  4. Backup Größe ioBroker
115 Beiträge 6 Kommentatoren 19.9k Aufrufe 4 Beobachtet
    @iced112 wie wär's mit zeigen?
    I Offline
    I Offline
    IceD112
    #93
    @homoran said in Backup Größe ioBroker:
    Als Beispiel der Heos Adapter, dort steht eine installierte Instanz
    Taucht aber hier nicht auf
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: ioBroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     14:37:36 up 17:06,  3 users,  load average: 0.27, 0.51, 0.44
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2023-11-27 14:37:36 CET
               Universal time: Mon 2023-11-27 13:37:36 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.8G        1.5G        3.6G         35M        2.7G        6.2G
    Swap:            99M          0B         99M
    Total:          7.9G        1.5G        3.7G
             7812 M total memory
             1457 M used memory
             1643 M active memory
             2166 M inactive memory
             3630 M free memory
              119 M buffer memory
             2604 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       59G  6.1G   50G  11% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
    [Sun Nov 26 21:30:53 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:46:90:AF vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=49bd46ba-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sun Nov 26 21:30:54 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Sun Nov 26 21:30:54 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Sun Nov 26 21:30:55 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Sun Nov 26 21:30:55 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Nov 26 21:30:55 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Nov 26 21:30:57 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    576M    /var/
    177M    /var/lib
    167M    /var/cache
    155M    /var/cache/apt
    132M    /var/log
    Archived and active journals take up 128.0M in the file system.
    /opt/iobroker/backups:
    146M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    522M    /opt/iobroker/iobroker-data/
    295M    /opt/iobroker/iobroker-data/files
    89M     /opt/iobroker/iobroker-data/backup-objects
    74M     /opt/iobroker/iobroker-data/files/vis.0
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    81M     /opt/iobroker/iobroker-data/states.jsonl
    59M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.16
    admin:          6.12.4
    javascript:     7.1.6
    Adapters from github:   1
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.bring.0                  : bring                 : ioBroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
    + system.adapter.denon.0                  : denon                 : ioBroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
    + system.adapter.energiefluss.1           : energiefluss          : ioBroker                                 -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 -  enabled
      system.adapter.followthesun.0           : followthesun          : ioBroker                                 - disabled
      system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker                                 - disabled
    + system.adapter.fronius-solarweb.1       : fronius-solarweb      : ioBroker                                 -  enabled
      system.adapter.ham.0                    : ham                   : ioBroker                                 - disabled
      system.adapter.harmony.0                : harmony               : ioBroker                                 - disabled
      system.adapter.heos.0                   : heos                  : ioBroker                                 - disabled
      system.adapter.hue-extended.0           : hue-extended          : ioBroker                                 - disabled
      system.adapter.hue.0                    : hue                   : ioBroker                                 - disabled, port: 443
      system.adapter.ical.0                   : ical                  : ioBroker                                 - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
      system.adapter.javascript.0             : javascript            : ioBroker                                 - disabled
      system.adapter.lgtv11.0                 : lgtv11                : ioBroker                                 - disabled, port: 8080
      system.adapter.meross.0                 : meross                : ioBroker                                 - disabled
      system.adapter.panasonic-viera.0        : panasonic-viera       : ioBroker                                 - disabled
      system.adapter.ping.0                   : ping                  : ioBroker                                 - disabled
      system.adapter.scenes.0                 : scenes                : ioBroker                                 - disabled
      system.adapter.shelly.0                 : shelly                : ioBroker                                 - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 - disabled
      system.adapter.telegram.0               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.tr-064.0                 : tr-064                : ioBroker                                 - disabled
      system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 - disabled
      system.adapter.web.0                    : web                   : ioBroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yr.0                     : yr                    : ioBroker                                 - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
    Adapter    "admin"        : 6.12.5   , installed 6.12.4 [Updatable]
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.1 [Updatable]
    Adapter    "backitup"     : 2.9.4    , installed 2.9.4
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
    Adapter    "denon"        : 1.15.4   , installed 1.15.4
    Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "followthesun" : 0.4.2    , installed 0.4.2
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "harmony"      : 1.3.0    , installed 1.3.0
    Adapter    "heos"         : 2.1.0    , installed 2.1.0
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.16   , installed 5.0.16
    Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
    Adapter    "meross"       : 1.16.1   , installed 1.15.1 [Updatable]
    Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
    Adapter    "telegram"     : 3.0.0    , installed 3.0.0
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "vis"          : 1.5.1    , installed 1.5.1
    Adapter    "vis-icontwo"  : 0.98.0   , installed 0.97.3 [Updatable]
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Objects and States
    Objects:        39455
    States:         32474
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11072      554/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          29990      6904/cupsd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18178      2241/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18185      2241/iobroker.js-co
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11074      554/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          29989      6904/cupsd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       27543      6030/io.admin.0
    udp        0      0 0.0.0.0:36350           0.0.0.0:*                           108        13741      396/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12872      469/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          30793      6909/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13739      396/avahi-daemon: r
    udp6       0      0 :::33105                :::*                                108        13742      396/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          16441      469/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        13740      396/avahi-daemon: r
    2023-11-27 14:29:38.109  - info: admin.0 (6030) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
    2023-11-27 14:30:00.144  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 16169
    2023-11-27 14:30:03.091  - info: dwd.0 (16169) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.16
    2023-11-27 14:30:04.210  - info: host.ioBroker instance system.adapter.daswetter.0 started with pid 16184
    2023-11-27 14:30:07.157  - info: daswetter.0 (16184) starting. Version 3.1.11 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.18.2, js-controller: 5.0.16
    2023-11-27 14:30:08.590  - info: dwd.0 (16169) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-11-27 14:30:09.142  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-11-27 14:30:22.962  - info: daswetter.0 (16184) still wrong data structure from server received! repaired...
    2023-11-27 14:30:27.521  - info: daswetter.0 (16184) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-11-27 14:30:28.037  - info: daswetter.0 (16184) cleaned everything up...
    2023-11-27 14:30:28.060  - info: host.ioBroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-11-27 14:30:39.032  - info: admin.0 (6030) Subscribe to all states again
    2023-11-27 14:31:39.156  - info: admin.0 (6030) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
    2023-11-27 14:32:39.250  - info: admin.0 (6030) Subscribe to all states again
    2023-11-27 14:33:38.387  - info: admin.0 (6030) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
    2023-11-27 14:34:39.314  - info: admin.0 (6030) Subscribe to all states again
    2023-11-27 14:35:00.076  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 16204
    2023-11-27 14:35:03.289  - info: dwd.0 (16204) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.16
    2023-11-27 14:35:07.239  - info: dwd.0 (16204) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-11-27 14:35:07.775  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-11-27 14:35:38.438  - info: admin.0 (6030) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
    2023-11-27 14:36:39.358  - info: admin.0 (6030) Subscribe to all states again
    2023-11-27 14:37:38.485  - info: admin.0 (6030) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
    2023-11-27 14:38:39.454  - info: admin.0 (6030) Subscribe to all states again
    2023-11-27 14:38:42.576  - info: admin.0 (6030) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
    • I IceD112
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               7812 M total memory
               1457 M used memory
               3630 M free memory
                119 M buffer memory
               2604 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      576M    /var/
      177M    /var/lib
      167M    /var/cache
      155M    /var/cache/apt
      132M    /var/log
      USB-Devices by-id:
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.4
      javascript:     7.1.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        39455
      States:         32474
      Pending Updates: 1
      #94
      @iced112 sagte in Backup Größe ioBroker:
      X-Server: true
      Ausschalten...
      sudo systemctl default-set multi-user.target
      Wassen da passiert?
      IMMER die Kiste ordentlich herunterfahren. Stromentzug ist kein ordentliches Herunterfahren...
      • I Offline
        I Offline
        IceD112
        schrieb am zuletzt editiert von IceD112
        #95
        Reicht es nicht mit
        iob stop
        und dann ausschalten?
        @thomas-braun said in Backup Größe ioBroker:
        X-Server: true
        Ausschalten...
        ist das der Befehl für den pi runter zu fahren?
        CodierknechtC Thomas BraunT 2 Antworten Letzte Antwort
        • I IceD112
          Reicht es nicht mit
          iob stop
          X-Server: true
          Ausschalten...
          CodierknechtC Offline
          Codierknecht
          #96
          Nein - damit wird der Desktop abgeschaltet.
          Runterfahren mit
          sudo shutdown -h 0
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
          • I IceD112
            Reicht es nicht mit
            iob stop
            X-Server: true
            Ausschalten...
            #97
            Nein, die Kiste muss komplett heruntergefahren werden.
            Du schredderst sonst das Dateisystem. (Siehe oben...)
            sudo poweroff
            und dann auch gerne eine Weile warten, das dauert bis zu einer Minute.
            I 1 Antwort Letzte Antwort
              sudo poweroff
              I Offline
              I Offline
              IceD112
              #98
              ok, das wusste ich tatsächlich alles nicht
              Also wenn ich den pi vom Strom trennen möchte oder muss, dann
              iob stop
              sudo shutdown -h 0
              sudo poweroff
              oder ist das zuviel des Guten?
              • I IceD112
                iob stop
                sudo shutdown -h 0
                sudo poweroff
                HomoranH Offline
                HomoranH Offline
                #99
                zuviel des Guten
                die 2. Zeile nur jetzt einmalig
                und die 3. oder 4.
                • I IceD112
                  iob stop
                  sudo shutdown -h 0
                  sudo poweroff
                  #100
                  Das ist nur einmal für das geänderte Boot Target zumachen.
                  Und
                  sudo shutdown -h 0
                  sudo poweroff
                  ist synonym. Du kannst also einen der beiden Befehle verwenden.
                    zuviel des Guten
                    und die 3. oder 4.
                    I Offline
                    I Offline
                    IceD112
                    #101
                    pi@ioBroker:~ $ sudo systemctl default-set multi-user.target
                    Unknown command verb default-set.
                    pi@ioBroker:~ $
                      Und
                      sudo shutdown -h 0
                      sudo poweroff
                      I Offline
                      I Offline
                      IceD112
                      #102
                      ok, danke
                      • I IceD112
                        pi@ioBroker:~ $
                        #103
                        Wenn man aus der Erinnerung schreibt...
                        Das muss natürlich
                        sudo systemctl set-default multi-user.target
                        lauten.
                          Das muss natürlich
                          lauten.
                          I Offline
                          I Offline
                          IceD112
                          #104
                          pi@ioBroker:~ $ sudo systemctl set-default multi-user.target
                          Removed /etc/systemd/system/default.target.
                          Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-user.target.
                          • I IceD112
                            #105
                            @iced112
                            Ja, das ist so richtig.
                              @iced112
                              I Offline
                              I Offline
                              IceD112
                              #106
                              Muss ich die Instanzen, die aktuell nicht angezeigt werden, denn evtl mit
                              iobroker restart adapterName.instance
                              starten.
                              Also alle die laut diag auf disabled stehen?
                              Thomas BraunT I 2 Antworten Letzte Antwort
                              • I IceD112
                                starten.
                                #107
                                @iced112
                                Kannst du machen.
                                • I IceD112
                                  starten.
                                  I Offline
                                  I Offline
                                  IceD112
                                  #108
                                  @iced112 said in Backup Größe ioBroker:
                                  starten.
                                  ok, da sind zwei Instanzen schonmal :-) vis.0 und fronius-solarweb.0, aber ich komme bei beiden nicht drauf. Seiten-Ladefehler
                                  einen Sammelbefehl für alle zu starten gibts nicht? oder?
                                  • I IceD112
                                    starten.
                                    HomoranH Offline
                                    HomoranH Offline
                                    #109
                                    oder!
                                    iob start all
                                    wie versuchst du es?
                                      oder!
                                      iob start all
                                      I Offline
                                      I Offline
                                      IceD112
                                      #110
                                      Ich visualisiere u.a. meine PV-Analge über den Energiefluss Adapter, die Daten kommen aus dem Fronius-Solarweb Adapter.
                                      links im Menü konnte ich unten auf die Energiefluss instanz mir die Visualisierung anzeigen. Da kommt der Seiten-Ladefehler
                                      bei der VIS gehe ich wie gewohnt auf die VIS in der Übersicht, auch da, das selbe. Bei den Instanzen fehlt mir bei der VIS auch der Schraubenschlüssel, um in die Einstellungen da zu kommen
                                      mit
                                      iob start all
                                      sind die Instanzen nun alle enabled... 👍 und sichtbar
                                      EDIT: Die Visualisierung des Energifluss Adapters ist nun sichtbar, die VIS selber ebenfalls
                                      • I IceD112
                                        mit
                                        iob start all
                                        I Offline
                                        I Offline
                                        IceD112
                                        #111
                                        Ich glaube die Wiederherstellung hat nun funktioniert. Adapter, Instanzen und Objekte sind wieder da. Werte lassen sich setzen und Automationen und Routinen über Skripte funktionieren auch, ebenso wie die einzelnen VIS Projekte.
                                        Glücklich bis hier her 😊
                                        Nu, aber vielleicht nochmal gerade zurück zum Backup
                                        Der Adapter ist eingestellt, dass zur FritzBox sichern soll. EIne gerade ausgeführtes Backup wurde aber nach /opt/iobroker/backups gesichert?
                                        • I IceD112
                                          #112
                                          Das ist richtig. Eine CIFS/SMB-Freigabe wird auf /opt/iobroker/backups eingehängt/gemounted, das Backup wird also immer in das Verzeichnis /opt/iobroker/backups geschrieben, dem ist es dann vollkommen egal welches Dateisystem physisch dahinter liegt.
                                          Aus diesem Grund muss /opt/iobroker/backups auch leer sein, wenn die Freigabe gerade nicht gemounted ist.
