  3. Off Topic
  4. Upgrade von Debian 11/Bullseye auf 12/Bookworm
upgrade bullseye bookworm
351 Beiträge 51 Kommentatoren 116.4k Aufrufe 52 Beobachtet
    @reutli
    Grafana und Influx können weiter verwendet werden, weil die in ihnen Repos keine release names sondern 'stable' als Version stehen haben.
    Und die sources.list muss stärker umgebaut werden, deswegen der volle Text an der Stelle. non-free-firmware ist erst seit bookworm dabei.
    reutli
    #269
    Dann habe ich doch noch eine Frage:
    Das heisst ich ersetze meinen Inhalt der sources.list
    # deb cdrom:[Official Debian GNU/Linux Live 10.3.0 standard 2020-02-08T12:27]/ bullseye main
    #deb cdrom:[Official Debian GNU/Linux Live 10.3.0 standard 2020-02-08T12:27]/ bullseye main
    deb http://deb.debian.org/debian/ bullseye main non-free
    deb-src http://deb.debian.org/debian/ bullseye main
    deb http://security.debian.org/debian-security bullseye-security main
    deb-src http://security.debian.org/debian-security bullseye-security main
    # bullseye-updates, previously known as 'volatile'
    deb http://deb.debian.org/debian/ bullseye-updates main
    deb-src http://deb.debian.org/debian/ bullseye-updates main
    # This system was installed using small removable media
    # (e.g. netinst, live or single CD). The matching "deb cdrom"
    # entries were disabled at the end of the installation process.
    # For information about how to configure apt package sources,
    # see the sources.list(5) manual.
    komplett mit
    deb http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware
     deb http://security.debian.org/debian-security bookworm-security main contrib non-free non-free-firmware
     deb http://deb.debian.org/debian bookworm-updates main contrib non-free non-free-firmware
     # Uncomment deb-src lines below then 'apt-get update' to enable 'apt-get source'
     deb-src http://deb.debian.org/debian bookworm main contrib non-free
     deb-src http://security.debian.org/debian-security bookworm-security main contrib non-free
     deb-src http://deb.debian.org/debian bookworm-updates main contrib non-free
    oder nur Teile davon?
    @thomas-braun sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
    Influx hast du aber in (vermutlich) zwei .list files in /etc/apt/sources.list.d stehen. Lösch die mit dem release name drin.
    Habe nur eine influxdata.list
    admin@macmini-iobroker:/etc/apt/sources.list.d$ ls -la
    insgesamt 24
    drwxr-xr-x 2 root root 4096 15. Okt 18:40 .
    drwxr-xr-x 9 root root 4096 24. Sep 18:59 ..
    -rw-r--r-- 1 root root   84 16. Apr 2023  grafana.list
    -rw-r--r-- 1 root root  117 16. Apr 2023  influxdata.list
    -rw-r--r-- 1 root root   56 16. Apr 2023  influxdb.list
    -rw-r--r-- 1 root root  100 15. Okt 18:40 nodesource.list
    mit
    deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main
    das passt dann, oder?
    iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
    *Wer freundlich ist, dem wird freundlich geholfen *
    • R reutli
      komplett mit
      insgesamt 24
      mit
      #270
      @reutli sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
      influxdb.list
      Dann ist die zuviel.
      Ich sag ja, es gibt zwei Dateien mit Bezug zu influxdb.
      Hatte ich im HowTo nicht dazu geschrieben, dass die sources.list komplett mit dem neuen Inhalt versehen werden muss? Dann muss ich das noch nachtragen...
      R 1 Antwort Letzte Antwort
        influxdb.list
        reutli
        schrieb am zuletzt editiert von reutli
        #271
        influxdb.list
        Ok, dann wird die gelöscht, da steht tatsächlich
        admin@macmini-iobroker:/etc/apt/sources.list.d$ cat influxdb.list
        deb https://repos.influxdata.com/debian bullseye stable
        Da steht
        In die Datei /etc/apt/sources.list kopieren wir diese neuen Zeilen rein, die alten Einträge fliegen dafür raus:
        Das kann man schon so verstehen. Vielleicht einfach deutlicher "alle anderen Einträge fliegen raus"?
        Dann habe ich es (sorry) immer noch nicht kapiert, weil da steht:
        Wenn ich aber alles, also
        rein nehme, dann sind die deb-src ja eben NICHT aaskommentiert???
        Scheint ich bin zu doof das zu kapieren.
        • R reutli
          influxdb.list
          Da steht
          #272
          deb-src braucht es auf einem üblichen System nicht. Die Pakete von dort werden nur für die Software-Entwicklung benötigt.
          Ist mehr oder weniger egal, ob die Zeilen aktiv sind oder nicht. Brauchen tust du die wohl eher nicht.
          un99known99U R 2 Antworten Letzte Antwort
            un99known99U Offline
            un99known99
            schrieb am zuletzt editiert von un99known99
            #273
            Hi, what about:
            "deb http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi"
            is that needed for the upgrade or is it replaced by the debian entry?
            Thomas BraunT Meister MopperM 2 Antworten Letzte Antwort
            • un99known99U un99known99
              Hi, what about:
              #274
              @un99known99
              Still needed for the Raspberry OS specific packages.
              raspi-config for example.
                Hi, what about:
                Meister MopperM Offline
                Meister Mopper
                #275
                @un99known99
                Here is my raspi.list for bookworm:
                thomas@rpizigbee:~ $ cat /etc/apt/sources.list.d/raspi.list
                deb http://archive.raspberrypi.com/debian/ bookworm main
                Proxmox und HA ...
                un99known99U 1 Antwort Letzte Antwort
                  @un99known99
                  un99known99
                  #276
                  @meister-mopper @Thomas-Braun
                  I have:
                  root@pihole[/etc/apt/sources.list.d] # cat raspi.list
                  deb http://archive.raspberrypi.org/debian/ bullseye main
                  Uncomment line below then 'apt-get update' to enable 'apt-get source'
                  #deb-src http://archive.raspberrypi.org/debian/ bullseye main
                  and
                  that ok and only exchange with bookworm?
                  no entry with e.g. security ...?
                  do I need to add as well:
                  deb http://security.debian.org/debian-security bookworm-security main contrib non-free non-free-firmware?
                  Thomas BraunT Samson71S 2 Antworten Letzte Antwort
                    I have:
                    and
                    #277
                    @un99known99
                    Absolutely NO root shell!
                    Use your default user, not root!
                    And please use the commands in the initial posting of this thread.
                      reutli
                      #278
                      Update erfolgt!
                      Habe folgende Warnings erhalten:
                      dpkg: Warnung: Altes Verzeichnis »/usr/lib/udev/rules.d« kann nicht gelöscht werden: Das Verzeichnis ist nicht leer
                      dpkg: Warnung: Altes Verzeichnis »/usr/lib/udev« kann nicht gelöscht werden: Das Verzeichnis ist nicht leer
                      Entpacken von dkms (3.0.10-8+deb12u1) über (2.8.4-3) ...
                      dpkg: Warnung: Altes Verzeichnis »/etc/dkms/template-dkms-mkdeb/debian« kann nicht gelöscht werden: Das Verzeichnis ist nicht leer
                      dpkg: Warnung: Altes Verzeichnis »/etc/dkms/template-dkms-mkdeb« kann nicht gelöscht werden: Das Verzeichnis ist nicht leer
                      dpkg: Warnung: Altes Verzeichnis »/etc/dkms/template-dkms-mkbmdeb/debian« kann nicht gelöscht werden: Das Verzeichnis ist nicht leer
                      dpkg: Warnung: Altes Verzeichnis »/etc/dkms/template-dkms-mkbmdeb« kann nicht gelöscht werden: Das Verzeichnis ist nicht leer
                      Warning: Stopping lvm2-lvmpolld.service, but it can still be activated by:
                        lvm2-lvmpolld.socket
                      Warning: os-prober will not be executed to detect other bootable partitions.
                      update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
                      rehash: warning: skipping ca-certificates.crt,it does not contain exactly one certificate or CRL
                      Ansonsten scheint es gut auszusehen:
                      admin@macmini-iobroker:~$ sudo apt update
                      [sudo] Passwort für admin:
                      OK:1 http://deb.debian.org/debian bookworm InRelease
                      OK:2 http://security.debian.org/debian-security bookworm-security InRelease
                      OK:3 http://deb.debian.org/debian bookworm-updates InRelease
                      OK:4 https://repos.influxdata.com/debian stable InRelease
                      OK:5 https://apt.grafana.com stable InRelease
                      OK:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Holen:7 http://deb.debian.org/debian bookworm/main amd64 DEP-11 Metadata [4.492 kB]
                      Holen:8 http://deb.debian.org/debian bookworm/contrib amd64 DEP-11 Metadata [16,5 kB]
                      Holen:9 http://deb.debian.org/debian bookworm/non-free amd64 DEP-11 Metadata [4.428 B]
                      Holen:10 http://deb.debian.org/debian bookworm/non-free-firmware amd64 DEP-11 Metadata [15,5 kB]
                      Es wurden 4.529 kB in 2 s geholt (2.057 kB/s).
                      Alle Pakete sind aktuell.
                        I have:
                        and
                        Samson71S Offline
                        Samson71S Offline
                        Samson71
                        #279
                        @un99known99
                        IP aus DE und wir sind im DE-Teil des Forums? Warum nicht auf Deutsch?
                        Markus
                        Bitte beachten:
                        • Samson71S Samson71
                          @un99known99
                          un99known99
                          #280
                          @samson71
                          sry, Macht der Gewohnheit
                            Vorab:
                            Debian 12 'Bookworm' ist am 10.06.2023 als stabil veröffentlicht worden.
                            Raspberry OS 'Bullseye' ist seit dem 10. Oktober 2023 auch verfügbar. Hier ist allerdings ein in-line-Upgrade von der Vorversion nicht so einfach wie in der Vergangenheit möglich. Es sollte hier eine komplette Neuinstallation vorgenommen werden.
                            Desweiteren würde ich empfehlen die Gelegenheit zu nutzen und 32bit-Systeme auf Raspberry Pi-Kisten auf 64bit umzustellen. Das funktioniert allerdings nicht wie hier vorgestellt, bei einem Wechsel der CPU-Architektur ist eine Neuinstallation erforderlich. Desweiteren gilt für Raspberry OS die dringende Empfehlung einer Neuinstallation:
                            Edit:
                            Diesmal rät Raspberry OS allerdings noch dringender als sonst dazu, die Systeme nicht von einem zum anderen Release rüberzuheben, sondern eine komplette Neuinstallation zu machen:
                            Wichtig zu wissen: Früher empfahl man eine frische Installation, aber es war möglich, vom Vorgänger zu aktualisieren. Die jetzige Installation sollte aber auf jeden Fall neu sein.
                            Da die Änderungen an der zugrundeliegenden Architektur so signifikant sind, schlägt man dieses Mal keine Prozedur vor, um ein Bullseye-Image auf Bookworm zu aktualisieren; jeder Versuch, dies zu tun, wird mit ziemlicher Sicherheit mit einem nicht bootenden Desktop und Datenverlust enden.
                            Die einzige Möglichkeit, Bookworm zu bekommen, ist entweder eine SD-Karte mit dem Raspberry Pi Imager zu erstellen oder ein Bookworm-Image von hier herunterzuladen und mit dem Tool der Wahl zu flashen.
                            Gilt aber auch für ein System ohne Desktop, bei meinen Versuchen hab ich schwer mit dem Bootvorgang zu kämpfen, den aktuellen Kernel habe ich nicht vollständig gestartet bekommen.
                            Wer es entgegen aller Warnungen versuchen möchte:
                            https://www.heise.de/hintergrund/Raspberry-Pi-OS-InPlace-Upgrade-von-Bullseye-auf-Bookworm-wagen-9999516.html
                            #Upgrade von Debian 11 'Bullseye' auf Debain 12 'Bookworm'
                            Gegeben ist ein System, auf dem 'Debian 11 - Bullseye' läuft:
                            pi@mysterium2:~ $ lsb_release -a
                            No LSB modules are available.
                            Distributor ID: Raspbian
                            Description:    Raspbian GNU/Linux 11 (bullseye)
                            Release:        11
                            Codename:       bullseye
                            Der Stand soll auf Debian 12 'Bookworm' gehoben werden. Ich mache das wie folgt:
                            Zunächst alles auf den letzten Stand bringen
                            pi@mysterium2:~ $ sudo apt update
                            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                            Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                            Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                            Get:4 https://pkgs.tailscale.com/stable/raspbian bullseye InRelease
                            Fetched 6,522 B in 6s (1,042 B/s)
                            Reading package lists... Done
                            113 packages can be upgraded. Run 'apt list --upgradable' to see them.
                            Wenn in der Liste irgendwas mit bullseye-backports oder bullseye-propsed-updates oder ähnliches auftauchen sollte, dann ist diese Quelle zuvor zu deaktivieren. Ebenso andere manuelle Eingriffe in die Paket-Datenbank. Z.B. ein apt-hold auf das Paket 'udev' ist ja von einigen getätigt worden, diese Sperren müssen aufgehoben werden. Kann man per
                            apt-mark showhold
                            prüfen. Die aufgelisteten Pakete dann mit
                            sudo apt-mark unhold `apt-mark showhold`
                            wieder frei laufen lassen.
                            Also
                            sudo apt full-upgrade
                            sudo reboot
                            Nach dem reboot dürfen keine Pakete mehr in der Pipeline hängen.
                            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                            Fetched 6,522 B in 2s (3,644 B/s)
                            All packages are up to date.
                            Prima, jetzt ist die Basis stabil und wir können auf bookworm/Debian12 umschwenken.
                            Via
                            sudo nano /etc/apt/sources.list
                            das einkopieren:
                            Zusätzlich stellen wir auch noch weitere Dateien auf bookworm um:
                            sudo sed -i 's/bullseye/bookworm/g' /etc/apt/sources.list
                            sudo sed -i 's/bullseye/bookworm/g' /etc/apt/sources.list.d/*
                            Wenn ein erneutes
                            sudo apt update
                            Meldungen wie die folgende ergibt:
                            Err:2 http://deb.debian.org/debian bookworm InRelease
                              The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
                            muss der Schlüssel jeweils herangezogen werden.
                            Macht man so:
                            sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 648ACFD622F3D138
                            Die ID des keys übernimmt man natürlich aus der vorherigen Meldung.
                            Das macht man mit allen fehlenden Schlüsseln, bis es so oder so ähnlich aussieht, die Meldungen bzgl. der Schlüssel also nicht mehr vorhanden sind:
                            Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
                            Hit:2 http://deb.debian.org/debian bookworm InRelease
                            Hit:4 http://security.debian.org/debian-security bookworm-security InRelease
                            Hit:5 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
                            Hit:6 https://deb.nodesource.com/node_18.x bookworm InRelease
                            Get:7 https://pkgs.tailscale.com/stable/debian bookworm InRelease
                            Fetched 6,522 B in 3s (2,404 B/s)
                            445 packages can be upgraded. Run 'apt list --upgradable' to see them.
                            Auch dürfen da keine Einträge mit bullseye mehr vorkommen.
                            Vor dem eigentlichen Upgrade schaut man per
                            sudo apt -o APT::Get::Trivial-Only=true full-upgrade
                            nach ob auch genug Platz auf dem Datenträger ist. Wenn E: You don't have enough free space in /var/cache/apt/archives/. gemeldet wird sollte man vorher aufräumen, z. B. per
                            sudo apt clean
                            Jetzt aber los...
                            sudo apt update
                            Wenn während des Upgrades Rückfragen kommen, ob eine neue Version einer Konfig-Datei eingespielt werden soll bitte immer mit yes bestätigen. Es wird von der ursprünglichen Datei eine Kopie mit der Endung .dpkg-old gespeichert, welche bei Bedarf dann zurückgespielt werden kann.
                            Gleiches gilt für die Frage, ob Services automatisch neugestartet werden sollen.
                            Aus der Anzeige des ChangeLogs kommt man durch Eingabe von q heraus.
                            Jetzt holt man sich einen Kaffee (alternativ Club Mate) und schaut wie ein Superhacker mit schwarzem Kaputzenpulli und koffeinhaltigem Getränk in der Hand angestrengt auf die vorbeilaufenden Meldungen im Terminal und haut gelegentlich bei den obengenannten Rückfragen auf die Y-Taste.
                            Wenn alles durchgelaufen ist und nach einem beherzten
                            sudo reboot
                            befinden wir uns in Debian 12 'Bookworm'
                                   _,met$$$$$gg.          pi@mysterium2
                                ,g$$$$$$$$$$$$$$$P.       -------------
                              ,g$$P"     """Y$$.".        OS: Debian GNU/Linux 12 (bookworm) armv7l
                             ,$$P'              `$$$.     Host: Raspberry Pi 3 Model B Plus Rev 1.3
                            ',$$P       ,ggs.     `$$b:   Kernel: 6.1.21-v7+
                            `d$$'     ,$P"'   .    $$$    Uptime: 1 hour, 31 mins
                             $$P      d$'     ,    $$P    Packages: 711 (dpkg)
                             $$:      $$.   -    ,d$$'    Shell: bash 5.2.15
                             $$;      Y$b._   _,d$P'      Terminal: /dev/pts/0
                             Y$$.    `.`"Y$$$$P"'         CPU: BCM2835 (4) @ 1.400GHz
                             `$$b      "-.__              Memory: 70MiB / 965MiB
                              `Y$$
                               `Y$$.
                                 `$$b.
                                   `Y$$b.
                                      `"Y$b._
                            Falls Meldungen bei einem
                            sudo apt update
                            bezüglich apt-key auftauchen:
                            W: http://security.debian.org/debian-security/dists/bookworm-security/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                            W: http://raspbian.raspberrypi.org/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                            W: http://deb.debian.org/debian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                            W: http://archive.raspberrypi.org/debian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                            W: http://deb.debian.org/debian/dists/bookworm-updates/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                            W: http://archive.raspberrypi.org/debian/dists/bullseye/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                            W: https://pkgs.tailscale.com/stable/debian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                            kann man die noch an eine andere Stelle schieben:
                            sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
                            Das ist zwar nicht der Königsweg, sorgt aber dafür das die Meldungen für das erste verschwinden.
                            Fertig, viel Spaß mit dem Bücherwurm / Debian 12.
                            U Offline
                            U Offline
                            UV-on-fire
                            #281
                            Also hat problemlos geklapp auf meinem NUC. Container problemlos upgedatet und hochgelaufen.
                            Vielen Dank für deine Anleitung. Perfekt 👍 👏
                            • U UV-on-fire
                              lobomauL Offline
                              lobomauL Offline
                              lobomau
                              schrieb am zuletzt editiert von lobomau
                              #282
                              Das Update auf dem NUC von Debian 11 auf 12 lief ohne Prpbleme durch.
                              Nur der Pi4 als slave will nicht mehr connecten. Kann es am Update auf Debian 12 liegen? Hab am Pi4 eigentlich nichts geändert, da läuft weiterhin bullseye.
                              Beim slave kommt:
                              pi@Pi4:~ $ sudo iobroker multihost browse
                              No connection to states 192.168.1.19:6379[redis]
                              Und vorher beim Host:
                              lobomau@ioBroker:~$ sudo iobroker multihost enable
                              [sudo] password for lobomau:
                              Please check the binding of the configured jsonl server to allow remote connections.
                              No configuration change needed.
                              Multihost discovery server: enabled
                              Discovery authentication:   enabled
                              Persistent activation:      disabled
                              Objects:                    jsonl on 0.0.0.0
                              States:                     redis on 0.0.0.0
                              Host: NUC8i3 mit Proxmox:
                              • Slave: Pi4
                              • lobomauL lobomau
                                Beim slave kommt:
                                #283
                                @lobomau sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
                                sudo iobroker
                                Wie immer: iobroker wird NICHT per sudo angepackt. Nie.
                                Du verbiegst dir die Rechte, bis es zu genau solch merkwürdigen Meldungen wie jetzt bei dir kommt.
                                iob fix
                                auf allen Installationen.
                                  sudo iobroker
                                  iob fix
                                  lobomauL Offline
                                  lobomauL Offline
                                  lobomau
                                  #284
                                  @thomas-braun Danke für den Hinweis. iob fix hab ich gemacht. Hat aber erstmal nichts geändert.
                                  Weiter unten in der Beschreibung zu multihost ist nochmal der Hinweis zu Redis.
                                  Bei mir steht in der zu ändernden Zeile (hatte da aber auch nie etwas geändert):
                                  bind 127.0.0.1 -::1
                                  Hab ich angepasst auf:
                                  bind 127.0.0.1 192.168.1.19
                                  Alle Maschinen neugestartet, aber es funktioniert nicht mehr. Irgendwas mit dem "binding"?
                                  lobomau@ioBroker:~$ iobroker multihost enable
                                  • Slave: Pi4
                                  • lobomauL lobomau
                                    bind 127.0.0.1 -::1
                                    reutli
                                    #285
                                    @lobomau
                                    ... aber nicht dass es damit
                                    https://forum.iobroker.net/topic/69019/raspberry-pi-os-lite-bookworm-ist-da/56
                                    zusammenhängt?
                                    Kann ich nicht beurteilen aber bei mir hat es (ohne Redis) geholfen.
                                    meuteM lobomauL 2 Antworten Letzte Antwort
                                    • R reutli
                                      @lobomau
                                      zusammenhängt?
                                      meuteM Offline
                                      meuteM Offline
                                      meute
                                      #286
                                      @Thomas-Braun
                                      Top Anleitung. 👍
                                      Ich habe meinen Test-Raspi hochgezogen.
                                      Er läuft noch, jetzt mit 12/bookworm.
                                      Du schreibst in Deiner Anleitung folgendes:
                                      "Wenn während des Upgrades Rückfragen kommen, ob eine neue Version einer Konfig-Datei eingespielt werden soll bitte immer mit yes bestätigen. Es wird von der ursprünglichen Datei eine Kopie mit der Endung .dpkg-old gespeichert, welche bei Bedarf dann zurückgespielt werden kann."
                                      Das habe ich gemacht.
                                      Bei mir gab es gesicherte Dateien mit folgenden Endungen:
                                      .dpkg-old
                                      .ucf-old
                                      .update-old
                                      Einen Vorschlag habe ich dazu.
                                      Du könntest in Deiner Anleitung als Anmerkung die Suche nach solchen Dateien hinzufügen.
                                      Danach ist es ein leichtes, alt und neu zu kontrollieren.
                                      sudo find /etc/ -iname *-old | sort
                                      fraenk for friends Code: MATF103
                                      • R reutli
                                        @lobomau
                                        zusammenhängt?
                                        lobomauL Offline
                                        lobomauL Offline
                                        lobomau
                                        #287
                                        @reutli Danke für den Hinweis! "ohne Redis" war der richtige Tipp. Nun läuft alles und zwar mit jsonl. Habe auch den Pi4 auf bookworm hochgezogen.
                                        • Slave: Pi4
                                        • lobomauL lobomau
                                          #288
                                          @lobomau
                                          Moin,
                                          es geht leider aus dem Post nicht hervor, somit weiß ich nicht, ob es nur eine Momentaufnahme ist, aber die CPU beim ioBroker ist mit 99,67 % doch schon recht hoch!
                                          Wie gesagt, kann natürlich der Momentaufnahme geschuldet sein.
                                          Bernd
                                          Edit
                                          Rechtschreibung und Satzbau
