  4. jarvis v3.1.x - just another remarkable vis
1.9k Beiträge 94 Kommentatoren 927.4k Aufrufe 77 Beobachtet
  • M MCU
    @smarthome2020 Ja dann
    [{"Rubrik":"Erste","Gerätename":"FritzBox","IP":"<a href=\"https://192.168.178.1\" target=\"_blank­\">192.168.178.1</a>"}, usw.]
    Beispiel
    https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/system-effektprog./tr064-devices-jsontable
    2023.10.26 -> aktuelle Version v1.0.4
    sigi234S Online
    sigi234S Online
    #1144
    @mcu
    Hallo, wenn ich keine entsprechende Geräte habe kann ich die wo deaktivieren im Skript?
    javascript.0
    2023-10-25 18:03:21.965	warn	at script.js.Sigi.Devices:353:3
    javascript.0
    2023-10-25 18:03:21.965	warn	at script.js.Sigi.Devices:56:21
    javascript.0
    2023-10-25 18:03:21.964	warn	getState "hue-extended.0.config.ipaddress" not found (3)
    javascript.0
    2023-10-25 18:02:55.543	warn	at script.js.Sigi.Devices:353:3
    javascript.0
    2023-10-25 18:02:55.543	warn	at script.js.Sigi.Devices:56:21
    javascript.0
    2023-10-25 18:02:55.543	warn	getState "hue-extended.0.config.ipaddress" not found (3)
    javascript.0
    2023-10-25 18:02:52.614	warn	at script.js.Sigi.Devices:353:3
    javascript.0
    2023-10-25 18:02:52.614	warn	at script.js.Sigi.Devices:76:4
    javascript.0
    2023-10-25 18:02:52.614	warn	at setState (C:\SmartHome\node_modules\iobroker.javascript\lib\sandbox.js:1740:20)
    javascript.0
    2023-10-25 18:02:52.614	warn	State "0_userdata.0.devices.useBroadlink2" not found
    javascript.0
    2023-10-25 18:02:52.613	warn	at script.js.Sigi.Devices:353:3
    javascript.0
    2023-10-25 18:02:52.613	warn	at script.js.Sigi.Devices:71:4
    javascript.0
    2023-10-25 18:02:52.613	warn	at setState (C:\SmartHome\node_modules\iobroker.javascript\lib\sandbox.js:1740:20)
    javascript.0
    2023-10-25 18:02:52.613	warn	State "0_userdata.0.devices.useWifilight" not found
    javascript.0
    2023-10-25 18:02:52.612	warn	at script.js.Sigi.Devices:353:3
    javascript.0
    2023-10-25 18:02:52.612	warn	at script.js.Sigi.Devices:60:5
    javascript.0
    2023-10-25 18:02:52.611	warn	at setState (C:\SmartHome\node_modules\iobroker.javascript\lib\sandbox.js:1740:20)
    javascript.0
    2023-10-25 18:02:52.610	warn	State "0_userdata.0.devices.useMeross" not found
    javascript.0
    2023-10-25 18:02:52.609	warn	at script.js.Sigi.Devices:353:3
    javascript.0
    2023-10-25 18:02:52.609	warn	at script.js.Sigi.Devices:56:21
    javascript.0
    2023-10-25 18:02:52.608	warn	getState "hue-extended.0.config.ipaddress" not found (3)
    javascript.0
    2023-10-25 18:02:52.608	warn	at script.js.Sigi.Devices:353:3
    javascript.0
    2023-10-25 18:02:52.608	warn	at script.js.Sigi.Devices:54:5
    javascript.0
    2023-10-25 18:02:52.608	warn	at setState (C:\SmartHome\node_modules\iobroker.javascript\lib\sandbox.js:1740:20)
    javascript.0
    2023-10-25 18:02:52.608	warn	State "0_userdata.0.devices.useSonoff" not found
    javascript.0
    2023-10-25 18:02:52.606	warn	at script.js.Sigi.Devices:353:3
    javascript.0
    2023-10-25 18:02:52.606	warn	at script.js.Sigi.Devices:48:5
    javascript.0
    2023-10-25 18:02:52.605	warn	at setState (C:\SmartHome\node_modules\iobroker.javascript\lib\sandbox.js:1740:20)
    javascript.0
    2023-10-25 18:02:52.603	warn	State "0_userdata.0.devices.useWLED" not found
    • sigi234S sigi234
      @mcu
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      MCU
      #1145
      @sigi234 Sillte automatisch deaktiviert werden, ausser bei hue-extended da weiss ich es , habe ich vergessen. Aber sonst muss ich mir anschauen. Bin noch unterwegs. Danke für den Hinweis.
      Kann auch sein, dass die Fehler nur beim ersten Start aufgetreten sind?
      • M MCU
        Beispiel
        smarthome2020
        #1146
        @mcu sagte in jarvis v3.1.x - just another remarkable vis:
        [{"Rubrik":"Erste","Gerätename":"FritzBox","IP":"<a href="https://192.168.178.1" target="_blank­">192.168.178.1</a>"}, usw.]
        Du bist schon genial :) Danke für deine Lösung
        • M MCU
          sigi234S Online
          sigi234S Online
          #1147
          Ja, teilweise:
          javascript.0
          2023-10-25 20:36:55.651	info	script.js.Sigi.Devices: registered 27 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2023-10-25 20:36:55.649	info	script.js.Sigi.Devices: Keine WifiLight`s vorhanden -> useWifiLight false
          javascript.0
          2023-10-25 20:36:55.647	info	script.js.Sigi.Devices: Keine WifiLight`s vorhanden -> useWifiLight false
          javascript.0
          2023-10-25 20:36:55.644	info	script.js.Sigi.Devices: Keine Meross`s vorhanden -> useMeross false
          javascript.0
          2023-10-25 20:36:55.643	warn	at script.js.Sigi.Devices:353:3
          javascript.0
          2023-10-25 20:36:55.643	warn	at script.js.Sigi.Devices:56:21
          javascript.0
          2023-10-25 20:36:55.642	warn	getState "hue-extended.0.config.ipaddress" not found (3)
          javascript.0
          2023-10-25 20:36:55.642	info	script.js.Sigi.Devices: Keine Sonoffs vorhanden -> useSonoff false
          javascript.0
          2023-10-25 20:36:55.640	info	script.js.Sigi.Devices: Keine WLED vorhanden -> useWLED false
          javascript.0
          2023-10-25 20:36:55.626	info	Start javascript script.js.Sigi.Devices
          javascript.0
          2023-10-25 20:36:55.620	info	Stop script script.js.Sigi.Devices
          • M MCU
            Beispiel
            smarthome2020
            #1148
            Beispiel
            Ich bin nun nach deiner Anleitung vorgegangen. Ich habe insgesamt 8 Tasmota-Steckdosen-Plugs aktiv. Es wird mir aber nur eine als Tasmota-Device angezeigt. Kann ich die anderen manuell noch definieren?
            • S smarthome2020
              Beispiel
              MCU
              #1149
              @smarthome2020 Man muss die Geräte alle in der Instanz tr064 definiert haben, sonst werden sie nicht in der Liste vom tr064 übernommen?
              • M MCU
                smarthome2020
                #1150
                @mcu
                Die Plugs sind in der Liste vorhanden. Sie werden nur nicht blau hinterlegt, so dass eine Website dazu geöffnet werden kann.
                Beispiel: Badezimmersteckdose ist ein Tasmota-Device
                PC-Steckdose ist auch ein Tasmota-Device (gleiche Steckdose)
                  MCU
                  #1151
                  @smarthome2020 ok. Dann haben die Geräte keine IP in der Info.
                  Du kannst aber zu der IP in dem nameArr-Objekt Dein Link, den du haben möchtest zu dieser IP, einstellen.
                  Wenn man nur zur IP ein Link setzen möchte, dann so:
                      "ip": "192.168.178.75",
                      "link": "http://192.168.178.75/cs?"
                  Sonoff prüft auf diese Objekte: sonoff.0.*.INFO.IPAddress
                  Die Steckdose ist aber im sonoff-Adapter hinterlegt? Ich dachte INFO wäre da Standard.
                  • sigi234S sigi234
                    Ja, teilweise:
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    MCU
                    #1152
                    @sigi234 Programm korrigiert, sollte nicht mehr vorkommen.
                    Doku -> STRG+F5. -> v1.0.1
                    • M MCU
                      sigi234S Online
                      sigi234S Online
                      #1153
                      • sigi234S sigi234
                        MCU
                        #1154
                        @sigi234 Nochmal bitte -> v1.0.2
                        • M MCU
                          sigi234S Online
                          sigi234S Online
                          #1155
                          • sigi234S sigi234
                            MCU
                            #1156
                            @sigi234 Jo, auf ein Neues ->v1.0.3
                            • M MCU
                              sigi234S Online
                              sigi234S Online
                              #1157
                              Jupp, läuft. 👍
                              • sigi234S sigi234
                                Jupp, läuft. 👍
                                MCU
                                #1158
                                @sigi234 Danke.
                                • M mpl1338
                                  Ist es möglich einen Rollladen per true/false zu fahren?
                                  Im Moment läuft es über "Absolute Position" , hier wird bei Pfeil hoch/runter 100 bzw 0 an die GA "Absolute Position" gesendet.
                                  Ich habe jedoch eine weitere GA "Auf/Ab" diese reagiert auf false/true.
                                  Hintergrund ist, dass mein Jalousie Aktor gerne mal die Absolute Position vergisst und dann keine fahrbefehle per Absolute Position mehr annimmt bis er wieder in einer endlage ist. Die fahrbefehle per AUF/AB (0/1) hingegen nimmt er an.
                                  mpl1338
                                  #1159
                                  @mpl1338 said in jarvis v3.1.x - just another remarkable vis:
                                  kann mir niemand helfen?
                                  • M mpl1338
                                    MCU
                                    #1160
                                    @mpl1338 Zeig mal bitte die ioBroker-Objekte zu den einzelnen Rollladen.
                                    • M MCU
                                      mpl1338
                                      #1161
                                      @mcu said in jarvis v3.1.x - just another remarkable vis:
                                      aktuelle Konfiguration funktioniert wie gewollt.
                                      Screenshot 2023-10-26 193657.png Screenshot 2023-10-26 193509.png Screenshot 2023-10-26 193448.png
                                      mir wäre es jedoch lieber über "Raffstore_küche_fahren" zu fahren.
                                      • M mpl1338
                                        MCU
                                        #1162
                                        @mpl1338 Also, wenn Raffstore_Küche_fahren = true -> rauf und bei false -> runter?
                                          mpl1338
                                          #1163
                                          als Notlösung mach ich das über ein Skript. Wenn 100 dann true, wenn 0 dann false, wenn 1-99 dann 1-99
