  4. js-controller 5.0.x jetzt für alle User im STABLE!
js-controllerstableupgrade
509 Beiträge 82 Kommentatoren 178.3k Aufrufe 65 Beobachtet
  • M Merowinger
    iob diag
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
      iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
      iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
      iobroker rebuild [<module>]                                  Rebuild all native modules or path
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
      iobroker object                                              Object management  [aliases: o]
      iobroker state                                               State management  [aliases: s]
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation  [aliases: id]
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
    Options:
      --help  Show help  [boolean]
    Ist das hier aus dem service status evtl das Problem?
    Sep 15 11:14:22 iobroker bash[3271]: /bin/sh: 1: hcitool: not found
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    jetzt habe ich das js-controller update so zum drittel Mal durchgeführt...
    von den iob Befehlen funktioniert jeder nur bei iob fix, zeigt er mir die Befehlsliste an...
    Sep 15 11:38:59 iobroker bash[21714]:     at Module.require (node:internal/modules/cjs/loader:1143:19) {
    Sep 15 11:38:59 iobroker bash[21714]:   code: 'MODULE_NOT_FOUND',
    Sep 15 11:38:59 iobroker bash[21714]:   requireStack: [
    Sep 15 11:38:59 iobroker bash[21714]:     '/opt/iobroker/node_modules/iobroker.fritzbox/lib/utils.js',
    Sep 15 11:38:59 iobroker bash[21714]:     '/opt/iobroker/node_modules/iobroker.fritzbox/main.js'
    Jetzt habe ich wieder den crash. fritzbox adapter deinstalliert.
    service iobroker stop und start durchgeführt...
    jetzt kann ich wieder den admin adapter auf 6.8.0 upgraden und der js-controller ist auch wieder der 4er...
    #67
    @merowinger
    Da ist deine Basis verfummelt...
    root...
    Mach einen separaten Thread auf. Da dann die Langfassung vom manuellen Aufruf rein:
    curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
    DuffyD 1 Antwort Letzte Antwort
    • M Merowinger
      iob diag
      iobroker [command]
      Commands:
      Options:
      mcm1957M Online
      mcm1957M Online
      mcm1957
      #68
      Aktualisierung der Liste erforderlicher Adapterupdates:
      javascript 7.1.4 - stable verfügbar ab 15.9. nachmittags
      enigma2 2.0.3 - nur via latest repository verfügbar
      plenticore 2.3.0 - z.Z. nur im latest, stable in Planung
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • mcm1957M mcm1957
        @mcm57 said in js-controller 5.0.x jetzt für alle User im STABLE!:
        @foxriver76
        Ok
        Wenn ihr keine Zeit habt kann ich am Abend release versuchen
        Ok, der botvac hat weder release script noch github tests - Museumsstand was die Infrastruktur betrifft. Ich werd dann mal anfangen, kann aber auch noch nen Tag dauern bis ne saubere Release entsteht.
        Wer will, kann zwischenzeitlich die GITHUB Version versuchen (übliches Disclaimer - at own risk + Backup). Der Code sollte an js-controller 5 angepasst sein. Er enthält allerdings auch ein paar weitere Änderungen die nicht ins README gefunden haben, da muss ich erst mal schaun ob da ne Info was geändert wurde extrahieren kann.
        JohGreJ Offline
        JohGreJ Offline
        JohGre
        #69
        @mcm57 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
        @foxriver76
        Ok
        Funkt leider nicht
        2023-09-15 12:00:23.203 - debug: botvac.0 (24567) Redis Objects: Use Redis connection: 10.0.0.227:9001
        2023-09-15 12:00:23.246 - debug: botvac.0 (24567) Objects client ready ... initialize now
        2023-09-15 12:00:23.249 - debug: botvac.0 (24567) Objects create System PubSub Client
        2023-09-15 12:00:23.250 - debug: botvac.0 (24567) Objects create User PubSub Client
        2023-09-15 12:00:23.317 - debug: botvac.0 (24567) Objects client initialize lua scripts
        2023-09-15 12:00:23.323 - debug: botvac.0 (24567) Objects connected to redis: 10.0.0.227:9001
        2023-09-15 12:00:23.360 - debug: botvac.0 (24567) Redis States: Use Redis connection: 10.0.0.227:9000
        2023-09-15 12:00:23.381 - debug: botvac.0 (24567) States create System PubSub Client
        2023-09-15 12:00:23.381 - debug: botvac.0 (24567) States create User PubSub Client
        2023-09-15 12:00:23.469 - debug: botvac.0 (24567) States connected to redis: 10.0.0.227:9000
        2023-09-15 12:00:23.700 - info: botvac.0 (24567) starting. Version 1.0.4 (non-npm: iobroker-community-adapters/ioBroker.botvac#331c3718f9b221f76efdec922ed38ba587c1d392) in /opt/iobroker/node_modules/iobroker.botvac, node: v18.17.1, js-controller: 5.0.12
        2023-09-15 12:00:28.485 - info: botvac.0 (24567) devices found: 4
        2023-09-15 12:00:28.719 - warn: botvac.0 (24567) Device"Erdgeschoss" with id: Erdgeschoss is not exists in cloud any more!
        2023-09-15 12:00:28.984 - warn: botvac.0 (24567) Device"Erdgeschoss" with id: Erdgeschoss is not exists in cloud any more!
        2023-09-15 12:00:28.985 - warn: botvac.0 (24567) Device"Turnverein Oben" with id: Turnverein Oben is not exists in cloud any more!
        2023-09-15 12:00:29.209 - warn: botvac.0 (24567) Device"Erdgeschoss" with id: Erdgeschoss is not exists in cloud any more!
        2023-09-15 12:00:29.209 - warn: botvac.0 (24567) Device"Keller" with id: Keller is not exists in cloud any more!
        2023-09-15 12:00:29.210 - warn: botvac.0 (24567) Device"Turnverein Oben" with id: Turnverein Oben is not exists in cloud any more!
        2023-09-15 12:00:30.373 - error: botvac.0 (24567) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-09-15 12:00:30.374 - error: botvac.0 (24567) unhandled promise rejection: undefined is not a valid state value
        2023-09-15 12:00:30.376 - error: botvac.0 (24567) Error: undefined is not a valid state value
        at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17)
        at AdapterClass._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49)
        at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21)
        at /opt/iobroker/node_modules/iobroker.botvac/main.js:514:17
        at Robot. (/opt/iobroker/node_modules/node-botvac/lib/robot.js:77:17)
        at /opt/iobroker/node_modules/node-botvac/lib/robot.js:610:17
        at /opt/iobroker/node_modules/node-botvac/lib/api.js:40:45
        at
        at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
        2023-09-15 12:00:30.376 - error: botvac.0 (24567) undefined is not a valid state value
        2023-09-15 12:00:30.385 - info: botvac.0 (24567) terminating
        2023-09-15 12:00:30.386 - warn: botvac.0 (24567) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-09-15 12:00:30.395 - warn: botvac.0 (24567) State value to set for "botvac.0.Turnverein Oben.commands.spotWidth" has value "0" less than min "100"
        2023-09-15 12:00:30.398 - warn: botvac.0 (24567) State value to set for "botvac.0.Turnverein Oben.commands.spotHeight" has value "0" less than min "100"
        2023-09-15 12:00:30.524 - debug: botvac.0 (24567) get schedule {"type":1,"enabled":true,"events":[{"day":0,"startTime":"04:00"},{"day":2,"startTime":"04:00"},{"day":4,"startTime":"04:00"},{"day":1,"startTime":"04:00"},{"day":3,"startTime":"04:00"},{"day":5,"startTime":"04:00"},{"day":6,"startTime":"04:00"}]}
        2023-09-15 12:00:30.560 - error: botvac.0 (24567) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-09-15 12:00:30.560 - error: botvac.0 (24567) unhandled promise rejection: undefined is not a valid state value
        2023-09-15 12:00:30.560 - error: botvac.0 (24567) Error: undefined is not a valid state value
        at
        2023-09-15 12:00:30.561 - error: botvac.0 (24567) undefined is not a valid state value
        2023-09-15 12:00:30.577 - warn: botvac.0 (24567) State value to set for "botvac.0.Erdgeschoss.commands.spotWidth" has value "0" less than min "100"
        2023-09-15 12:00:30.578 - warn: botvac.0 (24567) State value to set for "botvac.0.Erdgeschoss.commands.spotHeight" has value "0" less than min "100"
        2023-09-15 12:00:30.586 - error: botvac.0 (24567) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-09-15 12:00:30.586 - error: botvac.0 (24567) unhandled promise rejection: undefined is not a valid state value
        2023-09-15 12:00:30.587 - error: botvac.0 (24567) Error: undefined is not a valid state value
        at
        2023-09-15 12:00:30.587 - error: botvac.0 (24567) undefined is not a valid state value
        2023-09-15 12:00:30.670 - warn: botvac.0 (24567) State value to set for "botvac.0.Obergeschoss.commands.spotWidth" has value "0" less than min "100"
        2023-09-15 12:00:30.671 - warn: botvac.0 (24567) State value to set for "botvac.0.Obergeschoss.commands.spotHeight" has value "0" less than min "100"
        2023-09-15 12:00:30.673 - debug: botvac.0 (24567) get schedule {"enabled":true,"events":[{"mode":2,"day":0,"startTime":"19:30","boundary":{"id":"a94e2a00-949e-4414-ab56-d506f2725d74","name":"Vorraum"},"mapId":"2022-10-03T15:30:57Z"},{"mode":2,"day":1,"startTime":"19:30","boundary":{"id":"a94e2a00-949e-4414-ab56-d506f2725d74","name":"Vorraum"},"mapId":"2022-10-03T15:30:57Z"},{"mode":2,"day":2,"startTime":"19:30","boundary":{"id":"a94e2a00-949e-4414-ab56-d506f2725d74","name":"Vorraum"},"mapId":"2022-10-03T15:30:57Z"},{"mode":2,"day":3,"startTime":"19:30","boundary":{"id":"a94e2a00-949e-4414-ab56-d506f2725d74","name":"Vorraum"},"mapId":"2022-10-03T15:30:57Z"},{"mode":2,"day":4,"startTime":"19:30","boundary":{"id":"a94e2a00-949e-4414-ab56-d506f2725d74","name":"Vorraum"},"mapId":"2022-10-03T15:30:57Z"},{"mode":2,"day":5,"startTime":"19:30","boundary":{"id":"a94e2a00-949e-4414-ab56-d506f2725d74","name":"Vorraum"},"mapId":"2022-10-03T15:30:57Z"},{"mode":2,"day":6,"startTime":"19:30","boundary":{"id":"a94e2a00-949e-4414-ab56-d506f2725d74","name":"Vorraum"},"mapId":"2022-10-03T15:30:57Z"}]}
        2023-09-15 12:00:30.702 - debug: botvac.0 (24567) get schedule {"enabled":true,"events":[{"mode":2,"day":1,"startTime":"07:50"},{"mode":2,"day":2,"startTime":"07:50"},{"mode":2,"day":3,"startTime":"07:50"},{"mode":2,"day":4,"startTime":"07:50"},{"mode":2,"day":5,"startTime":"08:30"},{"mode":2,"day":6,"startTime":"09:30"}]}
        2023-09-15 12:00:30.714 - debug: botvac.0 (24567) get schedule {"enabled":true,"events":[{"mode":2,"day":5,"startTime":"08:30","boundary":{"id":"7a60a658-82aa-4ef2-b2e5-bf6655c39f59","name":"Vorraum "},"mapId":"2021-11-01T08:33:05Z"},{"mode":2,"day":5,"startTime":"08:50","boundary":{"id":"7c8bb571-74aa-4150-8edd-bb46bf5939c9","name":"Bad Klo"},"mapId":"2021-11-01T08:33:05Z"},{"mode":2,"day":2,"startTime":"07:50"},{"mode":2,"day":3,"startTime":"07:50"},{"mode":2,"day":1,"startTime":"07:50","boundary":{"id":"7a60a658-82aa-4ef2-b2e5-bf6655c39f59","name":"Vorraum "},"mapId":"2021-11-01T08:33:05Z"},{"mode":2,"day":4,"startTime":"07:50","boundary":{"id":"7a60a658-82aa-4ef2-b2e5-bf6655c39f59","name":"Vorraum "},"mapId":"2021-11-01T08:33:05Z"},{"mode":2,"day":1,"startTime":"08:15","boundary":{"id":"7c8bb571-74aa-4150-8edd-bb46bf5939c9","name":"Bad Klo"},"mapId":"2021-11-01T08:33:05Z"},{"mode":2,"day":4,"startTime":"08:15","boundary":{"id":"7c8bb571-74aa-4150-8edd-bb46bf5939c9","name":"Bad Klo"},"mapId":"2021-11-01T08:33:05Z"},{"mode":2,"day":6,"startTime":"09:30"}]}
        2023-09-15 12:00:30.832 - error: botvac.0 (24567) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-09-15 12:00:30.833 - error: botvac.0 (24567) unhandled promise rejection: undefined is not a valid state value
        2023-09-15 12:00:30.833 - error: botvac.0 (24567) Error: undefined is not a valid state value
        at
        2023-09-15 12:00:30.834 - error: botvac.0 (24567) undefined is not a valid state value
        2023-09-15 12:00:30.879 - warn: botvac.0 (24567) State value to set for "botvac.0.Keller.commands.spotWidth" has value "0" less than min "100"
        2023-09-15 12:00:30.886 - info: botvac.0 (24567) terminating
        2023-09-15 12:00:30.920 - warn: botvac.0 (24567) State value to set for "botvac.0.Keller.commands.spotHeight" has value "0" less than min "100"
        2023-09-15 12:00:30.927 - warn: botvac.0 (24567) get state error: DB closed
        2023-09-15 12:00:30.928 - warn: botvac.0 (24567) get state error: DB closed
        2023-09-15 12:00:31.058 - error: host.VM-Slave instance system.adapter.botvac.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2023-09-15 12:00:31.061 - warn: host.VM-Slave Do not restart adapter system.adapter.botvac.0 because restart loop detected
        nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
        • JohGreJ JohGre
          @foxriver76
          Ok
          Funkt leider nicht
          at
          at
          at
          at
          mcm1957M Online
          mcm1957M Online
          mcm1957
          #70
          @JohGre
          OK und sorry,
          Dann mach bitte ein neues Issue beim Adapter auf und erstell hier ggF einen eigenen Thread zum Thema botvac. Das ist definitiv ain Anpassungsproblem diese Uralt Adapters der leider schon länger keine Wartung mehr hatte.
          Hoff ich / jemand kann das fixen auch ohne die passende Hardware zu haben.
          Aber wie gesagt - bitte in getrenntem Thread weiter behandeln (und diesn ggF hier verlinken). Das wird zu speziell hier.
          DANKE
          JohGreJ 1 Antwort Letzte Antwort
          • mcm1957M mcm1957
            @JohGre
            OK und sorry,
            DANKE
            JohGreJ Offline
            JohGreJ Offline
            JohGre
            schrieb am zuletzt editiert von JohGre
            #71
            @mcm57 Zur Info
            Habe gerade einen fork des community-Adapters gefunden der funktioniert. Vielleicht könnt ihr das zusammenlegen.
            https://github.com/PeterVoronov/ioBroker.botvac/tree/patch-1
            zugehöriger Thread:
            https://forum.iobroker.net/topic/44822/neato-botvac-adapter-further-development/45?_=1694772899628
            mcm1957M 2 Antworten Letzte Antwort
            • JohGreJ JohGre
              @mcm57 Zur Info
              zugehöriger Thread:
              mcm1957M Online
              mcm1957M Online
              mcm1957
              #72
              @johgre
              Danke für die Info; schaus mir an. Dieser Fork unterscheidet sich aber nur bei einer Variablen - nicht aber dort wo es jetzt bei dir gecrashed hat. Der Fix aus dem Fork kommt aber jedenfalls in die nächste Release.
              Aber bitte entweder im referenzierten Thread weiter oder einen neuen öffnen.
              • mcm1957M mcm1957
                @johgre
                mcm1957M Online
                mcm1957M Online
                mcm1957
                #73
                plenticore 2.3.0 - z.Z. nur im latest, stable in Planung (mit Vorbehalt, siehe untern)
                Weitere Adapter mit Problemen:
                • Adapter PLENTICORE ist (zumindest in der im stable verfügbaren Version 2.2.0) mit js-controller inkompatibel.
                  https://forum.iobroker.net/topic/68313/plenticore-adapter-startet-nicht-nach-aktualisierung
                • Adapter FITBIT-FITNESS ist mit js-controlelr 5 inkompatibel. Dev hat auf Issue aus April bisher nicht reagiert. Eine Meldung über Probleme, eine Meldung dass alles OK ...
                  https://forum.iobroker.net/topic/68328/fitbit-app-läuft-mit-js-controller-5-0-12-nicht-mehr
                  https://forum.iobroker.net/topic/68290/js-controller-5-0-x-jetzt-für-alle-user-im-stable/86
                  @merowinger
                  root...
                  DuffyD Online
                  DuffyD Online
                  Duffy
                  schrieb am zuletzt editiert von Duffy
                  #74
                  Hallo thomas-braun,
                  ich habe mir das jetzt alles mal durchgelesen und mir raucht jetzt echt der Kopf, ich habe da einfach zu wenig Ahnung von der Materie.
                  Deshalb meine Frage an dich, du warst mir schon oft eine grosse hilfe ob man das Update durch klicken auf den Update Button starten soll, muss, kann. (Siehe Bild)
                  Die ganzen Adapter die heute neu als Stable angeboten wurden habe ich gemacht und meine Node.js ist v18.17.1
                  Aktuell habe ich auf meinem Raspberry Pi noch Bullseye laufen.
                  Backup ist mit Backitup gemacht.
                  Kann ich unter den Voraussetzungen ein Update wagen? Ich frage lieber vorher bevor ich Tage lang versuchen muss alles neu aufzusetzen.
                  Viele Grüße Duffy
                  Edit:
                  Habe bei meinem Test Pi auf den "Knopf" gedrückt und es kam eine Installationsanleitung:
                  cd /opt/iobroker/
                  sudo iobroker stop
                  sudo iobroker upgrade
                  sudo iobroker upgrade self
                  sudo iobroker start
                  Sollte es also mit den Befehlen, die ja vergleichbar sind zum ersten Post, klappen?
                  Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
                  Node.js: v22.23.2
                  NPM: 10.9.4
                  js-controller 7.1.2
                  Linux: Trixie
                  DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                  • DuffyD Duffy
                    Hallo thomas-braun,
                    Viele Grüße Duffy
                    Edit:
                    cd /opt/iobroker/
                    sudo iobroker stop
                    sudo iobroker start
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    #75
                    @duffy sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                    sudo iobroker stop
                    SUDO ist in Verbindung mit iobroker so ziemlich verboten.
                    Woher hast Du diese Anleitung ?
                    Lehrling seit 1975 !!!
                    • DJMarc75D DJMarc75
                      sudo iobroker stop
                      DuffyD Online
                      DuffyD Online
                      Duffy
                      #76
                      @djmarc75
                      Die u.A die Befehle kamen als ich auf den "Knopf" bgedrückt habe aus meinem Post.
                      Node.js: v22.23.2
                      NPM: 10.9.4
                      js-controller 7.1.2
                      Linux: Trixie
                      • DuffyD Duffy
                        Hallo thomas-braun,
                        Viele Grüße Duffy
                        Edit:
                        cd /opt/iobroker/
                        sudo iobroker stop
                        sudo iobroker start
                        #77
                        klappen?
                        Mit sudo klappt da nix. Nur alles zusammen.
                        Vermutlich. Ist aber auch kein Thema für diesen Thread.
                        • DuffyD Duffy
                          @djmarc75
                          #78
                          Du hast aber vermutlich keine manuelle Installation als root gemacht sondern das Skript verwendet.
                            klappen?
                            DuffyD Online
                            DuffyD Online
                            Duffy
                            #79
                            Sorry, hate nur hier gefragt weil es hier ja um das Update geht.
                            Gruß Duffy
                            Node.js: v22.23.2
                            NPM: 10.9.4
                            js-controller 7.1.2
                            Linux: Trixie
                            • DuffyD Duffy
                              Gruß Duffy
                              #80
                              @duffy
                              Die Befehle, aber ohne sudo vorweg.
                              • wendy2702W wendy2702
                                @x4n70 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                                Hat jemand den linux-control mal getestet? Er scheint ja nicht mehr gepflegt zu werden, sieht für mich in GitHub ziemlich eindeutig aus. Aber funktioniert er denn unter 5.x?
                                Läuft bei mir auch noch
                                sunny9999
                                #81
                                @wendy2702 @x4N70 @Latzi
                                bei mir leider nicht mehr haut folgende Fehler raus :
                                host.IOBROKER-MASTER
                                2023-09-15 16:16:45.354	info	Restart adapter system.adapter.linux-control.0 because enabled
                                2023-09-15 16:16:45.354	error	instance system.adapter.linux-control.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                2023-09-15 16:16:45.354	error	Caught by controller[22]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-15 16:16:45.354	error	Caught by controller[22]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                                2023-09-15 16:16:45.354	error	Caught by controller[22]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                                2023-09-15 16:16:45.354	error	Caught by controller[22]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                2023-09-15 16:16:45.354	error	Caught by controller[22]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2023-09-15 16:16:45.354	error	Caught by controller[21]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-15 16:16:45.354	error	Caught by controller[21]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                                2023-09-15 16:16:45.354	error	Caught by controller[21]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                                2023-09-15 16:16:45.354	error	Caught by controller[21]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                2023-09-15 16:16:45.354	error	Caught by controller[20]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2023-09-15 16:16:45.354	error	Caught by controller[19]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-15 16:16:45.354	error	Caught by controller[19]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                                2023-09-15 16:16:45.354	error	Caught by controller[19]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                                2023-09-15 16:16:45.354	error	Caught by controller[19]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                2023-09-15 16:16:45.354	error	Caught by controller[19]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2023-09-15 16:16:45.354	error	Caught by controller[18]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-15 16:16:45.354	error	Caught by controller[18]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                                2023-09-15 16:16:45.354	error	Caught by controller[18]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                                2023-09-15 16:16:45.354	error	Caught by controller[18]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                2023-09-15 16:16:45.354	error	Caught by controller[18]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2023-09-15 16:16:45.354	error	Caught by controller[17]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-15 16:16:45.354	error	Caught by controller[17]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                                2023-09-15 16:16:45.353	error	Caught by controller[17]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                                2023-09-15 16:16:45.353	error	Caught by controller[17]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                2023-09-15 16:16:45.353	error	Caught by controller[17]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2023-09-15 16:16:45.353	error	Caught by controller[16]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-15 16:16:45.353	error	Caught by controller[16]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                                2023-09-15 16:16:45.353	error	Caught by controller[16]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                                2023-09-15 16:16:45.353	error	Caught by controller[16]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                2023-09-15 16:16:45.353	error	Caught by controller[15]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2023-09-15 16:16:45.353	error	Caught by controller[14]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-15 16:16:45.353	error	Caught by controller[14]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                                2023-09-15 16:16:45.353	error	Caught by controller[14]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                                2023-09-15 16:16:45.353	error	Caught by controller[14]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                2023-09-15 16:16:45.353	error	Caught by controller[13]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2023-09-15 16:16:45.353	error	Caught by controller[12]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-15 16:16:45.353	error	Caught by controller[12]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                                2023-09-15 16:16:45.353	error	Caught by controller[12]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                                2023-09-15 16:16:45.353	error	Caught by controller[12]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                2023-09-15 16:16:45.350	error	Caught by controller[11]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2023-09-15 16:16:45.350	error	Caught by controller[10]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-15 16:16:45.350	error	Caught by controller[10]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                                2023-09-15 16:16:45.350	error	Caught by controller[10]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                                2023-09-15 16:16:45.350	error	Caught by controller[10]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                2023-09-15 16:16:45.350	error	Caught by controller[10]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2023-09-15 16:16:45.349	error	Caught by controller[9]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-15 16:16:45.349	error	Caught by controller[9]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                                2023-09-15 16:16:45.349	error	Caught by controller[9]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                                2023-09-15 16:16:45.349	error	Caught by controller[9]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                2023-09-15 16:16:45.349	error	Caught by controller[9]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2023-09-15 16:16:45.349	error	Caught by controller[8]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-15 16:16:45.349	error	Caught by controller[8]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                                2023-09-15 16:16:45.349	error	Caught by controller[8]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                                2023-09-15 16:16:45.349	error	Caught by controller[8]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                2023-09-15 16:16:45.349	error	Caught by controller[8]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2023-09-15 16:16:45.349	error	Caught by controller[7]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-15 16:16:45.349	error	Caught by controller[7]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                                2023-09-15 16:16:45.349	error	Caught by controller[7]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                                2023-09-15 16:16:45.349	error	Caught by controller[7]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                2023-09-15 16:16:45.349	error	Caught by controller[7]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2023-09-15 16:16:45.349	error	Caught by controller[6]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-15 16:16:45.349	error	Caught by controller[6]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                                2023-09-15 16:16:45.349	error	Caught by controller[6]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                                2023-09-15 16:16:45.349	error	Caught by controller[6]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.start" is not a valid ID pattern
                                2023-09-15 16:16:45.349	error	Caught by controller[6]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2023-09-15 16:16:45.349	error	Caught by controller[5]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-15 16:16:45.349	error	Caught by controller[5]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                                2023-09-15 16:16:45.349	error	Caught by controller[5]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                                2023-09-15 16:16:45.349	error	Caught by controller[5]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                2023-09-15 16:16:45.349	error	Caught by controller[5]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2023-09-15 16:16:45.349	error	Caught by controller[4]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-15 16:16:45.349	error	Caught by controller[4]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                                2023-09-15 16:16:45.349	error	Caught by controller[4]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                                2023-09-15 16:16:45.349	error	Caught by controller[4]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                2023-09-15 16:16:45.349	error	Caught by controller[4]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2023-09-15 16:16:45.349	error	Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-15 16:16:45.349	error	Caught by controller[3]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                                2023-09-15 16:16:45.349	error	Caught by controller[3]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                                2023-09-15 16:16:45.349	error	Caught by controller[3]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                2023-09-15 16:16:45.349	error	Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2023-09-15 16:16:45.349	error	Caught by controller[2]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-15 16:16:45.349	error	Caught by controller[2]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                                2023-09-15 16:16:45.349	error	Caught by controller[2]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                                2023-09-15 16:16:45.348	error	Caught by controller[2]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                2023-09-15 16:16:45.348	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2023-09-15 16:16:45.348	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-15 16:16:45.348	error	Caught by controller[1]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                                2023-09-15 16:16:45.348	error	Caught by controller[1]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                                2023-09-15 16:16:45.348	error	Caught by controller[1]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                2023-09-15 16:16:45.348	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                2023-09-15 16:16:45.348	error	Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-15 16:16:45.348	error	Caught by controller[0]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                                2023-09-15 16:16:45.348	error	Caught by controller[0]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                                2023-09-15 16:16:45.348	error	Caught by controller[0]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                2023-09-15 16:16:45.348	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                linux-control.0
                                2023-09-15 16:16:44.899	error	The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.899	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0
                                2023-09-15 16:16:44.899	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.898	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0
                                2023-09-15 16:16:44.897	error	The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.897	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0
                                2023-09-15 16:16:44.896	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.896	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0
                                2023-09-15 16:16:44.888	error	The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.888	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0
                                2023-09-15 16:16:44.888	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.887	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0
                                2023-09-15 16:16:44.885	error	The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.885	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0
                                2023-09-15 16:16:44.885	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.885	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0
                                2023-09-15 16:16:44.875	error	The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.875	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0
                                2023-09-15 16:16:44.875	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.874	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0
                                2023-09-15 16:16:44.872	error	The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.872	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0
                                2023-09-15 16:16:44.872	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.872	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0
                                2023-09-15 16:16:44.857	error	The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.857	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0
                                2023-09-15 16:16:44.857	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.857	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0
                                2023-09-15 16:16:44.854	error	The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.854	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0
                                2023-09-15 16:16:44.854	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.854	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0
                                2023-09-15 16:16:44.795	error	The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.795	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0
                                2023-09-15 16:16:44.794	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.794	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0
                                2023-09-15 16:16:44.792	error	The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.792	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0
                                2023-09-15 16:16:44.791	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.791	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0
                                2023-09-15 16:16:44.773	error	The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.772	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0
                                2023-09-15 16:16:44.772	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.772	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0
                                2023-09-15 16:16:44.770	error	The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.770	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0
                                2023-09-15 16:16:44.769	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.769	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0
                                2023-09-15 16:16:44.677	error	The pattern "io.linux-control.0.Monitor-PI.services.●.start" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.677	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.start" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0
                                2023-09-15 16:16:44.677	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.start" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.677	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0
                                2023-09-15 16:16:44.670	error	The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.670	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0
                                2023-09-15 16:16:44.670	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.669	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0
                                2023-09-15 16:16:44.667	error	The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.667	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0
                                2023-09-15 16:16:44.666	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.666	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0
                                2023-09-15 16:16:44.636	error	The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.635	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0
                                2023-09-15 16:16:44.635	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.635	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0
                                2023-09-15 16:16:44.633	error	The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.632	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0
                                2023-09-15 16:16:44.632	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.632	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0
                                2023-09-15 16:16:44.611	error	The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.611	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0
                                2023-09-15 16:16:44.610	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.610	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0
                                2023-09-15 16:16:44.576	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                linux-control.0
                                2023-09-15 16:16:44.575	info	terminating
                                linux-control.0
                                2023-09-15 16:16:44.575	info	cleaned everything up...
                                linux-control.0
                                2023-09-15 16:16:44.558	error	The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.558	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                linux-control.0
                                2023-09-15 16:16:44.481	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
                                linux-control.0
                                2023-09-15 16:16:44.480	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                linux-control.0
                                2023-09-15 16:16:38.470	info	getting data from Monitor-PI (192.168.10.25:22, Adapter start)
                                linux-control.0
                                2023-09-15 16:16:38.469	info	getting data from IO-SLAVE (192.168.10.17:22, Adapter start)
                                linux-control.0
                                2023-09-15 16:16:38.469	info	getting data from RDP-PI (192.168.10.65:22, Adapter start)
                                linux-control.0
                                2023-09-15 16:16:38.468	info	getting data from LABEL-PI (192.168.10.66:22, Adapter start)
                                linux-control.0
                                2023-09-15 16:16:38.431	info	starting. Version 1.1.6 (non-npm: Scrounger/ioBroker.linux-control#59f578f3402850684ba8767a24a9ff288b05a3f0) in /opt/iobroker/node_modules/iobroker.linux-control, node: v18.16.1, js-controller: 5.0.12
                                Schon deinstalliert und neu installiert.
                                Hab auch noch Probleme mit email und samsung_tizen adaptern..... Rest rennt
                                Jemand noch nen Tip ?
                                Sunny
                                mcm1957M Thomas BraunT 2 Antworten Letzte Antwort
                                • S sunny9999
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  linux-control.0
                                  Sunny
                                  mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  #82
                                  Es gab da ein issue beim linux control
                                  https://github.com/Scrounger/ioBroker.linux-control/issues/49
                                  Keine Ahnung ob relevant für dein Problem. Abercschau mal rein.
                                  • S sunny9999
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    linux-control.0
                                    Sunny
                                    #83
                                    @sunny9999 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                                    ices.●.rest
                                    Dürfte ein illegales Zeichen an der Stelle sein.
                                    • foxriver76F foxriver76
                                      Hallo ioBroker-Community,
                                      Heute möchten wir Euch den js-controller 5.0 endlich auch im STABLE Repository zur Verfügung stellen. Dieser Post enthält alle wichtigen Infos. Bitte unbedingt lesen!!
                                      Wir bedanken uns bei allen Usern die bisher die neue Version bereits als Alpha oder Beta getestet und Feedback gegeben haben.
                                      Node.js Versions-Anforderungen
                                      In diesem Release entfällt Node.js 12.x welches seit April letztem Jahr nicht mehr gepflegt wird und Node.js 14.x welches seit April diesem Jahres EOL ist. Node.js 18.x ist dazugekommen. Die unterstützten Node.js Versionen sind: 16.4.0+ und 18.x und nach aktuellem Stand Node.js 20.x, wobei hier noch erfahrungen fehlen. Die empfohlene Node.js Version für ioBroker haben wir vor kurzem auf 18.x angehoben.
                                      Bitte beachtet weiterhin bei Node.js Updates die Anleitung im Forum unter https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-14-16-und-18 !
                                      Informationen zur Version
                                      Es gibt EINIGE Adapter die aktualisiert werden müssen!! Bitte weiter unten lesen!
                                      In dieser Version wurde die Umstellung des Quellcodes auf TypeScript sehr stark vorangetrieben (inzwischen bei 88%), wodurch am Ende die Stabilität weiter steigt weil viele Code-Fehler nicht mehr auftreten können. Natürlich sind neben Optimierungen und Fehlerbehebungen auch ein paar neue Features hinzugekommen. Auch wenn mit dieser Version keine neuen Prüfungen hinzukommen, die zu Log-Ausgaben bei Adaptern führen, meldet aktuelle Logausgaben bitte weiterhin bei den Adaptern.
                                      Detailliertere Informationen zu allen Änderungen und Features findet Ihr weiter unten und im Changelog.
                                      Für die aktive Mitarbeit an dieser Version des js-controller bedanke mich diesmal wieder besonders bei Apollon77, AlCalzone und natürlich Bluefox und auch ein paar weiteren Entwicklern!
                                      ACHTUNG backups inkompatibel bei Downgrades!!
                                      Neben der Node.js Version gibt es eine wichtige Inkompatibilität: Backups die mit der 5.0 des js-controller erstellt wurden lassen sich nicht mit einem js-controller 4 oder kleiner wieder restoren!
                                      Darüber hinaus ist der js-controller 5.0 generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2/3.x ist problemlos möglich. Wir empfehlen allerings vor dem Update auf die 5.0 idealerweise ein Update auf die 4.0 und vorher auf 3.3.x durchzuführen, da ein Downgrade nach einem erfolgten Update nur auf eine 3.3.x möglich ist (siehe FAQ)! Nur die Node.js Version muss weiterhin mindestens 16.x sein, wie oben bereits ausgeführt. Wer überlegt die Node.js Version anzuheben bitte weiter unten im Abschnitt "Was ist zu testen" lesen 🙂
                                      Aufgrund einiger internen Umstellungen brauchen wieder einige Adapter Updates. Diese sollten am besten VOR dem Update installiert werden!
                                      Bitte dazu die Informationen weiter unten beachten!
                                      Installation
                                      VOR der Installation
                                      Wie bei jedem Upgrade dieser Art: Bitte macht ein Backup! iobroker backup bzw kopieren des iobroker-data Verzeichnisses reichen an sich aus. Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt. Eine alte 4.0.x-Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version ("version" durch die gewünschte Versionsnummer ersetzen) installiert werden und sollte alles wieder herstellen (Vorheriger Stable Stand ist die 4.0.24)
                                      Nötige Adapter-Aktualisierungen
                                      Am besten dennoch VOR dem js-controller Update alle verfügbaren Adapter-Updates prüfen und alle Updates installieren, die im Changelog auf Optimierungen oder Anpassungen für den js-controller 4.0 oder höher hinweisen.
                                      Diesmal sind doch einige Adapter auf der Liste die man updaten muss -falls installiert! Siehe Spoiler!
                                      • ✅ acme - required: none / 0.1.0 - released
                                      • ✅ admin - required: 6.8.0 - released
                                      • ✅ anelhut - required: 1.0.15 - released
                                      • ✅b-control-em - required: 0.3.1 - released
                                      • ⚪ bosch-ebike - required: none
                                      • ✅ cul - required: 2.2.0 - released (no change)
                                      • ✅ daikin-cloud - required: 0.3.0 - released
                                      • ✅ doorbird - required: 0.1.7 - newer released
                                      • ✅ ds18b20 - required: 2.0.4 - released
                                      • ✅ energymanager - required: 1.4.2 - released
                                      • ⚪ enigma2 - required: none - not at stable yet
                                      • ✅ fakeroku - required: 0.2.2+ - released
                                      • ✅ fhem - required: 2.0.5 - released
                                      • ✅ history - required: 2.2.6 - released
                                      • ✅ iqontrol - required: 2.3.0 - released
                                      • ⚪ javascript - required: none
                                      • 🚫 km200 - deprecated - Ersatz: ems-esp
                                      • ✅ lgtv - required: 1.1.12 - released
                                      • ❗linux-control - required: ???
                                      • ✅ maxcul - required: 1.3.1 (no change)
                                      • ⚪ miio - required: none - not at stable
                                      • ✅ mydlink - required: 1.3.4 - released
                                      • ✅ nanoleaf-lightpanales - required: 1.4.0 - released
                                      • ✅ node-red - required: 4.03+ (no change)
                                      • ✅ notification.manager - required: 0.1.1 - released
                                      • ✅ pi-hole - required: 1.3.6+ - released
                                      • ✅ ping - required: 1.6.2 - released
                                      • ✅ pushbullet - required: 1.0.1 - released
                                      • 🚫 samsung_tyzen - stale repo - deprecated with js-controller 5
                                      • ✅ socketio - required: 6.5.2 - released
                                      • ✅ stiebel-isg - required: 1.7.6+ - newer released
                                      • ✅ systeminfo - required: 1.0.0 - released
                                      • ✅ viessmann - required: 1.4.4+ - released
                                      • ✅ web - required: 6.1.0 - released
                                      • ✅ ws - required: 2.5.3 - released
                                      • ✅yahka - required: 1.0.1 - newer version released
                                      • ✅ zigbee - required: 1.8.23 - released
                                      Achtung: MASTER-Systeme Reihenfolgen beachten!
                                      Bei einem Multi-Host-System, welches auf js-controller 2.2, 3.x oder 4.0.x läuft, ist es beim Update auf Version 5.0 empfohlen, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
                                      Bei Updates von Master/Slave-Systemen mit js-controller 1.5 oder früher Bitte die jeweiligen Update Threads der empfohlenen Zwischenversionen prüfen.
                                      Windows
                                      Generell muss das Update manuell via npm installiert werden.
                                      Hierzu im ioBroker-Verzeichnis nach stoppen des ioBroker den Befehl iob upgrade self ausführen.
                                      Linux
                                      • ioBroker stoppen (iobroker stop)
                                      • Prüfen das keine Prozesse (Adapter, Backups) mehr laufen (ps auxww|grep io und auch ps auxww|grep backup ). Es passiert manchmal das trotz dem Stoppen noch Zombies zurückbleiben
                                      • cd /opt/iobroker
                                      • Das Update erfolgt via iob upgrade self
                                      • ioBroker starten (iobroker start)
                                      Bei Fehlern:
                                      Wenn bei der Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer (iobroker fix wer schon einen js-controller 2.x oder höher hat, alternativ weiterhin manuell via curl -sL https://iobroker.net/fix.sh | bash -) nutzen und die Installation wiederholen.
                                      Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install iobroker.js-controller versuchen. Bitte berichtet solche Fälle hier im Thread.
                                      NACH der Installation
                                      Wenn alles klappt merkt Ihr ausser der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt.
                                      Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
                                      Was hat sich geändert, was besonders ansehen/beachten?
                                      Neben einiger weiterer Bugfixes gibt es folgende Änderungen und Fixes zu erwähnen:
                                      • generell siehe Changelog, speziell auch für die Features
                                      • generell bitte im CLI und auch sonst überall drüber schauen. Die Typescript Umstellungen haben sehr viel Code angefasst.
                                      • Falls jemand sporadisch Alias Fehler im Log hatte bitte versuchen diese mit der neuen version wieder zu provoziere und rückmelden
                                      Speziell die Entwickler sollten bitte die genannten Deprecations und neuen Features anschauen und beachten.
                                      Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
                                      5.0. Release Jana
                                      BREAKING CHANGES
                                      • Support for Node.js 12 and 14 is dropped! Supported are Node.js 16.4.0+ and 18.x and hopefully 20.x
                                      • Backups created with the new js-controller version cannot be restored on hosts with lower js-controller version!
                                      • Update recommended npm version to 8
                                      • Deprecate binary states, Adapters will change to use Files instead!
                                      Features
                                      • (foxriver76) Show npm error message on failing adapter installations and update also without debug parameter
                                      • (foxriver76) Introduce iobroker setting (dnsResolution) to choose between verbatim and ipv4 first dns resolution order
                                      • (foxriver76) Add support for windows for iob fix
                                      • (bluefox) Added CLI option to restart/start/stop all instances of an adapter (e.g. iob stop admin now also works)
                                      • (foxriver76) Allow to use iob host oldname command when new host already exists but has no instances
                                      • (foxriver76) Added an admin notification if redis is misconfigured and info how to fix it
                                      • (foxriver76) Enable upgrade of js-controller via Admin UI (Linux only)
                                      Optimizations and Fixes
                                      • (foxriver76) Speedup "getStates" calls with many IDs often used by visualizations: JSONL 17 times faster, Redis 23 times faster
                                      • (foxriver76) significantly reduce backup size
                                      • (foxriver76) Enhance CLI help for list command to show all possible types to list
                                      • (foxriver76) Also stop instances before updating from GitHub
                                      • (foxriver76) Conversion of big parts of the js-controller codebase to typeScript and address all found issues
                                      • (Apollon77) Only log error on "enable/disable via .alive" if there is an error
                                      • (foxriver76) Optimize adapter unload and stop handling for edge cases
                                      • (AlCalzone) Carefully normalize jsonlOptions
                                      • (bluefox) Do not show warning on a requested adapter stop/termination
                                      • (bluefox) Make sure that the first log line is not missing in Admin
                                      • (foxriver76) Fix wrong formatting of cli get binary state if no encoding is passed
                                      • (foxriver76) Fix restoring backups from pre js-controller 4.x which were created without config.system
                                      • (foxriver76) Preserve tier setting on adapter upload
                                      • (foxriver76) update apt sources before installing os dependencies
                                      • (foxriver76) Only skip erase on upload if opted out explicitly to always cleanup unneeded files
                                      • (foxriver76) Try to fix strange alias errors, inform us if it happens again!
                                      • (foxriver76) Remove windows bat files completely, installer will create them when needed
                                      • (AlCalzone/Apollon77) Update jsonl db to prevent locking issues
                                      • (foxriver76) Fixes iob file sync not working for jsonl
                                      • (foxriver76) Do not crash if we cannot initialize db backup directory on start
                                      • (foxriver76) Fixed issue with certificate validity on leap years
                                      • (Apollon77/foxriver76) Make sure that all relevant files are removed when eraseOnUpload is used
                                      • (foxriver76) fix wrong hostname after backup restore
                                      • (bluefox) allow CLI vendor update without explicitly specifying vendor file (default file is used)
                                      • (Apollon77, foxriver76, bluefox, AlCalzone) Several fixes and refactorings to prevent potential crash cases reported by Sentry and other sources
                                      Developer relevant DEPRECATIONS/WARNINGS
                                      • Deprecate binary states, Migrate your adapters to use Files instead!
                                      • If you need to access special js-controller common tools please use adapter-core instead of js-controller directly - see https://github.com/ioBroker/adapter-core#commontools
                                      • Parameter that contain patterns (e.g. mqtt.*) are now checked for allowed characters and general correctness!
                                      Developer relevant new Features
                                      • (bluefox) Added options to subscribe to file changes: subscribeForeignFiles, unsubscribeForeignFiles, onAdapterFileChanged (event contains id, fileName, size and not the whole content of the file!)
                                      • (foxriver76) Introduce on("install") handler for adapter which is automatically called when adapter process is started with --install
                                      • (foxriver76) Introduce io-package flag common.nodeProcessParams to allow to pass adapter specific nodejs process parameters (disables compact mode for the adapter!)
                                      • (foxriver76) Respect dns resolution (ipv4/ipv6 first) from config internally and provide relevant methods via adapter-core
                                      • (foxriver76) Add JSON-Schema for iobroker.json
                                      • (bluefox) Allowed export of password.js (to be used with adapter-core)
                                      • (bluefox) Added _design/chart to the system designs
                                      • (foxriver76) Automatically generated Code-Docs for Adapter class https://github.com/ioBroker/ioBroker.js-controller/tree/master/packages/controller/doc
                                      • (foxriver76) Added (foreign)objectExists to adapter methods
                                      • (bluefox) Extend getSuitableLicenses to look for other licenses
                                      • (buefox/foxriver76) Added new category for notifications: blocked and respect js-controller common.blockedVersions to block versions from starting
                                      • (bluefox) Added new system view "custom-full" to return the full objects for objects with a custom part and not only the custom details
                                      • (foxriver76) Added support for getForeignObjects with an array of strings as pattern
                                      • (AlCalzone) Preparations to allow js-controller Dev version to be used with dev-server
                                      • (foxriver76) Validate max timeout value (max 32bit max number) on setTimeout/setInterval and throw on error to prevent issues
                                      • (foxriver76) new io-package flag common.supportedMessages to replace messagebox and other messagebox-related properties
                                      • (foxriver76) adapter.sendTo now accepts an optional timeout argument
                                      • Developer relevant Optimizations and Fixes
                                      • (foxriver76) Ensure setObjectNotExists returns id on success
                                      • (foxriver76) Fix Typings for sendTo/sendToHost
                                      • (Bluefox) Add User permission check to requireLog
                                      • (foxriver76) added nonEdit property of objects to types and document functionality
                                      • (foxriver76) introduced constants for state quality
                                      • (foxriver76) subscribeStates now also accepts an array of ids
                                      • general dependency updates
                                      • code style optimizations and streamline code
                                      Generell ist zu testen, ob alles noch so funktioniert wie vorher auch. Das ist das wichtigste!
                                      Wie Fehler melden?
                                      Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
                                      Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Kommandozeile endet, dann dazu am besten direkt ein GitHub-Issue im js-controller Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben.
                                      Bitte postet auch die Ausgabe von iob diag mit rein.
                                      Wir wünschen allen viel Spaß mit dem neuen Controller und vielen Dank für Eure Unterstützung!
                                      fox
                                      FabioF Offline
                                      FabioF Offline
                                      Fabio
                                      schrieb am zuletzt editiert von Fabio
                                      #84
                                      @foxriver76 @Bluefox eben kam das Update vom Javasript 7.1.4
                                      Das Exportieren der Scripte funktioniert wieder. Vielen Dank euch.....👍
                                      Fabio
                                      Iobroker:
                                      • Matter over Thread Hilfe
                                      • liv-in-skyL liv-in-sky
                                        @foxriver76
                                        also sayit hat sich erledigt - neu installiert und jetzt kommt kein fehler
                                        das mit ws.5 ist etwas seltsam - habe nur ws.0 und ws.1 aktiv und ws.5 - habe jetzt ws5 abgeschaltet und in ws.2 definiert - dann startet alles ohne fehler und die vis ist wieder da
                                        diese ganzen ws.x hatte ich mal installiert und getestet, ob meine tablets die vis stabiler anzeigen, wenn jedes tablet eigene instanzen hat
                                        bleibt n nur noch diese warnung:
                                        	Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
                                        MartinPM Online
                                        MartinPM Online
                                        MartinP
                                        #85
                                        @liv-in-sky said in js-controller 5.0.x jetzt für alle User im STABLE!:
                                        @foxriver76
                                        Diese Warnung habe ich auch von simple-api.0 ... keine Antwort auf Deine Frage im Thread gefunden
                                        liv-in-skyL foxriver76F mcm1957M 3 Antworten Letzte Antwort
                                        • mcm1957M mcm1957
                                          Aktualisierung der Liste erforderlicher Adapterupdates:
                                          javascript 7.1.4 - stable verfügbar ab 15.9. nachmittags
                                          enigma2 2.0.3 - nur via latest repository verfügbar
                                          #86
                                          @mcm57 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                                          Das war bei mir am Anfang mit den Alpha 5.x, seit der 5.0.10 läuft der Fitbit Adapter einwandfrei.
                                          Node 18.17.0, NPM 9.6, Debian bookworm im lxc.
