  4. Adapter Aktualisierung funktioniert nicht
    5.2k
28 Beiträge 6 Kommentatoren 2.2k Aufrufe 6 Beobachtet
    @manmac1 sagte in Adapter Aktualisierung funktioniert nicht:
    @homoran meinst du die ELSPROBLEMS?
    nein,
    oder doch ??
    diexwaren doch eben och da
    Adapter State
                            *** Listening Ports ***
    und der Rest
    manmac1
    habs nochmal rauskopiert:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : vmware
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     16:56:43 up 15:03,  3 users,  load average: 0.29, 0.52, 0.52
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Sun 2023-09-03 16:56:43 CEST
               Universal time: Sun 2023-09-03 14:56:43 UTC
                     RTC time: Sun 2023-09-03 14:56:43
                    Time zone: Europe/Vienna (CEST, +0200)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    iobroker
    /home/iobroker
    iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev bluetooth
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.9G        2.5G        2.8G        0.0K        2.7G        5.5G
    Swap:           2.0G          0B        2.0G
    Total:            9G        2.5G        4.8G
             7945 M total memory
             2456 M used memory
             1277 M active memory
             3294 M inactive memory
             2783 M free memory
              409 M buffer memory
             2295 M swap cache
             2044 M total swap
                0 M used swap
             2044 M free swap
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     795M  736K  794M   1% /run
    /dev/sda1      ext4       30G   16G   13G  55% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     795M  4.0K  795M   1% /run/user/1000
    [Sun Sep  3 01:53:08 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Sep  3 01:53:09 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    2.8G    /var/
    1.5G    /var/cache/apt
    1.5G    /var/cache
    1.4G    /var/cache/apt/archives
    823M    /var/lib
    Archived and active journals take up 32.0M in the file system.
    /opt/iobroker/backups:
    360M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.4G    /opt/iobroker/iobroker-data/
    1.9G    /opt/iobroker/iobroker-data/sonosCache
    332M    /opt/iobroker/iobroker-data/files
    152M    /opt/iobroker/iobroker-data/backup-objects
    53M     /opt/iobroker/iobroker-data/files/javascript.admin
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    13M     /opt/iobroker/iobroker-data/objects.jsonl
    11M     /opt/iobroker/iobroker-data/objects.json.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
         18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
     *** 18.16.0-deb-1nodesource1 100
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @harmonyhub/discover@1.0.5 /opt/iobroker/node_modules/@harmonyhub/discover
    npm ERR! extraneous: @iobroker/adapter-core@1.0.1 /opt/iobroker/node_modules/@iobroker/adapter-core
    npm ERR! extraneous: @node-red/editor-api@0.20.7 /opt/iobroker/node_modules/@node-red/editor-api
    npm ERR! extraneous: @node-red/editor-client@0.20.7 /opt/iobroker/node_modules/@node-red/editor-client
    npm ERR! extraneous: @node-red/nodes@0.20.7 /opt/iobroker/node_modules/@node-red/nodes
    npm ERR! extraneous: @node-red/registry@0.20.7 /opt/iobroker/node_modules/@node-red/registry
    npm ERR! extraneous: @node-red/runtime@0.20.7 /opt/iobroker/node_modules/@node-red/runtime
    npm ERR! extraneous: @node-red/util@0.20.7 /opt/iobroker/node_modules/@node-red/util
    npm ERR! extraneous: @types/form-data@2.2.1 /opt/iobroker/node_modules/@types/form-data
    npm ERR! extraneous: @types/iobroker@1.4.0 /opt/iobroker/node_modules/@types/iobroker
    npm ERR! extraneous: @types/request@2.48.1 /opt/iobroker/node_modules/@types/request
    npm ERR! extraneous: agent-base@4.3.0 /opt/iobroker/node_modules/agent-base
    npm ERR! extraneous: alcalzone-shared@1.4.0 /opt/iobroker/node_modules/alcalzone-shared
    npm ERR! extraneous: alexa-cookie2@2.1.0 /opt/iobroker/node_modules/alexa-cookie2
    npm ERR! extraneous: alexa-remote2@2.5.5 /opt/iobroker/node_modules/alexa-remote2
    npm ERR! extraneous: asap@2.0.6 /opt/iobroker/node_modules/asap
    npm ERR! extraneous: async@2.5.0 /opt/iobroker/node_modules/async
    npm ERR! extraneous: autobind-decorator@2.4.0 /opt/iobroker/node_modules/autobind-decorator
    npm ERR! extraneous: aws-iot-device-sdk@2.2.1 /opt/iobroker/node_modules/aws-iot-device-sdk
    npm ERR! extraneous: axios@0.15.3 /opt/iobroker/node_modules/axios
    npm ERR! extraneous: base64url@2.0.0 /opt/iobroker/node_modules/base64url
    npm ERR! extraneous: binrpc@1.0.0 /opt/iobroker/node_modules/binrpc
    npm ERR! extraneous: bson@1.1.1 /opt/iobroker/node_modules/bson
    npm ERR! extraneous: buffer-crc32@0.2.13 /opt/iobroker/node_modules/buffer-crc32
    npm ERR! extraneous: callback-stream@1.1.0 /opt/iobroker/node_modules/callback-stream
    npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/chalk
    npm ERR! extraneous: cheerio@1.0.0-rc.3 /opt/iobroker/node_modules/cheerio
    npm ERR! extraneous: cls-bluebird@1.1.3 /opt/iobroker/node_modules/cls-bluebird
    npm ERR! extraneous: commander@2.11.0 /opt/iobroker/node_modules/commander
    npm ERR! extraneous: cron@1.7.1 /opt/iobroker/node_modules/cron
    npm ERR! extraneous: crypto-js@3.1.6 /opt/iobroker/node_modules/crypto-js
    npm ERR! extraneous: deep-extend@0.4.2 /opt/iobroker/node_modules/deep-extend
    npm ERR! extraneous: dicer@0.2.5 /opt/iobroker/node_modules/dicer
    npm ERR! extraneous: dotenv@4.0.0 /opt/iobroker/node_modules/dotenv
    npm ERR! extraneous: epoll@0.1.22 /opt/iobroker/node_modules/epoll
    npm ERR! extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
    npm ERR! extraneous: es6-set@0.1.5 /opt/iobroker/node_modules/es6-set
    npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/escape-string-regexp
    npm ERR! extraneous: event-emitter@0.3.5 /opt/iobroker/node_modules/event-emitter
    npm ERR! extraneous: eventemitter3@2.0.3 /opt/iobroker/node_modules/eventemitter3
    npm ERR! extraneous: express-fileupload@0.1.4 /opt/iobroker/node_modules/express-fileupload
    npm ERR! extraneous: express-session@1.16.2 /opt/iobroker/node_modules/express-session
    npm ERR! extraneous: express@4.16.2 /opt/iobroker/node_modules/express
    npm ERR! extraneous: extract-zip@1.7.0 /opt/iobroker/node_modules/extract-zip
    npm ERR! extraneous: fd-slicer@1.1.0 /opt/iobroker/node_modules/fd-slicer
    npm ERR! extraneous: finalhandler@1.1.0 /opt/iobroker/node_modules/finalhandler
    npm ERR! extraneous: fs-extra@0.22.1 /opt/iobroker/node_modules/fs-extra
    npm ERR! extraneous: fs-minipass@1.2.3 /opt/iobroker/node_modules/fs-minipass
    npm ERR! extraneous: generate-function@2.0.0 /opt/iobroker/node_modules/generate-function
    npm ERR! extraneous: generate-object-property@1.2.0 /opt/iobroker/node_modules/generate-object-property
    npm ERR! extraneous: glob-parent@3.1.0 /opt/iobroker/node_modules/glob-parent
    npm ERR! extraneous: glob-stream@6.1.0 /opt/iobroker/node_modules/glob-stream
    npm ERR! extraneous: harmonyhubws@1.0.4 /opt/iobroker/node_modules/harmonyhubws
    npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/has-flag
    npm ERR! extraneous: hasha@2.2.0 /opt/iobroker/node_modules/hasha
    npm ERR! extraneous: homematic-manager@1.0.14 /opt/iobroker/node_modules/homematic-manager
    npm ERR! extraneous: http-proxy-middleware@0.19.1 /opt/iobroker/node_modules/http-proxy-middleware
    npm ERR! extraneous: https-proxy-agent@2.2.1 /opt/iobroker/node_modules/https-proxy-agent
    npm ERR! extraneous: i18next@15.1.0 /opt/iobroker/node_modules/i18next
    npm ERR! extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/ignore-walk
    npm ERR! extraneous: imap@0.8.19 /opt/iobroker/node_modules/imap
    npm ERR! extraneous: io-packages.json@ /opt/iobroker/node_modules/io-packages.json
    npm ERR! missing: iobroker.geofency@^1.0.3, required by iobroker@1.0.0
    npm ERR! extraneous: iobroker.hmm@1.0.1 /opt/iobroker/node_modules/iobroker.hmm
    npm ERR! extraneous: iobroker.icons-icons8@0.0.1 /opt/iobroker/node_modules/iobroker.icons-icons8
    npm ERR! extraneous: iobroker.rp2@ /opt/iobroker/node_modules/iobroker.rp2
    npm ERR! extraneous: iobroker.type-detector@0.1.1 /opt/iobroker/node_modules/iobroker.type-detector
    npm ERR! extraneous: iobroker.vis-bars@0.1.4 /opt/iobroker/node_modules/iobroker.vis-bars
    npm ERR! extraneous: iobroker.vis-fancyswitch@1.1.0 /opt/iobroker/node_modules/iobroker.vis-fancyswitch
    npm ERR! extraneous: iobroker@1.0.2 /opt/iobroker/node_modules/iobroker
    npm ERR! extraneous: ipaddr.js@1.5.2 /opt/iobroker/node_modules/ipaddr.js
    npm ERR! extraneous: is-bluebird@1.0.2 /opt/iobroker/node_modules/is-bluebird
    npm ERR! extraneous: is-buffer@2.0.4 /opt/iobroker/node_modules/is-buffer
    npm ERR! extraneous: is-my-json-valid@2.16.1 /opt/iobroker/node_modules/is-my-json-valid
    npm ERR! extraneous: is-negated-glob@1.0.0 /opt/iobroker/node_modules/is-negated-glob
    npm ERR! extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
    npm ERR! extraneous: is-stream@1.1.0 /opt/iobroker/node_modules/is-stream
    npm ERR! extraneous: isemail@1.2.0 /opt/iobroker/node_modules/isemail
    npm ERR! extraneous: joi@6.10.1 /opt/iobroker/node_modules/joi
    npm ERR! extraneous: js-yaml@3.13.1 /opt/iobroker/node_modules/js-yaml
    npm ERR! extraneous: js2xmlparser@3.0.0 /opt/iobroker/node_modules/js2xmlparser
    npm ERR! extraneous: json-stable-stringify-without-jsonify@1.0.1 /opt/iobroker/node_modules/json-stable-stringify-without-jsonify
    npm ERR! extraneous: jsonata@1.6.5 /opt/iobroker/node_modules/jsonata
    npm ERR! extraneous: jsonfile@2.4.0 /opt/iobroker/node_modules/jsonfile
    npm ERR! extraneous: jsonpointer@4.0.1 /opt/iobroker/node_modules/jsonpointer
    npm ERR! extraneous: jsonwebtoken@8.1.1 /opt/iobroker/node_modules/jsonwebtoken
    npm ERR! extraneous: jws@3.1.4 /opt/iobroker/node_modules/jws
    npm ERR! extraneous: kew@0.7.0 /opt/iobroker/node_modules/kew
    npm ERR! extraneous: klaw@1.3.1 /opt/iobroker/node_modules/klaw
    npm ERR! extraneous: libbase64@1.0.3 /opt/iobroker/node_modules/libbase64
    npm ERR! extraneous: libmime@4.1.1 /opt/iobroker/node_modules/libmime
    npm ERR! extraneous: libqp@1.1.0 /opt/iobroker/node_modules/libqp
    npm ERR! extraneous: linkify-it@2.1.0 /opt/iobroker/node_modules/linkify-it
    npm ERR! extraneous: mailparser@2.7.1 /opt/iobroker/node_modules/mailparser
    npm ERR! extraneous: mailsplit@4.4.1 /opt/iobroker/node_modules/mailsplit
    npm ERR! extraneous: memorystore@1.6.1 /opt/iobroker/node_modules/memorystore
    npm ERR! extraneous: minipass@2.2.1 /opt/iobroker/node_modules/minipass
    npm ERR! extraneous: minizlib@1.0.4 /opt/iobroker/node_modules/minizlib
    npm ERR! extraneous: mongodb@3.3.0 /opt/iobroker/node_modules/mongodb
    npm ERR! extraneous: multer@1.4.1 /opt/iobroker/node_modules/multer
    npm ERR! extraneous: mustache@3.0.1 /opt/iobroker/node_modules/mustache
    npm ERR! extraneous: needle@2.9.1 /opt/iobroker/node_modules/needle
    npm ERR! extraneous: net-snmp@1.2.4 /opt/iobroker/node_modules/net-snmp
    npm ERR! extraneous: node-abi@2.15.0 /opt/iobroker/node_modules/node-abi
    npm ERR! extraneous: node-disk-info@ /opt/iobroker/node_modules/node-disk-info
    npm ERR! extraneous: node-hue-api@2.4.2 /opt/iobroker/node_modules/node-hue-api
    npm ERR! extraneous: node-ical@0.5.4 /opt/iobroker/node_modules/node-ical
    npm ERR! extraneous: node-red-contrib-polymer@0.0.21 /opt/iobroker/node_modules/node-red-contrib-polymer
    npm ERR! extraneous: node-red-dashboard@2.16.1 /opt/iobroker/node_modules/node-red-dashboard
    npm ERR! extraneous: node-red-node-email@1.6.2 /opt/iobroker/node_modules/node-red-node-email
    npm ERR! extraneous: node-red-node-feedparser@0.1.14 /opt/iobroker/node_modules/node-red-node-feedparser
    npm ERR! extraneous: node-red-node-rbe@0.2.5 /opt/iobroker/node_modules/node-red-node-rbe
    npm ERR! extraneous: node-red-node-sentiment@0.1.4 /opt/iobroker/node_modules/node-red-node-sentiment
    npm ERR! extraneous: node-red-node-tail@0.0.2 /opt/iobroker/node_modules/node-red-node-tail
    npm ERR! extraneous: node-red-node-twitter@1.1.5 /opt/iobroker/node_modules/node-red-node-twitter
    npm ERR! extraneous: node-red@0.20.7 /opt/iobroker/node_modules/node-red
    npm ERR! extraneous: node-ssdp@3.2.5 /opt/iobroker/node_modules/node-ssdp
    npm ERR! extraneous: node-static@0.7.11 /opt/iobroker/node_modules/node-static
    npm ERR! extraneous: node-telegram-bot-api@0.28.0 /opt/iobroker/node_modules/node-telegram-bot-api
    npm ERR! extraneous: nodemailer@6.3.0 /opt/iobroker/node_modules/nodemailer
    npm ERR! extraneous: noop-logger@0.1.1 /opt/iobroker/node_modules/noop-logger
    npm ERR! extraneous: npm-bundled@1.1.2 /opt/iobroker/node_modules/npm-bundled
    npm ERR! extraneous: npm-normalize-package-bin@1.0.1 /opt/iobroker/node_modules/npm-normalize-package-bin
    npm ERR! extraneous: npm-packlist@1.4.8 /opt/iobroker/node_modules/npm-packlist
    npm ERR! extraneous: object.assign@4.0.4 /opt/iobroker/node_modules/object.assign
    npm ERR! extraneous: openzwave-shared@1.4.1 /opt/iobroker/node_modules/openzwave-shared
    npm ERR! extraneous: optimist@0.6.1 /opt/iobroker/node_modules/optimist
    npm ERR! extraneous: ordered-read-streams@1.0.1 /opt/iobroker/node_modules/ordered-read-streams
    npm ERR! extraneous: parse5@3.0.3 /opt/iobroker/node_modules/parse5
    npm ERR! extraneous: passport@0.3.2 /opt/iobroker/node_modules/passport
    npm ERR! extraneous: path-dirname@1.0.2 /opt/iobroker/node_modules/path-dirname
    npm ERR! extraneous: pend@1.2.0 /opt/iobroker/node_modules/pend
    npm ERR! extraneous: poplib@0.1.7 /opt/iobroker/node_modules/poplib
    npm ERR! extraneous: prebuild-install@5.3.3 /opt/iobroker/node_modules/prebuild-install
    npm ERR! extraneous: progress@1.1.8 /opt/iobroker/node_modules/progress
    npm ERR! extraneous: promise@7.1.1 /opt/iobroker/node_modules/promise
    npm ERR! extraneous: proxy-addr@2.0.2 /opt/iobroker/node_modules/proxy-addr
    npm ERR! extraneous: pump@1.0.2 /opt/iobroker/node_modules/pump
    npm ERR! extraneous: pumpify@1.5.1 /opt/iobroker/node_modules/pumpify
    npm ERR! extraneous: request-progress@2.0.1 /opt/iobroker/node_modules/request-progress
    npm ERR! extraneous: request-promise-core@1.1.1 /opt/iobroker/node_modules/request-promise-core
    npm ERR! extraneous: request-promise-native@1.0.5 /opt/iobroker/node_modules/request-promise-native
    npm ERR! extraneous: request-promise@1.0.2 /opt/iobroker/node_modules/request-promise
    npm ERR! extraneous: require_optional@1.0.1 /opt/iobroker/node_modules/require_optional
    npm ERR! extraneous: resolve-from@2.0.0 /opt/iobroker/node_modules/resolve-from
    npm ERR! extraneous: rpi-gpio@0.7.0 /opt/iobroker/node_modules/rpi-gpio
    npm ERR! extraneous: rrule@2.2.0 /opt/iobroker/node_modules/rrule
    npm ERR! extraneous: semaphore@1.0.5 /opt/iobroker/node_modules/semaphore
    npm ERR! extraneous: serialport@4.0.7 /opt/iobroker/node_modules/serialport
    npm ERR! extraneous: shimmer@1.2.0 /opt/iobroker/node_modules/shimmer
    npm ERR! extraneous: sonos-discovery@1.1.3 /opt/iobroker/node_modules/sonos-discovery
    npm ERR! extraneous: sonos-web-controller@0.14.0 /opt/iobroker/node_modules/sonos-web-controller
    npm ERR! extraneous: sprintf-js@1.0.3 /opt/iobroker/node_modules/sprintf-js
    npm ERR! extraneous: streamifier@0.1.1 /opt/iobroker/node_modules/streamifier
    npm ERR! extraneous: suncalc@1.8.0 /opt/iobroker/node_modules/suncalc
    npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/supports-color
    npm ERR! extraneous: systeminformation@3.54.0 /opt/iobroker/node_modules/systeminformation
    npm ERR! extraneous: tail@2.2.4 /opt/iobroker/node_modules/tail
    npm ERR! extraneous: throttleit@1.0.0 /opt/iobroker/node_modules/throttleit
    npm ERR! extraneous: through2-filter@3.0.0 /opt/iobroker/node_modules/through2-filter
    npm ERR! extraneous: tlds@1.203.1 /opt/iobroker/node_modules/tlds
    npm ERR! extraneous: to-absolute-glob@2.0.2 /opt/iobroker/node_modules/to-absolute-glob
    npm ERR! extraneous: topo@1.1.0 /opt/iobroker/node_modules/topo
    npm ERR! extraneous: traits@0.4.0 /opt/iobroker/node_modules/traits
    npm ERR! extraneous: typescript@2.7.1 /opt/iobroker/node_modules/typescript
    npm ERR! extraneous: uc.micro@1.0.6 /opt/iobroker/node_modules/uc.micro
    npm ERR! extraneous: uglify-js@3.6.0 /opt/iobroker/node_modules/uglify-js
    npm ERR! extraneous: unique-stream@2.3.1 /opt/iobroker/node_modules/unique-stream
    npm ERR! extraneous: ursa-optional@0.9.8 /opt/iobroker/node_modules/ursa-optional
    npm ERR! extraneous: utf7@1.0.2 /opt/iobroker/node_modules/utf7
    npm ERR! extraneous: virtual-device-sdk@1.5.19 /opt/iobroker/node_modules/virtual-device-sdk
    npm ERR! extraneous: virtual-tsc@0.3.4 /opt/iobroker/node_modules/virtual-tsc
    npm ERR! extraneous: vm2@3.6.10 /opt/iobroker/node_modules/vm2
    npm ERR! extraneous: wake_on_lan@0.0.4 /opt/iobroker/node_modules/wake_on_lan
    npm ERR! extraneous: when@3.7.8 /opt/iobroker/node_modules/when
    npm ERR! extraneous: which-pm-runs@1.0.0 /opt/iobroker/node_modules/which-pm-runs
    npm ERR! extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
    npm ERR! extraneous: wordwrap@0.0.3 /opt/iobroker/node_modules/wordwrap
    npm ERR! extraneous: xmlbuilder@9.0.4 /opt/iobroker/node_modules/xmlbuilder
    npm ERR! extraneous: xmlcreate@1.0.2 /opt/iobroker/node_modules/xmlcreate
    npm ERR! extraneous: yauzl@2.10.0 /opt/iobroker/node_modules/yauzl
    npm ERR!     /home/iobroker/.npm/_logs/2023-09-03T14_56_53_179Z-debug-0.log
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker.esxi                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker.esxi                            -  enabled
      system.adapter.backitup.0               : backitup              : iobroker.esxi                            - disabled
      system.adapter.cloud.0                  : cloud                 : iobroker.esxi                            - disabled
      system.adapter.devices.0                : devices               : iobroker.esxi                            -  enabled
      system.adapter.discovery.0              : discovery             : iobroker.esxi                            - disabled
      system.adapter.flot.0                   : flot                  : iobroker.esxi                            -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker.esxi                            -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker.esxi                            -  enabled, port: 0
    + system.adapter.hue.0                    : hue                   : iobroker.esxi                            -  enabled, port: 443
    + system.adapter.influxdb.0               : influxdb              : iobroker.esxi                            -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker.esxi                            -  enabled
      system.adapter.iot.0                    : iot                   : iobroker.esxi                            - disabled
    + system.adapter.javascript.0             : javascript            : iobroker.esxi                            -  enabled
    + system.adapter.lametric.0               : lametric              : iobroker.esxi                            -  enabled
    + system.adapter.netatmo.0                : netatmo               : iobroker.esxi                            -  enabled
    + system.adapter.node-red.0               : node-red              : iobroker.esxi                            -  enabled, port: 1880, bind: 0.0.0.0 (SSL)
    + system.adapter.parser.0                 : parser                : iobroker.esxi                            -  enabled
    + system.adapter.sonos.0                  : sonos                 : iobroker.esxi                            -  enabled
    + system.adapter.systeminfo.0             : systeminfo            : iobroker.esxi                            -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker.esxi                            -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker.esxi                            -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker.esxi                            -  enabled
      system.adapter.vis.0                    : vis                   : iobroker.esxi                            -  enabled
    + system.adapter.web.0                    : web                   : iobroker.esxi                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : iobroker.esxi                            -  enabled
    + system.adapter.zwave2.0                 : zwave2                : iobroker.esxi                            -  enabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    sources       : conf/sources-dist.json
    online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
    Adapter    "alexa2"       : 3.24.1   , installed 3.23.2 [Updatable]
    Adapter    "backitup"     : 2.6.23   , installed 2.4.9  [Updatable]
    Adapter    "ble"          : 0.13.4   , installed 0.13.0 [Updatable]
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "cloud"        : 4.4.1    , installed 4.3.0  [Updatable]
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
    Adapter    "frontier_silicon": 0.0.11, installed 0.0.10 [Updatable]
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "history"      : 2.2.6    , installed 1.11.1 [Updatable]
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.46 [Updatable]
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.16 [Updatable]
    Adapter    "hue"          : 3.9.5    , installed 3.7.1  [Updatable]
    Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
    Adapter    "info"         : 1.9.26   , installed 1.9.19 [Updatable]
    Adapter    "iot"          : 1.14.5   , installed 1.14.2 [Updatable]
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "lametric"     : 2.4.1    , installed 2.4.1
    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "node-red"     : 4.0.3    , installed 4.0.0  [Updatable]
    Adapter    "owfs"         : 0.7.0    , installed 0.7.0
    Adapter    "parser"       : 1.3.2    , installed 1.1.8  [Updatable]
    Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
    Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
    Adapter    "radar2"       : 2.0.7    , installed 2.0.3  [Updatable]
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "snmp"         : 2.4.11   , installed 1.0.0  [Updatable]
    Adapter    "socketio"     : 6.5.2    , installed 4.2.0  [Updatable]
    Adapter    "sonos"        : 2.3.1    , installed 2.3.1
    Adapter    "systeminfo"   : 1.0.0    , installed 0.3.1  [Updatable]
    Adapter    "telegram"     : 1.16.0   , installed 1.15.6 [Updatable]
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.3.0  [Updatable]
    Adapter    "web"          : 6.1.0    , installed 4.3.0  [Updatable]
    Adapter    "ws"           : 2.5.3    , installed 1.3.0  [Updatable]
    Adapter    "yahka"        : 1.0.3    , installed 0.17.0 [Updatable]
    Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
    Objects and States
    Objects:        7546
    States:         7329
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security/updates InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 https://repos.influxdata.com/debian stable InRelease
    Hit:7 https://repos.influxdata.com/debian stretch InRelease
    Get:8 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
    Fetched 4586 B in 1s (7111 B/s)
    Reading package lists...
    Pending Updates: 10
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1711988    1801452/iobroker.js
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1711981    1801452/iobroker.js
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          9392       1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12738      587/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       1714317    1801565/node-red
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        13256      900/influxd
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          14710      1245/exim4
    tcp        0      0 127.0.0.1:2010          0.0.0.0:*               LISTEN      1000       1715056    1801591/io.hm-rpc.0
    tcp        0      0 127.0.0.1:35931         0.0.0.0:*               LISTEN      1000       1718958    1802489/io.yahka.0
    tcp        0      0 127.0.0.1:39589         0.0.0.0:*               LISTEN      1000       1721109    1802489/io.yahka.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          9396       1/init
    tcp6       0      0 :::80                   :::*                    LISTEN      1000       1714319    1801565/node-red
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1714058    1801470/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1729486    1811299/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        15440      900/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12749      587/sshd: /usr/sbin
    tcp6       0      0 :::45079                :::*                    LISTEN      1000       1718644    1802489/io.yahka.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      107        14792      1253/grafana
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          14711      1245/exim4
    tcp6       0      0 :::38237                :::*                    LISTEN      1000       1718648    1802489/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1718649    1802489/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1718645    1802489/io.yahka.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1714320    1801565/node-red
    udp        0      0 198.18.10.12:1905       0.0.0.0:*                           1000       1758117    1801661/io.sonos.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12534      538/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9393       1/init
    udp6       0      0 :::111                  :::*                                0          9399       1/init
    2023-09-03 16:45:18.264  - info: host.iobroker.esxi iobroker upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
    2023-09-03 16:45:18.266  - info: host.iobroker.esxi iobroker upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
    2023-09-03 16:45:18.268  - info: host.iobroker.esxi iobroker upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
    2023-09-03 16:45:18.270  - info: host.iobroker.esxi iobroker upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
    2023-09-03 16:45:18.272  - info: host.iobroker.esxi iobroker upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
    2023-09-03 16:45:18.274  - info: host.iobroker.esxi iobroker upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
    2023-09-03 16:45:18.278  - info: host.iobroker.esxi iobroker upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js static/js/2.b1d56998.chunk.js application/javascript
    2023-09-03 16:45:18.286  - info: host.iobroker.esxi iobroker upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.LICENSE.txt static/js/2.b1d56998.chunk.js.LICENSE.txt text/plain
    2023-09-03 16:45:18.324  - info: host.iobroker.esxi iobroker upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.map static/js/2.b1d56998.chunk.js.map application/json
    2023-09-03 16:45:18.570  - info: host.iobroker.esxi iobroker upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js static/js/main.034751df.chunk.js application/javascript
    2023-09-03 16:45:18.584  - info: host.iobroker.esxi iobroker upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js.map static/js/main.034751df.chunk.js.map application/json
    2023-09-03 16:45:18.587  - info: host.iobroker.esxi iobroker upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js static/js/runtime-main.7278cf1c.js application/javascript
    2023-09-03 16:45:18.590  - info: host.iobroker.esxi iobroker upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js.map static/js/runtime-main.7278cf1c.js.map application/json
    2023-09-03 16:45:18.593  - info: host.iobroker.esxi iobroker upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
    2023-09-03 16:45:18.596  - info: host.iobroker.esxi iobroker upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
    2023-09-03 16:45:18.600  - info: host.iobroker.esxi iobroker host.iobroker.esxi Adapter "system.adapter.web.0" is started
    2023-09-03 16:45:18.620  - info: host.iobroker.esxi "system.adapter.web.0" enabled
    2023-09-03 16:45:18.700  - info: host.iobroker.esxi instance system.adapter.web.0 started with pid 1811299
    2023-09-03 16:45:19.656  - info: host.iobroker.esxi iobroker exit 0
    2023-09-03 16:47:00.011  - info: javascript.0 (1801497) script.js.01_scripts.01_devices.bathroom.b_washingmachine: WM done?
    2023-09-03 16:47:01.174  - error: telegram.1 (1801535) Cannot send message [chatId -]: Error: ETELEGRAM: 403 Forbidden: user is deactivated
    2023-09-03 16:49:13.315  - info: host.iobroker.esxi Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
    2023-09-03 16:53:21.254  - info: host.iobroker.esxi "system.adapter.vis.0" disabled
    2023-09-03 16:53:21.276  - info: host.iobroker.esxi "system.adapter.vis.0" enabled
    2023-09-03 16:53:23.775  - info: host.iobroker.esxi instance system.adapter.vis.0 terminated while should be started once
    • M manmac1
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 2
                    NTP service: active
                RTC in local TZ: no
      iobroker
      /home/iobroker
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           2.0G          0B        2.0G
      Total:            9G        2.5G        4.8G
               7945 M total memory
               2456 M used memory
               2783 M free memory
                409 M buffer memory
               2295 M swap cache
               2044 M total swap
                  0 M used swap
               2044 M free swap
      *** FILESYSTEM ***
      /var:
      2.8G    /var/
      1.5G    /var/cache/apt
      1.5G    /var/cache
      823M    /var/lib
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     7.0.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        7546
      States:         7329
      Pending Updates: 10
      GlasfaserG Offline
      GlasfaserG Offline
      @manmac1
      Mache mal bitte :
      iob fix
      cd /opt/iobroker
      npm prune
      sudo reboot
      dann
      iobroker upgrade web@6.1.0 --debug
        manmac1
        @glasfaser said in Adapter Aktualisierung funktioniert nicht:
        sudo reboot
        npm prune wirft folgenden fehler, ich schau mal, wies nach dem reboot aussieht.
        npm ERR! code 1
        npm ERR! path /opt/iobroker/node_modules/openzwave-shared
        npm ERR! command failed
        npm ERR! command sh -c node-gyp rebuild
        npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/openzwave-shared/build“ wird betreten
        npm ERR!   CXX(target) Release/obj.target/openzwave_shared/src/callbacks.o
        npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/openzwave-shared/build“ wird verlassen
        npm ERR! gyp info it worked if it ends with ok
        npm ERR! gyp info using node-gyp@7.1.2
        npm ERR! gyp info using node@18.16.0 | linux | x64
        npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
        npm ERR! (node:1858850) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
        npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
        npm ERR! gyp info spawn /usr/bin/python3
        npm ERR! gyp info spawn args [
        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
        npm ERR! gyp info spawn args   'binding.gyp',
        npm ERR! gyp info spawn args   '-f',
        npm ERR! gyp info spawn args   'make',
        npm ERR! gyp info spawn args   '-I',
        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/openzwave-shared/build/config.gypi',
        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
        npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.16.0/include/node/common.gypi',
        npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
        npm ERR! gyp info spawn args   '-Dvisibility=default',
        npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.16.0',
        npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
        npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.16.0/<(target_arch)/node.lib',
        npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/openzwave-shared',
        npm ERR! gyp info spawn args   '-Dnode_engine=v8',
        npm ERR! gyp info spawn args   '--depth=.',
        npm ERR! gyp info spawn args   '--no-parallel',
        npm ERR! gyp info spawn args   '--generator-output',
        npm ERR! gyp info spawn args   'build',
        npm ERR! gyp info spawn args   '-Goutput_dir=.'
        npm ERR! gyp info spawn args ]
        npm ERR! gyp info spawn make
        npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
        npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-local-handle.h:12,
        npm ERR!                  from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-array-buffer.h:12,
        npm ERR!                  from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8.h:24,
        npm ERR!                  from ../src/openzwave.hpp:27,
        npm ERR!                  from ../src/callbacks.cc:18:
        npm ERR! /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-internal.h: In function ‘void v8::internal::PerformCastCheck(T*)’:
        npm ERR! /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-internal.h:646:38: error: ‘remove_cv_t’ is not a member of ‘std’; did you mean ‘remove_cv’?
        npm ERR!   646 |             !std::is_same<Data, std::remove_cv_t<T>>::value>::Perform(data);
        npm ERR!       |                                      ^~~~~~~~~~~
        npm ERR!       |                                      remove_cv
        npm ERR! /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-internal.h:646:50: error: template argument 2 is invalid
        npm ERR!       |                                                  ^
        npm ERR! /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-internal.h:646:63: error: ‘::Perform’ has not been declared
        npm ERR!       |                                                               ^~~~~~~
        npm ERR! make: *** [openzwave_shared.target.mk:150: Release/obj.target/openzwave_shared/src/callbacks.o] Fehler 1
        npm ERR! gyp ERR! build error
        npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
        npm ERR! gyp ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/node-gyp/lib/build.js:194:23)
        npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
        npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)
        npm ERR! gyp ERR! System Linux 5.10.0-25-amd64
        npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
        npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/openzwave-shared
        npm ERR! gyp ERR! node -v v18.16.0
        npm ERR! gyp ERR! node-gyp -v v7.1.2
        npm ERR! gyp ERR! not ok
        npm ERR!     /home/iobroker/.npm/_logs/2023-09-03T15_06_26_831Z-debug-0.log
          Bin für jeglichen Hinweis dankbar.
          Moin,
          mich interessiert mal eher, wieso ich bei einigen Posts jetzt immer diese alten Github Schinken angezeigt bekomme?
          Was möchte man mir damit sagen?
          Bernd
          GlasfaserG Offline
          GlasfaserG Offline
          @dp20eic sagte in Adapter Aktualisierung funktioniert nicht:
          OT
          Weil es in seinem Log enthalten ist .. z.b. dann poppen die als Github auf
          npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
          • M manmac1
            sudo reboot
            npm ERR! code 1
            npm ERR!       |                                                  ^
            npm ERR!       |                                                               ^~~~~~~
            GlasfaserG Offline
            GlasfaserG Offline
            bitte erst das andere mir zeigen was ich dir oben gepostet habe !!
            danach
            cd /opt/iobroker/node_modules/openzwave-shared
            npm install --omit=dev
            • GlasfaserG Glasfaser
              @manmac1
              Mache mal bitte :
              iob fix
              cd /opt/iobroker
              npm prune
              sudo reboot
              dann
              manmac1
              @glasfaser
              hat leider nicht geklappt.
              iobroker@iobroker:~$ iobroker upgrade web@6.1.0 --debug
              This upgrade of "web" will at least introduce the following changes:
              -> 6.1.0:
              Added the subscribing on the specific instance messages
              -> 6.0.3:
              Updated packages
              Implemented the possibility to view folder content
              -> 6.0.1:
              Removed letsencrypt handling from web adapter
              -> 5.5.3:
              Increased max size of the uploaded file via socket.io to 200MB (from 10MB)
              -> 5.5.2:
              Allowed deletion of fullcalendar objects
              -> 5.5.1:
              Allowed to read projects of vis-2-beta
              -> 5.5.0:
              Added special end-points for app authentication
              BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
              Would you like to upgrade web from @4.3.0 to @6.1.0 now? [(y)es, (n)o]: y
              Update web from @4.3.0 to @6.1.0
              host.iobroker.esxi Adapter "system.adapter.web.0" is stopped.
              NPM version: 9.5.1
              Installing iobroker.web@6.1.0... (System call)
              npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
              npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
              npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
              npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
              npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
              npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
              npm WARN deprecated har-validator@5.1.5: this library is no longer supported
              npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
              npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
              npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
              npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
              npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
              npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
              npm WARN deprecated phantomjs-prebuilt@2.1.16: this package is now deprecated
              npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
              npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
              npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
              npm ERR! code 1
              npm ERR! (node:7977) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
              npm ERR!       |                                                  ^
              npm ERR!       |                                                               ^~~~~~~
              npm ERR!     /home/iobroker/.npm/_logs/2023-09-03T15_11_29_375Z-debug-0.log
              upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
              upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
              upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
              upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
              upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
              upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
              upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
              upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
              upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
              upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
              upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
              upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
              upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
              upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
              upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
              upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
              upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
              upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
              upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
              upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
              upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
              upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
              upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
              upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
              upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
              upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
              upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
              upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
              upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
              upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
              upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
              upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
              upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
              upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
              upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
              upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
              upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                danach
                manmac1
                schrieb am zuletzt editiert von manmac1
                iobroker@iobroker:~$ cd /opt/iobroker/node_modules/openzwave-shared
                iobroker@iobroker:/opt/iobroker/node_modules/openzwave-shared$ npm install --omit=dev
                > openzwave-shared@1.4.1 preinstall
                > node lib/install-ozw.js
                > openzwave-shared@1.4.1 install
                > node-gyp rebuild
                (node:14306) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
                gyp info spawn make
                In file included from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:192,
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Value>, v8::PropertyAttribute)’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_maybe_43_inl.h:112:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
                  112 |   return obj->ForceSet(isolate->GetCurrentContext(), key, value, attribs);
                In file included from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters.h:59,
                                 from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:197,
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase<v8::Boolean>::return_t Nan::imp::ToFactory<v8::Boolean>::convert(v8::Local<v8::Value>)’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters_43_inl.h:18:67: error: cannot convert ‘v8::Local<v8::Context>’ to ‘v8::Isolate*’
                   18 |       val->To ## TYPE(v8::Isolate::GetCurrent()->GetCurrentContext())          \
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’
                   22 | X(Boolean)
                In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-primitive.h:11,
                                 from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:11,
                                 from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-array-buffer.h:13,
                                 from ../src/openzwave.hpp:26,
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-value.h:398:37: note:   initializing argument 1 of ‘v8::Local<v8::Boolean> v8::Value::ToBoolean(v8::Isolate*) const’
                  398 |   Local<Boolean> ToBoolean(Isolate* isolate) const;
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase<bool>::return_t Nan::imp::ToFactory<bool>::convert(v8::Local<v8::Value>)’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters_43_inl.h:37:55: error: cannot convert ‘v8::Local<v8::Context>’ to ‘v8::Isolate*’
                   37 |   return val->NAME ## Value(isolate->GetCurrentContext());                     \
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’
                   40 | X(bool, Boolean)
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-value.h:408:30: note:   initializing argument 1 of ‘bool v8::Value::BooleanValue(v8::Isolate*) const’
                  408 |   bool BooleanValue(Isolate* isolate) const;
                In file included from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_new.h:189,
                                 from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:198,
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::Function>::return_t Nan::imp::Factory<v8::Function>::New(Nan::FunctionCallback, v8::Local<v8::Value>)’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_implementation_12_inl.h:103:42: error: cannot convert ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
                  103 |   return scope.Escape(v8::Function::New( isolate
                      |                                          v8::Isolate*
                In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8.h:33,
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-function.h:33:22: note:   initializing argument 1 of ‘static v8::MaybeLocal<v8::Function> v8::Function::New(v8::Local<v8::Context>, v8::FunctionCallback, v8::Local<v8::Value>, int, v8::ConstructorBehavior, v8::SideEffectType)’
                   33 |       Local<Context> context, FunctionCallback callback,
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::StringObject>::return_t Nan::imp::Factory<v8::StringObject>::New(v8::Local<v8::String>)’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_implementation_12_inl.h:337:37: error: no matching function for call to ‘v8::StringObject::New(v8::Local<v8::String>&)’
                  337 |   return v8::StringObject::New(value).As<v8::StringObject>();
                In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8.h:47,
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-primitive-object.h:81:23: note: candidate: ‘static v8::Local<v8::Value> v8::StringObject::New(v8::Isolate*, v8::Local<v8::String>)’
                   81 |   static Local<Value> New(Isolate* isolate, Local<String> value);
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-primitive-object.h:81:23: note:   candidate expects 2 arguments, 1 provided
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_implementation_12_inl.h:337:58: error: expected primary-expression before ‘>’ token
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_implementation_12_inl.h:337:60: error: expected primary-expression before ‘)’ token
                In file included from ../src/openzwave.hpp:27,
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:835:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                  835 |         v8::Isolate::GetCurrent(), target, func, argc, argv);
                In file included from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:49,
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/node.h:195:50: note: declared here
                  195 |                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/node.h:112:42: note: in definition of macro ‘NODE_DEPRECATED’
                  112 |     __attribute__((deprecated(message))) declarator
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:850:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                  850 |         v8::Isolate::GetCurrent(), target, symbol, argc, argv);
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/node.h:188:50: note: declared here
                  188 |                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:865:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                  865 |         v8::Isolate::GetCurrent(), target, method, argc, argv);
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/node.h:181:50: note: declared here
                  181 |                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:911:53: error: no matching function for call to ‘v8::Value::ToString()’
                  911 |       v8::Local<v8::String> string = from->ToString();
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-value.h:360:44: note: candidate: ‘v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const’
                  360 |   V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-value.h:360:44: note:   candidate expects 1 argument, 0 provided
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:921:37: error: cannot convert ‘char*’ to ‘v8::Isolate*’
                  921 |         length_ = string->WriteUtf8(str_, static_cast<int>(len), 0, flags);
                      |                                     char*
                In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:11,
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-primitive.h:202:26: note:   initializing argument 1 of ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’
                  202 |   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1479:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                 1479 |     ));
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1533:64: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, const v8::Local<v8::Value>&)’
                 1533 |     New(persistentHandle)->Set(New(key).ToLocalChecked(), value);
                In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-array-buffer.h:13,
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:244:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’
                  244 |   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:244:37: note:   candidate expects 3 arguments, 2 provided
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:247:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’
                  247 |   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:247:37: note:   candidate expects 3 arguments, 2 provided
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1539:42: error: no matching function for call to ‘v8::Object::Set(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’
                 1539 |     New(persistentHandle)->Set(key, value);
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local<v8::Value>&)’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1545:44: error: no matching function for call to ‘v8::Object::Set(uint32_t&, const v8::Local<v8::Value>&)’
                 1545 |     New(persistentHandle)->Set(index, value);
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const char*) const’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1551:61: error: no matching function for call to ‘v8::Object::Get(v8::Local<v8::String>)’
                 1551 |         New(persistentHandle)->Get(New(key).ToLocalChecked()));
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:290:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’
                  290 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:290:43: note:   candidate expects 2 arguments, 1 provided
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:293:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’
                  293 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-object.h:293:43: note:   candidate expects 2 arguments, 1 provided
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const v8::Local<v8::String>&) const’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1557:55: error: no matching function for call to ‘v8::Object::Get(const v8::Local<v8::String>&)’
                 1557 |     return scope.Escape(New(persistentHandle)->Get(key));
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1562:57: error: no matching function for call to ‘v8::Object::Get(uint32_t&)’
                 1562 |     return scope.Escape(New(persistentHandle)->Get(index));
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1732:7: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                 1732 |     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, Nan::GetterCallback, Nan::SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, Nan::imp::Sig)’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:1977:16: warning: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>, v8::AccessorNameGetterCallback, v8::AccessorNameSetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, v8::Local<v8::AccessorSignature>, v8::SideEffectType, v8::SideEffectType)’ is deprecated: Do signature check in accessor [-Wdeprecated-declarations]
                 1977 |     , signature);
                In file included from /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-function.h:15,
                /home/iobroker/.cache/node-gyp/18.16.0/include/node/v8-template.h:838:8: note: declared here
                  838 |   void SetAccessor(
                In file included from /usr/include/c++/10/cassert:44,
                                 from /home/iobroker/.cache/node-gyp/18.16.0/include/node/node_object_wrap.h:26,
                                 from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:51,
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
                   24 |     assert(persistent().IsNearDeath());
                In file included from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:2222,
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_object_wrap.h:67:18: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘MarkIndependent’
                   67 |     persistent().MarkIndependent();
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’
                  124 |     assert(wrap->handle_.IsNearDeath());
                In file included from /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan.h:2313,
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_typedarray_contents.h: In constructor ‘Nan::TypedArrayContents<T>::TypedArrayContents(v8::Local<v8::Value>)’:
                /opt/iobroker/node_modules/openzwave-shared/node_modules/nan/nan_typedarray_contents.h:34:43: error: ‘class v8::ArrayBuffer’ has no member named ‘GetContents’
                   34 |       data   = static_cast<char*>(buffer->GetContents().Data()) + byte_offset;
                ../src/callbacks.cc: In function ‘void OZW::ozw_watcher_callback(const OpenZWave::Notification*, void*)’:
                ../src/callbacks.cc:80:37: warning: ‘uint8 OpenZWave::Notification::GetSceneId() const’ is deprecated [-Wdeprecated-declarations]
                   80 |     notif->sceneid = cb->GetSceneId();
                In file included from ../src/openzwave.hpp:32,
                /usr/local/include/openzwave/Notification.h:232:21: note: declared here
                  232 |    DEPRECATED uint8 GetSceneId() const
                make: *** [openzwave_shared.target.mk:136: Release/obj.target/openzwave_shared/src/callbacks.o] Fehler 1
                gyp ERR! not ok
                npm notice
                npm notice New major version of npm available! 9.5.1 -> 10.0.0
                npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.0.0
                npm notice Run npm install -g npm@10.0.0 to update!
                npm notice
                npm ERR! code 1
                npm ERR!     /home/iobroker/.npm/_logs/2023-09-03T15_16_59_988Z-debug-0.log
                • M manmac1
                  > node-gyp rebuild
                  gyp info spawn make
                     22 | X(Boolean)
                        |                                          v8::Isolate*
                        |                                     char*
                   1479 |     ));
                  gyp ERR! not ok
                  npm notice
                  npm notice
                  npm ERR! code 1
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @manmac1
                  so , jetzt nochmal zeigen
                    @manmac1
                    manmac1
                    iobroker@iobroker:/opt/iobroker/node_modules/openzwave-shared$ iobroker upgrade web@6.1.0 --debug
                    -> 6.1.0:
                    -> 6.0.3:
                    Updated packages
                    -> 6.0.1:
                    -> 5.5.3:
                    -> 5.5.2:
                    -> 5.5.1:
                    -> 5.5.0:
                    NPM version: 9.5.1
                    npm ERR! code 1
                    npm ERR! (node:25266) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
                    npm ERR!       |                                                  ^
                    npm ERR!       |                                                               ^~~~~~~
                    npm ERR!     /home/iobroker/.npm/_logs/2023-09-03T15_19_10_771Z-debug-0.log
                    • M manmac1
                      habs nochmal rauskopiert:
                      Skript v.2023-04-16
                      *** BASE SYSTEM ***
                      Architecture    : x86_64
                      Docker          : false
                      Virtualization  : vmware
                      Distributor ID: Debian
                      Description:    Debian GNU/Linux 11 (bullseye)
                      Release:        11
                      Codename:       bullseye
                      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                      NAME="Debian GNU/Linux"
                      VERSION_ID="11"
                      VERSION="11 (bullseye)"
                      VERSION_CODENAME=bullseye
                      ID=debian
                      HOME_URL="https://www.debian.org/"
                      SUPPORT_URL="https://www.debian.org/support"
                      BUG_REPORT_URL="https://bugs.debian.org/"
                      Systemuptime and Load:
                       16:56:43 up 15:03,  3 users,  load average: 0.29, 0.52, 0.52
                      CPU threads: 2
                      *** Time and Time Zones ***
                                     Local time: Sun 2023-09-03 16:56:43 CEST
                                 Universal time: Sun 2023-09-03 14:56:43 UTC
                                       RTC time: Sun 2023-09-03 14:56:43
                                      Time zone: Europe/Vienna (CEST, +0200)
                                    NTP service: active
                                RTC in local TZ: no
                      *** User and Groups ***
                      iobroker
                      /home/iobroker
                      iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev bluetooth
                      *** X-Server-Setup ***
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            7.9G        2.5G        2.8G        0.0K        2.7G        5.5G
                      Swap:           2.0G          0B        2.0G
                      Total:            9G        2.5G        4.8G
                               7945 M total memory
                               2456 M used memory
                               1277 M active memory
                               3294 M inactive memory
                               2783 M free memory
                                409 M buffer memory
                               2295 M swap cache
                               2044 M total swap
                                  0 M used swap
                               2044 M free swap
                      *** FILESYSTEM ***
                      udev           devtmpfs  3.9G     0  3.9G   0% /dev
                      tmpfs          tmpfs     795M  736K  794M   1% /run
                      /dev/sda1      ext4       30G   16G   13G  55% /
                      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                      tmpfs          tmpfs     795M  4.0K  795M   1% /run/user/1000
                      [Sun Sep  3 01:53:08 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                      [Sun Sep  3 01:53:09 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                      TARGET SOURCE    FSTYPE OPTIONS
                      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                      /var:
                      2.8G    /var/
                      1.5G    /var/cache/apt
                      1.5G    /var/cache
                      1.4G    /var/cache/apt/archives
                      823M    /var/lib
                      Archived and active journals take up 32.0M in the file system.
                      /opt/iobroker/backups:
                      360M    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      2.4G    /opt/iobroker/iobroker-data/
                      1.9G    /opt/iobroker/iobroker-data/sonosCache
                      332M    /opt/iobroker/iobroker-data/files
                      152M    /opt/iobroker/iobroker-data/backup-objects
                      53M     /opt/iobroker/iobroker-data/files/javascript.admin
                      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                      19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
                      15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                      13M     /opt/iobroker/iobroker-data/objects.jsonl
                      11M     /opt/iobroker/iobroker-data/objects.json.migrated
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v18.16.0
                      /usr/bin/node           v18.16.0
                      /usr/bin/npm            9.5.1
                      /usr/bin/npx            9.5.1
                      nodejs:
                        Installed: 18.16.0-deb-1nodesource1
                        Candidate: 18.17.1-deb-1nodesource1
                        Version table:
                           18.17.1-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                       *** 18.16.0-deb-1nodesource1 100
                           12.22.12~dfsg-1~deb11u4 500
                              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                           12.22.12~dfsg-1~deb11u3 500
                              500 http://deb.debian.org/debian bullseye/main amd64 Packages
                      No problems detected
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Core adapters versions
                      js-controller:  4.0.24
                      admin:          6.3.5
                      javascript:     7.0.3
                      npm ERR! code ELSPROBLEMS
                      npm ERR! extraneous: @harmonyhub/discover@1.0.5 /opt/iobroker/node_modules/@harmonyhub/discover
                      npm ERR! extraneous: @iobroker/adapter-core@1.0.1 /opt/iobroker/node_modules/@iobroker/adapter-core
                      npm ERR! extraneous: @node-red/editor-api@0.20.7 /opt/iobroker/node_modules/@node-red/editor-api
                      npm ERR! extraneous: @node-red/editor-client@0.20.7 /opt/iobroker/node_modules/@node-red/editor-client
                      npm ERR! extraneous: @node-red/nodes@0.20.7 /opt/iobroker/node_modules/@node-red/nodes
                      npm ERR! extraneous: @node-red/registry@0.20.7 /opt/iobroker/node_modules/@node-red/registry
                      npm ERR! extraneous: @node-red/runtime@0.20.7 /opt/iobroker/node_modules/@node-red/runtime
                      npm ERR! extraneous: @node-red/util@0.20.7 /opt/iobroker/node_modules/@node-red/util
                      npm ERR! extraneous: @types/form-data@2.2.1 /opt/iobroker/node_modules/@types/form-data
                      npm ERR! extraneous: @types/iobroker@1.4.0 /opt/iobroker/node_modules/@types/iobroker
                      npm ERR! extraneous: @types/request@2.48.1 /opt/iobroker/node_modules/@types/request
                      npm ERR! extraneous: agent-base@4.3.0 /opt/iobroker/node_modules/agent-base
                      npm ERR! extraneous: alcalzone-shared@1.4.0 /opt/iobroker/node_modules/alcalzone-shared
                      npm ERR! extraneous: alexa-cookie2@2.1.0 /opt/iobroker/node_modules/alexa-cookie2
                      npm ERR! extraneous: alexa-remote2@2.5.5 /opt/iobroker/node_modules/alexa-remote2
                      npm ERR! extraneous: asap@2.0.6 /opt/iobroker/node_modules/asap
                      npm ERR! extraneous: async@2.5.0 /opt/iobroker/node_modules/async
                      npm ERR! extraneous: autobind-decorator@2.4.0 /opt/iobroker/node_modules/autobind-decorator
                      npm ERR! extraneous: aws-iot-device-sdk@2.2.1 /opt/iobroker/node_modules/aws-iot-device-sdk
                      npm ERR! extraneous: axios@0.15.3 /opt/iobroker/node_modules/axios
                      npm ERR! extraneous: base64url@2.0.0 /opt/iobroker/node_modules/base64url
                      npm ERR! extraneous: binrpc@1.0.0 /opt/iobroker/node_modules/binrpc
                      npm ERR! extraneous: bson@1.1.1 /opt/iobroker/node_modules/bson
                      npm ERR! extraneous: buffer-crc32@0.2.13 /opt/iobroker/node_modules/buffer-crc32
                      npm ERR! extraneous: callback-stream@1.1.0 /opt/iobroker/node_modules/callback-stream
                      npm ERR! extraneous: chalk@2.4.2 /opt/iobroker/node_modules/chalk
                      npm ERR! extraneous: cheerio@1.0.0-rc.3 /opt/iobroker/node_modules/cheerio
                      npm ERR! extraneous: cls-bluebird@1.1.3 /opt/iobroker/node_modules/cls-bluebird
                      npm ERR! extraneous: commander@2.11.0 /opt/iobroker/node_modules/commander
                      npm ERR! extraneous: cron@1.7.1 /opt/iobroker/node_modules/cron
                      npm ERR! extraneous: crypto-js@3.1.6 /opt/iobroker/node_modules/crypto-js
                      npm ERR! extraneous: deep-extend@0.4.2 /opt/iobroker/node_modules/deep-extend
                      npm ERR! extraneous: dicer@0.2.5 /opt/iobroker/node_modules/dicer
                      npm ERR! extraneous: dotenv@4.0.0 /opt/iobroker/node_modules/dotenv
                      npm ERR! extraneous: epoll@0.1.22 /opt/iobroker/node_modules/epoll
                      npm ERR! extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
                      npm ERR! extraneous: es6-set@0.1.5 /opt/iobroker/node_modules/es6-set
                      npm ERR! extraneous: escape-string-regexp@1.0.5 /opt/iobroker/node_modules/escape-string-regexp
                      npm ERR! extraneous: event-emitter@0.3.5 /opt/iobroker/node_modules/event-emitter
                      npm ERR! extraneous: eventemitter3@2.0.3 /opt/iobroker/node_modules/eventemitter3
                      npm ERR! extraneous: express-fileupload@0.1.4 /opt/iobroker/node_modules/express-fileupload
                      npm ERR! extraneous: express-session@1.16.2 /opt/iobroker/node_modules/express-session
                      npm ERR! extraneous: express@4.16.2 /opt/iobroker/node_modules/express
                      npm ERR! extraneous: extract-zip@1.7.0 /opt/iobroker/node_modules/extract-zip
                      npm ERR! extraneous: fd-slicer@1.1.0 /opt/iobroker/node_modules/fd-slicer
                      npm ERR! extraneous: finalhandler@1.1.0 /opt/iobroker/node_modules/finalhandler
                      npm ERR! extraneous: fs-extra@0.22.1 /opt/iobroker/node_modules/fs-extra
                      npm ERR! extraneous: fs-minipass@1.2.3 /opt/iobroker/node_modules/fs-minipass
                      npm ERR! extraneous: generate-function@2.0.0 /opt/iobroker/node_modules/generate-function
                      npm ERR! extraneous: generate-object-property@1.2.0 /opt/iobroker/node_modules/generate-object-property
                      npm ERR! extraneous: glob-parent@3.1.0 /opt/iobroker/node_modules/glob-parent
                      npm ERR! extraneous: glob-stream@6.1.0 /opt/iobroker/node_modules/glob-stream
                      npm ERR! extraneous: harmonyhubws@1.0.4 /opt/iobroker/node_modules/harmonyhubws
                      npm ERR! extraneous: has-flag@3.0.0 /opt/iobroker/node_modules/has-flag
                      npm ERR! extraneous: hasha@2.2.0 /opt/iobroker/node_modules/hasha
                      npm ERR! extraneous: homematic-manager@1.0.14 /opt/iobroker/node_modules/homematic-manager
                      npm ERR! extraneous: http-proxy-middleware@0.19.1 /opt/iobroker/node_modules/http-proxy-middleware
                      npm ERR! extraneous: https-proxy-agent@2.2.1 /opt/iobroker/node_modules/https-proxy-agent
                      npm ERR! extraneous: i18next@15.1.0 /opt/iobroker/node_modules/i18next
                      npm ERR! extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/ignore-walk
                      npm ERR! extraneous: imap@0.8.19 /opt/iobroker/node_modules/imap
                      npm ERR! extraneous: io-packages.json@ /opt/iobroker/node_modules/io-packages.json
                      npm ERR! missing: iobroker.geofency@^1.0.3, required by iobroker@1.0.0
                      npm ERR! extraneous: iobroker.hmm@1.0.1 /opt/iobroker/node_modules/iobroker.hmm
                      npm ERR! extraneous: iobroker.icons-icons8@0.0.1 /opt/iobroker/node_modules/iobroker.icons-icons8
                      npm ERR! extraneous: iobroker.rp2@ /opt/iobroker/node_modules/iobroker.rp2
                      npm ERR! extraneous: iobroker.type-detector@0.1.1 /opt/iobroker/node_modules/iobroker.type-detector
                      npm ERR! extraneous: iobroker.vis-bars@0.1.4 /opt/iobroker/node_modules/iobroker.vis-bars
                      npm ERR! extraneous: iobroker.vis-fancyswitch@1.1.0 /opt/iobroker/node_modules/iobroker.vis-fancyswitch
                      npm ERR! extraneous: iobroker@1.0.2 /opt/iobroker/node_modules/iobroker
                      npm ERR! extraneous: ipaddr.js@1.5.2 /opt/iobroker/node_modules/ipaddr.js
                      npm ERR! extraneous: is-bluebird@1.0.2 /opt/iobroker/node_modules/is-bluebird
                      npm ERR! extraneous: is-buffer@2.0.4 /opt/iobroker/node_modules/is-buffer
                      npm ERR! extraneous: is-my-json-valid@2.16.1 /opt/iobroker/node_modules/is-my-json-valid
                      npm ERR! extraneous: is-negated-glob@1.0.0 /opt/iobroker/node_modules/is-negated-glob
                      npm ERR! extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
                      npm ERR! extraneous: is-stream@1.1.0 /opt/iobroker/node_modules/is-stream
                      npm ERR! extraneous: isemail@1.2.0 /opt/iobroker/node_modules/isemail
                      npm ERR! extraneous: joi@6.10.1 /opt/iobroker/node_modules/joi
                      npm ERR! extraneous: js-yaml@3.13.1 /opt/iobroker/node_modules/js-yaml
                      npm ERR! extraneous: js2xmlparser@3.0.0 /opt/iobroker/node_modules/js2xmlparser
                      npm ERR! extraneous: json-stable-stringify-without-jsonify@1.0.1 /opt/iobroker/node_modules/json-stable-stringify-without-jsonify
                      npm ERR! extraneous: jsonata@1.6.5 /opt/iobroker/node_modules/jsonata
                      npm ERR! extraneous: jsonfile@2.4.0 /opt/iobroker/node_modules/jsonfile
                      npm ERR! extraneous: jsonpointer@4.0.1 /opt/iobroker/node_modules/jsonpointer
                      npm ERR! extraneous: jsonwebtoken@8.1.1 /opt/iobroker/node_modules/jsonwebtoken
                      npm ERR! extraneous: jws@3.1.4 /opt/iobroker/node_modules/jws
                      npm ERR! extraneous: kew@0.7.0 /opt/iobroker/node_modules/kew
                      npm ERR! extraneous: klaw@1.3.1 /opt/iobroker/node_modules/klaw
                      npm ERR! extraneous: libbase64@1.0.3 /opt/iobroker/node_modules/libbase64
                      npm ERR! extraneous: libmime@4.1.1 /opt/iobroker/node_modules/libmime
                      npm ERR! extraneous: libqp@1.1.0 /opt/iobroker/node_modules/libqp
                      npm ERR! extraneous: linkify-it@2.1.0 /opt/iobroker/node_modules/linkify-it
                      npm ERR! extraneous: mailparser@2.7.1 /opt/iobroker/node_modules/mailparser
                      npm ERR! extraneous: mailsplit@4.4.1 /opt/iobroker/node_modules/mailsplit
                      npm ERR! extraneous: memorystore@1.6.1 /opt/iobroker/node_modules/memorystore
                      npm ERR! extraneous: minipass@2.2.1 /opt/iobroker/node_modules/minipass
                      npm ERR! extraneous: minizlib@1.0.4 /opt/iobroker/node_modules/minizlib
                      npm ERR! extraneous: mongodb@3.3.0 /opt/iobroker/node_modules/mongodb
                      npm ERR! extraneous: multer@1.4.1 /opt/iobroker/node_modules/multer
                      npm ERR! extraneous: mustache@3.0.1 /opt/iobroker/node_modules/mustache
                      npm ERR! extraneous: needle@2.9.1 /opt/iobroker/node_modules/needle
                      npm ERR! extraneous: net-snmp@1.2.4 /opt/iobroker/node_modules/net-snmp
                      npm ERR! extraneous: node-abi@2.15.0 /opt/iobroker/node_modules/node-abi
                      npm ERR! extraneous: node-disk-info@ /opt/iobroker/node_modules/node-disk-info
                      npm ERR! extraneous: node-hue-api@2.4.2 /opt/iobroker/node_modules/node-hue-api
                      npm ERR! extraneous: node-ical@0.5.4 /opt/iobroker/node_modules/node-ical
                      npm ERR! extraneous: node-red-contrib-polymer@0.0.21 /opt/iobroker/node_modules/node-red-contrib-polymer
                      npm ERR! extraneous: node-red-dashboard@2.16.1 /opt/iobroker/node_modules/node-red-dashboard
                      npm ERR! extraneous: node-red-node-email@1.6.2 /opt/iobroker/node_modules/node-red-node-email
                      npm ERR! extraneous: node-red-node-feedparser@0.1.14 /opt/iobroker/node_modules/node-red-node-feedparser
                      npm ERR! extraneous: node-red-node-rbe@0.2.5 /opt/iobroker/node_modules/node-red-node-rbe
                      npm ERR! extraneous: node-red-node-sentiment@0.1.4 /opt/iobroker/node_modules/node-red-node-sentiment
                      npm ERR! extraneous: node-red-node-tail@0.0.2 /opt/iobroker/node_modules/node-red-node-tail
                      npm ERR! extraneous: node-red-node-twitter@1.1.5 /opt/iobroker/node_modules/node-red-node-twitter
                      npm ERR! extraneous: node-red@0.20.7 /opt/iobroker/node_modules/node-red
                      npm ERR! extraneous: node-ssdp@3.2.5 /opt/iobroker/node_modules/node-ssdp
                      npm ERR! extraneous: node-static@0.7.11 /opt/iobroker/node_modules/node-static
                      npm ERR! extraneous: node-telegram-bot-api@0.28.0 /opt/iobroker/node_modules/node-telegram-bot-api
                      npm ERR! extraneous: nodemailer@6.3.0 /opt/iobroker/node_modules/nodemailer
                      npm ERR! extraneous: noop-logger@0.1.1 /opt/iobroker/node_modules/noop-logger
                      npm ERR! extraneous: npm-bundled@1.1.2 /opt/iobroker/node_modules/npm-bundled
                      npm ERR! extraneous: npm-normalize-package-bin@1.0.1 /opt/iobroker/node_modules/npm-normalize-package-bin
                      npm ERR! extraneous: npm-packlist@1.4.8 /opt/iobroker/node_modules/npm-packlist
                      npm ERR! extraneous: object.assign@4.0.4 /opt/iobroker/node_modules/object.assign
                      npm ERR! extraneous: openzwave-shared@1.4.1 /opt/iobroker/node_modules/openzwave-shared
                      npm ERR! extraneous: optimist@0.6.1 /opt/iobroker/node_modules/optimist
                      npm ERR! extraneous: ordered-read-streams@1.0.1 /opt/iobroker/node_modules/ordered-read-streams
                      npm ERR! extraneous: parse5@3.0.3 /opt/iobroker/node_modules/parse5
                      npm ERR! extraneous: passport@0.3.2 /opt/iobroker/node_modules/passport
                      npm ERR! extraneous: path-dirname@1.0.2 /opt/iobroker/node_modules/path-dirname
                      npm ERR! extraneous: pend@1.2.0 /opt/iobroker/node_modules/pend
                      npm ERR! extraneous: poplib@0.1.7 /opt/iobroker/node_modules/poplib
                      npm ERR! extraneous: prebuild-install@5.3.3 /opt/iobroker/node_modules/prebuild-install
                      npm ERR! extraneous: progress@1.1.8 /opt/iobroker/node_modules/progress
                      npm ERR! extraneous: promise@7.1.1 /opt/iobroker/node_modules/promise
                      npm ERR! extraneous: proxy-addr@2.0.2 /opt/iobroker/node_modules/proxy-addr
                      npm ERR! extraneous: pump@1.0.2 /opt/iobroker/node_modules/pump
                      npm ERR! extraneous: pumpify@1.5.1 /opt/iobroker/node_modules/pumpify
                      npm ERR! extraneous: request-progress@2.0.1 /opt/iobroker/node_modules/request-progress
                      npm ERR! extraneous: request-promise-core@1.1.1 /opt/iobroker/node_modules/request-promise-core
                      npm ERR! extraneous: request-promise-native@1.0.5 /opt/iobroker/node_modules/request-promise-native
                      npm ERR! extraneous: request-promise@1.0.2 /opt/iobroker/node_modules/request-promise
                      npm ERR! extraneous: require_optional@1.0.1 /opt/iobroker/node_modules/require_optional
                      npm ERR! extraneous: resolve-from@2.0.0 /opt/iobroker/node_modules/resolve-from
                      npm ERR! extraneous: rpi-gpio@0.7.0 /opt/iobroker/node_modules/rpi-gpio
                      npm ERR! extraneous: rrule@2.2.0 /opt/iobroker/node_modules/rrule
                      npm ERR! extraneous: semaphore@1.0.5 /opt/iobroker/node_modules/semaphore
                      npm ERR! extraneous: serialport@4.0.7 /opt/iobroker/node_modules/serialport
                      npm ERR! extraneous: shimmer@1.2.0 /opt/iobroker/node_modules/shimmer
                      npm ERR! extraneous: sonos-discovery@1.1.3 /opt/iobroker/node_modules/sonos-discovery
                      npm ERR! extraneous: sonos-web-controller@0.14.0 /opt/iobroker/node_modules/sonos-web-controller
                      npm ERR! extraneous: sprintf-js@1.0.3 /opt/iobroker/node_modules/sprintf-js
                      npm ERR! extraneous: streamifier@0.1.1 /opt/iobroker/node_modules/streamifier
                      npm ERR! extraneous: suncalc@1.8.0 /opt/iobroker/node_modules/suncalc
                      npm ERR! extraneous: supports-color@5.5.0 /opt/iobroker/node_modules/supports-color
                      npm ERR! extraneous: systeminformation@3.54.0 /opt/iobroker/node_modules/systeminformation
                      npm ERR! extraneous: tail@2.2.4 /opt/iobroker/node_modules/tail
                      npm ERR! extraneous: throttleit@1.0.0 /opt/iobroker/node_modules/throttleit
                      npm ERR! extraneous: through2-filter@3.0.0 /opt/iobroker/node_modules/through2-filter
                      npm ERR! extraneous: tlds@1.203.1 /opt/iobroker/node_modules/tlds
                      npm ERR! extraneous: to-absolute-glob@2.0.2 /opt/iobroker/node_modules/to-absolute-glob
                      npm ERR! extraneous: topo@1.1.0 /opt/iobroker/node_modules/topo
                      npm ERR! extraneous: traits@0.4.0 /opt/iobroker/node_modules/traits
                      npm ERR! extraneous: typescript@2.7.1 /opt/iobroker/node_modules/typescript
                      npm ERR! extraneous: uc.micro@1.0.6 /opt/iobroker/node_modules/uc.micro
                      npm ERR! extraneous: uglify-js@3.6.0 /opt/iobroker/node_modules/uglify-js
                      npm ERR! extraneous: unique-stream@2.3.1 /opt/iobroker/node_modules/unique-stream
                      npm ERR! extraneous: ursa-optional@0.9.8 /opt/iobroker/node_modules/ursa-optional
                      npm ERR! extraneous: utf7@1.0.2 /opt/iobroker/node_modules/utf7
                      npm ERR! extraneous: virtual-device-sdk@1.5.19 /opt/iobroker/node_modules/virtual-device-sdk
                      npm ERR! extraneous: virtual-tsc@0.3.4 /opt/iobroker/node_modules/virtual-tsc
                      npm ERR! extraneous: vm2@3.6.10 /opt/iobroker/node_modules/vm2
                      npm ERR! extraneous: wake_on_lan@0.0.4 /opt/iobroker/node_modules/wake_on_lan
                      npm ERR! extraneous: when@3.7.8 /opt/iobroker/node_modules/when
                      npm ERR! extraneous: which-pm-runs@1.0.0 /opt/iobroker/node_modules/which-pm-runs
                      npm ERR! extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
                      npm ERR! extraneous: wordwrap@0.0.3 /opt/iobroker/node_modules/wordwrap
                      npm ERR! extraneous: xmlbuilder@9.0.4 /opt/iobroker/node_modules/xmlbuilder
                      npm ERR! extraneous: xmlcreate@1.0.2 /opt/iobroker/node_modules/xmlcreate
                      npm ERR! extraneous: yauzl@2.10.0 /opt/iobroker/node_modules/yauzl
                      npm ERR!     /home/iobroker/.npm/_logs/2023-09-03T14_56_53_179Z-debug-0.log
                      Adapters from github:   0
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : iobroker.esxi                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                      + system.adapter.alexa2.0                 : alexa2                : iobroker.esxi                            -  enabled
                        system.adapter.backitup.0               : backitup              : iobroker.esxi                            - disabled
                        system.adapter.cloud.0                  : cloud                 : iobroker.esxi                            - disabled
                        system.adapter.devices.0                : devices               : iobroker.esxi                            -  enabled
                        system.adapter.discovery.0              : discovery             : iobroker.esxi                            - disabled
                        system.adapter.flot.0                   : flot                  : iobroker.esxi                            -  enabled
                      + system.adapter.hm-rega.0                : hm-rega               : iobroker.esxi                            -  enabled
                      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker.esxi                            -  enabled, port: 0
                      + system.adapter.hue.0                    : hue                   : iobroker.esxi                            -  enabled, port: 443
                      + system.adapter.influxdb.0               : influxdb              : iobroker.esxi                            -  enabled, port: 8086
                      + system.adapter.info.0                   : info                  : iobroker.esxi                            -  enabled
                        system.adapter.iot.0                    : iot                   : iobroker.esxi                            - disabled
                      + system.adapter.javascript.0             : javascript            : iobroker.esxi                            -  enabled
                      + system.adapter.lametric.0               : lametric              : iobroker.esxi                            -  enabled
                      + system.adapter.netatmo.0                : netatmo               : iobroker.esxi                            -  enabled
                      + system.adapter.node-red.0               : node-red              : iobroker.esxi                            -  enabled, port: 1880, bind: 0.0.0.0 (SSL)
                      + system.adapter.parser.0                 : parser                : iobroker.esxi                            -  enabled
                      + system.adapter.sonos.0                  : sonos                 : iobroker.esxi                            -  enabled
                      + system.adapter.systeminfo.0             : systeminfo            : iobroker.esxi                            -  enabled
                      + system.adapter.telegram.0               : telegram              : iobroker.esxi                            -  enabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.telegram.1               : telegram              : iobroker.esxi                            -  enabled, port: 8443, bind: 0.0.0.0
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker.esxi                            -  enabled
                        system.adapter.vis.0                    : vis                   : iobroker.esxi                            -  enabled
                      + system.adapter.web.0                    : web                   : iobroker.esxi                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.yahka.0                  : yahka                 : iobroker.esxi                            -  enabled
                      + system.adapter.zwave2.0                 : zwave2                : iobroker.esxi                            -  enabled
                      + instance is alive
                      ioBroker-Repositories
                      Stable (default): http://download.iobroker.net/sources-dist.json
                      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                      sources       : conf/sources-dist.json
                      online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
                      Installed ioBroker-Instances
                      Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
                      Adapter    "alexa2"       : 3.24.1   , installed 3.23.2 [Updatable]
                      Adapter    "backitup"     : 2.6.23   , installed 2.4.9  [Updatable]
                      Adapter    "ble"          : 0.13.4   , installed 0.13.0 [Updatable]
                      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                      Adapter    "cloud"        : 4.4.1    , installed 4.3.0  [Updatable]
                      Adapter    "devices"      : 1.1.5    , installed 1.1.5
                      Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
                      Adapter    "frontier_silicon": 0.0.11, installed 0.0.10 [Updatable]
                      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                      Adapter    "history"      : 2.2.6    , installed 1.11.1 [Updatable]
                      Adapter    "hm-rega"      : 3.0.47   , installed 3.0.46 [Updatable]
                      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.16 [Updatable]
                      Adapter    "hue"          : 3.9.5    , installed 3.7.1  [Updatable]
                      Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
                      Adapter    "info"         : 1.9.26   , installed 1.9.19 [Updatable]
                      Adapter    "iot"          : 1.14.5   , installed 1.14.2 [Updatable]
                      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
                      Adapter    "lametric"     : 2.4.1    , installed 2.4.1
                      Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
                      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                      Adapter    "node-red"     : 4.0.3    , installed 4.0.0  [Updatable]
                      Adapter    "owfs"         : 0.7.0    , installed 0.7.0
                      Adapter    "parser"       : 1.3.2    , installed 1.1.8  [Updatable]
                      Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
                      Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
                      Adapter    "radar2"       : 2.0.7    , installed 2.0.3  [Updatable]
                      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                      Adapter    "snmp"         : 2.4.11   , installed 1.0.0  [Updatable]
                      Adapter    "socketio"     : 6.5.2    , installed 4.2.0  [Updatable]
                      Adapter    "sonos"        : 2.3.1    , installed 2.3.1
                      Adapter    "systeminfo"   : 1.0.0    , installed 0.3.1  [Updatable]
                      Adapter    "telegram"     : 1.16.0   , installed 1.15.6 [Updatable]
                      Adapter    "vis-hqwidgets": 1.4.0    , installed 1.3.0  [Updatable]
                      Adapter    "web"          : 6.1.0    , installed 4.3.0  [Updatable]
                      Adapter    "ws"           : 2.5.3    , installed 1.3.0  [Updatable]
                      Adapter    "yahka"        : 1.0.3    , installed 0.17.0 [Updatable]
                      Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
                      Objects and States
                      Objects:        7546
                      States:         7329
                      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                      Hit:2 http://deb.debian.org/debian bullseye InRelease
                      Hit:3 http://security.debian.org/debian-security bullseye-security/updates InRelease
                      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                      Hit:5 https://apt.grafana.com stable InRelease
                      Hit:6 https://repos.influxdata.com/debian stable InRelease
                      Hit:7 https://repos.influxdata.com/debian stretch InRelease
                      Get:8 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
                      Fetched 4586 B in 1s (7111 B/s)
                      Reading package lists...
                      Pending Updates: 10
                      *** Listening Ports ***
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1711988    1801452/iobroker.js
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1711981    1801452/iobroker.js
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          9392       1/init
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12738      587/sshd: /usr/sbin
                      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       1714317    1801565/node-red
                      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        13256      900/influxd
                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          14710      1245/exim4
                      tcp        0      0 127.0.0.1:2010          0.0.0.0:*               LISTEN      1000       1715056    1801591/io.hm-rpc.0
                      tcp        0      0 127.0.0.1:35931         0.0.0.0:*               LISTEN      1000       1718958    1802489/io.yahka.0
                      tcp        0      0 127.0.0.1:39589         0.0.0.0:*               LISTEN      1000       1721109    1802489/io.yahka.0
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          9396       1/init
                      tcp6       0      0 :::80                   :::*                    LISTEN      1000       1714319    1801565/node-red
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1714058    1801470/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1729486    1811299/io.web.0
                      tcp6       0      0 :::8086                 :::*                    LISTEN      999        15440      900/influxd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          12749      587/sshd: /usr/sbin
                      tcp6       0      0 :::45079                :::*                    LISTEN      1000       1718644    1802489/io.yahka.0
                      tcp6       0      0 :::3000                 :::*                    LISTEN      107        14792      1253/grafana
                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          14711      1245/exim4
                      tcp6       0      0 :::38237                :::*                    LISTEN      1000       1718648    1802489/io.yahka.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1718649    1802489/io.yahka.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1718645    1802489/io.yahka.0
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1714320    1801565/node-red
                      udp        0      0 198.18.10.12:1905       0.0.0.0:*                           1000       1758117    1801661/io.sonos.0
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12534      538/dhclient
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9393       1/init
                      udp6       0      0 :::111                  :::*                                0          9399       1/init
                      2023-09-03 16:45:18.264  - info: host.iobroker.esxi iobroker upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
                      2023-09-03 16:45:18.266  - info: host.iobroker.esxi iobroker upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
                      2023-09-03 16:45:18.268  - info: host.iobroker.esxi iobroker upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
                      2023-09-03 16:45:18.270  - info: host.iobroker.esxi iobroker upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
                      2023-09-03 16:45:18.272  - info: host.iobroker.esxi iobroker upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
                      2023-09-03 16:45:18.274  - info: host.iobroker.esxi iobroker upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
                      2023-09-03 16:45:18.278  - info: host.iobroker.esxi iobroker upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js static/js/2.b1d56998.chunk.js application/javascript
                      2023-09-03 16:45:18.286  - info: host.iobroker.esxi iobroker upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.LICENSE.txt static/js/2.b1d56998.chunk.js.LICENSE.txt text/plain
                      2023-09-03 16:45:18.324  - info: host.iobroker.esxi iobroker upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.map static/js/2.b1d56998.chunk.js.map application/json
                      2023-09-03 16:45:18.570  - info: host.iobroker.esxi iobroker upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js static/js/main.034751df.chunk.js application/javascript
                      2023-09-03 16:45:18.584  - info: host.iobroker.esxi iobroker upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js.map static/js/main.034751df.chunk.js.map application/json
                      2023-09-03 16:45:18.587  - info: host.iobroker.esxi iobroker upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js static/js/runtime-main.7278cf1c.js application/javascript
                      2023-09-03 16:45:18.590  - info: host.iobroker.esxi iobroker upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js.map static/js/runtime-main.7278cf1c.js.map application/json
                      2023-09-03 16:45:18.593  - info: host.iobroker.esxi iobroker upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
                      2023-09-03 16:45:18.596  - info: host.iobroker.esxi iobroker upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                      2023-09-03 16:45:18.600  - info: host.iobroker.esxi iobroker host.iobroker.esxi Adapter "system.adapter.web.0" is started
                      2023-09-03 16:45:18.620  - info: host.iobroker.esxi "system.adapter.web.0" enabled
                      2023-09-03 16:45:18.700  - info: host.iobroker.esxi instance system.adapter.web.0 started with pid 1811299
                      2023-09-03 16:45:19.656  - info: host.iobroker.esxi iobroker exit 0
                      2023-09-03 16:47:00.011  - info: javascript.0 (1801497) script.js.01_scripts.01_devices.bathroom.b_washingmachine: WM done?
                      2023-09-03 16:47:01.174  - error: telegram.1 (1801535) Cannot send message [chatId -]: Error: ETELEGRAM: 403 Forbidden: user is deactivated
                      2023-09-03 16:49:13.315  - info: host.iobroker.esxi Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                      2023-09-03 16:53:21.254  - info: host.iobroker.esxi "system.adapter.vis.0" disabled
                      2023-09-03 16:53:21.276  - info: host.iobroker.esxi "system.adapter.vis.0" enabled
                      2023-09-03 16:53:23.775  - info: host.iobroker.esxi instance system.adapter.vis.0 terminated while should be started once
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @manmac1 sagte in Adapter Aktualisierung funktioniert nicht:
                      Nach deiner oberen Ausgabe wenn ich es mir genauer anschaue ,
                      hast du früher sehr viel aus Github die Adapter gezogen .
                      Das ist alles querbeet und seit Nodejs 16/18 wir genauer darauf geschaut.
                      Ich wurde ein Backup nehmen und ioBroker neu aufsetzen , denn du bis seit Nodejs12 dabei.
                      Meine Empfehlung !
                        Meine Empfehlung !
                        manmac1
                        @glasfaser
                        Hab ich mir vorhin auch schon gedacht. Hab etwas bammel ob ich das Backup und die Wiederherstellung auch so hinbekomme, dass sich an dem aktuellen Setup nichts verändert - ist mittlerweile doch sehr komplex ;) .
                        • M manmac1
                          @glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Ich sehe da nichts von , sieht normal aus ,
                          Meinst du deswegen :
                          Dein :
                          /usr/bin/npm 9.5.1
                          /usr/bin/npx 9.5.1
                          ist auch schon alt , Aktuell ist
                          Wie gesagt , setze es neu auf ..
                          aber bitte den Benutzer nicht iobroker nennen !
                            Dein :
                            /usr/bin/npm 9.5.1
                            /usr/bin/npx 9.5.1
                            manmac1
                            @glasfaser
                            ja, mach ich.
                            Hast du einen Tip für eine gute Anleitung?
                            Such grad nach dem richtigen Debian image für meine vm ;)
                            • M manmac1
                              @glasfaser
                              ja, mach ich.
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Hast du einen Tip
                              Auf Debian 12 Bookworm gehen
                                @manmac1 und dem root kein Passwort geben
                                • M manmac1
                                  @glasfaser
                                  ja, mach ich.
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @manmac1
                                  Ich habe nochmal in Ruhe deine Angaben durchgelesen :
                                  Ich habe gerade ein Großes ?
                                  Im Eröffnungs Thread :
                                  iobroker@iobroker:/opt/iobroker$ nodejs -v && node -v && npm -v
                                  v18.17.1
                                  v18.17.1
                                  9.6.7
                                  in der Ausgabe von iob diag
                                  /usr/bin/npm 9.5.1
                                  /usr/bin/npx 9.5.1
                                  wie geht das denn !?
                                    @manmac1
                                    v18.17.1
                                    v18.17.1
                                    9.6.7
                                    /usr/bin/npm 9.5.1
                                    /usr/bin/npx 9.5.1
                                    manmac1
                                    @glasfaser
                                    kommt wahrscheinlich daher, dass ich zwischendurch auf einen früheren Snapshot von heute zurücksteigen musste - sorry für die Verwirrung
                                    GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                                    • M manmac1
                                      @glasfaser
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @manmac1
                                      NUR zur INFO !
                                      OK ... das ist natürlich Käse :(
                                      Bitte ... wenn du etwas veränderst , hier immer alles mitteilen .
                                      bzw .
                                      Wie sollten wir hier helfen , wenn du zwischenzeitlich etwas anderes machst , was wir nicht wissen !?
                                      Deshalb lese bitte auch das genau durch :
                                      • M manmac1
                                        @glasfaser
                                        @manmac1
                                        Dann räum zunächst mal die Quellen auf.
                                        Schmeiß den Eintrag zu grafana/stretch raus.
                                        Dann die Kiste auf Stand bringen, inkl. nodejs.
                                        Solange openzwave nicht sauber kompiliert geht auch nichts mit anderen Adaptern. Warum es das nicht tut kann ich dir aber nicht sagen.
                                        Vielleicht mal den cache löschen und/oder den Adapter dazu rauswerfen.
