  4. Backup Größe ioBroker
115 Beiträge 6 Kommentatoren 19.9k Aufrufe 4 Beobachtet
  • I IceD112
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: ioBroker
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     16:24:58 up 20 min,  2 users,  load average: 1.68, 2.09, 1.90
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Fri 2023-11-24 16:24:59 CET
               Universal time: Fri 2023-11-24 15:24:59 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            1.8G        1.5G        239M        0.0K        133M        307M
    Swap:            99M         80M         19M
    Total:          1.9G        1.6G        258M
             1849 M total memory
             1477 M used memory
              533 M active memory
              945 M inactive memory
              238 M free memory
                5 M buffer memory
              127 M swap cache
               99 M total swap
               80 M used swap
               19 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G  7.6G   21G  28% /
    devtmpfs       devtmpfs  667M     0  667M   0% /dev
    tmpfs          tmpfs     925M     0  925M   0% /dev/shm
    tmpfs          tmpfs     370M  828K  370M   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
    [Fri Nov 24 16:04:31 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:CF:73:10 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f85227ed-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Fri Nov 24 16:04:32 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Fri Nov 24 16:04:32 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Fri Nov 24 16:04:33 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Fri Nov 24 16:04:33 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Nov 24 16:04:33 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Fri Nov 24 16:04:35 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    3.5G    /var/
    2.9G    /var/log/journal/25070aeb79f44c94a7f7bcc85e4ba968
    2.9G    /var/log
    387M    /var/cache
    Archived and active journals take up 2.8G in the file system.
    /opt/iobroker/backups:
    74M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    737M    /opt/iobroker/iobroker-data/
    316M    /opt/iobroker/iobroker-data/files
    274M    /opt/iobroker/iobroker-data/backup-objects
    74M     /opt/iobroker/iobroker-data/files/vis.0
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    119M    /opt/iobroker/iobroker-data/states.jsonl
    29M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.16
    admin:          6.12.4
    javascript:     7.1.6
    Adapters from github:   1
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.bring.0                  : bring                 : ioBroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
    + system.adapter.denon.0                  : denon                 : ioBroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
    + system.adapter.energiefluss.1           : energiefluss          : ioBroker                                 -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 -  enabled
    + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
    + system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker                                 -  enabled
    + system.adapter.ham.0                    : ham                   : ioBroker                                 -  enabled
    + system.adapter.harmony.0                : harmony               : ioBroker                                 -  enabled
    + system.adapter.heos.0                   : heos                  : ioBroker                                 -  enabled
    + system.adapter.hue-extended.0           : hue-extended          : ioBroker                                 -  enabled
    + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
    + system.adapter.lgtv11.0                 : lgtv11                : ioBroker                                 -  enabled, port: 8080
    + system.adapter.meross.0                 : meross                : ioBroker                                 -  enabled
    + system.adapter.panasonic-viera.0        : panasonic-viera       : ioBroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
    + system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yr.0                     : yr                    : ioBroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
    Adapter    "admin"        : 6.12.5   , installed 6.12.4 [Updatable]
    Adapter    "alexa2"       : 3.26.2   , installed 3.26.1 [Updatable]
    Adapter    "backitup"     : 2.9.4    , installed 2.9.4
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
    Adapter    "denon"        : 1.15.4   , installed 1.15.4
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "followthesun" : 0.4.2    , installed 0.4.2
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "harmony"      : 1.3.0    , installed 1.3.0
    Adapter    "heos"         : 2.1.0    , installed 2.1.0
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.16   , installed 5.0.16
    Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
    Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
    Adapter    "meross"       : 1.15.1   , installed 1.15.1
    Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
    Adapter    "telegram"     : 3.0.0    , installed 3.0.0
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "vis"          : 1.5.1    , installed 1.5.1
    Adapter    "vis-icontwo"  : 0.97.3   , installed 0.97.3
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Objects and States
    Objects:        34709
    States:         28960
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12702      505/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       37937      3214/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       37338      3214/iobroker.js-co
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12704      505/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35444      3232/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       39627      3782/io.web.0
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       40041      3587/io.harmony.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12063      366/avahi-daemon: r
    udp        0      0 0.0.0.0:54738           0.0.0.0:*                           1001       38702      3614/io.heos.0
    udp        0      0 0.0.0.0:48670           0.0.0.0:*                           108        12065      366/avahi-daemon: r
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       40042      3587/io.harmony.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       37629      3400/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15363      739/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        12064      366/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          12844      739/dhcpcd
    udp6       0      0 :::36996                :::*                                108        12066      366/avahi-daemon: r
    2023-11-24 16:24:57.534  - warn: javascript.0 (3243)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
    2023-11-24 16:24:57.534  - warn: javascript.0 (3243)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2023-11-24 16:24:57.534  - warn: javascript.0 (3243)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11220:62)
    2023-11-24 16:24:57.535  - warn: javascript.0 (3243)     at processImmediate (node:internal/timers:476:21)
    2023-11-24 16:24:57.541  - info: javascript.0 (3243) State value to set for "0_userdata.0.Anwesenheit.Anwesenheit" has to be stringified but received type "boolean"
    2023-11-24 16:25:00.142  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 4474
    2023-11-24 16:25:05.250  - info: dwd.0 (4474) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.16
    2023-11-24 16:25:09.631  - info: dwd.0 (4474) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-11-24 16:25:10.170  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-11-24 16:25:13.134  - warn: javascript.0 (3243) You are assigning a boolean to the state "0_userdata.0.Anwesenheit.Anwesenheit" which expects a object. Please fix your code to use a object or change the state type to boolean. This warning might become an error in future versions.
    2023-11-24 16:25:13.137  - warn: javascript.0 (3243)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
    2023-11-24 16:25:13.138  - warn: javascript.0 (3243)     at Object.<anonymous> (script.js.Anwesenheit.Anwesenheit:3:5)
    2023-11-24 16:25:13.139  - warn: javascript.0 (3243)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
    2023-11-24 16:25:13.140  - warn: javascript.0 (3243)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2023-11-24 16:25:13.141  - warn: javascript.0 (3243)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11220:62)
    2023-11-24 16:25:13.142  - warn: javascript.0 (3243)     at processImmediate (node:internal/timers:476:21)
    2023-11-24 16:25:13.157  - info: javascript.0 (3243) State value to set for "0_userdata.0.Anwesenheit.Anwesenheit" has to be stringified but received type "boolean"
    2023-11-24 16:25:29.674  - warn: javascript.0 (3243) You are assigning a boolean to the state "0_userdata.0.Anwesenheit.Anwesenheit" which expects a object. Please fix your code to use a object or change the state type to boolean. This warning might become an error in future versions.
    2023-11-24 16:25:29.677  - warn: javascript.0 (3243)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
    2023-11-24 16:25:29.677  - warn: javascript.0 (3243)     at Object.<anonymous> (script.js.Anwesenheit.Anwesenheit:5:5)
    2023-11-24 16:25:29.677  - warn: javascript.0 (3243)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
    2023-11-24 16:25:29.678  - warn: javascript.0 (3243)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2023-11-24 16:25:29.678  - warn: javascript.0 (3243)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11220:62)
    2023-11-24 16:25:29.678  - warn: javascript.0 (3243)     at processImmediate (node:internal/timers:476:21)
    2023-11-24 16:25:29.770  - info: javascript.0 (3243) State value to set for "0_userdata.0.Anwesenheit.Anwesenheit" has to be stringified but received type "boolean"
    iob diag has finished.
    I Offline
    I Offline
    IceD112
    Woran liegt es denn, dass das Backup nicht vollständig ist?
    • I IceD112
      Marc BergM Offline
      Marc BergM Offline
      Marc Berg
      @iced112
      was sagt
      ls -lah /opt/iobroker/backups
      EDIT: Ach Quatsch, das Verzeichnis ist ja gemountet. Was liegt in //192.168.178.1/IceDBox/IOBROKER/ioBroker ?
      • Thomas BraunT Online
        @iced112
        Mounte Mal mit der Option 'Cache Loose'.
        Unter Umständen erst in der Beta-Version von Backitup zu finden.
        I 1 Antwort Letzte Antwort
        • I IceD112
          Hallo
          Nach Performance-Problemen mit meinem aktuellen Pi (2GB Ram) habe ich was stärkeres im Zulauf und möchte mein System neu aufbauen. Bzw. aus einem Backup auf dem neuen Pi wieder herstellen.
          Ich sicher mir regelmäßig ein Backup mit dem Backitup Adapter den ich so konfiguriert habe
          die Sicherungen gehen auf meinen FRITZ!NAS, dort habe ich einen Stick für die Sicherungen dran.
          2 Fragen:
          1. Bei der Sicherung des ioBrokers, ist da die VIS mit dabei?
          2. Ist es plausibel, dass die Sicherung, bei 42 Installierten Adaptern nur 35,38 kb hat?
          letztes Backup gerade
          Started iobroker ...
          [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=ioB_Backup,password=****,noserverino,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.1/IceDBox/IOBROKER/ioBroker /opt/iobroker/backups"
          [DEBUG] [mount] - mount successfully completed
          [DEBUG] [mount] - done
          [DEBUG] [iobroker] - host.ioBroker 28978 states saved
          [DEBUG] [iobroker] - host.ioBroker 33970 objects saved
          [DEBUG] [iobroker] - done
          [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
          [DEBUG] [javascripts] - found Script: Anwesenheit
          [DEBUG] [javascripts] - found Script: Anwesenheit_Kinder
          [DEBUG] [javascripts] - found Script: Blink-Kamera
          [DEBUG] [javascripts] - found Script: Blink_Kamera
          [DEBUG] [javascripts] - found Script: Garagenlicht
          [DEBUG] [javascripts] - found Script: Licht_Esszimmer_normal
          [DEBUG] [javascripts] - found Script: Weihnachten
          [DEBUG] [javascripts] - found Script: Regenradar
          [DEBUG] [javascripts] - found Script: Rollo_Fenster_Warnung
          [DEBUG] [javascripts] - found Script: Rollo_Schlafzimmer
          [DEBUG] [javascripts] - found Script: Rollo_Wochenende
          [DEBUG] [javascripts] - found Script: Rollo_Wohnzimmer
          [DEBUG] [javascripts] - found Script: Batterieüberwachung
          [DEBUG] [javascripts] - found Script: Fenster_Bad
          [DEBUG] [javascripts] - found Script: Fenster_Status
          [DEBUG] [javascripts] - found Script: Stimmungslicht
          [DEBUG] [javascripts] - found Script: Subwoofer_aus
          [DEBUG] [javascripts] - found Script: Wecker
          [DEBUG] [javascripts] - found Script: Fußball
          [DEBUG] [javascripts] - found Script: Multiroom_starten
          [DEBUG] [javascripts] - found Script: Telegrammbaustein
          [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
          [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
          [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2023_11_24-15_57_59_backupiobroker.tar.gz
          [DEBUG] [javascripts] - done
          [DEBUG] [cifs] - used copy path: /IceDBox/IOBROKER/ioBroker
          [DEBUG] [cifs] - done
          [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
          [DEBUG] [clean] - done
          [DEBUG] [historyHTML] - new history html values created
          [DEBUG] [historyHTML] - done
          [DEBUG] [historyJSON] - new history json values created
          [DEBUG] [historyJSON] - done
          [DEBUG] [umount] - mount activ, umount is started ...
          [DEBUG] [umount] - umount successfully completed
          [DEBUG] [umount] - done
          [EXIT] 0
          I Offline
          I Offline
          IceD112
          @Marc-Berg said in Backup Größe ioBroker:
          1. Ist es plausibel, dass die Sicherung, bei 42 Installierten Adaptern nur 35,38 kb hat?
          Da liegen die Backups
          Die allermeisten sind 0 kb, also leer
          weis aber nicht warum
            @iced112
            I Offline
            I Offline
            IceD112
            Wo Finde ich die Einstellung?
            Meinst du den Verbindungstyp
            • I IceD112
              @iced112
              Nein, die Mountoption für ein CIFS/SMB Mount.
                @iced112
                I Offline
                I Offline
                IceD112
                Ah, wurde mir gerade erst angezeigt, komisch...
                Den anderen Haken bei "noserverino" dafür entfernen?
                • I IceD112
                  @iced112
                  Nein, bei FritzNAS beides aktiv setzen.
                    @iced112
                    I Offline
                    I Offline
                    IceD112
                    schrieb am zuletzt editiert von IceD112
                    ok, dann sicher ich grade nochmal ein Backup
                    EDIT: Also an der Datei Größe hat sich nicht geändert
                    [DEBUG] [mount] - mount activ... umount is started before mount!!
                    [DEBUG] [mount] - umount successfully completed
                    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=ioB_Backup,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.1/IceDBox/IOBROKER/ioBroker /opt/iobroker/backups"
                    [DEBUG] [iobroker] - host.ioBroker 28368 states saved
                    [DEBUG] [iobroker] - host.ioBroker 33321 objects saved
                    [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2023_11_25-15_25_43_backupiobroker.tar.gz
                    [EXIT] 0
                    • I Offline
                      I Offline
                      IceD112
                      Kann mir niemand beantworten, warum das Backup vom ioBroker nicht funktioniert?
                      • I IceD112
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        @iced112 sagte in Backup Größe ioBroker:
                        wie ich ganz oben schon erwähnt habe bist Du "sportlich" unterwegs:
                        2GB Ram und 42 Adapter installiert. Da geht bei Dir nichts mehr wenn das Backup startet, denn dieser Start vom Backup braucht auch Speicher.
                        Lehrling seit 1975 !!!
                        • DJMarc75D DJMarc75
                          I Offline
                          I Offline
                          IceD112
                          @djmarc75
                          Hab den neuen PI mit 8gb schon hier vor mir. Ist fertig konfiguriert und ein neuer iob installiert.
                          Irgendwie muss das alte system doch zu sichern sein?
                          • I IceD112
                            @djmarc75
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            Vom "neuen" iob bitte auch mal
                            iob diag
                            zeigen.
                            Jo, dazu gibt es den Adapter "BackitUp".
                              iob diag
                              zeigen.
                              I Offline
                              I Offline
                              IceD112
                              Damit arbeite ich ja.
                              Die Sicherungen gehen auf die Fritzbox. Aber jedes Backup hat 0 MB. Weis aber nicht warum
                              • I IceD112
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                Wir drehen uns im Kreis:
                                https://forum.iobroker.net/topic/70494/backup-größe-iobroker/28?_=1700978716741
                                @djmarc75 sagte in Backup Größe ioBroker:
                                  I Offline
                                  I Offline
                                  IceD112
                                  @djmarc75
                                  Ja, schon verstanden, aber das soll ja nicht bedeuten, dass ich ganz von vorne anfangen muss
                                  • I Offline
                                    I Offline
                                    IceD112
                                    Wenn der Backitup Adapter ja so viel Leistung bindet, dass er kein Backup durchführen kann, muss es doch auch ne andere Lösung geben, ein Backup zu erstellen
                                    Marc BergM HomoranH 2 Antworten Letzte Antwort
                                    • I IceD112
                                      Marc BergM Offline
                                      Marc BergM Offline
                                      Marc Berg
                                      Auch wenn es ziemlich wahrscheinlich ist, dass der RAM knapp wird, würde ich trotzdem mal versuchen, das Backup lokal zu speichern, um auszuschließen, dass es am Mount/an der Fritzbox liegt.
                                      • Marc BergM Marc Berg
                                        I Offline
                                        I Offline
                                        IceD112
                                        @marc-berg Dazu mach ich den Haken bei NAS weg und starte eine neue Sicherung?
                                        Wo genau finde ich sie dann?
                                        • I IceD112
                                          Marc BergM Offline
                                          Marc BergM Offline
                                          Marc Berg
                                          unter /opt/iobroker/backups
