  4. Vis-2(.0) - Neuer Adapter als Beta
691 Beiträge 101 Kommentatoren 303.0k Aufrufe 115 Beobachtet
  • DJMarc75D DJMarc75
    @hosabeni sagte in Vis-2(.0) - Neuer Adapter als Beta:
    Hab ich versuchen, hat aber nicht geholfen.
    na dann zeig mal die Ausgabe von
    iob diag
    und bitte die Langfassung in Codetags posten
    hosabeni
    #540
    @djmarc75 Hallo hier die Langfassung von iob diag im Spoiler
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     10:41:30 up 1 day, 12:36,  3 users,  load average: 2.16, 1.86, 1.27
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2023-12-03 10:41:30 CET
               Universal time: Sun 2023-12-03 09:41:30 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.8G        3.4G        665M         21M        3.8G        4.3G
    Swap:            99M          0B         99M
    Total:          7.9G        3.4G        765M
             7812 M total memory
             3376 M used memory
             3812 M active memory
             3075 M inactive memory
              664 M free memory
              219 M buffer memory
             3550 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       59G   15G   42G  26% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    /dev/sda1      ext4      458G  2.4G  432G   1% /media/usb0
    tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
    [Fri Dec  1 22:05:27 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:CB:CD:86 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=0e2244e3-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Fri Dec  1 22:05:28 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Dec  1 22:05:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Fri Dec  1 22:05:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    [Fri Dec  1 22:05:34 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/media/usb0 /dev/sda1      ext4   rw,relatime
    /var:
    3.8G    /var/
    1.9G    /var/cache/apt
    1.9G    /var/cache
    1.8G    /var/cache/apt/archives
    1.6G    /var/log/journal/2cd78d8029364b2bbf6704cd23c592f6
    Archived and active journals take up 1.5G in the file system.
    /opt/iobroker/backups:
    2.5G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    565M    /opt/iobroker/iobroker-data/
    422M    /opt/iobroker/iobroker-data/files
    124M    /opt/iobroker/iobroker-data/files/vis-2
    100M    /opt/iobroker/iobroker-data/backup-objects
    90M     /opt/iobroker/iobroker-data/files/echarts.admin
    37M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-FTDI_USB_HS_SERIAL_CONVERTER_FTELTVKZ-if00-port0
    /dev/serial/by-id/usb-FTDI_USB_HS_SERIAL_CONVERTER_FTELTVKS-if00-port0
    /dev/serial/by-id/usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01A64D1A-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.16
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   5
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: horst
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.beckhoff.0               : beckhoff              : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker                                 -  enabled
    + system.adapter.enocean.0                : enocean               : iobroker                                 -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.kecontact.0              : kecontact             : iobroker                                 -  enabled
    + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
      system.adapter.proxy.0                  : proxy                 : iobroker                                 -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
      system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : iobroker                                 -  enabled
    + system.adapter.smartmeter.2             : smartmeter            : iobroker                                 -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "beckhoff"     : 1.5.3    , installed 1.5.3
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "echarts"      : 1.5.4    , installed 1.5.4
    Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.16   , installed 5.0.16
    Adapter    "kecontact"    : 2.0.2    , installed 2.0.2
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "proxy"        : 1.3.2    , installed 1.3.2
    Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
    Adapter    "schoolfree"   : 1.1.3    , installed 1.1.3
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "telegram"     : 2.0.1    , installed 3.0.0
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "vis"          : 1.4.16   , installed 1.5.1
    Adapter    "vw-connect"   : 0.0.67   , installed 0.1.0
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Objects and States
    Objects:        11773
    States:         11226
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 https://apt.grafana.com stable InRelease
    Hit:5 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          3890       567/vncserver-x11-c
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       21748      2075/io.shelly.0
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       16801      538/iobroker.js-con
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       17740      538/iobroker.js-con
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1677795    82700/cupsd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1906       597/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       22614      2582/io.jarvis.0
    tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      116        13806      641/mariadbd
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          3889       567/vncserver-x11-c
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1908       597/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18186      1314/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23804      2789/io.web.0
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1677794    82700/cupsd
    tcp6       0      0 :::3000                 :::*                    LISTEN      117        18929      722/grafana
    udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       23656      2626/io.kecontact.0
    udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       23657      2626/io.kecontact.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          3932       562/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1677820    82704/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1784       430/avahi-daemon: r
    udp        0      0 0.0.0.0:54804           0.0.0.0:*                           108        1786       430/avahi-daemon: r
    udp        0      0 0.0.0.0:42882           0.0.0.0:*                           1001       21429      2626/io.kecontact.0
    udp6       0      0 :::56214                :::*                                108        1787       430/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          13960      562/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        1785       430/avahi-daemon: r
    2023-12-03 00:02:00.293  - info: javascript.0 (1605) script.js.common.Sonstige.Update_TimeStamp: {'error':null,'result':{'fieldCount':0,'affectedRows':127,'insertId':0,'info':'','serverStatus':16418,'warningStatus':0,'stateChanges':{'systemVariables':{},'schema':'','trackStateChange':null}}}
    2023-12-03 02:05:11.036  - warn: ical.0 (88825) get state error: Connection is closed.
    2023-12-03 03:16:00.283  - warn: javascript.0 (1605) Read-only state "vw-connect.0.WVWZZZE1ZPP020635.status.chargingSettings.targetSOC_pct" has been written without ack-flag with value "65"
    2023-12-03 04:39:32.200  - warn: telegram.0 (25541) polling_error: EFATAL, EFATAL: Error: read ECONNRESET
    2023-12-03 04:39:48.595  - warn: ecovacs-deebot.0 (2356) Request Timeout (command 'getAdvancedMode')
    2023-12-03 04:40:27.315  - warn: ecovacs-deebot.0 (2356) Connection is interrupted: read ECONNRESET
    2023-12-03 04:41:19.259  - warn: ecovacs-deebot.0 (2356) Connection is interrupted: MQTT client error: read ECONNRESET
    2023-12-03 07:44:45.662  - warn: javascript.0 (1605) Read-only state "vw-connect.0.WVWZZZE1ZPP020635.status.chargingSettings.targetSOC_pct" has been written without ack-flag with value "80"
                            v.2023-10-10
             Icon name: computer
          Architecture: arm64
    Kernel:                 aarch64
    Userland:               arm64
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               true
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
    Recommended versions are nodejs 18.19.0 and npm 10.2.3
    MEMORY:
    Mem:            7.8G        3.5G        526M         21M        3.8G        4.2G
    Swap:            99M          0B         99M
    Total:          7.9G        3.5G        626M
    Active iob-Instances:   28
    ioBroker Core:          js-controller           5.0.16
                            admin                   6.12.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                11773
    States:                 11226
    Size of iob-Database:
    4.6M    /opt/iobroker/iobroker-data/states.jsonl
    • apollon77A apollon77
      @hosabeni Also an sich darf /opt/iobroker keinen Zugriffsfehler geben ...
      hosabeni
      schrieb am zuletzt editiert von hosabeni
      #541
      @apollon77 Ich habe die Berechtigung von /opt/iobroker auf 777 geändert und dann funktioniert es.
      Haben sich die Berechtigungsanforderungen für vis-2 im Verhältnis zu vis geändert?
      Werden die Berechtigungen auf das Verzeichnis nicht mit iob fix geprüft?
      apollon77A Thomas BraunT 2 Antworten Letzte Antwort
      • H hosabeni
        #542
        @hosabeni Ich glaube iob fix prüft alles IM Ordner aber nicht den ordner selbst weil es zb bei Docker sein kann das der prozess darauf keine schreibrechtr hat ... was ja auch nicht nötig ist.
        • FeuersturmF Feuersturm
          Mit influx.0 funktioniert es bei mir auch.
          sigi234S Online
          sigi234S Online
          #543
          @feuersturm
          Hallo, bei dir auch so?
          iobroker.vis-2@2.9.3
          Alle Vis 2 - Material-Widgets - Schalter oder Knöpfe haben sich verstellt.
          I FeuersturmF 2 Antworten Letzte Antwort
          • H hosabeni
            #544
            @hosabeni
            Was haste denn da nun eingestellt?
            Auf dem Verzeichnis liegt ACL...
            Das muss so aussehen:
            echad@chet:~ $ getfacl /opt/iobroker/
            getfacl: Removing leading '/' from absolute path names
            # file: opt/iobroker/
            # owner: iobroker
            # group: iobroker
            user::rwx
            group::r-x
            group:iobroker:rwx
            mask::rwx
            other::r-x
            default:user::rwx
            default:group::r-x
            default:group:iobroker:rwx
            default:mask::rwx
            default:other::r-x
            echad@chet:~ $
            • sigi234S sigi234
              @feuersturm
              I Offline
              I Offline
              intruder7
              #545
              @sigi234
              bei mir auch so...
              • sigi234S sigi234
                @feuersturm
                FeuersturmF Offline
                FeuersturmF Offline
                Feuersturm
                #546
                @sigi234 sagte in Vis-2(.0) - Neuer Adapter als Beta:
                Hi, hab die 2.9.3 nicht mitgenommen und gerade auf die 2.9.4 aktualisiert. Dort habe ich spontan kein Problem in meinem Projekt gesehen.
                I 1 Antwort Letzte Antwort
                  I Offline
                  I Offline
                  intruder7
                  #547
                  @feuersturm ja, bei 2.9.4 gehts auch wieder
                  • sigi234S Online
                    sigi234S Online
                    #548
                    Vis-2 Material-Widgets Helfer keine Funktion bzw. Widgets werden nicht erstellt:
                    VIS-2 V 2.9.4
                    https://github.com/ioBroker/ioBroker.vis-2/issues/238
                      Sandy
                      #549
                      habe da Gefühl umso mehr neue Updates kommen um so mehr geht am Ende nicht mehr :-(
                      Jetzt geht meine Heizungssteuerung und Code Eingabe auch nicht mehr :-(
                      vorher
                      nachher
                      vorher
                      nachher
                      und der Touch auf dem Display ging von Anfang an nicht mehr und geht leider immer noch nicht.
                      LG Sandy
                      • S Sandy
                        vorher
                        nachher
                        vorher
                        nachher
                        LG Sandy
                        FeuersturmF Offline
                        FeuersturmF Offline
                        Feuersturm
                        #550
                        @sandy Welche Version hast du installiert.
                        Foxriver hat vor kurzem an deinem issue https://github.com/ioBroker/ioBroker.vis-2/issues/52 gearbeitet. Prüfe einmal, ob es sich verbessert hat, ansonsten dein issue kommentieren, das wir es wieder öffnen.
                        Bezüglich deiner aktuellen Probleme. Hast du einmal deinen Cache gelöscht bzw. deine Seite mal in einem privatem Tab geöffnet? Es klingt / sieht so ähnlich aus wie das issue hier: https://github.com/ioBroker/ioBroker.vis-2/issues/235
                        Das gehört zur Entwicklung dazu. Gerade von Software, welche noch im Beta Stadium ist. Wenn es keine Änderungen gibt, dann werden auch keine Bugs behoben. Ich finde es bemerkenswert mit welcher Energie / Zeit foxriver und Bluefox und sich gerade um die issues kümmern.
                          Sandy
                          #551
                          @feuersturm danke für deine schnelle Antwort :-) Habe den Cache gelöscht und sie da das Touch Problem ist weg :-) "ich frei mich)
                          mit der Darstellungssache hat sich leider nichts geändert. Auch nicht im privaten Tab. Mir ist auch aufgefallen das jetzt überall graue kleine Striche sind. Auf jeder Seite überall.
                          LG Sandy
                          PS: ich finde es auch eine Leistung was die Jungs da machen. Bitte nicht falsch verstehen :-) ich bin dankbar das sie sich da so rein hängen.
                          • S Sandy
                            LG Sandy
                            FeuersturmF Offline
                            FeuersturmF Offline
                            Feuersturm
                            #552
                            @sandy sagte in Vis-2(.0) - Neuer Adapter als Beta:
                            Das Thema gab es hier weiter oben im Thread schon einmal, scroll mal etwas höher. Ich meine es hing damit zusammen, das man bei den Widgets die Option "zeige letzte Änderung" aktiv war. Deaktiviere mal die Option, dann sollten die grauen Balken weg sein.
                            • L lub104
                              Hallo zusammen, ich habe mit selbst hochgeladen Bilder sie werden im Vis2 nicht angezeigt. PNG Bilder wurden in den Projektordner hochgeladen, Bilder werden als kleines Icon erkannt aber nicht angezeigt was ist mein Fehler. Für kurze Hilfe wäre ich dankbar.
                              Kail
                              #553
                              @lub104
                              Hallo lub104,
                              ersetze mal in der Pfadangebe zum Bild das "PRJ Name_" durch folgende Schreibweise :"..VIS-2.O/Projek....." die den Pfad zum Bild beschreibt.
                              • AgrippinenserA Offline
                                Agrippinenser
                                schrieb am zuletzt editiert von Agrippinenser
                                #554
                                @kail @lub104
                                bei mir geht \vis-2.0/RHv2/images/mailbox_empty.png
                                nicht aber ..vis-2.0/RHv2/images/mailbox_empty.png
                                Grüße vom Rhein @Colonia Claudia Ara Agrippinensium
                                  Sandy
                                  schrieb am zuletzt editiert von Sandy
                                  #555
                                  ich nochmal :-)
                                  Ich habe in der Vis folgendes genutzt um auf die jeweiligen Seiten zu kommen. Weis aber nicht mehr genau welches Widget das damals war.
                                  Wenn ich im Vis2 was ändern möchte habe ich an der rechten Seite folgende Bemerkung.
                                  müsste ich jetzt die Navigationsbutton neu machen ? Wenn ja welches Widget von Vis2 kann ich da nehmen ? Die dann so aussehen wie die die ich habe.
                                  Und wenn ich einmal auf meinen Hintergrund geklickt habe komme kann ich kein anderes Widget mehr anklicken. Gibt es da auch nen Trick ?
                                  LG Sandy
                                  @Feuersturm Der Tipp mit "Zeige letzte Änderung" hat geklappt :-)
                                    Hallo liebe Visualisierungsfreunde,
                                    einige von euch haben sich schon einige Zeit mit der Alpha Version von Vis 2.0 beschäftigt, was in den letzten Monaten unter https://forum.iobroker.net/topic/60398/test-adapter-vis-2-0-alpha bereits sehr ausführlich getestet wurde. Vielen Dank, vor allem auch im Namen von Denis, an alle die hier tatkräftig unterstützt haben!
                                    Die Software ist inzwischen aus dem Alpha-Status herausgewachsen weil schon sehr viel geht. Da vis 2.0 allerdings eine komplette Neuentwicklung auf aktuellen Technologien ist, hat sich die Rückwärtskompatibilität also doch nicht so einfach zu lösen herausgestellt. Denis hat einigen Aufwand investiert schon viele der alten Widgets anzupassen. Das wird aber nicht bei allen gehen.
                                    Aus diesem, und auch anderen Gründen, und um die weitere Arbeit nicht weiter aufzuhalten mit Rückwärtskompatibilitäts-Themen, hat Denis die Entscheidung getroffen das vis 2.0 ein NEUER Adapter sein wird namens vis-2. Dies bedeutet das es kein automatisches Update von "vis" zu "vis-2" gibt und so jeder User selbst entscheiden kann was er nutzt. Damit einher geht allerdings auch das vis2 die Visualisierungprojekte von vis importieren kann und auch viel gehen wird, allerdings einige Widgets nicht gehen werden. Hier müsstet Ihr dann Eure Visus umbauen.
                                    Wir denken das es so für alle Beteiligten am Transparentesten und klarsten ist. Auch von der Erwartungshaltung her!
                                    In dem Zuge gibt es aber eine Thematik wo Ihr aktiv werden müsst: Stichwort Lizenzen:
                                    Aktuell kann man EINE freie vis-Lizenz haben in einem Account und ggf gekaufte Lizenzen. Dazu können die aktuellen vis(1.0) Lizenzen in vis-2 Lizenzen umgewandelt werden unter https://iobroker.net . Wichtig ist hierbei das dies NICHT wieder zurück zu wandeln geht! Also bitte wandelt um wenn Ihr dann wirklich Eure Vis auf Basis von vis2 "Inbetriebnehmt"! Die "alte" vis (1.0) kann nach einer Umwandlung bis auf weiteres noch für die bestehende vis1.0 Instanz genutzt werden und ist weiterhin gültig.
                                    Damit gesagt ist vis-2 als neuer Adapter seit ein paar Tagen im beta Repository und vis2-beta ist nicht mehr verfügbar und bekommt auch keine Updates mehr. Für alle vis2-beta Nutzer werden die vis2beta Projekte in vis-2 beim ersten Start übernommen. Sonst die von vis1.
                                    Dann hier noch ein paar Informationen zu vis-2:
                                    Bilder sagen mehr als 1000 Worte ...
                                    Ein Video mit super Bildern, und mehr als 1000 Worten, sagt noch mehr ;-)
                                    @haus-automatisierung hat mal wieder ein Super Video zu Vis2 gemacht, wo man nochmal sehr genau alles vorher sieht und auch einige der Features und Änderungen vorstellt. Vielen Dank dafür!
                                    --> https://m.youtube.com/watch?v=zBFCmcCidhA
                                    Was ist neu?
                                    Um Bluefox zu zitieren: "Es ist einfacher zu sagen was nicht neu ist!" :-)
                                    Vis 2.0 ist zu großen Teilen - vor allem im Editor, aber auch in der sog. "Runtime" (also der Teil der eine Visualisierung dann anzeigt) - neu geschrieben worden. Dabei wurde versucht auch alte Widgets zu unterstützen, es kann aber sehr gut sein das bei diesen Anpassungen nötig sind! Es gibt auch einige neue Widgets, die technisch auch eine ganz andere Basis haben.
                                    Bisher war vis vor allem gut darin auf festen Displaygrößen manuell zusammengestellte Oberflächen mit fest positionierten Elementen zu gestalten. Wer also eine Tablet und eine Mobile Ansicht braucht musste alles doppelt machen.
                                    Mit den neuen Material-basierten Widgets und den neuen Features von Vis ist es ebenso möglich Oberflächen zu erstellen, die sich responsive mit anpassen, wenn die Screengröße geändert wird. Man kann - sofern es Sinn ergibt - immer noch einzelne Elemente Fest positionieren.
                                    Denis und Ingo
                                    Agrippinenser
                                    #556
                                    ich habe es geschafft :-) nichts geht mehr.
                                    nachdem ich ein Basic-Bar Widget per Copy Paste von einer zur anderen Seite kopiert habe wird nichts mehr gerendert.
                                    Habe Vis-2 und Web Adapter neu gestartet.
                                    Wie komme ich da wieder raus?
                                    EDIT Vv2.9.4
                                    Ich war zu ungeduldig. Cache löschen Browser neu starten hat geholfen.
                                      Agrippinenser
                                      #557
                                      In Vis 1 war die Anzahl der Bindings je Seite begrenzt.
                                      Besteht diese Begrenzung auch in VIS-2 ?
                                        Sandy
                                        #558
                                        habe jetzt Vis 2 schon mal gut auf Vordermann gebracht :-) Mir ist aufgefallen das die Symbole
                                        /icons-mfd-png/scene_robo_vac_cleaner_charging.png
                                        jetzt auf einmal Navigationssymbole geworden sind, die jetzt aber eine kleine Umrandung haben und sich vom Hintergrund abzeichnen. Was ich aber nicht will.
                                        Kann mir einer sagen wie ich das ausstellen kann.
                                        danke LG Sandy
                                        Und was ich nicht mehr kann ist irgendwelche Widget mit der Maus verschieben. Ich muss sie immer mit der Tastatur verschieben.
                                        AgrippinenserA 1 Antwort Letzte Antwort
                                        • S Sandy
                                          danke LG Sandy
                                          Agrippinenser
                                          #559
                                          @sandy kann'ste mal den Export des Widget einstellen ?
