  4. Adapter Aktualisierung funktioniert nicht
    5.2k
28 Beiträge 6 Kommentatoren 2.2k Aufrufe 6 Beobachtet
  • M manmac1
    habs nochmal rauskopiert:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : vmware
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     16:56:43 up 15:03,  3 users,  load average: 0.29, 0.52, 0.52
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Sun 2023-09-03 16:56:43 CEST
               Universal time: Sun 2023-09-03 14:56:43 UTC
                     RTC time: Sun 2023-09-03 14:56:43
                    Time zone: Europe/Vienna (CEST, +0200)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    iobroker
    /home/iobroker
    iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev bluetooth
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.9G        2.5G        2.8G        0.0K        2.7G        5.5G
    Swap:           2.0G          0B        2.0G
    Total:            9G        2.5G        4.8G
             7945 M total memory
             2456 M used memory
             1277 M active memory
             3294 M inactive memory
             2783 M free memory
              409 M buffer memory
             2295 M swap cache
             2044 M total swap
                0 M used swap
             2044 M free swap
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     795M  736K  794M   1% /run
    /dev/sda1      ext4       30G   16G   13G  55% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     795M  4.0K  795M   1% /run/user/1000
    [Sun Sep  3 01:53:08 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Sep  3 01:53:09 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    2.8G    /var/
    1.5G    /var/cache/apt
    1.5G    /var/cache
    1.4G    /var/cache/apt/archives
    823M    /var/lib
    Archived and active journals take up 32.0M in the file system.
    /opt/iobroker/backups:
    360M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.4G    /opt/iobroker/iobroker-data/
    1.9G    /opt/iobroker/iobroker-data/sonosCache
    332M    /opt/iobroker/iobroker-data/files
    152M    /opt/iobroker/iobroker-data/backup-objects
    53M     /opt/iobroker/iobroker-data/files/javascript.admin
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    13M     /opt/iobroker/iobroker-data/objects.jsonl
    11M     /opt/iobroker/iobroker-data/objects.json.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
         18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
     *** 18.16.0-deb-1nodesource1 100
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @harmonyhub/discover@1.0.5 /opt/iobroker/node_modules/@harmonyhub/discover
    npm ERR! extraneous: @iobroker/adapter-core@1.0.1 /opt/iobroker/node_modules/@iobroker/adapter-core
    npm ERR! extraneous: @node-red/editor-api@0.20.7 /opt/iobroker/node_modules/@node-red/editor-api
    npm ERR! extraneous: @node-red/editor-client@0.20.7 /opt/iobroker/node_modules/@node-red/editor-client
    npm ERR! extraneous: @node-red/nodes@0.20.7 /opt/iobroker/node_modules/@node-red/nodes
    npm ERR! extraneous: @node-red/registry@0.20.7 /opt/iobroker/node_modules/@node-red/registry
    npm ERR! extraneous: @node-red/runtime@0.20.7 /opt/iobroker/node_modules/@node-red/runtime
    npm ERR! extraneous: @node-red/util@0.20.7 /opt/iobroker/node_modules/@node-red/util
    npm ERR! extraneous: @types/form-data@2.2.1 /opt/iobroker/node_modules/@types/form-data
    npm ERR! extraneous: @types/iobroker@1.4.0 /opt/iobroker/node_modules/@types/iobroker
    npm ERR! extraneous: @types/request@2.48.1 /opt/iobroker/node_modules/@types/request
    npm ERR! extraneous: agent-base@4.3.0 /opt/iobroker/node_modules/agent-base
    npm ERR! extraneous: alcalzone-shared@1.4.0 /opt/iobroker/node_modules/alcalzone-shared
    npm ERR! extraneous: alexa-cookie2@2.1.0 /opt/iobroker/node_modules/alexa-cookie2
    npm ERR! extraneous: alexa-remote2@2.5.5 /opt/iobroker/node_modules/alexa-remote2
    npm ERR! extraneous: asap@2.0.6 /opt/iobroker/node_modules/asap
    npm ERR! extraneous: async@2.5.0 /opt/iobroker/node_modules/async
    npm ERR! extraneous: autobind-decorator@2.4.0 /opt/iobroker/node_modules/autobind-decorator
    npm ERR! extraneous: aws-iot-device-sdk@2.2.1 /opt/iobroker/node_modules/aws-iot-device-sdk
    npm ERR! extraneous: axios@0.15.3 /opt/iobroker/node_modules/axios
    npm ERR! extraneous: base64url@2.0.0 /opt/iobroker/node_modules/base64url
    npm ERR! extraneous: binrpc@1.0.0 /opt/iobroker/node_modules/binrpc
    npm ERR! extraneous: bson@1.1.1 /opt/iobroker/node_modules/bson
    npm ERR! extraneous: buffer-crc32@0.2.13 /opt/iobroker/node_modules/buffer-crc32
    npm ERR! extraneous: callback-stream@1.1.0 /opt/iobroker/node_modules/callback-stream
    npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/chalk
    npm ERR! extraneous: cheerio@1.0.0-rc.3 /opt/iobroker/node_modules/cheerio
    npm ERR! extraneous: cls-bluebird@1.1.3 /opt/iobroker/node_modules/cls-bluebird
    npm ERR! extraneous: commander@2.11.0 /opt/iobroker/node_modules/commander
    npm ERR! extraneous: cron@1.7.1 /opt/iobroker/node_modules/cron
    npm ERR! extraneous: crypto-js@3.1.6 /opt/iobroker/node_modules/crypto-js
    npm ERR! extraneous: deep-extend@0.4.2 /opt/iobroker/node_modules/deep-extend
    npm ERR! extraneous: dicer@0.2.5 /opt/iobroker/node_modules/dicer
    npm ERR! extraneous: dotenv@4.0.0 /opt/iobroker/node_modules/dotenv
    npm ERR! extraneous: epoll@0.1.22 /opt/iobroker/node_modules/epoll
    npm ERR! extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
    npm ERR! extraneous: es6-set@0.1.5 /opt/iobroker/node_modules/es6-set
    npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/escape-string-regexp
    npm ERR! extraneous: event-emitter@0.3.5 /opt/iobroker/node_modules/event-emitter
    npm ERR! extraneous: eventemitter3@2.0.3 /opt/iobroker/node_modules/eventemitter3
    npm ERR! extraneous: express-fileupload@0.1.4 /opt/iobroker/node_modules/express-fileupload
    npm ERR! extraneous: express-session@1.16.2 /opt/iobroker/node_modules/express-session
    npm ERR! extraneous: express@4.16.2 /opt/iobroker/node_modules/express
    npm ERR! extraneous: extract-zip@1.7.0 /opt/iobroker/node_modules/extract-zip
    npm ERR! extraneous: fd-slicer@1.1.0 /opt/iobroker/node_modules/fd-slicer
    npm ERR! extraneous: finalhandler@1.1.0 /opt/iobroker/node_modules/finalhandler
    npm ERR! extraneous: fs-extra@0.22.1 /opt/iobroker/node_modules/fs-extra
    npm ERR! extraneous: fs-minipass@1.2.3 /opt/iobroker/node_modules/fs-minipass
    npm ERR! extraneous: generate-function@2.0.0 /opt/iobroker/node_modules/generate-function
    npm ERR! extraneous: generate-object-property@1.2.0 /opt/iobroker/node_modules/generate-object-property
    npm ERR! extraneous: glob-parent@3.1.0 /opt/iobroker/node_modules/glob-parent
    npm ERR! extraneous: glob-stream@6.1.0 /opt/iobroker/node_modules/glob-stream
    npm ERR! extraneous: harmonyhubws@1.0.4 /opt/iobroker/node_modules/harmonyhubws
    npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/has-flag
    npm ERR! extraneous: hasha@2.2.0 /opt/iobroker/node_modules/hasha
    npm ERR! extraneous: homematic-manager@1.0.14 /opt/iobroker/node_modules/homematic-manager
    npm ERR! extraneous: http-proxy-middleware@0.19.1 /opt/iobroker/node_modules/http-proxy-middleware
    npm ERR! extraneous: https-proxy-agent@2.2.1 /opt/iobroker/node_modules/https-proxy-agent
    npm ERR! extraneous: i18next@15.1.0 /opt/iobroker/node_modules/i18next
    npm ERR! extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/ignore-walk
    npm ERR! extraneous: imap@0.8.19 /opt/iobroker/node_modules/imap
    npm ERR! extraneous: io-packages.json@ /opt/iobroker/node_modules/io-packages.json
    npm ERR! missing: iobroker.geofency@^1.0.3, required by iobroker@1.0.0
    npm ERR! extraneous: iobroker.hmm@1.0.1 /opt/iobroker/node_modules/iobroker.hmm
    npm ERR! extraneous: iobroker.icons-icons8@0.0.1 /opt/iobroker/node_modules/iobroker.icons-icons8
    npm ERR! extraneous: iobroker.rp2@ /opt/iobroker/node_modules/iobroker.rp2
    npm ERR! extraneous: iobroker.type-detector@0.1.1 /opt/iobroker/node_modules/iobroker.type-detector
    npm ERR! extraneous: iobroker.vis-bars@0.1.4 /opt/iobroker/node_modules/iobroker.vis-bars
    npm ERR! extraneous: iobroker.vis-fancyswitch@1.1.0 /opt/iobroker/node_modules/iobroker.vis-fancyswitch
    npm ERR! extraneous: iobroker@1.0.2 /opt/iobroker/node_modules/iobroker
    npm ERR! extraneous: ipaddr.js@1.5.2 /opt/iobroker/node_modules/ipaddr.js
    npm ERR! extraneous: is-bluebird@1.0.2 /opt/iobroker/node_modules/is-bluebird
    npm ERR! extraneous: is-buffer@2.0.4 /opt/iobroker/node_modules/is-buffer
    npm ERR! extraneous: is-my-json-valid@2.16.1 /opt/iobroker/node_modules/is-my-json-valid
    npm ERR! extraneous: is-negated-glob@1.0.0 /opt/iobroker/node_modules/is-negated-glob
    npm ERR! extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
    npm ERR! extraneous: is-stream@1.1.0 /opt/iobroker/node_modules/is-stream
    npm ERR! extraneous: isemail@1.2.0 /opt/iobroker/node_modules/isemail
    npm ERR! extraneous: joi@6.10.1 /opt/iobroker/node_modules/joi
    npm ERR! extraneous: js-yaml@3.13.1 /opt/iobroker/node_modules/js-yaml
    npm ERR! extraneous: js2xmlparser@3.0.0 /opt/iobroker/node_modules/js2xmlparser
    npm ERR! extraneous: json-stable-stringify-without-jsonify@1.0.1 /opt/iobroker/node_modules/json-stable-stringify-without-jsonify
    npm ERR! extraneous: jsonata@1.6.5 /opt/iobroker/node_modules/jsonata
    npm ERR! extraneous: jsonfile@2.4.0 /opt/iobroker/node_modules/jsonfile
    npm ERR! extraneous: jsonpointer@4.0.1 /opt/iobroker/node_modules/jsonpointer
    npm ERR! extraneous: jsonwebtoken@8.1.1 /opt/iobroker/node_modules/jsonwebtoken
    npm ERR! extraneous: jws@3.1.4 /opt/iobroker/node_modules/jws
    npm ERR! extraneous: kew@0.7.0 /opt/iobroker/node_modules/kew
    npm ERR! extraneous: klaw@1.3.1 /opt/iobroker/node_modules/klaw
    npm ERR! extraneous: libbase64@1.0.3 /opt/iobroker/node_modules/libbase64
    npm ERR! extraneous: libmime@4.1.1 /opt/iobroker/node_modules/libmime
    npm ERR! extraneous: libqp@1.1.0 /opt/iobroker/node_modules/libqp
    npm ERR! extraneous: linkify-it@2.1.0 /opt/iobroker/node_modules/linkify-it
    npm ERR! extraneous: mailparser@2.7.1 /opt/iobroker/node_modules/mailparser
    npm ERR! extraneous: mailsplit@4.4.1 /opt/iobroker/node_modules/mailsplit
    npm ERR! extraneous: memorystore@1.6.1 /opt/iobroker/node_modules/memorystore
    npm ERR! extraneous: minipass@2.2.1 /opt/iobroker/node_modules/minipass
    npm ERR! extraneous: minizlib@1.0.4 /opt/iobroker/node_modules/minizlib
    npm ERR! extraneous: mongodb@3.3.0 /opt/iobroker/node_modules/mongodb
    npm ERR! extraneous: multer@1.4.1 /opt/iobroker/node_modules/multer
    npm ERR! extraneous: mustache@3.0.1 /opt/iobroker/node_modules/mustache
    npm ERR! extraneous: needle@2.9.1 /opt/iobroker/node_modules/needle
    npm ERR! extraneous: net-snmp@1.2.4 /opt/iobroker/node_modules/net-snmp
    npm ERR! extraneous: node-abi@2.15.0 /opt/iobroker/node_modules/node-abi
    npm ERR! extraneous: node-disk-info@ /opt/iobroker/node_modules/node-disk-info
    npm ERR! extraneous: node-hue-api@2.4.2 /opt/iobroker/node_modules/node-hue-api
    npm ERR! extraneous: node-ical@0.5.4 /opt/iobroker/node_modules/node-ical
    npm ERR! extraneous: node-red-contrib-polymer@0.0.21 /opt/iobroker/node_modules/node-red-contrib-polymer
    npm ERR! extraneous: node-red-dashboard@2.16.1 /opt/iobroker/node_modules/node-red-dashboard
    npm ERR! extraneous: node-red-node-email@1.6.2 /opt/iobroker/node_modules/node-red-node-email
    npm ERR! extraneous: node-red-node-feedparser@0.1.14 /opt/iobroker/node_modules/node-red-node-feedparser
    npm ERR! extraneous: node-red-node-rbe@0.2.5 /opt/iobroker/node_modules/node-red-node-rbe
    npm ERR! extraneous: node-red-node-sentiment@0.1.4 /opt/iobroker/node_modules/node-red-node-sentiment
    npm ERR! extraneous: node-red-node-tail@0.0.2 /opt/iobroker/node_modules/node-red-node-tail
    npm ERR! extraneous: node-red-node-twitter@1.1.5 /opt/iobroker/node_modules/node-red-node-twitter
    npm ERR! extraneous: node-red@0.20.7 /opt/iobroker/node_modules/node-red
    npm ERR! extraneous: node-ssdp@3.2.5 /opt/iobroker/node_modules/node-ssdp
    npm ERR! extraneous: node-static@0.7.11 /opt/iobroker/node_modules/node-static
    npm ERR! extraneous: node-telegram-bot-api@0.28.0 /opt/iobroker/node_modules/node-telegram-bot-api
    npm ERR! extraneous: nodemailer@6.3.0 /opt/iobroker/node_modules/nodemailer
    npm ERR! extraneous: noop-logger@0.1.1 /opt/iobroker/node_modules/noop-logger
    npm ERR! extraneous: npm-bundled@1.1.2 /opt/iobroker/node_modules/npm-bundled
    npm ERR! extraneous: npm-normalize-package-bin@1.0.1 /opt/iobroker/node_modules/npm-normalize-package-bin
    npm ERR! extraneous: npm-packlist@1.4.8 /opt/iobroker/node_modules/npm-packlist
    npm ERR! extraneous: object.assign@4.0.4 /opt/iobroker/node_modules/object.assign
    npm ERR! extraneous: openzwave-shared@1.4.1 /opt/iobroker/node_modules/openzwave-shared
    npm ERR! extraneous: optimist@0.6.1 /opt/iobroker/node_modules/optimist
    npm ERR! extraneous: ordered-read-streams@1.0.1 /opt/iobroker/node_modules/ordered-read-streams
    npm ERR! extraneous: parse5@3.0.3 /opt/iobroker/node_modules/parse5
    npm ERR! extraneous: passport@0.3.2 /opt/iobroker/node_modules/passport
    npm ERR! extraneous: path-dirname@1.0.2 /opt/iobroker/node_modules/path-dirname
    npm ERR! extraneous: pend@1.2.0 /opt/iobroker/node_modules/pend
    npm ERR! extraneous: poplib@0.1.7 /opt/iobroker/node_modules/poplib
    npm ERR! extraneous: prebuild-install@5.3.3 /opt/iobroker/node_modules/prebuild-install
    npm ERR! extraneous: progress@1.1.8 /opt/iobroker/node_modules/progress
    npm ERR! extraneous: promise@7.1.1 /opt/iobroker/node_modules/promise
    npm ERR! extraneous: proxy-addr@2.0.2 /opt/iobroker/node_modules/proxy-addr
    npm ERR! extraneous: pump@1.0.2 /opt/iobroker/node_modules/pump
    npm ERR! extraneous: pumpify@1.5.1 /opt/iobroker/node_modules/pumpify
    npm ERR! extraneous: request-progress@2.0.1 /opt/iobroker/node_modules/request-progress
    npm ERR! extraneous: request-promise-core@1.1.1 /opt/iobroker/node_modules/request-promise-core
    npm ERR! extraneous: request-promise-native@1.0.5 /opt/iobroker/node_modules/request-promise-native
    npm ERR! extraneous: request-promise@1.0.2 /opt/iobroker/node_modules/request-promise
    npm ERR! extraneous: require_optional@1.0.1 /opt/iobroker/node_modules/require_optional
    npm ERR! extraneous: resolve-from@2.0.0 /opt/iobroker/node_modules/resolve-from
    npm ERR! extraneous: rpi-gpio@0.7.0 /opt/iobroker/node_modules/rpi-gpio
    npm ERR! extraneous: rrule@2.2.0 /opt/iobroker/node_modules/rrule
    npm ERR! extraneous: semaphore@1.0.5 /opt/iobroker/node_modules/semaphore
    npm ERR! extraneous: serialport@4.0.7 /opt/iobroker/node_modules/serialport
    npm ERR! extraneous: shimmer@1.2.0 /opt/iobroker/node_modules/shimmer
    npm ERR! extraneous: sonos-discovery@1.1.3 /opt/iobroker/node_modules/sonos-discovery
    npm ERR! extraneous: sonos-web-controller@0.14.0 /opt/iobroker/node_modules/sonos-web-controller
    npm ERR! extraneous: sprintf-js@1.0.3 /opt/iobroker/node_modules/sprintf-js
    npm ERR! extraneous: streamifier@0.1.1 /opt/iobroker/node_modules/streamifier
    npm ERR! extraneous: suncalc@1.8.0 /opt/iobroker/node_modules/suncalc
    npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/supports-color
    npm ERR! extraneous: systeminformation@3.54.0 /opt/iobroker/node_modules/systeminformation
    npm ERR! extraneous: tail@2.2.4 /opt/iobroker/node_modules/tail
    npm ERR! extraneous: throttleit@1.0.0 /opt/iobroker/node_modules/throttleit
    npm ERR! extraneous: through2-filter@3.0.0 /opt/iobroker/node_modules/through2-filter
    npm ERR! extraneous: tlds@1.203.1 /opt/iobroker/node_modules/tlds
    npm ERR! extraneous: to-absolute-glob@2.0.2 /opt/iobroker/node_modules/to-absolute-glob
    npm ERR! extraneous: topo@1.1.0 /opt/iobroker/node_modules/topo
    npm ERR! extraneous: traits@0.4.0 /opt/iobroker/node_modules/traits
    npm ERR! extraneous: typescript@2.7.1 /opt/iobroker/node_modules/typescript
    npm ERR! extraneous: uc.micro@1.0.6 /opt/iobroker/node_modules/uc.micro
    npm ERR! extraneous: uglify-js@3.6.0 /opt/iobroker/node_modules/uglify-js
    npm ERR! extraneous: unique-stream@2.3.1 /opt/iobroker/node_modules/unique-stream
    npm ERR! extraneous: ursa-optional@0.9.8 /opt/iobroker/node_modules/ursa-optional
    npm ERR! extraneous: utf7@1.0.2 /opt/iobroker/node_modules/utf7
    npm ERR! extraneous: virtual-device-sdk@1.5.19 /opt/iobroker/node_modules/virtual-device-sdk
    npm ERR! extraneous: virtual-tsc@0.3.4 /opt/iobroker/node_modules/virtual-tsc
    npm ERR! extraneous: vm2@3.6.10 /opt/iobroker/node_modules/vm2
    npm ERR! extraneous: wake_on_lan@0.0.4 /opt/iobroker/node_modules/wake_on_lan
    npm ERR! extraneous: when@3.7.8 /opt/iobroker/node_modules/when
    npm ERR! extraneous: which-pm-runs@1.0.0 /opt/iobroker/node_modules/which-pm-runs
    npm ERR! extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
    npm ERR! extraneous: wordwrap@0.0.3 /opt/iobroker/node_modules/wordwrap
    npm ERR! extraneous: xmlbuilder@9.0.4 /opt/iobroker/node_modules/xmlbuilder
    npm ERR! extraneous: xmlcreate@1.0.2 /opt/iobroker/node_modules/xmlcreate
    npm ERR! extraneous: yauzl@2.10.0 /opt/iobroker/node_modules/yauzl
    npm ERR!     /home/iobroker/.npm/_logs/2023-09-03T14_56_53_179Z-debug-0.log
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker.esxi                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker.esxi                            -  enabled
      system.adapter.backitup.0               : backitup              : iobroker.esxi                            - disabled
      system.adapter.cloud.0                  : cloud                 : iobroker.esxi                            - disabled
      system.adapter.devices.0                : devices               : iobroker.esxi                            -  enabled
      system.adapter.discovery.0              : discovery             : iobroker.esxi                            - disabled
      system.adapter.flot.0                   : flot                  : iobroker.esxi                            -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker.esxi                            -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker.esxi                            -  enabled, port: 0
    + system.adapter.hue.0                    : hue                   : iobroker.esxi                            -  enabled, port: 443
    + system.adapter.influxdb.0               : influxdb              : iobroker.esxi                            -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker.esxi                            -  enabled
      system.adapter.iot.0                    : iot                   : iobroker.esxi                            - disabled
    + system.adapter.javascript.0             : javascript            : iobroker.esxi                            -  enabled
    + system.adapter.lametric.0               : lametric              : iobroker.esxi                            -  enabled
    + system.adapter.netatmo.0                : netatmo               : iobroker.esxi                            -  enabled
    + system.adapter.node-red.0               : node-red              : iobroker.esxi                            -  enabled, port: 1880, bind: 0.0.0.0 (SSL)
    + system.adapter.parser.0                 : parser                : iobroker.esxi                            -  enabled
    + system.adapter.sonos.0                  : sonos                 : iobroker.esxi                            -  enabled
    + system.adapter.systeminfo.0             : systeminfo            : iobroker.esxi                            -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker.esxi                            -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker.esxi                            -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker.esxi                            -  enabled
      system.adapter.vis.0                    : vis                   : iobroker.esxi                            -  enabled
    + system.adapter.web.0                    : web                   : iobroker.esxi                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : iobroker.esxi                            -  enabled
    + system.adapter.zwave2.0                 : zwave2                : iobroker.esxi                            -  enabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    sources       : conf/sources-dist.json
    online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
    Adapter    "alexa2"       : 3.24.1   , installed 3.23.2 [Updatable]
    Adapter    "backitup"     : 2.6.23   , installed 2.4.9  [Updatable]
    Adapter    "ble"          : 0.13.4   , installed 0.13.0 [Updatable]
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "cloud"        : 4.4.1    , installed 4.3.0  [Updatable]
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
    Adapter    "frontier_silicon": 0.0.11, installed 0.0.10 [Updatable]
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "history"      : 2.2.6    , installed 1.11.1 [Updatable]
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.46 [Updatable]
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.16 [Updatable]
    Adapter    "hue"          : 3.9.5    , installed 3.7.1  [Updatable]
    Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
    Adapter    "info"         : 1.9.26   , installed 1.9.19 [Updatable]
    Adapter    "iot"          : 1.14.5   , installed 1.14.2 [Updatable]
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "lametric"     : 2.4.1    , installed 2.4.1
    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "node-red"     : 4.0.3    , installed 4.0.0  [Updatable]
    Adapter    "owfs"         : 0.7.0    , installed 0.7.0
    Adapter    "parser"       : 1.3.2    , installed 1.1.8  [Updatable]
    Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
    Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
    Adapter    "radar2"       : 2.0.7    , installed 2.0.3  [Updatable]
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "snmp"         : 2.4.11   , installed 1.0.0  [Updatable]
    Adapter    "socketio"     : 6.5.2    , installed 4.2.0  [Updatable]
    Adapter    "sonos"        : 2.3.1    , installed 2.3.1
    Adapter    "systeminfo"   : 1.0.0    , installed 0.3.1  [Updatable]
    Adapter    "telegram"     : 1.16.0   , installed 1.15.6 [Updatable]
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.3.0  [Updatable]
    Adapter    "web"          : 6.1.0    , installed 4.3.0  [Updatable]
    Adapter    "ws"           : 2.5.3    , installed 1.3.0  [Updatable]
    Adapter    "yahka"        : 1.0.3    , installed 0.17.0 [Updatable]
    Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
    Objects and States
    Objects:        7546
    States:         7329
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security/updates InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 https://repos.influxdata.com/debian stable InRelease
    Hit:7 https://repos.influxdata.com/debian stretch InRelease
    Get:8 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
    Fetched 4586 B in 1s (7111 B/s)
    Reading package lists...
    Pending Updates: 10
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1711988    1801452/iobroker.js
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1711981    1801452/iobroker.js
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          9392       1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12738      587/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       1714317    1801565/node-red
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        13256      900/influxd
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          14710      1245/exim4
    tcp        0      0 127.0.0.1:2010          0.0.0.0:*               LISTEN      1000       1715056    1801591/io.hm-rpc.0
    tcp        0      0 127.0.0.1:35931         0.0.0.0:*               LISTEN      1000       1718958    1802489/io.yahka.0
    tcp        0      0 127.0.0.1:39589         0.0.0.0:*               LISTEN      1000       1721109    1802489/io.yahka.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          9396       1/init
    tcp6       0      0 :::80                   :::*                    LISTEN      1000       1714319    1801565/node-red
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1714058    1801470/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1729486    1811299/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        15440      900/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12749      587/sshd: /usr/sbin
    tcp6       0      0 :::45079                :::*                    LISTEN      1000       1718644    1802489/io.yahka.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      107        14792      1253/grafana
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          14711      1245/exim4
    tcp6       0      0 :::38237                :::*                    LISTEN      1000       1718648    1802489/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1718649    1802489/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1718645    1802489/io.yahka.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1714320    1801565/node-red
    udp        0      0 198.18.10.12:1905       0.0.0.0:*                           1000       1758117    1801661/io.sonos.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12534      538/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9393       1/init
    udp6       0      0 :::111                  :::*                                0          9399       1/init
    2023-09-03 16:45:18.264  - info: host.iobroker.esxi iobroker upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
    2023-09-03 16:45:18.266  - info: host.iobroker.esxi iobroker upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
    2023-09-03 16:45:18.268  - info: host.iobroker.esxi iobroker upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
    2023-09-03 16:45:18.270  - info: host.iobroker.esxi iobroker upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
    2023-09-03 16:45:18.272  - info: host.iobroker.esxi iobroker upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
    2023-09-03 16:45:18.274  - info: host.iobroker.esxi iobroker upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
    2023-09-03 16:45:18.278  - info: host.iobroker.esxi iobroker upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js static/js/2.b1d56998.chunk.js application/javascript
    2023-09-03 16:45:18.286  - info: host.iobroker.esxi iobroker upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.LICENSE.txt static/js/2.b1d56998.chunk.js.LICENSE.txt text/plain
    2023-09-03 16:45:18.324  - info: host.iobroker.esxi iobroker upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.map static/js/2.b1d56998.chunk.js.map application/json
    2023-09-03 16:45:18.570  - info: host.iobroker.esxi iobroker upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js static/js/main.034751df.chunk.js application/javascript
    2023-09-03 16:45:18.584  - info: host.iobroker.esxi iobroker upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js.map static/js/main.034751df.chunk.js.map application/json
    2023-09-03 16:45:18.587  - info: host.iobroker.esxi iobroker upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js static/js/runtime-main.7278cf1c.js application/javascript
    2023-09-03 16:45:18.590  - info: host.iobroker.esxi iobroker upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js.map static/js/runtime-main.7278cf1c.js.map application/json
    2023-09-03 16:45:18.593  - info: host.iobroker.esxi iobroker upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
    2023-09-03 16:45:18.596  - info: host.iobroker.esxi iobroker upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
    2023-09-03 16:45:18.600  - info: host.iobroker.esxi iobroker host.iobroker.esxi Adapter "system.adapter.web.0" is started
    2023-09-03 16:45:18.620  - info: host.iobroker.esxi "system.adapter.web.0" enabled
    2023-09-03 16:45:18.700  - info: host.iobroker.esxi instance system.adapter.web.0 started with pid 1811299
    2023-09-03 16:45:19.656  - info: host.iobroker.esxi iobroker exit 0
    2023-09-03 16:47:00.011  - info: javascript.0 (1801497) script.js.01_scripts.01_devices.bathroom.b_washingmachine: WM done?
    2023-09-03 16:47:01.174  - error: telegram.1 (1801535) Cannot send message [chatId -]: Error: ETELEGRAM: 403 Forbidden: user is deactivated
    2023-09-03 16:49:13.315  - info: host.iobroker.esxi Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
    2023-09-03 16:53:21.254  - info: host.iobroker.esxi "system.adapter.vis.0" disabled
    2023-09-03 16:53:21.276  - info: host.iobroker.esxi "system.adapter.vis.0" enabled
    2023-09-03 16:53:23.775  - info: host.iobroker.esxi instance system.adapter.vis.0 terminated while should be started once
    GlasfaserG Offline
    GlasfaserG Offline
    @manmac1 sagte in Adapter Aktualisierung funktioniert nicht:
    Nach deiner oberen Ausgabe wenn ich es mir genauer anschaue ,
    hast du früher sehr viel aus Github die Adapter gezogen .
    Das ist alles querbeet und seit Nodejs 16/18 wir genauer darauf geschaut.
    Ich wurde ein Backup nehmen und ioBroker neu aufsetzen , denn du bis seit Nodejs12 dabei.
    Meine Empfehlung !
    • GlasfaserG Glasfaser
      Meine Empfehlung !
      manmac1
      @glasfaser
      Hab ich mir vorhin auch schon gedacht. Hab etwas bammel ob ich das Backup und die Wiederherstellung auch so hinbekomme, dass sich an dem aktuellen Setup nichts verändert - ist mittlerweile doch sehr komplex ;) .
      • M manmac1
        @glasfaser
        GlasfaserG Offline
        GlasfaserG Offline
        Ich sehe da nichts von , sieht normal aus ,
        Meinst du deswegen :
        Dein :
        /usr/bin/npm 9.5.1
        /usr/bin/npx 9.5.1
        ist auch schon alt , Aktuell ist
        Wie gesagt , setze es neu auf ..
        aber bitte den Benutzer nicht iobroker nennen !
          Dein :
          /usr/bin/npm 9.5.1
          /usr/bin/npx 9.5.1
          manmac1
          @glasfaser
          ja, mach ich.
          Hast du einen Tip für eine gute Anleitung?
          Such grad nach dem richtigen Debian image für meine vm ;)
          • M manmac1
            @glasfaser
            ja, mach ich.
            GlasfaserG Offline
            GlasfaserG Offline
            Hast du einen Tip
            Auf Debian 12 Bookworm gehen
              @manmac1 und dem root kein Passwort geben
              • M manmac1
                @glasfaser
                ja, mach ich.
                GlasfaserG Offline
                GlasfaserG Offline
                @manmac1
                Ich habe nochmal in Ruhe deine Angaben durchgelesen :
                Ich habe gerade ein Großes ?
                Im Eröffnungs Thread :
                iobroker@iobroker:/opt/iobroker$ nodejs -v && node -v && npm -v
                v18.17.1
                v18.17.1
                9.6.7
                in der Ausgabe von iob diag
                /usr/bin/npm 9.5.1
                /usr/bin/npx 9.5.1
                wie geht das denn !?
                  @manmac1
                  v18.17.1
                  v18.17.1
                  9.6.7
                  /usr/bin/npm 9.5.1
                  /usr/bin/npx 9.5.1
                  manmac1
                  @glasfaser
                  kommt wahrscheinlich daher, dass ich zwischendurch auf einen früheren Snapshot von heute zurücksteigen musste - sorry für die Verwirrung
                  GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                  • M manmac1
                    @glasfaser
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @manmac1
                    NUR zur INFO !
                    OK ... das ist natürlich Käse :(
                    Bitte ... wenn du etwas veränderst , hier immer alles mitteilen .
                    bzw .
                    Wie sollten wir hier helfen , wenn du zwischenzeitlich etwas anderes machst , was wir nicht wissen !?
                    Deshalb lese bitte auch das genau durch :
                    • M manmac1
                      @glasfaser
                      @manmac1
                      Dann räum zunächst mal die Quellen auf.
                      Schmeiß den Eintrag zu grafana/stretch raus.
                      Dann die Kiste auf Stand bringen, inkl. nodejs.
                      Solange openzwave nicht sauber kompiliert geht auch nichts mit anderen Adaptern. Warum es das nicht tut kann ich dir aber nicht sagen.
                      Vielleicht mal den cache löschen und/oder den Adapter dazu rauswerfen.
