  4. Adapter Aktualisierung funktioniert nicht
    5.2k
28 Beiträge 6 Kommentatoren 2.2k Aufrufe 6 Beobachtet
  • M manmac1
    @glasfaser said in Adapter Aktualisierung funktioniert nicht:
    iobroker@iobroker:~$ cd /opt/iobroker/node_modules/openzwave-shared
    iobroker@iobroker:/opt/iobroker/node_modules/openzwave-shared$ npm install --omit=dev
    > openzwave-shared@1.4.1 preinstall
    > node lib/install-ozw.js
    > openzwave-shared@1.4.1 install
    > node-gyp rebuild
    gyp info it worked if it ends with ok
    gyp info using node-gyp@7.1.2
    gyp info using node@18.16.0 | linux | x64
    gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
    (node:14306) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
    (Use `node --trace-deprecation ...` to show where the warning was created)
    gyp info spawn /usr/bin/python3
    gyp info spawn args [
    gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
    gyp info spawn args   'binding.gyp',
    gyp info spawn args   '-f',
    gyp info spawn args   'make',
    gyp info spawn args   '-I',
    gyp info spawn args   '/opt/iobroker/node_modules/openzwave-shared/build/config.gypi',
    gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
    gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.16.0/include/node/common.gypi',
    gyp info spawn args   '-Dlibrary=shared_library',
    gyp info spawn args   '-Dvisibility=default',
    gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.16.0',
    gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
    gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.16.0/<(target_arch)/node.lib',
    gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/openzwave-shared',
    gyp info spawn args   '-Dnode_engine=v8',
    gyp info spawn args   '--depth=.',
    gyp info spawn args   '--no-parallel',
    gyp info spawn args   '--generator-output',
    gyp info spawn args   'build',
    gyp info spawn args   '-Goutput_dir=.'
    gyp info spawn args ]
    gyp info spawn make
    gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
    make: Verzeichnis „/opt/iobroker/node_modules/openzwave-shared/build“ wird betreten
      CXX(target) Release/obj.target/openzwave_shared/src/callbacks.o
    In file included from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:192,
                     from ../src/openzwave.hpp:27,
                     from ../src/callbacks.cc:18:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Value>, v8::PropertyAttribute)’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_maybe_43_inl.h:112:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
      112 |   return obj->ForceSet(isolate->GetCurrentContext(), key, value, attribs);
    In file included from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters.h:59,
                     from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:197,
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase<v8::Boolean>::return_t Nan::imp::ToFactory<v8::Boolean>::convert(v8::Local<v8::Value>)’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters_43_inl.h:18:67: error: cannot convert ‘v8::Local<v8::Context>’ to ‘v8::Isolate*’
       18 |       val->To ## TYPE(v8::Isolate::GetCurrent()->GetCurrentContext())          \
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’
       22 | X(Boolean)
    In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-primitive.h:11,
                     from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:11,
                     from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-array-buffer.h:13,
                     from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8.h:24,
                     from ../src/openzwave.hpp:26,
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-value.h:398:37: note:   initializing argument 1 of ‘v8::Local<v8::Boolean> v8::Value::ToBoolean(v8::Isolate*) const’
      398 |   Local<Boolean> ToBoolean(Isolate* isolate) const;
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase<bool>::return_t Nan::imp::ToFactory<bool>::convert(v8::Local<v8::Value>)’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters_43_inl.h:37:55: error: cannot convert ‘v8::Local<v8::Context>’ to ‘v8::Isolate*’
       37 |   return val->NAME ## Value(isolate->GetCurrentContext());                     \
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’
       40 | X(bool, Boolean)
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-value.h:408:30: note:   initializing argument 1 of ‘bool v8::Value::BooleanValue(v8::Isolate*) const’
      408 |   bool BooleanValue(Isolate* isolate) const;
    In file included from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_new.h:189,
                     from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:198,
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::Function>::return_t Nan::imp::Factory<v8::Function>::New(Nan::FunctionCallback, v8::Local<v8::Value>)’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_implementation_12_inl.h:103:42: error: cannot convert ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
      103 |   return scope.Escape(v8::Function::New( isolate
          |                                          v8::Isolate*
    In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8.h:33,
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-function.h:33:22: note:   initializing argument 1 of ‘static v8::MaybeLocal<v8::Function> v8::Function::New(v8::Local<v8::Context>, v8::FunctionCallback, v8::Local<v8::Value>, int, v8::ConstructorBehavior, v8::SideEffectType)’
       33 |       Local<Context> context, FunctionCallback callback,
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::StringObject>::return_t Nan::imp::Factory<v8::StringObject>::New(v8::Local<v8::String>)’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_implementation_12_inl.h:337:37: error: no matching function for call to ‘v8::StringObject::New(v8::Local<v8::String>&)’
      337 |   return v8::StringObject::New(value).As<v8::StringObject>();
    In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8.h:47,
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-primitive-object.h:81:23: note: candidate: ‘static v8::Local<v8::Value> v8::StringObject::New(v8::Isolate*, v8::Local<v8::String>)’
       81 |   static Local<Value> New(Isolate* isolate, Local<String> value);
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-primitive-object.h:81:23: note:   candidate expects 2 arguments, 1 provided
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_implementation_12_inl.h:337:58: error: expected primary-expression before ‘>’ token
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_implementation_12_inl.h:337:60: error: expected primary-expression before ‘)’ token
    In file included from ../src/openzwave.hpp:27,
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:835:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
      835 |         v8::Isolate::GetCurrent(), target, func, argc, argv);
    In file included from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:49,
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/node.h:195:50: note: declared here
      195 |                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/node.h:112:42: note: in definition of macro ‘NODE_DEPRECATED’
      112 |     __attribute__((deprecated(message))) declarator
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:850:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
      850 |         v8::Isolate::GetCurrent(), target, symbol, argc, argv);
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/node.h:188:50: note: declared here
      188 |                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:865:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
      865 |         v8::Isolate::GetCurrent(), target, method, argc, argv);
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/node.h:181:50: note: declared here
      181 |                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:911:53: error: no matching function for call to ‘v8::Value::ToString()’
      911 |       v8::Local<v8::String> string = from->ToString();
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-value.h:360:44: note: candidate: ‘v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const’
      360 |   V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-value.h:360:44: note:   candidate expects 1 argument, 0 provided
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:921:37: error: cannot convert ‘char*’ to ‘v8::Isolate*’
      921 |         length_ = string->WriteUtf8(str_, static_cast<int>(len), 0, flags);
          |                                     char*
    In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:11,
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-primitive.h:202:26: note:   initializing argument 1 of ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’
      202 |   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1479:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
     1479 |     ));
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1533:64: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, const v8::Local<v8::Value>&)’
     1533 |     New(persistentHandle)->Set(New(key).ToLocalChecked(), value);
    In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-array-buffer.h:13,
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:244:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’
      244 |   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:244:37: note:   candidate expects 3 arguments, 2 provided
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:247:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’
      247 |   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:247:37: note:   candidate expects 3 arguments, 2 provided
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1539:42: error: no matching function for call to ‘v8::Object::Set(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’
     1539 |     New(persistentHandle)->Set(key, value);
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local<v8::Value>&)’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1545:44: error: no matching function for call to ‘v8::Object::Set(uint32_t&, const v8::Local<v8::Value>&)’
     1545 |     New(persistentHandle)->Set(index, value);
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const char*) const’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1551:61: error: no matching function for call to ‘v8::Object::Get(v8::Local<v8::String>)’
     1551 |         New(persistentHandle)->Get(New(key).ToLocalChecked()));
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:290:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’
      290 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:290:43: note:   candidate expects 2 arguments, 1 provided
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:293:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’
      293 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:293:43: note:   candidate expects 2 arguments, 1 provided
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const v8::Local<v8::String>&) const’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1557:55: error: no matching function for call to ‘v8::Object::Get(const v8::Local<v8::String>&)’
     1557 |     return scope.Escape(New(persistentHandle)->Get(key));
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1562:57: error: no matching function for call to ‘v8::Object::Get(uint32_t&)’
     1562 |     return scope.Escape(New(persistentHandle)->Get(index));
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1732:7: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
     1732 |     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, Nan::GetterCallback, Nan::SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, Nan::imp::Sig)’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1977:16: warning: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>, v8::AccessorNameGetterCallback, v8::AccessorNameSetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, v8::Local<v8::AccessorSignature>, v8::SideEffectType, v8::SideEffectType)’ is deprecated: Do signature check in accessor [-Wdeprecated-declarations]
     1977 |     , signature);
    In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-function.h:15,
    /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-template.h:838:8: note: declared here
      838 |   void SetAccessor(
    In file included from /usr/include/c++/10/cassert:44,
                     from /home/iobroker/.cache/node-gyp/18.16.0/include/node/node_object_wrap.h:26,
                     from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:51,
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
       24 |     assert(persistent().IsNearDeath());
    In file included from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:2222,
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_object_wrap.h:67:18: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘MarkIndependent’
       67 |     persistent().MarkIndependent();
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
      124 |     assert(wrap->handle_.IsNearDeath());
    In file included from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:2313,
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_typedarray_contents.h: In constructor ‘Nan::TypedArrayContents<T>::TypedArrayContents(v8::Local<v8::Value>)’:
    /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_typedarray_contents.h:34:43: error: ‘class v8::ArrayBuffer’ has no member named ‘GetContents’
       34 |       data   = static_cast<char*>(buffer->GetContents().Data()) + byte_offset;
    ../src/callbacks.cc: In function ‘void OZW::ozw_watcher_callback(const OpenZWave::Notification*, void*)’:
    ../src/callbacks.cc:80:37: warning: ‘uint8 OpenZWave::Notification::GetSceneId() const’ is deprecated [-Wdeprecated-declarations]
       80 |     notif->sceneid = cb->GetSceneId();
    In file included from ../src/openzwave.hpp:32,
    /usr/local/include/openzwave/Notification.h:232:21: note: declared here
      232 |    DEPRECATED uint8 GetSceneId() const
    make: *** [openzwave_shared.target.mk:136: Release/obj.target/openzwave_shared/src/callbacks.o] Fehler 1
    make: Verzeichnis „/opt/iobroker/node_modules/openzwave-shared/build“ wird verlassen
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
    gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)
    gyp ERR! System Linux 5.10.0-25-amd64
    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/openzwave-shared
    gyp ERR! node -v v18.16.0
    gyp ERR! node-gyp -v v7.1.2
    gyp ERR! not ok
    npm notice
    npm notice New major version of npm available! 9.5.1 -> 10.0.0
    npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.0.0
    npm notice Run npm install -g npm@10.0.0 to update!
    npm notice
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/openzwave-shared
    npm ERR! command failed
    npm ERR! command sh -c node-gyp rebuild
    npm ERR!     /home/iobroker/.npm/_logs/2023-09-03T15_16_59_988Z-debug-0.log
    GlasfaserG Offline
    GlasfaserG Offline
    @manmac1
    so , jetzt nochmal zeigen
    iobroker upgrade web@6.1.0 --debug
    • GlasfaserG Glasfaser
      @manmac1
      manmac1
      iobroker@iobroker:/opt/iobroker/node_modules/openzwave-shared$ iobroker upgrade web@6.1.0 --debug
      This upgrade of "web" will at least introduce the following changes:
      -> 6.1.0:
      Added the subscribing on the specific instance messages
      -> 6.0.3:
      Updated packages
      Implemented the possibility to view folder content
      -> 6.0.1:
      Removed letsencrypt handling from web adapter
      -> 5.5.3:
      Increased max size of the uploaded file via socket.io to 200MB (from 10MB)
      -> 5.5.2:
      Allowed deletion of fullcalendar objects
      -> 5.5.1:
      Allowed to read projects of vis-2-beta
      -> 5.5.0:
      Added special end-points for app authentication
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade web from @4.3.0 to @6.1.0 now? [(y)es, (n)o]: y
      Update web from @4.3.0 to @6.1.0
      host.iobroker.esxi Adapter "system.adapter.web.0" is stopped.
      NPM version: 9.5.1
      Installing iobroker.web@6.1.0... (System call)
      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
      npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
      npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
      npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
      npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
      npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
      npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
      npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
      npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
      npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
      npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
      npm WARN deprecated phantomjs-prebuilt@2.1.16: this package is now deprecated
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
      npm ERR! code 1
      npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/openzwave-shared/build“ wird betreten
      npm ERR!   CXX(target) Release/obj.target/openzwave_shared/src/callbacks.o
      npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/openzwave-shared/build“ wird verlassen
      npm ERR! gyp info it worked if it ends with ok
      npm ERR! gyp info using node-gyp@7.1.2
      npm ERR! gyp info using node@18.16.0 | linux | x64
      npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
      npm ERR! (node:25266) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
      npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
      npm ERR! gyp info spawn /usr/bin/python3
      npm ERR! gyp info spawn args [
      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
      npm ERR! gyp info spawn args   'binding.gyp',
      npm ERR! gyp info spawn args   '-f',
      npm ERR! gyp info spawn args   'make',
      npm ERR! gyp info spawn args   '-I',
      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/openzwave-shared/build/config.gypi',
      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
      npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.16.0/include/node/common.gypi',
      npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
      npm ERR! gyp info spawn args   '-Dvisibility=default',
      npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.16.0',
      npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
      npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.16.0/<(target_arch)/node.lib',
      npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/openzwave-shared',
      npm ERR! gyp info spawn args   '-Dnode_engine=v8',
      npm ERR! gyp info spawn args   '--depth=.',
      npm ERR! gyp info spawn args   '--no-parallel',
      npm ERR! gyp info spawn args   '--generator-output',
      npm ERR! gyp info spawn args   'build',
      npm ERR! gyp info spawn args   '-Goutput_dir=.'
      npm ERR! gyp info spawn args ]
      npm ERR! gyp info spawn make
      npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
      npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-local-handle.h:12,
      npm ERR!                  from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-array-buffer.h:12,
      npm ERR!                  from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8.h:24,
      npm ERR!                  from ../src/openzwave.hpp:27,
      npm ERR!                  from ../src/callbacks.cc:18:
      npm ERR! /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-internal.h: In function ‘void v8::internal::PerformCastCheck(T*)’:
      npm ERR! /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-internal.h:646:38: error: ‘remove_cv_t’ is not a member of ‘std’; did you mean ‘remove_cv’?
      npm ERR!   646 |             !std::is_same<Data, std::remove_cv_t<T>>::value>::Perform(data);
      npm ERR!       |                                      ^~~~~~~~~~~
      npm ERR!       |                                      remove_cv
      npm ERR! /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-internal.h:646:50: error: template argument 2 is invalid
      npm ERR!       |                                                  ^
      npm ERR! /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-internal.h:646:63: error: ‘::Perform’ has not been declared
      npm ERR!       |                                                               ^~~~~~~
      npm ERR! make: *** [openzwave_shared.target.mk:150: Release/obj.target/openzwave_shared/src/callbacks.o] Fehler 1
      npm ERR! gyp ERR! build error
      npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
      npm ERR! gyp ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/node-gyp/lib/build.js:194:23)
      npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
      npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)
      npm ERR! gyp ERR! System Linux 5.10.0-25-amd64
      npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
      npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/openzwave-shared
      npm ERR! gyp ERR! node -v v18.16.0
      npm ERR! gyp ERR! node-gyp -v v7.1.2
      npm ERR! gyp ERR! not ok
      npm ERR!     /home/iobroker/.npm/_logs/2023-09-03T15_19_10_771Z-debug-0.log
      upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
      upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
      upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
      upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
      upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
      upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
      upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
      upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
      upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
      upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
      upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
      upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
      upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
      upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
      upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
      upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
      upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
      upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
      upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
      upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
      upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
      upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
      upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
      upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
      upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
      upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
      upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
      upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
      upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
      upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
      upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
      upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
      upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
      upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
      upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
      upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
      upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
      upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
      upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
      upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
      upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
      upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
      upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js static/js/2.b1d56998.chunk.js application/javascript
      upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.LICENSE.txt static/js/2.b1d56998.chunk.js.LICENSE.txt text/plain
      upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.map static/js/2.b1d56998.chunk.js.map application/json
      upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js static/js/main.034751df.chunk.js application/javascript
      upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js.map static/js/main.034751df.chunk.js.map application/json
      upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js static/js/runtime-main.7278cf1c.js application/javascript
      upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js.map static/js/runtime-main.7278cf1c.js.map application/json
      upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
      upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
      host.iobroker.esxi Adapter "system.adapter.web.0" is started
      • M manmac1
        habs nochmal rauskopiert:
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Architecture    : x86_64
        Docker          : false
        Virtualization  : vmware
        Distributor ID: Debian
        Description:    Debian GNU/Linux 11 (bullseye)
        Release:        11
        Codename:       bullseye
        PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
        NAME="Debian GNU/Linux"
        VERSION_ID="11"
        VERSION="11 (bullseye)"
        VERSION_CODENAME=bullseye
        ID=debian
        HOME_URL="https://www.debian.org/"
        SUPPORT_URL="https://www.debian.org/support"
        BUG_REPORT_URL="https://bugs.debian.org/"
        Systemuptime and Load:
         16:56:43 up 15:03,  3 users,  load average: 0.29, 0.52, 0.52
        CPU threads: 2
        *** Time and Time Zones ***
                       Local time: Sun 2023-09-03 16:56:43 CEST
                   Universal time: Sun 2023-09-03 14:56:43 UTC
                         RTC time: Sun 2023-09-03 14:56:43
                        Time zone: Europe/Vienna (CEST, +0200)
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        iobroker
        /home/iobroker
        iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev bluetooth
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.9G        2.5G        2.8G        0.0K        2.7G        5.5G
        Swap:           2.0G          0B        2.0G
        Total:            9G        2.5G        4.8G
                 7945 M total memory
                 2456 M used memory
                 1277 M active memory
                 3294 M inactive memory
                 2783 M free memory
                  409 M buffer memory
                 2295 M swap cache
                 2044 M total swap
                    0 M used swap
                 2044 M free swap
        *** FILESYSTEM ***
        udev           devtmpfs  3.9G     0  3.9G   0% /dev
        tmpfs          tmpfs     795M  736K  794M   1% /run
        /dev/sda1      ext4       30G   16G   13G  55% /
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     795M  4.0K  795M   1% /run/user/1000
        [Sun Sep  3 01:53:08 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
        [Sun Sep  3 01:53:09 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
        TARGET SOURCE    FSTYPE OPTIONS
        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
        /var:
        2.8G    /var/
        1.5G    /var/cache/apt
        1.5G    /var/cache
        1.4G    /var/cache/apt/archives
        823M    /var/lib
        Archived and active journals take up 32.0M in the file system.
        /opt/iobroker/backups:
        360M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        2.4G    /opt/iobroker/iobroker-data/
        1.9G    /opt/iobroker/iobroker-data/sonosCache
        332M    /opt/iobroker/iobroker-data/files
        152M    /opt/iobroker/iobroker-data/backup-objects
        53M     /opt/iobroker/iobroker-data/files/javascript.admin
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
        15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
        13M     /opt/iobroker/iobroker-data/objects.jsonl
        11M     /opt/iobroker/iobroker-data/objects.json.migrated
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.16.0
        /usr/bin/node           v18.16.0
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
        nodejs:
          Installed: 18.16.0-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
             18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         *** 18.16.0-deb-1nodesource1 100
             12.22.12~dfsg-1~deb11u4 500
                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
             12.22.12~dfsg-1~deb11u3 500
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.3.5
        javascript:     7.0.3
        npm ERR! code ELSPROBLEMS
        npm ERR! extraneous: @harmonyhub/discover@1.0.5 /opt/iobroker/node_modules/@harmonyhub/discover
        npm ERR! extraneous: @iobroker/adapter-core@1.0.1 /opt/iobroker/node_modules/@iobroker/adapter-core
        npm ERR! extraneous: @node-red/editor-api@0.20.7 /opt/iobroker/node_modules/@node-red/editor-api
        npm ERR! extraneous: @node-red/editor-client@0.20.7 /opt/iobroker/node_modules/@node-red/editor-client
        npm ERR! extraneous: @node-red/nodes@0.20.7 /opt/iobroker/node_modules/@node-red/nodes
        npm ERR! extraneous: @node-red/registry@0.20.7 /opt/iobroker/node_modules/@node-red/registry
        npm ERR! extraneous: @node-red/runtime@0.20.7 /opt/iobroker/node_modules/@node-red/runtime
        npm ERR! extraneous: @node-red/util@0.20.7 /opt/iobroker/node_modules/@node-red/util
        npm ERR! extraneous: @types/form-data@2.2.1 /opt/iobroker/node_modules/@types/form-data
        npm ERR! extraneous: @types/iobroker@1.4.0 /opt/iobroker/node_modules/@types/iobroker
        npm ERR! extraneous: @types/request@2.48.1 /opt/iobroker/node_modules/@types/request
        npm ERR! extraneous: agent-base@4.3.0 /opt/iobroker/node_modules/agent-base
        npm ERR! extraneous: alcalzone-shared@1.4.0 /opt/iobroker/node_modules/alcalzone-shared
        npm ERR! extraneous: alexa-cookie2@2.1.0 /opt/iobroker/node_modules/alexa-cookie2
        npm ERR! extraneous: alexa-remote2@2.5.5 /opt/iobroker/node_modules/alexa-remote2
        npm ERR! extraneous: asap@2.0.6 /opt/iobroker/node_modules/asap
        npm ERR! extraneous: async@2.5.0 /opt/iobroker/node_modules/async
        npm ERR! extraneous: autobind-decorator@2.4.0 /opt/iobroker/node_modules/autobind-decorator
        npm ERR! extraneous: aws-iot-device-sdk@2.2.1 /opt/iobroker/node_modules/aws-iot-device-sdk
        npm ERR! extraneous: axios@0.15.3 /opt/iobroker/node_modules/axios
        npm ERR! extraneous: base64url@2.0.0 /opt/iobroker/node_modules/base64url
        npm ERR! extraneous: binrpc@1.0.0 /opt/iobroker/node_modules/binrpc
        npm ERR! extraneous: bson@1.1.1 /opt/iobroker/node_modules/bson
        npm ERR! extraneous: buffer-crc32@0.2.13 /opt/iobroker/node_modules/buffer-crc32
        npm ERR! extraneous: callback-stream@1.1.0 /opt/iobroker/node_modules/callback-stream
        npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/chalk
        npm ERR! extraneous: cheerio@1.0.0-rc.3 /opt/iobroker/node_modules/cheerio
        npm ERR! extraneous: cls-bluebird@1.1.3 /opt/iobroker/node_modules/cls-bluebird
        npm ERR! extraneous: commander@2.11.0 /opt/iobroker/node_modules/commander
        npm ERR! extraneous: cron@1.7.1 /opt/iobroker/node_modules/cron
        npm ERR! extraneous: crypto-js@3.1.6 /opt/iobroker/node_modules/crypto-js
        npm ERR! extraneous: deep-extend@0.4.2 /opt/iobroker/node_modules/deep-extend
        npm ERR! extraneous: dicer@0.2.5 /opt/iobroker/node_modules/dicer
        npm ERR! extraneous: dotenv@4.0.0 /opt/iobroker/node_modules/dotenv
        npm ERR! extraneous: epoll@0.1.22 /opt/iobroker/node_modules/epoll
        npm ERR! extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
        npm ERR! extraneous: es6-set@0.1.5 /opt/iobroker/node_modules/es6-set
        npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/escape-string-regexp
        npm ERR! extraneous: event-emitter@0.3.5 /opt/iobroker/node_modules/event-emitter
        npm ERR! extraneous: eventemitter3@2.0.3 /opt/iobroker/node_modules/eventemitter3
        npm ERR! extraneous: express-fileupload@0.1.4 /opt/iobroker/node_modules/express-fileupload
        npm ERR! extraneous: express-session@1.16.2 /opt/iobroker/node_modules/express-session
        npm ERR! extraneous: express@4.16.2 /opt/iobroker/node_modules/express
        npm ERR! extraneous: extract-zip@1.7.0 /opt/iobroker/node_modules/extract-zip
        npm ERR! extraneous: fd-slicer@1.1.0 /opt/iobroker/node_modules/fd-slicer
        npm ERR! extraneous: finalhandler@1.1.0 /opt/iobroker/node_modules/finalhandler
        npm ERR! extraneous: fs-extra@0.22.1 /opt/iobroker/node_modules/fs-extra
        npm ERR! extraneous: fs-minipass@1.2.3 /opt/iobroker/node_modules/fs-minipass
        npm ERR! extraneous: generate-function@2.0.0 /opt/iobroker/node_modules/generate-function
        npm ERR! extraneous: generate-object-property@1.2.0 /opt/iobroker/node_modules/generate-object-property
        npm ERR! extraneous: glob-parent@3.1.0 /opt/iobroker/node_modules/glob-parent
        npm ERR! extraneous: glob-stream@6.1.0 /opt/iobroker/node_modules/glob-stream
        npm ERR! extraneous: harmonyhubws@1.0.4 /opt/iobroker/node_modules/harmonyhubws
        npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/has-flag
        npm ERR! extraneous: hasha@2.2.0 /opt/iobroker/node_modules/hasha
        npm ERR! extraneous: homematic-manager@1.0.14 /opt/iobroker/node_modules/homematic-manager
        npm ERR! extraneous: http-proxy-middleware@0.19.1 /opt/iobroker/node_modules/http-proxy-middleware
        npm ERR! extraneous: https-proxy-agent@2.2.1 /opt/iobroker/node_modules/https-proxy-agent
        npm ERR! extraneous: i18next@15.1.0 /opt/iobroker/node_modules/i18next
        npm ERR! extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/ignore-walk
        npm ERR! extraneous: imap@0.8.19 /opt/iobroker/node_modules/imap
        npm ERR! extraneous: io-packages.json@ /opt/iobroker/node_modules/io-packages.json
        npm ERR! missing: iobroker.geofency@^1.0.3, required by iobroker@1.0.0
        npm ERR! extraneous: iobroker.hmm@1.0.1 /opt/iobroker/node_modules/iobroker.hmm
        npm ERR! extraneous: iobroker.icons-icons8@0.0.1 /opt/iobroker/node_modules/iobroker.icons-icons8
        npm ERR! extraneous: iobroker.rp2@ /opt/iobroker/node_modules/iobroker.rp2
        npm ERR! extraneous: iobroker.type-detector@0.1.1 /opt/iobroker/node_modules/iobroker.type-detector
        npm ERR! extraneous: iobroker.vis-bars@0.1.4 /opt/iobroker/node_modules/iobroker.vis-bars
        npm ERR! extraneous: iobroker.vis-fancyswitch@1.1.0 /opt/iobroker/node_modules/iobroker.vis-fancyswitch
        npm ERR! extraneous: iobroker@1.0.2 /opt/iobroker/node_modules/iobroker
        npm ERR! extraneous: ipaddr.js@1.5.2 /opt/iobroker/node_modules/ipaddr.js
        npm ERR! extraneous: is-bluebird@1.0.2 /opt/iobroker/node_modules/is-bluebird
        npm ERR! extraneous: is-buffer@2.0.4 /opt/iobroker/node_modules/is-buffer
        npm ERR! extraneous: is-my-json-valid@2.16.1 /opt/iobroker/node_modules/is-my-json-valid
        npm ERR! extraneous: is-negated-glob@1.0.0 /opt/iobroker/node_modules/is-negated-glob
        npm ERR! extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
        npm ERR! extraneous: is-stream@1.1.0 /opt/iobroker/node_modules/is-stream
        npm ERR! extraneous: isemail@1.2.0 /opt/iobroker/node_modules/isemail
        npm ERR! extraneous: joi@6.10.1 /opt/iobroker/node_modules/joi
        npm ERR! extraneous: js-yaml@3.13.1 /opt/iobroker/node_modules/js-yaml
        npm ERR! extraneous: js2xmlparser@3.0.0 /opt/iobroker/node_modules/js2xmlparser
        npm ERR! extraneous: json-stable-stringify-without-jsonify@1.0.1 /opt/iobroker/node_modules/json-stable-stringify-without-jsonify
        npm ERR! extraneous: jsonata@1.6.5 /opt/iobroker/node_modules/jsonata
        npm ERR! extraneous: jsonfile@2.4.0 /opt/iobroker/node_modules/jsonfile
        npm ERR! extraneous: jsonpointer@4.0.1 /opt/iobroker/node_modules/jsonpointer
        npm ERR! extraneous: jsonwebtoken@8.1.1 /opt/iobroker/node_modules/jsonwebtoken
        npm ERR! extraneous: jws@3.1.4 /opt/iobroker/node_modules/jws
        npm ERR! extraneous: kew@0.7.0 /opt/iobroker/node_modules/kew
        npm ERR! extraneous: klaw@1.3.1 /opt/iobroker/node_modules/klaw
        npm ERR! extraneous: libbase64@1.0.3 /opt/iobroker/node_modules/libbase64
        npm ERR! extraneous: libmime@4.1.1 /opt/iobroker/node_modules/libmime
        npm ERR! extraneous: libqp@1.1.0 /opt/iobroker/node_modules/libqp
        npm ERR! extraneous: linkify-it@2.1.0 /opt/iobroker/node_modules/linkify-it
        npm ERR! extraneous: mailparser@2.7.1 /opt/iobroker/node_modules/mailparser
        npm ERR! extraneous: mailsplit@4.4.1 /opt/iobroker/node_modules/mailsplit
        npm ERR! extraneous: memorystore@1.6.1 /opt/iobroker/node_modules/memorystore
        npm ERR! extraneous: minipass@2.2.1 /opt/iobroker/node_modules/minipass
        npm ERR! extraneous: minizlib@1.0.4 /opt/iobroker/node_modules/minizlib
        npm ERR! extraneous: mongodb@3.3.0 /opt/iobroker/node_modules/mongodb
        npm ERR! extraneous: multer@1.4.1 /opt/iobroker/node_modules/multer
        npm ERR! extraneous: mustache@3.0.1 /opt/iobroker/node_modules/mustache
        npm ERR! extraneous: needle@2.9.1 /opt/iobroker/node_modules/needle
        npm ERR! extraneous: net-snmp@1.2.4 /opt/iobroker/node_modules/net-snmp
        npm ERR! extraneous: node-abi@2.15.0 /opt/iobroker/node_modules/node-abi
        npm ERR! extraneous: node-disk-info@ /opt/iobroker/node_modules/node-disk-info
        npm ERR! extraneous: node-hue-api@2.4.2 /opt/iobroker/node_modules/node-hue-api
        npm ERR! extraneous: node-ical@0.5.4 /opt/iobroker/node_modules/node-ical
        npm ERR! extraneous: node-red-contrib-polymer@0.0.21 /opt/iobroker/node_modules/node-red-contrib-polymer
        npm ERR! extraneous: node-red-dashboard@2.16.1 /opt/iobroker/node_modules/node-red-dashboard
        npm ERR! extraneous: node-red-node-email@1.6.2 /opt/iobroker/node_modules/node-red-node-email
        npm ERR! extraneous: node-red-node-feedparser@0.1.14 /opt/iobroker/node_modules/node-red-node-feedparser
        npm ERR! extraneous: node-red-node-rbe@0.2.5 /opt/iobroker/node_modules/node-red-node-rbe
        npm ERR! extraneous: node-red-node-sentiment@0.1.4 /opt/iobroker/node_modules/node-red-node-sentiment
        npm ERR! extraneous: node-red-node-tail@0.0.2 /opt/iobroker/node_modules/node-red-node-tail
        npm ERR! extraneous: node-red-node-twitter@1.1.5 /opt/iobroker/node_modules/node-red-node-twitter
        npm ERR! extraneous: node-red@0.20.7 /opt/iobroker/node_modules/node-red
        npm ERR! extraneous: node-ssdp@3.2.5 /opt/iobroker/node_modules/node-ssdp
        npm ERR! extraneous: node-static@0.7.11 /opt/iobroker/node_modules/node-static
        npm ERR! extraneous: node-telegram-bot-api@0.28.0 /opt/iobroker/node_modules/node-telegram-bot-api
        npm ERR! extraneous: nodemailer@6.3.0 /opt/iobroker/node_modules/nodemailer
        npm ERR! extraneous: noop-logger@0.1.1 /opt/iobroker/node_modules/noop-logger
        npm ERR! extraneous: npm-bundled@1.1.2 /opt/iobroker/node_modules/npm-bundled
        npm ERR! extraneous: npm-normalize-package-bin@1.0.1 /opt/iobroker/node_modules/npm-normalize-package-bin
        npm ERR! extraneous: npm-packlist@1.4.8 /opt/iobroker/node_modules/npm-packlist
        npm ERR! extraneous: object.assign@4.0.4 /opt/iobroker/node_modules/object.assign
        npm ERR! extraneous: openzwave-shared@1.4.1 /opt/iobroker/node_modules/openzwave-shared
        npm ERR! extraneous: optimist@0.6.1 /opt/iobroker/node_modules/optimist
        npm ERR! extraneous: ordered-read-streams@1.0.1 /opt/iobroker/node_modules/ordered-read-streams
        npm ERR! extraneous: parse5@3.0.3 /opt/iobroker/node_modules/parse5
        npm ERR! extraneous: passport@0.3.2 /opt/iobroker/node_modules/passport
        npm ERR! extraneous: path-dirname@1.0.2 /opt/iobroker/node_modules/path-dirname
        npm ERR! extraneous: pend@1.2.0 /opt/iobroker/node_modules/pend
        npm ERR! extraneous: poplib@0.1.7 /opt/iobroker/node_modules/poplib
        npm ERR! extraneous: prebuild-install@5.3.3 /opt/iobroker/node_modules/prebuild-install
        npm ERR! extraneous: progress@1.1.8 /opt/iobroker/node_modules/progress
        npm ERR! extraneous: promise@7.1.1 /opt/iobroker/node_modules/promise
        npm ERR! extraneous: proxy-addr@2.0.2 /opt/iobroker/node_modules/proxy-addr
        npm ERR! extraneous: pump@1.0.2 /opt/iobroker/node_modules/pump
        npm ERR! extraneous: pumpify@1.5.1 /opt/iobroker/node_modules/pumpify
        npm ERR! extraneous: request-progress@2.0.1 /opt/iobroker/node_modules/request-progress
        npm ERR! extraneous: request-promise-core@1.1.1 /opt/iobroker/node_modules/request-promise-core
        npm ERR! extraneous: request-promise-native@1.0.5 /opt/iobroker/node_modules/request-promise-native
        npm ERR! extraneous: request-promise@1.0.2 /opt/iobroker/node_modules/request-promise
        npm ERR! extraneous: require_optional@1.0.1 /opt/iobroker/node_modules/require_optional
        npm ERR! extraneous: resolve-from@2.0.0 /opt/iobroker/node_modules/resolve-from
        npm ERR! extraneous: rpi-gpio@0.7.0 /opt/iobroker/node_modules/rpi-gpio
        npm ERR! extraneous: rrule@2.2.0 /opt/iobroker/node_modules/rrule
        npm ERR! extraneous: semaphore@1.0.5 /opt/iobroker/node_modules/semaphore
        npm ERR! extraneous: serialport@4.0.7 /opt/iobroker/node_modules/serialport
        npm ERR! extraneous: shimmer@1.2.0 /opt/iobroker/node_modules/shimmer
        npm ERR! extraneous: sonos-discovery@1.1.3 /opt/iobroker/node_modules/sonos-discovery
        npm ERR! extraneous: sonos-web-controller@0.14.0 /opt/iobroker/node_modules/sonos-web-controller
        npm ERR! extraneous: sprintf-js@1.0.3 /opt/iobroker/node_modules/sprintf-js
        npm ERR! extraneous: streamifier@0.1.1 /opt/iobroker/node_modules/streamifier
        npm ERR! extraneous: suncalc@1.8.0 /opt/iobroker/node_modules/suncalc
        npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/supports-color
        npm ERR! extraneous: systeminformation@3.54.0 /opt/iobroker/node_modules/systeminformation
        npm ERR! extraneous: tail@2.2.4 /opt/iobroker/node_modules/tail
        npm ERR! extraneous: throttleit@1.0.0 /opt/iobroker/node_modules/throttleit
        npm ERR! extraneous: through2-filter@3.0.0 /opt/iobroker/node_modules/through2-filter
        npm ERR! extraneous: tlds@1.203.1 /opt/iobroker/node_modules/tlds
        npm ERR! extraneous: to-absolute-glob@2.0.2 /opt/iobroker/node_modules/to-absolute-glob
        npm ERR! extraneous: topo@1.1.0 /opt/iobroker/node_modules/topo
        npm ERR! extraneous: traits@0.4.0 /opt/iobroker/node_modules/traits
        npm ERR! extraneous: typescript@2.7.1 /opt/iobroker/node_modules/typescript
        npm ERR! extraneous: uc.micro@1.0.6 /opt/iobroker/node_modules/uc.micro
        npm ERR! extraneous: uglify-js@3.6.0 /opt/iobroker/node_modules/uglify-js
        npm ERR! extraneous: unique-stream@2.3.1 /opt/iobroker/node_modules/unique-stream
        npm ERR! extraneous: ursa-optional@0.9.8 /opt/iobroker/node_modules/ursa-optional
        npm ERR! extraneous: utf7@1.0.2 /opt/iobroker/node_modules/utf7
        npm ERR! extraneous: virtual-device-sdk@1.5.19 /opt/iobroker/node_modules/virtual-device-sdk
        npm ERR! extraneous: virtual-tsc@0.3.4 /opt/iobroker/node_modules/virtual-tsc
        npm ERR! extraneous: vm2@3.6.10 /opt/iobroker/node_modules/vm2
        npm ERR! extraneous: wake_on_lan@0.0.4 /opt/iobroker/node_modules/wake_on_lan
        npm ERR! extraneous: when@3.7.8 /opt/iobroker/node_modules/when
        npm ERR! extraneous: which-pm-runs@1.0.0 /opt/iobroker/node_modules/which-pm-runs
        npm ERR! extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
        npm ERR! extraneous: wordwrap@0.0.3 /opt/iobroker/node_modules/wordwrap
        npm ERR! extraneous: xmlbuilder@9.0.4 /opt/iobroker/node_modules/xmlbuilder
        npm ERR! extraneous: xmlcreate@1.0.2 /opt/iobroker/node_modules/xmlcreate
        npm ERR! extraneous: yauzl@2.10.0 /opt/iobroker/node_modules/yauzl
        npm ERR!     /home/iobroker/.npm/_logs/2023-09-03T14_56_53_179Z-debug-0.log
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker.esxi                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.alexa2.0                 : alexa2                : iobroker.esxi                            -  enabled
          system.adapter.backitup.0               : backitup              : iobroker.esxi                            - disabled
          system.adapter.cloud.0                  : cloud                 : iobroker.esxi                            - disabled
          system.adapter.devices.0                : devices               : iobroker.esxi                            -  enabled
          system.adapter.discovery.0              : discovery             : iobroker.esxi                            - disabled
          system.adapter.flot.0                   : flot                  : iobroker.esxi                            -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker.esxi                            -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker.esxi                            -  enabled, port: 0
        + system.adapter.hue.0                    : hue                   : iobroker.esxi                            -  enabled, port: 443
        + system.adapter.influxdb.0               : influxdb              : iobroker.esxi                            -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker.esxi                            -  enabled
          system.adapter.iot.0                    : iot                   : iobroker.esxi                            - disabled
        + system.adapter.javascript.0             : javascript            : iobroker.esxi                            -  enabled
        + system.adapter.lametric.0               : lametric              : iobroker.esxi                            -  enabled
        + system.adapter.netatmo.0                : netatmo               : iobroker.esxi                            -  enabled
        + system.adapter.node-red.0               : node-red              : iobroker.esxi                            -  enabled, port: 1880, bind: 0.0.0.0 (SSL)
        + system.adapter.parser.0                 : parser                : iobroker.esxi                            -  enabled
        + system.adapter.sonos.0                  : sonos                 : iobroker.esxi                            -  enabled
        + system.adapter.systeminfo.0             : systeminfo            : iobroker.esxi                            -  enabled
        + system.adapter.telegram.0               : telegram              : iobroker.esxi                            -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.1               : telegram              : iobroker.esxi                            -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker.esxi                            -  enabled
          system.adapter.vis.0                    : vis                   : iobroker.esxi                            -  enabled
        + system.adapter.web.0                    : web                   : iobroker.esxi                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.yahka.0                  : yahka                 : iobroker.esxi                            -  enabled
        + system.adapter.zwave2.0                 : zwave2                : iobroker.esxi                            -  enabled
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        sources       : conf/sources-dist.json
        online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
        Installed ioBroker-Instances
        Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
        Adapter    "alexa2"       : 3.24.1   , installed 3.23.2 [Updatable]
        Adapter    "backitup"     : 2.6.23   , installed 2.4.9  [Updatable]
        Adapter    "ble"          : 0.13.4   , installed 0.13.0 [Updatable]
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "cloud"        : 4.4.1    , installed 4.3.0  [Updatable]
        Adapter    "devices"      : 1.1.5    , installed 1.1.5
        Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
        Adapter    "frontier_silicon": 0.0.11, installed 0.0.10 [Updatable]
        Adapter    "harmony"      : 1.2.2    , installed 1.2.2
        Adapter    "history"      : 2.2.6    , installed 1.11.1 [Updatable]
        Adapter    "hm-rega"      : 3.0.47   , installed 3.0.46 [Updatable]
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.16 [Updatable]
        Adapter    "hue"          : 3.9.5    , installed 3.7.1  [Updatable]
        Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
        Adapter    "info"         : 1.9.26   , installed 1.9.19 [Updatable]
        Adapter    "iot"          : 1.14.5   , installed 1.14.2 [Updatable]
        Adapter    "javascript"   : 7.0.3    , installed 7.0.3
        Adapter    "lametric"     : 2.4.1    , installed 2.4.1
        Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "node-red"     : 4.0.3    , installed 4.0.0  [Updatable]
        Adapter    "owfs"         : 0.7.0    , installed 0.7.0
        Adapter    "parser"       : 1.3.2    , installed 1.1.8  [Updatable]
        Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
        Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
        Adapter    "radar2"       : 2.0.7    , installed 2.0.3  [Updatable]
        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
        Adapter    "snmp"         : 2.4.11   , installed 1.0.0  [Updatable]
        Adapter    "socketio"     : 6.5.2    , installed 4.2.0  [Updatable]
        Adapter    "sonos"        : 2.3.1    , installed 2.3.1
        Adapter    "systeminfo"   : 1.0.0    , installed 0.3.1  [Updatable]
        Adapter    "telegram"     : 1.16.0   , installed 1.15.6 [Updatable]
        Adapter    "vis-hqwidgets": 1.4.0    , installed 1.3.0  [Updatable]
        Adapter    "web"          : 6.1.0    , installed 4.3.0  [Updatable]
        Adapter    "ws"           : 2.5.3    , installed 1.3.0  [Updatable]
        Adapter    "yahka"        : 1.0.3    , installed 0.17.0 [Updatable]
        Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
        Objects and States
        Objects:        7546
        States:         7329
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://security.debian.org/debian-security bullseye-security/updates InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:5 https://apt.grafana.com stable InRelease
        Hit:6 https://repos.influxdata.com/debian stable InRelease
        Hit:7 https://repos.influxdata.com/debian stretch InRelease
        Get:8 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
        Fetched 4586 B in 1s (7111 B/s)
        Reading package lists...
        Pending Updates: 10
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1711988    1801452/iobroker.js
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1711981    1801452/iobroker.js
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          9392       1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12738      587/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       1714317    1801565/node-red
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        13256      900/influxd
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          14710      1245/exim4
        tcp        0      0 127.0.0.1:2010          0.0.0.0:*               LISTEN      1000       1715056    1801591/io.hm-rpc.0
        tcp        0      0 127.0.0.1:35931         0.0.0.0:*               LISTEN      1000       1718958    1802489/io.yahka.0
        tcp        0      0 127.0.0.1:39589         0.0.0.0:*               LISTEN      1000       1721109    1802489/io.yahka.0
        tcp6       0      0 :::111                  :::*                    LISTEN      0          9396       1/init
        tcp6       0      0 :::80                   :::*                    LISTEN      1000       1714319    1801565/node-red
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1714058    1801470/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1729486    1811299/io.web.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        15440      900/influxd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          12749      587/sshd: /usr/sbin
        tcp6       0      0 :::45079                :::*                    LISTEN      1000       1718644    1802489/io.yahka.0
        tcp6       0      0 :::3000                 :::*                    LISTEN      107        14792      1253/grafana
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          14711      1245/exim4
        tcp6       0      0 :::38237                :::*                    LISTEN      1000       1718648    1802489/io.yahka.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1718649    1802489/io.yahka.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1718645    1802489/io.yahka.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1714320    1801565/node-red
        udp        0      0 198.18.10.12:1905       0.0.0.0:*                           1000       1758117    1801661/io.sonos.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12534      538/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9393       1/init
        udp6       0      0 :::111                  :::*                                0          9399       1/init
        2023-09-03 16:45:18.264  - info: host.iobroker.esxi iobroker upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
        2023-09-03 16:45:18.266  - info: host.iobroker.esxi iobroker upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
        2023-09-03 16:45:18.268  - info: host.iobroker.esxi iobroker upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
        2023-09-03 16:45:18.270  - info: host.iobroker.esxi iobroker upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
        2023-09-03 16:45:18.272  - info: host.iobroker.esxi iobroker upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
        2023-09-03 16:45:18.274  - info: host.iobroker.esxi iobroker upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
        2023-09-03 16:45:18.278  - info: host.iobroker.esxi iobroker upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js static/js/2.b1d56998.chunk.js application/javascript
        2023-09-03 16:45:18.286  - info: host.iobroker.esxi iobroker upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.LICENSE.txt static/js/2.b1d56998.chunk.js.LICENSE.txt text/plain
        2023-09-03 16:45:18.324  - info: host.iobroker.esxi iobroker upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.map static/js/2.b1d56998.chunk.js.map application/json
        2023-09-03 16:45:18.570  - info: host.iobroker.esxi iobroker upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js static/js/main.034751df.chunk.js application/javascript
        2023-09-03 16:45:18.584  - info: host.iobroker.esxi iobroker upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js.map static/js/main.034751df.chunk.js.map application/json
        2023-09-03 16:45:18.587  - info: host.iobroker.esxi iobroker upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js static/js/runtime-main.7278cf1c.js application/javascript
        2023-09-03 16:45:18.590  - info: host.iobroker.esxi iobroker upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js.map static/js/runtime-main.7278cf1c.js.map application/json
        2023-09-03 16:45:18.593  - info: host.iobroker.esxi iobroker upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
        2023-09-03 16:45:18.596  - info: host.iobroker.esxi iobroker upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
        2023-09-03 16:45:18.600  - info: host.iobroker.esxi iobroker host.iobroker.esxi Adapter "system.adapter.web.0" is started
        2023-09-03 16:45:18.620  - info: host.iobroker.esxi "system.adapter.web.0" enabled
        2023-09-03 16:45:18.700  - info: host.iobroker.esxi instance system.adapter.web.0 started with pid 1811299
        2023-09-03 16:45:19.656  - info: host.iobroker.esxi iobroker exit 0
        2023-09-03 16:47:00.011  - info: javascript.0 (1801497) script.js.01_scripts.01_devices.bathroom.b_washingmachine: WM done?
        2023-09-03 16:47:01.174  - error: telegram.1 (1801535) Cannot send message [chatId -]: Error: ETELEGRAM: 403 Forbidden: user is deactivated
        2023-09-03 16:49:13.315  - info: host.iobroker.esxi Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
        2023-09-03 16:53:21.254  - info: host.iobroker.esxi "system.adapter.vis.0" disabled
        2023-09-03 16:53:21.276  - info: host.iobroker.esxi "system.adapter.vis.0" enabled
        2023-09-03 16:53:23.775  - info: host.iobroker.esxi instance system.adapter.vis.0 terminated while should be started once
        GlasfaserG Offline
        GlasfaserG Offline
        @manmac1 sagte in Adapter Aktualisierung funktioniert nicht:
        Nach deiner oberen Ausgabe wenn ich es mir genauer anschaue ,
        hast du früher sehr viel aus Github die Adapter gezogen .
        Das ist alles querbeet und seit Nodejs 16/18 wir genauer darauf geschaut.
        Ich wurde ein Backup nehmen und ioBroker neu aufsetzen , denn du bis seit Nodejs12 dabei.
        Meine Empfehlung !
          Meine Empfehlung !
          manmac1
          @glasfaser
          Hab ich mir vorhin auch schon gedacht. Hab etwas bammel ob ich das Backup und die Wiederherstellung auch so hinbekomme, dass sich an dem aktuellen Setup nichts verändert - ist mittlerweile doch sehr komplex ;) .
          • M manmac1
            @glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            Ich sehe da nichts von , sieht normal aus ,
            Meinst du deswegen :
            Dein :
            /usr/bin/npm 9.5.1
            /usr/bin/npx 9.5.1
            ist auch schon alt , Aktuell ist
            Wie gesagt , setze es neu auf ..
            aber bitte den Benutzer nicht iobroker nennen !
              Dein :
              /usr/bin/npm 9.5.1
              /usr/bin/npx 9.5.1
              manmac1
              @glasfaser
              ja, mach ich.
              Hast du einen Tip für eine gute Anleitung?
              Such grad nach dem richtigen Debian image für meine vm ;)
              • M manmac1
                @glasfaser
                ja, mach ich.
                GlasfaserG Offline
                GlasfaserG Offline
                Hast du einen Tip
                Auf Debian 12 Bookworm gehen
                  @manmac1 und dem root kein Passwort geben
                  • M manmac1
                    @glasfaser
                    ja, mach ich.
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @manmac1
                    Ich habe nochmal in Ruhe deine Angaben durchgelesen :
                    Ich habe gerade ein Großes ?
                    Im Eröffnungs Thread :
                    iobroker@iobroker:/opt/iobroker$ nodejs -v && node -v && npm -v
                    v18.17.1
                    v18.17.1
                    9.6.7
                    in der Ausgabe von iob diag
                    /usr/bin/npm 9.5.1
                    /usr/bin/npx 9.5.1
                    wie geht das denn !?
                      @manmac1
                      v18.17.1
                      v18.17.1
                      9.6.7
                      /usr/bin/npm 9.5.1
                      /usr/bin/npx 9.5.1
                      manmac1
                      @glasfaser
                      kommt wahrscheinlich daher, dass ich zwischendurch auf einen früheren Snapshot von heute zurücksteigen musste - sorry für die Verwirrung
                      GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                      • M manmac1
                        @glasfaser
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @manmac1
                        NUR zur INFO !
                        OK ... das ist natürlich Käse :(
                        Bitte ... wenn du etwas veränderst , hier immer alles mitteilen .
                        bzw .
                        Wie sollten wir hier helfen , wenn du zwischenzeitlich etwas anderes machst , was wir nicht wissen !?
                        Deshalb lese bitte auch das genau durch :
                        • M manmac1
                          @glasfaser
                          @manmac1
                          Dann räum zunächst mal die Quellen auf.
                          Schmeiß den Eintrag zu grafana/stretch raus.
                          Dann die Kiste auf Stand bringen, inkl. nodejs.
                          Solange openzwave nicht sauber kompiliert geht auch nichts mit anderen Adaptern. Warum es das nicht tut kann ich dir aber nicht sagen.
                          Vielleicht mal den cache löschen und/oder den Adapter dazu rauswerfen.
