  4. Update ioBroker klappt nicht - gelöst durch neuinstallation
42 Beiträge 7 Kommentatoren 5.7k Aufrufe 4 Beobachtet
  • D DLaurenz
    @dlaurenz
    root@io-fhem:~# find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \; &> /dev/null
    root@io-fhem:~#
    root@io-fhem:~# cd /opt/iobroker/
    root@io-fhem:/opt/iobroker# npm list
    iobroker.inst@2.0.3 /opt/iobroker
    ├── colors@1.4.0
    ├── fs-extra@7.0.1
    ├── iobroker.admin@6.2.23
    ├── iobroker.backitup@2.5.6
    ├── iobroker.ble@0.13.4
    ├── iobroker.discovery@3.2.0
    ├── iobroker.fhem@2.0.3
    ├── iobroker.flot@1.12.0
    ├── iobroker.fritzdect@2.3.1
    ├── iobroker.homeconnect@1.0.1
    ├── iobroker.info@1.9.26
    ├── iobroker.js-controller@4.0.24
    ├── iobroker.simple-api@2.7.2
    ├── iobroker.socketio@6.5.2
    ├── iobroker.vis@1.4.16
    ├── iobroker.web@5.5.3
    ├── iobroker.ws@2.5.3
    ├── iobroker.zigbee@1.8.10
    ├── iobroker@2.0.3
    ├── semver@5.7.2
    ├── serialport@7.1.5
    └── yargs@7.1.2
    root@io-fhem:/opt/iobroker# iob upgrade fritzdect --debug
    This upgrade of "fritzdect" will introduce the following changes:
    -> 2.4.1:
    correctionts reported by adapter-checker
    -> 2.4.0:
    new function for routines, correction for templates
    Would you like to upgrade fritzdect from @2.3.1 to @2.4.1 now? [(y)es, (n)o]: y
    Update fritzdect from @2.3.1 to @2.4.1
    NPM version: 10.2.0
    Installing iobroker.fritzdect@2.4.1... (System call)
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN cleanup Failed to remove some directories [
    npm WARN cleanup   [
    npm WARN cleanup     '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket',
    npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/build/Release'] {
    npm WARN cleanup       errno: -39,
    npm WARN cleanup       code: 'ENOTEMPTY',
    npm WARN cleanup       syscall: 'rmdir',
    npm WARN cleanup       path: '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/build/Release'
    npm WARN cleanup     }
    npm WARN cleanup   ],
    npm WARN cleanup   [
    npm WARN cleanup     }
    npm WARN cleanup   ]
    npm WARN cleanup ]
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/@serialport/bindings
    npm ERR! command failed
    npm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
    npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird betreten
    npm ERR!   CXX(target) Release/obj.target/bindings/src/serialport.o
    npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird verlassen
    npm ERR! gyp info it worked if it ends with ok
    npm ERR! gyp info using node-gyp@9.4.0
    npm ERR! gyp info using node@18.18.1 | linux | arm
    npm ERR! gyp info find Python using Python version 3.7.3 found at "/usr/bin/python3"
    npm ERR! gyp info spawn /usr/bin/python3
    npm ERR! gyp info spawn args [
    npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
    npm ERR! gyp info spawn args   'binding.gyp',
    npm ERR! gyp info spawn args   '-f',
    npm ERR! gyp info spawn args   'make',
    npm ERR! gyp info spawn args   '-I',
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/@serialport/bindings/build/config.gypi',
    npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
    npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.1/include/node/common.gypi',
    npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
    npm ERR! gyp info spawn args   '-Dvisibility=default',
    npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.1',
    npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
    npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.1/<(target_arch)/node.lib',
    npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/@serialport/bindings',
    npm ERR! gyp info spawn args   '-Dnode_engine=v8',
    npm ERR! gyp info spawn args   '--depth=.',
    npm ERR! gyp info spawn args   '--no-parallel',
    npm ERR! gyp info spawn args   '--generator-output',
    npm ERR! gyp info spawn args   'build',
    npm ERR! gyp info spawn args   '-Goutput_dir=.'
    npm ERR! gyp info spawn args ]
    npm ERR! gyp info spawn make
    npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
    npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    npm ERR! ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    npm ERR!        ^~~~~~~~~~~~~
    npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    npm ERR! ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    npm ERR!        ^~~~~~~~~~~~~~~
    npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    npm ERR! ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    npm ERR! ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    npm ERR! ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    npm ERR! ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
    npm ERR! ../src/serialport.cpp:329:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
    npm ERR!      results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
    npm ERR!        ^
    npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-array-buffer.h:13,
    npm ERR!                  from /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8.h:24,
    npm ERR!                  from /home/iobroker/.cache/node-gyp/18.18.1/include/node/node.h:73,
    npm ERR!                  from ../../../nan/nan.h:62,
    npm ERR!                  from ../src/./serialport.h:6,
    npm ERR!                  from ../src/serialport.cpp:1:
    npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:244:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’
    npm ERR!    V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,
    npm ERR!                                      ^~~
    npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:244:37: note:   candidate expects 3 arguments, 2 provided
    npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:247:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’
    npm ERR!    V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
    npm ERR!                                      ^~~
    npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/v8-object.h:247:37: note:   candidate expects 3 arguments, 2 provided
    npm ERR! ../src/serialport.cpp:330:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
    npm ERR!      results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
    npm ERR!        ^
    npm ERR!                                      ^~~
    npm ERR!                                      ^~~
    npm ERR! ../src/serialport.cpp:331:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
    npm ERR!      results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
    npm ERR!        ^
    npm ERR!                                      ^~~
    npm ERR!                                      ^~~
    npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    npm ERR! ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    npm ERR!        ^~~~~~~~~~~~~~~~~~~~
    npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
    npm ERR! ../src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)’
    npm ERR!      results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
    npm ERR!        ^
    npm ERR!                                      ^~~
    npm ERR!                                      ^~~
    npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    npm ERR! ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
    npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    npm ERR! ../src/serialport.cpp: At global scope:
    npm ERR! ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
    npm ERR!  SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    npm ERR!                             ^
    npm ERR! ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
    npm ERR!  SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    npm ERR!                               ^
    npm ERR! In file included from ../../../nan/nan.h:62,
    npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/node.h:1014:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
    npm ERR!        (node::addon_register_func) (regfunc),                          \
    npm ERR!                                            ^
    npm ERR! /home/iobroker/.cache/node-gyp/18.18.1/include/node/node.h:1048:3: note: in expansion of macro ‘NODE_MODULE_X’
    npm ERR!    NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    npm ERR! ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
    npm ERR!  NODE_MODULE(serialport, init);
    npm ERR! make: *** [bindings.target.mk:114: Release/obj.target/bindings/src/serialport.o] Fehler 1
    npm ERR! gyp ERR! build error
    npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
    npm ERR! gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:203:23)
    npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
    npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
    npm ERR! gyp ERR! System Linux 5.10.103-v7+
    npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
    npm ERR! gyp ERR! node -v v18.18.1
    npm ERR! gyp ERR! node-gyp -v v9.4.0
    npm ERR! gyp ERR! not ok
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-12T04_24_27_413Z-debug-0.log
    Adapter "system.adapter.vis.0" restarted.
    upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
    upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
    upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
    upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
    upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
    Thomas BraunT
    Thomas BraunT
    @dlaurenz
    Buster ist tot und du hampelst da als root herum und für 1GB läuft da auch viel zu viel komisches Zeug mit.
    Was ist saltprojext? Was macht webmin auf der Kiste? Was sind das für seltsame mounts?
    ? D 3 Antworten Letzte Antwort
      @dlaurenz
      @thomas-braun sagte in Update ioBroker klappt nicht:
      saltprojext
      Moin,
      das ist ein Automatisierungstool salt, mit Client/Server, Du schreibst Dir Kochbücher für die verschiedenen Nodes, die Du dann einfach von einer zentralen Stelle, verteilen kannst oder der Node holt sich die Informationen mittel Pull vom Server.
      Ansible, Terraform, Puppet, Chef und Salt
      Bernd
        @dlaurenz
        D
        D
        DLaurenz
        Salt ist eine Konfiguration Management und der RPI macht FHEM & Zigbee... die Mounts sind für Backups
        willst du mir sagen dass ein update auf bulls-eye das problem behebt?
        deine anmerkungen gehen überhaupt nicht in richtung lösungsfindung
        • D DLaurenz
          Thomas BraunT
          Thomas BraunT
          @dlaurenz sagte in Update ioBroker klappt nicht:
          Nö. Aber verschafft erstmal eine sinnvolle Basis für weiteres.
          Warum nicht?
          D 2 Antworten Letzte Antwort
            Warum nicht?
            D
            D
            DLaurenz
            gut mache ich - melde mich
              Warum nicht?
              D
              D
              DLaurenz
              "hampelst"....
              übirgens habe ich noch einen buster-pi, der lässt sich einwandfrei updaten und sieht genauso aus...
              (salt, webmin, root)
              ich betreibe das ganze schon seit den anfangstagen von iobroker
              • D DLaurenz
                "hampelst"....
                Thomas BraunT
                Thomas BraunT
                @dlaurenz
                Und das bedeutet jetzt für den Patienten genau was?
                  @dlaurenz
                  D
                  D
                  DLaurenz
                  2x raspbian, 2x debian buster, 2x iobroker, 2x Node 18, einer lässt sich updaten, der andere nicht.
                  Wie wahrscheinlich ist es, dass es am OS liegt?
                  • D DLaurenz
                    gern
                    pi@io-fhem:~ $ iob fix
                    library: loaded
                    Library version=2023-10-10
                        Welcome to the ioBroker installation fixer!
                        Script version: 2023-04-02
                        You might need to enter your password a couple of times.
                        Installing prerequisites (1/5)
                    OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                    OK:2 http://archive.raspberrypi.org/debian buster InRelease
                    OK:3 https://repo.saltproject.io/py3/debian/10/amd64/latest buster InRelease
                    OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Ign:5 https://download.webmin.com/download/repository sarge InRelease
                    OK:6 https://download.webmin.com/download/repository sarge Release
                    E: Paket gcc-c+ kann nicht gefunden werden.
                    E: Mittels regulärem Ausdruck »gcc-c+« konnte kein Paket gefunden werden.
                    Installed gcc-c++
                        Checking ioBroker user and directory permissions (2/5)
                        Check and cleanup npm temporary directories (3/5)
                    Done.
                        Database maintenance (4/5)
                    Checking for uncompressed JSONL databases... This might take a while!
                    No relevant JSONL files found to compress, skip
                        Checking autostart (5/5)
                    Enabling autostart...
                    Autostart enabled!
                        Your installation was fixed successfully
                        Run iobroker start to start ioBroker again!
                    und danach iob diag:
                    pi@io-fhem:~ $ iob diag
                    *** iob diag is starting up, please wait ***
                    The state system.host.io-fhem.versions.nodeNewestNext was not found!
                    The state system.host.io-fhem.versions.npmNewestNext was not found!
                    The state system.host.io-fhem.versions.nodeCurrent was not found!
                    *** ioBroker Diagnosis ***
                    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                    https://forum.iobroker.net
                    Just copy and paste the Summary Page, including the ``` characters at start and end.
                    It helps us to help you!
                    Press any key to continue
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                       Static hostname: io-fhem
                             Icon name: computer
                      Operating System: Raspbian GNU/Linux 10 (buster)
                                Kernel: Linux 5.10.103-v7+
                          Architecture: arm
                    Model           : Raspberry Pi 3 Model B Rev 1.2
                    Docker          : false
                    Virtualization  : none
                    Kernel          : armv7l
                    Userland        : armhf
                    Systemuptime and Load:
                     05:49:13 up 11:03,  1 user,  load average: 0.74, 0.52, 0.35
                    CPU threads: 4
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                    *** Time and Time Zones ***
                                   Local time: Thu 2023-10-12 05:49:13 CEST
                               Universal time: Thu 2023-10-12 03:49:13 UTC
                                     RTC time: n/a
                                  NTP service: inactive
                              RTC in local TZ: no
                    *** User and Groups ***
                    pi
                    /home/pi
                    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                    *** X-Server-Setup ***
                    X-Server:       false
                    Desktop:
                    Terminal:
                    Boot Target:    multi-user.target
                    *** MEMORY ***
                    Mem:           972M        142M        222M        3.0M        607M        762M
                    Swap:           99M         57M         42M
                    Total:         1.1G        200M        265M
                              972 M total memory
                              142 M used memory
                              458 M active memory
                              168 M inactive memory
                              222 M free memory
                              130 M buffer memory
                              476 M swap cache
                               99 M total swap
                               57 M used swap
                               42 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FAILED SERVICES ***
                      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                    * iobroker.service loaded failed failed ioBroker Server
                    1 loaded units listed. Pass --all to see loaded but inactive units, too.
                    To show all installed unit files use 'systemctl list-unit-files'.
                    *** FILESYSTEM ***
                    Filesystem                         Type      Size  Used Avail Use% Mounted on
                    /dev/root                          ext4       30G  7.6G   20G  28% /
                    devtmpfs                           devtmpfs  454M     0  454M   0% /dev
                    tmpfs                              tmpfs     487M  8.0K  487M   1% /dev/shm
                    tmpfs                              tmpfs     487M   13M  474M   3% /run
                    tmpfs                              tmpfs     5.0M  4.0K  5.0M   1% /run/lock
                    tmpfs                              tmpfs     487M     0  487M   0% /sys/fs/cgroup
                    /dev/mmcblk0p1                     vfat       43M   25M   18M  59% /boot
                    tmpfs                              tmpfs      98M     0   98M   0% /run/user/0
                    fs01.samba.laurenz.ws:/BACKUPS     nfs        11T  7.2T  3.4T  69% /autofs/backup
                    fs04.samba.laurenz.ws:/SOFTWARE    nfs       8.2T  5.9T  2.3T  73% /autofs/software
                    fs04.samba.laurenz.ws:/MAILFUJITSU nfs       8.2T  5.9T  2.3T  73% /autofs/mailfujitsu
                    fs01.samba.laurenz.ws:/NFS         nfs        11T  7.2T  3.4T  69% /autofs/nfs
                    [Wed Oct 11 18:45:40 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=1bf224e2-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                    [Wed Oct 11 18:45:43 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                    [Wed Oct 11 18:45:43 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                    [Wed Oct 11 18:45:45 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                    [Wed Oct 11 23:32:51 2023] [<802b0ee8>] (filemap_fault) from [<8042d260>] (ext4_filemap_fault+0x38/0x4c)
                    [Wed Oct 11 23:32:51 2023] [<8042d228>] (ext4_filemap_fault) from [<802e8900>] (__do_fault+0x48/0x14c)
                    TARGET                SOURCE                             FSTYPE OPTIONS
                    /                     /dev/mmcblk0p2                     ext4   rw,noatime
                    |-/sys/fs/bpf         none                               bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                    |-/boot               /dev/mmcblk0p1                     vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    |-/autofs/software    fs04.samba.laurenz.ws:/SOFTWARE    nfs    rw,relatime,sync,vers=3,rsize=32768,wsize=32768,namlen=255,hard,proto=tcp,timeo=14,retrans=2,sec=sys,mountaddr=192.168.2.74,mountvers=3,mountport=30000,mountproto=udp,local_lock=none,addr=192.168.2.74
                    |-/autofs/mailfujitsu fs04.samba.laurenz.ws:/MAILFUJITSU nfs    rw,relatime,sync,vers=3,rsize=32768,wsize=32768,namlen=255,hard,proto=tcp,timeo=14,retrans=2,sec=sys,mountaddr=192.168.2.74,mountvers=3,mountport=30000,mountproto=udp,local_lock=none,addr=192.168.2.74
                    |-/autofs/backup      fs01.samba.laurenz.ws:/BACKUPS     nfs    rw,relatime,sync,vers=3,rsize=32768,wsize=32768,namlen=255,hard,proto=tcp,timeo=14,retrans=2,sec=sys,mountaddr=192.168.2.72,mountvers=3,mountport=30000,mountproto=udp,local_lock=none,addr=192.168.2.72
                    `-/autofs/nfs         fs01.samba.laurenz.ws:/NFS         nfs    rw,relatime,sync,vers=3,rsize=32768,wsize=32768,namlen=255,hard,proto=tcp,timeo=14,retrans=2,sec=sys,mountaddr=192.168.2.72,mountvers=3,mountport=30000,mountproto=udp,local_lock=none,addr=192.168.2.72
                    /var:
                    1.7G    /var/
                    881M    /var/cache
                    705M    /var/cache/apt
                    645M    /var/cache/apt/archives
                    583M    /var/mail
                    Archived and active journals take up 12.1M in the file system.
                    /opt/iobroker/backups:
                    4.0K    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    5.2M    /opt/iobroker/iobroker-data/
                    776K    /opt/iobroker/iobroker-data/backup-objects
                    532K    /opt/iobroker/iobroker-data/files
                    440K    /opt/iobroker/iobroker-data/files/discovery.admin
                    88K     /opt/iobroker/iobroker-data/files/admin.admin
                    1.5M    /opt/iobroker/iobroker-data/objects.jsonl
                    1.5M    /opt/iobroker/iobroker-data/objects.json.migrated
                    964K    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                    448K    /opt/iobroker/iobroker-data/backup-objects/2020-08-24_00-13_objects.json.gz
                    288K    /opt/iobroker/iobroker-data/backup-objects/2019-05-10_23-20_objects.json.gz
                    USB-Devices by-id:
                    /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_DJ00TW49-if00-port0
                    /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014B93EF0-if00
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v18.18.1
                    /usr/bin/node           v18.18.1
                    /usr/bin/npm            10.2.0
                    /usr/bin/npx            10.2.0
                    /usr/bin/corepack       0.21.0
                    nodejs:
                      Installed: 18.18.1-1nodesource1
                      Candidate: 18.18.1-1nodesource1
                      Version table:
                     *** 18.18.1-1nodesource1 500
                            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                         18.18.0-1nodesource1 500
                         18.17.1-1nodesource1 500
                         18.17.0-1nodesource1 500
                         18.16.1-1nodesource1 500
                         18.16.0-1nodesource1 500
                         18.15.0-1nodesource1 500
                         18.14.2-1nodesource1 500
                         18.14.1-1nodesource1 500
                         18.14.0-1nodesource1 500
                         18.13.0-1nodesource1 500
                         18.12.0-1nodesource1 500
                         18.11.0-1nodesource1 500
                         18.10.0-1nodesource1 500
                         18.9.1-1nodesource1 500
                         18.9.0-1nodesource1 500
                         18.8.0-1nodesource1 500
                         18.7.0-1nodesource1 500
                         18.6.0-1nodesource1 500
                         18.5.0-1nodesource1 500
                         18.4.0-1nodesource1 500
                         18.3.0-1nodesource1 500
                         18.2.0-1nodesource1 500
                         18.1.0-1nodesource1 500
                         18.0.0-1nodesource1 500
                         10.24.0~dfsg-1~deb10u3 500
                    No problems detected
                    Errors in npm tree:
                    npm ERR! code ELSPROBLEMS
                    npm ERR! invalid: iobroker.js-controller@5.0.13 /opt/iobroker/node_modules/iobroker.js-controller
                    npm ERR! invalid: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
                    npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents
                    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-12T03_49_27_265Z-debug-0.log
                    *** ioBroker-Installation ***
                    ioBroker Status
                    iobroker is not running on this host.
                    At least one iobroker host is running.
                    Objects type: jsonl
                    States  type: jsonl
                    Core adapters versions
                    js-controller:  5.0.13
                    admin:          6.2.23
                    javascript:     "javascript" not found
                    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-12T03_49_54_984Z-debug-0.log
                    Adapters from github:   0
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : io-master                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      system.adapter.admin.1                  : admin                 : io-vis                                   - disabled, port: 8081, bind: 127.0.0.1, run as: admin
                      system.adapter.admin.2                  : admin                 : io-blegw02                               - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                      system.adapter.admin.3                  : admin                 : io-influxdb                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.backitup.0               : backitup              : io-master                                -  enabled
                      system.adapter.backitup.1               : backitup              : io-fhem                                  - disabled
                    + system.adapter.ble.0                    : ble                   : io-blegw02                               -  enabled
                      system.adapter.daswetter.0              : daswetter             : io-vis                                   -  enabled
                    + system.adapter.discovery.0              : discovery             : io-master                                -  enabled
                      system.adapter.dwd.0                    : dwd                   : io-vis                                   -  enabled
                      system.adapter.fhem.0                   : fhem                  : io-fhem                                  -  enabled, port: 7072
                      system.adapter.flot.0                   : flot                  : io-vis                                   -  enabled
                    + system.adapter.fritzdect.0              : fritzdect             : io-master                                -  enabled
                    + system.adapter.hmip.0                   : hmip                  : io-master                                -  enabled
                      system.adapter.homeconnect.0            : homeconnect           : io-master                                - disabled
                      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: io-vis                                   -  enabled
                      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : io-vis                                   -  enabled
                      system.adapter.icons-icons8.0           : icons-icons8          : io-vis                                   -  enabled
                      system.adapter.icons-material-png.0     : icons-material-png    : io-vis                                   -  enabled
                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : io-vis                                   -  enabled
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : io-vis                                   -  enabled
                      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: io-vis                                   -  enabled
                      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : io-vis                                   -  enabled
                    + system.adapter.influxdb.0               : influxdb              : io-influxdb                              -  enabled, port: 8086
                    + system.adapter.info.0                   : info                  : io-master                                -  enabled
                    + system.adapter.meross.0                 : meross                : io-master                                -  enabled
                      system.adapter.smartgarden.0            : smartgarden           : io-master                                - disabled
                      system.adapter.vis-bars.0               : vis-bars              : io-vis                                   -  enabled
                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : io-vis                                   -  enabled
                      system.adapter.vis-colorpicker.0        : vis-colorpicker       : io-vis                                   -  enabled
                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : io-vis                                   -  enabled
                      system.adapter.vis-history.0            : vis-history           : io-vis                                   -  enabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : io-vis                                   -  enabled
                      system.adapter.vis-justgage.0           : vis-justgage          : io-vis                                   -  enabled
                      system.adapter.vis-lcars.0              : vis-lcars             : io-vis                                   -  enabled
                      system.adapter.vis-material.0           : vis-material          : io-vis                                   -  enabled
                      system.adapter.vis-metro.0              : vis-metro             : io-vis                                   -  enabled
                      system.adapter.vis-rgraph.0             : vis-rgraph            : io-vis                                   -  enabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : io-vis                                   -  enabled
                      system.adapter.vis-weather.0            : vis-weather           : io-vis                                   -  enabled
                      system.adapter.vis.0                    : vis                   : io-vis                                   -  enabled
                    + system.adapter.web.0                    : web                   : io-vis                                   -  enabled, port: 8082, bind: 192.168.2.112, run as: admin
                      system.adapter.zigbee.0                 : zigbee                : io-fhem                                  - disabled, port: /dev/ttyACM0
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): beta
                    Installed ioBroker-Instances
                    Used repository: beta
                    Adapter    "admin"        : 6.10.7   , installed 6.2.23 [Updatable]
                    Adapter    "backitup"     : 2.8.4    , installed 2.5.6  [Updatable]
                    Adapter    "ble"          : 0.13.4   , installed 0.13.4
                    Adapter    "discovery"    : 4.2.0    , installed 3.2.0  [Updatable]
                    Adapter    "fhem"         : 2.0.5    , installed 2.0.3  [Updatable]
                    Adapter    "fritzdect"    : 2.4.1    , installed 2.3.1  [Updatable]
                    Adapter    "homeconnect"  : 1.1.1    , installed 1.0.1  [Updatable]
                    Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
                    Controller "js-controller": 5.0.13   , installed 5.0.13
                    Adapter    "socketio"     : 6.5.8    , installed 6.5.2  [Updatable]
                    Adapter    "web"          : 6.1.5    , installed 5.5.3  [Updatable]
                    Adapter    "ws"           : 2.5.8    , installed 2.5.3  [Updatable]
                    Adapter    "zigbee"       : 1.8.24   , installed 1.8.10 [Updatable]
                    Objects and States
                    Objects:        4796
                    States:         4194
                    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                    Hit:3 https://repo.saltproject.io/py3/debian/10/amd64/latest buster InRelease
                    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Hit:6 https://download.webmin.com/download/repository sarge Release
                    Reading package lists...
                    Pending Updates: 2
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          23649      1/init
                    tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          515393     4086/perl
                    tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      999        520728     4302/perl
                    tcp        0      0 0.0.0.0:48531           0.0.0.0:*               LISTEN      106        514537     4093/rpc.statd
                    tcp        0      0 0.0.0.0:43957           0.0.0.0:*               LISTEN      0          165832     -
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17133      679/sshd
                    tcp        0      0 0.0.0.0:7072            0.0.0.0:*               LISTEN      999        518479     4302/perl
                    tcp6       0      0 :::42983                :::*                    LISTEN      0          165834     -
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          23655      1/init
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          17135      679/sshd
                    tcp6       0      0 :::6556                 :::*                    LISTEN      998        657078     5951/cmk-agent-ctl
                    tcp6       0      0 :::47389                :::*                    LISTEN      106        514541     4093/rpc.statd
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15128      512/dhcpcd
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          23651      1/init
                    udp        0      0 192.168.2.113:123       0.0.0.0:*                           109        20456      583/ntpd
                    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          16992      583/ntpd
                    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          16988      583/ntpd
                    udp        0      0 0.0.0.0:56477           0.0.0.0:*                           108        12093      362/avahi-daemon: r
                    udp        0      0 0.0.0.0:51910           0.0.0.0:*                           0          165831     -
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12091      362/avahi-daemon: r
                    udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          515394     4086/perl
                    udp        0      0 127.0.0.1:877           0.0.0.0:*                           0          514531     4093/rpc.statd
                    udp        0      0 0.0.0.0:56857           0.0.0.0:*                           106        514535     4093/rpc.statd
                    udp6       0      0 :::35385                :::*                                108        12094      362/avahi-daemon: r
                    udp6       0      0 :::111                  :::*                                0          21979      1/init
                    udp6       0      0 :::53872                :::*                                106        514539     4093/rpc.statd
                    udp6       0      0 :::123                  :::*                                0          16985      583/ntpd
                    udp6       0      0 :::5353                 :::*                                108        12092      362/avahi-daemon: r
                    udp6       0      0 :::53242                :::*                                0          165833     -
                    2023-10-12 04:42:14.144  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                    2023-10-12 04:47:14.127  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                    2023-10-12 04:52:14.129  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                    2023-10-12 04:57:14.131  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                    2023-10-12 05:02:14.132  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                    2023-10-12 05:07:14.134  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                    2023-10-12 05:12:14.137  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                    2023-10-12 05:17:14.136  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                    2023-10-12 05:22:14.140  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                    2023-10-12 05:27:14.141  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                    2023-10-12 05:32:14.143  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                    2023-10-12 05:37:14.146  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                    2023-10-12 05:42:14.147  - info: fhem.0 (5908) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                    2023-10-12 05:44:01.807  - info: host.io-fhem received SIGTERM
                    2023-10-12 05:44:01.820  - info: host.io-fhem stopInstance system.adapter.fhem.0 (force=false, process=true)
                    2023-10-12 05:44:01.824  - info: host.io-fhem stopInstance system.adapter.zigbee.0 (force=false, process=false)
                    2023-10-12 05:44:01.825  - info: host.io-fhem stopInstance system.adapter.backitup.1 (force=false, process=false)
                    2023-10-12 05:44:01.830  - info: fhem.0 (5908) terminating
                    2023-10-12 05:44:01.834  - info: host.io-fhem stopInstance system.adapter.fhem.0 send kill signal
                    2023-10-12 05:44:01.833  - info: fhem.0 (5908) Terminated (NO_ERROR): Without reason
                    2023-10-12 05:44:01.837  - info: fhem.0 (5908) Got terminate signal TERMINATE_YOURSELF
                    2023-10-12 05:44:02.327  - info: fhem.0 (5908) terminating
                    2023-10-12 05:44:02.638  - info: host.io-fhem instance system.adapter.fhem.0 terminated with code 0 (NO_ERROR)
                    2023-10-12 05:44:02.640  - info: host.io-fhem All instances are stopped.
                    2023-10-12 05:44:02.664  - info: host.io-fhem terminated
                                            v.2023-10-10
                             Icon name: computer
                          Architecture: arm
                    Kernel:                 armv7l
                    Userland:               armhf
                    User-ID:                1000
                    X-Server:               false
                    Pending OS-Updates:     2
                    Pending iob updates:    11
                    Nodejs-Installation:    /usr/bin/nodejs         v18.18.1
                                            /usr/bin/npm            10.2.0
                                            /usr/bin/npx            10.2.0
                    Recommended versions are nodejs  and npm
                    MEMORY:
                    Mem:           972M        142M        214M        3.0M        616M        763M
                    Swap:           99M         57M         42M
                    Total:         1.1G        199M        256M
                    Active iob-Instances:   11
                    ioBroker Core:          js-controller           5.0.13
                                            admin                   6.2.23
                    ioBroker Status:        iobroker is not running on this host.
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                4796
                    States:                 4194
                    Size of iob-Database:
                    8.0K    /opt/iobroker/iobroker-data/states.jsonl
                    8.0K    /opt/iobroker/iobroker-data/states.json.migrated
                    8.0K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                    DJMarc75D
                    DJMarc75D
                    DJMarc75
                    10.2.0
                    Die NPM passt nicht zu NODE 18.18.1
                    Lehrling seit 1975 !!!
                    • DJMarc75D DJMarc75
                      10.2.0
                      D
                      D
                      DLaurenz
                      @djmarc75
                      laut iob diag ok....
                                              /usr/bin/npm            10.2.0
                                              /usr/bin/npx            10.2.0
                      wie bekomme ich die hoch? bzw. welche version muss es sein?
                        @dlaurenz
                        D
                        D
                        DLaurenz
                        @dlaurenz
                        ich muss gerade schmunzeln während das update zu bulls-eye läuft....
                        ihr liefert selber ein Image mit buster aus?
                        Image basiert auf dem aktuellen Raspberry Pi OS (Buster) Lite
                        https://forum.iobroker.net/topic/41520/raspberry-os-lite-image-for-with-iobroker
                        • D DLaurenz
                          Thomas BraunT
                          Thomas BraunT
                          Egal. Die Version ist obsolet... TOT.
                          sudo apt install --reinstall nodejs
                          • D DLaurenz
                            @djmarc75
                                                    /usr/bin/npm            10.2.0
                                                    /usr/bin/npx            10.2.0
                            CodierknechtC
                            CodierknechtC
                            Codierknecht
                            Nö. Der sagt Dir lediglich, dass Node korrekt installiert ist.
                            Der zur Node-Version passende NPM hat immer die "halbe" Versionsnummer.
                            Node 18 also mit NPM 9. Node 20 dementsprechend NPM 10.
                            Ohne @Thomas-Braun hier zu nahe treten oder seine Arbeit an der Ecke schmälern zu wollen: iob diag ist ein Hilfsmittel ... mehr nicht.
                            Es nimmt einem nicht die Arbeit ab.
                            "hampelst"....
                            Das allererste was ein Linux-Admin lernt: Man agiert im System nicht als User "root".
                            Alles was man mit der Hand am Arm im System treibt, wird allerhöchstens mit temporären Rechten per "sudo" ausgeführt. Da mit "root" unterwegs zu sein, ist reine Bequemlichkeit und führt in aller Regel zu Fehlern.
                            Es gibt da so einen schönen Spruch, der sinngemäß lautet: "Nur ausgewiesene Profis sollten sich als root anmelden - und die werden es nicht tun"
                            Ansonsten wurde ja schon erwähnt:
                            Ein Pi3 mit 1 GB RAM ist die absolute Minimalausstattung und mittlerweile fast nicht mehr sinnvoll (produktiv) einsetzbar. Da noch zusätzliche Verwaltungstools einzusetzen verbietet sich fast von selbst.
                            Debian "buster" liegt inzwischen 2 Versionen zurück und ist definitiv tot. Inzwischen gibt's auch offiziell "bookworm" für den Pi.
                            HmIP|ZigBee|Tasmota|Unifi
                            Zabbix Certified Specialist
                            Thomas BraunT D 2 Antworten Letzte Antwort
                            • CodierknechtC Codierknecht
                              "hampelst"....
                              Thomas BraunT
                              Thomas BraunT
                              @codierknecht sagte in Update ioBroker klappt nicht:
                              Mehr soll es auch nicht sein.
                              • D DLaurenz
                                @dlaurenz
                                datum gelesen?
                                Das war 2021
                                  datum gelesen?
                                  Das war 2021
                                  D
                                  D
                                  DLaurenz
                                  genau, deswegen ist es auch offiziell verlinkt.... wenn etwas nicht mehr freigegeben oder supported ist, gehört es entsprechend makiert, macht man so...
                                  • D DLaurenz
                                    Wenn du den Download nutzen würdest, würdest du ein aktuelle Image bekommen, kein Buster.
                                    der Beitrag ist historisch. Den lässt man so.
                                      "hampelst"....
                                      D
                                      D
                                      DLaurenz
                                      @codierknecht
                                      können wir mal über die sinn oder unsinnhaftigkeit bei mir aufhören zu sprechen und uns dem problem widmen? bisher hat sich keiner die mühe gemacht, zu fragen warum dinge so laufen sondern es wird wie üblich der oberlehrer rausgekehrt...
                                      ich kenn linux schon seit dem es noch bookware war, ich weiß also was ich tue oder nicht tue... das dürften so ca. 25 jahre sein...
                                      danke!
                                        D
                                        D
                                        DLaurenz
                                        so erledigt:
                                        root@io-fhem:~# apt install --reinstall nodejs
                                        Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                                          libdns-export1110 libisc-export1105 openresolv
                                        Verwenden Sie »apt autoremove«, um sie zu entfernen.
                                        0 aktualisiert, 0 neu installiert, 1 erneut installiert, 0 zu entfernen und 1 nicht aktualisiert.
                                        Es müssen noch 0 B von 26,7 MB an Archiven heruntergeladen werden.
                                        Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
                                        (Lese Datenbank ... 97255 Dateien und Verzeichnisse sind derzeit installiert.)
                                        Vorbereitung zum Entpacken von .../nodejs_18.18.1-1nodesource1_armhf.deb ...
                                        Detected old npm client, removing...
                                        Entpacken von nodejs (18.18.1-1nodesource1) über (18.18.1-1nodesource1) ...
                                        nodejs (18.18.1-1nodesource1) wird eingerichtet ...
                                        Trigger für man-db (2.9.4-2) werden verarbeitet ...
                                        Prüfe Prozesse...
                                        Prüfe Kandidaten...
                                        Scanning processor microcode...
                                        Prüfe Linux-Kernel...
                                        Der laufende Kernel ist aktuell.
                                        Fehler beim Ermitteln von verfügbaren Prozessor Mikrocode-Upgrades.
                                        Dienste werden neu gestartet...
                                         systemctl restart iobroker.service
                                        Es müssen keine Container neu gestartet werden.
                                        Es gibt keine Nutzer-Sitzungen mit veralteten Prozessen.
                                        root@io-fhem:~# npm -v
                                        9.8.1
                                        übrigens OS auch aktualisiert:
                                        root@io-fhem:~# cat /etc/os-release
                                        PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                                        NAME="Raspbian GNU/Linux"
                                        VERSION_ID="11"
                                        VERSION="11 (bullseye)"
                                        VERSION_CODENAME=bullseye
                                        ID=raspbian
                                        ID_LIKE=debian
                                        HOME_URL="http://www.raspbian.org/"
                                        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                                        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                                        wie zu erwarten ist das alles NICHT DAS PROBLEM...
                                        root@io-fhem:~# iob upgrade fritzdect --debug
                                        -> 2.4.1:
                                        -> 2.4.0:
                                        NPM version: 9.8.1
                                        npm ERR! code ENOTEMPTY
                                        npm ERR! syscall rename
                                        npm ERR! path /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
                                        npm ERR! dest /opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo
                                        npm ERR! errno -39
                                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket' -> '/opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo'
                                        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-12T09_12_07_605Z-debug-0.log
                                        host.io-fhem Cannot install iobroker.fritzdect@2.4.1: 217
                                        achso - zur Auslastung des Systems: (die letzte 35 Tage)
                                        2023-10-12 11_16_43-Checkmk Local site homelab - Service graphs CPU utilization, io-fhem.png 2023-10-12 11_16_08-Checkmk Local site homelab - Service graphs io-fhem, Memory.png
                                        Last ist immer nur wenn Sicherungen laufen....
                                        der macht genau 2 Dinge - zigbee gateway & fhem host (für selve rolläden) das war es dann auch schon
                                        Könnten wir dann mit der analyse starten? das wäre fein
                                        Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                                        • D DLaurenz
                                          so erledigt:
                                          Prüfe Prozesse...
                                          Prüfe Kandidaten...
                                          9.8.1
                                          VERSION_ID="11"
                                          ID=raspbian
                                          ID_LIKE=debian
                                          -> 2.4.1:
                                          -> 2.4.0:
                                          NPM version: 9.8.1
                                          npm ERR! errno -39
                                          Thomas BraunT
                                          Thomas BraunT
                                          Das hat auch NIEMAND behauptet.
