  4. Diskussion zum HowTo nodejs-Installation und upgrade
nodejs
844 Beiträge 91 Kommentatoren 328.1k Aufrufe 63 Beobachtet
  • D djsirius
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 3 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     09:27:08 up 14:00,  1 user,  load average: 2.07, 2.00, 1.17
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Thu 2024-01-04 09:27:08 CET
               Universal time: Thu 2024-01-04 08:27:08 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            909M        589M         64M        0.0K        255M        260M
    Swap:            99M         99M        0.0K
    Total:          1.0G        689M         64M
              909 M total memory
              590 M used memory
              416 M active memory
              344 M inactive memory
               63 M free memory
                9 M buffer memory
              246 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       59G   32G   25G  57% /
    devtmpfs       devtmpfs  325M     0  325M   0% /dev
    tmpfs          tmpfs     455M     0  455M   0% /dev/shm
    tmpfs          tmpfs     182M 1020K  181M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
    tmpfs          tmpfs      91M     0   91M   0% /run/user/0
    [Wed Jan  3 19:27:05 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d3cf0315-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Wed Jan  3 19:27:08 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Wed Jan  3 19:27:08 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Wed Jan  3 19:27:08 2024] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
    [Wed Jan  3 19:27:08 2024] EXT4-fs (mmcblk0p2): 4 orphan inodes deleted
    [Wed Jan  3 19:27:08 2024] EXT4-fs (mmcblk0p2): recovery complete
    [Wed Jan  3 19:27:08 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Jan  3 19:27:08 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Wed Jan  3 19:27:12 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    27G     /var/
    22G     /var/lib/mysql/iobroker
    22G     /var/lib/mysql
    22G     /var/lib
    4.5G    /var/log
    Archived and active journals take up 4.0G in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    18M     /opt/iobroker/iobroker-data/
    14M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    3.0M    /opt/iobroker/iobroker-data/objects.jsonl
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.12.0
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : debian                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : debian                                   -  enabled
    + system.adapter.backitup.0               : backitup              : debian                                   -  enabled
      system.adapter.daswetter.0              : daswetter             : debian                                   -  enabled
      system.adapter.devices.0                : devices               : debian                                   -  enabled
    + system.adapter.discovery.0              : discovery             : debian                                   -  enabled
      system.adapter.dwd.0                    : dwd                   : debian                                   -  enabled
    + system.adapter.enigma2.0                : enigma2               : raspberrypi                              -  enabled
      system.adapter.feiertage.0              : feiertage             : debian                                   -  enabled
      system.adapter.flot.0                   : flot                  : debian                                   -  enabled
    + system.adapter.history.0                : history               : debian                                   -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : debian                                   -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : debian                                   -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : debian                                   -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : debian                                   -  enabled
      system.adapter.ical.1                   : ical                  : debian                                   -  enabled
      system.adapter.ical.2                   : ical                  : debian                                   -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : debian                                   -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : debian                                   -  enabled
    + system.adapter.info.0                   : info                  : debian                                   -  enabled
    + system.adapter.iot.0                    : iot                   : debian                                   -  enabled
    + system.adapter.javascript.0             : javascript            : debian                                   -  enabled
    + system.adapter.lg-thinq.0               : lg-thinq              : debian                                   -  enabled
    + system.adapter.linux-control.0          : linux-control         : debian                                   -  enabled
    + system.adapter.logparser.0              : logparser             : debian                                   -  enabled
    + system.adapter.meross.0                 : meross                : debian                                   -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : debian                                   -  enabled, port: 54321
      system.adapter.mobile.0                 : mobile                : debian                                   -  enabled
    + system.adapter.modbus.0                 : modbus                : debian                                   -  enabled
    + system.adapter.openligadb.0             : openligadb            : debian                                   -  enabled
    + system.adapter.ping.0                   : ping                  : debian                                   -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : debian                                   -  enabled
    + system.adapter.rpi2.1                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.scenes.0                 : scenes                : debian                                   -  enabled
    + system.adapter.shelly.0                 : shelly                : debian                                   -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : debian                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : debian                                   -  enabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.sql.0                    : sql                   : debian                                   -  enabled, port: 3306
    + system.adapter.systeminfo.0             : systeminfo            : debian                                   -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : debian                                   -  enabled
    + system.adapter.telegram.0               : telegram              : debian                                   -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : debian                                   -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.text2command.0           : text2command          : debian                                   -  enabled
    + system.adapter.tibberlink.0             : tibberlink            : debian                                   -  enabled
    + system.adapter.tr-064.0                 : tr-064                : debian                                   -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : debian                                   -  enabled
    + system.adapter.upnp.0                   : upnp                  : debian                                   -  enabled
    + system.adapter.viessmannapi.0           : viessmannapi          : debian                                   -  enabled
      system.adapter.vis-bars.0               : vis-bars              : debian                                   -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : debian                                   -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : debian                                   -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : debian                                   -  enabled
      system.adapter.vis-history.0            : vis-history           : debian                                   -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debian                                   -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : debian                                   -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : debian                                   -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : debian                                   -  enabled
      system.adapter.vis-metro.0              : vis-metro             : debian                                   -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : debian                                   -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : debian                                   -  enabled
      system.adapter.vis-weather.0            : vis-weather           : debian                                   -  enabled
      system.adapter.vis.0                    : vis                   : debian                                   -  enabled
    + system.adapter.web.0                    : web                   : debian                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
    Controller "js-controller": 5.0.17   , installed 4.0.24 [Updatable]
    Adapter    "unifi"        : 0.6.7    , installed 0.6.7
    Adapter    "zigbee"       : 1.9.5    , installed 1.8.23 [Updatable]
    Objects and States
    Objects:        27972
    States:         22604
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11952      526/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11954      526/sshd: /usr/sbin
    tcp6       0      0 :::3306                 :::*                    LISTEN      110        14596      568/mariadbd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12753      394/avahi-daemon: r
    udp        0      0 0.0.0.0:58923           0.0.0.0:*                           108        12755      394/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12822      697/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        12754      394/avahi-daemon: r
    udp6       0      0 :::59929                :::*                                108        12756      394/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          12083      697/dhcpcd
    2024-01-04 08:46:50.276  - info: zigbee.0 (129073)   --> transmitPower : normal
    2024-01-04 08:46:50.308  - info: zigbee.0 (129073) Currently 18 devices are joined:
    2024-01-04 08:46:50.630  - info: zigbee.0 (129073) 0x00158d00069b00d3 (addr 12111): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2024-01-04 08:46:50.642  - info: zigbee.0 (129073) 0x00158d00053f42d6 (addr 25476): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2024-01-04 08:46:50.652  - info: zigbee.0 (129073) 0x00124b001f7a8b1c (addr 48495): GL-C-007-2ID - Gledopto Zigbee LED Controller RGBW (2 ID) (Router)
    2024-01-04 08:46:50.658  - info: zigbee.0 (129073) 0x00158d00045ced13 (addr 57845): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2024-01-04 08:46:50.663  - info: zigbee.0 (129073) 0x7cb03eaa0a07df5f (addr 3784): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
    2024-01-04 08:46:50.667  - info: zigbee.0 (129073) 0x00158d00053f72a6 (addr 38940): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2024-01-04 08:46:50.671  - info: zigbee.0 (129073) 0x00158d0006a034d9 (addr 9912): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2024-01-04 08:46:50.675  - info: zigbee.0 (129073) 0x7cb03eaa0a07df70 (addr 52141): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
    2024-01-04 08:46:50.681  - info: zigbee.0 (129073) 0xb4e3f9fffe8119c5 (addr 52016): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
    2024-01-04 08:46:50.685  - info: zigbee.0 (129073) 0xb4e3f9fffe810ccf (addr 7537): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
    2024-01-04 08:46:50.690  - info: zigbee.0 (129073) 0x00158d00068b6d42 (addr 4761): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2024-01-04 08:46:50.693  - info: zigbee.0 (129073) 0x00158d00069c5148 (addr 61445): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2024-01-04 08:46:50.697  - info: zigbee.0 (129073) 0x00158d00069d3207 (addr 54025): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2024-01-04 08:46:50.701  - info: zigbee.0 (129073) 0x00158d00047dd980 (addr 56066): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2024-01-04 08:46:50.706  - info: zigbee.0 (129073) 0x00158d00069ae75b (addr 18976): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2024-01-04 08:46:50.712  - info: zigbee.0 (129073) 0x00158d00069c52b6 (addr 10299): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2024-01-04 08:46:50.716  - info: zigbee.0 (129073) 0x00158d00053fad60 (addr 54656): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2024-01-04 08:46:50.720  - info: zigbee.0 (129073) 0x00158d000659e158 (addr 22041): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2024-01-04 08:46:50.723  - info: zigbee.0 (129073) Zigbee started
    2024-01-04 08:46:50.937  - info: zigbee.0 (129073) debug devices set to []
    2024-01-04 08:47:10.049  - warn: zigbee.0 (129073) DeviceAvailability:Failed to ping 0x7cb03eaa0a07df70 Classic A60 W clear - LIGHTIFY
    2024-01-04 09:18:02.612  - warn: zigbee.0 (129073) DeviceAvailability:Stopping to ping 0x7cb03eaa0a07df70 Classic A60 W clear - LIGHTIFY after 4 ping attempts
    2024-01-04 09:28:52.925  - warn: zigbee.0 (129073) Device '0x7cb03eaa0a07df70' announced itself
    iob diag has finished.
    Log sagt nichts, da ich das Update irgendwann abbreche, weil es nicht weiter geht.
    host.raspberrypi
    2024-01-04 09:34:57.508	info	iobroker Installing iobroker.zigbee@1.9.5... (System call)
    host.raspberrypi
    2024-01-04 09:34:57.504	info	iobroker NPM version: 10.2.3
    host.raspberrypi
    2024-01-04 09:34:56.787	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.raspberrypi
    2024-01-04 09:34:56.225	info	stopInstance system.adapter.zigbee.0 killing pid 129073
    host.raspberrypi
    2024-01-04 09:34:55.220	info	stopInstance system.adapter.zigbee.0 send kill signal
    host.raspberrypi
    2024-01-04 09:34:55.108	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
    host.raspberrypi
    2024-01-04 09:34:55.103	info	"system.adapter.zigbee.0" disabled
    host.raspberrypi
    2024-01-04 09:34:55.087	info	iobroker host.raspberrypi Adapter "system.adapter.zigbee.0" is stopped.
    host.raspberrypi
    2024-01-04 09:34:55.025	info	iobroker Update zigbee from @1.8.23 to @1.9.5
    host.raspberrypi
    2024-01-04 09:34:50.295	info	iobroker upgrade zigbee@1.9.5 --debug
    #705
    @djsirius sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
    Dein Dateisystem hat 'nen Treffer.
    Update den js-controller.
    • DJMarc75D DJMarc75
      @djsirius
      So am Rande: auf einem RPI3 mit 1 GB RAM sind 30+ aktive Instanzen mehr als sportlich.
      Dir geht definitiv der Speicher aus.
      djsirius
      #706
      @djmarc75 auf dem System laufen nur 3 Instanzen, es handelt sich hierbei um ein Slave.
      djsirius
        Dann lass es einfach mal laufen...
        djsirius
        #707
        @thomas-braun Ich habe das Update um 09:34 gestartet und es hängt noch immer. :-(
        djsirius
        • D djsirius
          #708
          Nein, das läuft noch immer. Finger weg, laufen lassen.
            djsirius
            schrieb am zuletzt editiert von djsirius
            #709
            Es hat sich nichts mehr getan. Hab jetzt versucht auf meinem Master den js-controller zu updaten.
            Leider bleibt er auch hängen.
            /opt/iobroker$ iob upgrade self
            Update js-controller from @4.0.24 to @5.0.17
            Stopped Objects DB
            Stopped States DB
            NPM version: 10.2.3
            Installing iobroker.js-controller@5.0.17... (System call)
            djsirius
            • D djsirius
              Stopped Objects DB
              Stopped States DB
              NPM version: 10.2.3
              #710
              @djsirius dann mach es mal mit --debug
                djsirius
                #711
                @homoran keine Veränderung
                iobroker@debian:~$ cd /opt/iobroker
                iobroker@debian:/opt/iobroker$ iobroker stop
                iobroker@debian:/opt/iobroker$ iob upgrade self --debug
                Stopped Objects DB
                Stopped States DB
                NPM version: 10.2.3
                djsirius
                • D djsirius
                  Stopped Objects DB
                  Stopped States DB
                  NPM version: 10.2.3
                  #712
                  keine Veränderung
                  was bedeutet
                  denn in Zahlen?
                  wie sieht es denn
                  auf meinem Master
                  mit iob diag aus?
                  was ist das für ein Rechner?
                  hast du mal eine zweite Terminalsession aufgemacht und z.B. mit top nachgesehen was da gerade rödelt?
                    keine Veränderung
                    was bedeutet
                    denn in Zahlen?
                    wie sieht es denn
                    auf meinem Master
                    mit iob diag aus?
                    djsirius
                    #713
                    @homoran said in Diskussion zum HowTo nodejs-Installation und upgrade:
                    iob diag
                    ich habe das update für den js-controller über eine Terminalverbindung gemacht. Da Update bleibt einfach stehen. Ich bekomme weiter nichts angezeigt. Nach Installing iobroker.js-controller@5.0.17... (System call)
                    geht es nicht weiter. Bis ich das Update abbreche.
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                       Static hostname: debian
                             Icon name: computer-desktop
                               Chassis: desktop
                                Kernel: Linux 5.10.0-26-amd64
                          Architecture: x86-64
                    model name      : Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                     13:50:42 up 18:23,  1 user,  load average: 0.00, 0.00, 0.01
                    CPU threads: 4
                                   Local time: Thu 2024-01-04 13:50:42 CET
                               Universal time: Thu 2024-01-04 12:50:42 UTC
                                     RTC time: Thu 2024-01-04 12:50:42
                                  NTP service: active
                              RTC in local TZ: no
                    iobroker
                    /home/iobroker
                    iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            7.9G        201M        6.9G        5.0M        740M        7.4G
                    Swap:           4.0G          0B        4.0G
                    Total:           11G        201M         10G
                             7864 M total memory
                              201 M used memory
                              377 M active memory
                              392 M inactive memory
                             6923 M free memory
                               85 M buffer memory
                              655 M swap cache
                             4015 M total swap
                                0 M used swap
                             4015 M free swap
                      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                    * iobroker.service loaded failed failed ioBroker Server
                    1 loaded units listed.
                    *** FILESYSTEM ***
                    Filesystem                         Type      Size  Used Avail Use% Mounted on
                    udev                               devtmpfs  3.9G     0  3.9G   0% /dev
                    tmpfs                              tmpfs     787M  2.5M  785M   1% /run
                    /dev/sda2                          ext4      454G   44G  387G  11% /
                    tmpfs                              tmpfs     3.9G     0  3.9G   0% /dev/shm
                    /dev/sda1                          vfat      511M  5.8M  506M   2% /boot/efi
                    //192.168.1.1/GLADYS7490/TREKSTOR/ cifs      467G  353G  114G  76% /media/fritzbox
                    tmpfs                              tmpfs     787M   40K  787M   1% /run/user/1000
                    [Wed Jan  3 19:27:32 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Jan  3 19:27:39 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
                    /                 /dev/sda2                          ext4   rw,relatime,errors=remount-ro
                    |-/media/fritzbox //192.168.1.1/GLADYS7490/TREKSTOR/ cifs   rw,relatime,vers=1.0,cache=strict,username=mount,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.1.1,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=61440,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1
                    `-/boot/efi       /dev/sda1                          vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
                    /var:
                    7.3G    /var/
                    4.1G    /var/log
                    4.0G    /var/log/journal/f063d3dd2a6e40efad76adb6a70d9daf
                    2.4G    /var/cache/apt
                    Archived and active journals take up 3.6G in the file system.
                    115M    /opt/iobroker/backups/
                    1.1G    /opt/iobroker/iobroker-data/
                    600M    /opt/iobroker/iobroker-data/files
                    357M    /opt/iobroker/iobroker-data/backup-objects
                    73M     /opt/iobroker/iobroker-data/files/telegram.admin
                    67M     /opt/iobroker/iobroker-data/files/javascript.admin
                    60M     /opt/iobroker/iobroker-data/states.jsonl
                    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                    31M     /opt/iobroker/iobroker-data/objects.jsonl
                    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
                    USB-Devices by-id:
                    find: '/dev/serial/by-id/': No such file or directory
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                            500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages
                            500 http://deb.debian.org/debian bullseye/main amd64 Packages
                    Errors in npm tree:
                    npm ERR! code ELSPROBLEMS
                    npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                    npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                    npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                    npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
                    npm ERR! invalid: iobroker.openligadb@1.3.4 /opt/iobroker/node_modules/iobroker.openligadb
                    npm ERR! invalid: iobroker.tibberconnect@0.0.10 /opt/iobroker/node_modules/iobroker.tibberconnect
                    npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
                    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                    npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                    npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                    npm ERR! extraneous: typescript@5.2.2 /opt/iobroker/node_modules/typescript
                    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                    npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
                    npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
                    npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
                    npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
                    npm ERR! invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-04T12_51_00_273Z-debug-0.log
                    ioBroker Status
                    iobroker is not running on this host.
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.6
                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-04T12_51_19_738Z-debug-0.log
                    Adapters from github:   2
                    Adapter State
                      system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled, port: /dev/ttyUSB0
                    + instance is alive
                    Adapter    "alexa2"       : 3.26.3   , installed 3.26.2 [Updatable]
                    Adapter    "backitup"     : 2.9.8    , installed 2.8.7  [Updatable]
                    Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
                    Adapter    "devices"      : 1.1.5    , installed 1.1.5
                    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                    Adapter    "ical"         : 1.13.3   , installed 1.13.3
                    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                    Adapter    "info"         : 2.0.0    , installed 2.0.0
                    Adapter    "iot"          : 2.0.11   , installed 2.0.11
                    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                    Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
                    Adapter    "linux-control": 1.1.5    , installed 1.1.5
                    Adapter    "logparser"    : 2.2.0    , installed 2.2.0
                    Adapter    "meross"       : 1.16.1   , installed 1.16.1
                    Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
                    Adapter    "modbus"       : 6.0.1    , installed 6.0.1
                    Adapter    "openligadb"   : 1.2.4    , installed 1.3.4
                    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                    Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
                    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                    Adapter    "text2command" : 3.0.2    , installed 3.0.2
                    Adapter    "tibberlink"   : 2.0.0    , installed 2.0.0
                    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                    Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
                    Adapter    "vis"          : 1.5.4    , installed 1.5.4
                    Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
                    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                    Adapter    "web"          : 6.1.10   , installed 6.1.10
                    Adapter    "ws"           : 2.5.8    , installed 2.5.8
                    Objects and States
                    Objects:        27978
                    States:         22605
                    Hit:1 http://ftp.de.debian.org/debian bullseye InRelease
                    Hit:2 http://ftp.de.debian.org/debian bullseye-updates InRelease
                    Hit:3 http://deb.debian.org/debian bullseye InRelease
                    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:5 http://deb.debian.org/debian bullseye-backports InRelease
                    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Hit:7 https://packages.sury.org/php bullseye InRelease
                    Hit:8 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                    Pending Updates: 0
                    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          16729      808/smbd
                    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          16730      808/smbd
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          618        1/init
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1719       509/sshd: /usr/sbin
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1073875    562579/cupsd
                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          17439      800/exim4
                    tcp6       0      0 :::443                  :::*                    LISTEN      0          1851       787/apache2
                    tcp6       0      0 :::445                  :::*                    LISTEN      0          16727      808/smbd
                    tcp6       0      0 :::139                  :::*                    LISTEN      0          16728      808/smbd
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          622        1/init
                    tcp6       0      0 :::80                   :::*                    LISTEN      0          1847       787/apache2
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          1721       509/sshd: /usr/sbin
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1073874    562579/cupsd
                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          17440      800/exim4
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1076452    562586/cups-browsed
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        1609       419/avahi-daemon: r
                    udp        0      0 0.0.0.0:59503           0.0.0.0:*                           112        1611       419/avahi-daemon: r
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          619        1/init
                    udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          18480      538/nmbd
                    udp        0      0 192.168.1.16:137        0.0.0.0:*                           0          18479      538/nmbd
                    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          18460      538/nmbd
                    udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          18482      538/nmbd
                    udp        0      0 192.168.1.16:138        0.0.0.0:*                           0          18481      538/nmbd
                    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          18461      538/nmbd
                    udp6       0      0 fe80::ca9c:dcff:fee:546 :::*                                0          16340      422/NetworkManager
                    udp6       0      0 :::5353                 :::*                                112        1610       419/avahi-daemon: r
                    udp6       0      0 :::59025                :::*                                112        1612       419/avahi-daemon: r
                    udp6       0      0 :::111                  :::*                                0          625        1/init
                    2024-01-04 13:18:36.279  - info: host.debian instance system.adapter.linux-control.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    2024-01-04 13:18:36.298  - info: host.debian instance system.adapter.pollenflug.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    2024-01-04 13:18:36.341  - info: host.debian instance system.adapter.simple-api.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    2024-01-04 13:18:36.341  - info: host.debian instance system.adapter.socketio.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    2024-01-04 13:18:36.360  - info: host.debian instance system.adapter.terminal.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    2024-01-04 13:18:36.377  - info: host.debian instance system.adapter.trashschedule.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    2024-01-04 13:18:36.406  - info: host.debian instance system.adapter.viessmannapi.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    2024-01-04 13:18:36.423  - info: host.debian instance system.adapter.logparser.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    2024-01-04 13:18:36.460  - info: host.debian instance system.adapter.hm-rpc.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    2024-01-04 13:18:36.460  - info: host.debian instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    2024-01-04 13:18:36.494  - info: host.debian instance system.adapter.iot.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    2024-01-04 13:18:36.821  - info: host.debian instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    2024-01-04 13:18:36.839  - warn: host.debian instance system.adapter.telegram.0 terminated due to SIGTERM
                    2024-01-04 13:18:36.839  - info: host.debian instance system.adapter.telegram.0 terminated with code null ()
                    2024-01-04 13:18:36.861  - warn: host.debian instance system.adapter.ping.0 terminated due to SIGTERM
                    2024-01-04 13:18:36.861  - info: host.debian instance system.adapter.ping.0 terminated with code null ()
                    2024-01-04 13:18:36.885  - warn: host.debian instance system.adapter.text2command.0 terminated due to SIGTERM
                    2024-01-04 13:18:36.885  - info: host.debian instance system.adapter.text2command.0 terminated with code null ()
                    2024-01-04 13:18:36.902  - info: host.debian instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    2024-01-04 13:18:36.946  - info: host.debian instance system.adapter.sql.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    2024-01-04 13:18:36.946  - info: host.debian instance system.adapter.history.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    2024-01-04 13:18:37.290  - info: meross.0 (1962438) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2024-01-04 13:18:37.909  - info: host.debian instance system.adapter.meross.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                    2024-01-04 13:18:37.909  - info: host.debian All instances are stopped.
                    2024-01-04 13:18:38.089  - info: host.debian terminated
                    djsirius
                    HomoranH Thomas BraunT 3 Antworten Letzte Antwort
                    • D djsirius
                      iob diag
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                                 Chassis: desktop
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : amd64
                      CPU threads: 4
                                    NTP service: active
                                RTC in local TZ: no
                      iobroker
                      /home/iobroker
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:           4.0G          0B        4.0G
                      Total:           11G        201M         10G
                               7864 M total memory
                                201 M used memory
                                377 M active memory
                               6923 M free memory
                                 85 M buffer memory
                                655 M swap cache
                               4015 M total swap
                                  0 M used swap
                               4015 M free swap
                      *** FILESYSTEM ***
                      /var:
                      7.3G    /var/
                      4.1G    /var/log
                      2.4G    /var/cache/apt
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.0
                      javascript:     7.1.6
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        27978
                      States:         22605
                      Pending Updates: 0
                      #714
                      soweit ist das bekannt!
                      Die fehlenden Antworten auf die Fragen
                      • Wie lange hast du gewartet?
                      • hast du mit einer zweiten Session nachgesehen was da klemmt?
                      • wie sieht iob diag auf dem Master aus
                      bitte nachreichen
                      • D djsirius
                        iob diag
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                   Chassis: desktop
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : amd64
                        CPU threads: 4
                                      NTP service: active
                                  RTC in local TZ: no
                        iobroker
                        /home/iobroker
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:           4.0G          0B        4.0G
                        Total:           11G        201M         10G
                                 7864 M total memory
                                  201 M used memory
                                  377 M active memory
                                 6923 M free memory
                                   85 M buffer memory
                                  655 M swap cache
                                 4015 M total swap
                                    0 M used swap
                                 4015 M free swap
                        *** FILESYSTEM ***
                        /var:
                        7.3G    /var/
                        4.1G    /var/log
                        2.4G    /var/cache/apt
                        USB-Devices by-id:
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.12.0
                        javascript:     7.1.6
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        27978
                        States:         22605
                        Pending Updates: 0
                        #715
                        da läuft ja nix
                        Probleme mit npm?
                        s.o.
                        • D djsirius
                          iob diag
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                     Chassis: desktop
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : amd64
                          CPU threads: 4
                                        NTP service: active
                                    RTC in local TZ: no
                          iobroker
                          /home/iobroker
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:           4.0G          0B        4.0G
                          Total:           11G        201M         10G
                                   7864 M total memory
                                    201 M used memory
                                    377 M active memory
                                   6923 M free memory
                                     85 M buffer memory
                                    655 M swap cache
                                   4015 M total swap
                                      0 M used swap
                                   4015 M free swap
                          *** FILESYSTEM ***
                          /var:
                          7.3G    /var/
                          4.1G    /var/log
                          2.4G    /var/cache/apt
                          USB-Devices by-id:
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.12.0
                          javascript:     7.1.6
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        27978
                          States:         22605
                          Pending Updates: 0
                          #716
                          Installier die beiden Adapter nochmal. Am besten NICHT über github, sondern eine 'ordentliche' Installation aus einem Repo.
                            da läuft ja nix
                            Probleme mit npm?
                            s.o.
                            djsirius
                            #717
                            da läuft ja nix
                            Probleme mit npm?
                            s.o.
                            Ich habe den iobroker gestoppt um das Update vom js-controller zu machen. Ist das falsch?
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                       Chassis: desktop
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : amd64
                             15:01:52 up 19:34,  1 user,  load average: 0.37, 0.48, 0.28
                            CPU threads: 4
                                           Local time: Thu 2024-01-04 15:01:52 CET
                                       Universal time: Thu 2024-01-04 14:01:52 UTC
                                             RTC time: Thu 2024-01-04 14:01:52
                                          NTP service: active
                                      RTC in local TZ: no
                            iobroker
                            /home/iobroker
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            7.9G        2.8G        3.9G        5.0M        1.1G        4.7G
                            Swap:           4.0G          0B        4.0G
                            Total:           11G        2.8G        7.9G
                                     7864 M total memory
                                     2838 M used memory
                                      684 M active memory
                                     2912 M inactive memory
                                     3928 M free memory
                                      121 M buffer memory
                                      976 M swap cache
                                     4015 M total swap
                                        0 M used swap
                                     4015 M free swap
                            *** FILESYSTEM ***
                            /var:
                            7.3G    /var/
                            4.1G    /var/log
                            2.4G    /var/cache/apt
                            70M     /opt/iobroker/iobroker-data/states.jsonl
                            34M     /opt/iobroker/iobroker-data/objects.jsonl
                            USB-Devices by-id:
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-04T14_01_54_476Z-debug-0.log
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.12.0
                            javascript:     7.1.6
                            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-04T14_02_02_971Z-debug-0.log
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        27978
                            States:         22662
                            Pending Updates: 0
                            tcp        0      0 192.168.1.16:8701       0.0.0.0:*               LISTEN      1000       3906617    2073310/io.hm-rpc.1
                            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       3901948    2072931/iobroker.js
                            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       3901937    2072931/iobroker.js
                            tcp        0      0 192.168.1.16:2001       0.0.0.0:*               LISTEN      1000       3903816    2073084/io.hm-rpc.0
                            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       3904358    2073336/io.shelly.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       3903614    2072950/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1000       3914125    2076273/io.web.0
                            tcp6       0      0 :::8084                 :::*                    LISTEN      1000       3910869    2074746/io.socketio
                            tcp6       0      0 :::8087                 :::*                    LISTEN      1000       3910040    2074489/io.simple-a
                            tcp6       0      0 :::8088                 :::*                    LISTEN      1000       3911944    2075331/io.terminal
                            udp        0      0 192.168.1.16:5353       0.0.0.0:*                           1000       3906800    2073282/io.tr-064.0
                            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       3915805    2075908/io.upnp.0
                            udp        0      0 0.0.0.0:57375           0.0.0.0:*                           1000       3912188    2075908/io.upnp.0
                            udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       3905755    2073211/io.mihome-v
                            2024-01-04 14:57:07.416  - info: lg-thinq.0 (2076539) MQTT connected to: t20/op/4859c133c7b998076e20059473cf71b1ebd27dfe4321c9740a3ce75973cbbf5a/inbox
                            2024-01-04 14:57:08.267  - info: host.debian instance system.adapter.tibberlink.0 started with pid 2076872
                            2024-01-04 14:57:09.704  - info: tibberlink.0 (2076872) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.tibberlink, node: v18.19.0, js-controller: 4.0.24
                            2024-01-04 14:57:28.874  - info: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: Error: Device has no data connection available
                            2024-01-04 14:57:28.875  - warn: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: undefined
                            2024-01-04 14:58:35.018  - info: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: Error: Device has no data connection available
                            2024-01-04 14:58:35.019  - warn: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: undefined
                            2024-01-04 14:59:41.163  - info: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: Error: Device has no data connection available
                            2024-01-04 14:59:41.163  - warn: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: undefined
                            2024-01-04 15:00:00.028  - info: host.debian instance system.adapter.dwd.0 started with pid 2083021
                            2024-01-04 15:00:00.155  - info: javascript.0 (2072992) script.js.Speedtest: Speedtest mit Server 44081 gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
                            2024-01-04 15:00:01.308  - info: dwd.0 (2083021) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 4.0.24
                            2024-01-04 15:00:03.904  - info: dwd.0 (2083021) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2024-01-04 15:00:04.035  - info: host.debian instance system.adapter.daswetter.0 started with pid 2083350
                            2024-01-04 15:00:04.455  - info: host.debian instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2024-01-04 15:00:05.306  - info: daswetter.0 (2083350) starting. Version 3.1.11 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.19.0, js-controller: 4.0.24
                            2024-01-04 15:00:13.817  - info: daswetter.0 (2083350) still wrong data structure from server received! repaired...
                            2024-01-04 15:00:15.732  - info: daswetter.0 (2083350) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                            2024-01-04 15:00:16.243  - info: daswetter.0 (2083350) cleaned everything up...
                            2024-01-04 15:00:16.258  - info: host.debian instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2024-01-04 15:00:26.694  - info: javascript.0 (2072992) script.js.Speedtest: Speedtest durchgeführt. Ergebnisse: Download: 10.47 MB/s | Upload: 4.43 MB/s | Ping: 14.979ms
                            2024-01-04 15:00:47.306  - info: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: Error: Device has no data connection available
                            2024-01-04 15:00:47.307  - warn: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: undefined
                            2024-01-04 15:01:53.450  - info: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: Error: Device has no data connection available
                            2024-01-04 15:01:53.450  - warn: meross.0 (2073191) Can not get Data for Device 1912244352887225188148e1e9147e10: undefined
                            djsirius
                              djsirius
                              #718
                              @thomas-braun said in Diskussion zum HowTo nodejs-Installation und upgrade:
                              Kann das denn das Problem sein? Es ist doch vor dem Update von Nodejs und NPM ja auch gelaufen.
                              djsirius
                              • D djsirius
                                #719
                                Das sorgt jedenfalls für die angemeckerten npm errors.
                                  djsirius
                                  #720
                                  Weil z.B. Openligadb läuft Version aus dem repo nicht ohne Fehler.
                                  djsirius
                                  • D djsirius
                                    #721
                                    @djsirius
                                    Dann installier es nochmal aus github. Es muss aber halt nochmal frisch draufgebügelt werden.
                                      @djsirius
                                      djsirius
                                      #722
                                      @thomas-braun ich kann ja leider keine Adapter installieren, bzw. updaten, weil ja jede Installation bzw. Update stehen bleibt. Das ist ja mein Problem, seitdem ich Nodejs und NPM geupdatet habe. :-(
                                      djsirius
                                      • D djsirius
                                        #723
                                        @djsirius
                                        iob update && iob upgrade all -y --debug
                                        auf dem Host 'debian' sagt?
                                          @djsirius
                                          djsirius
                                          #724
                                          das habe ich auch schon versucht.
                                          iobroker@debian:~$ iob update && iob upgrade all -y --debug
                                          Update backitup from @2.8.7 to @2.9.8
                                          host.debian Adapter "system.adapter.backitup.0" is stopped.
                                          NPM version: 10.2.3
                                          Installing iobroker.backitup@2.9.8... (System call)
                                          Danach tut sich nichts mehr!
                                          djsirius
                                          Thomas BraunT D 2 Antworten Letzte Antwort
