  4. Test Adapter TP-Link Tapo
887 Beiträge 123 Kommentatoren 451.8k Aufrufe 107 Beobachtet
  • A Android51
    Ich habe die gleichen Fehlermeldungen mit der Kamera Tapo C520WS
    023-10-18 21:50:06.558 - error: tapo.0 (3192) callback.call is not a function
    2023-10-18 21:50:06.611 - info: tapo.0 (3192) terminating
    2023-10-18 21:50:06.614 - warn: tapo.0 (3192) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-10-18 21:50:06.832 - error: host.raspberrypi-iobroker Caught by controller[0]: TypeError: callback.call is not a function
    2023-10-18 21:50:06.833 - error: host.raspberrypi-iobroker Caught by controller[0]: at Cam. (/opt/iobroker/node_modules/onvif/lib/events.js:309:14)
    2023-10-18 21:50:06.833 - error: host.raspberrypi-iobroker Caught by controller[0]: at parseSOAPString (/opt/iobroker/node_modules/onvif/lib/utils.js:108:3)
    2023-10-18 21:50:06.833 - error: host.raspberrypi-iobroker Caught by controller[0]: at IncomingMessage. (/opt/iobroker/node_modules/onvif/lib/cam.js:297:4)
    2023-10-18 21:50:06.834 - error: host.raspberrypi-iobroker Caught by controller[0]: at IncomingMessage.emit (node:events:525:35)
    2023-10-18 21:50:06.834 - error: host.raspberrypi-iobroker Caught by controller[0]: at IncomingMessage.emit (node:domain:489:12)
    2023-10-18 21:50:06.834 - error: host.raspberrypi-iobroker Caught by controller[0]: at endReadableNT (node:internal/streams/readable:1358:12)
    2023-10-18 21:50:06.834 - error: host.raspberrypi-iobroker Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:83:21)
    2023-10-18 21:50:06.834 - error: host.raspberrypi-iobroker instance system.adapter.tapo.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-10-18 21:50:06.834 - info: host.raspberrypi-iobroker Restart adapter system.adapter.tapo.0 because enabled
    M
    M
    Michaelnorge
    #247
    @android51 Hast Du zufällig auch andere Geräte von TAPO (Steckdosen) die die Tapo-App bei dem letzten Update selbstständig gefunden und mit in seine Liste eingefügt hat?
    Bin immer noch auf Fehlersuche....
    • Smart mit: Rasp 4B / ioBroker / Conbee2 / Trådfri / Xiaomi / HUE / Logitech Harmony / Aqara / Easee Wallbox / Hyundai Ioniq / Alexa / Google Home / Fully Kiosk / VIS
    • M Michaelnorge
      A
      A
      Android51
      #248
      @michaelnorge
      Nein, ich habe nur die eine Kamera. Habe auch in den Einstellungen der App erstmal soweit es geht alle Features deaktiviert. Dennoch funktioniert es nicht.
      Bekomme immer wieder diese Fehlermeldungen.
      • M mylan
        Falls das Protokoll was hilft, zu einem der betroffenen Plugs:
        tapo.0
        2023-09-16 14:53:06.970	debug	initResult 8022FCB18C2BC4CAD9AA8C78BD88EE0320A5D983 undefined
        tapo.0
        2023-09-16 14:53:06.970	error	52 - Get Device Info failed
        tapo.0
        2023-09-16 14:53:06.970	info	Initialized 8022FCB18C2BC4CAD9AA8C78BD88EE0320A5D983
        tapo.0
        2023-09-16 14:53:06.969	error	97 Error Code: 1003, undefined 192.168.1.124
        tapo.0
        2023-09-16 14:53:06.969	debug	Received Handshake P100 on host response: 192.168.1.124
        tapo.0
        2023-09-16 14:53:06.957	debug	Handshake P100 on host: 192.168.1.124
        tapo.0
        2023-09-16 14:53:06.535	debug	Constructing P100 on host: 192.168.1.124
        tapo.0
        2023-09-16 14:53:06.534	info	Init device 8022FCB18C2BC4CAD9AA8C78BD88EE0320A5D983 type P100 with ip 192.168.1.124
        tapo.0
        2023-09-16 14:53:06.533	debug	{"hwVer":"2.0","category":"plug","model":"P100","ssid":"xxx","mac":"30DE4B4D9A01","hwId":"xxx","fwId":"00000000000000000000000000000000","oemId":"6A0E161B05B8FB93E53988B66CE51E30","fwVer":"1.2.1 Build 230804 Rel.190922","ip":"192.168.1.124","onboardingTime":1694868088,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
        T
        T
        tombox
        #249
        @mylan Bitte die GitHub version testen die sollte die neue firmware unterstützen
        M M 3 Antworten Letzte Antwort
        • M
          M
          Michaelnorge
          schrieb am zuletzt editiert von Michaelnorge
          #250
          @tombox Habe nun alle Objekte gelöscht, die alte Version runtergeschmissen und die aus github direkt installiert, Zugangsdaten eingegeben, den MFA-Code eingegeben und die Instanz gestartet.
          Im Moment schweigt das Log, ich beobachte mal weiter....
          Zusatz:
          Ich habe eine Innenkamera an eine Schaltsteckdose angeschlossen, die schaltet aus Gründen der Privatsphäre die Kamera nur dann an wenn niemand zu Hause ist.
          Bei dieser Version kommt alle zwei Sekunden folgende Warnung ins Log:
          "FetchError: request to https://192.168.178.159/ failed, reason: connect EHOSTUNREACH 192.168.178.159:443"
          • T tombox
            M
            M
            Michaelnorge
            #251
            @tombox Mir scheint das der Adapter jetzt super seinen Dienst tut!
            Vielen lieben Dank und ein schönes Wochenende!!!
            • T tombox
              M
              M
              mylan
              #252
              @tombox
              Ja danke, in einem ersten Test kann ich eine P100 mit neuer Firmware wieder steuern! :)
              • T tombox
                M
                M
                Michaelnorge
                #253
                @tombox Mein ProxMox macht nachts ein Backup von ioBroker.
                Danach kommen die gleichen Fehler wieder ins Log, (sprich "tapo.0 (2311) callback.call is not a function") wahrscheinlich weil ProxMox für das Backup das System kurzzeitig stoppt und der Adapter damit nicht klar kommt.
                • M Michaelnorge
                  A
                  A
                  Android51
                  #254
                  @michaelnorge
                  Werde das heute Abend auch mal testen mit der Version. Mache auch nachts ein Backup. Werde berichten, wie es sich bei mir verhält.
                  • A
                    A
                    Android51
                    #255
                    Ich habe jetzt die Version 0.1.0 installiert und die Probleme bestehen weiterhin. Es kommen die gleichen Fehlermeldungen wie oben beschrieben.
                    @Michaelnorge
                    Was hast du denn bei MFA eingegeben? Der Code ändert sich doch stetig?! Ich dachte, man müsste MFA in der Handy-App deaktivieren.
                    • A Android51
                      @Michaelnorge
                      M
                      M
                      Michaelnorge
                      #256
                      @android51 Ich bekomme die per Email von TAPO, sobald der Adapter das im Log fordert.
                      Hast Du mal die ganzen Objekte gelöscht?
                      • M Michaelnorge
                        A
                        A
                        Android51
                        #257
                        @michaelnorge
                        und wie oft muss man den Code dann eingeben? Ich bekomme den auch per E-Mail, wenn das aktiviert ist. Aber den möchte man doch nicht andauernd neu eingeben müssen.
                        Ja, ich hatte die Objekte vorher vollständig gelöscht. Bin mir nur nicht sicher, ob das mit der Github-Installation so richtig funktioniert hat. Aber die Version deutet ja daraufhin, dass es die richtige ist.
                        • A Android51
                          @michaelnorge
                          A
                          A
                          Android51
                          schrieb am zuletzt editiert von Android51
                          #258
                          Bei mir läuft es jetzt auch. Hatte vorher in der Handy-App für die Kamera unter Erweiterte Einstellungen ziemlich komplexe Benutzerdaten (Benutzername + Passwort) vergeben. Vielleicht wurden irgendwelche Sonderzeichen nicht erkannt. Interessant ist aber, dass ich die Daten im ioBroker Adapter anschließend nicht aktualisiert habe und es trotzdem funktionierte. Aber zuletzt sogar die Daten (siehe Abbildung unten) freigelassen und es funktioniert. Der Adapter greift also nur die Daten aus der Handy-App ab. Ich hatte das eigentlich anders verstanden, dass die Daten nur noch lokal im Netzwerk bleiben.
                          Nicht falsch verstehen... Danke für den Adapter.
                          Ich hatte mir nur vorgestellt, dass ich die Kamera anschließend rein lokal verwenden kann, weil ich nicht möchte, dass mein Kamerabild in irgendeiner Cloud zu sehen ist.
                          Aber ich habe da schon eine Idee, wie sich das realisieren lässt.
                          T M 2 Antworten Letzte Antwort
                          • A Android51
                            T
                            T
                            tombox
                            #259
                            @android51 Kamera is lokal nur die Gerätelist wird aus dem tapo account gezogen
                            • A Android51
                              M
                              M
                              Michaelnorge
                              #260
                              @android51 said in Test Adapter TP-Link Tapo:
                              Ich hatte ebenfalls Bedenken (nicht seitens des Adapters aber seitens TAPOs).
                              Hab ne Kamera im Wohnzimmer bei der ich bisher immer die Funktion "tapo.remote.setLensMaskConfig" aktiviert habe, wenn jemand zu Hause war.
                              Jetzt hab ich direkt ne Schaltsteckdose dran, die physisch die Kamera vom Strom trennt - sicher ist sicher ;-)))
                              • M Michaelnorge
                                A
                                A
                                Android51
                                #261
                                Ich frage mich aber immer noch... Wenn ich die drei oben genannten Werte nicht ausfülle, wie greift der Adapter dann auf die Kamera zu?
                                Er hat dann nur noch Zugriff über den App Account. Wenn ich dann in der App Änderungen vornehme, sehe ich, wie die Objektdaten aktualisiert werden.
                                Mein Plan ist es zurzeit, der Kamera den Webzugriff im Router zu entziehen und nur lokal zu nutzen.
                                • A Android51
                                  M
                                  M
                                  Michaelnorge
                                  #262
                                  @android51 Nee das klappt eigentlich schon.
                                  Wenn ich in der pihole die Seiten "(.|^)tplinknbu.com$" und "n-da.tplinkcloud.com" blocke kann ich aus der Ferne (mit der App) nicht mehr auf die Kameras zugreifen, aber der Adapter funktioniert dann immer noch....
                                  • A
                                    A
                                    Android51
                                    #263
                                    @michaelnorge
                                    ok, guter Hinweis.
                                    Ich habe bisher nur der Kamera im Router die Internetberichtigung entzogen. Ich kann dann vom Handy über die App nur auf die Kamera zugreifen, wenn ich mich im hauseigenen WLAN befinde. Sobald ich WLAN deaktiviere, hat die App keine Funktion mehr. Demnach gehe ich davon aus, dass die App im eigenen WLAN auch lokal auf die Kamera zugreift, oder liege ich da falsch?
                                    • A Android51
                                      @michaelnorge
                                      ok, guter Hinweis.
                                      M
                                      M
                                      Michaelnorge
                                      #264
                                      @android51 Ja so sehe ich das auch
                                      • M
                                        M
                                        Michaelnorge
                                        #265
                                        Schwarmwissenmodus _ AN
                                        Hallo in die Runde!
                                        Habt ihr auch seit einigen Tagen das Problem, dass die C100 in den Objekten nicht mehr auf true/falsch schaltet bei Bewegungserkennung?
                                        In der App funktioniert die Cam wie sie soll.
                                        Ich weiß leider nicht ob es ein Update mit der Kamera gab (1.3.6 Build 230512 Rel.47982n(4555))
                                        Das Log gibt keinen Aufschluss und keine Fehlermeldungen raus.
                                        Die anderen Remotekontrollen in den Objekten funktionieren.
                                        Ich hab keine Probleme mit den C310 und der C320WS. hier zu Hause.
                                        Was die C100 hier ausmacht ist das sie im Wohnzimmer hängt und via Zwischenstecker deaktiviert wird wenn jemand zu Hause ist.
                                        Das protokolliert der Adapter auch, was ja richtig ist. Wenn sich die Kamera dann aktiviert, startet der Adapter neu und fährt wunschgemäß hoch.
                                        Die C100 wird auch gefunden - nur daß der true/false halt nicht auslöst.
                                        Im log steht bei dieser Kamera "hardwareId":2 - bei allen Anderen der Wert 1, keine Ahnung ob das was zu bedeuten hat.
                                        Jemand der mir sagen kann woran das liegt?
                                        Bin mit meinem Latein am Ende....
                                        @tombox ich habe vorsichtshalber schon mal ein Issue geschrieben ;-)
                                        • T tombox
                                          Hi ich habe ein neuen Adapter für TP-Link die mit der Tapo App überwacht werden können, geschrieben.
                                          Der Adapter loggt sich über die Cloud ein um alle Geräte mit IP zu finden
                                          Wenn das Gerät nicht als online erkannt wird kann manuell die IP gesetzt wird.
                                          tapo.0.id.ip
                                          Dann versucht er sich lokal mit username und Password auf die Geräte zu verbinden und zu steuern.
                                          Aktuelle Werte:
                                          tapo.0.id
                                          Motion Detection funktioniert mit Stream User und Password
                                          Minimum Node v14 muss installiert sein, sonst bekommt man exit code 25 beim installieren
                                          Zum Installieren:
                                          https://github.com/TA2k/ioBroker.tapo
                                          Loginablauf:
                                          Die Tapo App Zugangsdaten eingeben
                                          Steuern
                                          tapo.0.id.remote auf true setzen steuert den jeweiligen Befehl
                                          Steckdose und Kamerasteuerung aktivieren
                                          App auf Handy aufrufen
                                          "ich" (rechts unten) aufrufen
                                          "Dienste"
                                          "Dienste von Drittanbietern"
                                          "Kompatibilität mit Drittanbietern" auf "ON"
                                          Horst BöttcherH
                                          Horst BöttcherH
                                          Horst Böttcher
                                          #266
                                          @tombox led Band läst sich unter remote nicht steuern
                                          ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
                                          83.9k
