  4. Update ioBroker klappt nicht - gelöst durch neuinstallation
42 Beiträge 7 Kommentatoren 5.7k Aufrufe 4 Beobachtet
  • D DLaurenz
    gern
    pi@io-fhem:~ $ iob fix
    library: loaded
    Library version=2023-10-10
        Welcome to the ioBroker installation fixer!
        Script version: 2023-04-02
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    OK:2 http://archive.raspberrypi.org/debian buster InRelease
    OK:3 https://repo.saltproject.io/py3/debian/10/amd64/latest buster InRelease
    OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Ign:5 https://download.webmin.com/download/repository sarge InRelease
    OK:6 https://download.webmin.com/download/repository sarge Release
    E: Paket gcc-c+ kann nicht gefunden werden.
    E: Mittels regulärem Ausdruck »gcc-c+« konnte kein Paket gefunden werden.
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/5)
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    No relevant JSONL files found to compress, skip
        Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    und danach iob diag:
    pi@io-fhem:~ $ iob diag
    *** iob diag is starting up, please wait ***
    The state system.host.io-fhem.versions.nodeNewestNext was not found!
    The state system.host.io-fhem.versions.npmNewestNext was not found!
    The state system.host.io-fhem.versions.nodeCurrent was not found!
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    Press any key to continue
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: io-fhem
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7+
          Architecture: arm
    Model           : Raspberry Pi 3 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     05:49:13 up 11:03,  1 user,  load average: 0.74, 0.52, 0.35
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Thu 2023-10-12 05:49:13 CEST
               Universal time: Thu 2023-10-12 03:49:13 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:           972M        142M        222M        3.0M        607M        762M
    Swap:           99M         57M         42M
    Total:         1.1G        200M        265M
              972 M total memory
              142 M used memory
              458 M active memory
              168 M inactive memory
              222 M free memory
              130 M buffer memory
              476 M swap cache
               99 M total swap
               57 M used swap
               42 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service loaded failed failed ioBroker Server
    1 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    Filesystem                         Type      Size  Used Avail Use% Mounted on
    /dev/root                          ext4       30G  7.6G   20G  28% /
    devtmpfs                           devtmpfs  454M     0  454M   0% /dev
    tmpfs                              tmpfs     487M  8.0K  487M   1% /dev/shm
    tmpfs                              tmpfs     487M   13M  474M   3% /run
    tmpfs                              tmpfs     5.0M  4.0K  5.0M   1% /run/lock
    tmpfs                              tmpfs     487M     0  487M   0% /sys/fs/cgroup
    /dev/mmcblk0p1                     vfat       43M   25M   18M  59% /boot
    tmpfs                              tmpfs      98M     0   98M   0% /run/user/0
    fs01.samba.laurenz.ws:/BACKUPS     nfs        11T  7.2T  3.4T  69% /autofs/backup
    fs04.samba.laurenz.ws:/SOFTWARE    nfs       8.2T  5.9T  2.3T  73% /autofs/software
    fs04.samba.laurenz.ws:/MAILFUJITSU nfs       8.2T  5.9T  2.3T  73% /autofs/mailfujitsu
    fs01.samba.laurenz.ws:/NFS         nfs        11T  7.2T  3.4T  69% /autofs/nfs
    [Wed Oct 11 18:45:40 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=1bf224e2-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Wed Oct 11 18:45:43 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Wed Oct 11 18:45:43 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Wed Oct 11 18:45:45 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [Wed Oct 11 23:32:51 2023] [<802b0ee8>] (filemap_fault) from [<8042d260>] (ext4_filemap_fault+0x38/0x4c)
    [Wed Oct 11 23:32:51 2023] [<8042d228>] (ext4_filemap_fault) from [<802e8900>] (__do_fault+0x48/0x14c)
    TARGET                SOURCE                             FSTYPE OPTIONS
    /                     /dev/mmcblk0p2                     ext4   rw,noatime
    |-/sys/fs/bpf         none                               bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    |-/boot               /dev/mmcblk0p1                     vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    |-/autofs/software    fs04.samba.laurenz.ws:/SOFTWARE    nfs    rw,relatime,sync,vers=3,rsize=32768,wsize=32768,namlen=255,hard,proto=tcp,timeo=14,retrans=2,sec=sys,mountaddr=192.168.2.74,mountvers=3,mountport=30000,mountproto=udp,local_lock=none,addr=192.168.2.74
    |-/autofs/mailfujitsu fs04.samba.laurenz.ws:/MAILFUJITSU nfs    rw,relatime,sync,vers=3,rsize=32768,wsize=32768,namlen=255,hard,proto=tcp,timeo=14,retrans=2,sec=sys,mountaddr=192.168.2.74,mountvers=3,mountport=30000,mountproto=udp,local_lock=none,addr=192.168.2.74
    |-/autofs/backup      fs01.samba.laurenz.ws:/BACKUPS     nfs    rw,relatime,sync,vers=3,rsize=32768,wsize=32768,namlen=255,hard,proto=tcp,timeo=14,retrans=2,sec=sys,mountaddr=192.168.2.72,mountvers=3,mountport=30000,mountproto=udp,local_lock=none,addr=192.168.2.72
    `-/autofs/nfs         fs01.samba.laurenz.ws:/NFS         nfs    rw,relatime,sync,vers=3,rsize=32768,wsize=32768,namlen=255,hard,proto=tcp,timeo=14,retrans=2,sec=sys,mountaddr=192.168.2.72,mountvers=3,mountport=30000,mountproto=udp,local_lock=none,addr=192.168.2.72
    /var:
    1.7G    /var/
    881M    /var/cache
    705M    /var/cache/apt
    645M    /var/cache/apt/archives
    583M    /var/mail
    Archived and active journals take up 12.1M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    5.2M    /opt/iobroker/iobroker-data/
    776K    /opt/iobroker/iobroker-data/backup-objects
    532K    /opt/iobroker/iobroker-data/files
    440K    /opt/iobroker/iobroker-data/files/discovery.admin
    88K     /opt/iobroker/iobroker-data/files/admin.admin
    1.5M    /opt/iobroker/iobroker-data/objects.jsonl
    1.5M    /opt/iobroker/iobroker-data/objects.json.migrated
    964K    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    448K    /opt/iobroker/iobroker-data/backup-objects/2020-08-24_00-13_objects.json.gz
    288K    /opt/iobroker/iobroker-data/backup-objects/2019-05-10_23-20_objects.json.gz
    USB-Devices by-id:
    /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_DJ00TW49-if00-port0
    /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014B93EF0-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.1
    /usr/bin/node           v18.18.1
    /usr/bin/npm            10.2.0
    /usr/bin/npx            10.2.0
    /usr/bin/corepack       0.21.0
    nodejs:
      Installed: 18.18.1-1nodesource1
      Candidate: 18.18.1-1nodesource1
      Version table:
     *** 18.18.1-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! invalid: iobroker.js-controller@5.0.13 /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! invalid: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
    npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-12T03_49_27_265Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    At least one iobroker host is running.
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.13
    admin:          6.2.23
    javascript:     "javascript" not found
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-12T03_49_54_984Z-debug-0.log
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : io-master                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.1                  : admin                 : io-vis                                   - disabled, port: 8081, bind: 127.0.0.1, run as: admin
      system.adapter.admin.2                  : admin                 : io-blegw02                               - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.3                  : admin                 : io-influxdb                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : io-master                                -  enabled
      system.adapter.backitup.1               : backitup              : io-fhem                                  - disabled
    + system.adapter.ble.0                    : ble                   : io-blegw02                               -  enabled
      system.adapter.daswetter.0              : daswetter             : io-vis                                   -  enabled
    + system.adapter.discovery.0              : discovery             : io-master                                -  enabled
      system.adapter.dwd.0                    : dwd                   : io-vis                                   -  enabled
      system.adapter.fhem.0                   : fhem                  : io-fhem                                  -  enabled, port: 7072
      system.adapter.flot.0                   : flot                  : io-vis                                   -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : io-master                                -  enabled
    + system.adapter.hmip.0                   : hmip                  : io-master                                -  enabled
      system.adapter.homeconnect.0            : homeconnect           : io-master                                - disabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: io-vis                                   -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : io-vis                                   -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : io-vis                                   -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : io-vis                                   -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : io-vis                                   -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : io-vis                                   -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: io-vis                                   -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : io-vis                                   -  enabled
    + system.adapter.influxdb.0               : influxdb              : io-influxdb                              -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : io-master                                -  enabled
    + system.adapter.meross.0                 : meross                : io-master                                -  enabled
      system.adapter.smartgarden.0            : smartgarden           : io-master                                - disabled
      system.adapter.vis-bars.0               : vis-bars              : io-vis                                   -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : io-vis                                   -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : io-vis                                   -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : io-vis                                   -  enabled
      system.adapter.vis-history.0            : vis-history           : io-vis                                   -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : io-vis                                   -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : io-vis                                   -  enabled
      system.adapter.vis-lcars.0              : vis-lcars             : io-vis                                   -  enabled
      system.adapter.vis-material.0           : vis-material          : io-vis                                   -  enabled
      system.adapter.vis-metro.0              : vis-metro             : io-vis                                   -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : io-vis                                   -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : io-vis                                   -  enabled
      system.adapter.vis-weather.0            : vis-weather           : io-vis                                   -  enabled
      system.adapter.vis.0                    : vis                   : io-vis                                   -  enabled
    + system.adapter.web.0                    : web                   : io-vis                                   -  enabled, port: 8082, bind: 192.168.2.112, run as: admin
      system.adapter.zigbee.0                 : zigbee                : io-fhem                                  - disabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.10.7   , installed 6.2.23 [Updatable]
    Adapter    "backitup"     : 2.8.4    , installed 2.5.6  [Updatable]
    Adapter    "ble"          : 0.13.4   , installed 0.13.4
    Adapter    "discovery"    : 4.2.0    , installed 3.2.0  [Updatable]
    Adapter    "fhem"         : 2.0.5    , installed 2.0.3  [Updatable]
    Adapter    "fritzdect"    : 2.4.1    , installed 2.3.1  [Updatable]
    Adapter    "homeconnect"  : 1.1.1    , installed 1.0.1  [Updatable]
    Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
    Controller "js-controller": 5.0.13   , installed 5.0.13
    Adapter    "socketio"     : 6.5.8    , installed 6.5.2  [Updatable]
    Adapter    "web"          : 6.1.5    , installed 5.5.3  [Updatable]
    Adapter    "ws"           : 2.5.8    , installed 2.5.3  [Updatable]
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.10 [Updatable]
    Objects and States
    Objects:        4796
    States:         4194
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://repo.saltproject.io/py3/debian/10/amd64/latest buster InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:6 https://download.webmin.com/download/repository sarge Release
    Reading package lists...
    Pending Updates: 2
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          23649      1/init
    tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          515393     4086/perl
    tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      999        520728     4302/perl
    tcp        0      0 0.0.0.0:48531           0.0.0.0:*               LISTEN      106        514537     4093/rpc.statd
    tcp        0      0 0.0.0.0:43957           0.0.0.0:*               LISTEN      0          165832     -
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17133      679/sshd
    tcp        0      0 0.0.0.0:7072            0.0.0.0:*               LISTEN      999        518479     4302/perl
    tcp6       0      0 :::42983                :::*                    LISTEN      0          165834     -
    tcp6       0      0 :::111                  :::*                    LISTEN      0          23655      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17135      679/sshd
    tcp6       0      0 :::6556                 :::*                    LISTEN      998        657078     5951/cmk-agent-ctl
    tcp6       0      0 :::47389                :::*                    LISTEN      106        514541     4093/rpc.statd
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15128      512/dhcpcd
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          23651      1/init
    udp        0      0 192.168.2.113:123       0.0.0.0:*                           109        20456      583/ntpd
    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          16992      583/ntpd
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          16988      583/ntpd
    udp        0      0 0.0.0.0:56477           0.0.0.0:*                           108        12093      362/avahi-daemon: r
    udp        0      0 0.0.0.0:51910           0.0.0.0:*                           0          165831     -
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12091      362/avahi-daemon: r
    udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          515394     4086/perl
    udp        0      0 127.0.0.1:877           0.0.0.0:*                           0          514531     4093/rpc.statd
    udp        0      0 0.0.0.0:56857           0.0.0.0:*                           106        514535     4093/rpc.statd
    udp6       0      0 :::35385                :::*                                108        12094      362/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          21979      1/init
    udp6       0      0 :::53872                :::*                                106        514539     4093/rpc.statd
    udp6       0      0 :::123                  :::*                                0          16985      583/ntpd
    udp6       0      0 :::5353                 :::*                                108        12092      362/avahi-daemon: r
    udp6       0      0 :::53242                :::*                                0          165833     -
    2023-10-12 04:42:14.144  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
    2023-10-12 04:47:14.127  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
    2023-10-12 04:52:14.129  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
    2023-10-12 04:57:14.131  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
    2023-10-12 05:02:14.132  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
    2023-10-12 05:07:14.134  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
    2023-10-12 05:12:14.137  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
    2023-10-12 05:17:14.136  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
    2023-10-12 05:22:14.140  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
    2023-10-12 05:27:14.141  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
    2023-10-12 05:32:14.143  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
    2023-10-12 05:37:14.146  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
    2023-10-12 05:42:14.147  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
    2023-10-12 05:44:01.807  - info: host.io-fhem received SIGTERM
    2023-10-12 05:44:01.820  - info: host.io-fhem stopInstance system.adapter.fhem.0 (force=false, process=true)
    2023-10-12 05:44:01.824  - info: host.io-fhem stopInstance system.adapter.zigbee.0 (force=false, process=false)
    2023-10-12 05:44:01.825  - info: host.io-fhem stopInstance system.adapter.backitup.1 (force=false, process=false)
    2023-10-12 05:44:01.830  - info: fhem.0 (5908) terminating
    2023-10-12 05:44:01.834  - info: host.io-fhem stopInstance system.adapter.fhem.0 send kill signal
    2023-10-12 05:44:01.833  - info: fhem.0 (5908) Terminated (NO_ERROR): Without reason
    2023-10-12 05:44:01.837  - info: fhem.0 (5908) Got terminate signal TERMINATE_YOURSELF
    2023-10-12 05:44:02.327  - info: fhem.0 (5908) terminating
    2023-10-12 05:44:02.638  - info: host.io-fhem instance system.adapter.fhem.0 terminated with code 0 (NO_ERROR)
    2023-10-12 05:44:02.640  - info: host.io-fhem All instances are stopped.
    2023-10-12 05:44:02.664  - info: host.io-fhem terminated
                            v.2023-10-10
             Icon name: computer
          Architecture: arm
    Kernel:                 armv7l
    Userland:               armhf
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     2
    Pending iob updates:    11
    Nodejs-Installation:    /usr/bin/nodejs         v18.18.1
                            /usr/bin/npm            10.2.0
                            /usr/bin/npx            10.2.0
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:           972M        142M        214M        3.0M        616M        763M
    Swap:           99M         57M         42M
    Total:         1.1G        199M        256M
    Active iob-Instances:   11
    ioBroker Core:          js-controller           5.0.13
                            admin                   6.2.23
    ioBroker Status:        iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects:                4796
    States:                 4194
    Size of iob-Database:
    8.0K    /opt/iobroker/iobroker-data/states.jsonl
    8.0K    /opt/iobroker/iobroker-data/states.json.migrated
    8.0K    /opt/iobroker/iobroker-data/states.json.bak.migrated
    DJMarc75D
    DJMarc75D
    DJMarc75
    @dlaurenz sagte in Update ioBroker klappt nicht:
    10.2.0
    Die NPM passt nicht zu NODE 18.18.1
    Lehrling seit 1975 !!!
    • DJMarc75D DJMarc75
      10.2.0
      D
      D
      DLaurenz
      @djmarc75
      laut iob diag ok....
                              /usr/bin/npm            10.2.0
                              /usr/bin/npx            10.2.0
      wie bekomme ich die hoch? bzw. welche version muss es sein?
        @dlaurenz
        Buster ist tot und du hampelst da als root herum und für 1GB läuft da auch viel zu viel komisches Zeug mit.
        Was ist saltprojext? Was macht webmin auf der Kiste? Was sind das für seltsame mounts?
        D
        D
        DLaurenz
        @thomas-braun sagte in Update ioBroker klappt nicht:
        @dlaurenz
        ich muss gerade schmunzeln während das update zu bulls-eye läuft....
        ihr liefert selber ein Image mit buster aus?
        Image basiert auf dem aktuellen Raspberry Pi OS (Buster) Lite
        https://forum.iobroker.net/topic/41520/raspberry-os-lite-image-for-with-iobroker
        • D DLaurenz
          2x raspbian, 2x debian buster, 2x iobroker, 2x Node 18, einer lässt sich updaten, der andere nicht.
          Wie wahrscheinlich ist es, dass es am OS liegt?
          Thomas BraunT
          Thomas BraunT
          Egal. Die Version ist obsolet... TOT.
          sudo apt install --reinstall nodejs
          • D DLaurenz
            @djmarc75
                                    /usr/bin/npm            10.2.0
                                    /usr/bin/npx            10.2.0
            CodierknechtC
            CodierknechtC
            Codierknecht
            Nö. Der sagt Dir lediglich, dass Node korrekt installiert ist.
            Der zur Node-Version passende NPM hat immer die "halbe" Versionsnummer.
            Node 18 also mit NPM 9. Node 20 dementsprechend NPM 10.
            Ohne @Thomas-Braun hier zu nahe treten oder seine Arbeit an der Ecke schmälern zu wollen: iob diag ist ein Hilfsmittel ... mehr nicht.
            Es nimmt einem nicht die Arbeit ab.
            "hampelst"....
            Das allererste was ein Linux-Admin lernt: Man agiert im System nicht als User "root".
            Alles was man mit der Hand am Arm im System treibt, wird allerhöchstens mit temporären Rechten per "sudo" ausgeführt. Da mit "root" unterwegs zu sein, ist reine Bequemlichkeit und führt in aller Regel zu Fehlern.
            Es gibt da so einen schönen Spruch, der sinngemäß lautet: "Nur ausgewiesene Profis sollten sich als root anmelden - und die werden es nicht tun"
            Ansonsten wurde ja schon erwähnt:
            Ein Pi3 mit 1 GB RAM ist die absolute Minimalausstattung und mittlerweile fast nicht mehr sinnvoll (produktiv) einsetzbar. Da noch zusätzliche Verwaltungstools einzusetzen verbietet sich fast von selbst.
            Debian "buster" liegt inzwischen 2 Versionen zurück und ist definitiv tot. Inzwischen gibt's auch offiziell "bookworm" für den Pi.
            HmIP|ZigBee|Tasmota|Unifi
            Zabbix Certified Specialist
            Thomas BraunT D 2 Antworten Letzte Antwort
            • CodierknechtC Codierknecht
              "hampelst"....
              Thomas BraunT
              Thomas BraunT
              @codierknecht sagte in Update ioBroker klappt nicht:
              Mehr soll es auch nicht sein.
              • D DLaurenz
                @dlaurenz
                datum gelesen?
                Das war 2021
                  datum gelesen?
                  Das war 2021
                  D
                  D
                  DLaurenz
                  genau, deswegen ist es auch offiziell verlinkt.... wenn etwas nicht mehr freigegeben oder supported ist, gehört es entsprechend makiert, macht man so...
                  • D DLaurenz
                    Wenn du den Download nutzen würdest, würdest du ein aktuelle Image bekommen, kein Buster.
                    der Beitrag ist historisch. Den lässt man so.
                      "hampelst"....
                      D
                      D
                      DLaurenz
                      @codierknecht
                      können wir mal über die sinn oder unsinnhaftigkeit bei mir aufhören zu sprechen und uns dem problem widmen? bisher hat sich keiner die mühe gemacht, zu fragen warum dinge so laufen sondern es wird wie üblich der oberlehrer rausgekehrt...
                      ich kenn linux schon seit dem es noch bookware war, ich weiß also was ich tue oder nicht tue... das dürften so ca. 25 jahre sein...
                      danke!
                        D
                        D
                        DLaurenz
                        so erledigt:
                        root@io-fhem:~# apt install --reinstall nodejs
                        Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                          libdns-export1110 libisc-export1105 openresolv
                        Verwenden Sie »apt autoremove«, um sie zu entfernen.
                        0 aktualisiert, 0 neu installiert, 1 erneut installiert, 0 zu entfernen und 1 nicht aktualisiert.
                        Es müssen noch 0 B von 26,7 MB an Archiven heruntergeladen werden.
                        Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
                        (Lese Datenbank ... 97255 Dateien und Verzeichnisse sind derzeit installiert.)
                        Vorbereitung zum Entpacken von .../nodejs_18.18.1-1nodesource1_armhf.deb ...
                        Detected old npm client, removing...
                        Entpacken von nodejs (18.18.1-1nodesource1) über (18.18.1-1nodesource1) ...
                        nodejs (18.18.1-1nodesource1) wird eingerichtet ...
                        Trigger für man-db (2.9.4-2) werden verarbeitet ...
                        Prüfe Prozesse...
                        Prüfe Kandidaten...
                        Scanning processor microcode...
                        Prüfe Linux-Kernel...
                        Der laufende Kernel ist aktuell.
                        Fehler beim Ermitteln von verfügbaren Prozessor Mikrocode-Upgrades.
                        Dienste werden neu gestartet...
                         systemctl restart iobroker.service
                        Es müssen keine Container neu gestartet werden.
                        Es gibt keine Nutzer-Sitzungen mit veralteten Prozessen.
                        root@io-fhem:~# npm -v
                        9.8.1
                        übrigens OS auch aktualisiert:
                        root@io-fhem:~# cat /etc/os-release
                        PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                        NAME="Raspbian GNU/Linux"
                        VERSION_ID="11"
                        VERSION="11 (bullseye)"
                        VERSION_CODENAME=bullseye
                        ID=raspbian
                        ID_LIKE=debian
                        HOME_URL="http://www.raspbian.org/"
                        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                        wie zu erwarten ist das alles NICHT DAS PROBLEM...
                        root@io-fhem:~# iob upgrade fritzdect --debug
                        This upgrade of "fritzdect" will introduce the following changes:
                        -> 2.4.1:
                        correctionts reported by adapter-checker
                        -> 2.4.0:
                        new function for routines, correction for templates
                        Would you like to upgrade fritzdect from @2.3.1 to @2.4.1 now? [(y)es, (n)o]: y
                        Update fritzdect from @2.3.1 to @2.4.1
                        NPM version: 9.8.1
                        Installing iobroker.fritzdect@2.4.1... (System call)
                        npm ERR! code ENOTEMPTY
                        npm ERR! syscall rename
                        npm ERR! path /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
                        npm ERR! dest /opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo
                        npm ERR! errno -39
                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket' -> '/opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo'
                        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-12T09_12_07_605Z-debug-0.log
                        host.io-fhem Cannot install iobroker.fritzdect@2.4.1: 217
                        achso - zur Auslastung des Systems: (die letzte 35 Tage)
                        2023-10-12 11_16_43-Checkmk Local site homelab - Service graphs CPU utilization, io-fhem.png 2023-10-12 11_16_08-Checkmk Local site homelab - Service graphs io-fhem, Memory.png
                        Last ist immer nur wenn Sicherungen laufen....
                        der macht genau 2 Dinge - zigbee gateway & fhem host (für selve rolläden) das war es dann auch schon
                        Könnten wir dann mit der analyse starten? das wäre fein
                        Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                        • D DLaurenz
                          so erledigt:
                          Prüfe Prozesse...
                          Prüfe Kandidaten...
                          9.8.1
                          VERSION_ID="11"
                          ID=raspbian
                          ID_LIKE=debian
                          -> 2.4.1:
                          -> 2.4.0:
                          NPM version: 9.8.1
                          npm ERR! errno -39
                          Thomas BraunT
                          Thomas BraunT
                          Das hat auch NIEMAND behauptet.
                          • D DLaurenz
                            @codierknecht
                            danke!
                            CodierknechtC
                            CodierknechtC
                            Codierknecht
                            Warum fragst Du dann hier nach?
                            Da Probleme beim Update des ioBroker nach meiner Erfahrung nicht an ihm sondern am Unterbau liegen, sollte das Beheben der Ursache ja kein Problem sein.
                            Ich bin dann hier raus.
                            Viel Erfolg!
                            • D DLaurenz
                              so erledigt:
                              Prüfe Prozesse...
                              Prüfe Kandidaten...
                              9.8.1
                              VERSION_ID="11"
                              ID=raspbian
                              ID_LIKE=debian
                              -> 2.4.1:
                              -> 2.4.0:
                              NPM version: 9.8.1
                              npm ERR! errno -39
                              bitte nicht als root arbeiten. Das kann alle möglichen Rechte verbiegen.
                              Bitte iob fix als user ausführen in der Hoffnung, dass der Fixer die Rechte wiederherstellen kann.
                              • D DLaurenz
                                so erledigt:
                                Prüfe Prozesse...
                                Prüfe Kandidaten...
                                9.8.1
                                VERSION_ID="11"
                                ID=raspbian
                                ID_LIKE=debian
                                -> 2.4.1:
                                -> 2.4.0:
                                NPM version: 9.8.1
                                npm ERR! errno -39
                                Thomas BraunT
                                Thomas BraunT
                                Warum auch immer.
                                Das bauen von serialport geht in die Hose:
                                npm ERR! make: *** [bindings.target.mk:114: Release/obj.target/bindings/src/serialport.o] Fehler 1
                                npm ERR! gyp ERR! build error
                                npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
                                Warum auch immer. Vielleicht wegen alter Versionen vom gcc...
                                Installier den js-controller nochmal drüber.
                                cd /opt/iobroker
                                sudo -H -u iobroker npm install iobroker.js-controller
                                • D
                                  D
                                  DLaurenz
                                  danke...
                                  geht auch nicht weiter
                                  root@io-fhem:~# gcc -v
                                  Using built-in specs.
                                  COLLECT_GCC=gcc
                                  COLLECT_LTO_WRAPPER=/usr/lib/gcc/arm-linux-gnueabihf/10/lto-wrapper
                                  Target: arm-linux-gnueabihf
                                  Configured with: ../src/configure -v --with-pkgversion='Raspbian 10.2.1-6+rpi1' --with-bugurl=file:///usr/share/doc/gcc-10/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++,m2 --prefix=/usr --with-gcc-major-version-only --program-suffix=-10 --program-prefix=arm-linux-gnueabihf- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-bootstrap --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libitm --disable-libquadmath --disable-libquadmath-support --enable-plugin --with-system-zlib --enable-libphobos-checking=release --with-target-system-zlib=auto --enable-objc-gc=auto --enable-multiarch --disable-sjlj-exceptions --with-arch=armv6 --with-fpu=vfp --with-float=hard --disable-werror --enable-checking=release --build=arm-linux-gnueabihf --host=arm-linux-gnueabihf --target=arm-linux-gnueabihf
                                  Thread model: posix
                                  Supported LTO compression algorithms: zlib zstd
                                  gcc version 10.2.1 20210110 (Raspbian 10.2.1-6+rpi1)
                                  hier der output.... lösche ich dann das jeweiliger verzeichnis.... land ich wieder da
                                  iob fix
                                  root@io-fhem:~# cd /opt/iobroker
                                  root@io-fhem:/opt/iobroker# su - pi
                                  pi@io-fhem:~ $ cd /opt/iobroker/
                                  pi@io-fhem:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                                  npm ERR! errno -39
                                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-12T09_59_41_164Z-debug-0.log
                                  hab jetzt noch mal iob fix laufen lassen und dann nochmal
                                  pi@io-fhem:/opt/iobroker $ iob fix
                                  library: loaded
                                  OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                  OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                  OK:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                                  Ign:4 https://download.webmin.com/download/repository sarge InRelease
                                  OK:5 https://repo.saltproject.io/salt/py3/debian/11/arm64/latest bullseye InRelease
                                  Installed gcc-c++
                                  Done.
                                  Autostart enabled!
                                  jetzt ist es etwas anders... was ist mit den ganzen depricated warnungen?
                                  npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                  npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                  npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                  npm WARN cleanup Failed to remove some directories [
                                  npm WARN cleanup   [
                                  npm WARN cleanup     '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket',
                                  npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/build/Release'] {
                                  npm WARN cleanup       errno: -39,
                                  npm WARN cleanup       code: 'ENOTEMPTY',
                                  npm WARN cleanup       syscall: 'rmdir',
                                  npm WARN cleanup       path: '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/build/Release'
                                  npm WARN cleanup     }
                                  npm WARN cleanup   ],
                                  npm WARN cleanup   [
                                  npm WARN cleanup     }
                                  npm WARN cleanup   ]
                                  npm WARN cleanup ]
                                  npm ERR! code 1
                                  npm ERR! path /opt/iobroker/node_modules/@serialport/bindings
                                  npm ERR! command failed
                                  npm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                                  npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird betreten
                                  npm ERR!   CXX(target) Release/obj.target/bindings/src/serialport.o
                                  npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird verlassen
                                  npm ERR! gyp info it worked if it ends with ok
                                  npm ERR! gyp info using node-gyp@9.4.0
                                  npm ERR! gyp info using node@18.18.1 | linux | arm
                                  npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
                                  npm ERR! gyp info spawn /usr/bin/python3
                                  npm ERR! gyp info spawn args [
                                  npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
                                  npm ERR! gyp info spawn args   'binding.gyp',
                                  npm ERR! gyp info spawn args   '-f',
                                  npm ERR! gyp info spawn args   'make',
                                  npm ERR! gyp info spawn args   '-I',
                                  npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/@serialport/bindings/build/config.gypi',
                                  npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
                                  npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.1/include/node/common.gypi',
                                  npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
                                  npm ERR! gyp info spawn args   '-Dvisibility=default',
                                  npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.1',
                                  npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
                                  npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.1/<(target_arch)/node.lib',
                                  npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/@serialport/bindings',
                                  npm ERR! gyp info spawn args   '-Dnode_engine=v8',
                                  npm ERR! gyp info spawn args   '--depth=.',
                                  npm ERR! gyp info spawn args   '--no-parallel',
                                  npm ERR! gyp info spawn args   '--generator-output',
                                  npm ERR! gyp info spawn args   'build',
                                  npm ERR! gyp info spawn args   '-Goutput_dir=.'
                                  npm ERR! gyp info spawn args ]
                                  npm ERR! gyp info spawn make
                                  npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
                                  npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                                  npm ERR! ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  npm ERR!    78 |   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                                  npm ERR!       |                                                   ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                  npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                                  npm ERR! ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  npm ERR!   135 |   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                                  npm ERR!       |                                                     ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                  npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                                  npm ERR! ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  npm ERR!   175 |   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                                  npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                                  npm ERR! ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  npm ERR!   215 |   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                                  npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                                  npm ERR! ../src/serialport.cpp:270:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  npm ERR!   270 |   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                                  npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                                  npm ERR! ../src/serialport.cpp:314:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  npm ERR!   314 |   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                                  npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
                                  npm ERR! ../src/serialport.cpp:329:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
                                  npm ERR!   329 |     results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
                                  npm ERR!       |        ^
                                  npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-array-buffer.h:13,
                                  npm ERR!                  from /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8.h:24,
                                  npm ERR!                  from /home/iobroker/.cache/node-gyp/18.18.1/include/node/node.h:73,
                                  npm ERR!                  from ../../../nan/nan.h:62,
                                  npm ERR!                  from ../src/./serialport.h:6,
                                  npm ERR!                  from ../src/serialport.cpp:1:
                                  npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:244:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’
                                  npm ERR!   244 |   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,
                                  npm ERR!       |                                     ^~~
                                  npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:244:37: note:   candidate expects 3 arguments, 2 provided
                                  npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:247:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’
                                  npm ERR!   247 |   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
                                  npm ERR!       |                                     ^~~
                                  npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:247:37: note:   candidate expects 3 arguments, 2 provided
                                  npm ERR! ../src/serialport.cpp:330:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
                                  npm ERR!   330 |     results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
                                  npm ERR!       |        ^
                                  npm ERR!       |                                     ^~~
                                  npm ERR!       |                                     ^~~
                                  npm ERR! ../src/serialport.cpp:331:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
                                  npm ERR!   331 |     results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
                                  npm ERR!       |        ^
                                  npm ERR!       |                                     ^~~
                                  npm ERR!       |                                     ^~~
                                  npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                                  npm ERR! ../src/serialport.cpp:363:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  npm ERR!   363 |   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                                  npm ERR!       |                                                          ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                  npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
                                  npm ERR! ../src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)’
                                  npm ERR!   378 |     results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
                                  npm ERR!       |        ^
                                  npm ERR!       |                                     ^~~
                                  npm ERR!       |                                     ^~~
                                  npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                                  npm ERR! ../src/serialport.cpp:409:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  npm ERR!   409 |   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                                  npm ERR! ../src/serialport.cpp: At global scope:
                                  npm ERR! ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                                  npm ERR!   430 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                                  npm ERR!       |                            ^
                                  npm ERR! ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                                  npm ERR!   449 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                                  npm ERR!       |                              ^
                                  npm ERR! In file included from ../../../nan/nan.h:62,
                                  npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/node.h:1014:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                  npm ERR!  1014 |       (node::addon_register_func) (regfunc),                          \
                                  npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/node.h:1048:3: note: in expansion of macro ‘NODE_MODULE_X’
                                  npm ERR!  1048 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                  npm ERR! ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
                                  npm ERR!   483 | NODE_MODULE(serialport, init);
                                  npm ERR! gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:203:23)
                                  npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
                                  npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                                  npm ERR! gyp ERR! System Linux 5.10.103-v7+
                                  npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                  npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
                                  npm ERR! gyp ERR! node -v v18.18.1
                                  npm ERR! gyp ERR! node-gyp -v v9.4.0
                                  npm ERR! gyp ERR! not ok
                                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-12T10_03_57_827Z-debug-0.log
                                  Der witz ist, die datei ist während des befehls erstellt worden:
                                  pi@io-fhem:/opt/iobroker $ ls -la /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/build/Release
                                  insgesamt 72
                                  drwxrwxr-x+ 2 iobroker iobroker  4096 12. Okt 12:06 .
                                  drwxrwxr-x+ 3 iobroker iobroker  4096 12. Okt 12:06 ..
                                  -rwxrwxr-x+ 2 iobroker iobroker 62052 12. Okt 12:06 bluetooth_hci_socket.node
                                    Warum auch immer.
                                    cd /opt/iobroker
                                    DJMarc75D
                                    DJMarc75D
                                    DJMarc75
                                    https://forum.iobroker.net/topic/69038/iobroker-fix/5
                                    dort scheint u.U. das selbe Problem zu sein - kann mich aber auch täuschen
                                    • D
                                      D
                                      DLaurenz
                                      @djmarc75
                                      die meldung hatte ich auch gesehen - gibt aber kein gcc-c++ paket unter debian
                                      • D DLaurenz
                                        danke...
                                        COLLECT_GCC=gcc
                                        Thread model: posix
                                        iob fix
                                        npm ERR! errno -39
                                        library: loaded
                                        Installed gcc-c++
                                        Done.
                                        Autostart enabled!
                                        npm WARN cleanup   [
                                        npm WARN cleanup     }
                                        npm WARN cleanup   ],
                                        npm WARN cleanup   [
                                        npm WARN cleanup     }
                                        npm WARN cleanup   ]
                                        npm WARN cleanup ]
                                        npm ERR! code 1
                                        npm ERR!       |        ^
                                        npm ERR!       |                                     ^~~
                                        npm ERR!       |                                     ^~~
                                        npm ERR!       |        ^
                                        npm ERR!       |                                     ^~~
                                        npm ERR!       |                                     ^~~
                                        npm ERR!       |        ^
                                        npm ERR!       |                                     ^~~
                                        npm ERR!       |                                     ^~~
                                        npm ERR!       |        ^
                                        npm ERR!       |                                     ^~~
                                        npm ERR!       |                                     ^~~
                                        npm ERR!       |                            ^
                                        npm ERR!       |                              ^
                                        insgesamt 72
                                        @dlaurenz enotempty und code 25 erinnert mich an https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update
                                          D
                                          D
                                          DLaurenz
                                          auch schon x-mal gemacht...
                                          pi@io-fhem:~ $ find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec echo {} \;
                                          pi@io-fhem:~ $ sudo -H -u iobroker npm install iobroker.js-controller
                                          npm notice
                                          npm notice New major version of npm available! 9.8.1 -> 10.2.0
                                          npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.2.0
                                          npm notice Run npm install -g npm@10.2.0 to update!
                                          npm notice
                                          npm ERR! code EACCES
                                          npm ERR! syscall mkdir
                                          npm ERR! path /home/pi/node_modules
                                          npm ERR! errno -13
                                          npm ERR! Error: EACCES: permission denied, mkdir '/home/pi/node_modules'
                                          npm ERR!  [Error: EACCES: permission denied, mkdir '/home/pi/node_modules'] {
                                          npm ERR!   errno: -13,
                                          npm ERR!   code: 'EACCES',
                                          npm ERR!   syscall: 'mkdir',
                                          npm ERR!   path: '/home/pi/node_modules'
                                          npm ERR! }
                                          npm ERR!
                                          npm ERR! The operation was rejected by your operating system.
                                          npm ERR! It is likely you do not have the permissions to access this file as the current user
                                          npm ERR!
                                          npm ERR! If you believe this might be a permissions issue, please double-check the
                                          npm ERR! permissions of the file and its containing directories, or try running
                                          npm ERR! the command again as root/Administrator.
                                          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-12T10_31_49_005Z-debug-0.log
                                          npm WARN cleanup   [
                                          npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib'] {
                                          npm WARN cleanup       path: '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib'
                                          npm WARN cleanup     }
                                          npm WARN cleanup   ],
                                          npm WARN cleanup   [
                                          npm WARN cleanup     }
                                          npm WARN cleanup   ]
                                          npm WARN cleanup ]
                                          npm ERR! code 1
                                          npm ERR!       |        ^
                                          npm ERR!       |                                     ^~~
                                          npm ERR!       |                                     ^~~
                                          npm ERR!       |        ^
                                          npm ERR!       |                                     ^~~
                                          npm ERR!       |                                     ^~~
                                          npm ERR!       |        ^
                                          npm ERR!       |                                     ^~~
                                          npm ERR!       |                                     ^~~
                                          npm ERR!       |        ^
                                          npm ERR!       |                                     ^~~
                                          npm ERR!       |                                     ^~~
                                          npm ERR!       |                            ^
                                          npm ERR!       |                              ^
                                          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-12T10_33_16_805Z-debug-0.log
                                          ? Thomas BraunT HomoranH 3 Antworten Letzte Antwort
