  4. Adapter Aktualisierung funktioniert nicht
    5.2k
28 Beiträge 6 Kommentatoren 2.2k Aufrufe 6 Beobachtet
  • GlasfaserG Glasfaser
    @manmac1
    Mache mal bitte :
    iob fix
    cd /opt/iobroker
    npm prune
    sudo reboot
    dann
    iobroker upgrade web@6.1.0 --debug
    manmac1
    @glasfaser
    hat leider nicht geklappt.
    iobroker@iobroker:~$ iobroker upgrade web@6.1.0 --debug
    This upgrade of "web" will at least introduce the following changes:
    -> 6.1.0:
    Added the subscribing on the specific instance messages
    -> 6.0.3:
    Updated packages
    Implemented the possibility to view folder content
    -> 6.0.1:
    Removed letsencrypt handling from web adapter
    -> 5.5.3:
    Increased max size of the uploaded file via socket.io to 200MB (from 10MB)
    -> 5.5.2:
    Allowed deletion of fullcalendar objects
    -> 5.5.1:
    Allowed to read projects of vis-2-beta
    -> 5.5.0:
    Added special end-points for app authentication
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade web from @4.3.0 to @6.1.0 now? [(y)es, (n)o]: y
    Update web from @4.3.0 to @6.1.0
    host.iobroker.esxi Adapter "system.adapter.web.0" is stopped.
    NPM version: 9.5.1
    Installing iobroker.web@6.1.0... (System call)
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
    npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated phantomjs-prebuilt@2.1.16: this package is now deprecated
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/openzwave-shared
    npm ERR! command failed
    npm ERR! command sh -c node-gyp rebuild
    npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/openzwave-shared/build“ wird betreten
    npm ERR!   CXX(target) Release/obj.target/openzwave_shared/src/callbacks.o
    npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/openzwave-shared/build“ wird verlassen
    npm ERR! gyp info it worked if it ends with ok
    npm ERR! gyp info using node-gyp@7.1.2
    npm ERR! gyp info using node@18.16.0 | linux | x64
    npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
    npm ERR! (node:7977) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
    npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
    npm ERR! gyp info spawn /usr/bin/python3
    npm ERR! gyp info spawn args [
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
    npm ERR! gyp info spawn args   'binding.gyp',
    npm ERR! gyp info spawn args   '-f',
    npm ERR! gyp info spawn args   'make',
    npm ERR! gyp info spawn args   '-I',
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/openzwave-shared/build/config.gypi',
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
    npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.16.0/include/node/common.gypi',
    npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
    npm ERR! gyp info spawn args   '-Dvisibility=default',
    npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.16.0',
    npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
    npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.16.0/<(target_arch)/node.lib',
    npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/openzwave-shared',
    npm ERR! gyp info spawn args   '-Dnode_engine=v8',
    npm ERR! gyp info spawn args   '--depth=.',
    npm ERR! gyp info spawn args   '--no-parallel',
    npm ERR! gyp info spawn args   '--generator-output',
    npm ERR! gyp info spawn args   'build',
    npm ERR! gyp info spawn args   '-Goutput_dir=.'
    npm ERR! gyp info spawn args ]
    npm ERR! gyp info spawn make
    npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
    npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-local-handle.h:12,
    npm ERR!                  from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-array-buffer.h:12,
    npm ERR!                  from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8.h:24,
    npm ERR!                  from ../src/openzwave.hpp:27,
    npm ERR!                  from ../src/callbacks.cc:18:
    npm ERR! /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-internal.h: In function ‘void v8::internal::PerformCastCheck(T*)’:
    npm ERR! /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-internal.h:646:38: error: ‘remove_cv_t’ is not a member of ‘std’; did you mean ‘remove_cv’?
    npm ERR!   646 |             !std::is_same<Data, std::remove_cv_t<T>>::value>::Perform(data);
    npm ERR!       |                                      ^~~~~~~~~~~
    npm ERR!       |                                      remove_cv
    npm ERR! /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-internal.h:646:50: error: template argument 2 is invalid
    npm ERR!       |                                                  ^
    npm ERR! /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-internal.h:646:63: error: ‘::Perform’ has not been declared
    npm ERR!       |                                                               ^~~~~~~
    npm ERR! make: *** [openzwave_shared.target.mk:150: Release/obj.target/openzwave_shared/src/callbacks.o] Fehler 1
    npm ERR! gyp ERR! build error
    npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
    npm ERR! gyp ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/node-gyp/lib/build.js:194:23)
    npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
    npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)
    npm ERR! gyp ERR! System Linux 5.10.0-25-amd64
    npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
    npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/openzwave-shared
    npm ERR! gyp ERR! node -v v18.16.0
    npm ERR! gyp ERR! node-gyp -v v7.1.2
    npm ERR! gyp ERR! not ok
    npm ERR!     /home/iobroker/.npm/_logs/2023-09-03T15_11_29_375Z-debug-0.log
    upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
    upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
    upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
    upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
    upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
    upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
    upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
    upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
    upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
    upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
    upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
    upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
    upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
    upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
    upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
    upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
    upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
    upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
    upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
    upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
    upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
    upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
    upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
    upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
    upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
    upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
    upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
    upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
    upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
    upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
    upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
    upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
    upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
    upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
    upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
    upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
    upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
    upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
    upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
    upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
    upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
    upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
    upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js static/js/2.b1d56998.chunk.js application/javascript
    upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.LICENSE.txt static/js/2.b1d56998.chunk.js.LICENSE.txt text/plain
    upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.map static/js/2.b1d56998.chunk.js.map application/json
    upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js static/js/main.034751df.chunk.js application/javascript
    upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js.map static/js/main.034751df.chunk.js.map application/json
    upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js static/js/runtime-main.7278cf1c.js application/javascript
    upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js.map static/js/runtime-main.7278cf1c.js.map application/json
    upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
    upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
    host.iobroker.esxi Adapter "system.adapter.web.0" is started
      @manmac1 sagte in Adapter Aktualisierung funktioniert nicht:
      bitte erst das andere mir zeigen was ich dir oben gepostet habe !!
      danach
      cd /opt/iobroker/node_modules/openzwave-shared
      npm install --omit=dev
      manmac1
      schrieb am zuletzt editiert von manmac1
      @glasfaser said in Adapter Aktualisierung funktioniert nicht:
      iobroker@iobroker:~$ cd /opt/iobroker/node_modules/openzwave-shared
      iobroker@iobroker:/opt/iobroker/node_modules/openzwave-shared$ npm install --omit=dev
      > openzwave-shared@1.4.1 preinstall
      > node lib/install-ozw.js
      > openzwave-shared@1.4.1 install
      > node-gyp rebuild
      (node:14306) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
      gyp info spawn make
      In file included from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:192,
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Value>, v8::PropertyAttribute)’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_maybe_43_inl.h:112:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
        112 |   return obj->ForceSet(isolate->GetCurrentContext(), key, value, attribs);
      In file included from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters.h:59,
                       from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:197,
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase<v8::Boolean>::return_t Nan::imp::ToFactory<v8::Boolean>::convert(v8::Local<v8::Value>)’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters_43_inl.h:18:67: error: cannot convert ‘v8::Local<v8::Context>’ to ‘v8::Isolate*’
         18 |       val->To ## TYPE(v8::Isolate::GetCurrent()->GetCurrentContext())          \
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’
         22 | X(Boolean)
      In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-primitive.h:11,
                       from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:11,
                       from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-array-buffer.h:13,
                       from ../src/openzwave.hpp:26,
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-value.h:398:37: note:   initializing argument 1 of ‘v8::Local<v8::Boolean> v8::Value::ToBoolean(v8::Isolate*) const’
        398 |   Local<Boolean> ToBoolean(Isolate* isolate) const;
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase<bool>::return_t Nan::imp::ToFactory<bool>::convert(v8::Local<v8::Value>)’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters_43_inl.h:37:55: error: cannot convert ‘v8::Local<v8::Context>’ to ‘v8::Isolate*’
         37 |   return val->NAME ## Value(isolate->GetCurrentContext());                     \
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’
         40 | X(bool, Boolean)
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-value.h:408:30: note:   initializing argument 1 of ‘bool v8::Value::BooleanValue(v8::Isolate*) const’
        408 |   bool BooleanValue(Isolate* isolate) const;
      In file included from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_new.h:189,
                       from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:198,
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::Function>::return_t Nan::imp::Factory<v8::Function>::New(Nan::FunctionCallback, v8::Local<v8::Value>)’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_implementation_12_inl.h:103:42: error: cannot convert ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
        103 |   return scope.Escape(v8::Function::New( isolate
            |                                          v8::Isolate*
      In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8.h:33,
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-function.h:33:22: note:   initializing argument 1 of ‘static v8::MaybeLocal<v8::Function> v8::Function::New(v8::Local<v8::Context>, v8::FunctionCallback, v8::Local<v8::Value>, int, v8::ConstructorBehavior, v8::SideEffectType)’
         33 |       Local<Context> context, FunctionCallback callback,
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::StringObject>::return_t Nan::imp::Factory<v8::StringObject>::New(v8::Local<v8::String>)’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_implementation_12_inl.h:337:37: error: no matching function for call to ‘v8::StringObject::New(v8::Local<v8::String>&)’
        337 |   return v8::StringObject::New(value).As<v8::StringObject>();
      In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8.h:47,
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-primitive-object.h:81:23: note: candidate: ‘static v8::Local<v8::Value> v8::StringObject::New(v8::Isolate*, v8::Local<v8::String>)’
         81 |   static Local<Value> New(Isolate* isolate, Local<String> value);
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-primitive-object.h:81:23: note:   candidate expects 2 arguments, 1 provided
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_implementation_12_inl.h:337:58: error: expected primary-expression before ‘>’ token
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_implementation_12_inl.h:337:60: error: expected primary-expression before ‘)’ token
      In file included from ../src/openzwave.hpp:27,
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:835:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
        835 |         v8::Isolate::GetCurrent(), target, func, argc, argv);
      In file included from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:49,
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/node.h:195:50: note: declared here
        195 |                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/node.h:112:42: note: in definition of macro ‘NODE_DEPRECATED’
        112 |     __attribute__((deprecated(message))) declarator
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:850:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
        850 |         v8::Isolate::GetCurrent(), target, symbol, argc, argv);
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/node.h:188:50: note: declared here
        188 |                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:865:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
        865 |         v8::Isolate::GetCurrent(), target, method, argc, argv);
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/node.h:181:50: note: declared here
        181 |                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:911:53: error: no matching function for call to ‘v8::Value::ToString()’
        911 |       v8::Local<v8::String> string = from->ToString();
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-value.h:360:44: note: candidate: ‘v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const’
        360 |   V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-value.h:360:44: note:   candidate expects 1 argument, 0 provided
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:921:37: error: cannot convert ‘char*’ to ‘v8::Isolate*’
        921 |         length_ = string->WriteUtf8(str_, static_cast<int>(len), 0, flags);
            |                                     char*
      In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:11,
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-primitive.h:202:26: note:   initializing argument 1 of ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’
        202 |   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1479:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
       1479 |     ));
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1533:64: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, const v8::Local<v8::Value>&)’
       1533 |     New(persistentHandle)->Set(New(key).ToLocalChecked(), value);
      In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-array-buffer.h:13,
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:244:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’
        244 |   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:244:37: note:   candidate expects 3 arguments, 2 provided
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:247:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’
        247 |   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:247:37: note:   candidate expects 3 arguments, 2 provided
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1539:42: error: no matching function for call to ‘v8::Object::Set(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’
       1539 |     New(persistentHandle)->Set(key, value);
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local<v8::Value>&)’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1545:44: error: no matching function for call to ‘v8::Object::Set(uint32_t&, const v8::Local<v8::Value>&)’
       1545 |     New(persistentHandle)->Set(index, value);
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const char*) const’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1551:61: error: no matching function for call to ‘v8::Object::Get(v8::Local<v8::String>)’
       1551 |         New(persistentHandle)->Get(New(key).ToLocalChecked()));
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:290:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’
        290 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:290:43: note:   candidate expects 2 arguments, 1 provided
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:293:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’
        293 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:293:43: note:   candidate expects 2 arguments, 1 provided
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const v8::Local<v8::String>&) const’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1557:55: error: no matching function for call to ‘v8::Object::Get(const v8::Local<v8::String>&)’
       1557 |     return scope.Escape(New(persistentHandle)->Get(key));
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1562:57: error: no matching function for call to ‘v8::Object::Get(uint32_t&)’
       1562 |     return scope.Escape(New(persistentHandle)->Get(index));
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1732:7: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       1732 |     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, Nan::GetterCallback, Nan::SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, Nan::imp::Sig)’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1977:16: warning: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>, v8::AccessorNameGetterCallback, v8::AccessorNameSetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, v8::Local<v8::AccessorSignature>, v8::SideEffectType, v8::SideEffectType)’ is deprecated: Do signature check in accessor [-Wdeprecated-declarations]
       1977 |     , signature);
      In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-function.h:15,
      /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-template.h:838:8: note: declared here
        838 |   void SetAccessor(
      In file included from /usr/include/c++/10/cassert:44,
                       from /home/iobroker/.cache/node-gyp/18.16.0/include/node/node_object_wrap.h:26,
                       from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:51,
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
         24 |     assert(persistent().IsNearDeath());
      In file included from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:2222,
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_object_wrap.h:67:18: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘MarkIndependent’
         67 |     persistent().MarkIndependent();
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
        124 |     assert(wrap->handle_.IsNearDeath());
      In file included from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:2313,
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_typedarray_contents.h: In constructor ‘Nan::TypedArrayContents<T>::TypedArrayContents(v8::Local<v8::Value>)’:
      /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_typedarray_contents.h:34:43: error: ‘class v8::ArrayBuffer’ has no member named ‘GetContents’
         34 |       data   = static_cast<char*>(buffer->GetContents().Data()) + byte_offset;
      ../src/callbacks.cc: In function ‘void OZW::ozw_watcher_callback(const OpenZWave::Notification*, void*)’:
      ../src/callbacks.cc:80:37: warning: ‘uint8 OpenZWave::Notification::GetSceneId() const’ is deprecated [-Wdeprecated-declarations]
         80 |     notif->sceneid = cb->GetSceneId();
      In file included from ../src/openzwave.hpp:32,
      /usr/local/include/openzwave/Notification.h:232:21: note: declared here
        232 |    DEPRECATED uint8 GetSceneId() const
      make: *** [openzwave_shared.target.mk:136: Release/obj.target/openzwave_shared/src/callbacks.o] Fehler 1
      gyp ERR! not ok
      npm notice
      npm notice New major version of npm available! 9.5.1 -> 10.0.0
      npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.0.0
      npm notice Run npm install -g npm@10.0.0 to update!
      npm notice
      npm ERR! code 1
      npm ERR!     /home/iobroker/.npm/_logs/2023-09-03T15_16_59_988Z-debug-0.log
      • M manmac1
        > node-gyp rebuild
        gyp info spawn make
           22 | X(Boolean)
              |                                          v8::Isolate*
              |                                     char*
         1479 |     ));
        gyp ERR! not ok
        npm notice
        npm notice
        npm ERR! code 1
        GlasfaserG Offline
        GlasfaserG Offline
        @manmac1
        so , jetzt nochmal zeigen
          @manmac1
          manmac1
          iobroker@iobroker:/opt/iobroker/node_modules/openzwave-shared$ iobroker upgrade web@6.1.0 --debug
          -> 6.1.0:
          -> 6.0.3:
          Updated packages
          -> 6.0.1:
          -> 5.5.3:
          -> 5.5.2:
          -> 5.5.1:
          -> 5.5.0:
          NPM version: 9.5.1
          npm ERR! code 1
          npm ERR! (node:25266) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
          npm ERR!       |                                                  ^
          npm ERR!       |                                                               ^~~~~~~
          npm ERR!     /home/iobroker/.npm/_logs/2023-09-03T15_19_10_771Z-debug-0.log
          • M manmac1
            habs nochmal rauskopiert:
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Architecture    : x86_64
            Docker          : false
            Virtualization  : vmware
            Distributor ID: Debian
            Description:    Debian GNU/Linux 11 (bullseye)
            Release:        11
            Codename:       bullseye
            PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
            NAME="Debian GNU/Linux"
            VERSION_ID="11"
            VERSION="11 (bullseye)"
            VERSION_CODENAME=bullseye
            ID=debian
            HOME_URL="https://www.debian.org/"
            SUPPORT_URL="https://www.debian.org/support"
            BUG_REPORT_URL="https://bugs.debian.org/"
            Systemuptime and Load:
             16:56:43 up 15:03,  3 users,  load average: 0.29, 0.52, 0.52
            CPU threads: 2
            *** Time and Time Zones ***
                           Local time: Sun 2023-09-03 16:56:43 CEST
                       Universal time: Sun 2023-09-03 14:56:43 UTC
                             RTC time: Sun 2023-09-03 14:56:43
                            Time zone: Europe/Vienna (CEST, +0200)
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            iobroker
            /home/iobroker
            iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev bluetooth
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            7.9G        2.5G        2.8G        0.0K        2.7G        5.5G
            Swap:           2.0G          0B        2.0G
            Total:            9G        2.5G        4.8G
                     7945 M total memory
                     2456 M used memory
                     1277 M active memory
                     3294 M inactive memory
                     2783 M free memory
                      409 M buffer memory
                     2295 M swap cache
                     2044 M total swap
                        0 M used swap
                     2044 M free swap
            *** FILESYSTEM ***
            udev           devtmpfs  3.9G     0  3.9G   0% /dev
            tmpfs          tmpfs     795M  736K  794M   1% /run
            /dev/sda1      ext4       30G   16G   13G  55% /
            tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
            tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
            tmpfs          tmpfs     795M  4.0K  795M   1% /run/user/1000
            [Sun Sep  3 01:53:08 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
            [Sun Sep  3 01:53:09 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
            TARGET SOURCE    FSTYPE OPTIONS
            /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
            /var:
            2.8G    /var/
            1.5G    /var/cache/apt
            1.5G    /var/cache
            1.4G    /var/cache/apt/archives
            823M    /var/lib
            Archived and active journals take up 32.0M in the file system.
            /opt/iobroker/backups:
            360M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            2.4G    /opt/iobroker/iobroker-data/
            1.9G    /opt/iobroker/iobroker-data/sonosCache
            332M    /opt/iobroker/iobroker-data/files
            152M    /opt/iobroker/iobroker-data/backup-objects
            53M     /opt/iobroker/iobroker-data/files/javascript.admin
            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
            19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
            15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
            13M     /opt/iobroker/iobroker-data/objects.jsonl
            11M     /opt/iobroker/iobroker-data/objects.json.migrated
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.16.0
            /usr/bin/node           v18.16.0
            /usr/bin/npm            9.5.1
            /usr/bin/npx            9.5.1
            nodejs:
              Installed: 18.16.0-deb-1nodesource1
              Candidate: 18.17.1-deb-1nodesource1
              Version table:
                 18.17.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
             *** 18.16.0-deb-1nodesource1 100
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                 12.22.12~dfsg-1~deb11u3 500
                    500 http://deb.debian.org/debian bullseye/main amd64 Packages
            No problems detected
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  4.0.24
            admin:          6.3.5
            javascript:     7.0.3
            npm ERR! code ELSPROBLEMS
            npm ERR! extraneous: @harmonyhub/discover@1.0.5 /opt/iobroker/node_modules/@harmonyhub/discover
            npm ERR! extraneous: @iobroker/adapter-core@1.0.1 /opt/iobroker/node_modules/@iobroker/adapter-core
            npm ERR! extraneous: @node-red/editor-api@0.20.7 /opt/iobroker/node_modules/@node-red/editor-api
            npm ERR! extraneous: @node-red/editor-client@0.20.7 /opt/iobroker/node_modules/@node-red/editor-client
            npm ERR! extraneous: @node-red/nodes@0.20.7 /opt/iobroker/node_modules/@node-red/nodes
            npm ERR! extraneous: @node-red/registry@0.20.7 /opt/iobroker/node_modules/@node-red/registry
            npm ERR! extraneous: @node-red/runtime@0.20.7 /opt/iobroker/node_modules/@node-red/runtime
            npm ERR! extraneous: @node-red/util@0.20.7 /opt/iobroker/node_modules/@node-red/util
            npm ERR! extraneous: @types/form-data@2.2.1 /opt/iobroker/node_modules/@types/form-data
            npm ERR! extraneous: @types/iobroker@1.4.0 /opt/iobroker/node_modules/@types/iobroker
            npm ERR! extraneous: @types/request@2.48.1 /opt/iobroker/node_modules/@types/request
            npm ERR! extraneous: agent-base@4.3.0 /opt/iobroker/node_modules/agent-base
            npm ERR! extraneous: alcalzone-shared@1.4.0 /opt/iobroker/node_modules/alcalzone-shared
            npm ERR! extraneous: alexa-cookie2@2.1.0 /opt/iobroker/node_modules/alexa-cookie2
            npm ERR! extraneous: alexa-remote2@2.5.5 /opt/iobroker/node_modules/alexa-remote2
            npm ERR! extraneous: asap@2.0.6 /opt/iobroker/node_modules/asap
            npm ERR! extraneous: async@2.5.0 /opt/iobroker/node_modules/async
            npm ERR! extraneous: autobind-decorator@2.4.0 /opt/iobroker/node_modules/autobind-decorator
            npm ERR! extraneous: aws-iot-device-sdk@2.2.1 /opt/iobroker/node_modules/aws-iot-device-sdk
            npm ERR! extraneous: axios@0.15.3 /opt/iobroker/node_modules/axios
            npm ERR! extraneous: base64url@2.0.0 /opt/iobroker/node_modules/base64url
            npm ERR! extraneous: binrpc@1.0.0 /opt/iobroker/node_modules/binrpc
            npm ERR! extraneous: bson@1.1.1 /opt/iobroker/node_modules/bson
            npm ERR! extraneous: buffer-crc32@0.2.13 /opt/iobroker/node_modules/buffer-crc32
            npm ERR! extraneous: callback-stream@1.1.0 /opt/iobroker/node_modules/callback-stream
            npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/chalk
            npm ERR! extraneous: cheerio@1.0.0-rc.3 /opt/iobroker/node_modules/cheerio
            npm ERR! extraneous: cls-bluebird@1.1.3 /opt/iobroker/node_modules/cls-bluebird
            npm ERR! extraneous: commander@2.11.0 /opt/iobroker/node_modules/commander
            npm ERR! extraneous: cron@1.7.1 /opt/iobroker/node_modules/cron
            npm ERR! extraneous: crypto-js@3.1.6 /opt/iobroker/node_modules/crypto-js
            npm ERR! extraneous: deep-extend@0.4.2 /opt/iobroker/node_modules/deep-extend
            npm ERR! extraneous: dicer@0.2.5 /opt/iobroker/node_modules/dicer
            npm ERR! extraneous: dotenv@4.0.0 /opt/iobroker/node_modules/dotenv
            npm ERR! extraneous: epoll@0.1.22 /opt/iobroker/node_modules/epoll
            npm ERR! extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
            npm ERR! extraneous: es6-set@0.1.5 /opt/iobroker/node_modules/es6-set
            npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/escape-string-regexp
            npm ERR! extraneous: event-emitter@0.3.5 /opt/iobroker/node_modules/event-emitter
            npm ERR! extraneous: eventemitter3@2.0.3 /opt/iobroker/node_modules/eventemitter3
            npm ERR! extraneous: express-fileupload@0.1.4 /opt/iobroker/node_modules/express-fileupload
            npm ERR! extraneous: express-session@1.16.2 /opt/iobroker/node_modules/express-session
            npm ERR! extraneous: express@4.16.2 /opt/iobroker/node_modules/express
            npm ERR! extraneous: extract-zip@1.7.0 /opt/iobroker/node_modules/extract-zip
            npm ERR! extraneous: fd-slicer@1.1.0 /opt/iobroker/node_modules/fd-slicer
            npm ERR! extraneous: finalhandler@1.1.0 /opt/iobroker/node_modules/finalhandler
            npm ERR! extraneous: fs-extra@0.22.1 /opt/iobroker/node_modules/fs-extra
            npm ERR! extraneous: fs-minipass@1.2.3 /opt/iobroker/node_modules/fs-minipass
            npm ERR! extraneous: generate-function@2.0.0 /opt/iobroker/node_modules/generate-function
            npm ERR! extraneous: generate-object-property@1.2.0 /opt/iobroker/node_modules/generate-object-property
            npm ERR! extraneous: glob-parent@3.1.0 /opt/iobroker/node_modules/glob-parent
            npm ERR! extraneous: glob-stream@6.1.0 /opt/iobroker/node_modules/glob-stream
            npm ERR! extraneous: harmonyhubws@1.0.4 /opt/iobroker/node_modules/harmonyhubws
            npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/has-flag
            npm ERR! extraneous: hasha@2.2.0 /opt/iobroker/node_modules/hasha
            npm ERR! extraneous: homematic-manager@1.0.14 /opt/iobroker/node_modules/homematic-manager
            npm ERR! extraneous: http-proxy-middleware@0.19.1 /opt/iobroker/node_modules/http-proxy-middleware
            npm ERR! extraneous: https-proxy-agent@2.2.1 /opt/iobroker/node_modules/https-proxy-agent
            npm ERR! extraneous: i18next@15.1.0 /opt/iobroker/node_modules/i18next
            npm ERR! extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/ignore-walk
            npm ERR! extraneous: imap@0.8.19 /opt/iobroker/node_modules/imap
            npm ERR! extraneous: io-packages.json@ /opt/iobroker/node_modules/io-packages.json
            npm ERR! missing: iobroker.geofency@^1.0.3, required by iobroker@1.0.0
            npm ERR! extraneous: iobroker.hmm@1.0.1 /opt/iobroker/node_modules/iobroker.hmm
            npm ERR! extraneous: iobroker.icons-icons8@0.0.1 /opt/iobroker/node_modules/iobroker.icons-icons8
            npm ERR! extraneous: iobroker.rp2@ /opt/iobroker/node_modules/iobroker.rp2
            npm ERR! extraneous: iobroker.type-detector@0.1.1 /opt/iobroker/node_modules/iobroker.type-detector
            npm ERR! extraneous: iobroker.vis-bars@0.1.4 /opt/iobroker/node_modules/iobroker.vis-bars
            npm ERR! extraneous: iobroker.vis-fancyswitch@1.1.0 /opt/iobroker/node_modules/iobroker.vis-fancyswitch
            npm ERR! extraneous: iobroker@1.0.2 /opt/iobroker/node_modules/iobroker
            npm ERR! extraneous: ipaddr.js@1.5.2 /opt/iobroker/node_modules/ipaddr.js
            npm ERR! extraneous: is-bluebird@1.0.2 /opt/iobroker/node_modules/is-bluebird
            npm ERR! extraneous: is-buffer@2.0.4 /opt/iobroker/node_modules/is-buffer
            npm ERR! extraneous: is-my-json-valid@2.16.1 /opt/iobroker/node_modules/is-my-json-valid
            npm ERR! extraneous: is-negated-glob@1.0.0 /opt/iobroker/node_modules/is-negated-glob
            npm ERR! extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
            npm ERR! extraneous: is-stream@1.1.0 /opt/iobroker/node_modules/is-stream
            npm ERR! extraneous: isemail@1.2.0 /opt/iobroker/node_modules/isemail
            npm ERR! extraneous: joi@6.10.1 /opt/iobroker/node_modules/joi
            npm ERR! extraneous: js-yaml@3.13.1 /opt/iobroker/node_modules/js-yaml
            npm ERR! extraneous: js2xmlparser@3.0.0 /opt/iobroker/node_modules/js2xmlparser
            npm ERR! extraneous: json-stable-stringify-without-jsonify@1.0.1 /opt/iobroker/node_modules/json-stable-stringify-without-jsonify
            npm ERR! extraneous: jsonata@1.6.5 /opt/iobroker/node_modules/jsonata
            npm ERR! extraneous: jsonfile@2.4.0 /opt/iobroker/node_modules/jsonfile
            npm ERR! extraneous: jsonpointer@4.0.1 /opt/iobroker/node_modules/jsonpointer
            npm ERR! extraneous: jsonwebtoken@8.1.1 /opt/iobroker/node_modules/jsonwebtoken
            npm ERR! extraneous: jws@3.1.4 /opt/iobroker/node_modules/jws
            npm ERR! extraneous: kew@0.7.0 /opt/iobroker/node_modules/kew
            npm ERR! extraneous: klaw@1.3.1 /opt/iobroker/node_modules/klaw
            npm ERR! extraneous: libbase64@1.0.3 /opt/iobroker/node_modules/libbase64
            npm ERR! extraneous: libmime@4.1.1 /opt/iobroker/node_modules/libmime
            npm ERR! extraneous: libqp@1.1.0 /opt/iobroker/node_modules/libqp
            npm ERR! extraneous: linkify-it@2.1.0 /opt/iobroker/node_modules/linkify-it
            npm ERR! extraneous: mailparser@2.7.1 /opt/iobroker/node_modules/mailparser
            npm ERR! extraneous: mailsplit@4.4.1 /opt/iobroker/node_modules/mailsplit
            npm ERR! extraneous: memorystore@1.6.1 /opt/iobroker/node_modules/memorystore
            npm ERR! extraneous: minipass@2.2.1 /opt/iobroker/node_modules/minipass
            npm ERR! extraneous: minizlib@1.0.4 /opt/iobroker/node_modules/minizlib
            npm ERR! extraneous: mongodb@3.3.0 /opt/iobroker/node_modules/mongodb
            npm ERR! extraneous: multer@1.4.1 /opt/iobroker/node_modules/multer
            npm ERR! extraneous: mustache@3.0.1 /opt/iobroker/node_modules/mustache
            npm ERR! extraneous: needle@2.9.1 /opt/iobroker/node_modules/needle
            npm ERR! extraneous: net-snmp@1.2.4 /opt/iobroker/node_modules/net-snmp
            npm ERR! extraneous: node-abi@2.15.0 /opt/iobroker/node_modules/node-abi
            npm ERR! extraneous: node-disk-info@ /opt/iobroker/node_modules/node-disk-info
            npm ERR! extraneous: node-hue-api@2.4.2 /opt/iobroker/node_modules/node-hue-api
            npm ERR! extraneous: node-ical@0.5.4 /opt/iobroker/node_modules/node-ical
            npm ERR! extraneous: node-red-contrib-polymer@0.0.21 /opt/iobroker/node_modules/node-red-contrib-polymer
            npm ERR! extraneous: node-red-dashboard@2.16.1 /opt/iobroker/node_modules/node-red-dashboard
            npm ERR! extraneous: node-red-node-email@1.6.2 /opt/iobroker/node_modules/node-red-node-email
            npm ERR! extraneous: node-red-node-feedparser@0.1.14 /opt/iobroker/node_modules/node-red-node-feedparser
            npm ERR! extraneous: node-red-node-rbe@0.2.5 /opt/iobroker/node_modules/node-red-node-rbe
            npm ERR! extraneous: node-red-node-sentiment@0.1.4 /opt/iobroker/node_modules/node-red-node-sentiment
            npm ERR! extraneous: node-red-node-tail@0.0.2 /opt/iobroker/node_modules/node-red-node-tail
            npm ERR! extraneous: node-red-node-twitter@1.1.5 /opt/iobroker/node_modules/node-red-node-twitter
            npm ERR! extraneous: node-red@0.20.7 /opt/iobroker/node_modules/node-red
            npm ERR! extraneous: node-ssdp@3.2.5 /opt/iobroker/node_modules/node-ssdp
            npm ERR! extraneous: node-static@0.7.11 /opt/iobroker/node_modules/node-static
            npm ERR! extraneous: node-telegram-bot-api@0.28.0 /opt/iobroker/node_modules/node-telegram-bot-api
            npm ERR! extraneous: nodemailer@6.3.0 /opt/iobroker/node_modules/nodemailer
            npm ERR! extraneous: noop-logger@0.1.1 /opt/iobroker/node_modules/noop-logger
            npm ERR! extraneous: npm-bundled@1.1.2 /opt/iobroker/node_modules/npm-bundled
            npm ERR! extraneous: npm-normalize-package-bin@1.0.1 /opt/iobroker/node_modules/npm-normalize-package-bin
            npm ERR! extraneous: npm-packlist@1.4.8 /opt/iobroker/node_modules/npm-packlist
            npm ERR! extraneous: object.assign@4.0.4 /opt/iobroker/node_modules/object.assign
            npm ERR! extraneous: openzwave-shared@1.4.1 /opt/iobroker/node_modules/openzwave-shared
            npm ERR! extraneous: optimist@0.6.1 /opt/iobroker/node_modules/optimist
            npm ERR! extraneous: ordered-read-streams@1.0.1 /opt/iobroker/node_modules/ordered-read-streams
            npm ERR! extraneous: parse5@3.0.3 /opt/iobroker/node_modules/parse5
            npm ERR! extraneous: passport@0.3.2 /opt/iobroker/node_modules/passport
            npm ERR! extraneous: path-dirname@1.0.2 /opt/iobroker/node_modules/path-dirname
            npm ERR! extraneous: pend@1.2.0 /opt/iobroker/node_modules/pend
            npm ERR! extraneous: poplib@0.1.7 /opt/iobroker/node_modules/poplib
            npm ERR! extraneous: prebuild-install@5.3.3 /opt/iobroker/node_modules/prebuild-install
            npm ERR! extraneous: progress@1.1.8 /opt/iobroker/node_modules/progress
            npm ERR! extraneous: promise@7.1.1 /opt/iobroker/node_modules/promise
            npm ERR! extraneous: proxy-addr@2.0.2 /opt/iobroker/node_modules/proxy-addr
            npm ERR! extraneous: pump@1.0.2 /opt/iobroker/node_modules/pump
            npm ERR! extraneous: pumpify@1.5.1 /opt/iobroker/node_modules/pumpify
            npm ERR! extraneous: request-progress@2.0.1 /opt/iobroker/node_modules/request-progress
            npm ERR! extraneous: request-promise-core@1.1.1 /opt/iobroker/node_modules/request-promise-core
            npm ERR! extraneous: request-promise-native@1.0.5 /opt/iobroker/node_modules/request-promise-native
            npm ERR! extraneous: request-promise@1.0.2 /opt/iobroker/node_modules/request-promise
            npm ERR! extraneous: require_optional@1.0.1 /opt/iobroker/node_modules/require_optional
            npm ERR! extraneous: resolve-from@2.0.0 /opt/iobroker/node_modules/resolve-from
            npm ERR! extraneous: rpi-gpio@0.7.0 /opt/iobroker/node_modules/rpi-gpio
            npm ERR! extraneous: rrule@2.2.0 /opt/iobroker/node_modules/rrule
            npm ERR! extraneous: semaphore@1.0.5 /opt/iobroker/node_modules/semaphore
            npm ERR! extraneous: serialport@4.0.7 /opt/iobroker/node_modules/serialport
            npm ERR! extraneous: shimmer@1.2.0 /opt/iobroker/node_modules/shimmer
            npm ERR! extraneous: sonos-discovery@1.1.3 /opt/iobroker/node_modules/sonos-discovery
            npm ERR! extraneous: sonos-web-controller@0.14.0 /opt/iobroker/node_modules/sonos-web-controller
            npm ERR! extraneous: sprintf-js@1.0.3 /opt/iobroker/node_modules/sprintf-js
            npm ERR! extraneous: streamifier@0.1.1 /opt/iobroker/node_modules/streamifier
            npm ERR! extraneous: suncalc@1.8.0 /opt/iobroker/node_modules/suncalc
            npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/supports-color
            npm ERR! extraneous: systeminformation@3.54.0 /opt/iobroker/node_modules/systeminformation
            npm ERR! extraneous: tail@2.2.4 /opt/iobroker/node_modules/tail
            npm ERR! extraneous: throttleit@1.0.0 /opt/iobroker/node_modules/throttleit
            npm ERR! extraneous: through2-filter@3.0.0 /opt/iobroker/node_modules/through2-filter
            npm ERR! extraneous: tlds@1.203.1 /opt/iobroker/node_modules/tlds
            npm ERR! extraneous: to-absolute-glob@2.0.2 /opt/iobroker/node_modules/to-absolute-glob
            npm ERR! extraneous: topo@1.1.0 /opt/iobroker/node_modules/topo
            npm ERR! extraneous: traits@0.4.0 /opt/iobroker/node_modules/traits
            npm ERR! extraneous: typescript@2.7.1 /opt/iobroker/node_modules/typescript
            npm ERR! extraneous: uc.micro@1.0.6 /opt/iobroker/node_modules/uc.micro
            npm ERR! extraneous: uglify-js@3.6.0 /opt/iobroker/node_modules/uglify-js
            npm ERR! extraneous: unique-stream@2.3.1 /opt/iobroker/node_modules/unique-stream
            npm ERR! extraneous: ursa-optional@0.9.8 /opt/iobroker/node_modules/ursa-optional
            npm ERR! extraneous: utf7@1.0.2 /opt/iobroker/node_modules/utf7
            npm ERR! extraneous: virtual-device-sdk@1.5.19 /opt/iobroker/node_modules/virtual-device-sdk
            npm ERR! extraneous: virtual-tsc@0.3.4 /opt/iobroker/node_modules/virtual-tsc
            npm ERR! extraneous: vm2@3.6.10 /opt/iobroker/node_modules/vm2
            npm ERR! extraneous: wake_on_lan@0.0.4 /opt/iobroker/node_modules/wake_on_lan
            npm ERR! extraneous: when@3.7.8 /opt/iobroker/node_modules/when
            npm ERR! extraneous: which-pm-runs@1.0.0 /opt/iobroker/node_modules/which-pm-runs
            npm ERR! extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
            npm ERR! extraneous: wordwrap@0.0.3 /opt/iobroker/node_modules/wordwrap
            npm ERR! extraneous: xmlbuilder@9.0.4 /opt/iobroker/node_modules/xmlbuilder
            npm ERR! extraneous: xmlcreate@1.0.2 /opt/iobroker/node_modules/xmlcreate
            npm ERR! extraneous: yauzl@2.10.0 /opt/iobroker/node_modules/yauzl
            npm ERR!     /home/iobroker/.npm/_logs/2023-09-03T14_56_53_179Z-debug-0.log
            Adapters from github:   0
            Adapter State
            + system.adapter.admin.0                  : admin                 : iobroker.esxi                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
            + system.adapter.alexa2.0                 : alexa2                : iobroker.esxi                            -  enabled
              system.adapter.backitup.0               : backitup              : iobroker.esxi                            - disabled
              system.adapter.cloud.0                  : cloud                 : iobroker.esxi                            - disabled
              system.adapter.devices.0                : devices               : iobroker.esxi                            -  enabled
              system.adapter.discovery.0              : discovery             : iobroker.esxi                            - disabled
              system.adapter.flot.0                   : flot                  : iobroker.esxi                            -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : iobroker.esxi                            -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker.esxi                            -  enabled, port: 0
            + system.adapter.hue.0                    : hue                   : iobroker.esxi                            -  enabled, port: 443
            + system.adapter.influxdb.0               : influxdb              : iobroker.esxi                            -  enabled, port: 8086
            + system.adapter.info.0                   : info                  : iobroker.esxi                            -  enabled
              system.adapter.iot.0                    : iot                   : iobroker.esxi                            - disabled
            + system.adapter.javascript.0             : javascript            : iobroker.esxi                            -  enabled
            + system.adapter.lametric.0               : lametric              : iobroker.esxi                            -  enabled
            + system.adapter.netatmo.0                : netatmo               : iobroker.esxi                            -  enabled
            + system.adapter.node-red.0               : node-red              : iobroker.esxi                            -  enabled, port: 1880, bind: 0.0.0.0 (SSL)
            + system.adapter.parser.0                 : parser                : iobroker.esxi                            -  enabled
            + system.adapter.sonos.0                  : sonos                 : iobroker.esxi                            -  enabled
            + system.adapter.systeminfo.0             : systeminfo            : iobroker.esxi                            -  enabled
            + system.adapter.telegram.0               : telegram              : iobroker.esxi                            -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.1               : telegram              : iobroker.esxi                            -  enabled, port: 8443, bind: 0.0.0.0
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker.esxi                            -  enabled
              system.adapter.vis.0                    : vis                   : iobroker.esxi                            -  enabled
            + system.adapter.web.0                    : web                   : iobroker.esxi                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.yahka.0                  : yahka                 : iobroker.esxi                            -  enabled
            + system.adapter.zwave2.0                 : zwave2                : iobroker.esxi                            -  enabled
            + instance is alive
            ioBroker-Repositories
            Stable (default): http://download.iobroker.net/sources-dist.json
            Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
            sources       : conf/sources-dist.json
            online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
            Installed ioBroker-Instances
            Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
            Adapter    "alexa2"       : 3.24.1   , installed 3.23.2 [Updatable]
            Adapter    "backitup"     : 2.6.23   , installed 2.4.9  [Updatable]
            Adapter    "ble"          : 0.13.4   , installed 0.13.0 [Updatable]
            Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
            Adapter    "cloud"        : 4.4.1    , installed 4.3.0  [Updatable]
            Adapter    "devices"      : 1.1.5    , installed 1.1.5
            Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
            Adapter    "frontier_silicon": 0.0.11, installed 0.0.10 [Updatable]
            Adapter    "harmony"      : 1.2.2    , installed 1.2.2
            Adapter    "history"      : 2.2.6    , installed 1.11.1 [Updatable]
            Adapter    "hm-rega"      : 3.0.47   , installed 3.0.46 [Updatable]
            Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.16 [Updatable]
            Adapter    "hue"          : 3.9.5    , installed 3.7.1  [Updatable]
            Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
            Adapter    "info"         : 1.9.26   , installed 1.9.19 [Updatable]
            Adapter    "iot"          : 1.14.5   , installed 1.14.2 [Updatable]
            Adapter    "javascript"   : 7.0.3    , installed 7.0.3
            Adapter    "lametric"     : 2.4.1    , installed 2.4.1
            Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
            Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
            Adapter    "node-red"     : 4.0.3    , installed 4.0.0  [Updatable]
            Adapter    "owfs"         : 0.7.0    , installed 0.7.0
            Adapter    "parser"       : 1.3.2    , installed 1.1.8  [Updatable]
            Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
            Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
            Adapter    "radar2"       : 2.0.7    , installed 2.0.3  [Updatable]
            Adapter    "shelly"       : 6.4.1    , installed 6.4.1
            Adapter    "snmp"         : 2.4.11   , installed 1.0.0  [Updatable]
            Adapter    "socketio"     : 6.5.2    , installed 4.2.0  [Updatable]
            Adapter    "sonos"        : 2.3.1    , installed 2.3.1
            Adapter    "systeminfo"   : 1.0.0    , installed 0.3.1  [Updatable]
            Adapter    "telegram"     : 1.16.0   , installed 1.15.6 [Updatable]
            Adapter    "vis-hqwidgets": 1.4.0    , installed 1.3.0  [Updatable]
            Adapter    "web"          : 6.1.0    , installed 4.3.0  [Updatable]
            Adapter    "ws"           : 2.5.3    , installed 1.3.0  [Updatable]
            Adapter    "yahka"        : 1.0.3    , installed 0.17.0 [Updatable]
            Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
            Objects and States
            Objects:        7546
            States:         7329
            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:2 http://deb.debian.org/debian bullseye InRelease
            Hit:3 http://security.debian.org/debian-security bullseye-security/updates InRelease
            Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:5 https://apt.grafana.com stable InRelease
            Hit:6 https://repos.influxdata.com/debian stable InRelease
            Hit:7 https://repos.influxdata.com/debian stretch InRelease
            Get:8 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
            Fetched 4586 B in 1s (7111 B/s)
            Reading package lists...
            Pending Updates: 10
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1711988    1801452/iobroker.js
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1711981    1801452/iobroker.js
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          9392       1/init
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12738      587/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       1714317    1801565/node-red
            tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        13256      900/influxd
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          14710      1245/exim4
            tcp        0      0 127.0.0.1:2010          0.0.0.0:*               LISTEN      1000       1715056    1801591/io.hm-rpc.0
            tcp        0      0 127.0.0.1:35931         0.0.0.0:*               LISTEN      1000       1718958    1802489/io.yahka.0
            tcp        0      0 127.0.0.1:39589         0.0.0.0:*               LISTEN      1000       1721109    1802489/io.yahka.0
            tcp6       0      0 :::111                  :::*                    LISTEN      0          9396       1/init
            tcp6       0      0 :::80                   :::*                    LISTEN      1000       1714319    1801565/node-red
            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1714058    1801470/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1729486    1811299/io.web.0
            tcp6       0      0 :::8086                 :::*                    LISTEN      999        15440      900/influxd
            tcp6       0      0 :::22                   :::*                    LISTEN      0          12749      587/sshd: /usr/sbin
            tcp6       0      0 :::45079                :::*                    LISTEN      1000       1718644    1802489/io.yahka.0
            tcp6       0      0 :::3000                 :::*                    LISTEN      107        14792      1253/grafana
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          14711      1245/exim4
            tcp6       0      0 :::38237                :::*                    LISTEN      1000       1718648    1802489/io.yahka.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1718649    1802489/io.yahka.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1718645    1802489/io.yahka.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1714320    1801565/node-red
            udp        0      0 198.18.10.12:1905       0.0.0.0:*                           1000       1758117    1801661/io.sonos.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12534      538/dhclient
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9393       1/init
            udp6       0      0 :::111                  :::*                                0          9399       1/init
            2023-09-03 16:45:18.264  - info: host.iobroker.esxi iobroker upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
            2023-09-03 16:45:18.266  - info: host.iobroker.esxi iobroker upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
            2023-09-03 16:45:18.268  - info: host.iobroker.esxi iobroker upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
            2023-09-03 16:45:18.270  - info: host.iobroker.esxi iobroker upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
            2023-09-03 16:45:18.272  - info: host.iobroker.esxi iobroker upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
            2023-09-03 16:45:18.274  - info: host.iobroker.esxi iobroker upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
            2023-09-03 16:45:18.278  - info: host.iobroker.esxi iobroker upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js static/js/2.b1d56998.chunk.js application/javascript
            2023-09-03 16:45:18.286  - info: host.iobroker.esxi iobroker upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.LICENSE.txt static/js/2.b1d56998.chunk.js.LICENSE.txt text/plain
            2023-09-03 16:45:18.324  - info: host.iobroker.esxi iobroker upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.map static/js/2.b1d56998.chunk.js.map application/json
            2023-09-03 16:45:18.570  - info: host.iobroker.esxi iobroker upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js static/js/main.034751df.chunk.js application/javascript
            2023-09-03 16:45:18.584  - info: host.iobroker.esxi iobroker upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js.map static/js/main.034751df.chunk.js.map application/json
            2023-09-03 16:45:18.587  - info: host.iobroker.esxi iobroker upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js static/js/runtime-main.7278cf1c.js application/javascript
            2023-09-03 16:45:18.590  - info: host.iobroker.esxi iobroker upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js.map static/js/runtime-main.7278cf1c.js.map application/json
            2023-09-03 16:45:18.593  - info: host.iobroker.esxi iobroker upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
            2023-09-03 16:45:18.596  - info: host.iobroker.esxi iobroker upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
            2023-09-03 16:45:18.600  - info: host.iobroker.esxi iobroker host.iobroker.esxi Adapter "system.adapter.web.0" is started
            2023-09-03 16:45:18.620  - info: host.iobroker.esxi "system.adapter.web.0" enabled
            2023-09-03 16:45:18.700  - info: host.iobroker.esxi instance system.adapter.web.0 started with pid 1811299
            2023-09-03 16:45:19.656  - info: host.iobroker.esxi iobroker exit 0
            2023-09-03 16:47:00.011  - info: javascript.0 (1801497) script.js.01_scripts.01_devices.bathroom.b_washingmachine: WM done?
            2023-09-03 16:47:01.174  - error: telegram.1 (1801535) Cannot send message [chatId -]: Error: ETELEGRAM: 403 Forbidden: user is deactivated
            2023-09-03 16:49:13.315  - info: host.iobroker.esxi Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
            2023-09-03 16:53:21.254  - info: host.iobroker.esxi "system.adapter.vis.0" disabled
            2023-09-03 16:53:21.276  - info: host.iobroker.esxi "system.adapter.vis.0" enabled
            2023-09-03 16:53:23.775  - info: host.iobroker.esxi instance system.adapter.vis.0 terminated while should be started once
            GlasfaserG Offline
            GlasfaserG Offline
            Nach deiner oberen Ausgabe wenn ich es mir genauer anschaue ,
            hast du früher sehr viel aus Github die Adapter gezogen .
            Das ist alles querbeet und seit Nodejs 16/18 wir genauer darauf geschaut.
            Ich wurde ein Backup nehmen und ioBroker neu aufsetzen , denn du bis seit Nodejs12 dabei.
            Meine Empfehlung !
            • GlasfaserG Glasfaser
              Meine Empfehlung !
              manmac1
              @glasfaser
              Hab ich mir vorhin auch schon gedacht. Hab etwas bammel ob ich das Backup und die Wiederherstellung auch so hinbekomme, dass sich an dem aktuellen Setup nichts verändert - ist mittlerweile doch sehr komplex ;) .
              • M manmac1
                @glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                Ich sehe da nichts von , sieht normal aus ,
                Meinst du deswegen :
                Dein :
                /usr/bin/npm 9.5.1
                /usr/bin/npx 9.5.1
                ist auch schon alt , Aktuell ist
                Wie gesagt , setze es neu auf ..
                aber bitte den Benutzer nicht iobroker nennen !
                  Dein :
                  /usr/bin/npm 9.5.1
                  /usr/bin/npx 9.5.1
                  manmac1
                  @glasfaser
                  ja, mach ich.
                  Hast du einen Tip für eine gute Anleitung?
                  Such grad nach dem richtigen Debian image für meine vm ;)
                  • M manmac1
                    @glasfaser
                    ja, mach ich.
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Hast du einen Tip
                    Auf Debian 12 Bookworm gehen
                      @manmac1 und dem root kein Passwort geben
                      • M manmac1
                        @glasfaser
                        ja, mach ich.
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @manmac1
                        Ich habe nochmal in Ruhe deine Angaben durchgelesen :
                        Ich habe gerade ein Großes ?
                        Im Eröffnungs Thread :
                        iobroker@iobroker:/opt/iobroker$ nodejs -v && node -v && npm -v
                        v18.17.1
                        v18.17.1
                        9.6.7
                        in der Ausgabe von iob diag
                        /usr/bin/npm 9.5.1
                        /usr/bin/npx 9.5.1
                        wie geht das denn !?
                          @manmac1
                          v18.17.1
                          v18.17.1
                          9.6.7
                          /usr/bin/npm 9.5.1
                          /usr/bin/npx 9.5.1
                          manmac1
                          @glasfaser
                          kommt wahrscheinlich daher, dass ich zwischendurch auf einen früheren Snapshot von heute zurücksteigen musste - sorry für die Verwirrung
                          GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                          • M manmac1
                            @glasfaser
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @manmac1
                            NUR zur INFO !
                            OK ... das ist natürlich Käse :(
                            Bitte ... wenn du etwas veränderst , hier immer alles mitteilen .
                            bzw .
                            Wie sollten wir hier helfen , wenn du zwischenzeitlich etwas anderes machst , was wir nicht wissen !?
                            Deshalb lese bitte auch das genau durch :
                            • M manmac1
                              @glasfaser
                              @manmac1
                              Dann räum zunächst mal die Quellen auf.
                              Schmeiß den Eintrag zu grafana/stretch raus.
                              Dann die Kiste auf Stand bringen, inkl. nodejs.
                              Solange openzwave nicht sauber kompiliert geht auch nichts mit anderen Adaptern. Warum es das nicht tut kann ich dir aber nicht sagen.
                              Vielleicht mal den cache löschen und/oder den Adapter dazu rauswerfen.
