  4. Backup Größe ioBroker
115 Beiträge 6 Kommentatoren 19.9k Aufrufe 4 Beobachtet
    @iced112
    Mach das nochmal ordentlich und nicht so Kraut-und-Rüben-Durcheinander.
    I Offline
    I Offline
    IceD112
    ☺ Was meinst du mit ordenlich?
    • I Offline
      I Offline
      IceD112
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: ioBroker
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : armhf
      Systemuptime and Load:
       16:24:58 up 20 min,  2 users,  load average: 1.68, 2.09, 1.90
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Fri 2023-11-24 16:24:59 CET
                 Universal time: Fri 2023-11-24 15:24:59 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            1.8G        1.5G        239M        0.0K        133M        307M
      Swap:            99M         80M         19M
      Total:          1.9G        1.6G        258M
               1849 M total memory
               1477 M used memory
                533 M active memory
                945 M inactive memory
                238 M free memory
                  5 M buffer memory
                127 M swap cache
                 99 M total swap
                 80 M used swap
                 19 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       29G  7.6G   21G  28% /
      devtmpfs       devtmpfs  667M     0  667M   0% /dev
      tmpfs          tmpfs     925M     0  925M   0% /dev/shm
      tmpfs          tmpfs     370M  828K  370M   1% /run
      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
      [Fri Nov 24 16:04:31 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:CF:73:10 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f85227ed-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Fri Nov 24 16:04:32 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Fri Nov 24 16:04:32 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Fri Nov 24 16:04:33 2023] EXT4-fs (mmcblk0p2): recovery complete
      [Fri Nov 24 16:04:33 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Nov 24 16:04:33 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Fri Nov 24 16:04:35 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      3.5G    /var/
      2.9G    /var/log/journal/25070aeb79f44c94a7f7bcc85e4ba968
      2.9G    /var/log
      387M    /var/cache
      Archived and active journals take up 2.8G in the file system.
      /opt/iobroker/backups:
      74M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      737M    /opt/iobroker/iobroker-data/
      316M    /opt/iobroker/iobroker-data/files
      274M    /opt/iobroker/iobroker-data/backup-objects
      74M     /opt/iobroker/iobroker-data/files/vis.0
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      119M    /opt/iobroker/iobroker-data/states.jsonl
      29M     /opt/iobroker/iobroker-data/objects.jsonl
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
      USB-Devices by-id:
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.2
      /usr/bin/node           v18.18.2
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      /usr/bin/corepack       0.19.0
      nodejs:
        Installed: 18.18.2-1nodesource1
        Candidate: 18.18.2-1nodesource1
        Version table:
       *** 18.18.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.16
      admin:          6.12.4
      javascript:     7.1.6
      Adapters from github:   1
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      + system.adapter.bring.0                  : bring                 : ioBroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
      + system.adapter.denon.0                  : denon                 : ioBroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
      + system.adapter.energiefluss.1           : energiefluss          : ioBroker                                 -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 -  enabled
      + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
      + system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker                                 -  enabled
      + system.adapter.ham.0                    : ham                   : ioBroker                                 -  enabled
      + system.adapter.harmony.0                : harmony               : ioBroker                                 -  enabled
      + system.adapter.heos.0                   : heos                  : ioBroker                                 -  enabled
      + system.adapter.hue-extended.0           : hue-extended          : ioBroker                                 -  enabled
      + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
      + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      + system.adapter.lgtv11.0                 : lgtv11                : ioBroker                                 -  enabled, port: 8080
      + system.adapter.meross.0                 : meross                : ioBroker                                 -  enabled
      + system.adapter.panasonic-viera.0        : panasonic-viera       : ioBroker                                 -  enabled
      + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
      + system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
        system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.yr.0                     : yr                    : ioBroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
      Adapter    "admin"        : 6.12.5   , installed 6.12.4 [Updatable]
      Adapter    "alexa2"       : 3.26.2   , installed 3.26.1 [Updatable]
      Adapter    "backitup"     : 2.9.4    , installed 2.9.4
      Adapter    "bring"        : 1.8.4    , installed 1.8.4
      Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
      Adapter    "denon"        : 1.15.4   , installed 1.15.4
      Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
      Adapter    "followthesun" : 0.4.2    , installed 0.4.2
      Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "harmony"      : 1.3.0    , installed 1.3.0
      Adapter    "heos"         : 2.1.0    , installed 2.1.0
      Adapter    "hue"          : 3.10.1   , installed 3.10.1
      Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.16   , installed 5.0.16
      Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
      Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
      Adapter    "meross"       : 1.15.1   , installed 1.15.1
      Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "socketio"     : 6.6.0    , installed 6.6.0
      Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
      Adapter    "telegram"     : 3.0.0    , installed 3.0.0
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "vis"          : 1.5.1    , installed 1.5.1
      Adapter    "vis-icontwo"  : 0.97.3   , installed 0.97.3
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Objects and States
      Objects:        34709
      States:         28960
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12702      505/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       37937      3214/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       37338      3214/iobroker.js-co
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12704      505/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35444      3232/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       39627      3782/io.web.0
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       40041      3587/io.harmony.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12063      366/avahi-daemon: r
      udp        0      0 0.0.0.0:54738           0.0.0.0:*                           1001       38702      3614/io.heos.0
      udp        0      0 0.0.0.0:48670           0.0.0.0:*                           108        12065      366/avahi-daemon: r
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       40042      3587/io.harmony.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       37629      3400/io.shelly.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15363      739/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        12064      366/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          12844      739/dhcpcd
      udp6       0      0 :::36996                :::*                                108        12066      366/avahi-daemon: r
      2023-11-24 16:24:57.534  - warn: javascript.0 (3243)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
      2023-11-24 16:24:57.534  - warn: javascript.0 (3243)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2023-11-24 16:24:57.534  - warn: javascript.0 (3243)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11220:62)
      2023-11-24 16:24:57.535  - warn: javascript.0 (3243)     at processImmediate (node:internal/timers:476:21)
      2023-11-24 16:24:57.541  - info: javascript.0 (3243) State value to set for "0_userdata.0.Anwesenheit.Anwesenheit" has to be stringified but received type "boolean"
      2023-11-24 16:25:00.142  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 4474
      2023-11-24 16:25:05.250  - info: dwd.0 (4474) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.16
      2023-11-24 16:25:09.631  - info: dwd.0 (4474) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-11-24 16:25:10.170  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-11-24 16:25:13.134  - warn: javascript.0 (3243) You are assigning a boolean to the state "0_userdata.0.Anwesenheit.Anwesenheit" which expects a object. Please fix your code to use a object or change the state type to boolean. This warning might become an error in future versions.
      2023-11-24 16:25:13.137  - warn: javascript.0 (3243)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
      2023-11-24 16:25:13.138  - warn: javascript.0 (3243)     at Object.<anonymous> (script.js.Anwesenheit.Anwesenheit:3:5)
      2023-11-24 16:25:13.139  - warn: javascript.0 (3243)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
      2023-11-24 16:25:13.140  - warn: javascript.0 (3243)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2023-11-24 16:25:13.141  - warn: javascript.0 (3243)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11220:62)
      2023-11-24 16:25:13.142  - warn: javascript.0 (3243)     at processImmediate (node:internal/timers:476:21)
      2023-11-24 16:25:13.157  - info: javascript.0 (3243) State value to set for "0_userdata.0.Anwesenheit.Anwesenheit" has to be stringified but received type "boolean"
      2023-11-24 16:25:29.674  - warn: javascript.0 (3243) You are assigning a boolean to the state "0_userdata.0.Anwesenheit.Anwesenheit" which expects a object. Please fix your code to use a object or change the state type to boolean. This warning might become an error in future versions.
      2023-11-24 16:25:29.677  - warn: javascript.0 (3243)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
      2023-11-24 16:25:29.677  - warn: javascript.0 (3243)     at Object.<anonymous> (script.js.Anwesenheit.Anwesenheit:5:5)
      2023-11-24 16:25:29.677  - warn: javascript.0 (3243)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
      2023-11-24 16:25:29.678  - warn: javascript.0 (3243)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2023-11-24 16:25:29.678  - warn: javascript.0 (3243)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11220:62)
      2023-11-24 16:25:29.678  - warn: javascript.0 (3243)     at processImmediate (node:internal/timers:476:21)
      2023-11-24 16:25:29.770  - info: javascript.0 (3243) State value to set for "0_userdata.0.Anwesenheit.Anwesenheit" has to be stringified but received type "boolean"
      iob diag has finished.
      I 1 Antwort Letzte Antwort
      • I IceD112
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : armhf
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M         80M         19M
                 1849 M total memory
                 1477 M used memory
                  533 M active memory
                  238 M free memory
                    5 M buffer memory
                  127 M swap cache
                   99 M total swap
                   80 M used swap
                   19 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        3.5G    /var/
        2.9G    /var/log
        387M    /var/cache
        USB-Devices by-id:
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.4
        javascript:     7.1.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        34709
        States:         28960
        Pending Updates: 0
        I Offline
        I Offline
        IceD112
        Woran liegt es denn, dass das Backup nicht vollständig ist?
        • I IceD112
          Marc BergM Online
          Marc BergM Online
          Marc Berg
          @iced112
          was sagt
          ls -lah /opt/iobroker/backups
          EDIT: Ach Quatsch, das Verzeichnis ist ja gemountet. Was liegt in //192.168.178.1/IceDBox/IOBROKER/ioBroker ?
          • Thomas BraunT Online
            @iced112
            Mounte Mal mit der Option 'Cache Loose'.
            Unter Umständen erst in der Beta-Version von Backitup zu finden.
            • I IceD112
              Hallo
              Nach Performance-Problemen mit meinem aktuellen Pi (2GB Ram) habe ich was stärkeres im Zulauf und möchte mein System neu aufbauen. Bzw. aus einem Backup auf dem neuen Pi wieder herstellen.
              Ich sicher mir regelmäßig ein Backup mit dem Backitup Adapter den ich so konfiguriert habe
              die Sicherungen gehen auf meinen FRITZ!NAS, dort habe ich einen Stick für die Sicherungen dran.
              2 Fragen:
              1. Bei der Sicherung des ioBrokers, ist da die VIS mit dabei?
              2. Ist es plausibel, dass die Sicherung, bei 42 Installierten Adaptern nur 35,38 kb hat?
              letztes Backup gerade
              Started iobroker ...
              [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=ioB_Backup,password=****,noserverino,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.1/IceDBox/IOBROKER/ioBroker /opt/iobroker/backups"
              [DEBUG] [mount] - mount successfully completed
              [DEBUG] [mount] - done
              [DEBUG] [iobroker] - host.ioBroker 28978 states saved
              [DEBUG] [iobroker] - host.ioBroker 33970 objects saved
              [DEBUG] [iobroker] - done
              [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
              [DEBUG] [javascripts] - found Script: Anwesenheit
              [DEBUG] [javascripts] - found Script: Anwesenheit_Kinder
              [DEBUG] [javascripts] - found Script: Blink-Kamera
              [DEBUG] [javascripts] - found Script: Blink_Kamera
              [DEBUG] [javascripts] - found Script: Garagenlicht
              [DEBUG] [javascripts] - found Script: Licht_Esszimmer_normal
              [DEBUG] [javascripts] - found Script: Weihnachten
              [DEBUG] [javascripts] - found Script: Regenradar
              [DEBUG] [javascripts] - found Script: Rollo_Fenster_Warnung
              [DEBUG] [javascripts] - found Script: Rollo_Schlafzimmer
              [DEBUG] [javascripts] - found Script: Rollo_Wochenende
              [DEBUG] [javascripts] - found Script: Rollo_Wohnzimmer
              [DEBUG] [javascripts] - found Script: Batterieüberwachung
              [DEBUG] [javascripts] - found Script: Fenster_Bad
              [DEBUG] [javascripts] - found Script: Fenster_Status
              [DEBUG] [javascripts] - found Script: Stimmungslicht
              [DEBUG] [javascripts] - found Script: Subwoofer_aus
              [DEBUG] [javascripts] - found Script: Wecker
              [DEBUG] [javascripts] - found Script: Fußball
              [DEBUG] [javascripts] - found Script: Multiroom_starten
              [DEBUG] [javascripts] - found Script: Telegrammbaustein
              [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
              [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
              [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2023_11_24-15_57_59_backupiobroker.tar.gz
              [DEBUG] [javascripts] - done
              [DEBUG] [cifs] - used copy path: /IceDBox/IOBROKER/ioBroker
              [DEBUG] [cifs] - done
              [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
              [DEBUG] [clean] - done
              [DEBUG] [historyHTML] - new history html values created
              [DEBUG] [historyHTML] - done
              [DEBUG] [historyJSON] - new history json values created
              [DEBUG] [historyJSON] - done
              [DEBUG] [umount] - mount activ, umount is started ...
              [DEBUG] [umount] - umount successfully completed
              [DEBUG] [umount] - done
              [EXIT] 0
              I Offline
              I Offline
              IceD112
              @Marc-Berg said in Backup Größe ioBroker:
              1. Ist es plausibel, dass die Sicherung, bei 42 Installierten Adaptern nur 35,38 kb hat?
              Da liegen die Backups
              Die allermeisten sind 0 kb, also leer
              weis aber nicht warum
                @iced112
                I Offline
                I Offline
                IceD112
                Wo Finde ich die Einstellung?
                Meinst du den Verbindungstyp
                • I IceD112
                  @iced112
                  Nein, die Mountoption für ein CIFS/SMB Mount.
                    @iced112
                    I Offline
                    I Offline
                    IceD112
                    Ah, wurde mir gerade erst angezeigt, komisch...
                    Den anderen Haken bei "noserverino" dafür entfernen?
                    • I IceD112
                      @iced112
                      Nein, bei FritzNAS beides aktiv setzen.
                        @iced112
                        I Offline
                        I Offline
                        IceD112
                        schrieb am zuletzt editiert von IceD112
                        ok, dann sicher ich grade nochmal ein Backup
                        EDIT: Also an der Datei Größe hat sich nicht geändert
                        [DEBUG] [mount] - mount activ... umount is started before mount!!
                        [DEBUG] [mount] - umount successfully completed
                        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=ioB_Backup,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.1/IceDBox/IOBROKER/ioBroker /opt/iobroker/backups"
                        [DEBUG] [iobroker] - host.ioBroker 28368 states saved
                        [DEBUG] [iobroker] - host.ioBroker 33321 objects saved
                        [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2023_11_25-15_25_43_backupiobroker.tar.gz
                        [EXIT] 0
                        • I Offline
                          I Offline
                          IceD112
                          Kann mir niemand beantworten, warum das Backup vom ioBroker nicht funktioniert?
                          • I IceD112
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            @iced112 sagte in Backup Größe ioBroker:
                            wie ich ganz oben schon erwähnt habe bist Du "sportlich" unterwegs:
                            2GB Ram und 42 Adapter installiert. Da geht bei Dir nichts mehr wenn das Backup startet, denn dieser Start vom Backup braucht auch Speicher.
                            Lehrling seit 1975 !!!
                            • DJMarc75D DJMarc75
                              I Offline
                              I Offline
                              IceD112
                              @djmarc75
                              Hab den neuen PI mit 8gb schon hier vor mir. Ist fertig konfiguriert und ein neuer iob installiert.
                              Irgendwie muss das alte system doch zu sichern sein?
                              • I IceD112
                                @djmarc75
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                Vom "neuen" iob bitte auch mal
                                iob diag
                                zeigen.
                                Jo, dazu gibt es den Adapter "BackitUp".
                                  iob diag
                                  zeigen.
                                  I Offline
                                  I Offline
                                  IceD112
                                  Damit arbeite ich ja.
                                  Die Sicherungen gehen auf die Fritzbox. Aber jedes Backup hat 0 MB. Weis aber nicht warum
                                  • I IceD112
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    Wir drehen uns im Kreis:
                                    https://forum.iobroker.net/topic/70494/backup-größe-iobroker/28?_=1700978716741
                                    @djmarc75 sagte in Backup Größe ioBroker:
                                      I Offline
                                      I Offline
                                      IceD112
                                      @djmarc75
                                      Ja, schon verstanden, aber das soll ja nicht bedeuten, dass ich ganz von vorne anfangen muss
                                      • I Offline
                                        I Offline
                                        IceD112
                                        Wenn der Backitup Adapter ja so viel Leistung bindet, dass er kein Backup durchführen kann, muss es doch auch ne andere Lösung geben, ein Backup zu erstellen
                                        Marc BergM HomoranH 2 Antworten Letzte Antwort
                                        • I IceD112
                                          Marc BergM Online
                                          Marc BergM Online
                                          Marc Berg
                                          Auch wenn es ziemlich wahrscheinlich ist, dass der RAM knapp wird, würde ich trotzdem mal versuchen, das Backup lokal zu speichern, um auszuschließen, dass es am Mount/an der Fritzbox liegt.
