  4. Test Adapter Traccar v0.0.x
    6.4k
adaptertesttraccar
88 Beiträge 15 Kommentatoren 14.8k Aufrufe 14 Beobachtet
  • M ManfredHi
    @idlebit
    Hallo. Mit dem neuen Traccar Server 5.2 dürft es ein Problem mit iobroker geben, da der Adapter nicht mehr richtig startet.
    Laut traccar-Entwickler dürfte das am iobroker liegen.
    Der Fehler im Log-File:
    traccar.0
    2022-07-20 08:15:45.170    info    Connect to server over websocket connection.
    traccar.0
    2022-07-20 08:15:45.162    error    device.geofenceIds is not iterable
    traccar.0
    2022-07-20 08:15:45.162    error    TypeError: device.geofenceIds is not iterable at Traccar.getGeofencesState (/opt/iobroker/node_modules/iobroker.traccar/main.js:273:41) at Traccar.processData (/opt/iobroker/node_modules/iobroker.traccar/main.js:195:47) at Traccar.getTraccarDataOverAPI (/opt/iobroker/node_modules/iobroker.traccar/main.js:268:14) at processTicksAndRejections (node:internal/process/task_queues:96:5) at async Traccar.onReady (/opt/iobroker/node_modules/iobroker.traccar/main.js:61:13)
    traccar.0
    2022-07-20 08:15:45.161    error    unhandled promise rejection: device.geofenceIds is not iterable
    traccar.0
    2022-07-20 08:15:45.160    error    Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    traccar.0
    2022-07-20 08:15:45.027    info    starting. Version 0.0.11 (non-npm: o0shojo0o/ioBroker.traccar) in /opt/iobroker/node_modules/iobroker.traccar, node: v16.15.1, js-controller: 4.0.23
    Hier noch der Link zum traccar-Forums beitrag: https://www.traccar.org/forums/topic/iobroker-v51-geofence/#post-73205
    IdleBitI Offline
    IdleBitI Offline
    IdleBit
    @manfredh-1 teste mal die Gitversion -> https://github.com/o0shojo0o/ioBroker.traccar
    • IdleBitI IdleBit
      ManfredHi
      @idlebit said in Test Adapter Traccar v0.0.x:
      Super danke für die rasche Antwort. Die Gitversion funktioniert einwandfrei.
      Hat aber die selbe Versionsnummer.
      IdleBitI 1 Antwort Letzte Antwort
      • M ManfredHi
        IdleBitI Offline
        IdleBitI Offline
        IdleBit
        @manfredh-1 Ja das ist richtig da ich noch keine neue Version rausgeben habe, werde ich aber gleich nachholen ;)
        • liv-in-skyL Offline
          liv-in-skyL Offline
          @arteck
          moin moin,
          habe jetzt erstmal alles vorbereitet (clients umgestellt,...) um deine neue version zu testen - werde nachher mal eine testfahrt machen um dir feedback zu geben.
          was aber jetzt schon sichtbar ist, ist folgende meldung: kommt bei all diesen datenpunkten - habe alle dp gelöscht und neu anlegen lassen
          traccar.1
          2023-10-28 05:58:59.061	info	State value to set for "traccar.1.geofences.6.last_update" has to be type "string" but received type "number"
          traccar.1
          2023-10-28 05:58:59.060	info	State value to set for "traccar.1.geofences.5.last_update" has to be type "string" but received type "number"
          traccar.1
          2023-10-28 05:58:59.060	info	State value to set for "traccar.1.geofences.4.last_update" has to be type "string" but received type "number"
          traccar.1
          2023-10-28 05:58:59.060	info	State value to set for "traccar.1.geofences.3.last_update" has to be type "string" but received type "number"
          traccar.1
          2023-10-28 05:58:59.059	info	State value to set for "traccar.1.geofences.2.last_update" has to be type "string" but received type "number"
          traccar.1
          2023-10-28 05:58:59.059	info	State value to set for "traccar.1.devices.2.last_update" has to be type "string" but received type "number"
          traccar.1
          2023-10-28 05:58:59.059	info	State value to set for "traccar.1.devices.3.last_update" has to be type "string" but received type "number"
          traccar.1
          2023-10-28 05:58:59.058	info	State value to set for "traccar.1.devices.2.last_update" has to be type "string" but received type "number"
          traccar.1
          2023-10-28 05:58:59.050	info	State value to set for "traccar.1.devices.1.last_update" has to be type "string" but received type "number"
          traccar.1
          2023-10-28 05:58:58.755	info	Connect to server over websocket connection.
          traccar.1
          2023-10-28 05:58:58.549	info	starting. Version 1.1.3 (non-npm: arteck/ioBroker.traccar#b51ac9173cba2d182177d0742dce731caaf57eda) in /opt/iobroker/node_modules/iobroker.traccar, node: v18.17.1, js-controller: 5.0.12
          traccar.0
          2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.37.last_update" has to be type "string" but received type "number"
          traccar.0
          2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.36.last_update" has to be type "string" but received type "number"
          traccar.0
          2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.35.last_update" has to be type "string" but received type "number"
          traccar.0
          2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.34.last_update" has to be type "string" but received type "number"
          traccar.0
          2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.33.last_update" has to be type "string" but received type "number"
          traccar.0
          2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.32.last_update" has to be type "string" but received type "number"
          traccar.0
          2023-10-28 05:58:58.461	info	State value to set for "traccar.0.geofences.30.last_update" has to be type "string" but received type "number"
          traccar.0
          2023-10-28 05:58:58.433	info	State value to set for "traccar.0.geofences.29.last_update" has to be type "string" but received type "number"
          traccar.0
          2023-10-28 05:58:58.433	info	State value to set for "traccar.0.geofences.28.last_update" has to be type "string" but received type "number"
          • liv-in-skyL liv-in-sky
            @arteck
            moin moin,
            traccar.1
            traccar.1
            traccar.1
            traccar.1
            traccar.1
            traccar.1
            traccar.1
            traccar.1
            traccar.1
            traccar.1
            traccar.1
            traccar.0
            traccar.0
            traccar.0
            traccar.0
            traccar.0
            traccar.0
            traccar.0
            traccar.0
            traccar.0
            arteckA Offline
            arteckA Offline
            arteck
            @liv-in-sky jo korrigiert..komisch dass du die meldung bekommst und ich nicht..
            M liv-in-skyL 2 Antworten Letzte Antwort
            • arteckA arteck
              MartyBr
              @arteck Ich habe gestern auch den Adapter installiert. Er liefert auch Werte von dem Traccar-Server.
              Ich habe eine Frage zu dem Adapter. Wo sehe ich die Änderungen? In Github sehe ich keine aktuellen Zeiten. Wie kann ich die neue Version installieren? Latest oder per Github?
              Martin
              Homematic und Homematic IP
              • arteckA arteck
                liv-in-skyL Offline
                liv-in-skyL Offline
                @arteck bin noch am testen - sieht ganz gut aus - leider wird die total_distance hochgezählt, obwohl ich gerade daheim stehe - ist kein adapter thema - liegt wohl am handy - suche gerade lösung
                State value to set for "traccar.1.geofences.26.last_update" has to be type "string" but received type "number"
                die meldung verstehe ich eh nicht - da steht ein datum drin - kein timestamp - ist aber immer noch da
                  arteckA Offline
                  arteckA Offline
                  arteck
                  @liv-in-sky ja musst du den DP mal löschen..
                  • M MartyBr
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @martybr erstmal nur bei mir https://github.com/arteck/ioBroker.traccar
                    • arteckA arteck
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      @arteck wie oben erwähnt - hatte ich schon gemacht
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @liv-in-sky ach seh ich erst jetzt.. ist er andere DP.. jetzt nochmal von GIT
                        die total_distance kommt vom Server da rechnen wir nix
                        liv-in-skyL 3 Antworten Letzte Antwort
                        • arteckA arteck
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          @arteck sagte in Test Adapter Traccar v0.0.x:
                          total_distance
                          ja - ich weiß - konte das über eine einstellung beenden
                          <entry key='filter.distance'>20</entry>
                           <entry key='filter.enable'>true</entry>
                          • arteckA arteck
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            jetzt is es weg - mercy
                            • arteckA arteck
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              @arteck
                              also momentan sieht es ganz gut aus - der letzte fahrtest und mein script hat seine aufgabe erfüllt
                              vielen dank, dass du dir die zeit genommen hast - werde ab montag weiter beobachten , wenn wieder "on-tour"
                              so sieht die history aus für geofencies:
                              also keine andauernden updates auf diesen dp :-)
                                @arteck
                                arteckA Offline
                                arteckA Offline
                                arteck
                                @liv-in-sky das klingt doch schon mal gut.. ich schieb es mal ins normal repo
                                • BananaJoeB Online
                                  BananaJoeB Online
                                  BananaJoe
                                  Ich bin gerade dabei mich darin einzuarbeiten.
                                  Es gibt ja einen Datenpunkt in dem steht innerhalb welches Geofencing das Gerät sich befindet:
                                  traccar.0.devices.1.geofences_string
                                  Da steht bei mir nun z.B. Wohnort drin.
                                  Meine Tochter bewegt sich nun schon zum 3 Geofence und unter Ihrem Gerät ändert sich nichts, also am
                                  Umgekehrt sollte wohl bei den Geofences stehen wer gerade dort ist:
                                  Aber dort habe ich auch nie etwas gesehen.
                                  Muss ich auf der Traccar-Seite noch etwas einstellen?
                                  Danke!
                                  • BananaJoeB BananaJoe
                                    Danke!
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    @bananajoe du musst im traccar server das geofence definieren und dann beim benutzer (handy) dieses geofence noch auswählen
                                    also die geofencies müssen auch dem handy zugewiesen werden
                                      BananaJoeB Online
                                      BananaJoeB Online
                                      BananaJoe
                                      @liv-in-sky ah, ok, den Geofence "Wohnort" hatte ich aus dem Kontext meines Gerätes erstellt, deshalb war der gleich zugeordnet.
                                      Jetzt habe ich den Dialog an den Geräten gefunden, Danke!
                                      • N Offline
                                        N Offline
                                        navlis
                                        Hallo ihr,
                                        Ich habe heute nacht mal den Tracccar server installiert und mein handy darin aufgenommen soweit so gut 👍
                                        Dann wollte ich den adapter verbinden, klappte auch.
                                        Aber ich erhalte keine Daten die zwei Zonen die ich angelegt habe so wie mein Handy nix kommt im adapter an ?
                                        Gibbet da nen geheimen Trick den ich net kenne oder bin ich erstmal zu doof 😅🫣
                                        Server und adapter sind die neueste Version
                                        Hoffe auf eure Hilfe
                                        LG
                                        Silvan
                                        crunchipC liv-in-skyL 2 Antworten Letzte Antwort
                                        • N navlis
                                          Hallo ihr,
                                          LG
                                          Silvan
                                          crunchipC Offline
                                          crunchipC Offline
                                          @navlis sagte in Test Adapter Traccar v0.0.x:
                                          also Verbindung steht?
                                          Server sowie Handy aktiv?
                                          welche Daten kamen an und welche fehlen?
                                          N 1 Antwort Letzte Antwort
