  5. [gelöst] Lampe nach Zeit ein /ausschalten
93 Beiträge 6 Kommentatoren 6.2k Aufrufe 5 Beobachtet
  • A Alero
    Licht Terrasse
    Fensterkontakt
    Fenstergriffkontakt
    CodierknechtC Offline
    Codierknecht
    @alero
    Mit "Objektdaten" ist sowas gemeint:
      "common": {
        "name": "SwitchState",
        "desc": "Manuell erzeugt",
        "role": "state",
        "type": "boolean",
        "read": true,
        "write": true,
        "def": false
      "type": "state",
      "native": {},
      "_id": "0_userdata.0.Test.test_bool",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
      "user": "system.user.admin",
      "ts": 1679403446220
    HmIP|ZigBee|Tasmota|Unifi
    Zabbix Certified Specialist
    • A Alero
      Licht Terrasse
      Fensterkontakt
      Fenstergriffkontakt
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @alero und jetzt bitte noch auf den Bleistift bei jedem DP klicken und die Objektdaten hier in Codetags posten.
      Lehrling seit 1975 !!!
      • DJMarc75D DJMarc75
        Alero
        schrieb am zuletzt editiert von Alero
        @djmarc75
        Fenstergriff
          "type": "state",
          "common": {
            "def": "CLOSED",
            "type": "number",
            "read": true,
            "write": false,
            "min": 0,
            "max": 2,
            "states": {
              "0": "CLOSED",
              "1": "TILTED",
              "2": "OPEN"
            "role": "state",
            "name": "RHS_Wohnzimmer:1.STATE"
          "native": {
            "MIN": "CLOSED",
            "OPERATIONS": 5,
            "MAX": "OPEN",
            "FLAGS": 1,
            "ID ": "STATE",
            "TYPE": "ENUM",
            "DEFAULT": "CLOSED",
            "VALUE_LIST": [
              "CLOSED",
              "TILTED",
              "OPEN"
            "CONTROL": "RHS.STATE",
            "ID": "STATE"
          "from": "system.adapter.hm-rega.0",
          "ts": 1606565663365,
          "_id": "hm-rpc.1.0007DA4989ADED.1.STATE",
          "acl": {
            "object": 1636,
            "state": 1636,
        Fensterkontakt
          "type": "state",
          "common": {
            "def": 0,
            "type": "number",
            "read": true,
            "write": false,
            "min": 0,
            "max": 1,
            "states": {
              "0": "CLOSED",
              "1": "OPEN"
            "unit": "\"\"",
            "role": "value.window",
            "name": "TFK_Terrassentuer:1.STATE"
          "native": {
            "MIN": "CLOSED",
            "UNIT": "\"\"",
            "OPERATIONS": 5,
            "MAX": "OPEN",
            "FLAGS": 1,
            "ID": "STATE",
            "TAB_ORDER": 0,
            "TYPE": "ENUM",
            "VALUE_LIST": [
              "CLOSED",
              "OPEN"
            "CONTROL": "DOOR_SENSOR.STATE"
          "ts": 1683371744664,
          "_id": "hm-rpc.1.0000D8A99E5B80.1.STATE",
          "acl": {
            "object": 1636,
            "state": 1636,
        Schalter licht
          "type": "state",
          "common": {
            "def": false,
            "type": "boolean",
            "read": true,
            "write": true,
            "role": "switch",
            "name": "FS_Garage_Gartenlicht_1_bis_4:1.STATE"
          "native": {
            "CONTROL": "SWITCH.STATE",
            "DEFAULT": false,
            "FLAGS": 1,
            "ID": "STATE",
            "MAX": true,
            "MIN": false,
            "OPERATIONS": 7,
            "TAB_ORDER": 0,
            "TYPE": "BOOL",
            "UNIT": ""
          "ts": 1561403105982,
          "_id": "hm-rpc.0.IEQ0023606.1.STATE",
          "acl": {
            "object": 1636,
            "state": 1636,
        HomoranH DJMarc75D 2 Antworten Letzte Antwort
        • A Alero
          @djmarc75
          Fenstergriff
            "type": "state",
            "common": {
              "def": "CLOSED",
              "type": "number",
              "read": true,
              "write": false,
              "min": 0,
              "max": 2,
              "states": {
                "0": "CLOSED",
                "1": "TILTED",
                "2": "OPEN"
              "role": "state",
            "native": {
              "MIN": "CLOSED",
              "OPERATIONS": 5,
              "MAX": "OPEN",
              "FLAGS": 1,
              "ID ": "STATE",
              "TYPE": "ENUM",
              "VALUE_LIST": [
                "CLOSED",
                "TILTED",
                "OPEN"
              "ID": "STATE"
            "acl": {
              "object": 1636,
              "state": 1636,
          Fensterkontakt
            "type": "state",
            "common": {
              "def": 0,
              "type": "number",
              "read": true,
              "write": false,
              "min": 0,
              "max": 1,
              "states": {
                "0": "CLOSED",
                "1": "OPEN"
              "unit": "\"\"",
            "native": {
              "MIN": "CLOSED",
              "UNIT": "\"\"",
              "OPERATIONS": 5,
              "MAX": "OPEN",
              "FLAGS": 1,
              "ID": "STATE",
              "TAB_ORDER": 0,
              "TYPE": "ENUM",
              "VALUE_LIST": [
                "CLOSED",
                "OPEN"
            "acl": {
              "object": 1636,
              "state": 1636,
          Schalter licht
            "type": "state",
            "common": {
              "def": false,
              "type": "boolean",
              "read": true,
              "write": true,
              "role": "switch",
            "native": {
              "DEFAULT": false,
              "FLAGS": 1,
              "ID": "STATE",
              "MAX": true,
              "MIN": false,
              "OPERATIONS": 7,
              "TAB_ORDER": 0,
              "TYPE": "BOOL",
              "UNIT": ""
            "acl": {
              "object": 1636,
              "state": 1636,
          @alero sagte in Lampe nach Zeit ein /ausschalten:
          Fenstergriff
          ist der channel, nicht der state!
          Fensterkontakt
          ist wie erwartet Werteliste mit 0 und 1, weder bool, noch text
          Schalter licht
          ist bool
          • A Alero
            @djmarc75
            Fenstergriff
              "type": "state",
              "common": {
                "def": "CLOSED",
                "type": "number",
                "read": true,
                "write": false,
                "min": 0,
                "max": 2,
                "states": {
                  "0": "CLOSED",
                  "1": "TILTED",
                  "2": "OPEN"
                "role": "state",
              "native": {
                "MIN": "CLOSED",
                "OPERATIONS": 5,
                "MAX": "OPEN",
                "FLAGS": 1,
                "ID ": "STATE",
                "TYPE": "ENUM",
                "VALUE_LIST": [
                  "CLOSED",
                  "TILTED",
                  "OPEN"
                "ID": "STATE"
              "acl": {
                "object": 1636,
                "state": 1636,
            Fensterkontakt
              "type": "state",
              "common": {
                "def": 0,
                "type": "number",
                "read": true,
                "write": false,
                "min": 0,
                "max": 1,
                "states": {
                  "0": "CLOSED",
                  "1": "OPEN"
                "unit": "\"\"",
              "native": {
                "MIN": "CLOSED",
                "UNIT": "\"\"",
                "OPERATIONS": 5,
                "MAX": "OPEN",
                "FLAGS": 1,
                "ID": "STATE",
                "TAB_ORDER": 0,
                "TYPE": "ENUM",
                "VALUE_LIST": [
                  "CLOSED",
                  "OPEN"
              "acl": {
                "object": 1636,
                "state": 1636,
            Schalter licht
              "type": "state",
              "common": {
                "def": false,
                "type": "boolean",
                "read": true,
                "write": true,
                "role": "switch",
              "native": {
                "DEFAULT": false,
                "FLAGS": 1,
                "ID": "STATE",
                "MAX": true,
                "MIN": false,
                "OPERATIONS": 7,
                "TAB_ORDER": 0,
                "TYPE": "BOOL",
                "UNIT": ""
              "acl": {
                "object": 1636,
                "state": 1636,
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @alero Dann eben so:
            A NewpicselN 2 Antworten Letzte Antwort
              Alero
              @djmarc75
              hi,
              vielen dank, ich werde es ausprobieren und bescheid geben.
              Vielen vielen Dank an euch alle.
                Fenstergriff
                Fensterkontakt
                Schalter licht
                ist bool
                Codierknecht
                @homoran sagte in Lampe nach Zeit ein /ausschalten:
                DJMarc75D HomoranH 2 Antworten Letzte Antwort
                • CodierknechtC Codierknecht
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  @codierknecht er hat es editiert und steht nun korrekt drin ;)
                    @codierknecht sagte in Lampe nach Zeit ein /ausschalten:
                    enäää
                    nachträglich editiert ohne Kennzeichnung 😡
                    Strafmaß wird später bekannt gegeben 😂
                      enäää
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @homoran is der Vorteil wenn man nachgucken kann😜
                        @djmarc75 sagte in Lampe nach Zeit ein /ausschalten:
                        @Alero
                        und genau deswegen müssen Edits gekennzeichnet werden, weil sonst die folgenden Posts sinnentstellt werden
                          @Alero
                          Alero
                          hi,
                          habe jetzt mal das script gestestet.
                          Die Lampe geht an aber leider nicht wieder aus nach 3 min.
                          • A Alero
                            hi,
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            @alero
                            Verschiebe das obere "stop ausschalten" unter Deinen gelben KommentarBaustein.
                              @alero
                              Alero
                              @djmarc75
                              danke
                              werde es testen
                              • A Alero
                                @djmarc75
                                danke
                                werde es testen
                                Alero
                                Leider funzt es immer noch nicht
                                • A Alero
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  Blockly zeigen bitte
                                    Alero
                                    @djmarc75
                                    HI,
                                    hier das script. Das licht geht zwar an aber nicht wieder aus.
                                    • A Alero
                                      @djmarc75
                                      HI,
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      @alero kann es sein dass der BWM ständig eine Bewegung registriert ?
                                      Bau mal ein Debug ganz oben ein und beobachte das LOG
                                        Alero
                                        @djmarc75
                                        • A Alero
                                          @djmarc75
                                          @alero was willst du damit zeigen?
