  4. ZigBee neue Version 1.8.x
385 Beiträge 55 Kommentatoren 111.0k Aufrufe 49 Beobachtet
  • MyzerATM MyzerAT
    @dp20eic
    was willst du mir damit sagen ?
    hier nochmal ein logfile, ich gehe in den paringmodus und im log erscheint die neue LED in zeile 99 "498860000DA341A" aber mehr nicht! im Kopplungsmodus ist nichts zu sehen, keine FM nichts! Eventuell liegt ja der Fehler an der Zigbee Version selbst! Bin ja nicht dumm! habe schon hunderte male was eingebunden per pairing!
    2023-10-19 19:07:15.702 - debug: zigbee.0 (672) Routing for '0xc4988600004bdb43': {"neighbors":[{"linkquality":255,"networkAddress":0,"ieeeAddr":"0x00124b001940be75","relationship":2,"depth":255},{"linkquality":0,"networkAddress":8259,"ieeeAddr":"0xc498860000d9d0fa","relationship":5,"depth":255},{"linkquality":89,"networkAddress":9003,"ieeeAddr":"0x7cb03eaa00b09a56","relationship":2,"depth":255},{"linkquality":110,"networkAddress":12355,"ieeeAddr":"0x000b57fffe972bd2","relationship":2,"depth":255},{"linkquality":255,"networkAddress":16055,"ieeeAddr":"0xc4988600004bda67","relationship":2,"depth":255},{"linkquality":34,"networkAddress":18536,"ieeeAddr":"0x84182600000ff39d","relationship":2,"depth":255},{"linkquality":213,"networkAddress":19519,"ieeeAddr":"0x000d6ffffe9f907c","relationship":2,"depth":255},{"linkquality":165,"networkAddress":23639,"ieeeAddr":"0xf0d1b800001d8b83","relationship":2,"depth":255},{"linkquality":0,"networkAddress":35053,"ieeeAddr":"0xc498860000da341a","relationship":5,"depth":255},{"linkquality":75,"networkAddress":46489,"ieeeAddr":"0x000d6ffffe9c27d9","relationship":2,"depth":255},{"linkquality":103,"networkAddress":48806,"ieeeAddr":"0x000b57fffe9b4e54","relationship":2,"depth":255},{"linkquality":96,"networkAddress":55885,"ieeeAddr":"0xc498860000078314","relationship":2,"depth":255},{"linkquality":48,"networkAddress":60906,"ieeeAddr":"0x000b57fffe48a839","relationship":2,"depth":255},{"linkquality":117,"networkAddress":62541,"ieeeAddr":"0xc4988600004bda4b","relationship":2,"depth":255}]}
    zigbee_MyzerAT.txt
    #290
    @myzerat sagte in ZigBee neue Version 1.8.x:
    Moin,
    ich wollte damit nur fragen/sagen, dass Du den Reset etwas anders beschrieben hast als das, was ich im Internet gefunden habe.
    Bernd
    • MyzerATM MyzerAT
      @arteck sagte in ZigBee neue Version 1.8.x:
      aber das hast du schon zig mal gemacht..
      ja ich weiß, hab das im ganzen schon verstanden, habe ja vorher intensiv deine Info dazu gelesen, nur das mit der "wie komme ich auf die aktuelle Version" ist mir wieder mal entfallen! gibt ja drei Möglichkeiten!
      ps: das mit dem Log ist ein anderes Problem, hat nichts mit dem klickverhalten der WXKG01LM zu tun! ich kann warum auch immer keine innr Lampen pairen, daher das log!
      #Edit#
      so, nach vielen Stunden der Suche und des Probierens, auch mit Version 1.8.24 , bin ich mit meinem Latein am Ende! Selbst im debug log von zigbee wird nicht mal angezeigt, das was fehlschlägt beim pairen der zwei innr Lampen ! Sie tun auch als ob sie sich verbinden wollten!
      Einschalten, kurz warten "sie ändern die Farben" und dann 6x ein/aus und dann werden sie etwas dunkler, im Zigbee keine Reaktion - 0 - nichts - nada !
      Die Lampen sind nagelneu! Lassen sich ohne Probleme mit einem Echo von Amazon einbinden! Andere Devices kann ich ohne Probleme einbinden!
      laut QR Code an den Lampen haben sie folgende Kennung , damit finde ich sie im logfile, aber ich sehe sie nirgends im iobroker !!!
      Z:C**498860000D9D0FA** $I:532AAF965B1237FE635ABF668DC4F1387F5D
      Z:C**498860000DA341A** $I:DAF4DE68227C46700AA40E18F2CC76C0ADA8
      #291
      Moin,
      hast Du die da auch wieder entkoppelt?
      Bernd
      MyzerATM 1 Antwort Letzte Antwort
        Moin,
        Bernd
        MyzerATM Offline
        MyzerATM Offline
        MyzerAT
        #292
        @dp20eic ja klar, habe ja nur eine von sechs stück bei Amazon probiert und selbst alle anderen erscheinen nicht im iobroker ! Die waren noch nirgends eingebunden!
        lg Rudi
        Node 22.23.0
        Nodejs 22.23.0
        npm 10.9.8
        js-controller 7.2.2
        • MyzerATM MyzerAT
          arteckA Offline
          arteckA Offline
          arteck
          #293
          @myzerat anz sachte...
          zuerst adapter auf INFO.. kein debug da sind zu viele infos.
          also adapter stop -> auf info stellen -> coordinator rausziehen -> kurz warten -> wieder rein -> adapter starten
          vom start log posten
          dann anlernen.. und wieder log posten
          MyzerATM 2 Antworten Letzte Antwort
          • arteckA arteck
            MyzerATM Offline
            MyzerATM Offline
            MyzerAT
            #294
            @arteck
            mach ich am Nachmittag, thx
            lg Rudi
            Node 22.23.0
            Nodejs 22.23.0
            npm 10.9.8
            js-controller 7.2.2
            • arteckA arteck
              MyzerATM Offline
              MyzerATM Offline
              MyzerAT
              schrieb am zuletzt editiert von MyzerAT
              #295
              @arteck
              so habe es genau so gemacht wie du es oben verlangt hast!
              zigbee_start_pairing_log_MyzerAT.txt
              ps: gibt aber nur das eine log, weil nach dem pairing sich nix getan hat im log!
              hier nochmal das log von gestern, die zwei innr LED sind absolut neu und beim pairing erscheint keine Meldung, dennoch finde ich sie im debuglog!
              Z:C** 498860000D9D0FA ** $I:532AAF965B1237FE635ABF668DC4F1387F5D
              Z:C** 498860000DA341A ** $I:DAF4DE68227C46700AA40E18F2CC76C0ADA8
              beite im log_myzerAT#.txt
              lg Rudi
              Node 22.23.0
              Nodejs 22.23.0
              npm 10.9.8
              js-controller 7.2.2
              • arteckA Offline
                arteckA Offline
                arteck
                #296
                @myzerat deie Firmware ist alt 20200211
                und du findest die zwar abe rmit linkquality":0 also die senden garnix..ich würde vermuten das es an der Firmware liegt..
                genau kann ich es dir nicht sagen
                • WinniW Offline
                  WinniW Offline
                  Winni
                  #297
                  Guten Morgen in die Runde. Bei mir kommen immer wieder solche Fehlermeldungen:
                  zigbee.0
                  2023-10-23 06:53:09.486	error	Send command to 0xa4c1385dac2f6eda failed with no error code (Timeout - 13439 - 1 - 247 - 6 - 11 after 10000ms
                  Die Dosen funktionieren aber. Ich vermute, dass es sich irgendwie um ein Timing Problem handelt, denn wenn ich das richtig sehe, tritt das nur bei Dosen auf die über andere (Repeater) angebunden sind. Wäre es vielleicht möglich hier mittels einer Einstellung im Adapter was zu machen?
                  WinniW 1 Antwort Letzte Antwort
                  • arteckA arteck
                    MyzerATM Offline
                    MyzerATM Offline
                    MyzerAT
                    #298
                    @arteck
                    Ja stimmt, hab da länger nix an neuerer Firmware auf den USB Stick eingespielt! wobei ich ja die selben innr LED (5 Stk.) Lampen vor kurzem anlernen konnte ohne Probleme!
                    habe jetzt mal was anderes probiert! habe die innr alle von Strom genommen unbd siehe da ich konnte die neuen innr Lampwen sofort anlernen! Funktioniert jetzt!!! DANKE dennoch!!!!
                    ps: aber wie komme ich nun auf eine neuere Firmware bei meinem Zigbee Usbstick , ist schon Jahre her das ich das gemacht habe!
                    lg Rudi
                    Node 22.23.0
                    Nodejs 22.23.0
                    npm 10.9.8
                    js-controller 7.2.2
                    • MyzerATM MyzerAT
                      @arteck
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #299
                      es kommt auf den koordinator an.. von @haus-automatisierung gibts bestimmt ein video zu .. schau mal auf youtube nach
                      • arteckA arteck
                        MyzerATM Offline
                        MyzerATM Offline
                        MyzerAT
                        #300
                        @arteck
                        danke, habs gefunden : ZigBee-Stick - Firmware-Update per SSH unter Linux
                        lg Rudi
                        Node 22.23.0
                        Nodejs 22.23.0
                        npm 10.9.8
                        js-controller 7.2.2
                        • WinniW Winni
                          zigbee.0
                          WinniW Offline
                          WinniW Offline
                          Winni
                          #301
                          @winni so, jetzt habe ich mal 2 Dosen näher an den Stick gebracht und jetzt kommen keine Fehlermeldung mehr. Auch kann jetzt die Firmware der Dosen gecheckt werden, was vorher auch nicht möglich war. Das ist aber keine Lösung des Problems, weil ein großer Vorteil von Zigbee ist es ja doch, dass die Geräte selbstständig ein Netzwerk aufbauen und dann auch als Repeater fungieren. Aber täglich mehrere rote Fehlermeldungen sind auch nicht schön. Vielleicht kann da mal @arteck schauen, ob es eine Möglichkeit gibt einen längeren Timeout zu setzen.
                          Thomas BraunT arteckA 2 Antworten Letzte Antwort
                          • WinniW Winni
                            #302
                            @winni sagte in ZigBee neue Version 1.8.x:
                            Aber dafür muss die Topologie halt passen.
                            • WinniW Winni
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #303
                              nein das ist Standard.. auserdem nicht empfehlenswert.. damit wird das Netz verlangsamt
                              also nächstes schreibst du .. meine Geräte reagieren träge..
                              du köntest aber die Sendeleistung des Coordinator begrenzen auf low.. wenn Router in der nähe sind .. so dass die Geräte den coordinator nicht sehen und über Router gehen müssen..
                              • S Online
                                S Online
                                spike2
                                schrieb am zuletzt editiert von spike2
                                #304
                                ich habe seit knapp einem halben Jahr das Phänomen, dass der State (true/ false) von meiner Küchenbeleuchtung (ZG192910-4) nicht mehr erkannt wird.
                                Der State ändert sich natürlich, wenn über iobroker direkt angesteuert wird.
                                Es gibt dazu noch eine Funkfernbedienung, wo direkt gesteuert werden kann und dort wird ausschließlich der State (true/ false) nicht aktualisiert.
                                Sämtliche andere Geräte im Zigbee Netzwerk funktionieren einwandfrei.
                                Im Log ist auch kein Fehler.
                                Folgenden Dinge wurden durchgeführt:
                                • Gerät gelöscht und neu angelernt
                                • System neugestartet
                                • Reconfigure der Küchenbeleuchtung
                                • System auf dem neusten Stand
                                • Zigbee Küchenbeleuchtung vom Stromnetz getrennt
                                • State Cleanup durchgeführt
                                • Prüfung auf Firmwareupdate der Küchenbeleuchtung
                                • Zigbee Adapter Downgrade auf verschiedene Versionen
                                • Zigbee Adapter akt. Version 1.8.24 installiert
                                • Zigbee Coordinator neuste Firmware
                                Datenpunkte im Objektbaum wie „link_quality“ und „msg_from_zigbee“ werden ganz normal aktualisiert.
                                Komischerweise nach einem Neustart vom Zigbee Adapter, wird es meist 1-2 korrekt erkannt, danach aber nicht mehr.
                                • S spike2
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #305
                                  @spike2 soll ich jetzt ne Handauflegen auf mein Monitor oder wie ???
                                  du bist ja lustig.. ohne LOG stocher ich doch nur rum im Trüben
                                  machmal folgendes
                                  https://github.com/ioBroker/ioBroker.zigbee/wiki/debug-messages-with-zigbee.0.info.debugmessages
                                  amg_666A S 2 Antworten Letzte Antwort
                                  • arteckA arteck
                                    machmal folgendes
                                    amg_666A Offline
                                    amg_666A Offline
                                    amg_666
                                    schrieb am zuletzt editiert von amg_666
                                    #306
                                    Das wär doch einen Versuch wert :-)
                                    @spike2 Du könntest auch mal checken ob das Device aktuelle FW hat und ggf updaten
                                    • arteckA arteck
                                      machmal folgendes
                                      S Online
                                      S Online
                                      spike2
                                      #307
                                      @arteck
                                      Das habe ich so nicht verlangt, Entschuldige dass es so rüber kommt ;)
                                      machmal folgendes
                                      Das lasse ich seit ca. 30 min laufen, es ist bis jetzt kein Eintrag vorhanden.
                                      Testweise habe ich ein anderes Gerät geprüft, dort sind Log Einträge vorhanden.
                                      Edit: jetzt kam was im Log.
                                      zigbee.0
                                      	2023-11-05 16:52:15.797	warn	ELEVATED publishToState: value generated '145' from device 540f57fffe2cc9b1 for 'Link quality'
                                      zigbee.0
                                      	2023-11-05 16:52:15.796	warn	ELEVATED publishToState: message received '{"linkquality":145}' from device 540f57fffe2cc9b1 type 'ZG192910-4'
                                      zigbee.0
                                      	2023-11-05 16:52:12.816	warn	ELEVATED publishToState: value generated '145' from device 540f57fffe2cc9b1 for 'Link quality'
                                      zigbee.0
                                      	2023-11-05 16:52:12.815	warn	ELEVATED publishToState: message received '{"linkquality":145}' from device 540f57fffe2cc9b1 type 'ZG192910-4'
                                      zigbee.0
                                      	2023-11-05 16:52:09.797	warn	ELEVATED publishToState: value generated '142' from device 540f57fffe2cc9b1 for 'Link quality'
                                      zigbee.0
                                      	2023-11-05 16:52:09.796	warn	ELEVATED publishToState: message received '{"linkquality":142}' from device 540f57fffe2cc9b1 type 'ZG192910-4'
                                      zigbee.0
                                      	2023-11-05 16:52:06.821	warn	ELEVATED publishToState: value generated '142' from device 540f57fffe2cc9b1 for 'Link quality'
                                      zigbee.0
                                      	2023-11-05 16:52:06.820	warn	ELEVATED publishToState: message received '{"linkquality":142}' from device 540f57fffe2cc9b1 type 'ZG192910-4'
                                      zigbee.0
                                      	2023-11-05 16:52:03.815	warn	ELEVATED publishToState: value generated '145' from device 540f57fffe2cc9b1 for 'Link quality'
                                      zigbee.0
                                      	2023-11-05 16:52:03.814	warn	ELEVATED publishToState: message received '{"linkquality":145}' from device 540f57fffe2cc9b1 type 'ZG192910-4'
                                      zigbee.0
                                      	2023-11-05 16:49:47.817	warn	ELEVATED Change state 'state' at device 0x540f57fffe2cc9b1 type 'ZG192910-4'
                                      zigbee.0
                                      	2023-11-05 17:02:30.704	warn	ELEVATED publishToState: value generated '142' from device 540f57fffe2cc9b1 for 'Link quality'
                                      zigbee.0
                                      	2023-11-05 17:02:30.703	warn	ELEVATED publishToState: message received '{"linkquality":142}' from device 540f57fffe2cc9b1 type 'ZG192910-4'
                                      zigbee.0
                                      	2023-11-05 17:02:27.664	warn	ELEVATED publishToState: value generated '142' from device 540f57fffe2cc9b1 for 'Link quality'
                                      zigbee.0
                                      	2023-11-05 17:02:27.663	warn	ELEVATED publishToState: message received '{"linkquality":142}' from device 540f57fffe2cc9b1 type 'ZG192910-4'
                                      zigbee.0
                                      	2023-11-05 17:02:24.704	warn	ELEVATED publishToState: value generated '142' from device 540f57fffe2cc9b1 for 'Link quality'
                                      zigbee.0
                                      	2023-11-05 17:02:24.703	warn	ELEVATED publishToState: message received '{"linkquality":142}' from device 540f57fffe2cc9b1 type 'ZG192910-4'
                                      zigbee.0
                                      	2023-11-05 17:02:21.656	warn	ELEVATED publishToState: value generated '142' from device 540f57fffe2cc9b1 for 'Link quality'
                                      zigbee.0
                                      	2023-11-05 17:02:21.655	warn	ELEVATED publishToState: message received '{"linkquality":142}' from device 540f57fffe2cc9b1 type 'ZG192910-4'
                                      zigbee.0
                                      	2023-11-05 17:02:18.682	warn	ELEVATED publishToState: value generated '142' from device 540f57fffe2cc9b1 for 'Link quality'
                                      zigbee.0
                                      	2023-11-05 17:02:18.681	warn	ELEVATED publishToState: message received '{"linkquality":142}' from device 540f57fffe2cc9b1 type 'ZG192910-4'
                                      @amg_666 sagte in ZigBee neue Version 1.8.x:
                                      Das habe ich schon geprüft, ist die aktuelle. Habe ich oben aber schon geschrieben ;)
                                      • S spike2
                                        @arteck
                                        machmal folgendes
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #308
                                        @spike2 was schreibt Licht Küche wenn du den knopp drückst im log unter ELEVATED.. das ist interessant... kommt da nix .. unmitelbar..
                                        dann sendet das Gerät nix wenn du ihn per FB schaltest..
                                        • arteckA arteck
                                          S Online
                                          S Online
                                          spike2
                                          #309
                                          @arteck
                                          Das passiert wenn ich den Switch State im Zigbee Adapter ändere.
                                          Ein- sowie ausschalten funktioniert damit ohne Probleme.
                                          zigbee.0
                                          	2023-11-05 19:04:09.820	warn	ELEVATED Change state 'state' at device 0x540f57fffe2cc9b1 type 'ZG192910-4'
                                          zigbee.0
                                          	2023-11-05 19:04:09.766	warn	ELEVATED: User stateChange zigbee.0.540f57fffe2cc9b1.state {"val":false,"ack":false,"ts":1699207449762,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1699207449762}
                                          zigbee.0
                                          	2023-11-05 19:01:05.031	warn	ELEVATED Change state 'state' at device 0x540f57fffe2cc9b1 type 'ZG192910-4'
                                          zigbee.0
                                          	2023-11-05 19:01:04.199	warn	ELEVATED: User stateChange zigbee.0.540f57fffe2cc9b1.state {"val":true,"ack":false,"ts":1699207263976,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1699207263976}
