  5. [gelöst] Lampe nach Zeit ein /ausschalten
93 Beiträge 6 Kommentatoren 6.2k Aufrufe 5 Beobachtet
  • DJMarc75D DJMarc75
    @alero und jetzt bitte noch auf den Bleistift bei jedem DP klicken und die Objektdaten hier in Codetags posten.
    Alero
    schrieb am zuletzt editiert von Alero
    @djmarc75
    Fenstergriff
      "type": "state",
      "common": {
        "def": "CLOSED",
        "type": "number",
        "read": true,
        "write": false,
        "min": 0,
        "max": 2,
        "states": {
          "0": "CLOSED",
          "1": "TILTED",
          "2": "OPEN"
        "role": "state",
        "name": "RHS_Wohnzimmer:1.STATE"
      "native": {
        "MIN": "CLOSED",
        "OPERATIONS": 5,
        "MAX": "OPEN",
        "FLAGS": 1,
        "ID ": "STATE",
        "TYPE": "ENUM",
        "DEFAULT": "CLOSED",
        "VALUE_LIST": [
          "CLOSED",
          "TILTED",
          "OPEN"
        "CONTROL": "RHS.STATE",
        "ID": "STATE"
      "from": "system.adapter.hm-rega.0",
      "user": "system.user.admin",
      "ts": 1606565663365,
      "_id": "hm-rpc.1.0007DA4989ADED.1.STATE",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
    Fensterkontakt
      "type": "state",
      "common": {
        "def": 0,
        "type": "number",
        "read": true,
        "write": false,
        "min": 0,
        "max": 1,
        "states": {
          "0": "CLOSED",
          "1": "OPEN"
        "unit": "\"\"",
        "role": "value.window",
        "name": "TFK_Terrassentuer:1.STATE"
      "native": {
        "MIN": "CLOSED",
        "UNIT": "\"\"",
        "OPERATIONS": 5,
        "MAX": "OPEN",
        "FLAGS": 1,
        "ID": "STATE",
        "TAB_ORDER": 0,
        "TYPE": "ENUM",
        "VALUE_LIST": [
          "CLOSED",
          "OPEN"
        "CONTROL": "DOOR_SENSOR.STATE"
      "ts": 1683371744664,
      "_id": "hm-rpc.1.0000D8A99E5B80.1.STATE",
      "acl": {
        "object": 1636,
        "state": 1636,
    Schalter licht
      "type": "state",
      "common": {
        "def": false,
        "type": "boolean",
        "read": true,
        "write": true,
        "role": "switch",
        "name": "FS_Garage_Gartenlicht_1_bis_4:1.STATE"
      "native": {
        "CONTROL": "SWITCH.STATE",
        "DEFAULT": false,
        "FLAGS": 1,
        "ID": "STATE",
        "MAX": true,
        "MIN": false,
        "OPERATIONS": 7,
        "TAB_ORDER": 0,
        "TYPE": "BOOL",
        "UNIT": ""
      "ts": 1561403105982,
      "_id": "hm-rpc.0.IEQ0023606.1.STATE",
      "acl": {
        "object": 1636,
        "state": 1636,
    HomoranH DJMarc75D 2 Antworten Letzte Antwort
    • A Alero
      @djmarc75
      Fenstergriff
        "type": "state",
        "common": {
          "def": "CLOSED",
          "type": "number",
          "read": true,
          "write": false,
          "min": 0,
          "max": 2,
          "states": {
            "0": "CLOSED",
            "1": "TILTED",
            "2": "OPEN"
          "role": "state",
        "native": {
          "MIN": "CLOSED",
          "OPERATIONS": 5,
          "MAX": "OPEN",
          "FLAGS": 1,
          "ID ": "STATE",
          "TYPE": "ENUM",
          "VALUE_LIST": [
            "CLOSED",
            "TILTED",
            "OPEN"
          "ID": "STATE"
        "acl": {
          "object": 1636,
          "state": 1636,
      Fensterkontakt
        "type": "state",
        "common": {
          "def": 0,
          "type": "number",
          "read": true,
          "write": false,
          "min": 0,
          "max": 1,
          "states": {
            "0": "CLOSED",
            "1": "OPEN"
          "unit": "\"\"",
        "native": {
          "MIN": "CLOSED",
          "UNIT": "\"\"",
          "OPERATIONS": 5,
          "MAX": "OPEN",
          "FLAGS": 1,
          "ID": "STATE",
          "TAB_ORDER": 0,
          "TYPE": "ENUM",
          "VALUE_LIST": [
            "CLOSED",
            "OPEN"
        "acl": {
          "object": 1636,
          "state": 1636,
      Schalter licht
        "type": "state",
        "common": {
          "def": false,
          "type": "boolean",
          "read": true,
          "write": true,
          "role": "switch",
        "native": {
          "DEFAULT": false,
          "FLAGS": 1,
          "ID": "STATE",
          "MAX": true,
          "MIN": false,
          "OPERATIONS": 7,
          "TAB_ORDER": 0,
          "TYPE": "BOOL",
          "UNIT": ""
        "acl": {
          "object": 1636,
          "state": 1636,
      @alero sagte in Lampe nach Zeit ein /ausschalten:
      Fenstergriff
      ist der channel, nicht der state!
      Fensterkontakt
      ist wie erwartet Werteliste mit 0 und 1, weder bool, noch text
      Schalter licht
      ist bool
      • A Alero
        @djmarc75
        Fenstergriff
          "type": "state",
          "common": {
            "def": "CLOSED",
            "type": "number",
            "read": true,
            "write": false,
            "min": 0,
            "max": 2,
            "states": {
              "0": "CLOSED",
              "1": "TILTED",
              "2": "OPEN"
            "role": "state",
          "native": {
            "MIN": "CLOSED",
            "OPERATIONS": 5,
            "MAX": "OPEN",
            "FLAGS": 1,
            "ID ": "STATE",
            "TYPE": "ENUM",
            "VALUE_LIST": [
              "CLOSED",
              "TILTED",
              "OPEN"
            "ID": "STATE"
          "acl": {
            "object": 1636,
            "state": 1636,
        Fensterkontakt
          "type": "state",
          "common": {
            "def": 0,
            "type": "number",
            "read": true,
            "write": false,
            "min": 0,
            "max": 1,
            "states": {
              "0": "CLOSED",
              "1": "OPEN"
            "unit": "\"\"",
          "native": {
            "MIN": "CLOSED",
            "UNIT": "\"\"",
            "OPERATIONS": 5,
            "MAX": "OPEN",
            "FLAGS": 1,
            "ID": "STATE",
            "TAB_ORDER": 0,
            "TYPE": "ENUM",
            "VALUE_LIST": [
              "CLOSED",
              "OPEN"
          "acl": {
            "object": 1636,
            "state": 1636,
        Schalter licht
          "type": "state",
          "common": {
            "def": false,
            "type": "boolean",
            "read": true,
            "write": true,
            "role": "switch",
          "native": {
            "DEFAULT": false,
            "FLAGS": 1,
            "ID": "STATE",
            "MAX": true,
            "MIN": false,
            "OPERATIONS": 7,
            "TAB_ORDER": 0,
            "TYPE": "BOOL",
            "UNIT": ""
          "acl": {
            "object": 1636,
            "state": 1636,
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        @alero Dann eben so:
        Lehrling seit 1975 !!!
        A NewpicselN 2 Antworten Letzte Antwort
          Alero
          @djmarc75
          hi,
          vielen dank, ich werde es ausprobieren und bescheid geben.
          Vielen vielen Dank an euch alle.
            Fenstergriff
            Fensterkontakt
            Schalter licht
            ist bool
            CodierknechtC Offline
            Codierknecht
            @homoran sagte in Lampe nach Zeit ein /ausschalten:
            HmIP|ZigBee|Tasmota|Unifi
            Zabbix Certified Specialist
            DJMarc75D HomoranH 2 Antworten Letzte Antwort
            • CodierknechtC Codierknecht
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              @codierknecht er hat es editiert und steht nun korrekt drin ;)
                @codierknecht sagte in Lampe nach Zeit ein /ausschalten:
                enäää
                nachträglich editiert ohne Kennzeichnung 😡
                Strafmaß wird später bekannt gegeben 😂
                  enäää
                  crunchipC Offline
                  crunchipC Offline
                  @homoran is der Vorteil wenn man nachgucken kann😜
                    @djmarc75 sagte in Lampe nach Zeit ein /ausschalten:
                    @Alero
                    und genau deswegen müssen Edits gekennzeichnet werden, weil sonst die folgenden Posts sinnentstellt werden
                      @Alero
                      Alero
                      hi,
                      habe jetzt mal das script gestestet.
                      Die Lampe geht an aber leider nicht wieder aus nach 3 min.
                      • A Alero
                        hi,
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        @alero
                        Verschiebe das obere "stop ausschalten" unter Deinen gelben KommentarBaustein.
                          @alero
                          Alero
                          @djmarc75
                          danke
                          werde es testen
                          • A Alero
                            @djmarc75
                            danke
                            werde es testen
                            Alero
                            Leider funzt es immer noch nicht
                            • A Alero
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              Blockly zeigen bitte
                                Alero
                                @djmarc75
                                HI,
                                hier das script. Das licht geht zwar an aber nicht wieder aus.
                                • A Alero
                                  @djmarc75
                                  HI,
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  @alero kann es sein dass der BWM ständig eine Bewegung registriert ?
                                  Bau mal ein Debug ganz oben ein und beobachte das LOG
                                    Alero
                                    @djmarc75
                                    • A Alero
                                      @djmarc75
                                      @alero was willst du damit zeigen?
                                      • A Alero
                                        @djmarc75
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        @alero stell mal von debug auf error oder warn um
                                          Alero
                                          @djmarc75
                                          hi, habe ich . zusätzlich habe ich noch im iobroker im objekt nachgeschaut. er steht die ganze zeit auf false
                                          Bei Error kommt auch nix.
                                          DJMarc75D CodierknechtC 2 Antworten Letzte Antwort
