  4. esphome - wird dies noch gepflegt?
44 Beiträge 9 Kommentatoren 9.0k Aufrufe 12 Beobachtet
  • T tobiasp
    ich wollte ESPHome installieren.
    pi@raspberrypi:~ $ iob add esphome --host raspberrypi --debug
    installiert ist es, aber soblad ich das Dashboard aktiviere wirde der Adapter Rot.
    Was mache ich falsch?
    @tobiasp sagte in esphome - wird dies noch gepflegt?:
    Du zeigst kein Log davon.
    T 2 Antworten Letzte Antwort
      tobiasp
      stimmt sorry
      host.raspberrypi
      	2024-01-13 12:29:12.798	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      esphome.0
      	2024-01-13 12:29:12.393	info	terminating
      esphome.0
      	2024-01-13 12:29:11.711	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      esphome.0
      	2024-01-13 12:29:11.707	info	terminating
      esphome.0
      	2024-01-13 12:29:11.662	error	Exception-Code: MODULE_NOT_FOUND: Cannot find module '@mongodb-js/zstd-linux-arm-gnueabihf'Require stack:- /opt/iobroker/node_modules/@mongodb-js/zstd/index.js
      esphome.0
      	2024-01-13 12:29:11.661	error	Error: Cannot find module '@mongodb-js/zstd-linux-arm-gnueabihf'Require stack:- /opt/iobroker/node_modules/@mongodb-js/zstd/index.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Function.Module._load (node:internal/modules/cjs/loader:975:27) at Module.require (node:internal/modules/cjs/loader:1225:19) at require (node:internal/modules/helpers:177:18) at Object.<anonymous> (/opt/iobroker/node_modules/@mongodb-js/zstd/index.js:131:29) at Module._compile (node:internal/modules/cjs/loader:1356:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1414:10) at Module.load (node:internal/modules/cjs/loader:1197:32) at Function.Module._load (node:internal/modules/cjs/loader:1013:12) at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:202:29)
      esphome.0
      	2024-01-13 12:29:11.660	error	unhandled promise rejection: Cannot find module '@mongodb-js/zstd-linux-arm-gnueabihf'Require stack:- /opt/iobroker/node_modules/@mongodb-js/zstd/index.js
      esphome.0
      	2024-01-13 12:29:11.657	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      esphome.0
      	2024-01-13 12:29:11.267	info	[Error caught and send to Sentry, thank you collaborating!] error: Error: Cannot find module '@mongodb-js/zstd-linux-arm-gnueabihf'Require stack:- /opt/iobroker/node_modules/@mongodb-js/zstd/index.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1134:15) at Function.Module._load (node:internal/modules/cjs/loader:975:27) at Module.require (node:internal/modules/cjs/loader:1225:19) at require (node:internal/modules/helpers:177:18) at Object.<anonymous> (/opt/iobroker/node_modules/@mongodb-js/zstd/index.js:131:29) at Module._compile (node:internal/modules/cjs/loader:1356:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1414:10) at Module.load (node:internal/modules/cjs/loader:1197:32) at Function.Module._load (node:internal/modules/cjs/loader:1013:12) at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:202:29)
      esphome.0
      	2024-01-13 12:29:10.907	info	Native Integration of ESPHome Dashboard enabled
      esphome.0
      	2024-01-13 12:29:10.417	info	starting. Version 0.5.0-beta.8 in /opt/iobroker/node_modules/iobroker.esphome, node: v18.19.0, js-controller: 5.0.17
      • Thomas BraunT Online
        @tobiasp
        SuFu hätte das zutage gefördert:
        https://forum.iobroker.net/topic/70320/esp-home-webinterface-wird-nicht-geladen/31
          tobiasp
          Oh muss mich verbessern habe mit npm i iobroker.esphome installiert, da der andere befehl nicht funktioniert hat
          • T tobiasp
            @tobiasp
            Das macht man ja auch nicht mit npm...
              @tobiasp
              tobiasp
              wie kann ich es sonst installieren?
              • T tobiasp
                @tobiasp
                iobroker add ADAPTERNAME --host HOSTNAME --debug
                ist der Standardbefehl um Adapter hinzuzufügen.
                  @tobiasp
                  tobiasp
                  i@raspberrypi:~ $ iobroker add esphome --host raspberrypi --debug
                  host.raspberrypi Unknown packetName esphome. Please install packages from outside the repository using npm!
                  • T tobiasp
                    @tobiasp
                    Dann bist hast nicht das beta-Repo aktiv.
                    Der Adapter ist noch nicht in einer stabilen Version veröffentlicht worden.
                    Davon abgesehen sagt
                    iob diag
                    was zu deinem System?
                      @tobiasp
                      iob diag
                      tobiasp
                      ====================== SUMMARY =======================
                      v.2023-10-10
                      Static hostname: raspberrypi
                      Icon name: computer
                      Operating System: Raspbian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v7l+
                      Architecture: arm
                      Installation: native
                      Kernel: armv7l
                      Userland: armhf
                      Timezone: Europe/Berlin (CET, +0100)
                      User-ID: 1000
                      /home/iobroker/.diag.sh: line 469: [[: 1010
                      2037: syntax error in expression (error token is "2037")
                      X-Server: false
                      Boot Target: graphical.target
                      Pending OS-Updates: 0
                      Pending iob updates: 13
                      Nodejs-Installation: /usr/bin/nodejs v18.19.0
                      /usr/bin/node v18.19.0
                      /usr/bin/npm 10.2.3
                      /usr/bin/npx 10.2.3
                      /usr/bin/corepack 0.22.0
                      Recommended versions are nodejs 18.19.0 and npm 10.2.3
                      MEMORY:
                      total used free shared buff/cache available
                      Mem: 3.8G 2.1G 770M 35M 1.0G 1.6G
                      Swap: 99M 0B 99M
                      Total: 3.9G 2.1G 870M
                      Active iob-Instances: 39
                      Active repo(s): Beta (latest)
                      ioBroker Core: js-controller 5.0.17
                      admin 6.12.0
                      ioBroker Status: iobroker is running on this host.
                      Objects type: jsonl
                      States type: redis
                      • system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 192.168.2.130, run as: admin
                      • system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      • system.adapter.web.1 : web : raspberrypi - enabled, port: 20002, bind: 0.0.0.0, run as: admin
                      Objects: 20192
                      States: 15783
                      Size of iob-Database:
                      43M /opt/iobroker/iobroker-data/objects.jsonl
                      4.1M /opt/iobroker/iobroker-data/states.jsonl
                      =================== END OF SUMMARY ==
                      • T tobiasp
                        v.2023-10-10
                        Icon name: computer
                        Architecture: arm
                        Kernel: armv7l
                        Userland: armhf
                        User-ID: 1000
                        X-Server: false
                        /usr/bin/npm 10.2.3
                        /usr/bin/npx 10.2.3
                        MEMORY:
                        Swap: 99M 0B 99M
                        admin 6.12.0
                        Objects type: jsonl
                        States type: redis
                        Objects: 20192
                        States: 15783
                        @tobiasp
                        Die Langfassung.
                        In CodeTags eingebettet.
                          @tobiasp
                          Die Langfassung.
                          tobiasp
                          @thomas-braun ```
                          ======= Start marking the full check here =========
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm
                          Model		: Raspberry Pi 4 Model B Rev 1.2
                          Docker          : false
                          Virtualization  : none
                          Kernel          : armv7l
                          Userland        : armhf
                          Systemuptime and Load:
                           13:00:37 up 27 min,  2 users,  load average: 10.84, 6.09, 3.80
                          CPU threads: 4
                          *** RASPBERRY THROTTLING ***
                          Current issues:
                          Previously detected issues:
                          *** Time and Time Zones ***
                                         Local time: Sat 2024-01-13 13:00:37 CET
                                     Universal time: Sat 2024-01-13 12:00:37 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          *** User and Groups ***
                          pi
                          /home/pi
                          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                          *** X-Server-Setup ***
                          /home/iobroker/.diag.sh: line 200: [[: 1010
                          X-Server: 	false
                          Desktop: 	LXDE
                          Terminal: 	x11
                          *** MEMORY ***
                          Mem:            3.8G        2.3G        325M         35M        1.2G        1.4G
                          Swap:            99M          0B         99M
                          Total:          3.9G        2.3G        425M
                                   3839 M total memory
                                   2296 M used memory
                                    556 M active memory
                                   2634 M inactive memory
                                    325 M free memory
                                    173 M buffer memory
                                   1043 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FAILED SERVICES ***
                          0 loaded units listed.
                          *** FILESYSTEM ***
                          /dev/root      ext4       29G   13G   16G  44% /
                          devtmpfs       devtmpfs  1.9G     0  1.9G   0% /dev
                          tmpfs          tmpfs     768M  1.2M  767M   1% /run
                          /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
                          tmpfs          tmpfs     384M   16K  384M   1% /run/user/1000
                          [Sat Jan 13 12:33:30 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=480 bcm2708_fb.fbheight=320 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:84:C6:E5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=e83fc39a-02 rootfstype=ext4 fsck.repair=yes rootwait
                          [Sat Jan 13 12:33:32 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                          [Sat Jan 13 12:33:32 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                          [Sat Jan 13 12:33:34 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                          TARGET                       SOURCE         FSTYPE            OPTIONS
                          /                            /dev/mmcblk0p2 ext4              rw,noatime
                          |-/boot                      /dev/mmcblk0p1 vfat              rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                          `-/home/pi/thinclient_drives xrdp-chansrv   fuse.xrdp-chansrv rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                          /var:
                          du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
                          3.0G	/var/
                          2.0G	/var/log/journal/930d3456bd0f4a518633913ebabe942b
                          2.0G	/var/log
                          642M	/var/lib
                          Archived and active journals take up 1.9G in the file system.
                          /opt/iobroker/backups:
                          338M	/opt/iobroker/backups/
                          4.0K	/opt/iobroker/backups/redistmp
                          /opt/iobroker/iobroker-data:
                          2.7G	/opt/iobroker/iobroker-data/
                          2.0G	/opt/iobroker/iobroker-data/history
                          590M	/opt/iobroker/iobroker-data/files
                          89M	/opt/iobroker/iobroker-data/files/echarts.admin
                          78M	/opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                          35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                          24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                          24M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                          23M	/opt/iobroker/iobroker-data/objects.jsonl
                          23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
                          USB-Devices by-id:
                          find: '/dev/serial/by-id/': No such file or directory
                          *** NodeJS-Installation ***
                          /usr/bin/npm 		10.2.3
                          /usr/bin/npx 		10.2.3
                          nodejs:
                            Installed: 18.19.0-1nodesource1
                            Candidate: 18.19.0-1nodesource1
                            Version table:
                           *** 18.19.0-1nodesource1 1001
                                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                               18.18.2-1nodesource1 1001
                               18.18.1-1nodesource1 1001
                               18.18.0-1nodesource1 1001
                               18.17.1-1nodesource1 1001
                               18.17.0-1nodesource1 1001
                               18.16.1-1nodesource1 1001
                               18.16.0-1nodesource1 1001
                               18.15.0-1nodesource1 1001
                               18.14.2-1nodesource1 1001
                               18.14.1-1nodesource1 1001
                               18.14.0-1nodesource1 1001
                               18.13.0-1nodesource1 1001
                               18.12.0-1nodesource1 1001
                               18.11.0-1nodesource1 1001
                               18.10.0-1nodesource1 1001
                               18.9.1-1nodesource1 1001
                               18.9.0-1nodesource1 1001
                               18.8.0-1nodesource1 1001
                               18.7.0-1nodesource1 1001
                               18.6.0-1nodesource1 1001
                               18.5.0-1nodesource1 1001
                               18.4.0-1nodesource1 1001
                               18.3.0-1nodesource1 1001
                               18.2.0-1nodesource1 1001
                               18.1.0-1nodesource1 1001
                               18.0.0-1nodesource1 1001
                               12.22.12~dfsg-1~deb11u4 500
                          No problems detected
                          Errors in npm tree:
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: redis
                          Core adapters versions
                          admin: 		6.12.0
                          javascript: 	7.1.6
                          Adapters from github: 	8
                          Adapter State
                          + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
                          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.2.130, run as: admin
                            system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
                          + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                          + system.adapter.countdown.0              : countdown             : raspberrypi                              -  enabled
                            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                            system.adapter.devices.0                : devices               : raspberrypi                              - disabled
                          + system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              -  enabled, port: 8899
                            system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                          + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                          + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
                          + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
                          + system.adapter.energiefluss.1           : energiefluss          : raspberrypi                              -  enabled
                            system.adapter.esphome.0                : esphome               : raspberrypi                              -  enabled
                          + system.adapter.fahrplan.0               : fahrplan              : raspberrypi                              -  enabled
                            system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                          + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                          + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                          + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                          + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                            system.adapter.iceroad.0                : iceroad               : raspberrypi                              - disabled
                            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
                            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              - disabled
                            system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
                            system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
                            system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
                            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
                            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
                            system.adapter.luftdaten.0              : luftdaten             : raspberrypi                              -  enabled
                            system.adapter.meteoalarm.0             : meteoalarm            : raspberrypi                              -  enabled
                            system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1884, bind: 192.168.2.130
                          + system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              -  enabled, port: 1888, bind: 192.168.2.130
                          + system.adapter.mqtt.2                   : mqtt                  : raspberrypi                              -  enabled, port: 1896, bind: 0.0.0.0
                            system.adapter.onkyo.0                  : onkyo                 : raspberrypi                              - disabled
                          + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                          + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
                          + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                            system.adapter.ryd.0                    : ryd                   : raspberrypi                              -  enabled
                          + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                            system.adapter.smartthings.0            : smartthings           : raspberrypi                              - disabled
                          + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                          + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                          + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                          + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                            system.adapter.tvprogram.0              : tvprogram             : raspberrypi                              - disabled
                          + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
                            system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                            system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                            system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
                            system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
                          + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                            system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
                            system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              - disabled
                            system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              - disabled
                            system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
                            system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
                            system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                            system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
                            system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
                            system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                            system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                            system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                          + system.adapter.web.1                    : web                   : raspberrypi                              -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
                            system.adapter.worx.0                   : worx                  : raspberrypi                              - disabled
                          + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8095, bind: 0.0.0.0, run as: admin
                          + instance is alive
                          ioBroker-Repositories
                          Stable (default): http://download.iobroker.net/sources-dist.json
                          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                          Installed ioBroker-Instances
                          Used repository: Beta (latest)
                          Adapter    "accuweather"  : 1.3.2    , installed 1.3.2
                          Adapter    "admin"        : 6.13.15  , installed 6.12.0 [Updatable]
                          Adapter    "alarm"        : 3.6.0    , installed 3.4.3  [Updatable]
                          Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                          Adapter    "backitup"     : 2.10.1   , installed 2.9.8  [Updatable]
                          Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
                          Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                          Adapter    "countdown"    : 2.2.0    , installed 2.2.0
                          Adapter    "daswetter"    : 3.1.13   , installed 3.1.11 [Updatable]
                          Adapter    "devices"      : 1.1.5    , installed 1.1.5
                          Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
                          Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                          Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                          Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.14-alpha.4
                          Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
                          Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
                          Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
                          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                          Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
                          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                          Adapter    "hm-rpc"       : 1.16.0   , installed 1.15.19 [Updatable]
                          Adapter    "ical"         : 1.14.0   , installed 1.13.3 [Updatable]
                          Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
                          Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                          Adapter    "icons-material-png": 0.1.0, installed 0.1.1
                          Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                          Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                          Adapter    "info"         : 2.0.0    , installed 2.0.0
                          Adapter    "javascript"   : 7.6.3    , installed 7.1.6  [Updatable]
                          Controller "js-controller": 5.0.17   , installed 5.0.17
                          Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
                          Adapter    "meteoalarm"   : 2.3.7    , installed 2.3.7
                          Adapter    "mqtt"         : 5.2.0    , installed 5.1.0  [Updatable]
                          Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
                          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                          Adapter    "smartthings"  : 0.1.1    , installed 0.0.4  [Updatable]
                          Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                          Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                          Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                          Adapter    "trashschedule": 3.1.3    , installed 2.3.0  [Updatable]
                          Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
                          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                          Adapter    "vis"          : 1.5.4    , installed 1.5.4
                          Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
                          Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
                          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                          Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                          Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                          Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.6  [Updatable]
                          Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                          Adapter    "web"          : 6.2.3    , installed 6.1.10 [Updatable]
                          Adapter    "worx"         : 2.3.4    , installed 2.3.4
                          Adapter    "ws"           : 2.5.10   , installed 2.5.8  [Updatable]
                          Objects and States
                          Objects: 	20170
                          States: 	15747
                          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Hit:4 https://apt.pivccu.de/piVCCU stable InRelease
                          Reading package lists...
                          Pending Updates: 0
                          *** Listening Ports ***
                          tcp        0      0 192.168.2.130:8081      0.0.0.0:*               LISTEN      1001       102238     19610/io.admin.0
                          tcp        0      0 192.168.2.130:2010      0.0.0.0:*               LISTEN      1001       104075     20130/io.hm-rpc.0
                          tcp        0      0 192.168.2.130:2001      0.0.0.0:*               LISTEN      1001       104098     20266/io.hm-rpc.1
                          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      111        1971       933/redis-server 12
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       105756     20520/io.sonoff.0
                          tcp        0      0 192.168.2.130:1888      0.0.0.0:*               LISTEN      1001       104902     20418/io.mqtt.1
                          tcp        0      0 0.0.0.0:1897            0.0.0.0:*               LISTEN      1001       105737     20458/io.mqtt.2
                          tcp        0      0 0.0.0.0:1896            0.0.0.0:*               LISTEN      1001       105736     20458/io.mqtt.2
                          tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          13133      1027/dnsmasq
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       102004     19570/iobroker.js-c
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15415      968/sshd: /usr/sbin
                          tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      0          131088     26215/nc
                          tcp        0      0 192.168.2.130:9292      0.0.0.0:*               LISTEN      1001       105653     20403/io.hm-rpc.2
                          tcp6       0      0 :::8088                 :::*                    LISTEN      1001       112465     21969/io.terminal.0
                          tcp6       0      0 :::8095                 :::*                    LISTEN      1001       106247     21177/io.ws.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       108657     20889/io.web.0
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       108807     21162/io.simple-api
                          tcp6       0      0 ::1:3350                :::*                    LISTEN      0          1916       959/xrdp-sesman
                          tcp6       0      0 :::3389                 :::*                    LISTEN      116        14731      1012/xrdp
                          tcp6       0      0 ::1:6379                :::*                    LISTEN      111        1972       933/redis-server 12
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          15417      968/sshd: /usr/sbin
                          tcp6       0      0 :::20002                :::*                    LISTEN      1001       116875     22117/io.web.1
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14097      401/avahi-daemon: r
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       117906     22757/io.upnp.0
                          udp        0      0 0.0.0.0:58349           0.0.0.0:*                           108        14099      401/avahi-daemon: r
                          udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          13132      1027/dnsmasq
                          udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          13129      1027/dnsmasq
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12884      812/dhclient
                          udp        0      0 0.0.0.0:49274           0.0.0.0:*                           1001       116522     22757/io.upnp.0
                          udp6       0      0 :::5353                 :::*                                108        14098      401/avahi-daemon: r
                          udp6       0      0 :::39980                :::*                                108        14100      401/avahi-daemon: r
                          2024-01-13 13:01:03.374  - info: energiefluss.1 (22735) Adapter started and listening to 5 States
                          2024-01-13 13:01:04.706  - info: upnp.0 (22757) starting. Version 1.0.21 (non-npm: Jey-Cee/ioBroker.upnp#3c2a5fa39827e3615080e354eb75d6441ebfd5b3) in /opt/iobroker/node_modules/iobroker.upnp, node: v18.19.0, js-controller: 5.0.17
                          2024-01-13 13:01:04.835  - info: upnp.0 (22757) Auto discover: true
                          2024-01-13 13:01:08.076  - warn: upnp.0 (22757) Error: Error: Non-whitespace before first tag.
                          Line: 0
                          Column: 1
                          Char: s
                          2024-01-13 13:01:09.821  - info: ryd.0 (22037) Terminated (NO_ERROR): Without reason
                          2024-01-13 13:01:09.843  - info: ryd.0 (22037) State value to set for "ryd.0.lastUpdate" has to be stringified but received type "object"
                          2024-01-13 13:01:10.648  - info: host.raspberrypi instance system.adapter.ryd.0 terminated with code 0 (NO_ERROR)
                          2024-01-13 13:01:12.858  - info: pollenflug.0 (21722) Next DWD pollen request starts on Sun Jan 14 2024 11:00:00 GMT+0100 (Central European Standard Time)
                          2024-01-13 13:01:17.075  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                          2024-01-13 13:01:29.897  - info: fahrplan.0 (21586) Updated 2 routes, 2 enabled and 0 disabled
                          2024-01-13 13:01:32.038  - info: fahrplan.0 (21586) Updated 1 departure timetables, 1 enabled and 0 disabled
                          2024-01-13 13:01:32.796  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                          2024-01-13 13:01:48.907  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                          2024-01-13 13:01:49.905  - info: vis.0 (24342) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                          2024-01-13 13:01:52.364  - info: vis-google-fonts.0 (24382) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v18.19.0, js-controller: 5.0.17
                          2024-01-13 13:01:53.411  - info: vis-google-fonts.0 (24382) Terminated (NO_ERROR): Without reason
                          2024-01-13 13:01:54.799  - info: vis.0 (24342) Terminated (NO_ERROR): Without reason
                          2024-01-13 13:02:04.803  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                          2024-01-13 13:02:05.759  - info: tankerkoenig.0 (21775) Start first request
                          2024-01-13 13:02:20.153  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                          2024-01-13 13:02:35.279  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                          2024-01-13 13:02:50.813  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                          iob diag has finished.
                          • T tobiasp
                            @thomas-braun ```
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm
                            Docker          : false
                            Kernel          : armv7l
                            Userland        : armhf
                            CPU threads: 4
                            Current issues:
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            /home/pi
                            X-Server: 	false
                            Desktop: 	LXDE
                            Terminal: 	x11
                            *** MEMORY ***
                            Swap:            99M          0B         99M
                                     3839 M total memory
                                     2296 M used memory
                                      556 M active memory
                                      325 M free memory
                                      173 M buffer memory
                                     1043 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /var:
                            3.0G	/var/
                            2.0G	/var/log
                            642M	/var/lib
                            USB-Devices by-id:
                            /usr/bin/npm 		10.2.3
                            /usr/bin/npx 		10.2.3
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: redis
                            admin: 		6.12.0
                            javascript: 	7.1.6
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects: 	20170
                            States: 	15747
                            Pending Updates: 0
                            Line: 0
                            Column: 1
                            Char: s
                            @tobiasp
                            Das Ding ist komplett schief aufgesetzt.
                            Installier da NEU ein 64Bit Raspberry OS Lite.
