  4. Backup Größe ioBroker
115 Beiträge 6 Kommentatoren 19.9k Aufrufe 4 Beobachtet
  • I Offline
    I Offline
    IceD112
    #87
    Nu warten bis der Lade-Kreis vom ioB aufhört? oder einfach neu laden?
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: ioBroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     21:52:36 up 21 min,  3 users,  load average: 1.83, 0.92, 0.49
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2023-11-26 21:52:36 CET
               Universal time: Sun 2023-11-26 20:52:36 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.8G        655M        5.9G         35M        1.2G        7.0G
    Swap:            99M          0B         99M
    Total:          7.9G        655M        6.0G
             7812 M total memory
              656 M used memory
              829 M active memory
              857 M inactive memory
             5939 M free memory
               53 M buffer memory
             1163 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       59G  4.9G   51G   9% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
    [Sun Nov 26 21:30:53 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:46:90:AF vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=49bd46ba-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sun Nov 26 21:30:54 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Sun Nov 26 21:30:54 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Sun Nov 26 21:30:55 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Sun Nov 26 21:30:55 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Nov 26 21:30:55 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Nov 26 21:30:57 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    575M    /var/
    177M    /var/lib
    167M    /var/cache
    155M    /var/cache/apt
    132M    /var/log
    Archived and active journals take up 128.0M in the file system.
    /opt/iobroker/backups:
    146M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    231M    /opt/iobroker/iobroker-data/
    170M    /opt/iobroker/iobroker-data/files
    74M     /opt/iobroker/iobroker-data/files/vis.0
    30M     /opt/iobroker/iobroker-data/files/web.admin/static
    43M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    19M     /opt/iobroker/iobroker-data/states.jsonl
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.16
    admin:          "admin" not found
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
      system.adapter.accuweather.0            : accuweather           : ioBroker                                 - disabled
      system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : ioBroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      system.adapter.bring.0                  : bring                 : ioBroker                                 - disabled
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 - disabled
      system.adapter.denon.0                  : denon                 : ioBroker                                 - disabled
      system.adapter.dwd.0                    : dwd                   : ioBroker                                 - disabled
      system.adapter.energiefluss.1           : energiefluss          : ioBroker                                 - disabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 - disabled
      system.adapter.followthesun.0           : followthesun          : ioBroker                                 - disabled
      system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker                                 - disabled
      system.adapter.ham.0                    : ham                   : ioBroker                                 - disabled
      system.adapter.harmony.0                : harmony               : ioBroker                                 - disabled
      system.adapter.heos.0                   : heos                  : ioBroker                                 - disabled
      system.adapter.hue-extended.0           : hue-extended          : ioBroker                                 - disabled
      system.adapter.hue.0                    : hue                   : ioBroker                                 - disabled, port: 443
      system.adapter.ical.0                   : ical                  : ioBroker                                 - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
      system.adapter.javascript.0             : javascript            : ioBroker                                 - disabled
      system.adapter.lgtv11.0                 : lgtv11                : ioBroker                                 - disabled, port: 8080
      system.adapter.meross.0                 : meross                : ioBroker                                 - disabled
      system.adapter.panasonic-viera.0        : panasonic-viera       : ioBroker                                 - disabled
      system.adapter.ping.0                   : ping                  : ioBroker                                 - disabled
      system.adapter.scenes.0                 : scenes                : ioBroker                                 - disabled
      system.adapter.shelly.0                 : shelly                : ioBroker                                 - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 - disabled
      system.adapter.telegram.0               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.tr-064.0                 : tr-064                : ioBroker                                 - disabled
      system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 - disabled
      system.adapter.web.0                    : web                   : ioBroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yr.0                     : yr                    : ioBroker                                 - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "backitup"     : 2.9.4    , installed 2.9.4
    Controller "js-controller": 5.0.16   , installed 5.0.16
    Objects and States
    Objects:        34776
    States:         28760
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11072      554/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12713      515/cupsd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18178      2241/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18185      2241/iobroker.js-co
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11074      554/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12712      515/cupsd
    udp        0      0 0.0.0.0:36350           0.0.0.0:*                           108        13741      396/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12872      469/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15607      592/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13739      396/avahi-daemon: r
    udp6       0      0 :::33105                :::*                                108        13742      396/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          16441      469/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        13740      396/avahi-daemon: r
    2023-11-26 21:53:39.066  - info: host.ioBroker iobroker npm-install: upload [18] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/social/ic_whatshot_black_48dp.png social/ic_whatshot_black_48dp.png image/png
    2023-11-26 21:53:39.302  - info: host.ioBroker iobroker npm-install: upload [17] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/social/ic_whatshot_white_12dp.png social/ic_whatshot_white_12dp.png image/png
    2023-11-26 21:53:39.340  - info: host.ioBroker iobroker npm-install: upload [16] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/social/ic_whatshot_white_48dp.png social/ic_whatshot_white_48dp.png image/png
    2023-11-26 21:53:39.361  - info: host.ioBroker iobroker npm-install: upload [15] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_check_box_black_24dp.png toggle/ic_check_box_black_24dp.png image/png
    2023-11-26 21:53:39.381  - info: host.ioBroker iobroker npm-install: upload [14] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_check_box_outline_blank_black_24dp.png toggle/ic_check_box_outline_blank_black_24dp.png image/png
    2023-11-26 21:53:39.424  - info: host.ioBroker iobroker npm-install: upload [13] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_check_box_outline_blank_white_24dp.png toggle/ic_check_box_outline_blank_white_24dp.png image/png
    2023-11-26 21:53:39.444  - info: host.ioBroker iobroker npm-install: upload [12] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_check_box_white_24dp.png toggle/ic_check_box_white_24dp.png image/png
    2023-11-26 21:53:39.465  - info: host.ioBroker iobroker npm-install: upload [11] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_indeterminate_check_box_black_24dp.png toggle/ic_indeterminate_check_box_black_24dp.png image/png
    2023-11-26 21:53:39.489  - info: host.ioBroker iobroker npm-install: upload [10] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_indeterminate_check_box_white_24dp.png toggle/ic_indeterminate_check_box_white_24dp.png image/png
    2023-11-26 21:53:39.516  - info: host.ioBroker iobroker npm-install: upload [9] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_radio_button_off_black_24dp.png toggle/ic_radio_button_off_black_24dp.png image/png
    2023-11-26 21:53:39.537  - info: host.ioBroker iobroker npm-install: upload [8] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_radio_button_off_white_24dp.png toggle/ic_radio_button_off_white_24dp.png image/png
    2023-11-26 21:53:39.561  - info: host.ioBroker iobroker npm-install: upload [7] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_radio_button_on_black_24dp.png toggle/ic_radio_button_on_black_24dp.png image/png
    2023-11-26 21:53:41.099  - info: host.ioBroker iobroker npm-install: upload [6] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_radio_button_on_white_24dp.png toggle/ic_radio_button_on_white_24dp.png image/png
    2023-11-26 21:53:41.141  - info: host.ioBroker iobroker npm-install: upload [5] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_star_black_48dp.png toggle/ic_star_black_48dp.png image/png
    2023-11-26 21:53:41.167  - info: host.ioBroker iobroker npm-install: upload [4] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_star_half_black_48dp.png toggle/ic_star_half_black_48dp.png image/png
    2023-11-26 21:53:41.210  - info: host.ioBroker iobroker npm-install: upload [3] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_star_half_white_48dp.png toggle/ic_star_half_white_48dp.png image/png
    2023-11-26 21:53:41.234  - info: host.ioBroker iobroker npm-install: upload [2] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_star_outline_black_48dp.png toggle/ic_star_outline_black_48dp.png image/png
    2023-11-26 21:53:41.257  - info: host.ioBroker iobroker npm-install: upload [1] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_star_outline_white_48dp.png toggle/ic_star_outline_white_48dp.png image/png
    2023-11-26 21:53:41.282  - info: host.ioBroker iobroker npm-install: upload [0] icons-material-png /opt/iobroker/node_modules/iobroker.icons-material-png/www/toggle/ic_star_white_48dp.png toggle/ic_star_white_48dp.png image/png
    2023-11-26 21:53:41.517  - info: host.ioBroker iobroker npm-install: host.ioBroker object system.adapter.icons-material-png created/updated
    2023-11-26 21:53:42.750  - info: host.ioBroker iobroker npm-install: exit 0
    2023-11-26 21:53:43.752  - warn: host.ioBroker startInstance cannot find adapter "icons-mfd-png@1.1.0". Try to install it... 1 attempt
    2023-11-26 21:53:43.752  - info: host.ioBroker iobroker install icons-mfd-png@1.1.0 using installedFrom
    2023-11-26 21:53:48.294  - info: host.ioBroker iobroker npm-install: NPM version: 9.8.1
    2023-11-26 21:53:48.298  - info: host.ioBroker iobroker npm-install: Installing iobroker.icons-mfd-png@1.1.0... (System call)
    iob diag has finished.
    Press any key for a summary
    • I IceD112
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               7812 M total memory
                656 M used memory
                829 M active memory
               5939 M free memory
                 53 M buffer memory
               1163 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      575M    /var/
      177M    /var/lib
      167M    /var/cache
      155M    /var/cache/apt
      132M    /var/log
      USB-Devices by-id:
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Adapter State
      + instance is alive
      Objects and States
      Objects:        34776
      States:         28760
      Pending Updates: 0
      HomoranH Offline
      HomoranH Offline
      #88
      @iced112 du liest schon was ich schreibe?
      @homoran sagte in Backup Größe ioBroker:
      dass ein restore aber bis zu 1h dauern kann weisst du?
      hier werden jetzt erst die Adapter Stück für Stück neu gebaut.
      Das dauert!
      I 1 Antwort Letzte Antwort
        Das dauert!
        I Offline
        I Offline
        IceD112
        #89
        @homoran said in Backup Größe ioBroker:
        sorry, hab ich überlesen
        Das dauert!
        also kann ich den PC eigentlich aus machen und pennen gehen :-) und morgen nochmal alles checken?
        • I IceD112
          Das dauert!
          CodierknechtC Offline
          Codierknecht
          #90
          @iced112
          also kann ich den PC eigentlich aus machen und pennen gehen 🙂 und morgen nochmal alles checken?
          Ja! Das macht der Pi auch alleine.
          ... und schalte den Desktop ab
          X-Server:       true
          Sowas hat auf 'nem Server nix zu suchen.
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
          • I Offline
            I Offline
            IceD112
            #91
            Die Wiederherstellung hat - sagen wir mal - so semi funktioniert.
            Es wurden, soweit ich das überblicken kann, alle Objekte wieder hergestellt. Die Adapter sind auch eigentlich alle installiert aber die meisten Instanzen nicht. Wenn ich eine Instanz hinzufüge, dann erstellt er die Instanz.1 aber die .0, also die ursprüngliche Instanz kann ich nicht finden?
            • I IceD112
              HomoranH Offline
              HomoranH Offline
              #92
              @iced112 wie wär's mit zeigen?
                I Offline
                I Offline
                IceD112
                #93
                Als Beispiel der Heos Adapter, dort steht eine installierte Instanz
                Taucht aber hier nicht auf
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                 14:37:36 up 17:06,  3 users,  load average: 0.27, 0.51, 0.44
                CPU threads: 4
                Current issues:
                               Local time: Mon 2023-11-27 14:37:36 CET
                           Universal time: Mon 2023-11-27 13:37:36 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       true
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            7.8G        1.5G        3.6G         35M        2.7G        6.2G
                Swap:            99M          0B         99M
                Total:          7.9G        1.5G        3.7G
                         7812 M total memory
                         1457 M used memory
                         1643 M active memory
                         2166 M inactive memory
                         3630 M free memory
                          119 M buffer memory
                         2604 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /dev/root      ext4       59G  6.1G   50G  11% /
                /var:
                576M    /var/
                177M    /var/lib
                167M    /var/cache
                155M    /var/cache/apt
                132M    /var/log
                522M    /opt/iobroker/iobroker-data/
                295M    /opt/iobroker/iobroker-data/files
                89M     /opt/iobroker/iobroker-data/backup-objects
                67M     /opt/iobroker/iobroker-data/files/javascript.admin
                81M     /opt/iobroker/iobroker-data/states.jsonl
                59M     /opt/iobroker/iobroker-data/objects.jsonl
                8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
                USB-Devices by-id:
                /usr/bin/npm            9.8.1
                /usr/bin/npx            9.8.1
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.4
                javascript:     7.1.6
                Adapters from github:   1
                Adapter State
                + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
                + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                + system.adapter.bring.0                  : bring                 : ioBroker                                 -  enabled
                  system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
                + system.adapter.denon.0                  : denon                 : ioBroker                                 -  enabled
                  system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
                + system.adapter.energiefluss.1           : energiefluss          : ioBroker                                 -  enabled
                + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 -  enabled
                + system.adapter.fronius-solarweb.1       : fronius-solarweb      : ioBroker                                 -  enabled
                + instance is alive
                Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
                Adapter    "admin"        : 6.12.5   , installed 6.12.4 [Updatable]
                Adapter    "alexa2"       : 3.26.3   , installed 3.26.1 [Updatable]
                Adapter    "bring"        : 1.8.4    , installed 1.8.4
                Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
                Adapter    "denon"        : 1.15.4   , installed 1.15.4
                Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
                Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                Adapter    "followthesun" : 0.4.2    , installed 0.4.2
                Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                Adapter    "ham"          : 5.3.1    , installed 5.3.1
                Adapter    "harmony"      : 1.3.0    , installed 1.3.0
                Adapter    "heos"         : 2.1.0    , installed 2.1.0
                Adapter    "hue"          : 3.10.1   , installed 3.10.1
                Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                Adapter    "ical"         : 1.13.3   , installed 1.13.3
                Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
                Adapter    "meross"       : 1.16.1   , installed 1.15.1 [Updatable]
                Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
                Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
                Adapter    "telegram"     : 3.0.0    , installed 3.0.0
                Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                Adapter    "vis"          : 1.5.1    , installed 1.5.1
                Adapter    "vis-icontwo"  : 0.98.0   , installed 0.97.3 [Updatable]
                Adapter    "web"          : 6.1.10   , installed 6.1.10
                Adapter    "ws"           : 2.5.8    , installed 2.5.8
                Adapter    "yr"           : 5.3.0    , installed 5.3.0
                Objects and States
                Objects:        39455
                States:         32474
                Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:3 http://deb.debian.org/debian bullseye InRelease
                Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                Pending Updates: 1
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          29990      6904/cupsd
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          29989      6904/cupsd
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       27543      6030/io.admin.0
                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          30793      6909/cups-browsed
                2023-11-27 14:29:38.109  - info: admin.0 (6030) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                2023-11-27 14:30:00.144  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 16169
                2023-11-27 14:30:03.091  - info: dwd.0 (16169) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.16
                2023-11-27 14:30:04.210  - info: host.ioBroker instance system.adapter.daswetter.0 started with pid 16184
                2023-11-27 14:30:07.157  - info: daswetter.0 (16184) starting. Version 3.1.11 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.18.2, js-controller: 5.0.16
                2023-11-27 14:30:08.590  - info: dwd.0 (16169) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2023-11-27 14:30:09.142  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-11-27 14:30:22.962  - info: daswetter.0 (16184) still wrong data structure from server received! repaired...
                2023-11-27 14:30:27.521  - info: daswetter.0 (16184) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                2023-11-27 14:30:28.037  - info: daswetter.0 (16184) cleaned everything up...
                2023-11-27 14:30:28.060  - info: host.ioBroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-11-27 14:30:39.032  - info: admin.0 (6030) Subscribe to all states again
                2023-11-27 14:31:39.156  - info: admin.0 (6030) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                2023-11-27 14:32:39.250  - info: admin.0 (6030) Subscribe to all states again
                2023-11-27 14:33:38.387  - info: admin.0 (6030) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                2023-11-27 14:34:39.314  - info: admin.0 (6030) Subscribe to all states again
                2023-11-27 14:35:00.076  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 16204
                2023-11-27 14:35:03.289  - info: dwd.0 (16204) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.16
                2023-11-27 14:35:07.239  - info: dwd.0 (16204) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2023-11-27 14:35:07.775  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-11-27 14:35:38.438  - info: admin.0 (6030) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                2023-11-27 14:36:39.358  - info: admin.0 (6030) Subscribe to all states again
                2023-11-27 14:37:38.485  - info: admin.0 (6030) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                2023-11-27 14:38:39.454  - info: admin.0 (6030) Subscribe to all states again
                2023-11-27 14:38:42.576  - info: admin.0 (6030) Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                • I IceD112
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       true
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:            99M          0B         99M
                           7812 M total memory
                           1457 M used memory
                           3630 M free memory
                            119 M buffer memory
                           2604 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  576M    /var/
                  177M    /var/lib
                  167M    /var/cache
                  155M    /var/cache/apt
                  132M    /var/log
                  USB-Devices by-id:
                  /usr/bin/npm            9.8.1
                  /usr/bin/npx            9.8.1
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.12.4
                  javascript:     7.1.6
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        39455
                  States:         32474
                  Pending Updates: 1
                  #94
                  @iced112 sagte in Backup Größe ioBroker:
                  X-Server: true
                  Ausschalten...
                  sudo systemctl default-set multi-user.target
                  Wassen da passiert?
                  IMMER die Kiste ordentlich herunterfahren. Stromentzug ist kein ordentliches Herunterfahren...
                  • I Offline
                    I Offline
                    IceD112
                    schrieb am zuletzt editiert von IceD112
                    #95
                    Reicht es nicht mit
                    iob stop
                    und dann ausschalten?
                    @thomas-braun said in Backup Größe ioBroker:
                    X-Server: true
                    Ausschalten...
                    ist das der Befehl für den pi runter zu fahren?
                    CodierknechtC Thomas BraunT 2 Antworten Letzte Antwort
                    • I IceD112
                      Reicht es nicht mit
                      iob stop
                      X-Server: true
                      Ausschalten...
                      Codierknecht
                      #96
                      Nein - damit wird der Desktop abgeschaltet.
                      Runterfahren mit
                      sudo shutdown -h 0
                      • I IceD112
                        Reicht es nicht mit
                        iob stop
                        X-Server: true
                        Ausschalten...
                        #97
                        Nein, die Kiste muss komplett heruntergefahren werden.
                        Du schredderst sonst das Dateisystem. (Siehe oben...)
                        sudo poweroff
                        und dann auch gerne eine Weile warten, das dauert bis zu einer Minute.
                          sudo poweroff
                          I Offline
                          I Offline
                          IceD112
                          #98
                          ok, das wusste ich tatsächlich alles nicht
                          Also wenn ich den pi vom Strom trennen möchte oder muss, dann
                          iob stop
                          sudo shutdown -h 0
                          sudo poweroff
                          oder ist das zuviel des Guten?
                          • I IceD112
                            iob stop
                            sudo shutdown -h 0
                            sudo poweroff
                            HomoranH Offline
                            HomoranH Offline
                            #99
                            zuviel des Guten
                            die 2. Zeile nur jetzt einmalig
                            und die 3. oder 4.
                            • I IceD112
                              iob stop
                              sudo shutdown -h 0
                              sudo poweroff
                              #100
                              Das ist nur einmal für das geänderte Boot Target zumachen.
                              Und
                              sudo shutdown -h 0
                              sudo poweroff
                              ist synonym. Du kannst also einen der beiden Befehle verwenden.
                                zuviel des Guten
                                und die 3. oder 4.
                                I Offline
                                I Offline
                                IceD112
                                #101
                                pi@ioBroker:~ $ sudo systemctl default-set multi-user.target
                                Unknown command verb default-set.
                                pi@ioBroker:~ $
                                  Und
                                  sudo shutdown -h 0
                                  sudo poweroff
                                  I Offline
                                  I Offline
                                  IceD112
                                  #102
                                  ok, danke
                                  • I IceD112
                                    pi@ioBroker:~ $
                                    #103
                                    Wenn man aus der Erinnerung schreibt...
                                    Das muss natürlich
                                    sudo systemctl set-default multi-user.target
                                    lauten.
                                      Das muss natürlich
                                      lauten.
                                      I Offline
                                      I Offline
                                      IceD112
                                      #104
                                      pi@ioBroker:~ $ sudo systemctl set-default multi-user.target
                                      Removed /etc/systemd/system/default.target.
                                      Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-user.target.
                                      • I IceD112
                                        #105
                                        @iced112
                                        Ja, das ist so richtig.
                                          @iced112
                                          I Offline
                                          I Offline
                                          IceD112
                                          #106
                                          Muss ich die Instanzen, die aktuell nicht angezeigt werden, denn evtl mit
                                          iobroker restart adapterName.instance
                                          starten.
                                          Also alle die laut diag auf disabled stehen?
                                          Thomas BraunT I 2 Antworten Letzte Antwort
