  3. Einsteigerfragen
  4. ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme
    6.7k
267 Beiträge 8 Kommentatoren 63.7k Aufrufe 8 Beobachtet
  • G Gismoh
    @crunchip
    neue VM (vor erneutem iob fix)
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: ioBrokerVM
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-13-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
    model name      : QEMU Virtual CPU version 2.5+
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     15:40:50 up  1:05,  2 users,  load average: 0.16, 0.04, 0.01
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Thu 2023-11-09 15:40:50 CET
               Universal time: Thu 2023-11-09 14:40:50 UTC
                     RTC time: Thu 2023-11-09 14:40:50
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    idash
    /home/idash
    idash adm dialout sudo plugdev users input netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.1G        384M        3.4G        507K        574M        3.7G
    Swap:           1.0G          0B        1.0G
    Total:          5.1G        384M        4.4G
             3915 M total memory
              367 M used memory
              222 M active memory
              251 M inactive memory
             3248 M free memory
               67 M buffer memory
              480 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service loaded failed failed ioBroker Server
    1 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.9G     0  1.9G   0% /dev
    tmpfs          tmpfs     392M  500K  392M   1% /run
    /dev/sda1      ext4       31G  3.6G   26G  13% /
    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     392M     0  392M   0% /run/user/1002
    [Thu Nov  9 14:35:44 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Thu Nov  9 14:35:45 2023] EXT4-fs (sda1): re-mounted. Quota mode: none.
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    455M    /var/
    248M    /var/cache
    240M    /var/cache/apt
    169M    /var/lib
    164M    /var/cache/apt/archives
    Archived and active journals take up 24.0M in the file system.
    /opt/iobroker/backups:
    5.8M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    189M    /opt/iobroker/iobroker-data/
    157M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    27M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    8.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
    7.2M    /opt/iobroker/iobroker-data/files/ham.admin/static/js/main.8080bc0b.js.map
    7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
    find: '/dev/serial/by-id/': No such file or directory
    USB-Devices by-id:
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.8.0
    javascript:     7.1.4
    Adapters from github:   0
    Adapter State
      system.adapter.admin.0                  : admin                 : ioBrokerVM                               -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.alarm.0                  : alarm                 : ioBrokerVM                               - disabled
      system.adapter.alexa2.0                 : alexa2                : ioBrokerVM                               - disabled
      system.adapter.backitup.0               : backitup              : ioBrokerVM                               -  enabled
      system.adapter.daikin-cloud.0           : daikin-cloud          : ioBrokerVM                               - disabled
      system.adapter.daswetter.0              : daswetter             : ioBrokerVM                               - disabled
      system.adapter.deconz.0                 : deconz                : ioBrokerVM                               - disabled, port: 8090
      system.adapter.device-reminder.0        : device-reminder       : ioBrokerVM                               - disabled
      system.adapter.discovery.0              : discovery             : ioBrokerVM                               - disabled
      system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : ioBrokerVM                               - disabled
      system.adapter.enigma2.0                : enigma2               : ioBrokerVM                               - disabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBrokerVM                               - disabled
      system.adapter.fiat.0                   : fiat                  : ioBrokerVM                               - disabled
      system.adapter.flot.0                   : flot                  : ioBrokerVM                               - disabled
      system.adapter.fullybrowser.0           : fullybrowser          : ioBrokerVM                               - disabled
      system.adapter.go-e.0                   : go-e                  : ioBrokerVM                               - disabled
      system.adapter.go-e.1                   : go-e                  : ioBrokerVM                               - disabled
      system.adapter.ham.0                    : ham                   : ioBrokerVM                               - disabled
      system.adapter.harmony.0                : harmony               : ioBrokerVM                               - disabled
      system.adapter.hue-extended.0           : hue-extended          : ioBrokerVM                               - disabled
      system.adapter.hue.0                    : hue                   : ioBrokerVM                               - disabled, port: 443
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBrokerVM                               - disabled
      system.adapter.influxdb.0               : influxdb              : ioBrokerVM                               - disabled, port: 8086
      system.adapter.info.0                   : info                  : ioBrokerVM                               - disabled
      system.adapter.iot.0                    : iot                   : ioBrokerVM                               - disabled
      system.adapter.javascript.0             : javascript            : ioBrokerVM                               - disabled
      system.adapter.meross.0                 : meross                : ioBrokerVM                               - disabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBrokerVM                               - disabled, port: 54321
      system.adapter.mihome-vacuum.2          : mihome-vacuum         : ioBrokerVM                               - disabled, port: 54321
      system.adapter.mobile.0                 : mobile                : ioBrokerVM                               - disabled
      system.adapter.openweathermap.0         : openweathermap        : ioBrokerVM                               - disabled
      system.adapter.pi-hole.0                : pi-hole               : ioBrokerVM                               - disabled
      system.adapter.pushover.0               : pushover              : ioBrokerVM                               - disabled
      system.adapter.pvforecast.0             : pvforecast            : ioBrokerVM                               - disabled
      system.adapter.radar2.0                 : radar2                : ioBrokerVM                               - disabled
      system.adapter.shelly.0                 : shelly                : ioBrokerVM                               - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.shelly.1                 : shelly                : ioBrokerVM                               - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.smartcontrol.0           : smartcontrol          : ioBrokerVM                               - disabled
      system.adapter.socketio.0               : socketio              : ioBrokerVM                               - disabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.sonoff.0                 : sonoff                : ioBrokerVM                               - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.tado.0                   : tado                  : ioBrokerVM                               - disabled
      system.adapter.telegram.0               : telegram              : ioBrokerVM                               - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.tibberlink.0             : tibberlink            : ioBrokerVM                               - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBrokerVM                               - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBrokerVM                               - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBrokerVM                               - disabled
      system.adapter.vis-metro.0              : vis-metro             : ioBrokerVM                               - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBrokerVM                               - disabled
      system.adapter.vis.0                    : vis                   : ioBrokerVM                               - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : ioBrokerVM                               - disabled
      system.adapter.web.0                    : web                   : ioBrokerVM                               - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.worx.0                   : worx                  : ioBrokerVM                               - disabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://iobroker.live/repo/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.12.0   , installed 6.8.0  [Updatable]
    Adapter    "alarm"        : 3.4.0    , installed 3.3.13 [Updatable]
    Adapter    "alexa2"       : 3.25.2   , installed 3.23.2 [Updatable]
    Adapter    "backitup"     : 2.8.7    , installed 2.8.1  [Updatable]
    Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "device-reminder": 3.0.0  , installed 1.2.9  [Updatable]
    Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "fiat"         : 0.0.8    , installed 0.0.8
    Adapter    "fullybrowser" : 2.2.0    , installed 2.1.2  [Updatable]
    Adapter    "go-e"         : 1.0.27   , installed 1.0.27
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "hue"          : 3.10.1   , installed 3.10.0 [Updatable]
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "meross"       : 1.15.1   , installed 1.15.1
    Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "pvforecast"   : 2.9.0    , installed 2.8.1  [Updatable]
    Adapter    "radar2"       : 2.0.8    , installed 2.0.7  [Updatable]
    Adapter    "shelly"       : 6.6.1    , installed 6.4.1  [Updatable]
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Copy text starting here:
                            v.2023-10-10
             Chassis: vm 🖴
      Virtualization: kvm
    Installation:           kvm
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1002
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    16
    Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
    Recommended versions are nodejs 18.18.2 and npm 9.8.1
    MEMORY:
    Mem:            4.1G        418M        3.4G        512K        590M        3.7G
    Swap:           1.0G          0B        1.0G
    Total:          5.1G        418M        4.4G
    Active iob-Instances:   1
    ioBroker Core:          js-controller           5.0.12
                            admin                   6.8.0
    ioBroker Status:        iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects:                32918
    States:                 20853
    Size of iob-Database:
    35M     /opt/iobroker/iobroker-data/objects.jsonl
    4.9M    /opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    crunchipC Offline
    crunchipC Offline
    #153
    @gismoh sagte in ioBroker auf neuer Maschine aufgesetzt und Adapter Probleme:
    Fährst du noch all diese alten versionen auf dem alten System?
    Edit
    Vllt mal dein altes system auf stand bringen.
    Update's..
    iob fix
    Und dann ein backup ziehen
    Und dann die Ausgabe von iob diag nochmal
    G 1 Antwort Letzte Antwort
      Edit
      Update's..
      iob fix
      Gismoh
      #154
      @crunchip
      okay - werd ich versuchen.
      hatte die alte maschine nicht mehr weiter geupdated, da ich vor kurzer Zeit mal den Admin geupdatet hatte, und dann iob "Tot" war, ich also keinen zugriff mehr hatte. Aber in der Zwischenzeit bin ich dort auf Bullseye hoch gegangen.
      Werd ich mich also nachher noch mal ranmachen ;)
      ioBroker auf: Lenovo ThinkCentre M910Q Tiny i5-7500T 16 GB mit proxmox in VM (Bookworm)
      • G Gismoh
        @crunchip
        crunchipC Offline
        crunchipC Offline
        #155
        Das zeigt dir dann auch der diag an
        G 2 Antworten Letzte Antwort
          Gismoh
          schrieb am zuletzt editiert von Gismoh
          #156
          @crunchip
          Mist - vorhin aufgefallen, der iobroker im Docker läuft noch auf Buster.
          War mir sicher, das ich geupdatet hätte .... hatte wohl nur den Pi an sich auf Bullseye gebracht aber nicht den iobroker-container 😕
          Hoffe das klappt auch.
          Zumindest habe ich den ioBroker selber und den Adaptern nun updates verpasst.
            Gismoh
            #157
            @crunchip
            das Ergebnis vom (alten) Pi:
                                    v.2023-10-10
            /home/iobroker/.diag.sh: line 457: hostnamectl: command not found
            Installation:
            Kernel:                 armv7l
            Userland:               armhf
            /home/iobroker/.diag.sh: line 466: timedatectl: command not found
            Timezone:
            User-ID:                1001
            X-Server:               false
            /home/iobroker/.diag.sh: line 473: systemctl: command not found
            Boot Target:
            Pending OS-Updates:     60
            error: failed switching to "iobroker": operation not permitted
            Pending iob updates:    0
            Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                    /usr/bin/node           v18.17.1
                                    /usr/bin/npm            9.6.7
                                    /usr/bin/npx            9.6.7
                                    /usr/bin/corepack       0.18.0
            Recommended versions are nodejs  and npm
            MEMORY:
            Mem:           7.9G        1.9G        4.9G        1.0M        1.1G        5.8G
            Swap:           99M          0B         99M
            Total:         8.0G        1.9G        5.0G
            Active iob-Instances:   0
                                    admin
            ioBroker Status:
            Objects:                0
            States:                 0
            40M     /opt/iobroker/iobroker-data/objects.jsonl
            17M     /opt/iobroker/iobroker-data/objects.json.migrated
            17M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
            16K     /opt/iobroker/iobroker-data/objects.json.old
            31M     /opt/iobroker/iobroker-data/states.jsonl
            2.3M    /opt/iobroker/iobroker-data/states.json.migrated
            2.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
            2.0M    /opt/iobroker/iobroker-data/states.json.old
            • G Gismoh
              @crunchip
                                      v.2023-10-10
              Installation:
              Kernel:                 armv7l
              Userland:               armhf
              Timezone:
              User-ID:                1001
              X-Server:               false
              Boot Target:
                                      /usr/bin/npm            9.6.7
                                      /usr/bin/npx            9.6.7
              MEMORY:
              Swap:           99M          0B         99M
                                      admin
              ioBroker Status:
              Objects:                0
              States:                 0
              #158
              @gismoh
              Der muss aber sehr alt sein, wenn die Kommandos da gar nicht funktionieren.
                @gismoh
                Gismoh
                #159
                leider, ich gelobe Besserung.
                Hatte wohl meist nur die iob updates gemacht -.-
                bei
                sudo apt update
                spuckt er mir direkt eine Fehlermeldung wegen eines key´s raus.
                idash@raspberrypi:/opt/iobroker$ sudo apt update
                [sudo] password for idash:
                Hit:1 http://security.debian.org/debian-security buster/updates InRelease
                Hit:2 http://deb.debian.org/debian buster InRelease
                Hit:3 http://deb.debian.org/debian buster-updates InRelease
                Get:4 https://repos.influxdata.com/debian buster InRelease [7.047 B]
                Get:5 https://deb.nodesource.com/node_18.x buster InRelease [4.584 B]
                Err:4 https://repos.influxdata.com/debian buster InRelease
                  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                Fetched 11,6 kB in 2s (5.507 B/s)
                Reading package lists... Done
                Building dependency tree
                60 packages can be upgraded. Run 'apt list --upgradable' to see them.
                W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                W: Some index files failed to download. They have been ignored, or old ones used instead.
                Daher ersteinmal nicht weiter gemacht.
                • G Gismoh
                  bei
                  sudo apt update
                  crunchipC Offline
                  crunchipC Offline
                  #160
                  Findest du Anleitung auf Thomas Profil
                  Oder du kommentierst sie einfach aus in der repo list, brauchst ja eigentlich nimmer. Dann würden zumindest die updates für buster durchlaufen
                  Allerdings sieht deine Ausgabe von diag nicht gerade prickelnd aus
                    Gismoh
                    #161
                    @crunchip
                    die Anleitung auf Bullyseye hatte ich mir abgespeichert, hatte damit ja den Pi direkt gemacht xD
                    Aber wo finde ich diese Reprolist zum auskommentieren?
                    ah, evtl. mit der "apt list"
                    • G Gismoh
                      @crunchip
                      #162
                      Lösch einfach die entsprechende Datei aus
                      /etc/apt/sources.list.d/ heraus. Heißt influx...
                        Gismoh
                        #163
                        konnte noch eben den key erneuern - war für mich einfacher.
                          Gismoh
                          #164
                          Frage: beim upgrade von buster auf bullseye, aus deiner Anleitung:
                          sudo nano /etc/systemd/system/dhcpcd.service.d/wait.conf
                          Die Datei gibt es bei mir anscheinen nicht.
                          Mein "Ergebnis" sieht so aus:
                          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                          Hit:2 http://deb.debian.org/debian bullseye InRelease
                          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                          Hit:4 https://repos.influxdata.com/debian stable InRelease
                          Hit:5 https://repos.influxdata.com/debian bullseye InRelease
                          Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
                          All packages are up to date.
                          • G Gismoh
                            #165
                            Muss es ja auch nicht. Der Part ist doch nur optional bei Problemen, wenn ich mich recht entsinne.
                            Influxdb ist allerdings doppelt angelegt.
                            Und nodesource ist nicht um aktuellen Format.
                              Gismoh
                              #166
                              okay, super & Merci.
                              Dann mache ich mal weiter ;)
                              Edit: Muss ich bei der Influx noch was machen, irgendwie eine löschen?
                              Ist ja die Maschine, welche abgelöst werden soll.
                              Nach nodesoure suche ich dann. (evtl. in deinem Footer)
                              • G Gismoh
                                #167
                                iob nodejs-update
                                richtet das.
                                  iob nodejs-update
                                  richtet das.
                                  Gismoh
                                  #168
                                  @thomas-braun merci
                                    @gismoh zeig mal die Ausgabe
                                    iob diag
                                    von beiden Systemen, Raspberry und Vm
                                    Gismoh
                                    #169
                                    @crunchip
                                    die Ausgabe von iob diag vom Raspi:
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                    /home/iobroker/.diag.sh: line 63: hostnamectl: command not found
                                    Model           : Raspberry Pi 4 Model B Rev 1.4
                                    Docker          : false
                                    Virtualization  : Docker
                                    Kernel          : armv7l
                                    Userland        : armhf
                                     20:12:13 up 20:35,  0 users,  load average: 1.81, 1.87, 1.93
                                    CPU threads: 4
                                    /home/iobroker/.diag.sh: line 188: timedatectl: command not found
                                    idash
                                    /home/idash
                                    idash adm dialout sudo plugdev input iobroker
                                    X-Server:       false
                                    Desktop:
                                    Terminal:
                                    /home/iobroker/.diag.sh: line 211: systemctl: command not found
                                    Boot Target:
                                    *** MEMORY ***
                                    Mem:            7.9G        2.0G        3.6G        1.0M        2.3G        5.7G
                                    Swap:            99M          0B         99M
                                    Total:          8.0G        2.0G        3.7G
                                             7898 M total memory
                                             1955 M used memory
                                              591 M active memory
                                             3477 M inactive memory
                                             3593 M free memory
                                              227 M buffer memory
                                             2121 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    /home/iobroker/.diag.sh: line 232: systemctl: command not found
                                    *** FILESYSTEM ***
                                    Filesystem     Type     Size  Used Avail Use% Mounted on
                                    overlay        overlay   59G   44G   13G  78% /
                                    tmpfs          tmpfs     64M     0   64M   0% /dev
                                    shm            tmpfs     64M     0   64M   0% /dev/shm
                                    /dev/root      ext4      59G   44G   13G  78% /etc/influxdb
                                    tmpfs          tmpfs    3.9G     0  3.9G   0% /proc/asound
                                    tmpfs          tmpfs    3.9G     0  3.9G   0% /sys/firmware
                                    dmesg: read kernel buffer failed: Operation not permitted
                                    /etc/influxdb     /dev/root[/home/pi/influxdb/etc]        ext4   rw,noatime
                                    /opt/iobroker     /dev/root[/home/pi/iobroker]        ext4   rw,noatime
                                    /etc/resolv.conf  /dev/root[/var/lib/docker/containers/44cf01325e4af5b67c1ceefebfdd8ba53b8d1413acb411091f6e943bb11cf1cc/resolv.conf] ext4   rw,noatime
                                    /etc/hostname     /dev/root[/var/lib/docker/containers/44cf01325e4af5b67c1ceefebfdd8ba53b8d1413acb411091f6e943bb11cf1cc/hostname]    ext4   rw,noatime
                                    /etc/hosts        /dev/root[/var/lib/docker/containers/44cf01325e4af5b67c1ceefebfdd8ba53b8d1413acb411091f6e943bb11cf1cc/hosts]       ext4   rw,noatime
                                    /var/lib/influxdb /dev/root[/home/pi/influxdb/database]        ext4   rw,noatime
                                    /var:
                                    27G     /var/log/influxdb
                                    27G     /var/log
                                    27G     /var/
                                    563M    /var/lib
                                    532M    /var/lib/influxdb
                                    /home/iobroker/.diag.sh: line 256: journalctl: command not found
                                    4.6G    /opt/iobroker/backups/
                                    460M    /opt/iobroker/iobroker-data/
                                    216M    /opt/iobroker/iobroker-data/files
                                    117M    /opt/iobroker/iobroker-data/backup-objects
                                    43M     /opt/iobroker/iobroker-data/files/iot.admin
                                    56M     /opt/iobroker/iobroker-data/states.jsonl
                                    33M     /opt/iobroker/iobroker-data/objects.jsonl
                                    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                                    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                                    USB-Devices by-id:
                                    /usr/bin/npm            9.8.1
                                    /usr/bin/npx            9.8.1
                                    nodejs:
                                      Version table:
                                     *** 18.18.2-1nodesource1 1001
                                            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                         18.18.1-1nodesource1 1001
                                         18.18.0-1nodesource1 1001
                                         18.17.1-1nodesource1 1001
                                         18.17.0-1nodesource1 1001
                                         18.16.1-1nodesource1 1001
                                         18.16.0-1nodesource1 1001
                                         18.15.0-1nodesource1 1001
                                         18.14.2-1nodesource1 1001
                                         18.14.1-1nodesource1 1001
                                         18.14.0-1nodesource1 1001
                                         18.13.0-1nodesource1 1001
                                         18.12.0-1nodesource1 1001
                                         18.11.0-1nodesource1 1001
                                         18.10.0-1nodesource1 1001
                                         18.9.1-1nodesource1 1001
                                         18.9.0-1nodesource1 1001
                                         18.8.0-1nodesource1 1001
                                         18.7.0-1nodesource1 1001
                                         18.6.0-1nodesource1 1001
                                         18.5.0-1nodesource1 1001
                                         18.4.0-1nodesource1 1001
                                         18.3.0-1nodesource1 1001
                                         18.2.0-1nodesource1 1001
                                         18.1.0-1nodesource1 1001
                                         18.0.0-1nodesource1 1001
                                         12.22.12~dfsg-1~deb11u4 500
                                            500 http://deb.debian.org/debian bullseye/main armhf Packages
                                            500 http://security.debian.org/debian-security bullseye-security/main armhf Packages
                                    Errors in npm tree:
                                    ioBroker Status
                                    js-controller:
                                    admin:
                                    javascript:
                                    Adapter State
                                    Objects and States
                                    Objects:        0
                                    States:         0
                                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                                    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                                    Pending Updates: 0
                                    *** Listening Ports ***
                                    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          15514      -
                                    tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      0          15008      -
                                    tcp        0      0 127.0.0.1:8085          0.0.0.0:*               LISTEN      999        2436546    -
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14375      -
                                    tcp        0      0 0.0.0.0:8088            0.0.0.0:*               LISTEN      1000       18530      -
                                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       2441321    -
                                    tcp        0      0 0.0.0.0:8090            0.0.0.0:*               LISTEN      1000       18488      -
                                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       2440287    -
                                    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          11086      -
                                    tcp        0      0 0.0.0.0:8000            0.0.0.0:*               LISTEN      0          14150      -
                                    tcp        0      0 0.0.0.0:9443            0.0.0.0:*               LISTEN      0          11047      -
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       2438513    -
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       2436579    -
                                    tcp6       0      0 :::80                   :::*                    LISTEN      0          15519      -
                                    tcp6       0      0 :::8080                 :::*                    LISTEN      0          11055      -
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       2436746    -
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       2441021    -
                                    tcp6       0      0 :::8084                 :::*                    LISTEN      1000       2441982    -
                                    tcp6       0      0 :::8086                 :::*                    LISTEN      999        2438510    -
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          11950      -
                                    tcp6       0      0 :::3000                 :::*                    LISTEN      472        16567      -
                                    tcp6       0      0 :::443                  :::*                    LISTEN      0          15028      -
                                    tcp6       0      0 :::8000                 :::*                    LISTEN      0          11093      -
                                    tcp6       0      0 :::9443                 :::*                    LISTEN      0          15468      -
                                    tcp6       0      0 :::61991                :::*                    LISTEN      1000       2443739    -
                                    udp        0      0 0.0.0.0:33747           0.0.0.0:*                           108        10203      -
                                    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       2443740    -
                                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       2438877    -
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12019      -
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10201      -
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       2441396    -
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       2441394    -
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       2441391    -
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       2441389    -
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       2441387    -
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       2441383    -
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       17582      -
                                    udp6       0      0 :::546                  :::*                                0          14461      -
                                    udp6       0      0 :::45780                :::*                                108        10204      -
                                    udp6       0      0 :::5353                 :::*                                108        10202      -
                                    udp6       0      0 :::1900                 :::*                                1000       2441397    -
                                    udp6       0      0 :::1900                 :::*                                1000       2441395    -
                                    udp6       0      0 :::1900                 :::*                                1000       2441393    -
                                    udp6       0      0 :::1900                 :::*                                1000       2441392    -
                                    udp6       0      0 :::1900                 :::*                                1000       2441390    -
                                    udp6       0      0 :::1900                 :::*                                1000       2441388    -
                                    udp6       0      0 :::1900                 :::*                                1000       2441386    -
                                    udp6       0      0 :::1900                 :::*                                1000       2441385    -
                                    2023-11-10 20:12:13.836  - warn: sonoff.0 (265) Client [Tasmota1] has invalid password or username
                                    2023-11-10 20:12:15.115  - warn: sonoff.0 (265) Client [TasmotaL2USB] has invalid password or username
                                    2023-11-10 20:12:15.781  - warn: sonoff.0 (265) Client [Tasmota16] has invalid password or username
                                    2023-11-10 20:12:15.847  - warn: sonoff.0 (265) Client [Tasmota9] has invalid password or username
                                    2023-11-10 20:12:16.960  - warn: sonoff.0 (265) Client [Tasmota11] has invalid password or username
                                    2023-11-10 20:12:21.471  - warn: sonoff.0 (265) Client [Tasmota8Twin_14133E] has invalid password or username
                                    2023-11-10 20:12:21.747  - warn: sonoff.0 (265) Client [Tasmota3USB] has invalid password or username
                                    2023-11-10 20:12:22.236  - warn: sonoff.0 (265) Client [Tasmota12] has invalid password or username
                                    2023-11-10 20:12:25.300  - warn: sonoff.0 (265) Client [TasmotaL1USB] has invalid password or username
                                    2023-11-10 20:12:26.508  - warn: sonoff.0 (265) Client [Tasmota2USB] has invalid password or username
                                    2023-11-10 20:12:29.406  - warn: sonoff.0 (265) Client [Tasmota5USB] has invalid password or username
                                    2023-11-10 20:12:34.992  - warn: sonoff.0 (265) Client [Tasmota7Twin_1449B7] has invalid password or username
                                    2023-11-10 20:12:35.263  - warn: sonoff.0 (265) Client [Tasmota4USB] has invalid password or username
                                    2023-11-10 20:12:36.027  - warn: sonoff.0 (265) Client [Tasmota6] has invalid password or username
                                    2023-11-10 20:12:36.798  - warn: sonoff.0 (265) Client [Tasmota10] has invalid password or username
                                    2023-11-10 20:12:39.605  - warn: sonoff.0 (265) Client [Tasmota1] has invalid password or username
                                    2023-11-10 20:12:40.942  - warn: sonoff.0 (265) Client [TasmotaL2USB] has invalid password or username
                                    2023-11-10 20:12:41.635  - warn: sonoff.0 (265) Client [Tasmota9] has invalid password or username
                                    2023-11-10 20:12:42.734  - warn: sonoff.0 (265) Client [Tasmota11] has invalid password or username
                                    2023-11-10 20:12:47.294  - warn: sonoff.0 (265) Client [Tasmota8Twin_14133E] has invalid password or username
                                    2023-11-10 20:12:47.582  - warn: sonoff.0 (265) Client [Tasmota3USB] has invalid password or username
                                    2023-11-10 20:12:48.060  - warn: sonoff.0 (265) Client [Tasmota12] has invalid password or username
                                    2023-11-10 20:12:51.164  - warn: sonoff.0 (265) Client [TasmotaL1USB] has invalid password or username
                                    2023-11-10 20:12:52.303  - warn: sonoff.0 (265) Client [Tasmota2USB] has invalid password or username
                                    2023-11-10 20:12:55.186  - warn: sonoff.0 (265) Client [Tasmota5USB] has invalid password or username
                                    iob diag has finished.
                                    Press any key for a summary
                                                            v.2023-10-10
                                    Installation:
                                    Kernel:                 armv7l
                                    Userland:               armhf
                                    Timezone:
                                    User-ID:                1001
                                    X-Server:               false
                                    Boot Target:
                                                            /usr/bin/npm            9.8.1
                                                            /usr/bin/npx            9.8.1
                                    MEMORY:
                                    Swap:            99M          0B         99M
                                                            admin
                                    ioBroker Status:
                                    Objects:                0
                                    States:                 0
                                    34M     /opt/iobroker/iobroker-data/objects.jsonl
                                    7.0M    /opt/iobroker/iobroker-data/states.jsonl
                                    • G Gismoh
                                      @crunchip
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                      Docker          : false
                                      Kernel          : armv7l
                                      Userland        : armhf
                                      CPU threads: 4
                                      idash
                                      /home/idash
                                      X-Server:       false
                                      Desktop:
                                      Terminal:
                                      Boot Target:
                                      *** MEMORY ***
                                      Swap:            99M          0B         99M
                                               7898 M total memory
                                               1955 M used memory
                                                591 M active memory
                                               3593 M free memory
                                                227 M buffer memory
                                               2121 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      *** FILESYSTEM ***
                                      /var:
                                      27G     /var/log
                                      27G     /var/
                                      563M    /var/lib
                                      USB-Devices by-id:
                                      /usr/bin/npm            9.8.1
                                      /usr/bin/npx            9.8.1
                                      nodejs:
                                        Version table:
                                      Errors in npm tree:
                                      ioBroker Status
                                      js-controller:
                                      admin:
                                      javascript:
                                      Adapter State
                                      Objects and States
                                      Objects:        0
                                      States:         0
                                      Pending Updates: 0
                                                              v.2023-10-10
                                      Installation:
                                      Kernel:                 armv7l
                                      Userland:               armhf
                                      Timezone:
                                      User-ID:                1001
                                      X-Server:               false
                                      Boot Target:
                                                              /usr/bin/npm            9.8.1
                                                              /usr/bin/npx            9.8.1
                                      MEMORY:
                                      Swap:            99M          0B         99M
                                                              admin
                                      ioBroker Status:
                                      Objects:                0
                                      States:                 0
                                      #170
                                      @gismoh
                                      Welche Distribution läuft denn da?
                                      cat /etc/debian_version
                                        @gismoh
                                        Gismoh
                                        #171
                                        idash@raspberrypi:/opt/iobroker$ cat /etc/debian_version
                                        11.8
                                        • G Gismoh
                                          11.8
                                          #172
                                          @gismoh
                                          Da stimmt doch was hinten und vorne nicht...
                                          sudo systemctl  daemon-reload
