  4. Vis-2(.0) - Neuer Adapter als Beta
691 Beiträge 101 Kommentatoren 303.0k Aufrufe 115 Beobachtet
  • H hosabeni
    Ich habe Vis-2 über das Beta Repo installiert. Der Adapter geht nach dem eingeben der Liezens in eine Neustartschleife mit diesen Meldungen im Log. Der Vis Adapter läuft ohne Probleme.
    Habe ich etwas falsch konfiguriert oder ist das ein Bug?
    Vis-2 2.9.2
    host.iobroker
    	2023-12-01 21:51:32.120	error	instance system.adapter.vis-2.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
    vis-2.0
    	2023-12-01 21:51:31.429	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
    vis-2.0
    	2023-12-01 21:51:31.369	error	adapter disabled
    host.iobroker
    	2023-12-01 21:50:58.651	error	instance system.adapter.vis-2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    vis-2.0
    	2023-12-01 21:50:57.976	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    vis-2.0
    	2023-12-01 21:50:57.463	error	Exception-Code: EACCES: EACCES: permission denied, scandir '/opt/iobroker/'
    vis-2.0
    	2023-12-01 21:50:57.462	error	Error: EACCES: permission denied, scandir '/opt/iobroker/' at Object.readdirSync (node:fs:1527:3) at collectWidgetSets (/opt/iobroker/node_modules/iobroker.vis-2/main.js:512:19) at /opt/iobroker/node_modules/iobroker.vis-2/main.js:562:51 at Array.forEach (<anonymous>) at readAdapterList (/opt/iobroker/node_modules/iobroker.vis-2/main.js:562:36) at async buildHtmlPages (/opt/iobroker/node_modules/iobroker.vis-2/main.js:827:25) at async Object.main [as ready] (/opt/iobroker/node_modules/iobroker.vis-2/main.js:1009:5)
    vis-2.0
    	2023-12-01 21:50:57.460	error	unhandled promise rejection: EACCES: permission denied, scandir '/opt/iobroker/'
    vis-2.0
    	2023-12-01 21:50:57.456	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.iobroker
    	2023-12-01 21:33:18.133	warn	Do not restart adapter system.adapter.vis-2.0 because restart loop detected
    host.iobroker
    	2023-12-01 21:33:18.132	error	instance system.adapter.vis-2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    vis-2.0
    	2023-12-01 21:33:17.444	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    vis-2.0
    	2023-12-01 21:33:16.937	error	Exception-Code: EACCES: EACCES: permission denied, scandir '/opt/iobroker/'
    vis-2.0
    	2023-12-01 21:33:16.936	error	Error: EACCES: permission denied, scandir '/opt/iobroker/' at Object.readdirSync (node:fs:1527:3) at collectWidgetSets (/opt/iobroker/node_modules/iobroker.vis-2/main.js:512:19) at /opt/iobroker/node_modules/iobroker.vis-2/main.js:562:51 at Array.forEach (<anonymous>) at readAdapterList (/opt/iobroker/node_modules/iobroker.vis-2/main.js:562:36) at async buildHtmlPages (/opt/iobroker/node_modules/iobroker.vis-2/main.js:827:25) at async Object.main [as ready] (/opt/iobroker/node_modules/iobroker.vis-2/main.js:1009:5)
    vis-2.0
    	2023-12-01 21:33:16.934	error	unhandled promise rejection: EACCES: permission denied, scandir '/opt/iobroker/'
    vis-2.0
    	2023-12-01 21:33:16.930	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Dr. BakteriusD Offline
    Dr. Bakterius
    #535
    @hosabeni sagte in Vis-2(.0) - Neuer Adapter als Beta:
    Mach mal
    iob stop
    iob fix
    iob start
    H 1 Antwort Letzte Antwort
      Mach mal
      iob stop
      iob fix
      iob start
      hosabeni
      #536
      @dr-bakterius Hab ich versuchen, hat aber nicht geholfen.
      DJMarc75D apollon77A 2 Antworten Letzte Antwort
      • H hosabeni
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        #537
        na dann zeig mal die Ausgabe von
        iob diag
        und bitte die Langfassung in Codetags posten
        Lehrling seit 1975 !!!
        • H hosabeni
          #538
          @hosabeni Also an sich darf /opt/iobroker keinen Zugriffsfehler geben ...
          • L Offline
            lub104
            #539
            Hallo zusammen, ich habe mit selbst hochgeladen Bilder sie werden im Vis2 nicht angezeigt. PNG Bilder wurden in den Projektordner hochgeladen, Bilder werden als kleines Icon erkannt aber nicht angezeigt was ist mein Fehler. Für kurze Hilfe wäre ich dankbar.
            • DJMarc75D DJMarc75
              iob diag
              hosabeni
              #540
              @djmarc75 Hallo hier die Langfassung von iob diag im Spoiler
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                 Static hostname: iobroker
                       Icon name: computer
                Operating System: Debian GNU/Linux 11 (bullseye)
                          Kernel: Linux 6.1.21-v8+
                    Architecture: arm64
              Model           : Raspberry Pi 4 Model B Rev 1.4
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : arm64
              Systemuptime and Load:
               10:41:30 up 1 day, 12:36,  3 users,  load average: 2.16, 1.86, 1.27
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** Time and Time Zones ***
                             Local time: Sun 2023-12-03 10:41:30 CET
                         Universal time: Sun 2023-12-03 09:41:30 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server:       true
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            7.8G        3.4G        665M         21M        3.8G        4.3G
              Swap:            99M          0B         99M
              Total:          7.9G        3.4G        765M
                       7812 M total memory
                       3376 M used memory
                       3812 M active memory
                       3075 M inactive memory
                        664 M free memory
                        219 M buffer memory
                       3550 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              /dev/root      ext4       59G   15G   42G  26% /
              devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
              tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
              tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
              /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
              /dev/sda1      ext4      458G  2.4G  432G   1% /media/usb0
              tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
              [Fri Dec  1 22:05:27 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:CB:CD:86 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=0e2244e3-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
              [Fri Dec  1 22:05:28 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Fri Dec  1 22:05:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Fri Dec  1 22:05:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              [Fri Dec  1 22:05:34 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
              TARGET        SOURCE         FSTYPE OPTIONS
              /             /dev/mmcblk0p2 ext4   rw,noatime
              |-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              `-/media/usb0 /dev/sda1      ext4   rw,relatime
              /var:
              3.8G    /var/
              1.9G    /var/cache/apt
              1.9G    /var/cache
              1.8G    /var/cache/apt/archives
              1.6G    /var/log/journal/2cd78d8029364b2bbf6704cd23c592f6
              Archived and active journals take up 1.5G in the file system.
              /opt/iobroker/backups:
              2.5G    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              565M    /opt/iobroker/iobroker-data/
              422M    /opt/iobroker/iobroker-data/files
              124M    /opt/iobroker/iobroker-data/files/vis-2
              100M    /opt/iobroker/iobroker-data/backup-objects
              90M     /opt/iobroker/iobroker-data/files/echarts.admin
              37M     /opt/iobroker/iobroker-data/objects.jsonl
              24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
              24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
              24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
              USB-Devices by-id:
              /dev/serial/by-id/usb-FTDI_USB_HS_SERIAL_CONVERTER_FTELTVKZ-if00-port0
              /dev/serial/by-id/usb-FTDI_USB_HS_SERIAL_CONVERTER_FTELTVKS-if00-port0
              /dev/serial/by-id/usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01A64D1A-if00-port0
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.19.0
              /usr/bin/node           v18.19.0
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              /usr/bin/corepack       0.22.0
              nodejs:
                Installed: 18.19.0-1nodesource1
                Candidate: 18.19.0-1nodesource1
                Version table:
               *** 18.19.0-1nodesource1 1001
                      500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                   18.18.2-1nodesource1 1001
                   18.18.1-1nodesource1 1001
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.16
              admin:          6.12.0
              javascript:     7.1.6
              Adapters from github:   5
              Adapter State
              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: horst
              + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
              + system.adapter.beckhoff.0               : beckhoff              : iobroker                                 -  enabled
              + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
              + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
              + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker                                 -  enabled
              + system.adapter.enocean.0                : enocean               : iobroker                                 -  enabled
              + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
              + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
              + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
              + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              + system.adapter.kecontact.0              : kecontact             : iobroker                                 -  enabled
              + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                system.adapter.proxy.0                  : proxy                 : iobroker                                 -  enabled
              + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
              + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
              + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
              + system.adapter.smartmeter.1             : smartmeter            : iobroker                                 -  enabled
              + system.adapter.smartmeter.2             : smartmeter            : iobroker                                 -  enabled
              + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
              + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
              + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
                system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
              + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
              + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
              + instance is alive
              ioBroker-Repositories
              Stable (default): http://download.iobroker.net/sources-dist.json
              Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
              Installed ioBroker-Instances
              Adapter    "admin"        : 6.12.0   , installed 6.12.0
              Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
              Adapter    "alias-manager": 1.2.6    , installed 1.2.6
              Adapter    "backitup"     : 2.8.7    , installed 2.8.7
              Adapter    "beckhoff"     : 1.5.3    , installed 1.5.3
              Adapter    "discovery"    : 4.2.0    , installed 4.2.0
              Adapter    "echarts"      : 1.5.4    , installed 1.5.4
              Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
              Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
              Adapter    "ical"         : 1.13.3   , installed 1.13.3
              Adapter    "info"         : 2.0.0    , installed 2.0.0
              Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
              Adapter    "javascript"   : 7.1.6    , installed 7.1.6
              Controller "js-controller": 5.0.16   , installed 5.0.16
              Adapter    "kecontact"    : 2.0.2    , installed 2.0.2
              Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
              Adapter    "proxy"        : 1.3.2    , installed 1.3.2
              Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
              Adapter    "schoolfree"   : 1.1.3    , installed 1.1.3
              Adapter    "shelly"       : 6.6.1    , installed 6.6.1
              Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
              Adapter    "socketio"     : 6.6.0    , installed 6.6.0
              Adapter    "telegram"     : 2.0.1    , installed 3.0.0
              Adapter    "trashschedule": 2.3.0    , installed 2.3.0
              Adapter    "vis"          : 1.4.16   , installed 1.5.1
              Adapter    "vw-connect"   : 0.0.67   , installed 0.1.0
              Adapter    "web"          : 6.1.10   , installed 6.1.10
              Adapter    "ws"           : 2.5.8    , installed 2.5.8
              Objects and States
              Objects:        11773
              States:         11226
              Hit:1 http://deb.debian.org/debian bullseye InRelease
              Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:4 https://apt.grafana.com stable InRelease
              Hit:5 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          3890       567/vncserver-x11-c
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       21748      2075/io.shelly.0
              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       16801      538/iobroker.js-con
              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       17740      538/iobroker.js-con
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1677795    82700/cupsd
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1906       597/sshd: /usr/sbin
              tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       22614      2582/io.jarvis.0
              tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      116        13806      641/mariadbd
              tcp6       0      0 :::5900                 :::*                    LISTEN      0          3889       567/vncserver-x11-c
              tcp6       0      0 :::22                   :::*                    LISTEN      0          1908       597/sshd: /usr/sbin
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18186      1314/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23804      2789/io.web.0
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1677794    82700/cupsd
              tcp6       0      0 :::3000                 :::*                    LISTEN      117        18929      722/grafana
              udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       23656      2626/io.kecontact.0
              udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       23657      2626/io.kecontact.0
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          3932       562/dhcpcd
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1677820    82704/cups-browsed
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1784       430/avahi-daemon: r
              udp        0      0 0.0.0.0:54804           0.0.0.0:*                           108        1786       430/avahi-daemon: r
              udp        0      0 0.0.0.0:42882           0.0.0.0:*                           1001       21429      2626/io.kecontact.0
              udp6       0      0 :::56214                :::*                                108        1787       430/avahi-daemon: r
              udp6       0      0 :::546                  :::*                                0          13960      562/dhcpcd
              udp6       0      0 :::5353                 :::*                                108        1785       430/avahi-daemon: r
              2023-12-03 00:02:00.293  - info: javascript.0 (1605) script.js.common.Sonstige.Update_TimeStamp: {'error':null,'result':{'fieldCount':0,'affectedRows':127,'insertId':0,'info':'','serverStatus':16418,'warningStatus':0,'stateChanges':{'systemVariables':{},'schema':'','trackStateChange':null}}}
              2023-12-03 02:05:11.036  - warn: ical.0 (88825) get state error: Connection is closed.
              2023-12-03 03:16:00.283  - warn: javascript.0 (1605) Read-only state "vw-connect.0.WVWZZZE1ZPP020635.status.chargingSettings.targetSOC_pct" has been written without ack-flag with value "65"
              2023-12-03 04:39:32.200  - warn: telegram.0 (25541) polling_error: EFATAL, EFATAL: Error: read ECONNRESET
              2023-12-03 04:39:48.595  - warn: ecovacs-deebot.0 (2356) Request Timeout (command 'getAdvancedMode')
              2023-12-03 04:40:27.315  - warn: ecovacs-deebot.0 (2356) Connection is interrupted: read ECONNRESET
              2023-12-03 04:41:19.259  - warn: ecovacs-deebot.0 (2356) Connection is interrupted: MQTT client error: read ECONNRESET
              2023-12-03 07:44:45.662  - warn: javascript.0 (1605) Read-only state "vw-connect.0.WVWZZZE1ZPP020635.status.chargingSettings.targetSOC_pct" has been written without ack-flag with value "80"
                                      v.2023-10-10
                       Icon name: computer
                    Architecture: arm64
              Kernel:                 aarch64
              Userland:               arm64
              Timezone:               Europe/Berlin (CET, +0100)
              User-ID:                1000
              X-Server:               true
              Pending OS-Updates:     0
              Pending iob updates:    0
              Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                      /usr/bin/npm            10.2.3
                                      /usr/bin/npx            10.2.3
              Recommended versions are nodejs 18.19.0 and npm 10.2.3
              MEMORY:
              Mem:            7.8G        3.5G        526M         21M        3.8G        4.2G
              Swap:            99M          0B         99M
              Total:          7.9G        3.5G        626M
              Active iob-Instances:   28
              ioBroker Core:          js-controller           5.0.16
                                      admin                   6.12.0
              Objects type: jsonl
              States  type: jsonl
              Objects:                11773
              States:                 11226
              Size of iob-Database:
              4.6M    /opt/iobroker/iobroker-data/states.jsonl
              • apollon77A apollon77
                hosabeni
                schrieb am zuletzt editiert von hosabeni
                #541
                @apollon77 Ich habe die Berechtigung von /opt/iobroker auf 777 geändert und dann funktioniert es.
                Haben sich die Berechtigungsanforderungen für vis-2 im Verhältnis zu vis geändert?
                Werden die Berechtigungen auf das Verzeichnis nicht mit iob fix geprüft?
                apollon77A Thomas BraunT 2 Antworten Letzte Antwort
                • H hosabeni
                  #542
                  @hosabeni Ich glaube iob fix prüft alles IM Ordner aber nicht den ordner selbst weil es zb bei Docker sein kann das der prozess darauf keine schreibrechtr hat ... was ja auch nicht nötig ist.
                  • FeuersturmF Feuersturm
                    Mit influx.0 funktioniert es bei mir auch.
                    sigi234S Online
                    sigi234S Online
                    #543
                    @feuersturm
                    Hallo, bei dir auch so?
                    iobroker.vis-2@2.9.3
                    Alle Vis 2 - Material-Widgets - Schalter oder Knöpfe haben sich verstellt.
                    I FeuersturmF 2 Antworten Letzte Antwort
                    • H hosabeni
                      #544
                      @hosabeni
                      Was haste denn da nun eingestellt?
                      Auf dem Verzeichnis liegt ACL...
                      Das muss so aussehen:
                      echad@chet:~ $ getfacl /opt/iobroker/
                      getfacl: Removing leading '/' from absolute path names
                      # file: opt/iobroker/
                      # owner: iobroker
                      # group: iobroker
                      user::rwx
                      group::r-x
                      group:iobroker:rwx
                      mask::rwx
                      other::r-x
                      default:user::rwx
                      default:group::r-x
                      default:group:iobroker:rwx
                      default:mask::rwx
                      default:other::r-x
                      echad@chet:~ $
                      • sigi234S sigi234
                        @feuersturm
                        I Offline
                        I Offline
                        intruder7
                        #545
                        @sigi234
                        bei mir auch so...
                        • sigi234S sigi234
                          @feuersturm
                          FeuersturmF Offline
                          FeuersturmF Offline
                          Feuersturm
                          #546
                          @sigi234 sagte in Vis-2(.0) - Neuer Adapter als Beta:
                          Hi, hab die 2.9.3 nicht mitgenommen und gerade auf die 2.9.4 aktualisiert. Dort habe ich spontan kein Problem in meinem Projekt gesehen.
                          I 1 Antwort Letzte Antwort
                            I Offline
                            I Offline
                            intruder7
                            #547
                            @feuersturm ja, bei 2.9.4 gehts auch wieder
                            • sigi234S Online
                              sigi234S Online
                              #548
                              Vis-2 Material-Widgets Helfer keine Funktion bzw. Widgets werden nicht erstellt:
                              VIS-2 V 2.9.4
                              https://github.com/ioBroker/ioBroker.vis-2/issues/238
                                Sandy
                                #549
                                habe da Gefühl umso mehr neue Updates kommen um so mehr geht am Ende nicht mehr :-(
                                Jetzt geht meine Heizungssteuerung und Code Eingabe auch nicht mehr :-(
                                vorher
                                nachher
                                vorher
                                nachher
                                und der Touch auf dem Display ging von Anfang an nicht mehr und geht leider immer noch nicht.
                                LG Sandy
                                • S Sandy
                                  vorher
                                  nachher
                                  vorher
                                  nachher
                                  LG Sandy
                                  FeuersturmF Offline
                                  FeuersturmF Offline
                                  Feuersturm
                                  #550
                                  @sandy Welche Version hast du installiert.
                                  Foxriver hat vor kurzem an deinem issue https://github.com/ioBroker/ioBroker.vis-2/issues/52 gearbeitet. Prüfe einmal, ob es sich verbessert hat, ansonsten dein issue kommentieren, das wir es wieder öffnen.
                                  Bezüglich deiner aktuellen Probleme. Hast du einmal deinen Cache gelöscht bzw. deine Seite mal in einem privatem Tab geöffnet? Es klingt / sieht so ähnlich aus wie das issue hier: https://github.com/ioBroker/ioBroker.vis-2/issues/235
                                  Das gehört zur Entwicklung dazu. Gerade von Software, welche noch im Beta Stadium ist. Wenn es keine Änderungen gibt, dann werden auch keine Bugs behoben. Ich finde es bemerkenswert mit welcher Energie / Zeit foxriver und Bluefox und sich gerade um die issues kümmern.
                                    Sandy
                                    #551
                                    @feuersturm danke für deine schnelle Antwort :-) Habe den Cache gelöscht und sie da das Touch Problem ist weg :-) "ich frei mich)
                                    mit der Darstellungssache hat sich leider nichts geändert. Auch nicht im privaten Tab. Mir ist auch aufgefallen das jetzt überall graue kleine Striche sind. Auf jeder Seite überall.
                                    LG Sandy
                                    PS: ich finde es auch eine Leistung was die Jungs da machen. Bitte nicht falsch verstehen :-) ich bin dankbar das sie sich da so rein hängen.
                                    • S Sandy
                                      LG Sandy
                                      FeuersturmF Offline
                                      FeuersturmF Offline
                                      Feuersturm
                                      #552
                                      @sandy sagte in Vis-2(.0) - Neuer Adapter als Beta:
                                      Das Thema gab es hier weiter oben im Thread schon einmal, scroll mal etwas höher. Ich meine es hing damit zusammen, das man bei den Widgets die Option "zeige letzte Änderung" aktiv war. Deaktiviere mal die Option, dann sollten die grauen Balken weg sein.
                                      • L lub104
                                        Kail
                                        #553
                                        @lub104
                                        Hallo lub104,
                                        ersetze mal in der Pfadangebe zum Bild das "PRJ Name_" durch folgende Schreibweise :"..VIS-2.O/Projek....." die den Pfad zum Bild beschreibt.
                                        • AgrippinenserA Offline
                                          Agrippinenser
                                          schrieb am zuletzt editiert von Agrippinenser
                                          #554
                                          @kail @lub104
                                          bei mir geht \vis-2.0/RHv2/images/mailbox_empty.png
                                          nicht aber ..vis-2.0/RHv2/images/mailbox_empty.png
                                          Grüße vom Rhein @Colonia Claudia Ara Agrippinensium
