  3. Off Topic
  4. Proxmox
  5. Proxmox: Fehlermeldung bei backup - vzdump ?
    1.0k
    3.2k
Geplant Angeheftet Gesperrt Verschoben Proxmox
228 Beiträge 8 Kommentatoren 48.3k Aufrufe 6 Beobachtet
  • G GOETSCHHOFER
    @dp20eic
    root@NUC:~# mount
    sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
    proc on /proc type proc (rw,relatime)
    udev on /dev type devtmpfs (rw,nosuid,relatime,size=8104840k,nr_inodes=2026210,mode=755)
    devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
    tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=1626552k,mode=755)
    /dev/mapper/pve-root on / type ext4 (rw,relatime,errors=remount-ro)
    securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
    tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
    tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
    tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
    cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime)
    cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
    pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
    efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
    none on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
    cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
    cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio        )
    cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
    cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
    cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
    cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
    cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
    cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
    cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb)
    cgroup on /sys/fs/cgroup/rdma type cgroup (rw,nosuid,nodev,noexec,relatime,rdma)
    cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
    systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=31,pgrp=1,timeout=0,minproto=5,maxpro        to=5,direct,pipe_ino=19609)
    hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
    debugfs on /sys/kernel/debug type debugfs (rw,relatime)
    mqueue on /dev/mqueue type mqueue (rw,relatime)
    sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
    fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
    configfs on /sys/kernel/config type configfs (rw,relatime)
    /dev/nvme0n1p2 on /boot/efi type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859        -1,shortname=mixed,errors=remount-ro)
    lxcfs on /var/lib/lxcfs type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
    /dev/sdb1 on /media/usb_backup type ext4 (rw,nosuid,nodev,noexec,relatime,sync)
    /dev/fuse on /etc/pve type fuse (rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allo        w_other)
    tracefs on /sys/kernel/debug/tracing type tracefs (rw,relatime)
    binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,relatime)
    tmpfs on /run/user/0 type tmpfs (rw,nosuid,nodev,relatime,size=1626548k,mode=700)
    root@NUC:~# cat /pve/storage.cfg
    cat: /pve/storage.cfg: No such file or directory
    root@NUC:~#
    @goetschhofer sagte in Proxmox: Fehlermeldung bei backup - vzdump ?:
    Moin,
    nicht
    sondern
    # cat /etc/pve/storage.cfg
    Dann es ist nur das gemountet
    Was ist denn Backup_USB-Stick auch ein USB oder eine Partition auf der Festplatte?
    Bernd
    G 1 Antwort Letzte Antwort
    • G GOETSCHHOFER
      @meister-mopper said in Proxmox: Fehlermeldung bei backup - vzdump ?:
      Das Ganze ist mir seitdem einfach davongelaufen.
      Ich habe mein System von 6 auf 7 auf 8 gehoben, und es funktioniert noch immer. Wenn nicht, hätte ich es immer 'from scratch' auf neu aufgesetzt, das ist ja immer eine Option.
      Das 2. Problem ist, dass bei meinem INTEL-NUC (1,5 J. alt) der Lüfter defekt ist u. dieser phasenweise erheblichen Lärm erzeugt.
      **> Möglicherweise ist da nicht der Lüfter defekt, sondern es sind die Kühlrippen von Staub zugesetzt. Diese kannst du einfach ausblasen.
      Tipp: Mach das System weitestgehend staubfrei.**
      Frage: Kann ich bei Neuaufsetzen meine Backups der VM u. LXC verwenden ?
      Das sollte kein Problem darstellen, teste aber vorher, ob die Backups tatsächlich valide sind (einfach mal eines unter einer anderen numerischen Bezeichnung einlesen, die Originalmaschine stoppen und die neue Maschine starten. Wenn es dann läuft, kannst du sicher sein, dass das Backup valide ist).
      Danke für die vielen fachlichen Tipps.
      Bezüglich Lüfter:
      Ich habe vor ca. 4 Monaten versucht bei laufendem Betrieb mit dem Staubsauger seitlich den Staub wegzusaugen und seit dem macht er fallweise diese lauten Geräusche. Ich glaube hier habe ich etwas beschädigt.
      Wahrscheinlich hätte ich das System herunterfahren müssen ?
      Meister MopperM Online
      Meister Mopper
      schrieb am zuletzt editiert von Meister Mopper
      Omg, da feilen die jahrelang an filigranen, platzsparenden Mini-PC und DU kommst im laufenden Betrieb mit dem Staubsauger 😂 🤔 ?
      Proxmox und HA - dank KI/AI endlich "blocklyfrei"
        Moin,
        nicht
        sondern
        Bernd
        GOETSCHHOFER
        @dp20eic said in Proxmox: Fehlermeldung bei backup - vzdump ?:
        Moin,
        nicht
        sondern
        Bernd
        login as: karl
        karl@192.168.1.140's password:
        Linux NUC 5.4.143-1-pve #1 SMP PVE 5.4.143-1 (Tue, 28 Sep 2021 09:10:37 +0200) x86_64
        permitted by applicable law.
        Last login: Thu Nov 23 15:09:51 2023 from 192.168.1.3
        karl@NUC:~$ cat /etc/pve/storage.cfg
        cat: /etc/pve/storage.cfg: Permission denied
        karl@NUC:~$
        Backup_USB-Stick ist auch USB für BACKUP.
        Es gibt 2:
        1. Backup-USB-Stick (NUC) mit 64 GB
        2. usb_backup_120 GB(NUC)
        • G GOETSCHHOFER
          Moin,
          nicht
          sondern
          Bernd
          login as: karl
          karl@NUC:~$
          Es gibt 2:
          login as: karl
          Moin,
          es ist ja schön, dass Du nicht als root unterwegs bist, aber dann muss man auch wissen und lesen ;)
          Dann musst Du, wenn Du als User auf dem Proxmox Rechner eingeloggt bist auch ein sudo vor den Befehl machen.
          Warum machst Du Dir das Leben so schwer, die WEB UI von Proxmox bietet doch alles, was man braucht.
          Es gibt 2:
          Ja, und das verstehe ich nicht, warum/wofür? Wie und wo werden die Sticks gemountet, wie sehen den die Einstellungen im BackupitUp Adapter aus?
          Bernd
          crunchipC G 2 Antworten Letzte Antwort
            login as: karl
            Moin,
            Es gibt 2:
            Bernd
            crunchipC Abwesend
            crunchipC Abwesend
            @dp20eic sagte in Proxmox: Fehlermeldung bei backup - vzdump ?:
            weil sich da einer beschwert hat und ihm nahe gelegt hatte sich einen User anzulegen und niemals mehr mit root einloggen😜 (ich wars aber nicht)
            wenn ich mich recht entsinne, war der erste Stick um darauf die Maschinen zu sichern, da aber der Speicher zu klein(weil zu viele backups) hat er sich noch den zweiten zugelegt, bzw laufen da glaub ich auch die backups via backitup drauf.
            Thomas BraunT G 2 Antworten Letzte Antwort
              @crunchip sagte in Proxmox: Fehlermeldung bei backup - vzdump ?:
              weil sich da einer beschwert hat und ihm nahe gelegt hatte sich einen User anzulegen und niemals mehr mit root einloggen (ich wars aber nicht)
              War ich vermutlich. Was soll daran falsch sein?
                login as: karl
                Moin,
                Es gibt 2:
                Bernd
                GOETSCHHOFER
                @dp20eic
                Ich mache die backups nicht über den backitup-Adapter sondern in proxmox.
                login as: root
                root@192.168.1.140's password:
                Access denied
                Linux NUC 5.4.143-1-pve #1 SMP PVE 5.4.143-1 (Tue, 28 Sep 2021 09:10:37 +0200) x        86_64
                Last login: Wed Nov 22 12:23:49 2023 from 192.168.1.3
                root@NUC:~# cat /etc/pve/storage.cfg
                dir: local
                        path /var/lib/vz
                        content iso,rootdir
                        prune-backups keep-daily=5,keep-last=5
                        shared 0
                lvmthin: local-lvm
                        thinpool data
                        vgname pve
                        content rootdir,images
                dir: Backup-USB-Stick
                        path /media/USB-NUC-NAS
                        content backup,vztmpl
                        nodes NUC
                        prune-backups keep-last=3
                        shared 0
                dir: usb_backup_120GB
                        path /media/usb_backup
                        nodes NUC
                        prune-backups keep-last=14
                        shared 0
                root@NUC:~#
                  GOETSCHHOFER
                  schrieb am zuletzt editiert von GOETSCHHOFER
                  @crunchip
                  Ja, genau so war es, der 1. USB-Stick wurde rasch zu klein.
                  Du hast echt ein sehr gutes Gedächtnis. 👍 😀
                  • G GOETSCHHOFER
                    @crunchip
                    Meister Mopper
                    @crunchip
                    😊 Ich glaube eher, dass Mario sehr gut dokumentiert. Soviel treffsichere Links kann sich ja kein menschliches Hirn merken.
                    😉 @crunchip
                      @thomas-braun sagte in Proxmox: Fehlermeldung bei backup - vzdump ?:
                      Moin,
                      weil es Proxmox ist und es da dann auch ein Rollen/Rechte System gibt, wo man sich dann User mit den nötigen Rollen einrichtet.
                      Ich lass' das dann mal, das wird dann schon jemand richten :)
                      Bernd
                      Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
                        Moin,
                        Bernd
                        Meister Mopper
                        Ich denke nicht, dass es jemand richten wird.
                        Aber tatsächlich kann man bei Proxmox den root nicht ausknipsen wie in nativen Systemen.
                        Aber es sollte meines Erachtens immer wieder darauf hingewiesen werden, dass auch in der Proxmox-cli als normaler User mit sudo (wenn nötig) gearbeitet werden muss, um Kollateralschäden zu vermeiden, so wie es @Thomas-Braun richtigerweise immer wieder propagiert.
                        Also root arbeiten bedeutet eine Operation am offenen Herzen, und das sollten Spezialisten tun.
                          Moin,
                          Bernd
                          Ja, mein Reden...
                            @meister-mopper sagte in Proxmox: Fehlermeldung bei backup - vzdump ?:
                            Der ist in nativen Systemen ja auch nicht 'ausgeknipst' (geht auch gar nicht, weil der ja im Hintergrund aktiv sein muss), er wird aber nicht direkt/aktiv verwendet.
                              Meister Mopper
                              Natürlich!
                                Ja, mein Reden...
                                crunchipC Abwesend
                                crunchipC Abwesend
                                @thomas-braun er meint direkt in Proxmox
                                ne net wirklich, aber manch Sachen bleiben in Erinnerung
                                  GOETSCHHOFER
                                  @crunchip
                                  Möchte ein kurzes Feedback zu meinem Problem geben.
                                  Habe gestern die beiden dump Verzeichnisse in proxmox mit root😁 bereinigt und die backups in proxmox von beiden USB-Sticks wieder aktiviert.
                                  Siehe da, jetzt laufen die seit gestern wieder normal ohne Fehlermeldung durch.
                                  Vielen Dank nochmals für die Hilfe an Alle. 👍
                                  • G GOETSCHHOFER
                                    @crunchip
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    @goetschhofer wenn dem so ist, müsste local ja wieder die Ursprungsinstalltonsgröße haben, bzw dürfte dann in
                                    /opt/iobroker/
                                    Kein backup liegen
                                      /opt/iobroker/
                                      Kein backup liegen
                                      GOETSCHHOFER
                                      @crunchip said in Proxmox: Fehlermeldung bei backup - vzdump ?:
                                      /opt/iobroker/
                                      Kein backup liegen
                                      Meinst du dies hier ?
                                      • G GOETSCHHOFER
                                        /opt/iobroker/
                                        Kein backup liegen
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        @goetschhofer dein opt/iobroker/backups ist leer, passt
                                        Aber dein local ist ja schon wieder angestiegen
                                          GOETSCHHOFER
                                          @crunchip
                                          Kann es sein, dass dies mit den backups zusammenhängt ?
                                          6 Tage werden aufbewahrt.
                                          14 Tage werden aufbewahrt
