  4. Test Adapter Traccar v0.0.x
    6.4k
adaptertesttraccar
88 Beiträge 15 Kommentatoren 14.8k Aufrufe 14 Beobachtet
  • liv-in-skyL liv-in-sky
    @arteck
    moin moin,
    habe jetzt erstmal alles vorbereitet (clients umgestellt,...) um deine neue version zu testen - werde nachher mal eine testfahrt machen um dir feedback zu geben.
    was aber jetzt schon sichtbar ist, ist folgende meldung: kommt bei all diesen datenpunkten - habe alle dp gelöscht und neu anlegen lassen
    traccar.1
    2023-10-28 05:58:59.061	info	State value to set for "traccar.1.geofences.6.last_update" has to be type "string" but received type "number"
    traccar.1
    2023-10-28 05:58:59.060	info	State value to set for "traccar.1.geofences.5.last_update" has to be type "string" but received type "number"
    traccar.1
    2023-10-28 05:58:59.060	info	State value to set for "traccar.1.geofences.4.last_update" has to be type "string" but received type "number"
    traccar.1
    2023-10-28 05:58:59.060	info	State value to set for "traccar.1.geofences.3.last_update" has to be type "string" but received type "number"
    traccar.1
    2023-10-28 05:58:59.059	info	State value to set for "traccar.1.geofences.2.last_update" has to be type "string" but received type "number"
    traccar.1
    2023-10-28 05:58:59.059	info	State value to set for "traccar.1.devices.2.last_update" has to be type "string" but received type "number"
    traccar.1
    2023-10-28 05:58:59.059	info	State value to set for "traccar.1.devices.3.last_update" has to be type "string" but received type "number"
    traccar.1
    2023-10-28 05:58:59.058	info	State value to set for "traccar.1.devices.2.last_update" has to be type "string" but received type "number"
    traccar.1
    2023-10-28 05:58:59.050	info	State value to set for "traccar.1.devices.1.last_update" has to be type "string" but received type "number"
    traccar.1
    2023-10-28 05:58:58.755	info	Connect to server over websocket connection.
    traccar.1
    2023-10-28 05:58:58.549	info	starting. Version 1.1.3 (non-npm: arteck/ioBroker.traccar#b51ac9173cba2d182177d0742dce731caaf57eda) in /opt/iobroker/node_modules/iobroker.traccar, node: v18.17.1, js-controller: 5.0.12
    traccar.0
    2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.37.last_update" has to be type "string" but received type "number"
    traccar.0
    2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.36.last_update" has to be type "string" but received type "number"
    traccar.0
    2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.35.last_update" has to be type "string" but received type "number"
    traccar.0
    2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.34.last_update" has to be type "string" but received type "number"
    traccar.0
    2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.33.last_update" has to be type "string" but received type "number"
    traccar.0
    2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.32.last_update" has to be type "string" but received type "number"
    traccar.0
    2023-10-28 05:58:58.461	info	State value to set for "traccar.0.geofences.30.last_update" has to be type "string" but received type "number"
    traccar.0
    2023-10-28 05:58:58.433	info	State value to set for "traccar.0.geofences.29.last_update" has to be type "string" but received type "number"
    traccar.0
    2023-10-28 05:58:58.433	info	State value to set for "traccar.0.geofences.28.last_update" has to be type "string" but received type "number"
    arteckA Offline
    arteckA Offline
    arteck
    @liv-in-sky jo korrigiert..komisch dass du die meldung bekommst und ich nicht..
    M liv-in-skyL 2 Antworten Letzte Antwort
    • arteckA arteck
      MartyBr
      @arteck Ich habe gestern auch den Adapter installiert. Er liefert auch Werte von dem Traccar-Server.
      Ich habe eine Frage zu dem Adapter. Wo sehe ich die Änderungen? In Github sehe ich keine aktuellen Zeiten. Wie kann ich die neue Version installieren? Latest oder per Github?
      Martin
      Homematic und Homematic IP
      • arteckA arteck
        liv-in-skyL Offline
        liv-in-skyL Offline
        @arteck bin noch am testen - sieht ganz gut aus - leider wird die total_distance hochgezählt, obwohl ich gerade daheim stehe - ist kein adapter thema - liegt wohl am handy - suche gerade lösung
        State value to set for "traccar.1.geofences.26.last_update" has to be type "string" but received type "number"
        die meldung verstehe ich eh nicht - da steht ein datum drin - kein timestamp - ist aber immer noch da
          arteckA Offline
          arteckA Offline
          arteck
          @liv-in-sky ja musst du den DP mal löschen..
          • M MartyBr
            arteckA Offline
            arteckA Offline
            arteck
            @martybr erstmal nur bei mir https://github.com/arteck/ioBroker.traccar
            • arteckA arteck
              liv-in-skyL Offline
              liv-in-skyL Offline
              @arteck wie oben erwähnt - hatte ich schon gemacht
                arteckA Offline
                arteckA Offline
                arteck
                @liv-in-sky ach seh ich erst jetzt.. ist er andere DP.. jetzt nochmal von GIT
                die total_distance kommt vom Server da rechnen wir nix
                liv-in-skyL 3 Antworten Letzte Antwort
                • arteckA arteck
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  @arteck sagte in Test Adapter Traccar v0.0.x:
                  total_distance
                  ja - ich weiß - konte das über eine einstellung beenden
                  <entry key='filter.distance'>20</entry>
                   <entry key='filter.enable'>true</entry>
                  • arteckA arteck
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    jetzt is es weg - mercy
                    • arteckA arteck
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      @arteck
                      also momentan sieht es ganz gut aus - der letzte fahrtest und mein script hat seine aufgabe erfüllt
                      vielen dank, dass du dir die zeit genommen hast - werde ab montag weiter beobachten , wenn wieder "on-tour"
                      so sieht die history aus für geofencies:
                      also keine andauernden updates auf diesen dp :-)
                        @arteck
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @liv-in-sky das klingt doch schon mal gut.. ich schieb es mal ins normal repo
                        • BananaJoeB Online
                          BananaJoeB Online
                          BananaJoe
                          Ich bin gerade dabei mich darin einzuarbeiten.
                          Es gibt ja einen Datenpunkt in dem steht innerhalb welches Geofencing das Gerät sich befindet:
                          traccar.0.devices.1.geofences_string
                          Da steht bei mir nun z.B. Wohnort drin.
                          Meine Tochter bewegt sich nun schon zum 3 Geofence und unter Ihrem Gerät ändert sich nichts, also am
                          Umgekehrt sollte wohl bei den Geofences stehen wer gerade dort ist:
                          Aber dort habe ich auch nie etwas gesehen.
                          Muss ich auf der Traccar-Seite noch etwas einstellen?
                          Danke!
                          • BananaJoeB BananaJoe
                            Danke!
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            @bananajoe du musst im traccar server das geofence definieren und dann beim benutzer (handy) dieses geofence noch auswählen
                            also die geofencies müssen auch dem handy zugewiesen werden
                              BananaJoeB Online
                              BananaJoeB Online
                              BananaJoe
                              @liv-in-sky ah, ok, den Geofence "Wohnort" hatte ich aus dem Kontext meines Gerätes erstellt, deshalb war der gleich zugeordnet.
                              Jetzt habe ich den Dialog an den Geräten gefunden, Danke!
                              • N Offline
                                N Offline
                                navlis
                                Hallo ihr,
                                Ich habe heute nacht mal den Tracccar server installiert und mein handy darin aufgenommen soweit so gut 👍
                                Dann wollte ich den adapter verbinden, klappte auch.
                                Aber ich erhalte keine Daten die zwei Zonen die ich angelegt habe so wie mein Handy nix kommt im adapter an ?
                                Gibbet da nen geheimen Trick den ich net kenne oder bin ich erstmal zu doof 😅🫣
                                Server und adapter sind die neueste Version
                                Hoffe auf eure Hilfe
                                LG
                                Silvan
                                crunchipC liv-in-skyL 2 Antworten Letzte Antwort
                                • N navlis
                                  Hallo ihr,
                                  LG
                                  Silvan
                                  crunchipC Offline
                                  crunchipC Offline
                                  @navlis sagte in Test Adapter Traccar v0.0.x:
                                  also Verbindung steht?
                                  Server sowie Handy aktiv?
                                  welche Daten kamen an und welche fehlen?
                                  N 1 Antwort Letzte Antwort
                                  • N navlis
                                    Hallo ihr,
                                    LG
                                    Silvan
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    @navlis hast du die 3 Posts über dir gelesen
                                      N Offline
                                      N Offline
                                      navlis
                                      @crunchip der Server läuft da sehe ich mein Handy und auch positions Veränderungen so wie akku Stand.
                                      Der adapter sagt er ist verbunden aber ich habe keine Daten die ankommen die Ordner bleiben leer
                                      Danke für die schnelle Antwort 😉
                                      Screenshot_20240107_160650_Chrome.jpg Screenshot_20240107_160730_Chrome.jpg Screenshot_20240107_160836_Chrome.jpg
                                        N Offline
                                        N Offline
                                        navlis
                                        schrieb am zuletzt editiert von navlis
                                        @liv-in-sky ja allerdings stehe ich langsam aufm Schlauch 🫣 ich verstehe nur Bahnhof 😅
                                        Ich gelobe Besserung in der App bei mir kann ich keine berreiche zuordnen ?
                                        • N Offline
                                          N Offline
                                          navlis
                                          Hey ho ich schon wieder keine ahnung was ich gemacht habe darin bin ich am besten jetzt funktioniert alles wie es soll 😅🫣
