  3. Off Topic
  4. InfluxDB
  5. mit backitup kein Influxdb und Grafana backup möglich
    6.7k
Geplant Angeheftet Gesperrt Verschoben InfluxDB
119 Beiträge 10 Kommentatoren 19.8k Aufrufe 8 Beobachtet
  • C Christian 5
    @homoran sagte in Influx/Grafana Probleme:
    @marc-berg sagte in Vis über npm gibt EHOSTUNREACH:
    Für Garfana musst du
    @Christian-5
    ...einen neuen Thread in offTopic aufmachen.
    Hat mit diesem Thema nichts mehr zu tun.
    @Christian-0 Nachdem du das nicht gemacht hast, habe ich diesen Part jetzt abgespalten und verschoben!
    Danke!
    Christian 5
    @christian-5 nach dem grafana backup diese Meldung:
    code_text
    ```Started restore ...
    [DEBUG] [grafana] - Start Grafana Restore ...
    [DEBUG] [grafana] - filename for restore: /opt/iobroker/backups/grafana_2023_11_23-04_46_57_Meine001Sicherung_backupiobroker.tar.gz
    [DEBUG] [grafana] - Grafana tmp directory created: /opt/iobroker/backups/grafana_tmp
    [DEBUG] [grafana] - start decompress
    [DEBUG] [grafana] - Grafana request started
    [DEBUG] [grafana] - Grafana is available ... Status: 200
    [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB-1.json
    [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB.json
    [DEBUG] [grafana] - cannot restore datasource "InfluxDB": "data source with the same name already exists"
    [DEBUG] [grafana] - cannot restore datasource "InfluxDB-1": "data source with the same name already exists"
    [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/dashboard-alles-mogliche-1woche.json
    [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/kurven-1jahr.json
    [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/pv1-pv2-leistung-1tag.json
    [DEBUG] [grafana] - cannot restore dashboard "dashboard-alles-mogliche-1woche": {"extra":null,"message":"organization not found","messageId":"org.notFound","statusCode":404,"traceID":""}
    [DEBUG] [grafana] - cannot restore dashboard "kurven-1jahr": {"extra":null,"message":"organization not found","messageId":"org.notFound","statusCode":404,"traceID":""}
    [DEBUG] [grafana] - cannot restore dashboard "pv1-pv2-leistung-1tag": {"extra":null,"message":"organization not found","messageId":"org.notFound","statusCode":404,"traceID":""}
    [DEBUG] [grafana] - Grafana request ended
    [DEBUG] [grafana] - Try deleting the Grafana tmp directory
    [DEBUG] [grafana] - Grafana tmp directory was successfully deleted
    [DEBUG] [grafana] - Grafana Restore completed successfully
    [EXIT] Grafana restore done
      @Christian-5
      Bitte noch den provisorischen Threadtitel sinnvoll anpassen.
      Christian 5
      aber wie?
      • C Christian 5
        code_text
        Marc BergM Offline
        Marc BergM Offline
        Marc Berg
        @christian-5 sagte in Influx/Grafana Probleme:
        Du musst die Buckets manuell vor dem Restore löschen und am besten die Adapter stoppen, damit nicht gleich wieder Daten reinfliegen. Die entsprechende Funktion in den Backitup Einstellungen funktioniert nicht (immer?).
        • C Christian 5
          aber wie?
          Marc BergM Offline
          Marc BergM Offline
          Marc Berg
          aber wie?
          den ersten Post hier im Thread editieren.
          C 1 Antwort Letzte Antwort
          • Marc BergM Marc Berg
            aber wie?
            Christian 5
            @marc-berg danke, bucket in influx gelöscht, influx neu gestartet Adapter deaktiviert:
            code_text
            [DEBUG] [influxDB] - Created tmp directory
            [DEBUG] [influxDB] - Start infuxDB Restore ...
            [ERROR] [influxDB] - 2023/11/25 21:07:12 INFO: Restoring bucket "9d69ae680368264c" as "iobroker"
            Error: failed to restore bucket "iobroker": 401 Unauthorized: read:authorizations is unauthorized
            [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
            [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
            [DEBUG] [influxDB] - infuxDB Restore completed successfully
            [EXIT] influxDB restore done
            • C Christian 5
              code_text
              Marc BergM Offline
              Marc BergM Offline
              Marc Berg
              @christian-5 sagte in mit backitup kein Influxdb und Grafana backup möglich:
              Du benutzt einen falschen Token.
              https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup#influxdb2-restore
                Christian 5
                schrieb am zuletzt editiert von Christian 5
                @marc-berg neuen Token eingetragen und wieder das gleiche Ergebnis... ich bin zu blöd
                C Marc BergM 2 Antworten Letzte Antwort
                • C Christian 5
                  Christian 5
                  @christian-5 und in grafana das selbe jetzt hab ich den inhalt im Ordner /opt/iobroker/iobroker-data/backup-objects gelöscht, schau ma amoal
                  code_text
                  code_text
                    ich hab die beiden daten Quellen in Grafana aber gelöscht.
                  • C Christian 5
                    Marc BergM Offline
                    Marc BergM Offline
                    Marc Berg
                    wo hast du den neuen Token her?
                      Christian 5
                      @marc-berg aus influxdb unter API Tokens influx token.png erzeugt
                      ich hab in eurer Anleitung zum backitup adapter gelesen das die influxdb cli installiert gehört, dachte die influxdb cli wird jetzt automatisch mit installiert.
                      • C Christian 5
                        Marc BergM Offline
                        Marc BergM Offline
                        Marc Berg
                        aus influxdb unter API Tokens erzeugt
                        Und das ist falsch, darum hatte ich die Dokumentation dazu verlinkt, in der es erklärt ist.
                        Nein. Wer hat das je behauptet?
                          Christian 5
                          @marc-berg ok danke, dann ein weiterer Versuch, wie installier ich die cli auf dem raspi am einfachsten?
                          aber ein fehler das CLI nicht installiert ist hab ich auch keinen bekommen.
                          das heißt jetzt : Operator-Token für InfluxDB 2.x wiederherstellen
                          • Marc BergM Offline
                            Marc BergM Offline
                            Marc Berg
                            Ich sehe jetzt gerade nicht mehr durch, was jetzt gerade das Problem ist. Die influxdb2-cli scheint doch schon installiert zu sein, sonst bekämst du nicht diese Fehlermeldung:
                              Christian 5
                              @marc-berg ich habs nicht explizit installiert, darum die frage. ...aber jetzt Token erzeugen???
                              ist eure Anleitung aktuell?
                              • C Christian 5
                                Marc BergM Offline
                                Marc BergM Offline
                                Marc Berg
                                Ja, wenn du die influxdb2 installierst, dann ist die cli mit dabei. Da hatte ich das "automatisch" falsch verstanden.
                                In der Anleitung steht auch, wie der Operator Token AUSZULESEN ist. Wenn du den Token nicht gelöscht hast, würde das reichen.
                                  Christian 5
                                  @marc-berg in der Anleitung steht ja auch: Für die Verwendung des InfluxDB Backups muss influxd installiert sein
                                  Installationsanleitung InfluxDB 1.x
                                  Installationsanleitung InfluxDB 2.x
                                  Installationsanleitung Influx-CLI für 2.x ???
                                  Operator docken auslese Anleitung finde ich jetzt nicht wirklich, überlesen..blind
                                  lg
                                  crunchipC ? 2 Antworten Letzte Antwort
                                  • C Christian 5
                                    lg
                                    crunchipC Offline
                                    crunchipC Offline
                                    steht doch da
                                    Nun benötigen wir für den ioBroker.backitup Adapter den neuen Operator-Token, welcher z.B. über die Linux-Kommandozeile durch
                                    influx auth list -t <ein all access token>
                                    über den ersten Eintrag der Ausgabe eingesehen werden kann. (Hinweis: Beim Kopieren in die Instanz-Settings auf Zeilenumbrüche etc. achten!).
                                      steht doch da
                                      Christian 5
                                      @crunchip sagte in mit backitup kein Influxdb und Grafana backup möglich:
                                      steht doch da
                                      $ influx auth list -t <ein all access token>
                                      -bash: syntax error near unexpected token `newline'
                                      ich versteh den Befehl ja so das ich da einen Token eintragen muß
                                      • C Christian 5
                                        lg
                                        Moin,
                                        ich hatte zwar vor mich hier nicht mehr einzumischen und habe, zu meiner Schande, die Doku nicht gelesen, will nur mal wieder Korinthen kacken :)
                                        • ioBroker und influxDB2 auf demselben Rechner, muss nichts weiter installiert werden, alles ok.
                                        • ioBroker auf einem Rechner und influxDB2 auf einem anderen, dann muss auf ioBroker auch influxDB2-cli installiert werden, es braucht für das Backup den influxd
                                        • ioBroker und influxDB auf demselben Rechner, dann alles ok
                                        • ioBroker auf einem Rechner und influxDB auf einem anderen, dann muss influxDB auch auf dem ioBroker Rechner installiert werden, wird dort aber nicht gestartet, es wird nur influxd genutzt, um Backups zu machen.
                                        Bernd
                                          Moin,
                                          Bernd
                                          Christian 5
                                          @dp20eic Danke für die Info, bei mir läuft iobroker, influxdb und grafana auf einem Raspi mit bookworm.
                                          Vieleicht ist auch das Bookworm System zu neu für eurer Backitup?
                                          Jetzt hab ich versucht den Befehl [influx auth list -t] ( mit meinen admin token zu füttern danach kommt:
                                          ~ $ influx auth list -t <JFDFtCoikpXsamvQ1FoN6lJ2sHepumBw5N4VviHmnywuWZ4A2xKOQPb1WISCw9i3y_17x7cHHJ3_pLwH0NJvMQ==>
                                          ich depp hab ja <> stehen lassen
