  4. Backup Größe ioBroker
115 Beiträge 6 Kommentatoren 19.9k Aufrufe 4 Beobachtet
    @iced112
    Nein, die Mountoption für ein CIFS/SMB Mount.
    I Offline
    I Offline
    IceD112
    Ah, wurde mir gerade erst angezeigt, komisch...
    Den anderen Haken bei "noserverino" dafür entfernen?
    • I IceD112
      @iced112
      Nein, bei FritzNAS beides aktiv setzen.
      I 1 Antwort Letzte Antwort
        @iced112
        I Offline
        I Offline
        IceD112
        schrieb am zuletzt editiert von IceD112
        ok, dann sicher ich grade nochmal ein Backup
        EDIT: Also an der Datei Größe hat sich nicht geändert
        Started iobroker ...
        [DEBUG] [mount] - mount activ... umount is started before mount!!
        [DEBUG] [mount] - umount successfully completed
        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=ioB_Backup,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.1/IceDBox/IOBROKER/ioBroker /opt/iobroker/backups"
        [DEBUG] [mount] - mount successfully completed
        [DEBUG] [mount] - done
        [DEBUG] [iobroker] - host.ioBroker 28368 states saved
        [DEBUG] [iobroker] - host.ioBroker 33321 objects saved
        [DEBUG] [iobroker] - done
        [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
        [DEBUG] [javascripts] - found Script: Anwesenheit
        [DEBUG] [javascripts] - found Script: Anwesenheit_Kinder
        [DEBUG] [javascripts] - found Script: Blink-Kamera
        [DEBUG] [javascripts] - found Script: Blink_Kamera
        [DEBUG] [javascripts] - found Script: Garagenlicht
        [DEBUG] [javascripts] - found Script: Licht_Esszimmer_normal
        [DEBUG] [javascripts] - found Script: Weihnachten
        [DEBUG] [javascripts] - found Script: Regenradar
        [DEBUG] [javascripts] - found Script: Rollo_Fenster_Warnung
        [DEBUG] [javascripts] - found Script: Rollo_Schlafzimmer
        [DEBUG] [javascripts] - found Script: Rollo_Wochenende
        [DEBUG] [javascripts] - found Script: Rollo_Wohnzimmer
        [DEBUG] [javascripts] - found Script: Batterieüberwachung
        [DEBUG] [javascripts] - found Script: Fenster_Bad
        [DEBUG] [javascripts] - found Script: Fenster_Status
        [DEBUG] [javascripts] - found Script: Stimmungslicht
        [DEBUG] [javascripts] - found Script: Subwoofer_aus
        [DEBUG] [javascripts] - found Script: Wecker
        [DEBUG] [javascripts] - found Script: Fußball
        [DEBUG] [javascripts] - found Script: Multiroom_starten
        [DEBUG] [javascripts] - found Script: Telegrammbaustein
        [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
        [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
        [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2023_11_25-15_25_43_backupiobroker.tar.gz
        [DEBUG] [javascripts] - done
        [DEBUG] [cifs] - used copy path: /IceDBox/IOBROKER/ioBroker
        [DEBUG] [cifs] - done
        [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
        [DEBUG] [clean] - done
        [DEBUG] [historyHTML] - new history html values created
        [DEBUG] [historyHTML] - done
        [DEBUG] [historyJSON] - new history json values created
        [DEBUG] [historyJSON] - done
        [DEBUG] [umount] - mount activ, umount is started ...
        [DEBUG] [umount] - umount successfully completed
        [DEBUG] [umount] - done
        [EXIT] 0
        • I Offline
          I Offline
          IceD112
          Kann mir niemand beantworten, warum das Backup vom ioBroker nicht funktioniert?
          • I IceD112
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @iced112 sagte in Backup Größe ioBroker:
            wie ich ganz oben schon erwähnt habe bist Du "sportlich" unterwegs:
            2GB Ram und 42 Adapter installiert. Da geht bei Dir nichts mehr wenn das Backup startet, denn dieser Start vom Backup braucht auch Speicher.
            Lehrling seit 1975 !!!
            • DJMarc75D DJMarc75
              I Offline
              I Offline
              IceD112
              @djmarc75
              Hab den neuen PI mit 8gb schon hier vor mir. Ist fertig konfiguriert und ein neuer iob installiert.
              Irgendwie muss das alte system doch zu sichern sein?
              • I IceD112
                @djmarc75
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                Vom "neuen" iob bitte auch mal
                iob diag
                zeigen.
                Jo, dazu gibt es den Adapter "BackitUp".
                  iob diag
                  zeigen.
                  I Offline
                  I Offline
                  IceD112
                  Damit arbeite ich ja.
                  Die Sicherungen gehen auf die Fritzbox. Aber jedes Backup hat 0 MB. Weis aber nicht warum
                  • I IceD112
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    Wir drehen uns im Kreis:
                    https://forum.iobroker.net/topic/70494/backup-größe-iobroker/28?_=1700978716741
                    @djmarc75 sagte in Backup Größe ioBroker:
                      I Offline
                      I Offline
                      IceD112
                      @djmarc75
                      Ja, schon verstanden, aber das soll ja nicht bedeuten, dass ich ganz von vorne anfangen muss
                      • I Offline
                        I Offline
                        IceD112
                        Wenn der Backitup Adapter ja so viel Leistung bindet, dass er kein Backup durchführen kann, muss es doch auch ne andere Lösung geben, ein Backup zu erstellen
                        Marc BergM HomoranH 2 Antworten Letzte Antwort
                        • I IceD112
                          Marc BergM Online
                          Marc BergM Online
                          Marc Berg
                          Auch wenn es ziemlich wahrscheinlich ist, dass der RAM knapp wird, würde ich trotzdem mal versuchen, das Backup lokal zu speichern, um auszuschließen, dass es am Mount/an der Fritzbox liegt.
                          • Marc BergM Marc Berg
                            I Offline
                            I Offline
                            IceD112
                            @marc-berg Dazu mach ich den Haken bei NAS weg und starte eine neue Sicherung?
                            Wo genau finde ich sie dann?
                            • I IceD112
                              Marc BergM Online
                              Marc BergM Online
                              Marc Berg
                              unter /opt/iobroker/backups
                                I Offline
                                I Offline
                                IceD112
                                @marc-berg
                                Ist es normal dass der Admin Adapter beim Backup neu startet?
                                Ich verstehe halt nur nicht, ich sicher ja auch JavaScript und da sind Dateien drin, dann dürfte es eigentlich ja nicht am Mount liegen?
                                Marc BergM 2 Antworten Letzte Antwort
                                • I IceD112
                                  @marc-berg
                                  Marc BergM Online
                                  Marc BergM Online
                                  Marc Berg
                                  Nö, aber das spricht für die RAM Theorie.
                                  • I IceD112
                                    @marc-berg
                                    Marc BergM Online
                                    Marc BergM Online
                                    Marc Berg
                                    Ja, ist auch nur ein Versuch, um die Anzahl der Variablen zu reduzieren. Jedenfalls versuche ich mich immer so einem Problem zu nähern. Es KÖNNTE ja sein, dass die Größe der Dateien beim Mount ein Problem ist oder der Speicherplatz nicht reicht.
                                      I Offline
                                      I Offline
                                      IceD112
                                      @marc-berg
                                      Dumme Frage, aber ich nehme an, die SD Karte aus dem 2GB PI in den 8GB Pi stecken, bringt nichts
                                      Was kann ich sonst versuchen?
                                      • I IceD112
                                        @marc-berg
                                        Marc BergM Online
                                        Marc BergM Online
                                        Marc Berg
                                        Keine Ahnung, ob das funktioniert. Ein Versuch wäre aber noch, vor dem Backup alle Adapter zu stoppen, um RAM zu sparen. Es geht ja nur darum, das Backup 1x durchzuziehen, richtig?
                                          I Offline
                                          I Offline
                                          IceD112
                                          @marc-berg Richtig, Gute Idee. das probiere ich noch
                                          Und ggf über filezilla irgendwie was sichern? Also falls das andere nicht geht?
