  4. Test Adapter ioBroker.backitup v3.1.x
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.8m Aufrufe 113 Beobachtet
  • D DPO99
    Update**
    @simatec Fehler trat nun wieder auf. Anbei das log.
    2023-09-29 23:00:10.051 - debug: backitup.0 (929) The local storage check was completed successfully. On the host "iobroker" are currently 24137 MB free space available!
    2023-09-29 23:00:10.059 - debug: backitup.0 (929) Backup has started ...
    2023-09-29 23:00:20.060 - debug: backitup.0 (929) [iobroker/mount] noserverino option: false
    2023-09-29 23:00:20.061 - debug: backitup.0 (929) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.5/Backup_IoBroker/Backup /opt/iobroker/backups"
    2023-09-29 23:00:20.349 - debug: backitup.0 (929) [iobroker/mount] mount successfully completed
    2023-09-29 23:00:20.351 - debug: backitup.0 (929) [iobroker/mount] done
    2023-09-29 23:00:23.687 - debug: backitup.0 (929) [iobroker/iobroker] host.iobroker 3001 states saved
    2023-09-29 23:00:25.923 - debug: backitup.0 (929) [iobroker/iobroker] host.iobroker 3512 objects saved
    2023-09-29 23:00:29.810 - debug: backitup.0 (929) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2023_09_29-23_00_20_backupiobroker.tar.gz
    2023-09-29 23:00:37.788 - debug: backitup.0 (929) [iobroker/iobroker] done
    2023-09-29 23:00:38.692 - debug: backitup.0 (929) [iobroker/historyDB] compress from historyDB started ...
    2023-09-29 23:00:41.848 - debug: backitup.0 (929) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2023_09_29-23_00_38_backupiobroker.tar.gz
    2023-09-29 23:00:41.849 - debug: backitup.0 (929) [iobroker/historyDB] done
    2023-09-29 23:00:42.805 - debug: backitup.0 (929) [iobroker/javascripts] Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    2023-09-29 23:00:43.022 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Wochenverbrauch
    2023-09-29 23:00:43.023 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Monatsverbrauch
    2023-09-29 23:00:43.023 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Tagesverbrauch
    2023-09-29 23:00:43.024 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Verbrauchsmessung_Shellys
    2023-09-29 23:00:43.024 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Schaltung_openDTU
    2023-09-29 23:00:43.024 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Notabschaltung___Alarm
    2023-09-29 23:00:43.025 - debug: backitup.0 (929) [iobroker/javascripts] found Script: An-_Abschaltung_Solar
    2023-09-29 23:00:43.025 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Realtime_Untertägig
    2023-09-29 23:00:43.025 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Akku_Balancing
    2023-09-29 23:00:43.025 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Luftentfeuchter
    2023-09-29 23:00:43.026 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Raspberry_PI
    2023-09-29 23:00:43.026 - debug: backitup.0 (929) [iobroker/javascripts] found Script: OpenDTU
    2023-09-29 23:00:43.026 - debug: backitup.0 (929) [iobroker/javascripts] found Script: HM_WR_Keller
    2023-09-29 23:00:43.026 - debug: backitup.0 (929) [iobroker/javascripts] found Script: HW_WR_Garage
    2023-09-29 23:00:43.027 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Akkuladung_100
    2023-09-29 23:00:43.027 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Jahresverbrauch
    2023-09-29 23:00:43.027 - debug: backitup.0 (929) [iobroker/javascripts] found Script: TEST
    2023-09-29 23:00:43.027 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Test_Hama
    2023-09-29 23:00:43.324 - debug: backitup.0 (929) [iobroker/javascripts] Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
    2023-09-29 23:00:43.430 - debug: backitup.0 (929) [iobroker/javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
    2023-09-29 23:00:43.431 - debug: backitup.0 (929) [iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2023_09_29-23_00_42_backupiobroker.tar.gz
    2023-09-29 23:00:43.431 - debug: backitup.0 (929) [iobroker/javascripts] done
    2023-09-29 23:00:44.184 - debug: backitup.0 (929) [iobroker/cifs] used copy path: /Backup_IoBroker/Backup
    2023-09-29 23:00:44.185 - debug: backitup.0 (929) [iobroker/cifs] done
    2023-09-29 23:00:44.787 - error: backitup.0 (929) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
    2023-09-29 23:00:44.788 - debug: backitup.0 (929) [iobroker/clean] done
    2023-09-29 23:00:46.003 - debug: backitup.0 (929) [iobroker/historyHTML] new history html values created
    2023-09-29 23:00:46.069 - debug: backitup.0 (929) [iobroker/historyHTML] done
    2023-09-29 23:00:46.307 - debug: backitup.0 (929) [iobroker/historyJSON] new history json values created
    2023-09-29 23:00:46.308 - debug: backitup.0 (929) [iobroker/historyJSON] done
    2023-09-29 23:00:46.487 - debug: backitup.0 (929) [iobroker/umount] mount activ, umount is started ...
    2023-09-29 23:00:51.587 - debug: backitup.0 (929) [iobroker/umount] umount successfully completed
    2023-09-29 23:00:51.589 - debug: backitup.0 (929) [iobroker/umount] done
    2023-09-29 23:00:51.740 - debug: backitup.0 (929) [iobroker] exec: done
    Die Backups sind auch noch auf dem Pi gespeichert:
    iobroker@iobroker:/opt/iobroker/backups $ dir
    historyDB_2023_09_24-23_00_31_backupiobroker.tar.gz  iobroker_2023_09_27-23_00_20_backupiobroker.tar.gz
    historyDB_2023_09_25-23_00_31_backupiobroker.tar.gz  iobroker_2023_09_28-23_00_20_backupiobroker.tar.gz
    historyDB_2023_09_26-23_00_36_backupiobroker.tar.gz  iobroker_2023_09_29-23_00_20_backupiobroker.tar.gz
    historyDB_2023_09_27-23_00_32_backupiobroker.tar.gz  javascripts_2023_09_24-23_00_35_backupiobroker.tar.gz
    historyDB_2023_09_28-23_00_33_backupiobroker.tar.gz  javascripts_2023_09_25-23_00_35_backupiobroker.tar.gz
    historyDB_2023_09_29-23_00_38_backupiobroker.tar.gz  javascripts_2023_09_26-23_00_41_backupiobroker.tar.gz
    iobroker_2023_09_24-23_00_20_backupiobroker.tar.gz   javascripts_2023_09_27-23_00_36_backupiobroker.tar.gz
    iobroker_2023_09_25-23_00_20_backupiobroker.tar.gz   javascripts_2023_09_28-23_00_40_backupiobroker.tar.gz
    iobroker_2023_09_26-23_00_25_backupiobroker.tar.gz   javascripts_2023_09_29-23_00_42_backupiobroker.tar.gz
    Anbei einmal die Einstellungen:
    Zum System:
    Raspberry Pi 4 8GB
    Node.js: v18.18.0
    NPM: 9.8.1
    js-controller: 4.0.24
    backitup: v2.8.1
    Mir ist dann noch was aufgefallen.
    Er hat hier m.E. eine Version zu viel gelöscht. Ich hebe immer 5 auf, also hätte er doch am 23.09.2023 den 19.09.2023 noch gar nicht löschen dürfen oder?
    2023-09-23 23:00:37.923 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2023_09_19-23_00_20_backupiobroker.tar.gz
    2023-09-23 23:00:37.937 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/historyDB_2023_09_19-23_00_33_backupiobroker.tar.gz
    2023-09-23 23:00:37.951 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/javascripts_2023_09_19-23_00_40_backupiobroker.tar.gz
    2023-09-23 23:00:37.954 - debug: backitup.0 (258932) [iobroker/clean] done
    Am 26.09.2023 z.B. hat er tatsächlich 5 Versionen stehen lassen und die 6. gelöscht (also anders als am 23.09.2023):
    2023-09-26 23:00:42.869 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2023_09_21-23_54_53_backupiobroker.tar.gz
    2023-09-26 23:00:42.884 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/historyDB_2023_09_21-23_55_04_backupiobroker.tar.gz
    2023-09-26 23:00:42.898 - debug: backitup.0 (258932) [iobroker/clean] delete /opt/iobroker/backups/javascripts_2023_09_21-23_55_08_backupiobroker.tar.gz
    2023-09-26 23:00:42.901 - debug: backitup.0 (258932) [iobroker/clean] done
    simatecS Online
    simatecS Online
    simatec
    #2462
    @dpo99 sagte in Test Adapter ioBroker.backitup v2.8.x:
    Wenn du ein NAS nutzt, können die Backups nicht auf dem PI liegen
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • simatecS simatec
      DPO99
      #2463
      @simatec
      Diese Aussage deckt sich aber nicht mit dem Verhalten. Die Backups liegen auf dem PI und auf dem NAS. So gesehen "doppelt" könnte man sagen.
      DJMarc75D simatecS Thomas BraunT 3 Antworten Letzte Antwort
      • D DPO99
        @simatec
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        #2464
        @dpo99 Sind das manuell angestoßene Backups ?
        Lehrling seit 1975 !!!
        • D DPO99
          @simatec
          simatecS Online
          simatecS Online
          simatec
          #2465
          @dpo99 Und genau dies kann bei einem CIFS Mount nicht sein... Der lokale Pfad muss leer sein.
          • D DPO99
            @simatec
            #2466
            Üblicherweise werden NAS per NFS oder CIFS in dem Mountpunkt /opt/iobroker/backups gemountet. Da kann es keine Dopplung geben, weil die Dateien physisch auf dem NAS liegen und nur logisch in /opt/iobroker/backups.
            Dieser Ordner ist dann auch leer, wenn das NAS gerade nicht gemountet ist .
              DPO99
              schrieb am zuletzt editiert von DPO99
              #2467
              @thomas-braun @simatec
              Ah okay alles klar. Das wäre dann soweit logisch. Hab das NAS mal eben ausgemacht und in den lokalen Pfad geschaut. Sieht so aus, wie beschrieben:
              2023_02_19-18_44_43_backupiobroker.tar.gz
              Gibts zum ursprünglichen Problem und dem "stehen lassen" bzw. zu "früh" löschen von Backups auch eine Idee?
              @DJMarc75 Wenn mein NAS aus ist, dann sehe ich nur das manuelle Backup. Von daher passt das zur Aussage von Thomas Braun und Simatec.
              • D DPO99
                #2468
                ...muss das Verzeichnis leer sein. Lösch das Backup da raus.
                  DPO99
                  #2469
                  ist erl. Danke. Soll ich dann mal weiter beobachten?
                  • D DPO99
                    #2470
                    @dpo99
                    Statt dir besser ls -lAh verwenden. Das zeigt mehr und übersichtlicher an.
                      @dpo99
                      DPO99
                      #2471
                      @thomas-braun Danke für den Tipp. Dabei kommt das raus:
                      iobroker@iobroker:/opt/iobroker/backups $ ls -lAh
                      total 0
                        DPO99
                        #2472
                        @simatec
                        Fehler trat heute leider wieder auf. Sehr komisch...schreiben kann er die Backups aber löschen teilweise nicht...
                        2023-10-01 23:00:10.034 - debug: backitup.0 (929) The local storage check was completed successfully. On the host "iobroker" are currently 24128 MB free space available!
                        2023-10-01 23:00:10.036 - debug: backitup.0 (929) Backup has started ...
                        2023-10-01 23:00:20.037 - debug: backitup.0 (929) [iobroker/mount] noserverino option: false
                        2023-10-01 23:00:20.038 - debug: backitup.0 (929) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.5/Backup_IoBroker/Backup /opt/iobroker/backups"
                        2023-10-01 23:00:20.234 - debug: backitup.0 (929) [iobroker/mount] mount successfully completed
                        2023-10-01 23:00:20.236 - debug: backitup.0 (929) [iobroker/mount] done
                        2023-10-01 23:00:23.555 - debug: backitup.0 (929) [iobroker/iobroker] host.iobroker 3030 states saved
                        2023-10-01 23:00:26.328 - debug: backitup.0 (929) [iobroker/iobroker] host.iobroker 3545 objects saved
                        2023-10-01 23:00:30.484 - debug: backitup.0 (929) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2023_10_01-23_00_20_backupiobroker.tar.gz
                        2023-10-01 23:00:34.701 - debug: backitup.0 (929) [iobroker/iobroker] done
                        2023-10-01 23:00:35.604 - debug: backitup.0 (929) [iobroker/historyDB] compress from historyDB started ...
                        2023-10-01 23:00:38.610 - debug: backitup.0 (929) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2023_10_01-23_00_35_backupiobroker.tar.gz
                        2023-10-01 23:00:38.611 - debug: backitup.0 (929) [iobroker/historyDB] done
                        2023-10-01 23:00:39.523 - debug: backitup.0 (929) [iobroker/javascripts] Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                        2023-10-01 23:00:39.646 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Wochenverbrauch
                        2023-10-01 23:00:39.647 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Monatsverbrauch
                        2023-10-01 23:00:39.647 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Tagesverbrauch
                        2023-10-01 23:00:39.647 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Verbrauchsmessung_Shellys
                        2023-10-01 23:00:39.647 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Schaltung_openDTU
                        2023-10-01 23:00:39.648 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Notabschaltung___Alarm
                        2023-10-01 23:00:39.648 - debug: backitup.0 (929) [iobroker/javascripts] found Script: An-_Abschaltung_Solar
                        2023-10-01 23:00:39.648 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Realtime_Untertägig
                        2023-10-01 23:00:39.648 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Akku_Balancing
                        2023-10-01 23:00:39.649 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Luftentfeuchter
                        2023-10-01 23:00:39.649 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Raspberry_PI
                        2023-10-01 23:00:39.650 - debug: backitup.0 (929) [iobroker/javascripts] found Script: OpenDTU
                        2023-10-01 23:00:39.650 - debug: backitup.0 (929) [iobroker/javascripts] found Script: HM_WR_Keller
                        2023-10-01 23:00:39.650 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Akkuladung_100
                        2023-10-01 23:00:39.650 - debug: backitup.0 (929) [iobroker/javascripts] found Script: VAR_Jahresverbrauch
                        2023-10-01 23:00:39.651 - debug: backitup.0 (929) [iobroker/javascripts] found Script: TEST
                        2023-10-01 23:00:39.651 - debug: backitup.0 (929) [iobroker/javascripts] found Script: Test_Hama
                        2023-10-01 23:00:39.651 - debug: backitup.0 (929) [iobroker/javascripts] found Script: HM_WR_Garage
                        2023-10-01 23:00:39.771 - debug: backitup.0 (929) [iobroker/javascripts] Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                        2023-10-01 23:00:39.801 - debug: backitup.0 (929) [iobroker/javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                        2023-10-01 23:00:39.802 - debug: backitup.0 (929) [iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2023_10_01-23_00_39_backupiobroker.tar.gz
                        2023-10-01 23:00:39.802 - debug: backitup.0 (929) [iobroker/javascripts] done
                        2023-10-01 23:00:40.555 - debug: backitup.0 (929) [iobroker/cifs] used copy path: /Backup_IoBroker/Backup
                        2023-10-01 23:00:40.555 - debug: backitup.0 (929) [iobroker/cifs] done
                        2023-10-01 23:00:41.157 - error: backitup.0 (929) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                        2023-10-01 23:00:41.158 - debug: backitup.0 (929) [iobroker/clean] done
                        2023-10-01 23:00:42.364 - debug: backitup.0 (929) [iobroker/historyHTML] new history html values created
                        2023-10-01 23:00:42.421 - debug: backitup.0 (929) [iobroker/historyHTML] done
                        2023-10-01 23:00:42.611 - debug: backitup.0 (929) [iobroker/historyJSON] new history json values created
                        2023-10-01 23:00:42.612 - debug: backitup.0 (929) [iobroker/historyJSON] done
                        2023-10-01 23:00:42.781 - debug: backitup.0 (929) [iobroker/umount] mount activ, umount is started ...
                        2023-10-01 23:00:47.829 - debug: backitup.0 (929) [iobroker/umount] umount successfully completed
                        2023-10-01 23:00:47.830 - debug: backitup.0 (929) [iobroker/umount] done
                        2023-10-01 23:00:47.980 - debug: backitup.0 (929) [iobroker] exec: done
                        • D DPO99
                          @simatec
                          simatecS Online
                          simatecS Online
                          simatec
                          #2473
                          @dpo99 Was hast du für ein NAS?
                          • simatecS simatec
                            DPO99
                            #2474
                            @simatec
                            Synology DS220+. Hat Backitup ggf ein Problem, wenn der Speicher aus dem Standby nicht 100% online ist? Ich schalte den um 23h ein (zeitgleich startet auch das Backup). Aber schreiben konnte er ja immer...hm
                            Thomas BraunT Siggi0904S 2 Antworten Letzte Antwort
                            • D DPO99
                              @simatec
                              #2475
                              Dann mach das mal um ein paar Minuten versetzt...
                              • D DPO99
                                @simatec
                                Siggi0904S Offline
                                Siggi0904S Offline
                                Siggi0904
                                #2476
                                @dpo99 naja, gib dem NAS nach dem Hochfahren ruhig 15-30 Minuten.
                                Denn nach dem Aufwachen hat das NAS viel zu tun.
                                • I Offline
                                  I Offline
                                  ichderarnd
                                  schrieb am zuletzt editiert von ichderarnd
                                  #2477
                                  Mir ist heute aufgefallen, dass backitup in meiner Umgebung seit einem Monat keine Sicherungen mehr ablegt. Sicherungsziel ist eine Freigabe auf einem Windows 10 PC (also kein Fritzbox Problem). Der Befehl, den backitup für das Mounten des Verzeichnisses erstellt lautet:
                                  sudo mount -t cifs -o username=PiBackup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //srv02/Backups/ioBroker /opt/iobroker/backups
                                  Wenn ich den identischen Befehl in der Shell mit dem Passwort z.B. '$passwort$' statt der **** ausführe, funktioniert das Mounten.
                                  Ich habe dann in den ioBroker backitup Einstellungen als Passwort spaßeshalber mal das Passwort mit den Anführungszeichen eingegeben und siehe da, es funktioniert wieder.
                                  Hat sich an dieser Stelle in letzter Zeit etwas im Adapter geändert? Ich vermute, das $ im Passwort ist Ursache des Problems. Aber Sonderzeichen im Passwort sollten ja möglich sein.
                                  Ich habe jetzt nicht probiert, über das Passwort Code zu injezieren. Würde vermutlich möglich sein.
                                    DPO99
                                    #2478
                                    Habe das Backup mal versetzt (kurze Korrektur noch, der Speicher ist nicht AUS sondern immer im Standby). Um 23h wird er dennoch jeden Tag aufgeweckt, sollte er im Standy sein. Fehler trat leider trotzdem auf:
                                    2023-10-03 23:10:10.038 - debug: backitup.0 (495265) The local storage check was completed successfully. On the host "iobroker" are currently 24113 MB free space available!
                                    2023-10-03 23:10:10.113 - debug: backitup.0 (495265) Backup has started ...
                                    2023-10-03 23:10:10.124 - debug: backitup.0 (495265) [iobroker/mount] mount activ... umount is started before mount!!
                                    2023-10-03 23:10:10.189 - debug: backitup.0 (495265) [iobroker/mount] umount successfully completed
                                    2023-10-03 23:10:20.113 - debug: backitup.0 (495265) [iobroker/mount] noserverino option: false
                                    2023-10-03 23:10:20.114 - debug: backitup.0 (495265) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.5/Backup_IoBroker/Backup /opt/iobroker/backups"
                                    2023-10-03 23:10:20.263 - debug: backitup.0 (495265) [iobroker/mount] mount successfully completed
                                    2023-10-03 23:10:20.266 - debug: backitup.0 (495265) [iobroker/mount] done
                                    2023-10-03 23:10:23.725 - debug: backitup.0 (495265) [iobroker/iobroker] host.iobroker 3044 states saved
                                    2023-10-03 23:10:26.296 - debug: backitup.0 (495265) [iobroker/iobroker] host.iobroker 3561 objects saved
                                    2023-10-03 23:10:30.405 - debug: backitup.0 (495265) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2023_10_03-23_10_20_backupiobroker.tar.gz
                                    2023-10-03 23:10:32.496 - debug: backitup.0 (495265) [iobroker/iobroker] done
                                    2023-10-03 23:10:33.401 - debug: backitup.0 (495265) [iobroker/historyDB] compress from historyDB started ...
                                    2023-10-03 23:10:37.349 - debug: backitup.0 (495265) [iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2023_10_03-23_10_33_backupiobroker.tar.gz
                                    2023-10-03 23:10:37.350 - debug: backitup.0 (495265) [iobroker/historyDB] done
                                    2023-10-03 23:10:38.270 - debug: backitup.0 (495265) [iobroker/javascripts] Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                                    2023-10-03 23:10:38.402 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: VAR_Wochenverbrauch
                                    2023-10-03 23:10:38.405 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: VAR_Monatsverbrauch
                                    2023-10-03 23:10:38.406 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: VAR_Tagesverbrauch
                                    2023-10-03 23:10:38.406 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Verbrauchsmessung_Shellys
                                    2023-10-03 23:10:38.407 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Schaltung_openDTU
                                    2023-10-03 23:10:38.408 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Notabschaltung___Alarm
                                    2023-10-03 23:10:38.408 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: An-_Abschaltung_Solar
                                    2023-10-03 23:10:38.409 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: VAR_Realtime_Untertägig
                                    2023-10-03 23:10:38.409 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Akku_Balancing
                                    2023-10-03 23:10:38.410 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Luftentfeuchter
                                    2023-10-03 23:10:38.411 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Raspberry_PI
                                    2023-10-03 23:10:38.411 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: OpenDTU
                                    2023-10-03 23:10:38.412 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: HM_WR_Keller
                                    2023-10-03 23:10:38.412 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Akkuladung_100
                                    2023-10-03 23:10:38.421 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: VAR_Jahresverbrauch
                                    2023-10-03 23:10:38.423 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: TEST
                                    2023-10-03 23:10:38.424 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: Test_Hama
                                    2023-10-03 23:10:38.436 - debug: backitup.0 (495265) [iobroker/javascripts] found Script: HM_WR_Garage
                                    2023-10-03 23:10:38.555 - debug: backitup.0 (495265) [iobroker/javascripts] Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                                    2023-10-03 23:10:38.583 - debug: backitup.0 (495265) [iobroker/javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                                    2023-10-03 23:10:38.584 - debug: backitup.0 (495265) [iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2023_10_03-23_10_38_backupiobroker.tar.gz
                                    2023-10-03 23:10:38.584 - debug: backitup.0 (495265) [iobroker/javascripts] done
                                    2023-10-03 23:10:39.337 - debug: backitup.0 (495265) [iobroker/cifs] used copy path: /Backup_IoBroker/Backup
                                    2023-10-03 23:10:39.337 - debug: backitup.0 (495265) [iobroker/cifs] done
                                    2023-10-03 23:10:39.941 - error: backitup.0 (495265) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                                    2023-10-03 23:10:39.941 - debug: backitup.0 (495265) [iobroker/clean] done
                                    2023-10-03 23:10:41.167 - debug: backitup.0 (495265) [iobroker/historyHTML] new history html values created
                                    2023-10-03 23:10:41.229 - debug: backitup.0 (495265) [iobroker/historyHTML] done
                                    2023-10-03 23:10:41.418 - debug: backitup.0 (495265) [iobroker/historyJSON] new history json values created
                                    2023-10-03 23:10:41.419 - debug: backitup.0 (495265) [iobroker/historyJSON] done
                                    2023-10-03 23:10:41.589 - debug: backitup.0 (495265) [iobroker/umount] mount activ, umount is started ...
                                    2023-10-03 23:10:46.641 - debug: backitup.0 (495265) [iobroker/umount] umount successfully completed
                                    2023-10-03 23:10:46.642 - debug: backitup.0 (495265) [iobroker/umount] done
                                    2023-10-03 23:10:46.794 - debug: backitup.0 (495265) [iobroker] exec: done
                                    • D DPO99
                                      simatecS Online
                                      simatecS Online
                                      simatec
                                      #2479
                                      @dpo99 Kann dein NAS WOL? Vielleicht sollte das deine Lösung sein.
                                      Backitup kann über WOL dein NAS wecken...
                                      HomoranH D 2 Antworten Letzte Antwort
                                      • simatecS simatec
                                        #2480
                                        @simatec
                                        Ist inzwischen das CCU Backup nicht mehr über backitup abrufbar?
                                        hab in Doku und Forum nichts gefunden und erst mal eigenen Thread aufgemacht
                                        https://forum.iobroker.net/topic/68753/backitup-findet-ccu-backups-nicht-mehr/1
                                          @simatec
                                          simatecS Online
                                          simatecS Online
                                          simatec
                                          #2481
                                          @homoran sagte in Test Adapter ioBroker.backitup v2.8.x:
                                          War schon immer so Rainer ;-)
                                          https://github.com/simatec/ioBroker.backitup/wiki/ioBroker.backitup-Wiki-Deutsch#restore
