  3. Off Topic
  4. InfluxDB
  5. mit backitup kein Influxdb und Grafana backup möglich
    6.7k
Geplant Angeheftet Gesperrt Verschoben InfluxDB
119 Beiträge 10 Kommentatoren 19.8k Aufrufe 8 Beobachtet
  • C Christian 5
    @marc-berg neuen Token eingetragen und wieder das gleiche Ergebnis... ich bin zu blöd
    Christian 5
    schrieb am zuletzt editiert von Christian 5
    @christian-5 und in grafana das selbe jetzt hab ich den inhalt im Ordner /opt/iobroker/iobroker-data/backup-objects gelöscht, schau ma amoal
    code_text
    ```Started restore ...
    [DEBUG] [grafana] - Start Grafana Restore ...
    [DEBUG] [grafana] - filename for restore: /opt/iobroker/backups/grafana_2023_11_23-04_46_57_Meine001Sicherung_backupiobroker.tar.gz
    [DEBUG] [grafana] - Grafana tmp directory created: /opt/iobroker/backups/grafana_tmp
    [DEBUG] [grafana] - start decompress
    [DEBUG] [grafana] - Grafana request started
    [DEBUG] [grafana] - Grafana is available ... Status: 200
    [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB-1.json
    [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB.json
    [DEBUG] [grafana] - cannot restore datasource "InfluxDB-1": "data source with the same name already exists"
    [DEBUG] [grafana] - cannot restore datasource "InfluxDB": "data source with the same name already exists"
    [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/dashboard-alles-mogliche-1woche.json
    [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/kurven-1jahr.json
    [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/pv1-pv2-leistung-1tag.json
    [DEBUG] [grafana] - cannot restore dashboard "pv1-pv2-leistung-1tag": {"extra":null,"message":"organization not found","messageId":"org.notFound","statusCode":404,"traceID":""}
    [DEBUG] [grafana] - cannot restore dashboard "kurven-1jahr": {"extra":null,"message":"organization not found","messageId":"org.notFound","statusCode":404,"traceID":""}
    [DEBUG] [grafana] - cannot restore dashboard "dashboard-alles-mogliche-1woche": {"extra":null,"message":"organization not found","messageId":"org.notFound","statusCode":404,"traceID":""}
    [DEBUG] [grafana] - Grafana request ended
    [DEBUG] [grafana] - Try deleting the Grafana tmp directory
    [DEBUG] [grafana] - Grafana tmp directory was successfully deleted
    [DEBUG] [grafana] - Grafana Restore completed successfully
    [EXIT] Grafana restore done
    code_text
      ich hab die beiden daten Quellen in Grafana aber gelöscht.
    • C Christian 5
      Marc BergM Offline
      Marc BergM Offline
      Marc Berg
      @christian-5 sagte in mit backitup kein Influxdb und Grafana backup möglich:
      wo hast du den neuen Token her?
      C 1 Antwort Letzte Antwort
      • Marc BergM Marc Berg
        Christian 5
        @marc-berg aus influxdb unter API Tokens influx token.png erzeugt
        ich hab in eurer Anleitung zum backitup adapter gelesen das die influxdb cli installiert gehört, dachte die influxdb cli wird jetzt automatisch mit installiert.
        • C Christian 5
          Marc BergM Offline
          Marc BergM Offline
          Marc Berg
          aus influxdb unter API Tokens erzeugt
          Und das ist falsch, darum hatte ich die Dokumentation dazu verlinkt, in der es erklärt ist.
          Nein. Wer hat das je behauptet?
            Christian 5
            @marc-berg ok danke, dann ein weiterer Versuch, wie installier ich die cli auf dem raspi am einfachsten?
            aber ein fehler das CLI nicht installiert ist hab ich auch keinen bekommen.
            das heißt jetzt : Operator-Token für InfluxDB 2.x wiederherstellen
            • Marc BergM Offline
              Marc BergM Offline
              Marc Berg
              Ich sehe jetzt gerade nicht mehr durch, was jetzt gerade das Problem ist. Die influxdb2-cli scheint doch schon installiert zu sein, sonst bekämst du nicht diese Fehlermeldung:
              Error: failed to restore bucket "iobroker": 401 Unauthorized: read:authorizations is unauthorized
                Christian 5
                @marc-berg ich habs nicht explizit installiert, darum die frage. ...aber jetzt Token erzeugen???
                ist eure Anleitung aktuell?
                • C Christian 5
                  Marc BergM Offline
                  Marc BergM Offline
                  Marc Berg
                  Ja, wenn du die influxdb2 installierst, dann ist die cli mit dabei. Da hatte ich das "automatisch" falsch verstanden.
                  In der Anleitung steht auch, wie der Operator Token AUSZULESEN ist. Wenn du den Token nicht gelöscht hast, würde das reichen.
                    Christian 5
                    @marc-berg in der Anleitung steht ja auch: Für die Verwendung des InfluxDB Backups muss influxd installiert sein
                    Installationsanleitung InfluxDB 1.x
                    Installationsanleitung InfluxDB 2.x
                    Installationsanleitung Influx-CLI für 2.x ???
                    Operator docken auslese Anleitung finde ich jetzt nicht wirklich, überlesen..blind
                    lg
                    crunchipC ? 2 Antworten Letzte Antwort
                    • C Christian 5
                      lg
                      crunchipC Offline
                      crunchipC Offline
                      steht doch da
                      Nun benötigen wir für den ioBroker.backitup Adapter den neuen Operator-Token, welcher z.B. über die Linux-Kommandozeile durch
                      influx auth list -t <ein all access token>
                      über den ersten Eintrag der Ausgabe eingesehen werden kann. (Hinweis: Beim Kopieren in die Instanz-Settings auf Zeilenumbrüche etc. achten!).
                        steht doch da
                        Christian 5
                        @crunchip sagte in mit backitup kein Influxdb und Grafana backup möglich:
                        steht doch da
                        $ influx auth list -t <ein all access token>
                        -bash: syntax error near unexpected token `newline'
                        ich versteh den Befehl ja so das ich da einen Token eintragen muß
                        • C Christian 5
                          lg
                          Moin,
                          ich hatte zwar vor mich hier nicht mehr einzumischen und habe, zu meiner Schande, die Doku nicht gelesen, will nur mal wieder Korinthen kacken :)
                          • ioBroker und influxDB2 auf demselben Rechner, muss nichts weiter installiert werden, alles ok.
                          • ioBroker auf einem Rechner und influxDB2 auf einem anderen, dann muss auf ioBroker auch influxDB2-cli installiert werden, es braucht für das Backup den influxd
                          • ioBroker und influxDB auf demselben Rechner, dann alles ok
                          • ioBroker auf einem Rechner und influxDB auf einem anderen, dann muss influxDB auch auf dem ioBroker Rechner installiert werden, wird dort aber nicht gestartet, es wird nur influxd genutzt, um Backups zu machen.
                          Bernd
                            Moin,
                            Bernd
                            Christian 5
                            @dp20eic Danke für die Info, bei mir läuft iobroker, influxdb und grafana auf einem Raspi mit bookworm.
                            Vieleicht ist auch das Bookworm System zu neu für eurer Backitup?
                            Jetzt hab ich versucht den Befehl [influx auth list -t] ( mit meinen admin token zu füttern danach kommt:
                            ~ $ influx auth list -t <JFDFtCoikpXsamvQ1FoN6lJ2sHepumBw5N4VviHmnywuWZ4A2xKOQPb1WISCw9i3y_17x7cHHJ3_pLwH0NJvMQ==>
                            ich depp hab ja <> stehen lassen
                            • C Christian 5
                              steht doch da
                              crunchipC Offline
                              crunchipC Offline
                              @christian-5 ich hab zwar selbst keine influxdb2 aber so wie ich es verstehe,
                              du benötigst den Operator Token(dieser wird einmalig beim einrichten angezeigt)
                              wenn du ihn gelöscht hast, musst du einen neuen anlegen, sollte er noch vorhanden sein, dann
                              einen Token erstellen (all access token)...hast du ja bereits, soweit ich das sehen
                              und dann mit diesem Token den Befehl absetzen zum auslesen
                              • C Christian 5
                                Nein.
                                • C Christian 5
                                  crunchipC Offline
                                  crunchipC Offline
                                  @christian-5 die <> müssen weg
                                    Christian 5
                                    influx auth list -t JFDFtCoikpXsamvQ1FoN6lJ2sHepumBw5N4VviHmnywuWZ4A2xKOQPb1WISCw9i3y_17x7cHHJ3_pLwH0NJvMQ==
                                    ID                      Description                                     Token        Us                               er Name User ID                 Permissions
                                    0c2d801b8c011000        admin's Token                                   cQHuJNykWV5aRtKXVJZi5UgTOj2WwpslbSmwTDk9TyteHkQjTnicoSxf5oqWrZYLvfuLsHgRLJM9Up9zzgmzCA==        ad                               min             0c2d801b56411000        [read:/authorizations write:/authorizations read:/buckets write:/buckets read:/dashboards write:/dashboards read:/orgs write:/orgs                                read:/sources write:/sources read:/tasks write:/tasks read:/telegrafs write:/telegrafs read:/users write:/users read:/variables write:/variables read:/scrapers write:/sc                               rapers read:/secrets write:/secrets read:/labels write:/labels read:/views write:/views read:/documents write:/documents read:/notificationRules write:/notificationRules                                read:/notificationEndpoints write:/notificationEndpoints read:/checks write:/checks read:/dbrp write:/dbrp read:/notebooks write:/notebooks read:/annotations write:/annot                               ations read:/remotes write:/remotes read:/replications write:/replications]
                                    0c2d80d103411000        onboarding-cliWizard-token-1700908099560        Kyk2IZoDXhQZuaStF0QDjPqh6NFYFlCQog7EbIaFhwLZG5YGoj5RMJQOgahOG00uWCNjX6j55gC2VJnTrlUVzA==        ad                               min             0c2d801b56411000        [read:orgs/aaf9f9785dadebad/annotations write:orgs/aaf9f9785dadebad/annotations read:orgs/aaf9f9785dadebad/authorizations write:or                               gs/aaf9f9785dadebad/authorizations read:orgs/aaf9f9785dadebad/buckets write:orgs/aaf9f9785dadebad/buckets read:orgs/aaf9f9785dadebad/checks write:orgs/aaf9f9785dadebad/ch                               ecks read:orgs/aaf9f9785dadebad/dashboards write:orgs/aaf9f9785dadebad/dashboards read:orgs/aaf9f9785dadebad/dbrp write:orgs/aaf9f9785dadebad/dbrp read:orgs/aaf9f9785dade                               bad/documents write:orgs/aaf9f9785dadebad/documents read:orgs/aaf9f9785dadebad/labels write:orgs/aaf9f9785dadebad/labels read:orgs/aaf9f9785dadebad/notebooks write:orgs/a                               af9f9785dadebad/notebooks read:orgs/aaf9f9785dadebad/notificationEndpoints write:orgs/aaf9f9785dadebad/notificationEndpoints read:orgs/aaf9f9785dadebad/notificationRules                                write:orgs/aaf9f9785dadebad/notificationRules read:/orgs/aaf9f9785dadebad read:orgs/aaf9f9785dadebad/remotes write:orgs/aaf9f9785dadebad/remotes read:orgs/aaf9f9785dadeba                               d/replications write:orgs/aaf9f9785dadebad/replications read:orgs/aaf9f9785dadebad/scrapers write:orgs/aaf9f9785dadebad/scrapers read:orgs/aaf9f9785dadebad/secrets write:                               orgs/aaf9f9785dadebad/secrets read:orgs/aaf9f9785dadebad/sources write:orgs/aaf9f9785dadebad/sources read:orgs/aaf9f9785dadebad/tasks write:orgs/aaf9f9785dadebad/tasks re                               ad:orgs/aaf9f9785dadebad/telegrafs write:orgs/aaf9f9785dadebad/telegrafs read:/users/0c2d801b56411000 write:/users/0c2d801b56411000 read:orgs/aaf9f9785dadebad/variables w                               rite:orgs/aaf9f9785dadebad/variables read:orgs/aaf9f9785dadebad/views write:orgs/aaf9f9785dadebad/views]
                                    0c2d8d76d297d000        grafana                                         msIXJhJxmmX1Mb_CIRU4_wuauwBcxf4ePOAEdtiOu1Sb8oAy7rltutBdGTbwf3CNMh3aIleX3ExJR4ywvJPmmg==        ad                               min             0c2d801b56411000        [read:orgs/aaf9f9785dadebad/annotations write:orgs/aaf9f9785dadebad/annotations read:orgs/aaf9f9785dadebad/authorizations write:or                               gs/aaf9f9785dadebad/authorizations read:orgs/aaf9f9785dadebad/buckets write:orgs/aaf9f9785dadebad/buckets read:orgs/aaf9f9785dadebad/checks write:orgs/aaf9f9785dadebad/ch                               ecks read:orgs/aaf9f9785dadebad/dashboards write:orgs/aaf9f9785dadebad/dashboards read:orgs/aaf9f9785dadebad/dbrp write:orgs/aaf9f9785dadebad/dbrp read:orgs/aaf9f9785dade                               bad/documents write:orgs/aaf9f9785dadebad/documents read:orgs/aaf9f9785dadebad/labels write:orgs/aaf9f9785dadebad/labels read:orgs/aaf9f9785dadebad/notebooks write:orgs/a                               af9f9785dadebad/notebooks read:orgs/aaf9f9785dadebad/notificationEndpoints write:orgs/aaf9f9785dadebad/notificationEndpoints read:orgs/aaf9f9785dadebad/notificationRules                                write:orgs/aaf9f9785dadebad/notificationRules read:/orgs/aaf9f9785dadebad read:orgs/aaf9f9785dadebad/remotes write:orgs/aaf9f9785dadebad/remotes read:orgs/aaf9f9785dadeba                               d/replications write:orgs/aaf9f9785dadebad/replications read:orgs/aaf9f9785dadebad/scrapers write:orgs/aaf9f9785dadebad/scrapers read:orgs/aaf9f9785dadebad/secrets write:                               orgs/aaf9f9785dadebad/secrets read:orgs/aaf9f9785dadebad/sources write:orgs/aaf9f9785dadebad/sources read:orgs/aaf9f9785dadebad/tasks write:orgs/aaf9f9785dadebad/tasks re                               ad:orgs/aaf9f9785dadebad/telegrafs write:orgs/aaf9f9785dadebad/telegrafs read:/users/0c2d801b56411000 write:/users/0c2d801b56411000 read:orgs/aaf9f9785dadebad/variables w                               rite:orgs/aaf9f9785dadebad/variables read:orgs/aaf9f9785dadebad/views write:orgs/aaf9f9785dadebad/views]
                                    0c2e085522948000        backitup                                        lr7G2Rh7GgWvg-2EfUPV4ZRan69zLW2vTSTb5a4ytdd5XxbU8-gPIrB27oOICkXpQUDuSBfNGhOX6lbhS9n5GA==        ad                               min             0c2d801b56411000        [read:orgs/aaf9f9785dadebad/annotations write:orgs/aaf9f9785dadebad/annotations read:orgs/aaf9f9785dadebad/authorizations write:or                               gs/aaf9f9785dadebad/authorizations read:orgs/aaf9f9785dadebad/buckets write:orgs/aaf9f9785dadebad/buckets read:orgs/aaf9f9785dadebad/checks write:orgs/aaf9f9785dadebad/ch                               ecks read:orgs/aaf9f9785dadebad/dashboards write:orgs/aaf9f9785dadebad/dashboards read:orgs/aaf9f9785dadebad/dbrp write:orgs/aaf9f9785dadebad/dbrp read:orgs/aaf9f9785dade                               bad/documents write:orgs/aaf9f9785dadebad/documents read:orgs/aaf9f9785dadebad/labels write:orgs/aaf9f9785dadebad/labels read:orgs/aaf9f9785dadebad/notebooks write:orgs/a                               af9f9785dadebad/notebooks read:orgs/aaf9f9785dadebad/notificationEndpoints write:orgs/aaf9f9785dadebad/notificationEndpoints read:orgs/aaf9f9785dadebad/notificationRules                                write:orgs/aaf9f9785dadebad/notificationRules read:/orgs/aaf9f9785dadebad read:orgs/aaf9f9785dadebad/remotes write:orgs/aaf9f9785dadebad/remotes read:orgs/aaf9f9785dadeba                               d/replications write:orgs/aaf9f9785dadebad/replications read:orgs/aaf9f9785dadebad/scrapers write:orgs/aaf9f9785dadebad/scrapers read:orgs/aaf9f9785dadebad/secrets write:                               orgs/aaf9f9785dadebad/secrets read:orgs/aaf9f9785dadebad/sources write:orgs/aaf9f9785dadebad/sources read:orgs/aaf9f9785dadebad/tasks write:orgs/aaf9f9785dadebad/tasks re                               ad:orgs/aaf9f9785dadebad/telegrafs write:orgs/aaf9f9785dadebad/telegrafs read:/users/0c2d801b56411000 write:/users/0c2d801b56411000 read:orgs/aaf9f9785dadebad/variables w                               rite:orgs/aaf9f9785dadebad/variables read:orgs/aaf9f9785dadebad/views write:orgs/aaf9f9785dadebad/views]
                                    0c2ed4bfcb320000        admin's Token (cloned at 2023-11-26 11:13:29)   JFDFtCoikpXsamvQ1FoN6lJ2sHepumBw5N4VviHmnywuWZ4A2xKOQPb1WISCw9i3y_17x7cHHJ3_pLwH0NJvMQ==        ad                               min             0c2d801b56411000        [read:/authorizations write:/authorizations read:/buckets write:/buckets read:/dashboards write:/dashboards read:/orgs write:/orgs                                read:/sources write:/sources read:/tasks write:/tasks read:/telegrafs write:/telegrafs read:/users write:/users read:/variables write:/variables read:/scrapers write:/sc                               rapers read:/secrets write:/secrets read:/labels write:/labels read:/views write:/views read:/documents write:/documents read:/notificationRules write:/notificationRules                                read:/notificationEndpoints write:/notificationEndpoints read:/checks write:/checks read:/dbrp write:/dbrp read:/notebooks write:/notebooks read:/annotations write:/annot                               ations read:/remotes write:/remotes read:/replications write:/replications]
                                    und welchen soll ich jetzt nehmen?
                                    • C Christian 5
                                      crunchipC Offline
                                      crunchipC Offline
                                      @christian-5 laut Anleitung
                                      Das erste gelistete Token ist das Operator-Token
                                      C Marc BergM 2 Antworten Letzte Antwort
                                        Christian 5
                                        @crunchip nachdems mit dem ersten token wieder nicht funktioniert hat, hab ich jetzt mit
                                        <sudo influxd recovery auth create-operator --org my-org --username admin --bolt-path /var/lib/influxdb/influxd.bolt> einen neuen token erzeugt
                                         sudo influxd recovery auth create-operator --org my-org -                              -username admin --bolt-path /var/lib/influxdb/influxd.bolt
                                        2023-11-26T12:17:28.871113Z     info    Resources opened        {"log_id": "0ljt                              rN9W000", "system": "bolt-kvstore", "path": "/var/lib/influxdb/influxd.bolt"}
                                        ID                      User Name       User ID                 Description    T                              oken        P                              ermissions
                                        0c2d801b8c011000        admin           0c2d801b56411000        admin's Token  c                              QHuJNykWV5aRtKXVJZi5UgTOj2WwpslbSmwTDk9TyteHkQjTnicoSxf5oqWrZYLvfuLsHgRLJM9Up9zz                              gmzCA== [read:authorizations write:authorizations read:buckets write:buckets rea                              d:dashboards write:dashboards read:orgs write:orgs read:sources write:sources re                              ad:tasks write:tasks read:telegrafs write:telegrafs read:users write:users read:                              variables write:variables read:scrapers write:scrapers read:secrets write:secret                              s read:labels write:labels read:views write:views read:documents write:documents                               read:notificationRules write:notificationRules read:notificationEndpoints write                              :notificationEndpoints read:checks write:checks read:dbrp write:dbrp read:notebo                              oks write:notebooks read:annotations write:annotations read:remotes write:remote                              s read:replications write:replications]
                                        0c2d80d103411000        admin           0c2d801b56411000        onboarding-cliWi                              zard-token-1700908099560        Kyk2IZoDXhQZuaStF0QDjPqh6NFYFlCQog7EbIaFhwLZG5YG                              oj5RMJQOgahOG00uWCNjX6j55gC2VJnTrlUVzA==        [read:orgs/aaf9f9785dadebad/anno                              tations write:orgs/aaf9f9785dadebad/annotations read:orgs/aaf9f9785dadebad/autho                              rizations write:orgs/aaf9f9785dadebad/authorizations read:orgs/aaf9f9785dadebad/                              buckets write:orgs/aaf9f9785dadebad/buckets read:orgs/aaf9f9785dadebad/checks wr                              ite:orgs/aaf9f9785dadebad/checks read:orgs/aaf9f9785dadebad/dashboards write:org                              s/aaf9f9785dadebad/dashboards read:orgs/aaf9f9785dadebad/dbrp write:orgs/aaf9f97                              85dadebad/dbrp read:orgs/aaf9f9785dadebad/documents write:orgs/aaf9f9785dadebad/                              documents read:orgs/aaf9f9785dadebad/labels write:orgs/aaf9f9785dadebad/labels r                              ead:orgs/aaf9f9785dadebad/notebooks write:orgs/aaf9f9785dadebad/notebooks read:o                              rgs/aaf9f9785dadebad/notificationEndpoints write:orgs/aaf9f9785dadebad/notificat                              ionEndpoints read:orgs/aaf9f9785dadebad/notificationRules write:orgs/aaf9f9785da                              debad/notificationRules read:orgs/aaf9f9785dadebad read:orgs/aaf9f9785dadebad/re                              motes write:orgs/aaf9f9785dadebad/remotes read:orgs/aaf9f9785dadebad/replication                              s write:orgs/aaf9f9785dadebad/replications read:orgs/aaf9f9785dadebad/scrapers w                              rite:orgs/aaf9f9785dadebad/scrapers read:orgs/aaf9f9785dadebad/secrets write:org                              s/aaf9f9785dadebad/secrets read:orgs/aaf9f9785dadebad/sources write:orgs/aaf9f97                              85dadebad/sources read:orgs/aaf9f9785dadebad/tasks write:orgs/aaf9f9785dadebad/t                              asks read:orgs/aaf9f9785dadebad/telegrafs write:orgs/aaf9f9785dadebad/telegrafs                               read:users/0c2d801b56411000 write:users/0c2d801b56411000 read:orgs/aaf9f9785dade                              bad/variables write:orgs/aaf9f9785dadebad/variables read:orgs/aaf9f9785dadebad/v                              iews write:orgs/aaf9f9785dadebad/views]
                                        0c2d8d76d297d000        admin           0c2d801b56411000        grafana        m                              sIXJhJxmmX1Mb_CIRU4_wuauwBcxf4ePOAEdtiOu1Sb8oAy7rltutBdGTbwf3CNMh3aIleX3ExJR4ywv                              JPmmg== [read:orgs/aaf9f9785dadebad/annotations write:orgs/aaf9f9785dadebad/anno                              tations read:orgs/aaf9f9785dadebad/authorizations write:orgs/aaf9f9785dadebad/au                              thorizations read:orgs/aaf9f9785dadebad/buckets write:orgs/aaf9f9785dadebad/buck                              ets read:orgs/aaf9f9785dadebad/checks write:orgs/aaf9f9785dadebad/checks read:or                              gs/aaf9f9785dadebad/dashboards write:orgs/aaf9f9785dadebad/dashboards read:orgs/                              aaf9f9785dadebad/dbrp write:orgs/aaf9f9785dadebad/dbrp read:orgs/aaf9f9785dadeba                              d/documents write:orgs/aaf9f9785dadebad/documents read:orgs/aaf9f9785dadebad/lab                              els write:orgs/aaf9f9785dadebad/labels read:orgs/aaf9f9785dadebad/notebooks writ                              e:orgs/aaf9f9785dadebad/notebooks read:orgs/aaf9f9785dadebad/notificationEndpoin                              ts write:orgs/aaf9f9785dadebad/notificationEndpoints read:orgs/aaf9f9785dadebad/                              notificationRules write:orgs/aaf9f9785dadebad/notificationRules read:orgs/aaf9f9                              785dadebad read:orgs/aaf9f9785dadebad/remotes write:orgs/aaf9f9785dadebad/remote                              s read:orgs/aaf9f9785dadebad/replications write:orgs/aaf9f9785dadebad/replicatio                              ns read:orgs/aaf9f9785dadebad/scrapers write:orgs/aaf9f9785dadebad/scrapers read                              :orgs/aaf9f9785dadebad/secrets write:orgs/aaf9f9785dadebad/secrets read:orgs/aaf                              9f9785dadebad/sources write:orgs/aaf9f9785dadebad/sources read:orgs/aaf9f9785dad                              ebad/tasks write:orgs/aaf9f9785dadebad/tasks read:orgs/aaf9f9785dadebad/telegraf                              s write:orgs/aaf9f9785dadebad/telegrafs read:users/0c2d801b56411000 write:users/                              0c2d801b56411000 read:orgs/aaf9f9785dadebad/variables write:orgs/aaf9f9785dadeba                              d/variables read:orgs/aaf9f9785dadebad/views write:orgs/aaf9f9785dadebad/views]
                                        0c2e085522948000        admin           0c2d801b56411000        backitup       l                              r7G2Rh7GgWvg-2EfUPV4ZRan69zLW2vTSTb5a4ytdd5XxbU8-gPIrB27oOICkXpQUDuSBfNGhOX6lbhS                              9n5GA== [read:orgs/aaf9f9785dadebad/annotations write:orgs/aaf9f9785dadebad/anno                              tations read:orgs/aaf9f9785dadebad/authorizations write:orgs/aaf9f9785dadebad/au                              thorizations read:orgs/aaf9f9785dadebad/buckets write:orgs/aaf9f9785dadebad/buck                              ets read:orgs/aaf9f9785dadebad/checks write:orgs/aaf9f9785dadebad/checks read:or                              gs/aaf9f9785dadebad/dashboards write:orgs/aaf9f9785dadebad/dashboards read:orgs/                              aaf9f9785dadebad/dbrp write:orgs/aaf9f9785dadebad/dbrp read:orgs/aaf9f9785dadeba                              d/documents write:orgs/aaf9f9785dadebad/documents read:orgs/aaf9f9785dadebad/lab                              els write:orgs/aaf9f9785dadebad/labels read:orgs/aaf9f9785dadebad/notebooks writ                              e:orgs/aaf9f9785dadebad/notebooks read:orgs/aaf9f9785dadebad/notificationEndpoin                              ts write:orgs/aaf9f9785dadebad/notificationEndpoints read:orgs/aaf9f9785dadebad/                              notificationRules write:orgs/aaf9f9785dadebad/notificationRules read:orgs/aaf9f9                              785dadebad read:orgs/aaf9f9785dadebad/remotes write:orgs/aaf9f9785dadebad/remote                              s read:orgs/aaf9f9785dadebad/replications write:orgs/aaf9f9785dadebad/replicatio                              ns read:orgs/aaf9f9785dadebad/scrapers write:orgs/aaf9f9785dadebad/scrapers read                              :orgs/aaf9f9785dadebad/secrets write:orgs/aaf9f9785dadebad/secrets read:orgs/aaf                              9f9785dadebad/sources write:orgs/aaf9f9785dadebad/sources read:orgs/aaf9f9785dad                              ebad/tasks write:orgs/aaf9f9785dadebad/tasks read:orgs/aaf9f9785dadebad/telegraf                              s write:orgs/aaf9f9785dadebad/telegrafs read:users/0c2d801b56411000 write:users/                              0c2d801b56411000 read:orgs/aaf9f9785dadebad/variables write:orgs/aaf9f9785dadeba                              d/variables read:orgs/aaf9f9785dadebad/views write:orgs/aaf9f9785dadebad/views]
                                        0c2ed4bfcb320000        admin           0c2d801b56411000        admin's Token (c                              loned at 2023-11-26 11:13:29)   JFDFtCoikpXsamvQ1FoN6lJ2sHepumBw5N4VviHmnywuWZ4A                              2xKOQPb1WISCw9i3y_17x7cHHJ3_pLwH0NJvMQ==        [read:authorizations write:autho                              rizations read:buckets write:buckets read:dashboards write:dashboards read:orgs                               write:orgs read:sources write:sources read:tasks write:tasks read:telegrafs writ                              e:telegrafs read:users write:users read:variables write:variables read:scrapers                               write:scrapers read:secrets write:secrets read:labels write:labels read:views wr                              ite:views read:documents write:documents read:notificationRules write:notificati                              onRules read:notificationEndpoints write:notificationEndpoints read:checks write                              :checks read:dbrp write:dbrp read:notebooks write:notebooks read:annotations wri                              te:annotations read:remotes write:remotes read:replications write:replications]
                                        0c2ee365caef5000        admin           0c2d801b56411000        admin's Recovery                               Token                          30hFbjYYtxHC0neJrJfkZW0fIm2sndXuuszLv3FNohj9ycnB                              mrxgU-jVDTyjo96wPApcFWs_9xbjf4LNE7xgnA==        [read:authorizations write:autho                              rizations read:buckets write:buckets read:dashboards write:dashboards read:orgs                               write:orgs read:sources write:sources read:tasks write:tasks read:telegrafs writ                              e:telegrafs read:users write:users read:variables write:variables read:scrapers                               write:scrapers read:secrets write:secrets read:labels write:labels read:views wr                              ite:views read:documents write:documents read:notificationRules write:notificati                              onRules read:notificationEndpoints write:notificationEndpoints read:checks write                              :checks read:dbrp write:dbrp read:notebooks write:notebooks read:annotations wri                              te:annotations read:remotes write:remotes read:replications write:replications]
                                          Marc BergM Offline
                                          Marc BergM Offline
                                          Marc Berg
                                          Ja, da gibt es leider einen kleinen Haken. WENN der Operator Token noch nie neu erzeugt wurde, dann ist es der erste Eintrag. Sobald man den Token einmal gelöscht und neu erzeugt hat, ist es wahrscheinlich nicht mehr der erste.
                                          @Christian-5 Du kannst aber jetzt den "admin's Recovery Token" nehmen.
