Adapter: broadlink2
Ach befor es kommt auch mit RM4P
2023-08-15 13:15:20.018 info discover [ '192.168.1.133' ] from 0.0.0.0:34452 broadlink2.0 2023-08-15 13:15:20.014 info interface to be used: { netmaskBits: 24, address: '192.168.178.49/24', addrs: [ 192, 168, 178, 49 ], cidr: '192.168.178.49/24', bcaddr: '192.168.178.255' }: broadlink2.0 2023-08-15 13:15:15.607 warn Failed to authenticate device RM4P, undefined, ec:0b:ae:84:e9:f2, 192.168.178.133 with err [object Object] broadlink2.0 2023-08-15 13:15:14.781 info discover [ '192.168.178.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:34526 broadlink2.0 2023-08-15 13:15:14.780 info interface to be used: { netmaskBits: 24, address: '192.168.178.49/24', addrs: [ 192, 168, 178, 49 ], cidr: '192.168.178.49/24', bcaddr: '192.168.178.255' }: broadlink2.0 2023-08-15 13:15:14.718 info Discover Broadlink devices for 10sec on broadlink2.0 broadlink2.0 2023-08-15 13:15:14.717 info macObjects: [] broadlink2.0 2023-08-15 13:15:14.717 info interface to be used: { netmaskBits: 24, address: '192.168.178.49/24', addrs: [ 192, 168, 178, 49 ], cidr: '192.168.178.49/24', bcaddr: '192.168.178.255' }: broadlink2.0 2023-08-15 13:15:14.715 info broadlink2 has 0 old devices! broadlink2.0 2023-08-15 13:15:14.715 info Devices to rename: broadlink2.0 2023-08-15 13:15:14.714 info Devices to add: 21011=RM4P broadlink2.0 2023-08-15 13:15:14.714 info Scanning additional IP's: 192.168.1.133 broadlink2.0 2023-08-15 13:15:14.712 info broadlink2 initialization started... broadlink2.0 2023-08-15 13:15:14.607 info starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v18.17.1, js-controller: 4.0.24 -
2023-08-15 13:15:20.018 info discover [ '192.168.1.133' ] from 0.0.0.0:34452 broadlink2.0 2023-08-15 13:15:20.014 info interface to be used: { netmaskBits: 24, address: '192.168.178.49/24', addrs: [ 192, 168, 178, 49 ], cidr: '192.168.178.49/24', bcaddr: '192.168.178.255' }: broadlink2.0 2023-08-15 13:15:15.607 warn Failed to authenticate device RM4P, undefined, ec:0b:ae:84:e9:f2, 192.168.178.133 with err [object Object] broadlink2.0 2023-08-15 13:15:14.781 info discover [ '192.168.178.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:34526 broadlink2.0 2023-08-15 13:15:14.780 info interface to be used: { netmaskBits: 24, address: '192.168.178.49/24', addrs: [ 192, 168, 178, 49 ], cidr: '192.168.178.49/24', bcaddr: '192.168.178.255' }: broadlink2.0 2023-08-15 13:15:14.718 info Discover Broadlink devices for 10sec on broadlink2.0 broadlink2.0 2023-08-15 13:15:14.717 info macObjects: [] broadlink2.0 2023-08-15 13:15:14.717 info interface to be used: { netmaskBits: 24, address: '192.168.178.49/24', addrs: [ 192, 168, 178, 49 ], cidr: '192.168.178.49/24', bcaddr: '192.168.178.255' }: broadlink2.0 2023-08-15 13:15:14.715 info broadlink2 has 0 old devices! broadlink2.0 2023-08-15 13:15:14.715 info Devices to rename: broadlink2.0 2023-08-15 13:15:14.714 info Devices to add: 21011=RM4P broadlink2.0 2023-08-15 13:15:14.714 info Scanning additional IP's: 192.168.1.133 broadlink2.0 2023-08-15 13:15:14.712 info broadlink2 initialization started... broadlink2.0 2023-08-15 13:15:14.607 info starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v18.17.1, js-controller: 4.0.24@conector777 https://forum.iobroker.net/post/940424
stett was von 27755=RM4P -
Danke aber ich habe es gerade geschafft....Fehler war ...das sich durch das Update der Box wieder die Schutzfunktion im Menü aktiviert hat. Dann kann man sie nicht Auslesen
ich habe ein Signal einer Fernbedienung zum drehen um damit eine Lampe aus und eine zu fahren.
Wen ich das Signal nun ausführe geht die Lampe nur 2 cm ausgefahren, ich müsste das signal verlängern.
mache ich es mit blockly ruckelt die Lampe beim ausfahren.hat jemand eine Idee? wie ich ein Signal verlängern kann?
Grüße Jan
Grüße Jan
@flipkill1985 sagte in Adapter: broadlink2:
Geht soweit ich weiß mit dem Broadlink leider nicht.
Hallo Leute,
ich habe seid ein paar Tagen einen Problem. Der Broadlink schreibt eine Warnung in log.Error in StateChange for broadlink2.1.Scenes.Fernseher = Error: The id is empty! Please provide a valid id.at Validator.validateId (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/validator.js:113:19)at AdapterClass.setForeignState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:6048:25)at /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2037:16at new Promise (<anonymous>)at AdapterClass.setForeignStateAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2036:16)at /opt/iobroker/node_modules/iobroker.broadlink2/broadlink2.js:318:6at async sendScene (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink2.js:317:3)at async A.stateChange (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink2.js:182:47)Natürlich als Leier weiß ich nicht wirklich wie ich da vorgehen soll.
Mag mir mal jemand helfen? -
@padrino Eine Idee was ich zur Umsetzung benötige?
Hallo Leute,
Mag mir mal jemand helfen?@krisiun sagte in Adapter: broadlink2:
Hallo Leute,
Mag mir mal jemand helfen?Weißt hier wirklich niemand wie ich den Fehler los werden kann?
Hallo Leute,
@padrino sagte in Adapter: broadlink2:
@krisiun
Sorry, der Broadlink Adapter ist ziemlich tot...
Danke für Deine Antwort. Es ist nur der Fehler da der Broadlink funktioniert einwandfrei
@krisiun vermutlich wird da mit einer neueren JavaScript-Adapter oder was auch immer Version nicht mehr passen. Wobei "nicht passen": Die neueren Versionen prüfen halt mehr Dinge. Hat halt ggf. vorher zu keiner Fehlermeldung geführt (falls noch alles funktioniert).
Ich habe hier auch noch diverse Broadlinks liegen, nur noch einer ist in Betrieb. Ich habe diese inzwischen mit Tasmota-IR Empfängern/Sender abgelöst.
angelernt habe ich diese mit dem Broadlink weil die Fernbedienung meines Beamers zum Beispiel schon seit Jahren defekt ist. -
angelernt habe ich diese mit dem Broadlink weil die Fernbedienung meines Beamers zum Beispiel schon seit Jahren defekt ist.@bananajoe welche Tasmota IR verwendest Du ? Ich hab auch noch ein Broadlink in Betrieb.
@gargano ich habe 2 von denen hier im Einsatz:
https://www.amazon.de/gp/product/B07L146TXC
die habe ich auf Tasmota-IR umgeflasht.
Und vom Preis her ist es gerade ok wie ich sehe. Ich hab zwar im Sale 7,99 bezahlt, aber die Preise ändern sich halt. Besser als die 29,99 zwischenzeitlich (regulär scheint der bei 24,99 zu liegen).Hier ist die Anleitung für Tasmota: https://tasmota.github.io/docs/devices/YTF-IR-Bridge/
Ja das möchte ich auch mal wissen?
aber bevor ich alles umstellen muss möchte ich wissen ob mit meinem Broadlink noch was zu machen ist?
Ich habe bemerkt dass der Fehler immer nur dann kommt wenn der Fernseher einen Befehl zu einschalten bekommt. -
@krisiun bei google gibt es Anleitung wie man die Broadlink auf Tasmota umbaut ... indem man da einen Wemos D1 Mini einbaut ...
Wenn das Einschalten ansonsten geht ist doch - im Moment - noch alles gut
@bananajoe
Sieht ziemlich kompliziert aus -
@bananajoe
Sieht ziemlich kompliziert aus@krisiun Der Umbau? Jupp, deswegen habe ich es auch gelassen.
Die Dinger von Amazon: pfft wenn man schon ein paar mal Tasmota geflasht hat bzw. so einen Flasher eh da hat: nein.
Ich hab gerade mal geschaut, aber zum fertig kaufen habe ich es nicht gefunden
@bananajoe
OK. Vielen Dank.
Ich behalte mir deine Anweisungen im Hinterkopf auf. Ich versuche immer nach dem Motto zu handeln:
Dont tuch running system !!
Hab schon mehrmals die Regeln gebrochen und immer bereut. -
@bananajoe sagte in Adapter: broadlink2:
Also, wenn das das Projekt ist, dass ich kenne (war das nicht auch hier im Forum?), dann ist der Broadlink dabei doch nur Gehäuse- und Stromspender...
genau!
