  4. Iobroker nicht mehr erreichbar - Firewall?
38 Beiträge 6 Kommentatoren 4.2k Aufrufe 5 Beobachtet
  • L line
    @thomas-braun anbei
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     18:26:56 up  5:39,  3 users,  load average: 2.37, 2.24, 2.15
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    *** Time and Time Zones ***
                   Local time: Fri 2023-11-17 18:26:56 CET
               Universal time: Fri 2023-11-17 17:26:56 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    feline
    /home/feline
    feline adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    /home/iobroker/.diag.sh: line 200: [[: 678
    4373: syntax error in expression (error token is "4373")
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.8G        1.3G        4.2G         80M        2.3G        6.3G
    Swap:            99M          0B         99M
    Total:          7.9G        1.3G        4.3G
             7812 M total memory
             1251 M used memory
             1910 M active memory
             1298 M inactive memory
             4232 M free memory
              254 M buffer memory
             2073 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service loaded failed failed ioBroker Server
    1 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G   20G  8.3G  71% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G   29M  3.8G   1% /dev/shm
    tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     782M   28K  782M   1% /run/user/1000
    tmpfs          tmpfs     782M   28K  782M   1% /run/user/1002
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    3.5G    /var/
    3.1G    /var/log
    2.9G    /var/log/journal/378e881158e14149bc4f8e6771c6d1d7
    205M    /var/cache
    Archived and active journals take up 2.8G in the file system.
    /opt/iobroker/backups:
    230M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    384M    /opt/iobroker/iobroker-data/
    310M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    51M     /opt/iobroker/iobroker-data/backup-objects
    45M     /opt/iobroker/iobroker-data/files/devices.admin/static
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    11M     /opt/iobroker/iobroker-data/objects.jsonl
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.16
    admin:          6.12.0
    javascript:     7.1.4
    Adapters from github:   8
    Adapter State
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.178.69, run as: admin
      system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      system.adapter.apple-find-me.0          : apple-find-me         : raspberrypi                              - disabled
      system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
      system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
      system.adapter.evcc.0                   : evcc                  : raspberrypi                              -  enabled, port: 7070
      system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
      system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
      system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
      system.adapter.mediola-gateway.0        : mediola-gateway       : raspberrypi                              -  enabled
      system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
      system.adapter.modbus.0                 : modbus                : raspberrypi                              - disabled
      system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              - disabled, port: 1883
      system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              - disabled
      system.adapter.nuki.0                   : nuki                  : raspberrypi                              - disabled
      system.adapter.openligadb.0             : openligadb            : raspberrypi                              -  enabled
      system.adapter.parser.0                 : parser                : raspberrypi                              - disabled
      system.adapter.pegelalarm.0             : pegelalarm            : raspberrypi                              -  enabled
      system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
      system.adapter.radar2.0                 : radar2                : raspberrypi                              -  enabled
      system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
      system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
      system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.solaredge.0              : solaredge             : raspberrypi                              - disabled
      system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
      system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
      system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
      system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 192.168.178.69, run as: admin
      system.adapter.webcal.0                 : webcal                : raspberrypi                              -  enabled
      system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
    Adapter    "apple-find-me": 0.0.14   , installed 0.0.14
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "ble"          : 0.13.4   , installed 0.13.4
    Adapter    "bshb"         : 0.2.4    , installed 0.2.4
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "denon"        : 1.15.4   , installed 1.15.4
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
    Adapter    "evcc"         : 0.0.10   , installed 0.0.10
    Adapter    "fullybrowser" : 2.2.0    , installed 2.2.0
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "homekit-controller": 0.5.8, installed 0.5.8
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "iot"          : 2.0.11   , installed 1.14.5 [Updatable]
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.16   , installed 5.0.16
    Adapter    "lgtv"         : 2.1.2    , installed 2.1.1  [Updatable]
    Adapter    "mediola-gateway": 1.0.1  , installed 1.0.1
    Adapter    "meross"       : 1.15.1   , installed 1.15.1
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "openligadb"   : 1.2.4    , installed 1.3.4
    Adapter    "parser"       : 2.0.7    , installed 1.3.2  [Updatable]
    Adapter    "pegelalarm"   : 1.3.1    , installed 1.3.1
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "radar2"       : 2.0.8    , installed 2.0.8
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "solarviewdatareader": 1.0.7, installed 1.0.7
    Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
    Adapter    "trashschedule": 2.3.0    , installed 2.2.0  [Updatable]
    Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.1.10   , installed 6.1.2  [Updatable]
    Adapter    "ws"           : 2.5.8    , installed 2.5.5  [Updatable]
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Objects and States
    Objects:        12529
    States:         10443
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Get:4 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
    Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
    Fetched 5127 B in 3s (1924 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15515      659/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15651      612/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15517      659/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15650      612/cupsd
    tcp6       0      0 :::4712                 :::*                    LISTEN      116        107895     22094/evcc
    tcp6       0      0 :::3000                 :::*                    LISTEN      120        17960      620/grafana
    tcp6       0      0 :::7070                 :::*                    LISTEN      116        107024     22094/evcc
    tcp6       0      0 :::3389                 :::*                    LISTEN      117        13027      683/xrdp
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          15521      649/xrdp-sesman
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13004      696/cups-browsed
    udp        0      0 0.0.0.0:58178           0.0.0.0:*                           108        16393      467/avahi-daemon: r
    udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1002       107880     4761/chromium-brows
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16391      467/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16549      543/dhcpcd
    udp6       0      0 :::546                  :::*                                0          23799      543/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        16392      467/avahi-daemon: r
    udp6       0      0 :::59193                :::*                                108        16394      467/avahi-daemon: r
    @line
    Das sollte 0.0.0.0. heißen.
    • L line
      @thomas-braun anbei
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      feline
      /home/feline
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               7812 M total memory
               1251 M used memory
               4232 M free memory
                254 M buffer memory
               2073 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      3.5G    /var/
      3.1G    /var/log
      205M    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        12529
      States:         10443
      Pending Updates: 0
      @line
      Und schalt den Desktop aus!
      Insbesondere den Remote Desktop!
      • L line
        @thomas-braun anbei
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        feline
        /home/feline
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 7812 M total memory
                 1251 M used memory
                 4232 M free memory
                  254 M buffer memory
                 2073 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        3.5G    /var/
        3.1G    /var/log
        205M    /var/cache
        USB-Devices by-id:
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.0
        javascript:     7.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        12529
        States:         10443
        Pending Updates: 0
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        @line sagte in Iobroker nicht mehr erreichbar - Firewall?:
        Netzteil zu schwach ?
        Lehrling seit 1975 !!!
          @thomas-braun sagte in Iobroker nicht mehr erreichbar - Firewall?:
          @line
          @line
          siehe Doku:
          ist sogar rot
          L 1 Antwort Letzte Antwort
            @line
            @line
            siehe Doku:
            ist sogar rot
            line
            @homoran das hab ich nun umgestellt. Jetzt erreiche ich den iobroker nicht mal mehr über den raspi. Was nun?
            • L line
              iob list instances bitte
                line
                @homoran Danke dir
                system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
                + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
                + system.adapter.evcc.0                   : evcc                  : raspberrypi                              -  enabled, port: 7070
                + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
                + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                + system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
                + system.adapter.mediola-gateway.0        : mediola-gateway       : raspberrypi                              -  enabled
                + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                + system.adapter.openligadb.0             : openligadb            : raspberrypi                              -  enabled
                + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
                + system.adapter.radar2.0                 : radar2                : raspberrypi                              -  enabled
                + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
                + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                + system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
                + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 192.168.178.69, run as: admin
                + system.adapter.webcal.0                 : webcal                : raspberrypi                              -  enabled
                + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                + instance is alive
                • L line
                  @homoran Danke dir
                  + instance is alive
                  @line iob start admin
                    line
                    @homoran ok jetzt läuft er auf dem raspberry wieder - jetzt war ich gerade völlig verzweifelt. Danke dafür
                    Aber auf dem Pad oder pc sieht es immer noch nicht besser aus
                    • L line
                      @line
                      pgrep -f "Xorg"
                      Und nochmal die Ausgabe von
                      iob diag
                        @line
                        pgrep -f "Xorg"
                        iob diag
                        line
                        schrieb am zuletzt editiert von line
                        pgrep -f "Xorg"
                        673
                        2969
                        Ion diag
                        + instance is alive
                        feline@raspberrypi:~ $ iob start admin
                        The adapter "admin.0" was started.
                        feline@raspberrypi:~ $ pgrep -f "Xorg"
                        673
                        2969
                        feline@raspberrypi:~ $ iob diag
                        *** iob diag is starting up, please wait ***
                        *** ioBroker Diagnosis ***
                        Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                        The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                        https://forum.iobroker.net
                        Just copy and paste the Summary Page, including the ``` characters at start and end.
                        It helps us to help you!
                        Press any key to continue
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                         21:52:48 up 55 min,  3 users,  load average: 0.61, 0.54, 0.54
                        CPU threads: 4
                        Current issues:
                                       Local time: Fri 2023-11-17 21:52:48 CET
                                   Universal time: Fri 2023-11-17 20:52:48 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        feline
                        /home/feline
                        /home/iobroker/.diag.sh: line 200: [[: 673
                        2969: syntax error in expression (error token is "2969")
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            7.8G        2.3G        4.1G         73M        1.4G        5.3G
                        Swap:            99M          0B         99M
                        Total:          7.9G        2.3G        4.2G
                                 7812 M total memory
                                 2335 M used memory
                                 2930 M active memory
                                  618 M inactive memory
                                 4065 M free memory
                                   75 M buffer memory
                                 1335 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        0 loaded units listed.
                        *** FILESYSTEM ***
                        /dev/root      ext4       29G   20G  8.2G  71% /
                        tmpfs          tmpfs     3.9G   24M  3.8G   1% /dev/shm
                        [Fri Nov 17 20:57:07 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:38:62:0F vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b4c0fa64-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                        [Fri Nov 17 20:57:08 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Fri Nov 17 20:57:08 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Fri Nov 17 20:57:10 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                        `-/home/feline2/thinclient_drives xrdp-chansrv   fuse.xrdp-chansrv rw,nosuid,nodev,relatime,user_id=1002,group_id=1002
                        /var:
                        3.6G    /var/
                        3.1G    /var/log
                        205M    /var/cache
                        412M    /opt/iobroker/iobroker-data/
                        23M     /opt/iobroker/iobroker-data/states.jsonl
                        20M     /opt/iobroker/iobroker-data/objects.jsonl
                        USB-Devices by-id:
                        /usr/bin/npm            9.8.1
                        /usr/bin/npx            9.8.1
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.12.0
                        javascript:     7.1.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        /Objects:       12529
                                States:         10686
                        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                        Get:5 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
                        Fetched 5127 B in 2s (3331 B/s)
                        Pending Updates: 0
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       23905      2764/io.shelly.0
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12146      652/sshd: /usr/sbin
                        tcp        0      0 192.168.178.69:8082     0.0.0.0:*               LISTEN      1001       22476      2840/io.web.0
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       23627      2620/iobroker.js-co
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23634      2620/iobroker.js-co
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12213      611/cupsd
                        tcp6       0      0 :::38137                :::*                    LISTEN      1001       27437      3826/io.yahka.0
                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12212      611/cupsd
                        tcp6       0      0 :::4712                 :::*                    LISTEN      116        34678      5241/evcc
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          12148      652/sshd: /usr/sbin
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       34899      4873/io.admin.0
                        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       26414      3842/io.socketio.0
                        tcp6       0      0 :::3389                 :::*                    LISTEN      117        12250      679/xrdp
                        tcp6       0      0 :::7070                 :::*                    LISTEN      116        37154      5241/evcc
                        tcp6       0      0 :::3000                 :::*                    LISTEN      120        19507      613/grafana
                        tcp6       0      0 ::1:3350                :::*                    LISTEN      0          11133      645/xrdp-sesman
                        udp        0      0 0.0.0.0:1902            0.0.0.0:*                           1001       24557      3407/io.mediola-gat
                        udp        0      0 0.0.0.0:40074           0.0.0.0:*                           108        14830      467/avahi-daemon: r
                        udp        0      0 0.0.0.0:41021           0.0.0.0:*                           1001       24558      3407/io.mediola-gat
                        udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       22262      2753/io.radar2.0
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14961      546/dhcpcd
                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          12230      687/cups-browsed
                        udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1002       26205      3418/chromium-brows
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14828      467/avahi-daemon: r
                        udp6       0      0 :::44206                :::*                                108        14831      467/avahi-daemon: r
                        udp6       0      0 :::546                  :::*                                0          14990      546/dhcpcd
                        udp6       0      0 :::5353                 :::*                                108        14829      467/avahi-daemon: r
                        iob diag has finished.
                        Press any key for a summary
                        Copy text starting here:
                                                v.2023-10-10
                                 Icon name: computer
                              Architecture: arm64
                        Kernel:                 aarch64
                        Userland:               arm64
                        Timezone:               Europe/Berlin (CET, +0100)
                        User-ID:                1000
                        /home/iobroker/.diag.sh: line 469: [[: 673
                        X-Server:               false
                        Pending OS-Updates:     0
                        Pending iob updates:    7
                        Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                                /usr/bin/npm            9.8.1
                                                /usr/bin/npx            9.8.1
                        Recommended versions are nodejs 18.18.2 and npm 9.8.1
                        MEMORY:
                        Mem:            7.8G        2.4G        3.9G         73M        1.5G        5.2G
                        Swap:            99M          0B         99M
                        Total:          7.9G        2.4G        4.0G
                        Active iob-Instances:   28
                        ioBroker Core:          js-controller           5.0.16
                                                admin                   6.12.0
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                12529
                        States:                 10686
                        Size of iob-Database:
                        === Mark text until here for copying ===
                        • L line
                          pgrep -f "Xorg"
                          673
                          2969
                          Ion diag
                          + instance is alive
                          673
                          2969
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : arm64
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          feline
                          /home/feline
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:            99M          0B         99M
                                   7812 M total memory
                                   2335 M used memory
                                   4065 M free memory
                                     75 M buffer memory
                                   1335 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          3.6G    /var/
                          3.1G    /var/log
                          205M    /var/cache
                          USB-Devices by-id:
                          /usr/bin/npm            9.8.1
                          /usr/bin/npx            9.8.1
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.12.0
                          javascript:     7.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          /Objects:       12529
                                  States:         10686
                          Pending Updates: 0
                                                  v.2023-10-10
                                   Icon name: computer
                                Architecture: arm64
                          Kernel:                 aarch64
                          Userland:               arm64
                          User-ID:                1000
                          X-Server:               false
                                                  /usr/bin/npm            9.8.1
                                                  /usr/bin/npx            9.8.1
                          MEMORY:
                          Swap:            99M          0B         99M
                                                  admin                   6.12.0
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                12529
                          States:                 10686
                          @line der admin ist ja schon wieder deaktiviert!
                          warum?
                          edit
                          im diag ist er aktiv
                          • L line
                            Browsercache gelöscht?
                            • L line
                              pgrep -f "Xorg"
                              673
                              2969
                              Ion diag
                              + instance is alive
                              673
                              2969
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : arm64
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              feline
                              /home/feline
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:            99M          0B         99M
                                       7812 M total memory
                                       2335 M used memory
                                       4065 M free memory
                                         75 M buffer memory
                                       1335 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              3.6G    /var/
                              3.1G    /var/log
                              205M    /var/cache
                              USB-Devices by-id:
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.12.0
                              javascript:     7.1.4
                              Adapter State
                              + instance is alive
                              Objects and States
                              /Objects:       12529
                                      States:         10686
                              Pending Updates: 0
                                                      v.2023-10-10
                                       Icon name: computer
                                    Architecture: arm64
                              Kernel:                 aarch64
                              Userland:               arm64
                              User-ID:                1000
                              X-Server:               false
                                                      /usr/bin/npm            9.8.1
                                                      /usr/bin/npx            9.8.1
                              MEMORY:
                              Swap:            99M          0B         99M
                                                      admin                   6.12.0
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                12529
                              States:                 10686
                              @line
                              sudo systemctl set-default multi-user.target
                              sudo systemctl isolate multi-user.target
                              Der web-Adapter hat auch noch ein Binding...
                              Bring die Adapter auf Stand:
                                warum?
                                edit
                                line
                                @homoran keine Ahnung. Ich hab ihn nochmals neu gestartet.
                                Jetzt steht er auf enable.
                                  @line
                                  line
                                  @thomas-braun Ok, hab die Updates ausgeführt. Den Web Adapter das Binding raugommen. Jedoch erreiche ich ihn trotzdem nicht von einem pc oder pad
                                           Icon name: computer
                                        Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : arm64
                                   22:30:14 up  1:33,  2 users,  load average: 0.71, 1.18, 1.44
                                  CPU threads: 4
                                  Current issues:
                                                 Local time: Fri 2023-11-17 22:30:14 CET
                                             Universal time: Fri 2023-11-17 21:30:14 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  feline
                                  /home/feline
                                  X-Server:       true
                                  Desktop:
                                  Terminal:       tty
                                  Boot Target:    multi-user.target
                                  *** MEMORY ***
                                  Mem:            7.8G        2.4G        3.6G         98M        1.8G        5.1G
                                  Swap:            99M          0B         99M
                                  Total:          7.9G        2.4G        3.7G
                                           7812 M total memory
                                           2437 M used memory
                                           3037 M active memory
                                            940 M inactive memory
                                           3602 M free memory
                                            117 M buffer memory
                                           1655 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  tmpfs          tmpfs     3.9G   60M  3.8G   2% /dev/shm
                                  /var:
                                  3.6G    /var/
                                  3.1G    /var/log
                                  205M    /var/cache
                                  425M    /opt/iobroker/iobroker-data/
                                  325M    /opt/iobroker/iobroker-data/files
                                  33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                                  29M     /opt/iobroker/iobroker-data/states.jsonl
                                  21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                                  12M     /opt/iobroker/iobroker-data/objects.jsonl
                                  USB-Devices by-id:
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  nodejs:
                                    Version table:
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.12.0
                                  javascript:     7.1.4
                                  Adapter State
                                  + instance is alive
                                  Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                                  Adapter    "iot"          : 2.0.11   , installed 2.0.11
                                  Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
                                  Adapter    "parser"       : 2.0.7    , installed 2.0.7
                                  Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                                  Adapter    "web"          : 6.1.10   , installed 6.1.10
                                  Adapter    "ws"           : 2.5.8    , installed 2.5.8
                                  Objects and States
                                  Objects:        12534
                                  States:         10691
                                  Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                  Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                  Get:6 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
                                  Fetched 5127 B in 2s (2471 B/s)
                                  Pending Updates: 0
                                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       55250      9859/io.shelly.0
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       56608      9666/iobroker.js-co
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       54912      9666/iobroker.js-co
                                  tcp6       0      0 :::4712                 :::*                    LISTEN      116        60025      10429/evcc
                                  tcp6       0      0 :::41285                :::*                    LISTEN      1001       57653      10200/io.yahka.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       56623      9684/io.admin.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       60422      10318/io.web.0
                                  tcp6       0      0 :::8084                 :::*                    LISTEN      1001       58764      10211/io.socketio.0
                                  tcp6       0      0 :::7070                 :::*                    LISTEN      116        60830      10429/evcc
                                  udp        0      0 0.0.0.0:1902            0.0.0.0:*                           1001       59512      10091/io.mediola-ga
                                  udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       55168      9816/io.radar2.0
                                  udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1002       57876      3418/chromium-brows
                                  udp        0      0 0.0.0.0:50693           0.0.0.0:*                           1001       59513      10091/io.mediola-ga
                                  • L line
                                             Icon name: computer
                                          Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : arm64
                                    CPU threads: 4
                                    Current issues:
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    feline
                                    /home/feline
                                    X-Server:       true
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:            99M          0B         99M
                                             7812 M total memory
                                             2437 M used memory
                                             3602 M free memory
                                              117 M buffer memory
                                             1655 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /var:
                                    3.6G    /var/
                                    3.1G    /var/log
                                    205M    /var/cache
                                    USB-Devices by-id:
                                    /usr/bin/npm            9.8.1
                                    /usr/bin/npx            9.8.1
                                    nodejs:
                                      Version table:
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.12.0
                                    javascript:     7.1.4
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        12534
                                    States:         10691
                                    Pending Updates: 0
                                    Marc BergM Online
                                    Marc BergM Online
                                    Marc Berg
                                    gelöscht. Hier stand Unsinn.
                                    • Marc BergM Marc Berg
                                      line
                                      @marc-berg
                                      Der Error im NMP Tree kann man ignorieren?
                                      Hat sonst noch jemand eine Idee?
                                      • crunchipC Abwesend
                                        crunchipC Abwesend
                                        @line lösch vllt besser mal deine privaten ical Einträge aus dem log
                                        eventuell mal deinen Router neu starten
                                          line
                                          @crunchip Danke für den Hinweis.
                                          Router neu gestartet, keine Verbesserung. Ich werd noch verrückt.
                                          Als ich die influx installiert habe, hatte ich eine Anleitung, die eine codezeile für die Installation braucht
                                          ufw allow 22/tcp
