  4. vis 1 läuft nicht mehr
    6.0k
43 Beiträge 7 Kommentatoren 5.3k Aufrufe 6 Beobachtet
    @max-0 sagte in vis 1 läuft nicht mehr:
    Was meinst du mit iob diag?
    bitte diesen Befehl in der Konsole ausführen, und die Ausgabe posten
    Bin neu hier
    Na, dann hab ich hier was für dich zu lesen
    Max 0M Offline
    Max 0M Offline
    Max 0
    @homoran Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: raspberrypi5
           Icon name: computer
              Kernel: Linux 6.1.0-rpi7-rpi-2712
        Architecture: arm64
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     20:46:18 up  1:07,  2 users,  load average: 0.72, 0.33, 0.17
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Fri 2023-12-29 20:46:18 CET
               Universal time: Fri 2023-12-29 19:46:18 UTC
                     RTC time: Fri 2023-12-29 19:46:18
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            8.4G        730M        5.3G        5.3M        2.5G        7.7G
    Swap:           104M          0B        104M
    Total:          8.5G        730M        5.4G
             8053 M total memory
              697 M used memory
              655 M active memory
             2052 M inactive memory
             5037 M free memory
              149 M buffer memory
             2270 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    vc_gencmd_read_response returned -1
    error=1 error_msg="Command not registered"
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  3.8G     0  3.8G   0% /dev
    tmpfs          tmpfs     806M  5.0M  801M   1% /run
    /dev/mmcblk0p2 ext4       15G  2.8G   11G  21% /
    tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
    tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
    [Fri Dec 29 19:38:43 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:BB:FC:13 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=0fd8a7d6-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Fri Dec 29 19:38:46 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Dec 29 19:38:49 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    [Fri Dec 29 19:38:53 2023] EXT4-fs (mmcblk0p2): resizing filesystem from 536576 to 3768320 blocks
    [Fri Dec 29 19:38:56 2023] EXT4-fs (mmcblk0p2): resized filesystem to 3768320
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    496M    /var/
    206M    /var/cache
    200M    /var/cache/apt
    166M    /var/lib
    132M    /var/lib/apt/lists
    Archived and active journals take up 24.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    67M     /opt/iobroker/iobroker-data/
    59M     /opt/iobroker/iobroker-data/files
    30M     /opt/iobroker/iobroker-data/files/web.admin/static
    29M     /opt/iobroker/iobroker-data/files/web.admin/static/js
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
    7.9M    /opt/iobroker/iobroker-data/objects.jsonl
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            9.2.0
    /usr/bin/npx            9.2.0
    /home/iobroker/.diag.sh: line 281: corepack: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 18.19.0+dfsg-6~deb12u1
      Candidate: 18.19.0+dfsg-6~deb12u1
      Version table:
     *** 18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
         18.19.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi5                             -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypi5                             -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Objects and States
    Objects:        173
    States:         131
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50870      14564/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50877      14564/iobroker.js-c
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17375      1863/sshd: /usr/sbi
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17377      1863/sshd: /usr/sbi
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       50986      14607/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       52618      14824/io.web.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        758        655/avahi-daemon: r
    udp        0      0 0.0.0.0:33709           0.0.0.0:*                           104        760        655/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        759        655/avahi-daemon: r
    udp6       0      0 fe80::aaec:1ab3:54b:546 :::*                                0          16660      775/NetworkManager
    udp6       0      0 :::54271                :::*                                104        761        655/avahi-daemon: r
    2023-12-29 20:25:11.316  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
    2023-12-29 20:25:11.368  - info: web.0 (14824) ==> Connected system.user.admin from ::ffff:192.168.178.109
    2023-12-29 20:25:19.295  - info: vis.0 (14869) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
    2023-12-29 20:25:19.897  - info: vis.0 (14869) Terminated (NO_ERROR): Without reason
    2023-12-29 20:25:20.416  - info: host.raspberrypi5 instance system.adapter.vis.0 terminated while should be started once
    2023-12-29 20:25:22.291  - info: vis.0 (14884) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
    2023-12-29 20:25:22.889  - info: vis.0 (14884) Terminated (NO_ERROR): Without reason
    2023-12-29 20:25:23.407  - info: host.raspberrypi5 instance system.adapter.vis.0 terminated while should be started once
    2023-12-29 20:28:33.981  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
    2023-12-29 20:28:59.713  - info: web.0 (14824) ==> Connected system.user.admin from ::ffff:192.168.178.109
    2023-12-29 20:29:12.782  - info: web.0 (14824) ==> Connected system.user.admin from ::ffff:192.168.178.196
    2023-12-29 20:35:24.724  - warn: web.0 (14824) State "dev3" has no existing object, this might lead to an error in future versions
    2023-12-29 20:35:25.626  - warn: web.0 (14824) State "dev3" has no existing object, this might lead to an error in future versions
    2023-12-29 20:35:26.397  - warn: web.0 (14824) State "dev1" has no existing object, this might lead to an error in future versions
    2023-12-29 20:35:27.843  - warn: web.0 (14824) State "dev2" has no existing object, this might lead to an error in future versions
    2023-12-29 20:35:28.846  - warn: web.0 (14824) State "dev2" has no existing object, this might lead to an error in future versions
    2023-12-29 20:35:30.206  - warn: web.0 (14824) State "dev2" has no existing object, this might lead to an error in future versions
    2023-12-29 20:35:37.405  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.196 vis.0
    2023-12-29 20:35:45.761  - info: web.0 (14824) ==> Connected system.user.admin from ::ffff:192.168.178.196
    2023-12-29 20:36:03.952  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.196 vis.0
    2023-12-29 20:36:05.291  - info: web.0 (14824) ==> Connected system.user.admin from ::ffff:192.168.178.196
    2023-12-29 20:38:36.455  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.196 vis.0
    2023-12-29 20:40:00.042  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
    2023-12-29 20:40:03.827  - info: web.0 (14824) ==> Connected system.user.admin from ::ffff:192.168.178.109
    2023-12-29 20:40:06.584  - info: web.0 (14824) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
    iob diag has finished.
    Press any key for a summary
    • Max 0M Max 0
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           104M          0B        104M
               8053 M total memory
                697 M used memory
                655 M active memory
               5037 M free memory
                149 M buffer memory
               2270 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      *** FILESYSTEM ***
      /var:
      496M    /var/
      206M    /var/cache
      200M    /var/cache/apt
      166M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            9.2.0
      /usr/bin/npx            9.2.0
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        173
      States:         131
      Pending Updates: 0
      hattest du das nicht gemacht?
      bitte iob nodejs-update ausführen, da ist anscheinend noch das alte repo aktiv
      das ist wahrscheinlich der Fehler
      https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur/10
      hiernach läuft vis tatsächlich nicht
      iob start vis
      Max 0M 1 Antwort Letzte Antwort
        iob start vis
        Max 0M Offline
        Max 0M Offline
        Max 0
        @homoran resizing filesystem from 536576 to 3768320 blocks
        was bedeutet dies und was müsste ich da machen?
        Den iob nodejs-update habe ich gemacht
        und den iob start vis auch. Funktioniert aber immer noch nicht
        Und was meinst du mit *** 18.19.0+dfsg-6~deb12u1 500 ?
        habe auf dem Link geschaut aber nichts gefunden
        • Max 0M Max 0
          Und
          iob diag
          sagt nun?
            Und
            iob diag
            sagt nun?
            Max 0M Offline
            Max 0M Offline
            Max 0
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : arm64
             23:07:00 up  3:28,  2 users,  load average: 0.12, 0.11, 0.11
            CPU threads: 4
            Current issues:
                           Local time: Fri 2023-12-29 23:07:00 CET
                       Universal time: Fri 2023-12-29 22:07:00 UTC
                             RTC time: Fri 2023-12-29 22:07:00
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input render netdev gp        io i2c spi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            8.4G        681M        5.3G        5.3M        2.6G        7.8G
            Swap:           104M          0B        104M
            Total:          8.5G        681M        5.4G
                     8053 M total memory
                      650 M used memory
                      607 M active memory
                     2104 M inactive memory
                     5031 M free memory
                      168 M buffer memory
                     2304 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            *** FILESYSTEM ***
            /dev/mmcblk0p2 ext4       15G  2.9G   11G  22% /
            [Fri Dec 29 19:38:43 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  s        msc95xx.macaddr=D8:3A:DD:BB:FC:13 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x4        0000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=0fd8a7d6-02 rootfsty        pe=ext4 fsck.repair=yes rootwait
            `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            548M    /var/
            260M    /var/cache
            254M    /var/cache/apt
            164M    /var/lib
            142M    /var/cache/apt/archives
            69M     /opt/iobroker/iobroker-data/
            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.m        ap
            6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js.map
            2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js
            USB-Devices by-id:
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            /usr/bin/corepack       0.22.0
            nodejs:
              Installed: 18.19.0-1nodesource1
              Candidate: 18.19.0-1nodesource1
              Version table:
                    500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
             *** 18.19.0-1nodesource1 1001
                 18.18.2-1nodesource1 1001
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0+dfsg1-1 500
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.12.0
            Adapter State
            + instance is alive
            Objects and States
            Objects:        180
            States:         138
            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
            Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
            Pending Updates: 0
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       73444      20322/iobroker.js-c
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       73451      20322/iobroker.js-c
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       72340      20340/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       71622      20397/io.web.0
            2023-12-29 22:54:09.429  - info: host.raspberrypi5 instance system.adapter.discovery.0 started with pid 20367
            2023-12-29 22:54:10.104  - info: discovery.0 (20367) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.0, js-controller: 5.0.17
            2023-12-29 22:54:13.424  - info: host.raspberrypi5 instance system.adapter.backitup.0 started with pid 20382
            2023-12-29 22:54:14.130  - info: backitup.0 (20382) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
            2023-12-29 22:54:14.155  - info: backitup.0 (20382) [iobroker] backup will be activated at 02:48 every 1 day(s)
            2023-12-29 22:54:14.294  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
            2023-12-29 22:54:17.427  - info: host.raspberrypi5 instance system.adapter.web.0 started with pid 20397
            2023-12-29 22:54:18.144  - info: web.0 (20397) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
            2023-12-29 22:54:18.209  - info: web.0 (20397) socket.io server listening on port 8082
            2023-12-29 22:54:18.211  - info: web.0 (20397) http server listening on port 8082
            2023-12-29 22:54:18.937  - info: admin.0 (20340) <== Disconnect system.user.admin from ::ffff:192.168.178.109 admin
            2023-12-29 22:54:19.521  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
            2023-12-29 22:54:22.126  - info: vis.0 (20412) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
            2023-12-29 22:54:22.725  - info: vis.0 (20412) Terminated (NO_ERROR): Without reason
            2023-12-29 22:54:23.277  - info: host.raspberrypi5 instance system.adapter.vis.0 terminated while should be started once
            2023-12-29 22:54:34.893  - info: web.0 (20397) ==> Connected system.user.admin from ::ffff:192.168.178.109
            2023-12-29 22:54:37.305  - info: web.0 (20397) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
            2023-12-29 22:55:06.666  - info: admin.0 (20340) <== Disconnect system.user.admin from ::ffff:192.168.178.109 admin
            2023-12-29 22:55:07.139  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
            2023-12-29 22:58:25.891  - info: admin.0 (20340) <== Disconnect system.user.admin from ::ffff:192.168.178.109 admin
            2023-12-29 22:58:26.369  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
            2023-12-29 23:06:22.986  - info: admin.0 (20340) <== Disconnect system.user.admin from ::ffff:192.168.178.109 admin
            2023-12-29 23:06:23.461  - info: admin.0 (20340) ==> Connected system.user.admin from ::ffff:192.168.178.109
            2023-12-29 23:06:27.503  - info: web.0 (20397) ==> Connected system.user.admin from ::ffff:192.168.178.109
            2023-12-29 23:06:29.257  - info: web.0 (20397) <== Disconnect system.user.admin from ::ffff:192.168.178.109 vis.0
            • Max 0M Max 0
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
              CPU threads: 4
              Current issues:
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:           104M          0B        104M
                       8053 M total memory
                        650 M used memory
                        607 M active memory
                       5031 M free memory
                        168 M buffer memory
                       2304 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              *** FILESYSTEM ***
              /var:
              548M    /var/
              260M    /var/cache
              254M    /var/cache/apt
              164M    /var/lib
              USB-Devices by-id:
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              nodejs:
                Version table:
                   18.13.0+dfsg1-1 500
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.12.0
              Adapter State
              + instance is alive
              Objects and States
              Objects:        180
              States:         138
              Pending Updates: 0
              @max-0
              nodejs passt.
                @max-0
                nodejs passt.
                Max 0M Offline
                Max 0M Offline
                Max 0
                @thomas-brau
                Und jetzt?
                Thomas BraunT sigi234S 2 Antworten Letzte Antwort
                • Max 0M Max 0
                  @thomas-brau
                  Und jetzt?
                  @max-0
                  Von vis hab ich keine Ahnung.
                  • Max 0M Max 0
                    @thomas-brau
                    Und jetzt?
                    sigi234S Online
                    sigi234S Online
                    @thomas-brau
                    Und jetzt?
                    Screenshot vom WEB Adapter bitte.
                    • Max 0M Max 0
                      was bedeutet dies u
                      dass du von deiner SD Karte nur einen Bruchteil genutzt hattest
                      die Anleitung mit wenigen Befehlen stand direkt im ersten Post.
                      Hat sich aber wohl inzwischen erledigt.
                      • OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        @max-0
                        Welcher browser?
                        Welsch Version?
                        Was sagen die Fehlermeldungen in der browserkonsole? Öffnen mit F12
                        Meine Adapter und Widgets
                        Links im Profil
                        • sigi234S sigi234
                          @thomas-brau
                          Und jetzt?
                          Max 0M Offline
                          Max 0M Offline
                          Max 0
                          • OliverIOO OliverIO
                            @max-0
                            Welcher browser?
                            Welsch Version?
                            Max 0M Offline
                            Max 0M Offline
                            Max 0
                            @oliverio
                            Ich benutze den Opera browser
                            Opera Version 105.0.4970.63
                            Und hier die browserkonsole:
                            2023-12-30T10:48:23.961Z Connected => authenticate
                            data:application/json;charset=8{"name":"ioBroker vis","short_name":"vis","start_url":".#main/%22,%22display%22:%22standalone%22,%22background_color%22:%22#ffffff%22,%22description%22:%22WEB%20visualisation%20for%20ioBroker%20platform%22,%22icons%22:[{%22src%22:%22img/vis.png%22,%22sizes%22:%22192x192%22,%22type%22:%22image/png%22}]}:1
                                   Failed to load resource: net::ERR_INVALID_URL
                            conn.js:331 2023-12-30T10:48:24.070Z Authenticated: true
                            vis.js:3595 Create inner vis object demoTemperature
                            vis.js:3595 Create inner vis object demoHumidity
                            translate.js:20 "Use background": {"en": "Use background", "de": "Use background", "ru": "Use background"},
                            edit.html:1 Uncaught SyntaxError: Unexpected non-whitespace character after JSON at position 2 (line 1 column 3)
                                at JSON.parse (<anonymous>)
                                at Object.unserialize (loStorage.js:2:567)
                                at r.get (loStorage.js:2:1871)
                                at Function.get (loStorage.js:2:2346)
                                at Object.bindInstance (vis.js:576:54)
                                at Object.initNext (vis.js:705:14)
                                at Object.<anonymous> (vis.js:603:18)
                                at Object.loadWidgetSets (vis.js:568:34)
                                at Object.init (vis.js:602:14)
                                at vis.js:3661:29
                              was bedeutet dies u
                              Max 0M Offline
                              Max 0M Offline
                              Max 0
                              Hat das Auswirkungen das ich nur ein Bruchteil meiner SD Karte nutze?
                              Was kann ich dagegen tun?
                              DJMarc75D HomoranH 2 Antworten Letzte Antwort
                              • Max 0M Max 0
                                sigi234S Online
                                sigi234S Online
                                Haken setzen bei reine Websockes ....
                                • Max 0M Max 0
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  Im Terminal
                                  sudo raspi-config
                                  eingeben.
                                  Dann
                                  Zuletzt den Raspberry rebooten.
                                  Lehrling seit 1975 !!!
                                  • Max 0M Max 0
                                    ist doch jetzt passiert
                                    • DJMarc75D DJMarc75
                                      Im Terminal
                                      sudo raspi-config
                                      eingeben.
                                      Dann
                                      Max 0M Offline
                                      Max 0M Offline
                                      Max 0
                                      schrieb am zuletzt editiert von Max 0
                                      @djmarc75
                                      Habe ich gemacht
                                      Und jetzt?
                                      • Max 0M Offline
                                        Max 0M Offline
                                        Max 0
                                        Vlt hilft das
                                        • Max 0M Max 0
                                          Vlt hilft das
                                          Vlt hilft das
                                          als Text in code-tags wäre es besser.
                                          was willst du damit zeigen?
