  4. Server Cannot start inMem-objects on port 9001:
70 Beiträge 4 Kommentatoren 8.6k Aufrufe 3 Beobachtet
    @alex-smarthome
    Da ist aber einiges krumm...
    sudo apt remove node-*
    sudo apt autoremove
    iob diag
    Alex-Smarthome
    @thomas-braun Nachdem ich jetzt gefühlte 1000 mal mein PW eingebenmusste, geht es immernoch nicht.
    alexander@debian-IoBrocker:~$ iob fix
    library: loaded
    Library version=2023-10-13
        Welcome to the ioBroker installation fixer!
        Script version: 2023-10-13
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    [sudo] Passwort für alexander:
    Sorry, user alexander is not allowed to execute '/usr/bin/apt-get update' as root on debian-IoBrocker.fritz.box.
    Das hat nicht funktioniert, bitte nochmal probieren.
    Sorry, user alexander is not allowed to execute '/usr/sbin/setcap cap_net_admin,cap_net_bind_service,cap_net_raw+eip /usr/bin/node' as root on debian-IoBrocker.fritz.box.
        Checking ioBroker user and directory permissions (2/5)
    Sorry, user alexander is not allowed to execute '/usr/sbin/usermod -a -G iobroker alexander' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/rm -f /etc/sudoers.d/iobroker' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/sbin/visudo -c -q -f /home/alexander/temp_sudo_file' as root on debian-IoBrocker.fritz.box.
    sudo: 3 Fehlversuche bei der Passwort-Eingabe
    rrDas hat nicht funktioniert, bitte nochmal probieren.
    Sorry, user alexander is not allowed to execute '/usr/sbin/usermod -a -G dialout iobroker' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/sbin/usermod -a -G tty iobroker' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/sbin/usermod -a -G video iobroker' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/touch .npmrc' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/grep -v -E ^audit=true .npmrc' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/chown -R alexander:alexander .npmrc' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/grep -v -E ^update-notifier=true .npmrc' as root on debian-IoBrocker.fritz.box.
    main: Zeile 596: /home/alexander/.iobroker/iobroker_completions: Datei oder Verzeichnis nicht gefunden
    Sorry, user alexander is not allowed to execute '/usr/bin/grep -v -E ^engine-strict=false .npmrc' as root on debian-IoBrocker.fritz.box.
    main: Zeile 509: /home/alexander/.iobroker/npm_command_fix: Datei oder Verzeichnis nicht gefunden
    Sorry, user alexander is not allowed to execute '/usr/bin/mkdir -p /root/.iobroker' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/touch /root/.bashrc' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/chown -R iobroker:iobroker /opt/iobroker' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/chown -R iobroker:iobroker /home/iobroker/.npm' as root on debian-IoBrocker.fritz.box.
    This system does not support setting default permissions.
    Do not use npm to manually install adapters unless you know what you are doing!
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Sorry, user alexander is not allowed to execute '/usr/bin/npm x --yes @iobroker/jsonltool@latest /opt/iobroker/iobroker-data' as iobroker on debian-IoBrocker.fritz.box.
        Checking autostart (5/5)
    Sorry, user alexander is not allowed to execute '/usr/bin/rm /lib/systemd/system/iobroker.service' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/systemctl daemon-reload' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/rm -f /opt/iobroker/iobroker' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/rm -f /usr/bin/iobroker' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/rm -f /opt/iobroker/iob' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/rm -f /usr/bin/iob' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/ln -sfn /opt/iobroker/iobroker /usr/bin/iobroker' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/ln -sfn /opt/iobroker/iobroker /usr/bin/iob' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/chmod 755 /opt/iobroker/iobroker' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/chown iobroker:iobroker /opt/iobroker/iobroker' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/chown -h iobroker:iobroker /opt/iobroker/iob' as root on debian-IoBrocker.fritz.box.
    Enabling autostart...
    Sorry, user alexander is not allowed to execute '/usr/bin/chown root:root /lib/systemd/system/iobroker.service' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/chmod 644 /lib/systemd/system/iobroker.service' as root on debian-IoBrocker.fritz.box.
    Sorry, user alexander is not allowed to execute '/usr/bin/systemctl enable iobroker' as root on debian-IoBrocker.fritz.box.
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    alexander@debian-IoBrocker:~$ iobroker start
    alexander@debian-IoBrocker:~$ iob status
    <--- Last few GCs --->
    [13576:0x5dcc870]    17388 ms: Mark-sweep (reduce) 2047.4 (2068.7) -> 2046.4 (2065.5) MB, 5.3 / 0.0 ms  (+ 12.4 ms in 6 steps since start of marking, biggest step 10.2 ms, walltime since start of marking 22 ms) (average mu = 0.437, current mu = 0.371) fin[13576:0x5dcc870]    17423 ms: Mark-sweep (reduce) 2047.8 (2066.4) -> 2047.2 (2066.1) MB, 17.2 / 0.0 ms  (+ 11.3 ms in 15 steps since start of marking, biggest step 11.1 ms, walltime since start of marking 31 ms) (average mu = 0.316, current mu = 0.204) a
    <--- JS stacktrace --->
    FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
     1: 0xb95b60 node::Abort() [node]
     2: 0xa9a7f8  [node]
     3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [node]
     4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [node]
     5: 0xf4cba5  [node]
     6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [node]
     7: 0xf3978e v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node]
     8: 0xf3ab57 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node]
     9: 0xf1b0a0 v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [node]
    10: 0xf12b14 v8::internal::FactoryBase<v8::internal::Factory>::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [node]
    11: 0xf14ea8 v8::internal::FactoryBase<v8::internal::Factory>::NewRawTwoByteString(int, v8::internal::AllocationType) [node]
    12: 0xf1e35c v8::internal::Factory::NewStringFromUtf8(v8::base::Vector<char const> const&, v8::internal::AllocationType) [node]
    13: 0xd7e3a3 v8::String::NewFromUtf8(v8::Isolate*, char const*, v8::NewStringType, int) [node]
    14: 0xc84d71  [node]
    15: 0xc84e8d node::StringDecoder::DecodeData(v8::Isolate*, char const*, unsigned long*) [node]
    16: 0xc8545e  [node]
    17: 0x169372f  [node]
    /usr/bin/iob: Zeile 12: 13569 Abgebrochen             sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
      @alex-smarthome
      sudo apt autoremove
      iob diag
      Alex-Smarthome
      @thomas-braun said in Server Cannot start inMem-objects on port 9001::
      @alex-smarthome
      sudo apt autoremove
      iob diag
      Konnte das nur unter root ausführen, ind immernoch das gleiche Problem, root zuviele Rechte, User zuwenig rechte.
      alexander@debian-IoBrocker:~$ sudo apt remove node-*
      Sorry, user alexander is not allowed to execute '/usr/bin/apt remove node-*' as root on debian-IoBrocker.fritz.box.
      Passwort:
      root@debian-IoBrocker:/home/alexander# sudo apt remove node-*
      Hinweis: »node-types-postcss-reporter« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-d3-chord« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-elliptic« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.after« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-natural-sort« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-plur« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-pikaday« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-istanbul-lib-hook« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-camelcase-keys« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-responselike« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-inline-source-map« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-vega-scenegraph« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-querystringify« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-raw-body« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-d3-hierarchy« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-css-tree« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-babel-code-frame« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-picocolors« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-string-length« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-minimatch« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-uni-global« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-promise« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-minify-numeric-literals« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-destroy« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.last« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-source-map« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.stubarray« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-transformers« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-channels« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-minify-flip-comparisons« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-expand-brackets« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-jest-expect« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-stylus« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-module-not-found-error« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-highlight.js« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-d3-selection« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-bind-obj-methods« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-util-deprecate« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-consolidate« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-object-hash« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-jest-mock« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-normalize-git-url« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-bluebird« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-config-chain« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-map-age-cleaner« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-tap-mocha-reporter« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-xoauth2« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-postcss« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-addon-api« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.spread« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-basic-auth« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-type-fest« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-vega-voronoi« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-discoveryjs-json-ext« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.assignin« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-nouislider-doc« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-imagemagick« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-utf-8-validate« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-handlebars« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.xor« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.isnative« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-v8-to-istanbul« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-d3-format« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-dryice« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-temp-dir« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-acorn« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.pullallwith« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-wikibase-sdk« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-async-settle« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-security« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.random« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-mysticatea-eslint-plugin« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-collect-v8-coverage« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-big.js« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-core« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-split-string« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.trimstart« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-yargs-unparser« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-tsconfig-node10« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-tsconfig-node12« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-tsconfig-node14« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-tsconfig-node16« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-tsconfig-node18« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-yocto-queue« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-glob-stream« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-coffeescript« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-jstimezonedetect« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-walker« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-triple-beam« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-errs« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-core-js-builder« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-charcodes« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-nouislider« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-essentials« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.tosafeinteger« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.isarguments« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-constantinople« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-syntax-do-expressions« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-resolve« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-ensure-posix-path« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-change-case« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.remove« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-reserved« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.method« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-es-abstract« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-concat-map« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.zip« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.flattendepth« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.stubfalse« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-registry-url« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-cssom« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-requirejs-text« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-assertion-error« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-make-iterator« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-postgres-array« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-node« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-proposal-class-static-block« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-proposal-optional-chaining« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.findkey« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-commondir« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-date-time« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-applause« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-etag« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-esrecurse« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-fast-diff« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-deep-for-each« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-combine-source-map« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-through2-filter« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-istanbul-lib-source-maps« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-opentip« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-eslint-plugin-html« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-tweetnacl« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-telegram-bot-api« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.isweakmap« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-strophejs-plugin-mam« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-caniuse-lite« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-postcss-reporter« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-cycle« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-acorn-class-fields« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-vary« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-transform-modules-commonjs« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-ps-tree« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-forwarded« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.union« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-istanbul-reports« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-grunt-contrib-requirejs« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.memoize« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-regenerator« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-is-stream« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-gulp-changed« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lumino-signaling« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-single-line-log« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-path-exists« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-opener« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-glob-to-regexp« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-prompts« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-ldap-filter« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-request« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-mqtt-connection« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-libnpmexec« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.findlastkey« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-hash-sum« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-prosemirror-model« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-array-flatten« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.keys« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.lastindexof« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-es-shim-unscopables« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.pull« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-npmcli-metavuln-calculator« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-postcss-flexbugs-fixes« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-querystringify« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.oversome« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-remark-slide« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-webassemblyjs-ast« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-bufferstreams« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-keyv« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-puka« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-generic-pool« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-pump« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-jest-runtime« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-ansi-wrap« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-object-inspect« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-resolve« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-y-websocket« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lower-case« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-external-helpers« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-trust-keyto« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-regenerator-preset« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.isdate« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-transform-flow-strip-types« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-inquirer« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-dequeue« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-strip-final-newline« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.at« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-nodelib-fs.scandir« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lumino-dragdrop« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-backbone« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.ntharg« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-chartkick« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.eq« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-quote-stream« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-assertive« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-snapdragon-capture-set« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.gt« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-exit« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-events-to-array« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-winston-compat« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-eslint-parser« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.lt« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-vali-date« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-rollup-plugin-babel« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-clean-yaml-object« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.clamp« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-wcwidth« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-vega« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-webassemblyjs-cli« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-jstimezonedetect« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-jmespath« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-jest-validate« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-mini-css-extract-plugin« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-cookie« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-npmcli-run-script« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-transform-react-jsx-source« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.findlastindex« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-json-stringify-safe« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-create-require« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-cli-table2« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-helper-fixtures« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-varstream« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-unpipe« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-mustache« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-hash-base« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-babel-standalone« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-jest-globals« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-react-highlighter« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-fuzzaldrin-plus« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lumino-polling« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-spdx-expression-parse« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-morgan« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-statuses« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-array-sort« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-js-beautify« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.mapvalues« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-react-is« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-is-urlsearchparams« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-transform-react-inline-elements« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-parse5-htmlparser2-tree-adapter« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-fancy-log« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-sanitize-html« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-transform-flow-comments« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-regjsparser« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-webassemblyjs-ieee754« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-d3-array« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-which« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.sortby« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-jsbn« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-is-string« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-strophejs-plugin-rsm« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-istanbul-lib-coverage« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-websocket-stream« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-seedrandom« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.methodof« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-wawoff2« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-pacote« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-keygrip« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-require-relative« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-jest-react« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.isweakset« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-global-prefix« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-trim-newlines« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-minipass-json-stream« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-gulp-plumber« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.includes« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.iselement« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.isarraylikeobject« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-require-dir« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-array-initial« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-dottie« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-ip-regex« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-uglify-save-license« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-caller« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-data-urls« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-requirejs« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-performance-now« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-deps-sort« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-is-buffer« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-transform-property-mutators« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-eslint-plugin-eslint-plugin« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-codemirror« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-rollup-plugin-alias« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-busboy« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-console-browserify« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-pretty-ms« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-envinfo« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-istanbul-lib-report« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lazy-node-readlines« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-package-hash« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-zeparser« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.unzipwith« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-scope-analyzer« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-async-hook-domain« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.-reinterpolate« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-mime-types« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-source-map-resolve« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-esbuild-wasm« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.ismap« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lumino-widgets« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-cookies« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-gulp-header« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-sequencify« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-serialize-javascript« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-deep-equal« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-chai-as-promised« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.range« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-json-buffer« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-which-collection« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-klaw« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-latest-version« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-csv-spectrum« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.partialright« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-has-unicode« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-chancejs-bool« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-gulp-coffee« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-is-dotfile« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-number-is-nan« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-ansi-up« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-address« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lumino-example-dockpanel-iife« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.isnan« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-passport-strategy« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-require-from-string« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-parse-asn1« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-esniff« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-colorette« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.isnil« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.zipobjectdeep« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-uuid« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-core-js-compat« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-path-in-dir« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-gar-promisify« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-camel-case« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-is-upper-case« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-shasum« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-unc-path-regex« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-minimist« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.snakecase« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-copy-concurrently« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-parse-json« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-component-emitter« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-syntax-decimal« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-github-url-from-git« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.difference« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-knockout« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-process-nextick-args« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.escaperegexp« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.unset« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.tonumber« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.divide« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-p-each-series« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-whatwg-url« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-cookiejar« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-http2-wrapper« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-dagre-d3-renderer« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.sortedlastindex« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-uid-safe« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-prop-types« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-add-filename-increment« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-shell-quote« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-transform-react-display-name« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-bunyan« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-vue-server-renderer« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-proper-lockfile« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-cacheable-request« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-wikibase-edit« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-bytes« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.slice« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-enhanced-resolve« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-sigmund« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-whatwg-mimetype« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lazy-property« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-is-woff« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-highlight« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-helper-create-class-features-plugin« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-eslint-plugin-node« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-d3-dsv« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-grunt-legacy-log-utils« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.padend« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-acorn-dynamic-import« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-is-binary-path« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.sortedindex« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.invertby« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-globby« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-cbor-web« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-anymatch« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-less-loader« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-dot-prop« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-path-type« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-uglify« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-mousetrap« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-regenerator-runtime« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-postcss-cli« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.wrap« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-pify« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.propertyof« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-jest-hoist« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-stack-utils« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-hashish« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-is-relative« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-js-sdsl« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash-packages« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lumino-messaging« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-unset-value« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.tosafeinteger« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-escope« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-pascalcase« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.times« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-type-is« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-postcss-loader« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.unzipwith« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.deburr« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-stream-consume« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.issymbol« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-transform-typescript« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-vows« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.isset« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-d3-geo« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-extglob« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-d3-collection« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-fastcgi-stream« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-fbjs« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-repeat-element« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.tolength« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-grunt-known-options« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-gulp-sass« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-netmask« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-enabled« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-d3-time« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-type-detect« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-backbone« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-forever-agent« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-randombytes« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-postcss-will-change« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-sigmund« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-function-bind« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-invert-kv« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-amdefine« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-proposal-partial-application« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-deferred« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.rest« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-constant-case« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-rollup-plugin-string« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-ansi-gray« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-css-color-names« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-transform-minify-booleans« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.assignwith« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-throttleit« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-is-module« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-minify-replace« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-statuses« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-react-is« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lazystream« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-vega-selections« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-template« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-browserify-cipher« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-blueprintjs-colors« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-npm-packlist« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-write-file-atomic« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-minipass-collect« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.unzip« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-syntax-dynamic-import« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-icss-replace-symbols« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel-plugin-proposal-private-property-in-object« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-fg-loadcss« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-ebnf-parser« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.forownright« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.matches« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-spdx-correct« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.clone« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-unorm« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-csstype« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.clonedeepwith« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-babel7-standalone« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-prosemirror-state« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.toplainobject« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-xml2js« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-window-size« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-tiny-glob« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-array-unique« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.pullall« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-loader-utils« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.sortedlastindex« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-inflection« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-fs-extra« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-buffer-equal« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-is-generator-fn« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-node-addon-api« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-moment« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.uniqueid« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-libs-browser« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.partial« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.findlastkey« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-client-sessions« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-peek-readable« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.replace« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-acorn-jsx« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-isexe« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-es6-error« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-sentence-case« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-lodash.pullallwith« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-parse-glob« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-color-convert« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.flatmapdeep« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.reduce« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-terser« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-sinonjs-referee« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-diagnostics« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-webassemblyjs-helper-numbers« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-browserify-zlib« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-types-yargs-parser« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-hsluv« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-header-case« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-lodash.reverse« wird für das Suchmuster »node-*« gewählt.
      Hinweis: »node-resumer« wird für das Suchmuster »node-*« gewählt.
      >>>>GEKÜRZT WEIL ZULANG<<<<
      Paket »node-vue« ist nicht installiert, wird also auch nicht entfernt.
      Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
        gyp javascript-common libc-ares2 libjs-async libjs-events libjs-inherits libjs-is-typedarray libjs-prettify libjs-regenerate libjs-source-map libjs-sprintf-js libjs-typedarray-to-buffer libssl-dev libuv1-dev
      Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
      Die folgenden Pakete werden ENTFERNT:
        handlebars libreoffice-help-common libreoffice-help-de libreoffice-help-en-us node-abbrev node-ampproject-remapping node-ansi-escapes node-ansi-regex node-ansi-styles node-aproba node-are-we-there-yet
        node-argparse node-arrify node-async node-async-each node-babel-plugin-add-module-exports node-babel7-runtime node-balanced-match node-base64-js node-binary-extensions node-brace-expansion node-busboy
        node-camelcase node-caniuse-lite node-chownr node-chrome-trace-event node-ci-info node-cjs-module-lexer node-clipboard node-clone node-clone-deep node-color-convert node-color-name node-colors node-commander
        node-commondir node-concat-stream node-console-control-strings node-convert-source-map node-core-js node-core-js-pure node-core-util-is node-data-uri-to-buffer node-decompress-response node-deep-is
        node-defaults node-delegates node-depd node-diff node-electron-to-chromium node-encoding node-end-of-stream node-err-code node-error-ex node-es-module-lexer node-escape-string-regexp node-eslint-utils
        node-eslint-visitor-keys node-esquery node-estraverse node-esutils node-events node-fancy-log node-fast-deep-equal node-fast-levenshtein node-fetch node-find-up node-flatted node-for-in node-for-own
        node-foreground-child node-fs-readdir-recursive node-fs-write-stream-atomic node-fs.realpath node-function-bind node-functional-red-black-tree node-get-caller-file node-get-stream node-glob node-globals
        node-got node-graceful-fs node-has-flag node-has-unicode node-hosted-git-info node-iconv-lite node-ieee754 node-iferr node-imurmurhash node-indent-string node-inflight node-inherits node-ini node-interpret
        node-ip node-ip-regex node-is-arrayish node-is-binary-path node-is-buffer node-is-extendable node-is-extglob node-is-path-cwd node-is-plain-obj node-is-plain-object node-is-stream node-is-typedarray
        node-is-windows node-isarray node-isexe node-isobject node-js-tokens node-jsesc node-json-buffer node-json-parse-better-errors node-json-schema node-json-schema-traverse node-json-stable-stringify
        node-jsonify node-jsonparse node-kind-of node-levn node-loader-runner node-locate-path node-lodash-packages node-lowercase-keys node-lru-cache node-memfs node-merge-stream node-mimic-response node-minimatch
        node-minimist node-minipass node-mute-stream node-n3 node-negotiator node-neo-async node-normalize.css node-npm-run-path node-object-inspect node-once node-optimist node-optionator node-osenv
        node-p-cancelable node-p-limit node-p-locate node-p-map node-path-dirname node-path-exists node-path-is-absolute node-path-is-inside node-path-type node-pify node-pkg-dir node-postcss-value-parser
        node-prelude-ls node-prismjs node-process-nextick-args node-promise-inflight node-promise-retry node-promzard node-prr node-pump node-quick-lru node-randombytes node-read node-readable-stream node-rechoir
        node-regenerate node-regenerate-unicode-properties node-regenerator-runtime node-regenerator-transform node-regexpp node-regjsgen node-repeat-string node-require-directory node-resolve node-resolve-cwd
        node-resolve-from node-resumer node-retry node-run-queue node-safe-buffer node-serialize-javascript node-set-blocking node-set-immediate-shim node-shebang-command node-shebang-regex node-signal-exit
        node-slash node-slice-ansi node-source-list-map node-source-map node-source-map-support node-spdx-correct node-spdx-exceptions node-spdx-expression-parse node-spdx-license-ids node-sprintf-js node-ssri
        node-string-decoder node-strip-bom node-strip-json-comments node-supports-color node-tapable node-terser node-text-table node-through node-time-stamp node-to-fast-properties node-tslib node-type-check
        node-typedarray node-typedarray-to-buffer node-undici node-unicode-canonical-property-names-ecmascript node-unicode-match-property-value-ecmascript node-unicode-property-aliases-ecmascript
        node-unique-filename node-util-deprecate node-uuid node-v8flags node-validate-npm-package-license node-wcwidth.js node-webpack-sources node-wordwrap node-wrappy node-write-file-atomic node-xtend node-y18n
        node-yallist
      0 aktualisiert, 0 neu installiert, 231 zu entfernen und 0 nicht aktualisiert.
      Nach dieser Operation werden 118 MB Plattenplatz freigegeben.
      Möchten Sie fortfahren? [J/n] j
      (Lese Datenbank ... 185479 Dateien und Verzeichnisse sind derzeit installiert.)
      Entfernen von handlebars (3:4.7.7+~4.1.0-1) ...
      Entfernen von libreoffice-help-en-us (4:7.4.7-1) ...
      Entfernen von libreoffice-help-de (4:7.4.7-1) ...
      Entfernen von libreoffice-help-common (4:7.4.7-1) ...
      Entfernen von node-abbrev (1.1.1+~1.1.2-1) ...
      Entfernen von node-terser (5.16.5-2) ...
      Entfernen von node-ampproject-remapping (2.2.0+~cs5.15.37-1) ...
      Entfernen von node-ansi-escapes (5.0.0+really.4.3.1-1) ...
      Entfernen von node-ansi-regex (5.0.1-1) ...
      Entfernen von node-slice-ansi (5.0.0+~cs9.0.0-5) ...
      Entfernen von node-ansi-styles (6.2.1-2) ...
      Entfernen von node-run-queue (2.0.0-3) ...
      Entfernen von node-aproba (2.0.0-3) ...
      Entfernen von node-are-we-there-yet (3.0.1+~1.1.0-1) ...
      Entfernen von node-argparse (2.0.1-2) ...
      Entfernen von node-optimist (0.6.1+~0.0.30-2) ...
      Entfernen von node-minimist (1.2.7+~cs5.3.2-2) ...
      Entfernen von node-arrify (2.0.1-3) ...
      Entfernen von node-async (0.8.0-6) ...
      Entfernen von node-async-each (1.0.3-3) ...
      Entfernen von node-babel-plugin-add-module-exports (1.0.4+dfsg1~cs5.8.0-4) ...
      Entfernen von node-regenerator-transform (0.15.1+~0.10.8-1) ...
      Entfernen von node-babel7-runtime (7.20.15+ds1+~cs214.269.168-3+deb12u1) ...
      Entfernen von node-glob (8.0.3+~cs8.4.15-1) ...
      Entfernen von node-minimatch (5.1.1+~5.1.2-1) ...
      Entfernen von node-brace-expansion (2.0.1-2) ...
      Entfernen von node-balanced-match (2.0.0-1) ...
      Entfernen von node-base64-js (1.5.1+dfsg+~1.3.0-2) ...
      Entfernen von node-is-binary-path (2.1.0-5) ...
      Entfernen von node-binary-extensions (2.2.0-2) ...
      Entfernen von node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u1) ...
      Entfernen von node-busboy (1.6.0+~cs2.6.0-2) ...
      Entfernen von node-camelcase (7.0.0-3) ...
      Entfernen von node-caniuse-lite (1.0.30001436+dfsg+~1.0.1-1) ...
      Entfernen von node-chownr (2.0.0-2) ...
      Entfernen von node-chrome-trace-event (1.0.3-2) ...
      Entfernen von node-ci-info (3.6.1+~cs1.1.0-1) ...
      Entfernen von node-cjs-module-lexer (1.2.2+dfsg-5) ...
      Entfernen von node-prismjs (1.29.0+dfsg+~1.26.0-1) ...
      Entfernen von node-clipboard (2.0.11+ds+~cs9.6.11-1) ...
      Entfernen von node-wcwidth.js (1.0.2-2) ...
      Entfernen von node-defaults (1.0.4+~1.0.3-1) ...
      Entfernen von node-clone (2.1.2-4) ...
      Entfernen von node-clone-deep (4.0.1+~cs7.0.2-1) ...
      Entfernen von node-color-convert (2.0.1+~cs2.0.0-2) ...
      Entfernen von node-color-name (1.1.4+~1.1.1-2) ...
      Entfernen von node-colors (1.4.0-4) ...
      Entfernen von node-commander (9.4.1-1) ...
      Entfernen von node-commondir (1.0.1+~1.0.0-1) ...
      Entfernen von node-concat-stream (2.0.0+~2.0.0-2) ...
      Entfernen von node-console-control-strings (1.1.0-3) ...
      Entfernen von node-convert-source-map (1.9.0+~1.5.2-1) ...
      Entfernen von node-core-js (3.26.1-3) ...
      Entfernen von node-core-js-pure (3.26.1-3) ...
      Entfernen von node-n3 (1.16.3+~1.2.3+~1.10.4-1) ...
      Entfernen von node-fs-write-stream-atomic (1.0.10-6) ...
      Entfernen von node-readable-stream (3.6.0+~cs3.0.0-4) ...
      Entfernen von node-core-util-is (1.0.3-1) ...
      Entfernen von node-fetch (3.3.0+~cs11.4.11-2) ...
      Entfernen von node-data-uri-to-buffer (4.0.0-3) ...
      Entfernen von node-got (11.8.5+~cs58.13.36-3) ...
      Entfernen von node-decompress-response (6.0.0-2) ...
      Entfernen von node-optionator (0.9.1+dfsg+~cs1.2.3-1) ...
      Entfernen von node-deep-is (0.1.4-1) ...
      Entfernen von node-delegates (1.0.0-3) ...
      Entfernen von node-depd (2.0.0-2) ...
      Entfernen von node-diff (5.0.0~dfsg+~5.0.1-4) ...
      Entfernen von node-electron-to-chromium (1.4.284-1) ...
      Entfernen von node-ssri (9.0.1-2) ...
      Entfernen von node-minipass (3.3.6+~cs9.4.19-1) ...
      Entfernen von node-encoding (0.1.13-2) ...
      Entfernen von node-get-stream (6.0.1-1) ...
      Entfernen von node-pump (3.0.0-5) ...
      Entfernen von node-end-of-stream (1.4.4+~1.4.1-1) ...
      Entfernen von node-promise-retry (2.0.1-4) ...
      Entfernen von node-err-code (2.0.3+dfsg-3) ...
      Entfernen von node-error-ex (1.3.2-4) ...
      Entfernen von node-es-module-lexer (1.1.0+dfsg-2) ...
      Entfernen von node-p-map (4.0.0+~3.1.0+~3.0.1-1) ...
      Entfernen von node-escape-string-regexp (4.0.0-2) ...
      Entfernen von node-eslint-utils (3.0.0-3) ...
      Entfernen von node-eslint-visitor-keys (3.3.0+~1.0.0-1) ...
      Entfernen von node-esquery (1.4.2~ds-1) ...
      Entfernen von node-estraverse (5.3.0+ds+~5.1.1-1) ...
      Entfernen von node-esutils (2.0.3+~2.0.0-1) ...
      Entfernen von node-events (3.3.0+~3.0.0-3) ...
      Entfernen von node-fancy-log (1.3.3+~cs1.3.1-2) ...
      Entfernen von node-fast-deep-equal (3.1.3-3) ...
      Entfernen von node-fast-levenshtein (2.0.6+ds-3) ...
      Entfernen von node-pkg-dir (5.0.0-2) ...
      Entfernen von node-find-up (6.3.0-7) ...
      Entfernen von node-flatted (3.2.7~ds-1) ...
      Entfernen von node-for-own (1.0.0-3) ...
      Entfernen von node-for-in (1.0.2-4) ...
      Entfernen von node-foreground-child (2.0.0-5) ...
      Entfernen von node-fs-readdir-recursive (1.1.0+~1.1.0-1) ...
      Entfernen von node-fs.realpath (1.0.0-3) ...
      Entfernen von node-rechoir (0.8.0+~0.6.1-2) ...
      Entfernen von node-resolve (1.22.1+~cs5.31.10-1) ...
      Entfernen von node-function-bind (1.1.1+repacked+~1.0.3-2) ...
      Entfernen von node-functional-red-black-tree (1.0.1+20181105-7) ...
      Entfernen von node-get-caller-file (2.0.5+~cs1.1.1-4) ...
      Entfernen von node-globals (13.18.0-1) ...
      Entfernen von node-graceful-fs (4.2.10-1) ...
      Entfernen von node-supports-color (8.1.1+~8.1.1-1) ...
      Entfernen von node-has-flag (4.0.0-3) ...
      Entfernen von node-has-unicode (2.0.1-5) ...
      Entfernen von node-hosted-git-info (6.1.1-2) ...
      Entfernen von node-iconv-lite (0.6.3-3) ...
      Entfernen von node-ieee754 (1.2.1-3) ...
      Entfernen von node-iferr (1.0.2+~1.0.2-1) ...
      Entfernen von node-write-file-atomic (4.0.2+~4.0.0-1) ...
      Entfernen von node-unique-filename (1.1.1+ds-2) ...
      Entfernen von node-imurmurhash (0.1.4+dfsg+~0.1.1-2) ...
      Entfernen von node-indent-string (4.0.0-2) ...
      Entfernen von node-inflight (1.0.6-2) ...
      Entfernen von node-inherits (2.0.4-6) ...
      Entfernen von node-ini (3.0.1-2) ...
      Entfernen von node-interpret (2.2.0-3) ...
      Entfernen von node-ip (2.0.0+~1.1.0-1) ...
      Entfernen von node-ip-regex (4.3.0+~4.1.1-1) ...
      Entfernen von node-is-arrayish (0.3.2-3) ...
      Entfernen von node-kind-of (6.0.3+dfsg-2) ...
      Entfernen von node-is-buffer (2.0.5-2) ...
      Entfernen von node-is-extendable (1.0.1-3) ...
      Entfernen von node-is-extglob (2.1.1-5) ...
      Entfernen von node-is-path-cwd (2.2.0-2) ...
      Entfernen von node-is-plain-obj (3.0.0-2) ...
      Entfernen von node-is-plain-object (5.0.0-7) ...
      Entfernen von node-is-stream (3.0.0-4) ...
      Entfernen von node-typedarray-to-buffer (4.0.0-2) ...
      Entfernen von node-is-typedarray (1.0.0-4) ...
      Entfernen von node-is-windows (1.0.2+~cs1.0.0-1) ...
      Entfernen von node-isarray (2.0.5-4) ...
      Entfernen von node-isexe (2.0.0+~2.0.1-5) ...
      Entfernen von node-isobject (4.0.0-2) ...
      Entfernen von node-js-tokens (8.0.0-2) ...
      Entfernen von node-jsesc (3.0.2+~3.0.1-1) ...
      Entfernen von node-json-buffer (3.0.1+~3.0.0-1) ...
      Entfernen von node-json-parse-better-errors (1.0.2+~cs3.3.1-2) ...
      Entfernen von node-json-schema (0.4.0+~7.0.11-1) ...
      Entfernen von node-json-schema-traverse (1.0.0-3) ...
      Entfernen von node-json-stable-stringify (1.0.2+~cs5.2.34-1) ...
      Entfernen von node-jsonify (0.0.1-1) ...
      Entfernen von node-jsonparse (1.3.1-10) ...
      Entfernen von node-levn (0.4.1+dfsg-2) ...
      Entfernen von node-loader-runner (4.3.0-1) ...
      Entfernen von node-locate-path (7.1.1-2) ...
      Entfernen von node-lodash-packages (4.17.21+dfsg+~cs8.31.198.20210220-9) ...
      Entfernen von node-lowercase-keys (2.0.0-2) ...
      Entfernen von node-lru-cache (7.14.1-1) ...
      Entfernen von node-memfs (3.4.12+~cs1.0.3-1) ...
      Entfernen von node-merge-stream (2.0.0+~1.1.2-2) ...
      Entfernen von node-mimic-response (3.1.0-8) ...
      Entfernen von node-promzard (0.3.0-2) ...
      Entfernen von node-read (1.0.7-5) ...
      Entfernen von node-mute-stream (0.0.8+~0.0.1-3) ...
      Entfernen von node-negotiator (0.6.3+~0.6.1-1) ...
      Entfernen von node-neo-async (2.6.2+~cs3.0.0-2) ...
      Entfernen von node-normalize.css (8.0.1-5) ...
      Entfernen von node-npm-run-path (5.1.0+~4.0.0-8) ...
      Entfernen von node-object-inspect (1.12.2+~cs1.8.1-1) ...
      Entfernen von node-once (1.4.0-7) ...
      Entfernen von node-osenv (0.1.5+~0.1.1-1) ...
      Entfernen von node-p-cancelable (2.1.1-1) ...
      Entfernen von node-p-locate (6.0.0-12) ...
      Entfernen von node-p-limit (4.0.0+~cs4.0.0-5) ...
      Entfernen von node-path-dirname (1.0.2-2) ...
      Entfernen von node-path-exists (5.0.0-8) ...
      Entfernen von node-path-is-absolute (2.0.0-2) ...
      Entfernen von node-path-is-inside (1.0.2+~1.0.0-1) ...
      Entfernen von node-path-type (4.0.0-3) ...
      Entfernen von node-pify (5.0.0+~cs5.0.1-1) ...
      Entfernen von node-postcss-value-parser (4.2.0-1) ...
      Entfernen von node-type-check (0.4.0+dfsg-3) ...
      Entfernen von node-prelude-ls (1.2.1+dfsg-3) ...
      Entfernen von node-process-nextick-args (2.0.1-3) ...
      Entfernen von node-promise-inflight (1.0.1+~1.0.0-1) ...
      Entfernen von node-prr (1.0.1-3) ...
      Entfernen von node-quick-lru (6.1.1-4) ...
      Entfernen von node-serialize-javascript (6.0.0-2) ...
      Entfernen von node-randombytes (2.1.0+~2.0.0-2) ...
      Entfernen von node-regenerate-unicode-properties (10.1.0+ds-1) ...
      Entfernen von node-regenerate (1.4.2-3) ...
      Entfernen von node-regenerator-runtime (0.15.1+~0.10.8-1) ...
      Entfernen von node-regexpp (3.2.0-4) ...
      Entfernen von node-regjsgen (0.7.1+ds-1) ...
      Entfernen von node-repeat-string (1.6.1+repack-1) ...
      Entfernen von node-require-directory (2.1.1+~2.1.2-1) ...
      Entfernen von node-resolve-cwd (3.0.0-2) ...
      Entfernen von node-resolve-from (5.0.0+~3.1.0+~3.3.0+~2.0.0-1) ...
      Entfernen von node-resumer (0.0.0-6) ...
      Entfernen von node-retry (0.13.1+~0.12.1-1) ...
      Entfernen von node-string-decoder (1.3.0-6) ...
      Entfernen von node-safe-buffer (5.2.1+~cs2.1.2-3) ...
      Entfernen von node-set-blocking (2.0.0-2) ...
      Entfernen von node-set-immediate-shim (2.0.0-2) ...
      Entfernen von node-shebang-command (2.0.0-1) ...
      Entfernen von node-shebang-regex (3.0.0-2) ...
      Entfernen von node-signal-exit (3.0.7+~3.0.1-1) ...
      Entfernen von node-slash (4.0.0-3) ...
      Entfernen von node-webpack-sources (3.2.3+~3.2.0-2) ...
      Entfernen von node-source-list-map (2.0.1+dfsg-2) ...
      Entfernen von node-source-map-support (0.5.21+ds+~0.5.4-1) ...
      Entfernen von node-source-map (0.7.0++dfsg2+really.0.6.1-15) ...
      Entfernen von node-validate-npm-package-license (3.0.4-2) ...
      Entfernen von node-spdx-correct (3.1.1-2) ...
      Entfernen von node-spdx-expression-parse (3.0.1+~3.0.1-1) ...
      Entfernen von node-spdx-exceptions (2.3.0-2) ...
      Entfernen von node-spdx-license-ids (3.0.12-1) ...
      Entfernen von node-sprintf-js (1.1.2+ds1+~1.1.2-1) ...
      Entfernen von node-strip-bom (4.0.0-2) ...
      Entfernen von node-strip-json-comments (4.0.0-4) ...
      Entfernen von node-tapable (2.2.1-2) ...
      Entfernen von node-text-table (0.2.0-4) ...
      Entfernen von node-through (2.3.8+~cs0.0.30-1) ...
      Entfernen von node-time-stamp (2.2.0-2) ...
      Entfernen von node-to-fast-properties (3.0.1-3) ...
      Entfernen von node-tslib (2.4.1-1) ...
      Entfernen von node-typedarray (0.0.7-1) ...
      Entfernen von node-unicode-canonical-property-names-ecmascript (2.0.0-2) ...
      Entfernen von node-unicode-match-property-value-ecmascript (2.1.0+ds-1) ...
      Entfernen von node-unicode-property-aliases-ecmascript (2.1.0+ds-1) ...
      Entfernen von node-util-deprecate (1.0.2-3) ...
      Entfernen von node-uuid (8.3.2+~8.3.3-3) ...
      Entfernen von node-v8flags (3.2.0+~3.1.1-1) ...
      Entfernen von node-wordwrap (1.0.0-4) ...
      Entfernen von node-wrappy (1.0.2-3) ...
      Entfernen von node-xtend (4.0.2-3) ...
      Entfernen von node-y18n (5.0.8+~5.0.0-3) ...
      Entfernen von node-yallist (4.0.0+~4.0.1-1) ...
      Trigger für man-db (2.11.2-2) werden verarbeitet ...
      root@debian-IoBrocker:/home/alexander# sudo apt autoremove
      0 aktualisiert, 0 neu installiert, 14 zu entfernen und 0 nicht aktualisiert.
      Nach dieser Operation werden 15,5 MB Plattenplatz freigegeben.
      (Lese Datenbank ... 160357 Dateien und Verzeichnisse sind derzeit installiert.)
      Entfernen von gyp (0.1+20220404git9ecf45e-2) ...
      Entfernen von javascript-common (11+nmu1) ...
      Entfernen von libc-ares2:amd64 (1.18.1-3) ...
      Entfernen von libjs-async (0.8.0-6) ...
      Entfernen von libjs-events (3.3.0+~3.0.0-3) ...
      Entfernen von libjs-inherits (2.0.4-6) ...
      Entfernen von libjs-is-typedarray (1.0.0-4) ...
      Entfernen von libjs-prettify (2015.12.04+dfsg-1.1) ...
      Entfernen von libjs-regenerate (1.4.2-3) ...
      Entfernen von libjs-source-map (0.7.0++dfsg2+really.0.6.1-15) ...
      Entfernen von libjs-sprintf-js (1.1.2+ds1+~1.1.2-1) ...
      Entfernen von libjs-typedarray-to-buffer (4.0.0-2) ...
      Entfernen von libssl-dev:amd64 (3.0.11-1~deb12u2) ...
      Entfernen von libuv1-dev:amd64 (1.44.2-1) ...
      Trigger für libc-bin (2.36-9+deb12u3) werden verarbeitet ...
      root@debian-IoBrocker:/home/alexander# iob diag
      This script must not be run as root!
      Please use your standard user!
      A HomoranH 2 Antworten Letzte Antwort
      • A Alex-Smarthome
        @alex-smarthome
        Da ist aber einiges krumm...
        sudo apt autoremove
        iob diag
        [sudo] Passwort für alexander:
        Passwort:
          node-yallist
        Alex-Smarthome
        @alex-smarthome
        alexander@debian-IoBrocker:~$ iob diag
        Sorry, user alexander is not allowed to execute '/usr/bin/curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh' as iobroker on debian-IoBrocker.fritz.box.
        • A Alex-Smarthome
          @alex-smarthome
          sudo apt autoremove
          iob diag
          Passwort:
            node-yallist
          @alex-smarthome sagte in Server Cannot start inMem-objects on port 9001::
          und wie sieht das jetzt aus?
          groups als alexander?
          • A Alex-Smarthome
            @alex-smarthome
            @alex-smarthome
            Keine Ahnung was du da als root alles angestellt hast.
            Installiere es neu, diesmal richtig als user.
              Alex-Smarthome
              @homoran Unverändert
              alexander@debian-IoBrocker:~$ groups
              alexander cdrom floppy audio dip video plugdev users netdev bluetooth lpadmin scanner
                @alex-smarthome
                Alex-Smarthome
                @alex-smarthome
                Das Komplette System? Also Debian12 oder nur IoBroker? Es lief ja bis Sonntag abend gut.
                  @alex-smarthome
                  Als root:
                  apt update
                  apt install sudo
                  usermod -a -G sudo,iobroker alexander
                  exit
                  Nicht mehr als root herumkaspern...
                  iob fix
                  iob diag
                  @Alex-Smarthome
                  wo sind die Konsolenein- und -ausgaben davon?
                  @thomas-braun sagte in Server Cannot start inMem-objects on port 9001::
                  @alex-smarthome
                  Als root:
                  apt update
                  apt install sudo
                  exit
                  iob fix
                  iob diag
                  • A Alex-Smarthome
                    @alex-smarthome
                    @alex-smarthome
                    Ja klar das ganze System.
                    Das ist ja auch in Gänze von dir verfummelt worden.
                    Und vergib dieses mal dem root erst gar kein Passwort, dann passt das auch alles.
                      @Alex-Smarthome
                      @alex-smarthome
                      Als root:
                      apt update
                      apt install sudo
                      exit
                      iob fix
                      iob diag
                      Alex-Smarthome
                      @homoran said in Server Cannot start inMem-objects on port 9001::
                      @Alex-Smarthome
                      @alex-smarthome
                      Als root:
                      apt update
                      apt install sudo
                      exit
                      iob fix
                      iob diag
                      Der 8 post
                      root@debian-IoBrocker:/home/alexander# apt update
                      OK:1 http://security.debian.org/debian-security bookworm-security InRelease
                      OK:2 http://deb.debian.org/debian bookworm InRelease
                      Holen:3 http://deb.debian.org/debian bookworm-updates InRelease [52,1 kB]
                      OK:4 https://linux.teamviewer.com/deb stable InRelease
                      OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Es wurden 52,1 kB in 1 s geholt (57,3 kB/s).
                      • A Alex-Smarthome
                        @Alex-Smarthome
                        @alex-smarthome
                        Als root:
                        apt update
                        apt install sudo
                        exit
                        iob fix
                        iob diag
                        Der 8 post
                        Der 8 post
                        wo hast du da die Rechte neu vergeben?
                          Der 8 post
                          @homoran sagte in Server Cannot start inMem-objects on port 9001::
                          Nutzt nix, da ist noch ganz anderes krumm.
                          • A Alex-Smarthome
                            @Alex-Smarthome
                            @alex-smarthome
                            Als root:
                            apt update
                            apt install sudo
                            exit
                            iob fix
                            iob diag
                            Der 8 post
                            @alex-smarthome
                            Und Teamviewer hat auf dem System auch nix zu suchen, weil ein Server keine graphische Oberfläche hat und da gar nix zum teamviewen läuft. Terminal per SSH, fertig.
                              @alex-smarthome
                              Alex-Smarthome
                              @alex-smarthome
                              Terminal per SSH? Hab bis Dato sogut wie nie was mit Linux zu tun gehabt, und wenn dann immer mit graphische Oberfläche. Teamviewer ist darauf weil ich Win User durch und durch bin, und der NUC/Server ausserhalb im Gerätehaus steht. Verträgt sich Debian und Windows über Putty mittlerweile besser? Oder gibt es da mittlerweile eine Weboberfläche für?
                              • A Alex-Smarthome
                                @thomas-braun said in Server Cannot start inMem-objects on port 9001::
                                @alex-smarthome
                                besser als sehr gut?
                                und was viewst du da?
                                die lokale Konsole?
                                  die lokale Konsole?
                                  Alex-Smarthome
                                  die lokale Konsole?
                                  Zu meinen Zeiten mit Linux gehörte damals die zeit der Dreambox, und da gab es immerwieder bei Putty Probleme. Das einzige was mit Putty immer lief war der Consolenzugriff auf Switche. Und ja den Teamviewer benutze ich für die Lokale Konsole, Bzw. sollte auf den NUC noch Solar Guardian Power Management und Arduino.CC zum auslesen von Arduino Sensordaten. Aber das habe ich schon angefangen aauf ESP8266 umzurüsten.
                                  • A Alex-Smarthome
                                    die lokale Konsole?
                                    also war eher die Dreambox oder deren Konfiguration das Problem.
                                    wofür dann den ganzen Grafikkrempel draufsetzen um dann doch per Konsole zu administrieren?
                                    Dann doch direkt per Konsole, auch mit powershell ssh user@ip
                                    • A Alex-Smarthome
                                      die lokale Konsole?
                                      @alex-smarthome
                                      Die vorgesehene Verbindung zu einem Server ist immer ein Terminal. Und weil das seit Jahrzehnten so ist, ist das natürlich sowas von ausgereift das es da natürlich keine in der Verbindung begründete Probleme gibt.
                                        @alex-smarthome
                                        Alex-Smarthome
                                        Wie Schaut es den mit den IoBroker Backups auf meinem NAS aus? Habe ich hinterher eine chance das ich die wieder laden kann, oder muss ich mir dann wieder die Nächte um die Ohren schlagen um Alexa und co. wieder ans Rennen zubekommen, und alles wieder in VIS neu aufbauen?
                                        • A Alex-Smarthome
                                          @alex-smarthome
                                          Dafür sind Backups da.
