 0
                          2024-01-21 17:18:59.595  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef87315 = false
                          2024-01-21 17:18:59.599  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87315 = 0
                          2024-01-21 17:18:59.604  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef8731e = false
                          2024-01-21 17:18:59.608  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef8731e = 0
                          2024-01-21 17:18:59.613  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef84d2d = false
                          2024-01-21 17:18:59.623  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef84d2d = 0
                          2024-01-21 17:18:59.637  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef87b6a = false
                          2024-01-21 17:18:59.652  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87b6a = 0
                          2024-01-21 17:18:59.655  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef853ac = false
                          2024-01-21 17:18:59.670  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef853ac = 0
                          2024-01-21 17:18:59.689  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cd15fffefe9ca8 = false
                          2024-01-21 17:18:59.692  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cd15fffefe9ca8 = 0
                          2024-01-21 17:18:59.696  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xa4c138c66404899e = false
                          2024-01-21 17:18:59.700  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xa4c138c66404899e = 0
                          2024-01-21 17:19:03.382  - warn: zigbee.0 (1190) Failed to stop zigbee during startup
                          2024-01-21 17:19:03.714  - warn: host.raspberrypi instance system.adapter.zigbee.0 terminated due to SIGTERM
                          2024-01-21 17:19:03.714  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code null ()
                          2024-01-21 17:20:50.131  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1208
                          2024-01-21 17:20:57.122  - debug: zigbee.0 (1208) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2024-01-21 17:20:57.175  - debug: zigbee.0 (1208) Objects client ready ... initialize now
                          2024-01-21 17:20:57.178  - debug: zigbee.0 (1208) Objects create System PubSub Client
                          2024-01-21 17:20:57.179  - debug: zigbee.0 (1208) Objects create User PubSub Client
                          2024-01-21 17:20:57.241  - debug: zigbee.0 (1208) Objects client initialize lua scripts
                          2024-01-21 17:20:57.260  - debug: zigbee.0 (1208) Objects connected to redis: 127.0.0.1:9001
                          2024-01-21 17:20:57.320  - debug: zigbee.0 (1208) Redis States: Use Redis connection: 127.0.0.1:9000
                          2024-01-21 17:20:57.346  - debug: zigbee.0 (1208) States create System PubSub Client
                          2024-01-21 17:20:57.348  - debug: zigbee.0 (1208) States create User PubSub Client
                          2024-01-21 17:20:57.441  - debug: zigbee.0 (1208) States connected to redis: 127.0.0.1:9000
                          2024-01-21 17:20:57.535  - debug: zigbee.0 (1208) Plugin sentry Initialize Plugin (enabled=true)
                          2024-01-21 17:20:58.509  - info: zigbee.0 (1208) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                          2024-01-21 17:20:58.553  - debug: zigbee.0 (1208) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
                          2024-01-21 17:20:58.661  - info: zigbee.0 (1208) delete old Backup files. keep only last 10
                          2024-01-21 17:20:58.663  - info: zigbee.0 (1208) Starting Zigbee  npm ...
                          2024-01-21 17:20:58.724  - debug: zigbee.0 (1208) Starting zigbee-herdsman...
                          2024-01-21 17:21:00.498  - error: zigbee.0 (1208) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
                          2024-01-21 17:21:00.499  - error: zigbee.0 (1208) Failed to start Zigbee
                          2024-01-21 17:21:00.499  - error: zigbee.0 (1208) Error herdsman start
                          2024-01-21 17:21:00.507  - info: zigbee.0 (1208) Installed Version: iobroker.zigbee@1.10.1
                          2024-01-21 17:21:01.087  - debug: zigbee.0 (1208) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_21-17_20_58.tar.gz success
                          2024-01-21 17:21:10.505  - info: zigbee.0 (1208) Try to reconnect. 1 attempts left
                          2024-01-21 17:21:10.506  - info: zigbee.0 (1208) Starting Zigbee  npm ...
                          2024-01-21 17:21:10.512  - debug: zigbee.0 (1208) Starting zigbee-herdsman...
                          2024-01-21 17:21:10.524  - error: zigbee.0 (1208) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
                          2024-01-21 17:21:10.525  - error: zigbee.0 (1208) Failed to start Zigbee
                          2024-01-21 17:21:10.526  - error: zigbee.0 (1208) Error herdsman start
                          2024-01-21 17:21:10.535  - info: zigbee.0 (1208) Installed Version: iobroker.zigbee@1.10.1
                          2024-01-21 17:25:54.886  - error: zigbee.0 (1208) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                          2024-01-21 17:25:55.156  - info: zigbee.0 (1208) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"8eb6f719a99ded11ad35dca5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"}]
                          • T Tapdance 0
                            @tapdance-0
                            Du hast da immer noch den alten Stick in den Einstellungen. Das muss durch den aktuellen Link ersetzt werden.
                            Edit:
                            Okay, hier scheint es nun drin zu sein:
                              Da:
                              das eintragen:
                              /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0
                              Tapdance 0
                              habe den Punkt zum eintragen des Pfades gefunden. Der wird nur angezeigt wenn man über die Instanz in Menü geht. Pfad ist eingetragen Adapter ist grün, aber leider funktioniert noch nichts.
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                               Static hostname: raspberrypi
                                     Icon name: computer
                                        Kernel: Linux 6.1.0-rpi7-rpi-v8
                                  Architecture: arm64
                              Model           : Raspberry Pi 4 Model B Rev 1.1
                              Docker          : false
                              Virtualization  : none
                              Kernel          : aarch64
                              Userland        : arm64
                              Systemuptime and Load:
                               17:39:43 up 6 min,  3 users,  load average: 0.52, 0.90, 0.57
                              CPU threads: 4
                              *** RASPBERRY THROTTLING ***
                              Current issues:
                              Previously detected issues:
                              *** Time and Time Zones ***
                                             Local time: Sun 2024-01-21 17:39:43 CET
                                         Universal time: Sun 2024-01-21 16:39:43 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              *** User and Groups ***
                              PI
                              /home/PI
                              PI adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                              *** X-Server-Setup ***
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              Boot Target:    multi-user.target
                              *** MEMORY ***
                              Mem:            4.0G        1.6G        2.0G        1.3M        420M        2.3G
                              Swap:           104M          0B        104M
                              Total:          4.1G        1.6G        2.1G
                                       3793 M total memory
                                       1571 M used memory
                                       1603 M active memory
                                        166 M inactive memory
                                       1897 M free memory
                                         40 M buffer memory
                                        359 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FAILED SERVICES ***
                              0 loaded units listed.
                              *** FILESYSTEM ***
                              udev           devtmpfs  1.6G     0  1.6G   0% /dev
                              tmpfs          tmpfs     380M  1.2M  379M   1% /run
                              tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
                              tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                              /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
                              tmpfs          tmpfs     380M   32K  380M   1% /run/user/1000
                              [Sun Jan 21 17:32:52 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:64:62:CC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9515910b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                              [Sun Jan 21 17:32:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                              [Sun Jan 21 17:32:59 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                              TARGET           SOURCE         FSTYPE OPTIONS
                              /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                              `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                              /var:
                              667M    /var/
                              194M    /var/lib
                              187M    /var/log
                              186M    /var/log/journal/67fa5cc7176343b98d5ef1e5e5a27de6
                              Archived and active journals take up 185.5M in the file system.
                              /opt/iobroker/backups:
                              4.0K    /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              368M    /opt/iobroker/iobroker-data/
                              270M    /opt/iobroker/iobroker-data/files
                              78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                              73M     /opt/iobroker/iobroker-data/backup-objects
                              67M     /opt/iobroker/iobroker-data/files/javascript.admin
                              24M     /opt/iobroker/iobroker-data/objects.jsonl
                              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                              8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
                              7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
                              7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
                              USB-Devices by-id:
                              *** NodeJS-Installation ***
                              /usr/bin/node           v18.19.0
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
                              /usr/bin/corepack       0.22.0
                              nodejs:
                                Installed: 18.19.0-1nodesource1
                                Candidate: 18.19.0-1nodesource1
                                Version table:
                                   18.19.0+dfsg-6~deb12u1 500
                                      500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                               *** 18.19.0-1nodesource1 1001
                                      500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                                   18.18.2-1nodesource1 1001
                                   18.18.1-1nodesource1 1001
                                   18.18.0-1nodesource1 1001
                                   18.17.1-1nodesource1 1001
                                   18.17.0-1nodesource1 1001
                                   18.16.1-1nodesource1 1001
                                   18.16.0-1nodesource1 1001
                                   18.15.0-1nodesource1 1001
                                   18.14.2-1nodesource1 1001
                                   18.14.1-1nodesource1 1001
                                   18.14.0-1nodesource1 1001
                                   18.13.0+dfsg1-1 500
                                      500 http://deb.debian.org/debian bookworm/main arm64 Packages
                                   18.13.0-1nodesource1 1001
                                   18.12.0-1nodesource1 1001
                                   18.11.0-1nodesource1 1001
                                   18.10.0-1nodesource1 1001
                                   18.9.1-1nodesource1 1001
                                   18.9.0-1nodesource1 1001
                                   18.8.0-1nodesource1 1001
                                   18.7.0-1nodesource1 1001
                                   18.6.0-1nodesource1 1001
                                   18.5.0-1nodesource1 1001
                                   18.4.0-1nodesource1 1001
                                   18.3.0-1nodesource1 1001
                                   18.2.0-1nodesource1 1001
                                   18.1.0-1nodesource1 1001
                                   18.0.0-1nodesource1 1001
                              No problems detected
                              Errors in npm tree:
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Core adapters versions
                              admin:          6.12.0
                              javascript:     7.1.6
                              Adapters from github:   0
                              Adapter State
                              + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
                              + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                              + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                              + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                              + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                              + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                              + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                                system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
                                system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
                                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
                                system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
                              + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                              + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
                              + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
                              + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 192.168.2.4, run as: admin
                              + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                                system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                                system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                                system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
                              + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
                              + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
                              + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                              + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0
                              + instance is alive
                              ioBroker-Repositories
                              Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                              Stable (default): http://download.iobroker.net/sources-dist.json
                              Installed ioBroker-Instances
                              Adapter    "admin"        : 6.12.0   , installed 6.12.0
                              Adapter    "alarm"        : 3.6.0    , installed 3.6.0
                              Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                              Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                              Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                              Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                              Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                              Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                              Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                              Adapter    "info"         : 2.0.0    , installed 2.0.0
                              Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                              Controller "js-controller": 5.0.17   , installed 5.0.17
                              Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                              Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                              Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                              Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                              Adapter    "synology"     : 3.0.1    , installed 3.0.1
                              Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                              Adapter    "vis"          : 1.5.4    , installed 1.5.4
                              Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                              Adapter    "web"          : 6.1.10   , installed 6.1.10
                              Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                              Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                              Adapter    "ws"           : 2.5.8    , installed 2.5.8
                              Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                              Objects and States
                              Objects:        5503
                              States:         4905
                              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                              Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                              Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                              Pending Updates: 0
                              *** Listening Ports ***
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12153      804/sshd: /usr/sbin
                              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16485      794/cupsd
                              tcp        0      0 192.168.2.4:2001        0.0.0.0:*               LISTEN      1001       19586      1091/io.hm-rpc.0
                              tcp        0      0 192.168.2.4:2010        0.0.0.0:*               LISTEN      1001       16840      1092/io.hm-rpc.1
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16343      795/iobroker.js-con
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18476      795/iobroker.js-con
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18056      1150/io.sonoff.0
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          12155      804/sshd: /usr/sbin
                              tcp6       0      0 :::39615                :::*                    LISTEN      1001       19369      1962/io.yahka.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20340      1882/io.web.0
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17851      969/io.admin.0
                              tcp6       0      0 :::8088                 :::*                    LISTEN      1001       17327      1565/io.terminal.0
                              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16484      794/cupsd
                              udp        0      0 0.0.0.0:36784           0.0.0.0:*                           104        16424      573/avahi-daemon: r
                              udp        0      0 0.0.0.0:34788           0.0.0.0:*                           1001       20998      1325/io.broadlink2.
                              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16262      844/cups-browsed
                              udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       20995      1325/io.broadlink2.
                              udp        0      0 0.0.0.0:58383           0.0.0.0:*                           1001       22993      1325/io.broadlink2.
                              udp        0      0 192.168.2.4:5353        0.0.0.0:*                           1001       18718      1181/io.tr-064.0
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        16422      573/avahi-daemon: r
                              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       18034      1116/io.shelly.0
                              udp6       0      0 fe80::67d1:e1cb:7ef:546 :::*                                0          12279      733/NetworkManager
                              udp6       0      0 :::50277                :::*                                104        16425      573/avahi-daemon: r
                              udp6       0      0 :::5353                 :::*                                104        16423      573/avahi-daemon: r
                              2024-01-21 17:40:28.300  - debug: zigbee.0 (1229) DeviceAvailability:Non-pingable device 0x00158d000461da61 lumi.sensor_magnet was last seen '34744106.67' seconds ago.
                              2024-01-21 17:40:28.329  - debug: zigbee.0 (1229) DeviceAvailability:Non-pingable device 0x04cd15fffefe9ca8 ZBMINIL2 was last seen '5227.093' seconds ago.
                              2024-01-21 17:40:28.907  - warn: shelly.0 (1116) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
                              2024-01-21 17:40:37.805  - warn: sonoff.0 (1150) Client [Pavillon Beleuchtung] has invalid password or username
                              2024-01-21 17:40:38.241  - warn: shelly.0 (1116) State value to set for "shelly.0.SHDM-1#D3E918#1.temperatureF" has value "102.12" greater than max "100"
                              2024-01-21 17:40:38.726  - warn: sonoff.0 (1150) Client [Pool Beleuchtung] has invalid password or username
                              2024-01-21 17:40:38.782  - warn: sonoff.0 (1150) Client [Muschel Terrasse] has invalid password or username
                              2024-01-21 17:40:38.794  - warn: shelly.0 (1116) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                              2024-01-21 17:40:38.899  - warn: shelly.0 (1116) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                              2024-01-21 17:40:40.448  - warn: sonoff.0 (1150) Client [Pool Pumpe] has invalid password or username
                              2024-01-21 17:40:43.820  - warn: sonoff.0 (1150) Client [Taster-Schlafzimmer-Bett-L] has invalid password or username
                              2024-01-21 17:40:44.160  - warn: shelly.0 (1116) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
                              2024-01-21 17:40:44.159  - warn: sonoff.0 (1150) Client [Wohnzimmer-Vitrine] has invalid password or username
                              2024-01-21 17:40:44.733  - warn: sonoff.0 (1150) Client [PC-Buero] has invalid password or username
                              2024-01-21 17:40:51.475  - warn: shelly.0 (1116) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                              2024-01-21 17:40:51.688  - warn: shelly.0 (1116) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                              2024-01-21 17:40:51.753  - warn: shelly.0 (1116) State value to set for "shelly.0.SHDM-2#8CAAB54C4B57#1.temperatureF" has value "106.96" greater than max "100"
                              2024-01-21 17:40:55.957  - warn: shelly.0 (1116) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
                              2024-01-21 17:41:03.864  - warn: sonoff.0 (1150) Client [Pavillon Beleuchtung] has invalid password or username
                              2024-01-21 17:41:04.546  - warn: sonoff.0 (1150) Client [Pool Beleuchtung] has invalid password or username
                              2024-01-21 17:41:05.691  - warn: shelly.0 (1116) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                              2024-01-21 17:41:05.875  - warn: shelly.0 (1116) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                              2024-01-21 17:41:06.282  - warn: sonoff.0 (1150) Client [Pool Pumpe] has invalid password or username
                              2024-01-21 17:41:07.007  - warn: shelly.0 (1116) State value to set for "shelly.0.SHDM-2#8CAAB54C4B57#1.temperatureF" has value "107.08" greater than max "100"
                              2024-01-21 17:41:07.280  - warn: sonoff.0 (1150) Client [Muschel Terrasse] has invalid password or username
                              iob diag has finished.
                              Press any key for a summary
                              PI@raspberrypi:~ $ iob logs | grep zigbee
                              2024-01-21 17:34:16.171 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1229
                              2024-01-21 17:34:22.326 - debug: zigbee.0 (1229) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              2024-01-21 17:34:22.397 - debug: zigbee.0 (1229) Objects client ready ... initialize now
                              2024-01-21 17:34:22.400 - debug: zigbee.0 (1229) Objects create System PubSub Client
                              2024-01-21 17:34:22.402 - debug: zigbee.0 (1229) Objects create User PubSub Client
                              2024-01-21 17:34:22.481 - debug: zigbee.0 (1229) Objects client initialize lua scripts
                              2024-01-21 17:34:22.495 - debug: zigbee.0 (1229) Objects connected to redis: 127.0.0.1:9001
                              2024-01-21 17:34:22.546 - debug: zigbee.0 (1229) Redis States: Use Redis connection: 127.0.0.1:9000
                              2024-01-21 17:34:22.625 - debug: zigbee.0 (1229) States create System PubSub Client
                              2024-01-21 17:34:22.627 - debug: zigbee.0 (1229) States create User PubSub Client
                              2024-01-21 17:34:22.711 - debug: zigbee.0 (1229) States connected to redis: 127.0.0.1:9000
                              2024-01-21 17:34:22.780 - debug: zigbee.0 (1229) Plugin sentry Initialize Plugin (enabled=true)
                              2024-01-21 17:34:23.636 - info: zigbee.0 (1229) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                              2024-01-21 17:34:23.678 - debug: zigbee.0 (1229) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
                              2024-01-21 17:34:23.787 - info: zigbee.0 (1229) delete old Backup files. keep only last 10
                              2024-01-21 17:34:23.790 - info: zigbee.0 (1229) Starting Zigbee npm ...
                              2024-01-21 17:34:23.867 - debug: zigbee.0 (1229) Starting zigbee-herdsman...
                              2024-01-21 17:34:24.431 - info: zigbee.0 (1229) Installed Version: iobroker.zigbee@1.10.1
                              2024-01-21 17:34:25.075 - debug: zigbee.0 (1229) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_21-17_34_23.tar.gz success
                              2024-01-21 17:34:28.117 - debug: zigbee.0 (1229) zigbee-herdsman started
                              2024-01-21 17:34:28.120 - info: zigbee.0 (1229) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
                              2024-01-21 17:34:28.129 - debug: zigbee.0 (1229) Zigbee network parameters: panID=6754 channel=11 extendedPanID=dddddddddddddddd
                              2024-01-21 17:34:28.130 - info: zigbee.0 (1229) Disable LED
                              2024-01-21 17:34:28.131 - info: zigbee.0 (1229) Unable to disable LED, unsupported function.
                              2024-01-21 17:34:28.151 - info: zigbee.0 (1229) --> transmitPower : normal
                              2024-01-21 17:34:28.194 - info: zigbee.0 (1229) Currently 28 devices are joined:
                              2024-01-21 17:34:28.195 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00044d8e0b = true
                              2024-01-21 17:34:28.203 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00044d8e0b = 10
                              2024-01-21 17:34:28.211 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d000257bae7 = true
                              2024-01-21 17:34:28.218 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d000257bae7 = 10
                              2024-01-21 17:34:28.221 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00045f7cee = true
                              2024-01-21 17:34:28.225 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00045f7cee = 10
                              2024-01-21 17:34:28.228 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d0004521481 = true
                              2024-01-21 17:34:28.232 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d0004521481 = 10
                              2024-01-21 17:34:28.235 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d000461b53e = true
                              2024-01-21 17:34:28.239 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d000461b53e = 10
                              2024-01-21 17:34:28.243 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x680ae2fffec91ea4 = true
                              2024-01-21 17:34:28.247 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x680ae2fffec91ea4 = 10
                              2024-01-21 17:34:28.250 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x588e81fffe2b8762 = true
                              2024-01-21 17:34:28.254 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x588e81fffe2b8762 = 10
                              2024-01-21 17:34:28.258 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00045eb708 = true
                              2024-01-21 17:34:28.261 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00045eb708 = 10
                              2024-01-21 17:34:28.265 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d0002a71e25 = true
                              2024-01-21 17:34:28.269 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d0002a71e25 = 10
                              2024-01-21 17:34:28.273 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c794764 = true
                              2024-01-21 17:34:28.277 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c794764 = 10
                              2024-01-21 17:34:28.280 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c7946a1 = true
                              2024-01-21 17:34:28.284 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7946a1 = 10
                              2024-01-21 17:34:28.288 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00045f8d3d = true
                              2024-01-21 17:34:28.291 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00045f8d3d = 10
                              2024-01-21 17:34:28.295 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d0004597653 = true
                              2024-01-21 17:34:28.299 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d0004597653 = 10
                              2024-01-21 17:34:28.314 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0xbc33acfffe2ab392 = true
                              2024-01-21 17:34:28.318 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0xbc33acfffe2ab392 = 10
                              2024-01-21 17:34:28.322 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c7b5255 = true
                              2024-01-21 17:34:28.326 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b5255 = 10
                              2024-01-21 17:34:28.330 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c7b51f7 = true
                              2024-01-21 17:34:28.334 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b51f7 = 10
                              2024-01-21 17:34:28.338 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c78b7ba = true
                              2024-01-21 17:34:28.341 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c78b7ba = 10
                              2024-01-21 17:34:28.345 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d000461da61 = true
                              2024-01-21 17:34:28.349 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d000461da61 = 10
                              2024-01-21 17:34:28.354 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cd15fffefe9ca8 = true
                              2024-01-21 17:34:28.358 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cd15fffefe9ca8 = 10
                              grep: (standard input): binary file matches
                              code_text
                              • T Tapdance 0
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : arm64
                                CPU threads: 4
                                Current issues:
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                PI
                                /home/PI
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:           104M          0B        104M
                                         3793 M total memory
                                         1571 M used memory
                                         1897 M free memory
                                           40 M buffer memory
                                          359 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /dev/mmcblk0p2 ext4       28G  7.1G   20G  27% /
                                /var:
                                667M    /var/
                                194M    /var/lib
                                187M    /var/log
                                USB-Devices by-id:
                                /usr/bin/nodejs         v18.19.0
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
                                nodejs:
                                  Version table:
                                     18.13.0+dfsg1-1 500
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.12.0
                                javascript:     7.1.6
                                Adapter State
                                + instance is alive
                                Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                                Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                                Objects and States
                                Objects:        5503
                                States:         4905
                                Reading package lists...
                                Pending Updates: 0
                                code_text
                                @tapdance-0 sagte in Ziggbe sendet nicht mehr an empfängt aber noch Daten:
                                Läuft doch.
                                • T Tapdance 0
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : arm64
                                  CPU threads: 4
                                  Current issues:
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  PI
                                  /home/PI
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:           104M          0B        104M
                                           3793 M total memory
                                           1571 M used memory
                                           1897 M free memory
                                             40 M buffer memory
                                            359 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /var:
                                  667M    /var/
                                  194M    /var/lib
                                  187M    /var/log
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.2.3
                                  /usr/bin/npx            10.2.3
                                  nodejs:
                                    Version table:
                                       18.13.0+dfsg1-1 500
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.12.0
                                  javascript:     7.1.6
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        5503
                                  States:         4905
                                  Pending Updates: 0
                                  code_text
                                  firmware version: "revision":20210708
                                  Ist allerdings steinalt. Würde ich aktualisieren.
                                    Läuft doch.
                                    Tapdance 0
                                    Aber kein Gerät reagiert, selbst die nicht die vorher noch funktioniert haben.
                                    • T Tapdance 0
                                      Tapdance 0
                                      @tapdance-0
                                      PI@raspberrypi:~ $ ^C
                                      2024-01-21 17:36:23.926  - debug: zigbee.0 (1229) Failed to execute LQI for '0xf4b3b1fffef8731e'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n    at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:63:23)\n    at request (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:582:47)\n    at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:604:28\n    at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20)\n    at ZigbeeController.getMap (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:721:30)"
                                      PI@raspberrypi:~ $
                                        Tapdance 0
                                        Ok und wie mache ich das mit der Firmware Version?
                                        Jetzt bin ich wieder bei meinem Ursprungsproblem alles hat sich eingependelt und läuft außer.
                                        bei "MOES ZigBee Mini Smart" da kann ich keine Daten mehr senden kann nur empfangen.
                                        Ich kann im IO Broker aber den Status der Geräte sehen der Empfang der daten funktioniert also. Beispiel ich ändere am Schalter manuell die Helligkeit dann sehe ich im IOBrocker die aktuelle Prozentzahl der Helligkeit. Andere Zigbee Komponenten wie meine Bewegungsmelder von Acera scheinen nicht betroffen zu sein.
                                        • T Tapdance 0
                                          @tapdance-0
                                          https://www.zigbee2mqtt.io/guide/adapters/flashing/flashing_via_cc2538-bsl.html
