  4. esphome - wird dies noch gepflegt?
44 Beiträge 9 Kommentatoren 9.0k Aufrufe 12 Beobachtet
  • R Rushmed
    @thomas-braun Ich hatte doch hier schon EXTERNALLY-MANAGED entfernt.
    Damit kam ich ja zu:
    pi@Smartazamba:~ $ iob add esphome --host Smartazamba --debug
    NPM version: 9.6.7
    Installing iobroker.esphome@0.2.4... (System call)
    npm ERR! code 127
    npm ERR! path /opt/iobroker/node_modules/iobroker.esphome
    npm ERR! command failed
    npm ERR! command sh -c npip install
    npm ERR! sh: 1: npip: Permission denied
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-07-28T08_19_07_068Z-debug-0.log
    host.Smartazamba Cannot install iobroker.esphome@0.2.4: 127
    Davor war die Ausgabe folgende:
    NPM version: 9.6.7
    npm ERR! code 1
    npm ERR! No python_modules directory; installing pip locally if needed.
    npm ERR! pip 23.0.1 from /usr/lib/python3/dist-packages/pip (python 3.11)
    npm ERR! error: externally-managed-environment
    npm ERR!
    npm ERR! × This environment is externally managed
    npm ERR! ╰─> To install Python packages system-wide, try apt install
    npm ERR!     python3-xyz, where xyz is the package you are trying to
    npm ERR!     install.
    npm ERR!
    npm ERR!     If you wish to install a non-Debian-packaged Python package,
    npm ERR!     create a virtual environment using python3 -m venv path/to/venv.
    npm ERR!     Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
    npm ERR!     sure you have python3-full installed.
    npm ERR!
    npm ERR!     If you wish to install a non-Debian packaged Python application,
    npm ERR!     it may be easiest to use pipx install xyz, which will manage a
    npm ERR!     virtual environment for you. Make sure you have pipx installed.
    npm ERR!
    npm ERR!     See /usr/share/doc/python3.11/README.venv for more information.
    npm ERR!
    npm ERR! note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
    npm ERR! hint: See PEP 668 for the detailed specification.
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-07-28T08_03_31_442Z-debug-0.log
    @rushmed
    Ja, dann war das mit nopy der richtige nächste Schritt.
      andreas_n
      Wenn es noch wichtig ist....
      Es ist eine neue Version (Zur Zeit noch Beta) herausgekommen.
      Diese Version hat Module aus dem Internet geladen sodass alles wieder funktioniert. (Problem mit PlatformIO)
      Besten Dank @Dutchman
      Eines ist mir noch aufgefallen, was zwar die Funktion nicht beeinträchtigt aber unschön ist.
      Im Log finde ich viele Einträge, dass die Verbindung zu ioBroker mehrfach aufgebaut und einzeln abgebaut werden. (Dies ist neu - wird wohl am Beta-Stand liegen . oder?)
      [16:42:38][C][wifi:389]:   Signal strength: -49 dB ▂▄▆█
      [16:42:38][C][wifi:393]:   Channel: 5
      [16:42:38][C][wifi:394]:   Subnet: 255.255.255.0
      [16:42:38][C][wifi:395]:   Gateway: 192.168.1.1
      [16:42:38][C][wifi:396]:   DNS1: 192.168.1.1
      [16:42:38][C][wifi:397]:   DNS2: 0.0.0.0
      [16:42:38][D][api.connection:1050]: ESPHome Logs 2023.10.6 (192.168.1.95): Connected successfully
      [16:42:38][C][logger:416]: Logger:
      [16:42:38][C][logger:417]:   Level: DEBUG
      [16:42:38][C][logger:418]:   Log Baud Rate: 0
      [16:42:38][C][logger:420]:   Hardware UART: UART0
      [16:42:38][D][api:102]: Accepted 192.168.1.95
      [16:42:39][D][api:102]: Accepted 192.168.1.95
      [16:42:39][C][mdns:115]: mDNS:
      [16:42:39][C][mdns:116]:   Hostname: lifepo4-48vsolar1
      [16:42:39][C][ota:097]: Over-The-Air Updates:
      [16:42:39][C][ota:098]:   Address: lifepo4-48vsolar1.local:3232
      [16:42:39][C][ota:101]:   Using Password.
      [16:42:39][C][api:139]: API Server:
      [16:42:39][C][api:140]:   Address: lifepo4-48vsolar1.local:6053
      [16:42:39][C][api:142]:   Using noise encryption: YES
      [16:42:39][D][api.connection:1050]: ESPHome Logs 2023.10.6 (192.168.1.95): Connected successfully
      [16:42:39][W][component:214]: Component api took a long time for an operation (0.05 s).
      [16:42:39][W][component:215]: Components should block for at most 20-30ms.
      [16:42:40][W][api.connection:103]: ESPHome Logs 2023.10.6 (192.168.1.95): Connection closed
      [16:42:40][D][api:102]: Accepted 192.168.1.95
      [16:42:40][D][api.connection:1050]: ESPHome Logs 2023.10.6 (192.168.1.95): Connected successfully
      [16:42:40][W][component:214]: Component api took a long time for an operation (0.05 s).
      [16:42:40][W][component:215]: Components should block for at most 20-30ms.
      [16:42:41][D][api.connection:1050]: ESPHome Logs 2023.10.6 (192.168.1.95): Connected successfully
      [16:42:41][D][api:102]: Accepted 192.168.1.95
      [16:42:41][W][api.connection:103]: ESPHome Logs 2023.10.6 (192.168.1.95): Connection closed
      • W Offline
        W Offline
        WolfgangFB
        @andreas_n
        Ich haabe hier die 0.41 im Einsatz und bei der passiert das bei mir auch ständig. Komischerweise aber nur mit ESPs die ich mit der neuen Version erstellt habe. Ich habe hier ältere ESPs die seit Jahren durchlaufen, da tritt das komischerweise nicht auf.
        • W WolfgangFB
          @andreas_n
          andreas_n
          @wolfgangfb
          Bei mir ist es 0.5.0 Beta 8. (Läuft soweit aber ganz OK)
          • A andreas_n
            @wolfgangfb
            tobiasp
            ich wollte ESPHome installieren.
            pi@raspberrypi:~ $ iob add esphome --host raspberrypi --debug
            installiert ist es, aber soblad ich das Dashboard aktiviere wirde der Adapter Rot.
            Was mache ich falsch?
            • T tobiasp
              @tobiasp sagte in esphome - wird dies noch gepflegt?:
              Du zeigst kein Log davon.
              T 2 Antworten Letzte Antwort
                tobiasp
                stimmt sorry
                host.raspberrypi
                	2024-01-13 12:29:12.798	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                esphome.0
                	2024-01-13 12:29:12.393	info	terminating
                esphome.0
                	2024-01-13 12:29:11.711	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                esphome.0
                	2024-01-13 12:29:11.707	info	terminating
                esphome.0
                	2024-01-13 12:29:11.662	error	Exception-Code: MODULE_NOT_FOUND: Cannot find module '@mongodb-js/zstd-linux-arm-gnueabihf'Require stack:- /opt/iobroker/node_modules/@mongodb-js/zstd/index.js
                esphome.0
                	2024-01-13 12:29:11.661	error	Error: Cannot find module '@mongodb-js/zstd-linux-arm-gnueabihf'Require stack:- /opt/iobroker/node_modules/@mongodb-js/zstd/index.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Function.Module._load (node:internal/modules/cjs/loader:975:27) at Module.require (node:internal/modules/cjs/loader:1225:19) at require (node:internal/modules/helpers:177:18) at Object.<anonymous> (/opt/iobroker/node_modules/@mongodb-js/zstd/index.js:131:29) at Module._compile (node:internal/modules/cjs/loader:1356:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1414:10) at Module.load (node:internal/modules/cjs/loader:1197:32) at Function.Module._load (node:internal/modules/cjs/loader:1013:12) at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:202:29)
                esphome.0
                	2024-01-13 12:29:11.660	error	unhandled promise rejection: Cannot find module '@mongodb-js/zstd-linux-arm-gnueabihf'Require stack:- /opt/iobroker/node_modules/@mongodb-js/zstd/index.js
                esphome.0
                	2024-01-13 12:29:11.657	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                esphome.0
                	2024-01-13 12:29:11.267	info	[Error caught and send to Sentry, thank you collaborating!] error: Error: Cannot find module '@mongodb-js/zstd-linux-arm-gnueabihf'Require stack:- /opt/iobroker/node_modules/@mongodb-js/zstd/index.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Function.Module._load (node:internal/modules/cjs/loader:975:27) at Module.require (node:internal/modules/cjs/loader:1225:19) at require (node:internal/modules/helpers:177:18) at Object.<anonymous> (/opt/iobroker/node_modules/@mongodb-js/zstd/index.js:131:29) at Module._compile (node:internal/modules/cjs/loader:1356:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1414:10) at Module.load (node:internal/modules/cjs/loader:1197:32) at Function.Module._load (node:internal/modules/cjs/loader:1013:12) at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:202:29)
                esphome.0
                	2024-01-13 12:29:10.907	info	Native Integration of ESPHome Dashboard enabled
                esphome.0
                	2024-01-13 12:29:10.417	info	starting. Version 0.5.0-beta.8 in /opt/iobroker/node_modules/iobroker.esphome, node: v18.19.0, js-controller: 5.0.17
                • Thomas BraunT Online
                  @tobiasp
                  SuFu hätte das zutage gefördert:
                  https://forum.iobroker.net/topic/70320/esp-home-webinterface-wird-nicht-geladen/31
                    tobiasp
                    Oh muss mich verbessern habe mit npm i iobroker.esphome installiert, da der andere befehl nicht funktioniert hat
                    • T tobiasp
                      @tobiasp
                      Das macht man ja auch nicht mit npm...
                        @tobiasp
                        tobiasp
                        wie kann ich es sonst installieren?
                        • T tobiasp
                          @tobiasp
                          iobroker add ADAPTERNAME --host HOSTNAME --debug
                          ist der Standardbefehl um Adapter hinzuzufügen.
                            @tobiasp
                            tobiasp
                            i@raspberrypi:~ $ iobroker add esphome --host raspberrypi --debug
                            host.raspberrypi Unknown packetName esphome. Please install packages from outside the repository using npm!
                            • T tobiasp
                              @tobiasp
                              Dann bist hast nicht das beta-Repo aktiv.
                              Der Adapter ist noch nicht in einer stabilen Version veröffentlicht worden.
                              Davon abgesehen sagt
                              iob diag
                              was zu deinem System?
                                @tobiasp
                                iob diag
                                tobiasp
                                ====================== SUMMARY =======================
                                v.2023-10-10
                                Static hostname: raspberrypi
                                Icon name: computer
                                Operating System: Raspbian GNU/Linux 11 (bullseye)
                                Kernel: Linux 6.1.21-v7l+
                                Architecture: arm
                                Installation: native
                                Kernel: armv7l
                                Userland: armhf
                                Timezone: Europe/Berlin (CET, +0100)
                                User-ID: 1000
                                /home/iobroker/.diag.sh: line 469: [[: 1010
                                2037: syntax error in expression (error token is "2037")
                                X-Server: false
                                Boot Target: graphical.target
                                Pending OS-Updates: 0
                                Pending iob updates: 13
                                Nodejs-Installation: /usr/bin/nodejs v18.19.0
                                /usr/bin/node v18.19.0
                                /usr/bin/npm 10.2.3
                                /usr/bin/npx 10.2.3
                                /usr/bin/corepack 0.22.0
                                Recommended versions are nodejs 18.19.0 and npm 10.2.3
                                MEMORY:
                                total used free shared buff/cache available
                                Mem: 3.8G 2.1G 770M 35M 1.0G 1.6G
                                Swap: 99M 0B 99M
                                Total: 3.9G 2.1G 870M
                                Active iob-Instances: 39
                                Active repo(s): Beta (latest)
                                ioBroker Core: js-controller 5.0.17
                                admin 6.12.0
                                ioBroker Status: iobroker is running on this host.
                                Objects type: jsonl
                                States type: redis
                                • system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 192.168.2.130, run as: admin
                                • system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                • system.adapter.web.1 : web : raspberrypi - enabled, port: 20002, bind: 0.0.0.0, run as: admin
                                Objects: 20192
                                States: 15783
                                Size of iob-Database:
                                43M /opt/iobroker/iobroker-data/objects.jsonl
                                4.1M /opt/iobroker/iobroker-data/states.jsonl
                                =================== END OF SUMMARY ==
                                • T tobiasp
                                  v.2023-10-10
                                  Icon name: computer
                                  Architecture: arm
                                  Kernel: armv7l
                                  Userland: armhf
                                  User-ID: 1000
                                  X-Server: false
                                  /usr/bin/npm 10.2.3
                                  /usr/bin/npx 10.2.3
                                  MEMORY:
                                  Swap: 99M 0B 99M
                                  admin 6.12.0
                                  Objects type: jsonl
                                  States type: redis
                                  Objects: 20192
                                  States: 15783
                                  @tobiasp
                                  Die Langfassung.
                                  In CodeTags eingebettet.
                                    @tobiasp
                                    Die Langfassung.
                                    tobiasp
                                    @thomas-braun ```
                                    ======= Start marking the full check here =========
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm
                                    Model		: Raspberry Pi 4 Model B Rev 1.2
                                    Docker          : false
                                    Virtualization  : none
                                    Kernel          : armv7l
                                    Userland        : armhf
                                    Systemuptime and Load:
                                     13:00:37 up 27 min,  2 users,  load average: 10.84, 6.09, 3.80
                                    CPU threads: 4
                                    *** RASPBERRY THROTTLING ***
                                    Current issues:
                                    Previously detected issues:
                                    *** Time and Time Zones ***
                                                   Local time: Sat 2024-01-13 13:00:37 CET
                                               Universal time: Sat 2024-01-13 12:00:37 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    *** User and Groups ***
                                    pi
                                    /home/pi
                                    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                    *** X-Server-Setup ***
                                    /home/iobroker/.diag.sh: line 200: [[: 1010
                                    X-Server: 	false
                                    Desktop: 	LXDE
                                    Terminal: 	x11
                                    *** MEMORY ***
                                    Mem:            3.8G        2.3G        325M         35M        1.2G        1.4G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        2.3G        425M
                                             3839 M total memory
                                             2296 M used memory
                                              556 M active memory
                                             2634 M inactive memory
                                              325 M free memory
                                              173 M buffer memory
                                             1043 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FAILED SERVICES ***
                                    0 loaded units listed.
                                    *** FILESYSTEM ***
                                    /dev/root      ext4       29G   13G   16G  44% /
                                    devtmpfs       devtmpfs  1.9G     0  1.9G   0% /dev
                                    tmpfs          tmpfs     768M  1.2M  767M   1% /run
                                    /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
                                    tmpfs          tmpfs     384M   16K  384M   1% /run/user/1000
                                    [Sat Jan 13 12:33:30 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=480 bcm2708_fb.fbheight=320 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:84:C6:E5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=e83fc39a-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Sat Jan 13 12:33:32 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                    [Sat Jan 13 12:33:32 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                    [Sat Jan 13 12:33:34 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                    TARGET                       SOURCE         FSTYPE            OPTIONS
                                    /                            /dev/mmcblk0p2 ext4              rw,noatime
                                    |-/boot                      /dev/mmcblk0p1 vfat              rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                    `-/home/pi/thinclient_drives xrdp-chansrv   fuse.xrdp-chansrv rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                                    /var:
                                    du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
                                    3.0G	/var/
                                    2.0G	/var/log/journal/930d3456bd0f4a518633913ebabe942b
                                    2.0G	/var/log
                                    642M	/var/lib
                                    Archived and active journals take up 1.9G in the file system.
                                    /opt/iobroker/backups:
                                    338M	/opt/iobroker/backups/
                                    4.0K	/opt/iobroker/backups/redistmp
                                    /opt/iobroker/iobroker-data:
                                    2.7G	/opt/iobroker/iobroker-data/
                                    2.0G	/opt/iobroker/iobroker-data/history
                                    590M	/opt/iobroker/iobroker-data/files
                                    89M	/opt/iobroker/iobroker-data/files/echarts.admin
                                    78M	/opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                                    35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                    24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                                    24M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                                    23M	/opt/iobroker/iobroker-data/objects.jsonl
                                    23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
                                    USB-Devices by-id:
                                    find: '/dev/serial/by-id/': No such file or directory
                                    *** NodeJS-Installation ***
                                    /usr/bin/npm 		10.2.3
                                    /usr/bin/npx 		10.2.3
                                    nodejs:
                                      Installed: 18.19.0-1nodesource1
                                      Candidate: 18.19.0-1nodesource1
                                      Version table:
                                     *** 18.19.0-1nodesource1 1001
                                            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                         18.18.2-1nodesource1 1001
                                         18.18.1-1nodesource1 1001
                                         18.18.0-1nodesource1 1001
                                         18.17.1-1nodesource1 1001
                                         18.17.0-1nodesource1 1001
                                         18.16.1-1nodesource1 1001
                                         18.16.0-1nodesource1 1001
                                         18.15.0-1nodesource1 1001
                                         18.14.2-1nodesource1 1001
                                         18.14.1-1nodesource1 1001
                                         18.14.0-1nodesource1 1001
                                         18.13.0-1nodesource1 1001
                                         18.12.0-1nodesource1 1001
                                         18.11.0-1nodesource1 1001
                                         18.10.0-1nodesource1 1001
                                         18.9.1-1nodesource1 1001
                                         18.9.0-1nodesource1 1001
                                         18.8.0-1nodesource1 1001
                                         18.7.0-1nodesource1 1001
                                         18.6.0-1nodesource1 1001
                                         18.5.0-1nodesource1 1001
                                         18.4.0-1nodesource1 1001
                                         18.3.0-1nodesource1 1001
                                         18.2.0-1nodesource1 1001
                                         18.1.0-1nodesource1 1001
                                         18.0.0-1nodesource1 1001
                                         12.22.12~dfsg-1~deb11u4 500
                                    No problems detected
                                    Errors in npm tree:
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: redis
                                    Core adapters versions
                                    admin: 		6.12.0
                                    javascript: 	7.1.6
                                    Adapters from github: 	8
                                    Adapter State
                                    + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
                                    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.2.130, run as: admin
                                      system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
                                    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                                    + system.adapter.countdown.0              : countdown             : raspberrypi                              -  enabled
                                      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                                      system.adapter.devices.0                : devices               : raspberrypi                              - disabled
                                    + system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              -  enabled, port: 8899
                                      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                                    + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                                    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
                                    + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
                                    + system.adapter.energiefluss.1           : energiefluss          : raspberrypi                              -  enabled
                                      system.adapter.esphome.0                : esphome               : raspberrypi                              -  enabled
                                    + system.adapter.fahrplan.0               : fahrplan              : raspberrypi                              -  enabled
                                      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                                    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                                    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                                    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                                    + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                                      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                      system.adapter.iceroad.0                : iceroad               : raspberrypi                              - disabled
                                      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
                                      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              - disabled
                                      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
                                      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
                                      system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
                                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
                                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                                      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
                                      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
                                      system.adapter.luftdaten.0              : luftdaten             : raspberrypi                              -  enabled
                                      system.adapter.meteoalarm.0             : meteoalarm            : raspberrypi                              -  enabled
                                      system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1884, bind: 192.168.2.130
                                    + system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              -  enabled, port: 1888, bind: 192.168.2.130
                                    + system.adapter.mqtt.2                   : mqtt                  : raspberrypi                              -  enabled, port: 1896, bind: 0.0.0.0
                                      system.adapter.onkyo.0                  : onkyo                 : raspberrypi                              - disabled
                                    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                                    + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
                                    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                                      system.adapter.ryd.0                    : ryd                   : raspberrypi                              -  enabled
                                    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                      system.adapter.smartthings.0            : smartthings           : raspberrypi                              - disabled
                                    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                                    + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                                    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                                      system.adapter.tvprogram.0              : tvprogram             : raspberrypi                              - disabled
                                    + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
                                      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                                      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                                      system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
                                      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                                      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
                                    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                                      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
                                      system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              - disabled
                                      system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              - disabled
                                      system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
                                      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
                                      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                                      system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
                                      system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
                                      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
                                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                                      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                                      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                                    + system.adapter.web.1                    : web                   : raspberrypi                              -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
                                      system.adapter.worx.0                   : worx                  : raspberrypi                              - disabled
                                    + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8095, bind: 0.0.0.0, run as: admin
                                    + instance is alive
                                    ioBroker-Repositories
                                    Stable (default): http://download.iobroker.net/sources-dist.json
                                    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                                    Installed ioBroker-Instances
                                    Used repository: Beta (latest)
                                    Adapter    "accuweather"  : 1.3.2    , installed 1.3.2
                                    Adapter    "admin"        : 6.13.15  , installed 6.12.0 [Updatable]
                                    Adapter    "alarm"        : 3.6.0    , installed 3.4.3  [Updatable]
                                    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                                    Adapter    "backitup"     : 2.10.1   , installed 2.9.8  [Updatable]
                                    Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
                                    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                                    Adapter    "countdown"    : 2.2.0    , installed 2.2.0
                                    Adapter    "daswetter"    : 3.1.13   , installed 3.1.11 [Updatable]
                                    Adapter    "devices"      : 1.1.5    , installed 1.1.5
                                    Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
                                    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                                    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                                    Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.14-alpha.4
                                    Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
                                    Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
                                    Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
                                    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                                    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
                                    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                                    Adapter    "hm-rpc"       : 1.16.0   , installed 1.15.19 [Updatable]
                                    Adapter    "ical"         : 1.14.0   , installed 1.13.3 [Updatable]
                                    Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
                                    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                                    Adapter    "icons-material-png": 0.1.0, installed 0.1.1
                                    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                                    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                                    Adapter    "info"         : 2.0.0    , installed 2.0.0
                                    Adapter    "javascript"   : 7.6.3    , installed 7.1.6  [Updatable]
                                    Controller "js-controller": 5.0.17   , installed 5.0.17
                                    Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
                                    Adapter    "meteoalarm"   : 2.3.7    , installed 2.3.7
                                    Adapter    "mqtt"         : 5.2.0    , installed 5.1.0  [Updatable]
                                    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
                                    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                    Adapter    "smartthings"  : 0.1.1    , installed 0.0.4  [Updatable]
                                    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                                    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                                    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                                    Adapter    "trashschedule": 3.1.3    , installed 2.3.0  [Updatable]
                                    Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
                                    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                                    Adapter    "vis"          : 1.5.4    , installed 1.5.4
                                    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
                                    Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
                                    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                                    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                                    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                                    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                                    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                                    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.6  [Updatable]
                                    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                                    Adapter    "web"          : 6.2.3    , installed 6.1.10 [Updatable]
                                    Adapter    "worx"         : 2.3.4    , installed 2.3.4
                                    Adapter    "ws"           : 2.5.10   , installed 2.5.8  [Updatable]
                                    Objects and States
                                    Objects: 	20170
                                    States: 	15747
                                    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                                    Hit:4 https://apt.pivccu.de/piVCCU stable InRelease
                                    Reading package lists...
                                    Pending Updates: 0
                                    *** Listening Ports ***
                                    tcp        0      0 192.168.2.130:8081      0.0.0.0:*               LISTEN      1001       102238     19610/io.admin.0
                                    tcp        0      0 192.168.2.130:2010      0.0.0.0:*               LISTEN      1001       104075     20130/io.hm-rpc.0
                                    tcp        0      0 192.168.2.130:2001      0.0.0.0:*               LISTEN      1001       104098     20266/io.hm-rpc.1
                                    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      111        1971       933/redis-server 12
                                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       105756     20520/io.sonoff.0
                                    tcp        0      0 192.168.2.130:1888      0.0.0.0:*               LISTEN      1001       104902     20418/io.mqtt.1
                                    tcp        0      0 0.0.0.0:1897            0.0.0.0:*               LISTEN      1001       105737     20458/io.mqtt.2
                                    tcp        0      0 0.0.0.0:1896            0.0.0.0:*               LISTEN      1001       105736     20458/io.mqtt.2
                                    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          13133      1027/dnsmasq
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       102004     19570/iobroker.js-c
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15415      968/sshd: /usr/sbin
                                    tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      0          131088     26215/nc
                                    tcp        0      0 192.168.2.130:9292      0.0.0.0:*               LISTEN      1001       105653     20403/io.hm-rpc.2
                                    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       112465     21969/io.terminal.0
                                    tcp6       0      0 :::8095                 :::*                    LISTEN      1001       106247     21177/io.ws.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       108657     20889/io.web.0
                                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       108807     21162/io.simple-api
                                    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          1916       959/xrdp-sesman
                                    tcp6       0      0 :::3389                 :::*                    LISTEN      116        14731      1012/xrdp
                                    tcp6       0      0 ::1:6379                :::*                    LISTEN      111        1972       933/redis-server 12
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          15417      968/sshd: /usr/sbin
                                    tcp6       0      0 :::20002                :::*                    LISTEN      1001       116875     22117/io.web.1
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14097      401/avahi-daemon: r
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       117906     22757/io.upnp.0
                                    udp        0      0 0.0.0.0:58349           0.0.0.0:*                           108        14099      401/avahi-daemon: r
                                    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          13132      1027/dnsmasq
                                    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          13129      1027/dnsmasq
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12884      812/dhclient
                                    udp        0      0 0.0.0.0:49274           0.0.0.0:*                           1001       116522     22757/io.upnp.0
                                    udp6       0      0 :::5353                 :::*                                108        14098      401/avahi-daemon: r
                                    udp6       0      0 :::39980                :::*                                108        14100      401/avahi-daemon: r
                                    2024-01-13 13:01:03.374  - info: energiefluss.1 (22735) Adapter started and listening to 5 States
                                    2024-01-13 13:01:04.706  - info: upnp.0 (22757) starting. Version 1.0.21 (non-npm: Jey-Cee/ioBroker.upnp#3c2a5fa39827e3615080e354eb75d6441ebfd5b3) in /opt/iobroker/node_modules/iobroker.upnp, node: v18.19.0, js-controller: 5.0.17
                                    2024-01-13 13:01:04.835  - info: upnp.0 (22757) Auto discover: true
                                    2024-01-13 13:01:08.076  - warn: upnp.0 (22757) Error: Error: Non-whitespace before first tag.
                                    Line: 0
                                    Column: 1
                                    Char: s
                                    2024-01-13 13:01:09.821  - info: ryd.0 (22037) Terminated (NO_ERROR): Without reason
                                    2024-01-13 13:01:09.843  - info: ryd.0 (22037) State value to set for "ryd.0.lastUpdate" has to be stringified but received type "object"
                                    2024-01-13 13:01:10.648  - info: host.raspberrypi instance system.adapter.ryd.0 terminated with code 0 (NO_ERROR)
                                    2024-01-13 13:01:12.858  - info: pollenflug.0 (21722) Next DWD pollen request starts on Sun Jan 14 2024 11:00:00 GMT+0100 (Central European Standard Time)
                                    2024-01-13 13:01:17.075  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                    2024-01-13 13:01:29.897  - info: fahrplan.0 (21586) Updated 2 routes, 2 enabled and 0 disabled
                                    2024-01-13 13:01:32.038  - info: fahrplan.0 (21586) Updated 1 departure timetables, 1 enabled and 0 disabled
                                    2024-01-13 13:01:32.796  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                    2024-01-13 13:01:48.907  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                    2024-01-13 13:01:49.905  - info: vis.0 (24342) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                                    2024-01-13 13:01:52.364  - info: vis-google-fonts.0 (24382) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v18.19.0, js-controller: 5.0.17
                                    2024-01-13 13:01:53.411  - info: vis-google-fonts.0 (24382) Terminated (NO_ERROR): Without reason
                                    2024-01-13 13:01:54.799  - info: vis.0 (24342) Terminated (NO_ERROR): Without reason
                                    2024-01-13 13:02:04.803  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                    2024-01-13 13:02:05.759  - info: tankerkoenig.0 (21775) Start first request
                                    2024-01-13 13:02:20.153  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                    2024-01-13 13:02:35.279  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                    2024-01-13 13:02:50.813  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                    iob diag has finished.
                                    • T tobiasp
                                      @thomas-braun ```
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm
                                      Docker          : false
                                      Kernel          : armv7l
                                      Userland        : armhf
                                      CPU threads: 4
                                      Current issues:
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server: 	false
                                      Desktop: 	LXDE
                                      Terminal: 	x11
                                      *** MEMORY ***
                                      Swap:            99M          0B         99M
                                               3839 M total memory
                                               2296 M used memory
                                                556 M active memory
                                                325 M free memory
                                                173 M buffer memory
                                               1043 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /var:
                                      3.0G	/var/
                                      2.0G	/var/log
                                      642M	/var/lib
                                      USB-Devices by-id:
                                      /usr/bin/npm 		10.2.3
                                      /usr/bin/npx 		10.2.3
                                      nodejs:
                                        Version table:
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: redis
                                      admin: 		6.12.0
                                      javascript: 	7.1.6
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects: 	20170
                                      States: 	15747
                                      Pending Updates: 0
                                      Line: 0
                                      Column: 1
                                      Char: s
                                      @tobiasp
                                      Das Ding ist komplett schief aufgesetzt.
                                      Installier da NEU ein 64Bit Raspberry OS Lite.
