  4. Alle Instanzen rot,
Alle Instanzen rot,
27 Beiträge 6 Kommentatoren 3.7k Aufrufe 4 Beobachtet
  • M mibr85
    @djmarc75 sagte in Alle Instanzen rot,:
    iob diag
    Skript v.2023-10-10
    *** BASE SYSTEM ***
    Hardware Vendor : PC Engines
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v8.1.0
    Virtualization  : container-other
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     13:37:33 up 10 days, 20:49,  0 users,  load average: 1.38, 1.56, 1.89
    CPU threads: 4
    *** Time and Time Zones ***
    Sun Nov 12 12:37:33 UTC 2023
    Sun Nov 12 13:37:33 CET 2023
    CET +0100
    Etc/UTC
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            3.9G        2.4G        343M        9.0M        1.2G        1.3G
    Swap:           2.0G        769M        1.3G
    Total:          6.0G        3.1G        1.6G
             3939 M total memory
             2356 M used memory
             1986 M active memory
             1055 M inactive memory
              343 M free memory
              564 M buffer memory
              675 M swap cache
             2043 M total swap
              769 M used swap
             1274 M free swap
    *** FILESYSTEM ***
    Filesystem         Type     Size  Used Avail Use% Mounted on
    overlay            overlay  434G   39G  373G  10% /
    tmpfs              tmpfs     64M     0   64M   0% /dev
    tmpfs              tmpfs    2.0G     0  2.0G   0% /sys/fs/cgroup
    shm                tmpfs     64M     0   64M   0% /dev/shm
    /dev/mapper/system ext4     434G   39G  373G  10% /opt/iobroker
    tmpfs              tmpfs    2.0G     0  2.0G   0% /proc/asound
    tmpfs              tmpfs    2.0G     0  2.0G   0% /proc/acpi
    tmpfs              tmpfs    2.0G     0  2.0G   0% /sys/firmware
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET           SOURCE        FSTYPE OPTIONS
    /opt/iobroker    /dev/mapper/system[/var/lib/docker/volumes/iobroker_volume_new/_data]                                                       ext4   rw,noatime,discard,errors=remount-ro,data=ordered
    /etc/resolv.conf /dev/mapper/system[/var/lib/docker/containers/b8a23e09a240d48998b8749f2f7a8813378221bd5f2447cc348042651e82cbf0/resolv.conf] ext4   rw,noatime,discard,errors=remount-ro,data=ordered
    /etc/hostname    /dev/mapper/system[/var/lib/docker/containers/b8a23e09a240d48998b8749f2f7a8813378221bd5f2447cc348042651e82cbf0/hostname]    ext4   rw,noatime,discard,errors=remount-ro,data=ordered
    /etc/hosts       /dev/mapper/system[/var/lib/docker/containers/b8a23e09a240d48998b8749f2f7a8813378221bd5f2447cc348042651e82cbf0/hosts]       ext4   rw,noatime,discard,errors=remount-ro,data=ordered
    /var:
    34M     /var/
    32M     /var/lib
    18M     /var/lib/apt/lists
    18M     /var/lib/apt
    14M     /var/lib/dpkg
    /opt/iobroker/backups:
    35M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    319M    /opt/iobroker/iobroker-data/
    210M    /opt/iobroker/iobroker-data/files
    77M     /opt/iobroker/iobroker-data/backup-objects
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    21M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    11M     /opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /home/iobroker/.diag.sh: line 277: nodejs: command not found
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    /usr/bin/corepack       0.18.0
    /home/iobroker/.diag.sh: line 288: nodejs: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
            500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.12.0
    javascript:     7.1.4
    Adapters from github:   1
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBrokerTWS                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : ioBrokerTWS                              -  enabled
    + system.adapter.discovery.0              : discovery             : ioBrokerTWS                              -  enabled
    + system.adapter.doorbird.0               : doorbird              : ioBrokerTWS                              -  enabled
    + system.adapter.e3dc-rscp.0              : e3dc-rscp             : ioBrokerTWS                              -  enabled
    + system.adapter.gruenbeck.0              : gruenbeck             : ioBrokerTWS                              -  enabled
    + system.adapter.hue.0                    : hue                   : ioBrokerTWS                              -  enabled, port: 443
    + system.adapter.hue.1                    : hue                   : ioBrokerTWS                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : ioBrokerTWS                              -  enabled
    + system.adapter.info.0                   : info                  : ioBrokerTWS                              -  enabled
    + system.adapter.iot.0                    : iot                   : ioBrokerTWS                              -  enabled
    + system.adapter.javascript.0             : javascript            : ioBrokerTWS                              -  enabled
    + system.adapter.klf200.0                 : klf200                : ioBrokerTWS                              -  enabled
    + system.adapter.knx.0                    : knx                   : ioBrokerTWS                              -  enabled
      system.adapter.lg-thinq.0               : lg-thinq              : ioBrokerTWS                              - disabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBrokerTWS                              -  enabled, port: 54321
    + system.adapter.mqtt-client.0            : mqtt-client           : ioBrokerTWS                              -  enabled, port: 1883
      system.adapter.node-red.0               : node-red              : ioBrokerTWS                              - disabled, port: 1880, bind: 0.0.0.0
    + system.adapter.procon-ip.0              : procon-ip             : ioBrokerTWS                              -  enabled
      system.adapter.pvforecast.0             : pvforecast            : ioBrokerTWS                              - disabled
      system.adapter.scenes.0                 : scenes                : ioBrokerTWS                              - disabled
    + system.adapter.shelly.0                 : shelly                : ioBrokerTWS                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.statistics.0             : statistics            : ioBrokerTWS                              -  enabled
      system.adapter.synology.0               : synology              : ioBrokerTWS                              - disabled, port: 5001
    + system.adapter.telegram.0               : telegram              : ioBrokerTWS                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : ioBrokerTWS                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : ioBrokerTWS                              -  enabled
      system.adapter.unifi.0                  : unifi                 : ioBrokerTWS                              - disabled
    + system.adapter.viessmannapi.0           : viessmannapi          : ioBrokerTWS                              -  enabled
    + system.adapter.web.0                    : web                   : ioBrokerTWS                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yahka.0                  : yahka                 : ioBrokerTWS                              - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
    Adapter    "doorbird"     : 1.3.0    , installed 1.3.0
    Adapter    "e3dc-rscp"    : 1.2.3    , installed 1.2.3
    Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 1.14.5 [Updatable]
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "klf200"       : 1.1.2    , installed 1.1.2
    Adapter    "knx"          : 2.0.23   , installed 2.0.22 [Updatable]
    Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
    Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
    Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "procon-ip"    : 1.4.0    , installed 1.4.0
    Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.5.5    , installed 6.5.2  [Updatable]
    Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "telegram"     : 2.0.1    , installed 2.0.1
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
    Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
    Adapter    "web"          : 6.1.10   , installed 6.1.0  [Updatable]
    Adapter    "ws"           : 2.5.8    , installed 2.5.3  [Updatable]
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Objects and States
    leider ist mein Consolenfenster zuklein in der Portainer.io Container console, kann also nicht alles sehen.
    Hier noch die zusammenfassung:
                            v.2023-10-10
    model name      : AMD GX-412TC SOC
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v8.1.0
    Installation:           Docker
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Etc/UTC
    User-ID:                0
    X-Server:               false
    Pending OS-Updates:     33
    Pending iob updates:    6
    /home/iobroker/.diag.sh: line 486: nodejs: command not found
    Nodejs-Installation:
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.18.2 and npm 9.8.1
    Wrong installation path detected. This needs to be fixed.
    Please check
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    for more information on how to fix these errors.
    MEMORY:
    Mem:            3.9G        2.4G        509M        8.0M        1.1G        1.3G
    Swap:           2.0G        770M        1.3G
    Total:          6.0G        3.1G        1.8G
    Active iob-Instances:   24
    ioBroker Core:          js-controller           5.0.12
                            admin                   6.12.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                22206
    States:                 16744
    Size of iob-Database:
    27M     /opt/iobroker/iobroker-data/objects.jsonl
    15M     /opt/iobroker/iobroker-data/states.jsonl
    haselchenH Offline
    haselchenH Offline
    haselchen
    @mibr85
    Node Version ist nicht aktuell und falsch installiert .
    Und dann könnte Probleme mit den 2 Instanzen von HUE geben.
    Wieso 2?
    • haselchenH haselchen
      @mibr85
      Wieso 2?
      mibr85
      @haselchen
      wie bekomme ich die Node.js installation korrigiert?
      Ich habe zwei hue bridges also benötige ich auch zwei instanzen ;-)
      • M mibr85
        @haselchen
        haselchenH Offline
        haselchenH Offline
        haselchen
        @mibr85
        https://forum.iobroker.net/topic/69067/neuer-befehl-iob-nodejs-update?_=1699794162915
        Und das funktioniert mit den beiden Bridges?
        Hatte ich auch mal , war eine Katastrophe. Kann sein das Philipps da nachgebessert hat.
        Die Dinger laufen auf Port 443 bei Dir.
        Hab da oft von Problemen gelesen. Workaround wäre 80.
        Wie ist das Polling bei Beiden eingestellt ?
          @mibr85
          mibr85
          schrieb am zuletzt editiert von mibr85
          @haselchen
          der Link nützt mir leider nix da mein system im docker läuft..
          mit den zwei Hue bridges läuft es problemlos auf standard einstellungen.
          Warum kommt beim antworten auf einen Beitrag und rechts öfters Fehler forbidden
          DJMarc75D haselchenH 2 Antworten Letzte Antwort
          • M mibr85
            @haselchen
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @mibr85 sagte in Alle Instanzen rot,:
            weil Du wahrscheinlich mehrere Fenster (Tabs) vom Forum geöffnet hast ?!
            Lehrling seit 1975 !!!
            • DJMarc75D DJMarc75
              mibr85
              @djmarc75
              ok Danke.
              war mir nicht bewust das dies ein Problem darstellt.
              • M mibr85
                @djmarc75
                ok Danke.
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                Ein Problem stellt das nur dann dar wenn Du in den verschiedenen Tabs aktiv bist. Wenn Du dann in einem Anderen, nicht aktualisiertem Tab einen Beitrag schreibst/editierst dann kommt der Error.
                Deshalb sollte man auch nur ein Tab aufmachen, dann klappts auch mit dem Nachbarn ;)
                Ist jetzt aber OffTopic genug... back to the roots - zu Deinem "Problem"
                Ich vermute bei Dir einige Amok-Skripte. Da mal ansetzen
                  mibr85
                  @djmarc75
                  mhhh das es was mit meinen scripten zu tun hat, hatte ich auch schon im hinterkopf aber wie setz ich da bei der Fehlersuche am besten an? alle stoppen und einzeln wieder aktivieren? aber wo kann ich denn sehen das ein "Script amok läuft"?
                  • M mibr85
                    @djmarc75
                    geht, aber die 50/50 Mezhode ist schneller.
                    50% aktiviert lassen.
                    Problem -> davon 50% deaktivieren....
                    kein Problem -> von den übrigen 50% die Hälfte aktivieren.....
                    an der erzeugten Last, z.B. mit top
                    • M mibr85
                      @haselchen
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      @mibr85
                      Dann machste es halt so, wie ich es hier beschrieben habe:
                      https://forum.iobroker.net/topic/68035/iob-node-fix-skript/85?page=5
                      Allerdings müsstest Du vorher Deine Installation korrigieren.
                      Die Jetzige ist falsch installiert worden.
                      Das wird Dir zukünftig definitiv vor die Füsse fallen.
                        @mibr85
                        mibr85
                        @haselchen
                        ok aber wie kann ich denn meine istallation koorigieren mit iob fix?
                        • M mibr85
                          @haselchen
                          @mibr85
                          Mit einem aktuellen Docker.
                          • haselchenH Offline
                            haselchenH Offline
                            haselchen
                            @mibr85
                            Wäre auch meine Idee (von @Thomas-Braun )
                            Backup machen.
                            Neuen Container starten mit identischen Einstellungen und Backup einspielen.
                              @mibr85
                              Backup machen.
                              mibr85
                              Ja Habe ich gerade versucht einen ganz nackten Container mit neuem Volume aufzusetzen, leider startet der container nicht:
                              -------------------------     2023-11-12 15:35:11      -------------------------
                              -----              Welcome to your ioBroker Docker container!              -----
                              -----                    Startupscript is now running!                     -----
                              -----                          Please be patient!                          -----
                              -----                          System Information                          -----
                              -----                    arch:                x86_64                       -----
                              -----                    hostname:            ioBrokerTWS                  -----
                              -----                          Version Information                         -----
                              -----                    image:               v9.0.1                       -----
                              -----                    build:               2023-11-11T23:44:48+00:00    -----
                              -----                    node:                v18.18.2                     -----
                              -----                    node[22]: ../src/node_platform.cc:68:std::unique_ptr<long unsigned int> node::WorkerThreadsTaskRunner::DelayedTaskScheduler::Start(): Assertion `(0) == (uv_thread_create(t.get(), start_thread, this))' failed.
                               1: 0xb85bc0 node::Abort() [node]
                               2: 0xb85c3e  [node]
                               3: 0xbf30fe  [node]
                               4: 0xbf31e1 node::NodePlatform::NodePlatform(int, v8::TracingController*, v8::PageAllocator*) [node]
                               5: 0xb438f3 node::InitializeOncePerProcess(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, node::ProcessFlags::Flags) [node]
                               6: 0xb43f4b node::Start(int, char**) [node]
                               7: 0x7f489d0e71ca  [/lib/x86_64-linux-gnu/libc.so.6]
                               8: 0x7f489d0e7285 __libc_start_main [/lib/x86_64-linux-gnu/libc.so.6]
                               9: 0xac1f4e _start [node]
                              npm:                                              -----
                              -----                        Environment Variables                         -----
                              -----                    SETGID:              1000                         -----
                              -----                    SETUID:              1000                         -----
                              -----                   Step 1 of 5: Preparing container                   -----
                              Updating Linux packages on first run... Error: Updating failed.
                              Registering maintenance script as command... Done.
                              -----             Step 2 of 5: Detecting ioBroker installation             -----
                              Existing installation of ioBroker detected in "/opt/iobroker".
                              -----             Step 3 of 5: Checking ioBroker installation              -----
                              (Re)setting permissions (This might take a while! Please be patient!)... Done.
                              Checking Database connection... Failed.
                              Please check your configuration and try again.
                              For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs).
                              This Script will exit now.
                              • M mibr85
                                 2: 0xb85c3e  [node]
                                 3: 0xbf30fe  [node]
                                npm:                                              -----
                                haselchenH Offline
                                haselchenH Offline
                                haselchen
                                @mibr85
                                Wie genau aufgesetzt?
                                Da gibt es ja anscheinend x Möglichkeiten.
                                Ich mach das mit ner Synology.
                                Du vermutlich.....anders?!
                                  @mibr85
                                  mibr85
                                  @haselchen
                                  über Portainer auf einem Timberwolfserver. läuft eigentlich seit 2 Jahren ohne grössere Problem aber gerade hakt es
                                  • M mibr85
                                    @haselchen
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    aber gerade hakt es
                                    Hast Du die eventuellen (Amok) Skripte schon geprüft?
                                      aber gerade hakt es
                                      mibr85
                                      @djmarc75
                                      nein konnte ich nicht mehr der Container ist nicht mehr gestartet :-(
                                      • M mibr85
                                        @djmarc75
                                        mibr85
                                        kleines Update ich habe jetzt mal meinen Container neu aufgesetzt und das Backup wieder eingespielt.
                                        Läuft erstmal wieder.
                                        Bei den scripten habe ich erst mal alle Scripte ohne timeout wieder aktiviert, da ich glaube das evtl irgendwo immer wieder neue timer getrigert werden.
                                        kann man irgendwo sehen welche timeouts im hintergrund laufen bzw kann man sich anzeigen lassen wenn ein neuer timer getriggert und wieder gestoppt wird.
                                        wenn ich mit dem befehl top in der console arbeite bekommt man ja erst nach einer gewissen Zeit mit ob da mehr leistung gezogen wird, wenn es wirklich an den timeouts liegt, oder?
                                        Gibt es noch andere möglichkeiten Amokscripte zu identifizieren? Debug oder silly log einstellung für Javascripz adapter evtl?
                                        zur zeit sieht es nicht schlecht aus mMn:
                                          mibr85
                                          zB hier
                                          wird augenscheinlich 4 mal der timeout gestartet, Warum?
                                          wie kann man das besser lösen?
                                          wie kann man die gestartetetn timeouts wieder stoppen? Durch restart javascriptadapter?
                                          N 1 Antwort Letzte Antwort
